[Mapbender-commits] r4904 - trunk/mapbender/http/javascripts
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Tue Nov 3 05:05:45 EST 2009
Author: christoph
Date: 2009-11-03 05:05:45 -0500 (Tue, 03 Nov 2009)
New Revision: 4904
   trunk/mapbender/http/javascripts/mod_sandclock.js
Modified: trunk/mapbender/http/javascripts/mod_sandclock.js
--- trunk/mapbender/http/javascripts/mod_sandclock.js	2009-11-03 10:04:45 UTC (rev 4903)
+++ trunk/mapbender/http/javascripts/mod_sandclock.js	2009-11-03 10:05:45 UTC (rev 4904)
@@ -17,6 +17,10 @@
  * > var_value, context, var_type) VALUES ('<gui_id>', 'sandclock',
  * > 'mod_sandclock_image', '../img/sandclock.gif',
  * > 'define a sandclock-image', 'var');
+ * > INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name,
+ * > var_value, context, var_type) VALUES('<gui_id>', 'sandclock',
+ * > 'blockElement', '0', '' ,'var');
  * Help:
  * http://www.mapbender.org/Sandclock
@@ -39,19 +43,16 @@
 	// check if target is set correctly
-	if (!options.target) {
-		new Mb_Exception(this.id + "requires a target.");
-		return;
+	for (var i in options.target) {
+		if (!Mapbender.modules[options.target[i]]) {
+			new Mb_exception(
+				"Target " + options.target[i] + " not found by " + options.id
-	if (!Mapbender.modules[options.target]) {
-		new Mb_exception("Target " + options.target + " not found by " + this.id)
-	var map;
-	// element vars
+	// sandclock image
 	if (!options.mod_sandclock_image) {
 		options.mod_sandclock_image = "../img/sandclock.gif";
@@ -60,16 +61,30 @@
 	var mod_sandclock_img = new Image();
 	mod_sandclock_img.src = options.mod_sandclock_image;
+	// block the html element with a css shadow
+	if (typeof options.blockElement === "undefined") {
+		options.blockElement = 0;
-	// constructor
+	// if target objects are maps, bind sandclock to its repaint event
-	eventAfterMapRequest.register(function (obj) {
-		that.show(obj.myMapId);
+		(function () {
+			var nodeId = options.target[i];
+			if (typeof Mapbender.modules[nodeId].afterMapRequest === "object") {
+				Mapbender.modules[nodeId].afterMapRequest.register(function (obj) {
+					that.show(nodeId, {
+						mapId: obj.myMapId,
+						blockElement: options.blockElement
-	var isInitialised = false;
 	var aktiv;
@@ -77,27 +92,33 @@
 	 * Displays the sandclock
-	this.show = function (mapId) {
-		var temp = "<img src='"+mod_sandclock_img.src+"'>";
-		if (!isInitialised) {
-			map = Mapbender.modules[options.target];
-			var map_el = map.getDomElement();
-			if(!map_el.ownerDocument.getElementById(map.elementName+"_sandclock")){
-				//create Box Elements
-				el_top = map_el.ownerDocument.createElement("div");
-				el_top.style.position = "absolute";
-				el_top.style.top = "0px";
-				el_top.style.left = "0px";
-				el_top.style.overflow = "hidden";
-				el_top.style.zIndex = "1000";
-				el_top.style.visibility = "visible";
-				el_top.id = map.elementName+"_sandclock";
-				map_el.appendChild(el_top);
-			isInitialised = true;
+	this.show = function (nodeId, arg) {
+		var mapId = arg.mapId;
+		var $clock = $("#" + nodeId + "_sandclock");
+		if ($clock.size() === 0) {
+			//create Box Elements
+				"<div id='" + nodeId + "_sandclock'>"
+			).css({
+				position: "absolute",
+				top: "0px",
+				left: "0px",
+				width: "100%",
+				height: "100%",
+				overflow: "hidden",
+				zIndex: 1000,
+				visibility: "visible"
+			}).appendTo($("#" + nodeId));
-		writeTag(map.frameName, map.elementName+"_sandclock", temp);
-		mb_arrangeElement("", options.target+"_sandclock", (map.width/2 - 16), (map.height/2 - 16));
+		$clock.html(
+			"<img style='position:absolute; top:50%; left:50%' src='" +
+			mod_sandclock_img.src+"'></div>"
+		if (arg.blockElement) {
+			$clock.addClass("ui-widget-overlay");
 		// if mapId is not given, the sandclock has to be turned off manually
@@ -106,25 +127,28 @@
 		if (typeof mapId !== "undefined") {
 			aktiv = setTimeout(function () {
-				that.show(mapId);
+					mapId: mapId,
+					blockElement: arg.blockElement
 			},10);
 			var mapIdArray = mapId.split(",");
 			var complete = true;
-			var mapId;
+			var map = Mapbender.modules[nodeId];
 			for (var i = 0; i < mapIdArray.length && complete; i++) {
-				mapId = mapIdArray[i];
+				var currentMapId = mapIdArray[i];
 				var myDoc = map.getDomElement().ownerDocument;
-				if(myDoc.getElementById(mapId) &&
-					!myDoc.getElementById(mapId).complete) {
+				if(myDoc.getElementById(currentMapId) &&
+					!myDoc.getElementById(currentMapId).complete) {
 					complete = false;
 			if (complete) {
 				clearTimeout(aktiv);
-				that.hide(map);
+				that.hide(nodeId, map);
@@ -132,9 +156,11 @@
 	 * Hides the sandclock
-	this.hide = function () {
-		writeTag(map.frameName, map.elementName+"_sandclock", "");
+	this.hide = function (nodeId) {
+		$("#" + nodeId + "_sandclock").removeClass("ui-widget-overlay").empty();
-$.extend(Mapbender.modules[options.id], new Sandclock(options));
+Mapbender.events.init.register(function () {
+	$.extend(Mapbender.modules[options.id], new Sandclock(options));
More information about the Mapbender_commits mailing list
