[Mapbender-commits] r4928 -
trunk/mapbender/resources/db/pgsql/UTF-8/update
svn_mapbender at osgeo.org
Thu Nov 5 07:29:32 EST 2009
Author: kmq
Date: 2009-11-05 07:29:30 -0500 (Thu, 05 Nov 2009)
New Revision: 4928
trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6_to_2.7rc1_pgsql_UTF-8.sql
changin wmc_public type from BOOLEAN to INTEGER
Modified: trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6_to_2.7rc1_pgsql_UTF-8.sql
--- trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6_to_2.7rc1_pgsql_UTF-8.sql 2009-11-04 15:32:08 UTC (rev 4927)
+++ trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6_to_2.7rc1_pgsql_UTF-8.sql 2009-11-05 12:29:30 UTC (rev 4928)
@@ -514,3 +514,7 @@
-- jQuery CSS in Body
INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui1', 'body', 'jquery_UI', '../extensions/jquery-ui-1.7.2.custom/css/ui-lightness/jquery-ui-1.7.2.custom.css', '' ,'file/css');
INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui1', 'body', 'jquery_datatables', '../extensions/dataTables-1.5/media/css/demo_table_jui.css', '' ,'file/css');
+ALTER TABLE mb_user_wmc ADD COLUMN
+wmc_public INTEGER NOT NULL DEFAULT 0;
More information about the Mapbender_commits
