[Mapbender-commits] r4930 - trunk/mapbender/resources/db/pgsql/UTF-8/update
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Thu Nov 5 07:53:35 EST 2009
Author: christoph
Date: 2009-11-05 07:53:35 -0500 (Thu, 05 Nov 2009)
New Revision: 4930
   trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6_to_2.7rc1_pgsql_UTF-8.sql
Modified: trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6_to_2.7rc1_pgsql_UTF-8.sql
--- trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6_to_2.7rc1_pgsql_UTF-8.sql	2009-11-05 12:52:21 UTC (rev 4929)
+++ trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6_to_2.7rc1_pgsql_UTF-8.sql	2009-11-05 12:53:35 UTC (rev 4930)
@@ -518,4 +518,5 @@
 ALTER TABLE mb_user_wmc ADD COLUMN
 wmc_public INTEGER NOT NULL DEFAULT 0;
+-- loadwmc from session is now a php var. The initial WMC is only created when this is set to 1
 UPDATE gui_element_vars SET var_type = 'php_var' WHERE fkey_e_id = 'loadwmc' AND var_name = 'loadFromSession';
More information about the Mapbender_commits mailing list
