[Mapbender-commits] r4934 - in trunk/mapbender/http: javascripts php
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Thu Nov 5 07:57:36 EST 2009
Author: christoph
Date: 2009-11-05 07:57:36 -0500 (Thu, 05 Nov 2009)
New Revision: 4934
   trunk/mapbender/http/javascripts/map.php
   trunk/mapbender/http/javascripts/mod_admin.php
   trunk/mapbender/http/javascripts/mod_digitize_tab.php
   trunk/mapbender/http/javascripts/mod_wfs_gazetteer_client.php
   trunk/mapbender/http/php/mod_wfs_conf_client.php
correct links to jquery
Modified: trunk/mapbender/http/javascripts/map.php
--- trunk/mapbender/http/javascripts/map.php	2009-11-05 12:56:49 UTC (rev 4933)
+++ trunk/mapbender/http/javascripts/map.php	2009-11-05 12:57:36 UTC (rev 4934)
@@ -75,8 +75,8 @@
 // Load external JavaScript libraries
 $extPath = dirname(__FILE__) . "/../extensions/";
-$extFileArray = array(  "jquery-1.3.2.min.js",
-						"jqjson.js" // ,
+$extFileArray = array(  "jquery-ui-1.7.2.custom/js/jquery-1.3.2.min.js",
+						"jqjson.min.js" // ,
 //						"jquery.form.js"
Modified: trunk/mapbender/http/javascripts/mod_admin.php
--- trunk/mapbender/http/javascripts/mod_admin.php	2009-11-05 12:56:49 UTC (rev 4933)
+++ trunk/mapbender/http/javascripts/mod_admin.php	2009-11-05 12:57:36 UTC (rev 4934)
@@ -4,7 +4,7 @@
 <head>
-<script src="../extensions/jquery-1.3.2.min.js" type="text/javascript"></script>
+<script src="../extensions/jquery-ui-1.7.2.custom/js/jquery-1.3.2.min.js" type="text/javascript"></script>
 <script src="../extensions/jquery-ui-1.7.1.w.o.effects.min.js" type="text/javascript"></script>
 <script src="../extensions/jqjson.js" type="text/javascript"></script>
 <script src="mod_admin.js" type="text/javascript"></script>
Modified: trunk/mapbender/http/javascripts/mod_digitize_tab.php
--- trunk/mapbender/http/javascripts/mod_digitize_tab.php	2009-11-05 12:56:49 UTC (rev 4933)
+++ trunk/mapbender/http/javascripts/mod_digitize_tab.php	2009-11-05 12:57:36 UTC (rev 4934)
@@ -35,7 +35,7 @@
 $digitize_conf_filename = "digitize_default.conf";
 include '../include/dyn_css.php';
-<script type='text/javascript' src='../extensions/jquery-1.3.2.min.js'></script>
+<script type='text/javascript' src='../extensions/jquery-ui-1.7.2.custom/js/jquery-1.3.2.min.js'></script>
 <script type='text/javascript'>
 // Buttons
@@ -1833,7 +1833,7 @@
 		wfsWindow.document.write(headStr);
 	str += "<div id='elementForm'>\n" + elForm + "</div>";
-	str += "<script type='text/javascript' src='../extensions/jquery-1.3.2.min.js'><\/script>";
+	str += "<script type='text/javascript' src='../extensions/jquery-ui-1.7.2.custom/js/jquery-1.3.2.min.js'><\/script>";
 	str += "<script type='text/javascript' src='../extensions/jquery-ui-1.7.1.w.o.effects.min.js'><\/script>";
 	str += "</body></html>";
 	wfsWindow.document.write(str);
Modified: trunk/mapbender/http/javascripts/mod_wfs_gazetteer_client.php
--- trunk/mapbender/http/javascripts/mod_wfs_gazetteer_client.php	2009-11-05 12:56:49 UTC (rev 4933)
+++ trunk/mapbender/http/javascripts/mod_wfs_gazetteer_client.php	2009-11-05 12:57:36 UTC (rev 4934)
@@ -36,7 +36,7 @@
 <script type="text/javascript">
 <?php
 	include '../include/dyn_js.php';
-	include '../extensions/jquery-1.3.2.min.js';
+	include '../extensions/jquery-ui-1.7.2.custom/js/jquery-1.3.2.min.js';
 	include '../include/dyn_php.php';
 	include(dirname(__FILE__) . "/../../conf/" . $wfs_spatial_request_conf_filename);
Modified: trunk/mapbender/http/php/mod_wfs_conf_client.php
--- trunk/mapbender/http/php/mod_wfs_conf_client.php	2009-11-05 12:56:49 UTC (rev 4933)
+++ trunk/mapbender/http/php/mod_wfs_conf_client.php	2009-11-05 12:57:36 UTC (rev 4934)
@@ -78,7 +78,7 @@
 echo "var global_mb_log_js = '".LOG_JS."';";
 echo "var global_mb_log_level = '".LOG_LEVEL."';";
 echo "var global_log_levels = '".LOG_LEVEL_LIST."';";
-require_once "../extensions/jquery-1.3.2.min.js";
+require_once "../extensions/jquery-ui-1.7.2.custom/js/jquery-1.3.2.min.js";
 require_once "../extensions/jquery-ui-1.7.1.w.o.effects.min.js";
 require_once "../extensions/jqjson.js";
 require_once "../../lib/ajax.js";
More information about the Mapbender_commits mailing list
