[Mapbender-commits] r4937 - trunk/mapbender/http/extensions
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Thu Nov 5 08:08:22 EST 2009
Author: christoph
Date: 2009-11-05 08:08:22 -0500 (Thu, 05 Nov 2009)
New Revision: 4937
Added:
   trunk/mapbender/http/extensions/jqjson.min.js
Added: trunk/mapbender/http/extensions/jqjson.min.js
--- trunk/mapbender/http/extensions/jqjson.min.js	                        (rev 0)
+++ trunk/mapbender/http/extensions/jqjson.min.js	2009-11-05 13:08:22 UTC (rev 4937)
@@ -0,0 +1,12 @@
+(function($){var m={'\b':'\\b','\t':'\\t','\n':'\\n','\f':'\\f','\r':'\\r','"':'\\"','\\':'\\\\'},s={'array':function(x){var a=['['],b,f,i,l=x.length,v;for(i=0;i<l;i+=1){v=x[i];f=s[typeof v];if(f){v=f(v);if(typeof v=='string'){if(b){a[a.length]=',';}
+a[a.length]=v;b=true;}}}
+a[a.length]=']';return a.join('');},'boolean':function(x){return String(x);},'null':function(x){return"null";},'number':function(x){return isFinite(x)?String(x):'null';},'object':function(x){if(x){if(x instanceof Array){return s.array(x);}
+var a=['{'],b,f,i,v;for(i in x){v=x[i];f=s[typeof v];if(f){v=f(v);if(typeof v=='string'){if(b){a[a.length]=',';}
+a.push(s.string(i),':',v);b=true;}}}
+a[a.length]='}';return a.join('');}
+return'null';},'string':function(x){if(/["\\\x00-\x1f]/.test(x)){x=x.replace(/([\x00-\x1f\\"])/g,function(a,b){var c=m[b];if(c){return c;}
+c=b.charCodeAt();return'\\u00'+
+Math.floor(c/16).toString(16)+
+(c%16).toString(16);});}
+return'"'+x+'"';}};$.toJSON=function(v){var f=isNaN(v)?s[typeof v]:s['number'];if(f)return f(v);};$.parseJSON=function(v,safe){if(safe===undefined)safe=$.parseJSON.safe;if(safe&&!/^("(\\.|[^"\\\n\r])*?"|[,:{}\[\]0-9.\-+Eaeflnr-u \n\r\t])+?$/.test(v))
+return undefined;return eval('('+v+')');};$.parseJSON.safe=false;})(jQuery);
\ No newline at end of file
Property changes on: trunk/mapbender/http/extensions/jqjson.min.js
___________________________________________________________________
Added: svn:mergeinfo
More information about the Mapbender_commits mailing list
