[Mapbender-commits] r4940 - trunk/mapbender/http/extensions
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Thu Nov 5 08:09:40 EST 2009
Author: christoph
Date: 2009-11-05 08:09:40 -0500 (Thu, 05 Nov 2009)
New Revision: 4940
Removed:
   trunk/mapbender/http/extensions/FirePHP.class.php
   trunk/mapbender/http/extensions/fb.php
Deleted: trunk/mapbender/http/extensions/FirePHP.class.php
--- trunk/mapbender/http/extensions/FirePHP.class.php	2009-11-05 13:09:11 UTC (rev 4939)
+++ trunk/mapbender/http/extensions/FirePHP.class.php	2009-11-05 13:09:40 UTC (rev 4940)
@@ -1,1529 +0,0 @@
-<?php
- * *** BEGIN LICENSE BLOCK *****
- * This file is part of FirePHP (http://www.firephp.org/).
- * Software License Agreement (New BSD License)
- * Copyright (c) 2006-2009, Christoph Dorn
- * All rights reserved.
- * Redistribution and use in source and binary forms, with or without modification,
- * are permitted provided that the following conditions are met:
- *     * Redistributions of source code must retain the above copyright notice,
- *       this list of conditions and the following disclaimer.
- *     * Redistributions in binary form must reproduce the above copyright notice,
- *       this list of conditions and the following disclaimer in the documentation
- *       and/or other materials provided with the distribution.
- *     * Neither the name of Christoph Dorn nor the names of its
- *       contributors may be used to endorse or promote products derived from this
- *       software without specific prior written permission.
- * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND
- * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
- * WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
- * DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR
- * ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
- * (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
- * LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON
- * ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
- * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
- * SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
- * ***** END LICENSE BLOCK *****
- * @copyright   Copyright (C) 2007-2009 Christoph Dorn
- * @author      Christoph Dorn <christoph at christophdorn.com>
- * @license     http://www.opensource.org/licenses/bsd-license.php
- * @package     FirePHP
- * Sends the given data to the FirePHP Firefox Extension.
- * The data can be displayed in the Firebug Console or in the
- * "Server" request tab.
- * For more information see: http://www.firephp.org/
-class FirePHP {
-   * FirePHP version
-   * @var string
-  const VERSION = '0.3';
-   * Firebug LOG level
-   * Logs a message to firebug console.
-   * @var string
-  const LOG = 'LOG';
-   * Firebug INFO level
-   * Logs a message to firebug console and displays an info icon before the message.
-   * @var string
-  const INFO = 'INFO';
-   * Firebug WARN level
-   * Logs a message to firebug console, displays an warning icon before the message and colors the line turquoise.
-   * @var string
-  const WARN = 'WARN';
-   * Firebug ERROR level
-   * Logs a message to firebug console, displays an error icon before the message and colors the line yellow. Also increments the firebug error count.
-   * @var string
-  const ERROR = 'ERROR';
-   * Dumps a variable to firebug's server panel
-   * @var string
-  const DUMP = 'DUMP';
-   * Displays a stack trace in firebug console
-   * @var string
-  const TRACE = 'TRACE';
-   * Displays an exception in firebug console
-   * Increments the firebug error count.
-   * @var string
-  const EXCEPTION = 'EXCEPTION';
-   * Displays an table in firebug console
-   * @var string
-  const TABLE = 'TABLE';
-   * Starts a group in firebug console
-   * @var string
-  const GROUP_START = 'GROUP_START';
-   * Ends a group in firebug console
-   * @var string
-  const GROUP_END = 'GROUP_END';
-   * Singleton instance of FirePHP
-   * @var FirePHP
-  protected static $instance = null;
-   * Flag whether we are logging from within the exception handler
-   * @var boolean
-  protected $inExceptionHandler = false;
-   * Flag whether to throw PHP errors that have been converted to ErrorExceptions
-   * @var boolean
-  protected $throwErrorExceptions = true;
-   * Flag whether to convert PHP assertion errors to Exceptions
-   * @var boolean
-  protected $convertAssertionErrorsToExceptions = true;
-   * Flag whether to throw PHP assertion errors that have been converted to Exceptions
-   * @var boolean
-  protected $throwAssertionExceptions = false;
-   * Wildfire protocol message index
-   * @var int
-  protected $messageIndex = 1;
-   * Options for the library
-   * @var array
-  protected $options = array('maxObjectDepth' => 10,
-                             'maxArrayDepth' => 20,
-                             'useNativeJsonEncode' => true,
-                             'includeLineNumbers' => true);
-   * Filters used to exclude object members when encoding
-   * @var array
-  protected $objectFilters = array();
-   * A stack of objects used to detect recursion during object encoding
-   * @var object
-  protected $objectStack = array();
-   * Flag to enable/disable logging
-   * @var boolean
-  protected $enabled = true;
-   * The object constructor
-  function __construct() {
-   * When the object gets serialized only include specific object members.
-   * @return array
-  public function __sleep() {
-    return array('options','objectFilters','enabled');
-   * Gets singleton instance of FirePHP
-   * @param boolean $AutoCreate
-   * @return FirePHP
-  public static function getInstance($AutoCreate=false) {
-    if($AutoCreate===true && !self::$instance) {
-      self::init();
-    return self::$instance;
-   * Creates FirePHP object and stores it for singleton access
-   * @return FirePHP
-  public static function init() {
-    return self::$instance = new self();
-   * Enable and disable logging to Firebug
-   * @param boolean $Enabled TRUE to enable, FALSE to disable
-   * @return void
-  public function setEnabled($Enabled) {
-    $this->enabled = $Enabled;
-   * Check if logging is enabled
-   * @return boolean TRUE if enabled
-  public function getEnabled() {
-    return $this->enabled;
-   * Specify a filter to be used when encoding an object
-   * Filters are used to exclude object members.
-   * @param string $Class The class name of the object
-   * @param array $Filter An array of members to exclude
-   * @return void
-  public function setObjectFilter($Class, $Filter) {
-    $this->objectFilters[strtolower($Class)] = $Filter;
-   * Set some options for the library
-   * Options:
-   *  - maxObjectDepth: The maximum depth to traverse objects (default: 10)
-   *  - maxArrayDepth: The maximum depth to traverse arrays (default: 20)
-   *  - useNativeJsonEncode: If true will use json_encode() (default: true)
-   *  - includeLineNumbers: If true will include line numbers and filenames (default: true)
-   * @param array $Options The options to be set
-   * @return void
-  public function setOptions($Options) {
-    $this->options = array_merge($this->options,$Options);
-   * Get options from the library
-   * @return array The currently set options
-  public function getOptions() {
-    return $this->options;
-   * Register FirePHP as your error handler
-   * Will throw exceptions for each php error.
-   * @return mixed Returns a string containing the previously defined error handler (if any)
-  public function registerErrorHandler($throwErrorExceptions=true)
-    //NOTE: The following errors will not be caught by this error handler:
-    //      E_ERROR, E_PARSE, E_CORE_ERROR,
-    //      E_CORE_WARNING, E_COMPILE_ERROR,
-    //      E_COMPILE_WARNING, E_STRICT
-    $this->throwErrorExceptions = $throwErrorExceptions;
-    return set_error_handler(array($this,'errorHandler'));
-   * FirePHP's error handler
-   * Throws exception for each php error that will occur.
-   * @param int $errno
-   * @param string $errstr
-   * @param string $errfile
-   * @param int $errline
-   * @param array $errcontext
-  public function errorHandler($errno, $errstr, $errfile, $errline, $errcontext)
-    // Don't throw exception if error reporting is switched off
-    if (error_reporting() == 0) {
-      return;
-    // Only throw exceptions for errors we are asking for
-    if (error_reporting() & $errno) {
-      $exception = new ErrorException($errstr, 0, $errno, $errfile, $errline);
-      if($this->throwErrorExceptions) {
-        throw $exception;
-      } else {
-        $this->fb($exception);
-   * Register FirePHP as your exception handler
-   * @return mixed Returns the name of the previously defined exception handler,
-   *               or NULL on error.
-   *               If no previous handler was defined, NULL is also returned.
-  public function registerExceptionHandler()
-    return set_exception_handler(array($this,'exceptionHandler'));
-   * FirePHP's exception handler
-   * Logs all exceptions to your firebug console and then stops the script.
-   * @param Exception $Exception
-   * @throws Exception
-  function exceptionHandler($Exception) {
-    $this->inExceptionHandler = true;
-    header('HTTP/1.1 500 Internal Server Error');
-    $this->fb($Exception);
-    $this->inExceptionHandler = false;
-   * Register FirePHP driver as your assert callback
-   * @param boolean $convertAssertionErrorsToExceptions
-   * @param boolean $throwAssertionExceptions
-   * @return mixed Returns the original setting or FALSE on errors
-  public function registerAssertionHandler($convertAssertionErrorsToExceptions=true, $throwAssertionExceptions=false)
-    $this->convertAssertionErrorsToExceptions = $convertAssertionErrorsToExceptions;
-    $this->throwAssertionExceptions = $throwAssertionExceptions;
-    if($throwAssertionExceptions && !$convertAssertionErrorsToExceptions) {
-      throw $this->newException('Cannot throw assertion exceptions as assertion errors are not being converted to exceptions!');
-    return assert_options(ASSERT_CALLBACK, array($this, 'assertionHandler'));
-   * FirePHP's assertion handler
-   * Logs all assertions to your firebug console and then stops the script.
-   * @param string $file File source of assertion
-   * @param int    $line Line source of assertion
-   * @param mixed  $code Assertion code
-  public function assertionHandler($file, $line, $code)
-    if($this->convertAssertionErrorsToExceptions) {
-      $exception = new ErrorException('Assertion Failed - Code[ '.$code.' ]', 0, null, $file, $line);
-      if($this->throwAssertionExceptions) {
-        throw $exception;
-      } else {
-    } else {
-      $this->fb($code, 'Assertion Failed', FirePHP::ERROR, array('File'=>$file,'Line'=>$line));
-   * Set custom processor url for FirePHP
-   * @param string $URL
-  public function setProcessorUrl($URL)
-    $this->setHeader('X-FirePHP-ProcessorURL', $URL);
-   * Set custom renderer url for FirePHP
-  public function setRendererUrl($URL)
-    $this->setHeader('X-FirePHP-RendererURL', $URL);
-   * Start a group for following messages.
-   * Options:
-   *   Collapsed: [true|false]
-   *   Color:     [#RRGGBB|ColorName]
-   * @param string $Name
-   * @param array $Options OPTIONAL Instructions on how to log the group
-   * @return true
-  public function group($Name, $Options=null) {
-    if(!$Name) {
-      throw $this->newException('You must specify a label for the group!');
-    if($Options) {
-      if(!is_array($Options)) {
-        throw $this->newException('Options must be defined as an array!');
-      if(array_key_exists('Collapsed', $Options)) {
-        $Options['Collapsed'] = ($Options['Collapsed'])?'true':'false';
-    return $this->fb(null, $Name, FirePHP::GROUP_START, $Options);
-   * Ends a group you have started before
-   * @return true
-  public function groupEnd() {
-    return $this->fb(null, null, FirePHP::GROUP_END);
-   * Log object with label to firebug console
-   * @see FirePHP::LOG
-   * @param mixes $Object
-   * @param string $Label
-   * @return true
-  public function log($Object, $Label=null) {
-    return $this->fb($Object, $Label, FirePHP::LOG);
-   * @see FirePHP::INFO
-   * @return true
-  public function info($Object, $Label=null) {
-    return $this->fb($Object, $Label, FirePHP::INFO);
-   * @see FirePHP::WARN
-   * @return true
-  public function warn($Object, $Label=null) {
-    return $this->fb($Object, $Label, FirePHP::WARN);
-   * @see FirePHP::ERROR
-   * @return true
-  public function error($Object, $Label=null) {
-    return $this->fb($Object, $Label, FirePHP::ERROR);
-   * Dumps key and variable to firebug server panel
-   * @see FirePHP::DUMP
-   * @param string $Key
-   * @param mixed $Variable
-   * @return true
-  public function dump($Key, $Variable) {
-    return $this->fb($Variable, $Key, FirePHP::DUMP);
-   * Log a trace in the firebug console
-   * @see FirePHP::TRACE
-   * @return true
-  public function trace($Label) {
-    return $this->fb($Label, FirePHP::TRACE);
-   * Log a table in the firebug console
-   * @see FirePHP::TABLE
-   * @param string $Table
-   * @return true
-  public function table($Label, $Table) {
-    return $this->fb($Table, $Label, FirePHP::TABLE);
-   * Check if FirePHP is installed on client
-   * @return boolean
-  public function detectClientExtension() {
-    /* Check if FirePHP is installed on client */
-    if(!@preg_match_all('/\sFirePHP\/([\.|\d]*)\s?/si',$this->getUserAgent(),$m) ||
-       !version_compare($m[1][0],'0.0.6','>=')) {
-      return false;
-    return true;
-   * Log varible to Firebug
-   * @see http://www.firephp.org/Wiki/Reference/Fb
-   * @param mixed $Object The variable to be logged
-   * @return true Return TRUE if message was added to headers, FALSE otherwise
-  public function fb($Object) {
-    if(!$this->enabled) {
-      return false;
-    if (headers_sent($filename, $linenum)) {
-      // If we are logging from within the exception handler we cannot throw another exception
-      if($this->inExceptionHandler) {
-        // Simply echo the error out to the page
-        echo '<div style="border: 2px solid red; font-family: Arial; font-size: 12px; background-color: lightgray; padding: 5px;"><span style="color: red; font-weight: bold;">FirePHP ERROR:</span> Headers already sent in <b>'.$filename.'</b> on line <b>'.$linenum.'</b>. Cannot send log data to FirePHP. You must have Output Buffering enabled via ob_start() or output_buffering ini directive.</div>';
-      } else {
-        throw $this->newException('Headers already sent in '.$filename.' on line '.$linenum.'. Cannot send log data to FirePHP. You must have Output Buffering enabled via ob_start() or output_buffering ini directive.');
-    $Type = null;
-    $Label = null;
-    $Options = array();
-    if(func_num_args()==1) {
-    } else
-    if(func_num_args()==2) {
-      switch(func_get_arg(1)) {
-        case self::LOG:
-        case self::INFO:
-        case self::WARN:
-        case self::ERROR:
-        case self::DUMP:
-        case self::TRACE:
-        case self::EXCEPTION:
-        case self::TABLE:
-        case self::GROUP_START:
-        case self::GROUP_END:
-          $Type = func_get_arg(1);
-          break;
-        default:
-          $Label = func_get_arg(1);
-          break;
-    } else
-    if(func_num_args()==3) {
-      $Type = func_get_arg(2);
-    } else
-    if(func_num_args()==4) {
-      $Options = func_get_arg(3);
-    } else {
-      throw $this->newException('Wrong number of arguments to fb() function!');
-    if(!$this->detectClientExtension()) {
-      return false;
-    $meta = array();
-    $skipFinalObjectEncode = false;
-    if($Object instanceof Exception) {
-      $meta['file'] = $this->_escapeTraceFile($Object->getFile());
-      $meta['line'] = $Object->getLine();
-      $trace = $Object->getTrace();
-      if($Object instanceof ErrorException
-         && isset($trace[0]['function'])
-         && $trace[0]['function']=='errorHandler'
-         && isset($trace[0]['class'])
-         && $trace[0]['class']=='FirePHP') {
-        $severity = false;
-        switch($Object->getSeverity()) {
-          case E_WARNING: $severity = 'E_WARNING'; break;
-          case E_NOTICE: $severity = 'E_NOTICE'; break;
-          case E_USER_ERROR: $severity = 'E_USER_ERROR'; break;
-          case E_USER_WARNING: $severity = 'E_USER_WARNING'; break;
-          case E_USER_NOTICE: $severity = 'E_USER_NOTICE'; break;
-          case E_STRICT: $severity = 'E_STRICT'; break;
-          case E_RECOVERABLE_ERROR: $severity = 'E_RECOVERABLE_ERROR'; break;
-          case E_DEPRECATED: $severity = 'E_DEPRECATED'; break;
-          case E_USER_DEPRECATED: $severity = 'E_USER_DEPRECATED'; break;
-        $Object = array('Class'=>get_class($Object),
-                        'Message'=>$severity.': '.$Object->getMessage(),
-                        'File'=>$this->_escapeTraceFile($Object->getFile()),
-                        'Line'=>$Object->getLine(),
-                        'Type'=>'trigger',
-                        'Trace'=>$this->_escapeTrace(array_splice($trace,2)));
-        $skipFinalObjectEncode = true;
-      } else {
-                        'Message'=>$Object->getMessage(),
-                        'Type'=>'throw',
-                        'Trace'=>$this->_escapeTrace($trace));
-      $Type = self::EXCEPTION;
-    } else
-    if($Type==self::TRACE) {
-      $trace = debug_backtrace();
-      if(!$trace) return false;
-      for( $i=0 ; $i<sizeof($trace) ; $i++ ) {
-        if(isset($trace[$i]['class'])
-           && isset($trace[$i]['file'])
-           && ($trace[$i]['class']=='FirePHP'
-               || $trace[$i]['class']=='FB')
-           && (substr($this->_standardizePath($trace[$i]['file']),-18,18)=='FirePHPCore/fb.php'
-               || substr($this->_standardizePath($trace[$i]['file']),-29,29)=='FirePHPCore/FirePHP.class.php')) {
-          /* Skip - FB::trace(), FB::send(), $firephp->trace(), $firephp->fb() */
-        } else
-           && isset($trace[$i+1]['file'])
-           && $trace[$i]['class']=='FirePHP'
-           && substr($this->_standardizePath($trace[$i+1]['file']),-18,18)=='FirePHPCore/fb.php') {
-          /* Skip fb() */
-        } else
-        if($trace[$i]['function']=='fb'
-           || $trace[$i]['function']=='trace'
-           || $trace[$i]['function']=='send') {
-          $Object = array('Class'=>isset($trace[$i]['class'])?$trace[$i]['class']:'',
-                          'Type'=>isset($trace[$i]['type'])?$trace[$i]['type']:'',
-                          'Function'=>isset($trace[$i]['function'])?$trace[$i]['function']:'',
-                          'Message'=>$trace[$i]['args'][0],
-                          'File'=>isset($trace[$i]['file'])?$this->_escapeTraceFile($trace[$i]['file']):'',
-                          'Line'=>isset($trace[$i]['line'])?$trace[$i]['line']:'',
-                          'Args'=>isset($trace[$i]['args'])?$this->encodeObject($trace[$i]['args']):'',
-                          'Trace'=>$this->_escapeTrace(array_splice($trace,$i+1)));
-          $meta['file'] = isset($trace[$i]['file'])?$this->_escapeTraceFile($trace[$i]['file']):'';
-          $meta['line'] = isset($trace[$i]['line'])?$trace[$i]['line']:'';
-          break;
-    } else
-    if($Type==self::TABLE) {
-      if(isset($Object[0]) && is_string($Object[0])) {
-        $Object[1] = $this->encodeTable($Object[1]);
-      } else {
-        $Object = $this->encodeTable($Object);
-    } else
-    if($Type==self::GROUP_START) {
-      if(!$Label) {
-    } else {
-      if($Type===null) {
-        $Type = self::LOG;
-    if($this->options['includeLineNumbers']) {
-      if(!isset($meta['file']) || !isset($meta['line'])) {
-        for( $i=0 ; $trace && $i<sizeof($trace) ; $i++ ) {
-          } else
-            /* Skip fb() */
-          } else
-          if(isset($trace[$i]['file'])
-             && substr($this->_standardizePath($trace[$i]['file']),-18,18)=='FirePHPCore/fb.php') {
-            /* Skip FB::fb() */
-          } else {
-            break;
-    } else {
-      unset($meta['file']);
-      unset($meta['line']);
-  	$this->setHeader('X-Wf-Protocol-1','http://meta.wildfirehq.org/Protocol/JsonStream/0.2');
-  	$this->setHeader('X-Wf-1-Plugin-1','http://meta.firephp.org/Wildfire/Plugin/FirePHP/Library-FirePHPCore/'.self::VERSION);
-    $structure_index = 1;
-    if($Type==self::DUMP) {
-      $structure_index = 2;
-    	$this->setHeader('X-Wf-1-Structure-2','http://meta.firephp.org/Wildfire/Structure/FirePHP/Dump/0.1');
-    } else {
-    	$this->setHeader('X-Wf-1-Structure-1','http://meta.firephp.org/Wildfire/Structure/FirePHP/FirebugConsole/0.1');
-    	$msg = '{"'.$Label.'":'.$this->jsonEncode($Object, $skipFinalObjectEncode).'}';
-    } else {
-      $msg_meta = $Options;
-      $msg_meta['Type'] = $Type;
-      if($Label!==null) {
-        $msg_meta['Label'] = $Label;
-      if(isset($meta['file']) && !isset($msg_meta['File'])) {
-        $msg_meta['File'] = $meta['file'];
-      if(isset($meta['line']) && !isset($msg_meta['Line'])) {
-        $msg_meta['Line'] = $meta['line'];
-    	$msg = '['.$this->jsonEncode($msg_meta).','.$this->jsonEncode($Object, $skipFinalObjectEncode).']';
-    $parts = explode("\n",chunk_split($msg, 5000, "\n"));
-    for( $i=0 ; $i<count($parts) ; $i++) {
-        $part = $parts[$i];
-        if ($part) {
-            if(count($parts)>2) {
-              // Message needs to be split into multiple parts
-              $this->setHeader('X-Wf-1-'.$structure_index.'-'.'1-'.$this->messageIndex,
-                               (($i==0)?strlen($msg):'')
-                               . '|' . $part . '|'
-                               . (($i<count($parts)-2)?'\\':''));
-            } else {
-                               strlen($part) . '|' . $part . '|');
-            $this->messageIndex++;
-            if ($this->messageIndex > 99999) {
-                throw $this->newException('Maximum number (99,999) of messages reached!');
-  	$this->setHeader('X-Wf-1-Index',$this->messageIndex-1);
-    return true;
-   * Standardizes path for windows systems.
-   * @param string $Path
-   * @return string
-  protected function _standardizePath($Path) {
-    return preg_replace('/\\\\+/','/',$Path);
-   * Escape trace path for windows systems
-   * @param array $Trace
-   * @return array
-  protected function _escapeTrace($Trace) {
-    if(!$Trace) return $Trace;
-    for( $i=0 ; $i<sizeof($Trace) ; $i++ ) {
-      if(isset($Trace[$i]['file'])) {
-        $Trace[$i]['file'] = $this->_escapeTraceFile($Trace[$i]['file']);
-      if(isset($Trace[$i]['args'])) {
-        $Trace[$i]['args'] = $this->encodeObject($Trace[$i]['args']);
-    return $Trace;
-   * Escape file information of trace for windows systems
-   * @param string $File
-   * @return string
-  protected function _escapeTraceFile($File) {
-    /* Check if we have a windows filepath */
-    if(strpos($File,'\\')) {
-      /* First strip down to single \ */
-      $file = preg_replace('/\\\\+/','\\',$File);
-      return $file;
-    return $File;
-   * Send header
-   * @param string_type $Value
-  protected function setHeader($Name, $Value) {
-    return header($Name.': '.$Value);
-   * Get user agent
-   * @return string|false
-  protected function getUserAgent() {
-    if(!isset($_SERVER['HTTP_USER_AGENT'])) return false;
-    return $_SERVER['HTTP_USER_AGENT'];
-   * Returns a new exception
-   * @param string $Message
-   * @return Exception
-  protected function newException($Message) {
-    return new Exception($Message);
-   * Encode an object into a JSON string
-   * Uses PHP's jeson_encode() if available
-   * @param object $Object The object to be encoded
-   * @return string The JSON string
-  public function jsonEncode($Object, $skipObjectEncode=false)
-    if(!$skipObjectEncode) {
-      $Object = $this->encodeObject($Object);
-    if(function_exists('json_encode')
-       && $this->options['useNativeJsonEncode']!=false) {
-      return json_encode($Object);
-    } else {
-      return $this->json_encode($Object);
-   * Encodes a table by encoding each row and column with encodeObject()
-   * @param array $Table The table to be encoded
-   * @return array
-  protected function encodeTable($Table) {
-    if(!$Table) return $Table;
-    $new_table = array();
-    foreach($Table as $row) {
-      if(is_array($row)) {
-        $new_row = array();
-        foreach($row as $item) {
-          $new_row[] = $this->encodeObject($item);
-        $new_table[] = $new_row;
-    return $new_table;
-   * Encodes an object including members with
-   * protected and private visibility
-   * @param Object $Object The object to be encoded
-   * @param int $Depth The current traversal depth
-   * @return array All members of the object
-  protected function encodeObject($Object, $ObjectDepth = 1, $ArrayDepth = 1)
-    $return = array();
-    if (is_resource($Object)) {
-      return '** '.(string)$Object.' **';
-    } else
-    if (is_object($Object)) {
-        if ($ObjectDepth > $this->options['maxObjectDepth']) {
-          return '** Max Object Depth ('.$this->options['maxObjectDepth'].') **';
-        foreach ($this->objectStack as $refVal) {
-            if ($refVal === $Object) {
-                return '** Recursion ('.get_class($Object).') **';
-        array_push($this->objectStack, $Object);
-        $return['__className'] = $class = get_class($Object);
-        $class_lower = strtolower($class);
-        $reflectionClass = new ReflectionClass($class);
-        $properties = array();
-        foreach( $reflectionClass->getProperties() as $property) {
-          $properties[$property->getName()] = $property;
-        $members = (array)$Object;
-        foreach( $properties as $raw_name => $property ) {
-          $name = $raw_name;
-          if($property->isStatic()) {
-            $name = 'static:'.$name;
-          if($property->isPublic()) {
-            $name = 'public:'.$name;
-          } else
-          if($property->isPrivate()) {
-            $name = 'private:'.$name;
-            $raw_name = "\0".$class."\0".$raw_name;
-          } else
-          if($property->isProtected()) {
-            $name = 'protected:'.$name;
-            $raw_name = "\0".'*'."\0".$raw_name;
-          if(!(isset($this->objectFilters[$class_lower])
-               && is_array($this->objectFilters[$class_lower])
-               && in_array($raw_name,$this->objectFilters[$class_lower]))) {
-            if(array_key_exists($raw_name,$members)
-               && !$property->isStatic()) {
-              $return[$name] = $this->encodeObject($members[$raw_name], $ObjectDepth + 1, 1);
-            } else {
-              if(method_exists($property,'setAccessible')) {
-                $property->setAccessible(true);
-                $return[$name] = $this->encodeObject($property->getValue($Object), $ObjectDepth + 1, 1);
-              } else
-              } else {
-                $return[$name] = '** Need PHP 5.3 to get value **';
-          } else {
-            $return[$name] = '** Excluded by Filter **';
-        // Include all members that are not defined in the class
-        // but exist in the object
-        foreach( $members as $raw_name => $value ) {
-          if ($name{0} == "\0") {
-            $parts = explode("\0", $name);
-            $name = $parts[2];
-          if(!isset($properties[$name])) {
-            $name = 'undeclared:'.$name;
-              $return[$name] = $this->encodeObject($value, $ObjectDepth + 1, 1);
-            } else {
-        array_pop($this->objectStack);
-    } elseif (is_array($Object)) {
-        if ($ArrayDepth > $this->options['maxArrayDepth']) {
-          return '** Max Array Depth ('.$this->options['maxArrayDepth'].') **';
-        foreach ($Object as $key => $val) {
-          // Encoding the $GLOBALS PHP array causes an infinite loop
-          // if the recursion is not reset here as it contains
-          // a reference to itself. This is the only way I have come up
-          // with to stop infinite recursion in this case.
-          if($key=='GLOBALS'
-             && is_array($val)
-             && array_key_exists('GLOBALS',$val)) {
-            $val['GLOBALS'] = '** Recursion (GLOBALS) **';
-          $return[$key] = $this->encodeObject($val, 1, $ArrayDepth + 1);
-    } else {
-      if(self::is_utf8($Object)) {
-        return $Object;
-      } else {
-        return utf8_encode($Object);
-    return $return;
-   * Returns true if $string is valid UTF-8 and false otherwise.
-   * @param mixed $str String to be tested
-   * @return boolean
-  protected static function is_utf8($str) {
-    $c=0; $b=0;
-    $bits=0;
-    $len=strlen($str);
-    for($i=0; $i<$len; $i++){
-        $c=ord($str[$i]);
-        if($c > 128){
-            if(($c >= 254)) return false;
-            elseif($c >= 252) $bits=6;
-            elseif($c >= 248) $bits=5;
-            elseif($c >= 240) $bits=4;
-            elseif($c >= 224) $bits=3;
-            elseif($c >= 192) $bits=2;
-            else return false;
-            if(($i+$bits) > $len) return false;
-            while($bits > 1){
-                $i++;
-                $b=ord($str[$i]);
-                if($b < 128 || $b > 191) return false;
-                $bits--;
-    return true;
-   * Converts to and from JSON format.
-   * JSON (JavaScript Object Notation) is a lightweight data-interchange
-   * format. It is easy for humans to read and write. It is easy for machines
-   * to parse and generate. It is based on a subset of the JavaScript
-   * Programming Language, Standard ECMA-262 3rd Edition - December 1999.
-   * This feature can also be found in  Python. JSON is a text format that is
-   * completely language independent but uses conventions that are familiar
-   * to programmers of the C-family of languages, including C, C++, C#, Java,
-   * JavaScript, Perl, TCL, and many others. These properties make JSON an
-   * ideal data-interchange language.
-   * This package provides a simple encoder and decoder for JSON notation. It
-   * is intended for use with client-side Javascript applications that make
-   * use of HTTPRequest to perform server communication functions - data can
-   * be encoded into JSON notation for use in a client-side javascript, or
-   * decoded from incoming Javascript requests. JSON format is native to
-   * Javascript, and can be directly eval()'ed with no further parsing
-   * overhead
-   * All strings should be in ASCII or UTF-8 format!
-   * LICENSE: Redistribution and use in source and binary forms, with or
-   * without modification, are permitted provided that the following
-   * conditions are met: Redistributions of source code must retain the
-   * above copyright notice, this list of conditions and the following
-   * disclaimer. Redistributions in binary form must reproduce the above
-   * copyright notice, this list of conditions and the following disclaimer
-   * in the documentation and/or other materials provided with the
-   * distribution.
-   * THIS SOFTWARE IS PROVIDED ``AS IS'' AND ANY EXPRESS OR IMPLIED
-   * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF
-   * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN
-   * NO EVENT SHALL CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT,
-   * INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING,
-   * BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS
-   * OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
-   * ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR
-   * TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE
-   * USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH
-   * DAMAGE.
-   * @category
-   * @package     Services_JSON
-   * @author      Michal Migurski <mike-json at teczno.com>
-   * @author      Matt Knapp <mdknapp[at]gmail[dot]com>
-   * @author      Brett Stimmerman <brettstimmerman[at]gmail[dot]com>
-   * @copyright   2005 Michal Migurski
-   * @version     CVS: $Id: JSON.php,v 1.31 2006/06/28 05:54:17 migurski Exp $
-   * @link        http://pear.php.net/pepr/pepr-proposal-show.php?id=198
-   * Keep a list of objects as we descend into the array so we can detect recursion.
-  private $json_objectStack = array();
-  * convert a string from one UTF-8 char to one UTF-16 char
-  * Normally should be handled by mb_convert_encoding, but
-  * provides a slower PHP-only method for installations
-  * that lack the multibye string extension.
-  * @param    string  $utf8   UTF-8 character
-  * @return   string  UTF-16 character
-  * @access   private
-  private function json_utf82utf16($utf8)
-      // oh please oh please oh please oh please oh please
-      if(function_exists('mb_convert_encoding')) {
-          return mb_convert_encoding($utf8, 'UTF-16', 'UTF-8');
-      switch(strlen($utf8)) {
-          case 1:
-              // this case should never be reached, because we are in ASCII range
-              // see: http://www.cl.cam.ac.uk/~mgk25/unicode.html#utf-8
-              return $utf8;
-          case 2:
-              // return a UTF-16 character from a 2-byte UTF-8 char
-              return chr(0x07 & (ord($utf8{0}) >> 2))
-                   . chr((0xC0 & (ord($utf8{0}) << 6))
-                       | (0x3F & ord($utf8{1})));
-          case 3:
-              // return a UTF-16 character from a 3-byte UTF-8 char
-              return chr((0xF0 & (ord($utf8{0}) << 4))
-                       | (0x0F & (ord($utf8{1}) >> 2)))
-                   . chr((0xC0 & (ord($utf8{1}) << 6))
-                       | (0x7F & ord($utf8{2})));
-      // ignoring UTF-32 for now, sorry
-      return '';
-  * encodes an arbitrary variable into JSON format
-  * @param    mixed   $var    any number, boolean, string, array, or object to be encoded.
-  *                           see argument 1 to Services_JSON() above for array-parsing behavior.
-  *                           if var is a strng, note that encode() always expects it
-  *                           to be in ASCII or UTF-8 format!
-  * @return   mixed   JSON string representation of input var or an error if a problem occurs
-  * @access   public
-  private function json_encode($var)
-    if(is_object($var)) {
-      if(in_array($var,$this->json_objectStack)) {
-        return '"** Recursion **"';
-      switch (gettype($var)) {
-          case 'boolean':
-              return $var ? 'true' : 'false';
-          case 'NULL':
-              return 'null';
-          case 'integer':
-              return (int) $var;
-          case 'double':
-          case 'float':
-              return (float) $var;
-          case 'string':
-              // STRINGS ARE EXPECTED TO BE IN ASCII OR UTF-8 FORMAT
-              $ascii = '';
-              $strlen_var = strlen($var);
-              * Iterate over every character in the string,
-              * escaping with a slash or encoding to UTF-8 where necessary
-              for ($c = 0; $c < $strlen_var; ++$c) {
-                  $ord_var_c = ord($var{$c});
-                  switch (true) {
-                      case $ord_var_c == 0x08:
-                          $ascii .= '\b';
-                          break;
-                      case $ord_var_c == 0x09:
-                          $ascii .= '\t';
-                          break;
-                      case $ord_var_c == 0x0A:
-                          $ascii .= '\n';
-                          break;
-                      case $ord_var_c == 0x0C:
-                          $ascii .= '\f';
-                          break;
-                      case $ord_var_c == 0x0D:
-                          $ascii .= '\r';
-                          break;
-                      case $ord_var_c == 0x22:
-                      case $ord_var_c == 0x2F:
-                      case $ord_var_c == 0x5C:
-                          // double quote, slash, slosh
-                          $ascii .= '\\'.$var{$c};
-                          break;
-                      case (($ord_var_c >= 0x20) && ($ord_var_c <= 0x7F)):
-                          // characters U-00000000 - U-0000007F (same as ASCII)
-                          $ascii .= $var{$c};
-                          break;
-                      case (($ord_var_c & 0xE0) == 0xC0):
-                          // characters U-00000080 - U-000007FF, mask 110XXXXX
-                          // see http://www.cl.cam.ac.uk/~mgk25/unicode.html#utf-8
-                          $char = pack('C*', $ord_var_c, ord($var{$c + 1}));
-                          $c += 1;
-                          $utf16 = $this->json_utf82utf16($char);
-                          $ascii .= sprintf('\u%04s', bin2hex($utf16));
-                          break;
-                      case (($ord_var_c & 0xF0) == 0xE0):
-                          // characters U-00000800 - U-0000FFFF, mask 1110XXXX
-                                       ord($var{$c + 1}),
-                                       ord($var{$c + 2}));
-                          $c += 2;
-                          break;
-                      case (($ord_var_c & 0xF8) == 0xF0):
-                          // characters U-00010000 - U-001FFFFF, mask 11110XXX
-                                       ord($var{$c + 2}),
-                                       ord($var{$c + 3}));
-                          $c += 3;
-                          break;
-                      case (($ord_var_c & 0xFC) == 0xF8):
-                          // characters U-00200000 - U-03FFFFFF, mask 111110XX
-                                       ord($var{$c + 3}),
-                                       ord($var{$c + 4}));
-                          $c += 4;
-                          break;
-                      case (($ord_var_c & 0xFE) == 0xFC):
-                          // characters U-04000000 - U-7FFFFFFF, mask 1111110X
-                                       ord($var{$c + 4}),
-                                       ord($var{$c + 5}));
-                          $c += 5;
-                          break;
-              return '"'.$ascii.'"';
-          case 'array':
-              * As per JSON spec if any array key is not an integer
-              * we must treat the the whole array as an object. We
-              * also try to catch a sparsely populated associative
-              * array with numeric keys here because some JS engines
-              * will create an array with empty indexes up to
-              * max_index which can cause memory issues and because
-              * the keys, which may be relevant, will be remapped
-              * otherwise.
-              * As per the ECMA and JSON specification an object may
-              * have any string as a property. Unfortunately due to
-              * a hole in the ECMA specification if the key is a
-              * ECMA reserved word or starts with a digit the
-              * parameter is only accessible using ECMAScript's
-              * bracket notation.
-              // treat as a JSON object
-              if (is_array($var) && count($var) && (array_keys($var) !== range(0, sizeof($var) - 1))) {
-                  $this->json_objectStack[] = $var;
-                  $properties = array_map(array($this, 'json_name_value'),
-                                          array_keys($var),
-                                          array_values($var));
-                  array_pop($this->json_objectStack);
-                  foreach($properties as $property) {
-                      if($property instanceof Exception) {
-                          return $property;
-                  return '{' . join(',', $properties) . '}';
-              // treat it like a regular array
-              $elements = array_map(array($this, 'json_encode'), $var);
-              foreach($elements as $element) {
-                  if($element instanceof Exception) {
-                      return $element;
-              return '[' . join(',', $elements) . ']';
-          case 'object':
-              $vars = self::encodeObject($var);
-                                      array_keys($vars),
-                                      array_values($vars));
-                      return $property;
-          default:
-              return null;
-  * array-walking function for use in generating JSON-formatted name-value pairs
-  * @param    string  $name   name of key to use
-  * @param    mixed   $value  reference to an array element to be encoded
-  * @return   string  JSON-formatted name-value pair, like '"name":value'
-  * @access   private
-  private function json_name_value($name, $value)
-      if($name=='GLOBALS'
-         && is_array($value)
-         && array_key_exists('GLOBALS',$value)) {
-        $value['GLOBALS'] = '** Recursion **';
-      $encoded_value = $this->json_encode($value);
-      if($encoded_value instanceof Exception) {
-          return $encoded_value;
-      return $this->json_encode(strval($name)) . ':' . $encoded_value;
Deleted: trunk/mapbender/http/extensions/fb.php
--- trunk/mapbender/http/extensions/fb.php	2009-11-05 13:09:11 UTC (rev 4939)
+++ trunk/mapbender/http/extensions/fb.php	2009-11-05 13:09:40 UTC (rev 4940)
@@ -1,261 +0,0 @@
-<?php
-/* ***** BEGIN LICENSE BLOCK *****
-require_once dirname(__FILE__).'/FirePHP.class.php';
- * @return true
-function fb()
-  $instance = FirePHP::getInstance(true);
-  $args = func_get_args();
-  return call_user_func_array(array($instance,'fb'),$args);
-class FB
-   * @see FirePHP->setEnabled()
-   * @return void
-  public static function setEnabled($Enabled) {
-    $instance->setEnabled($Enabled);
-   * @see FirePHP->getEnabled()
-  public static function getEnabled() {
-    return $instance->getEnabled();
-   * @see FirePHP->setObjectFilter()
-   * @param array $Filter An array or members to exclude
-   * @return void
-  public static function setObjectFilter($Class, $Filter) {
-    $instance->setObjectFilter($Class, $Filter);
-   * @see FirePHP->setOptions()
-   * @return void
-  public static function setOptions($Options) {
-    $instance->setOptions($Options);
-   * Get options for the library
-   * @see FirePHP->getOptions()
-   * @return array The options
-  public static function getOptions() {
-    return $instance->getOptions();
-   * Log object to firebug
-   * @return true
-  public static function send()
-   * Options:
-   * @return true
-  public static function group($Name, $Options=null) {
-    return $instance->group($Name, $Options);
-   * @return true
-  public static function groupEnd() {
-    return self::send(null, null, FirePHP::GROUP_END);
-   * @return true
-  public static function log($Object, $Label=null) {
-    return self::send($Object, $Label, FirePHP::LOG);
-   * @return true
-  public static function info($Object, $Label=null) {
-    return self::send($Object, $Label, FirePHP::INFO);
-   * @return true
-  public static function warn($Object, $Label=null) {
-    return self::send($Object, $Label, FirePHP::WARN);
-   * @return true
-  public static function error($Object, $Label=null) {
-    return self::send($Object, $Label, FirePHP::ERROR);
-   * @return true
-  public static function dump($Key, $Variable) {
-    return self::send($Variable, $Key, FirePHP::DUMP);
-   * @return true
-  public static function trace($Label) {
-    return self::send($Label, FirePHP::TRACE);
-   * @return true
-  public static function table($Label, $Table) {
-    return self::send($Table, $Label, FirePHP::TABLE);
More information about the Mapbender_commits mailing list
