[Mapbender-commits] r4958 - trunk/mapbender/http/classes
svn_mapbender at osgeo.org
Fri Nov 6 10:31:07 EST 2009
Author: christoph
Date: 2009-11-06 10:31:07 -0500 (Fri, 06 Nov 2009)
New Revision: 4958
trunk/mapbender/http/classes/class_wmc.php
Modified: trunk/mapbender/http/classes/class_wmc.php
--- trunk/mapbender/http/classes/class_wmc.php 2009-11-06 15:30:40 UTC (rev 4957)
+++ trunk/mapbender/http/classes/class_wmc.php 2009-11-06 15:31:07 UTC (rev 4958)
@@ -226,12 +226,10 @@
// DATABASE FUNCTIONS
- public function getOtherUsersPublicWmcIds ($userId) {
+ public function getPublicWmcIds ($userId) {
$sql = "SELECT wmc_id FROM mb_user_wmc ";
- $sql .= "WHERE fkey_user_id <> $1 AND wmc_public = 1 GROUP BY wmc_id";
- $v = array($userId);
- $t = array("i");
- $res_wmc = db_prep_query($sql, $v, $t);
+ $sql .= "WHERE wmc_public = 1 GROUP BY wmc_id";
+ $res_wmc = db_query($sql);
$wmcArray = array();
while($row = db_fetch_array($res_wmc)){
@@ -246,9 +244,9 @@
// get WMC ids
$wmcIdArray = $user->getWmcByOwner();
- $publicWmcIdArray = $this->getOtherUsersPublicWmcIds($user->id);
+ $publicWmcIdArray = $this->getPublicWmcIds($user->id);
- $wmcIdArray = array_merge($wmcIdArray, $publicWmcIdArray);
+ $wmcIdArray = array_keys( array_flip(array_merge($wmcIdArray, $publicWmcIdArray)));
// get WMC data
$v = array();
@@ -303,7 +301,9 @@
$WMSIdList = $xpath->query($query_mbWMSId);
foreach($WMSIdList as $WMSId) {
$id = $WMSId->nodeValue;
- $sql = "SELECT wms_timestamp,wms_getmap,wms_getlegendurl FROM wms WHERE wms_id = $1";
+ $sql = "SELECT wms_timestamp,wms_getmap,wms_getlegendurl " .
+ "FROM wms WHERE wms_id = $1 AND " .
+ "wms_owsproxy <> NULL AND wms_owsproxy <> ''";
$v = array($id);
$t = array("t");
@@ -312,20 +312,20 @@
true;
} //FIMXE: PROPER ERROR MESSAGE
- if($row = db_fetch_row($res)) {
- $wms_timestamp = $row[0];
+ if($row = db_fetch_array($res)) {
+ $wms_timestamp = $row["wms_timestamp"];
if ($this->timestamp < $wms_timestamp) {
// wmc is fresh, life is good
else{
$MapResources = $xpath->query("../../wmc:Server/wmc:OnlineResource",$WMSId);
foreach($MapResources as $MapResource) {
- $MapResource->setAttribute("xlink:href",$row[1]);
+ $MapResource->setAttribute("xlink:href",$row["wms_getmap"]);
$LegendResources = $xpath->query("../../wmc:StyleList/wmc:Style/wmc:LegendURL/wmc:OnlineResource",$WMSId);
foreach ($LegendResources as $LegendResource) {
- $base = $row[2];
+ $base = $row["wms_getlegendurl"];
$origurl = explode('&', $LegendResource->getAttribute("xlink:href"),2);
$url = $base . $origurl[1];
$LegendResource->setAttribute("xlink:href",$url);
@@ -345,62 +345,58 @@
public function insert ($overwrite) {
$result = array();
- if ($this->userId && $this->xml && $this->wmc_title) {
- try {
- $user = new user($this->userId);
- } catch (Exception $E) {
- $errMsg = "Error while saving WMC document " . $this->wmc_title . "': Invalud UserId";
- $result["success"] = false;
- $result["message"] = $errMsg;
- $e = new mb_exception("mod_insertWMCIntoDB: " . $errMsg);
- return $result;
- $overwrite = ($user->isPublic())? false: $overwrite;
- db_begin();
- if($overwrite)
- $findsql = "SELECT fkey_user_id,wmc_title,wmc_timestamp FROM mb_user_wmc WHERE fkey_user_id = $1 AND wmc_title = $2 ORDER BY wmc_timestamp DESC LIMIT 1;";
- $v = array($this->userId, administration::convertOutgoingString($this->wmc_title));
- $t = array("i","s");
- $res = db_prep_query($findsql,$v,$t);
- if (db_error()) {
- $errMsg = "Error while saving WMC document '" . $this->wmc_title . "': " . db_error();
+ if ($this->userId && $this->xml && $this->wmc_title) {
+ try {
+ $user = new user($this->userId);
+ catch (Exception $E) {
+ $errMsg = "Error while saving WMC document " . $this->wmc_title . "': Invalud UserId";
- return $result;
+ return $result;
- $sql = "UPDATE mb_user_wmc SET wmc = $1, wmc_timestamp = $2 WHERE fkey_user_id = $3 AND wmc_title=$4 AND wmc_timestamp = $5";
- $v = array($this->xml, time(), $this->userId, administration::convertOutgoingString($this->wmc_title),$row[2]);
- $t = array("s", "s", "i", "s","s");
- }else{
- $sql = "INSERT INTO mb_user_wmc VALUES ($1, $2, $3, $4, $5, $6)";
- $v = array($this->wmc_id, $this->userId, $this->xml, administration::convertOutgoingString($this->wmc_title), time(),time());
- $t = array("s", "i", "s", "s", "s","s");
- }else{
+ $overwrite = ($user->isPublic())? false: $overwrite;
+ db_begin();
+ if($overwrite) {
+ $findsql = "SELECT fkey_user_id,wmc_title,wmc_timestamp FROM mb_user_wmc WHERE fkey_user_id = $1 AND wmc_title = $2 ORDER BY wmc_timestamp DESC LIMIT 1;";
+ $v = array($this->userId, administration::convertOutgoingString($this->wmc_title));
+ $t = array("i","s");
+ $res = db_prep_query($findsql,$v,$t);
+ if (db_error()) {
+ $errMsg = "Error while saving WMC document '" . $this->wmc_title . "': " . db_error();
+ $result["success"] = false;
+ $result["message"] = $errMsg;
+ $e = new mb_exception("mod_insertWMCIntoDB: " . $errMsg);
+ return $result;
+ if($row = db_fetch_row($res)) {
+ $sql = "UPDATE mb_user_wmc SET wmc = $1, wmc_timestamp = $2 WHERE fkey_user_id = $3 AND wmc_title=$4 AND wmc_timestamp = $5";
+ $v = array($this->xml, time(), $this->userId, administration::convertOutgoingString($this->wmc_title),$row[2]);
+ $t = array("s", "s", "i", "s","s");
+ else{
+ $sql = "INSERT INTO mb_user_wmc (" .
+ "wmc_id, fkey_user_id, wmc, wmc_title, wmc_public, wmc_timestamp, wmc_timestamp_create" .
+ ") VALUES ($1, $2, $3, $4, $5, $6, $7)";
+ $v = array($this->wmc_id, $this->userId, $this->xml, administration::convertOutgoingString($this->wmc_title), $user->isPublic()?1:0,time(),time());
+ $t = array("s", "i", "s", "s", "i", "s","s");
+ else{
+ $sql = "INSERT INTO mb_user_wmc (wmc_id, fkey_user_id, wmc, wmc_title, wmc_public, wmc_timestamp, wmc_timestamp_create) VALUES ($1, $2, $3, $4, $5, $6, $7)";
+ $v = array($this->wmc_id, $this->userId, $this->xml, administration::convertOutgoingString($this->wmc_title), $user->isPublic()?1:0, time(),time());
$res = db_prep_query($sql, $v, $t);
if (db_error()) {
More information about the Mapbender_commits
