[Mapbender-commits] r4969 - in trunk/mapbender: http/javascripts lib
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Mon Nov 9 12:08:22 EST 2009
Author: christoph
Date: 2009-11-09 12:08:22 -0500 (Mon, 09 Nov 2009)
New Revision: 4969
Added:
   trunk/mapbender/lib/history.js
   trunk/mapbender/http/javascripts/map_obj.js
   trunk/mapbender/http/javascripts/mod_box1.js
   trunk/mapbender/lib/extent.js
Modified: trunk/mapbender/http/javascripts/map_obj.js
--- trunk/mapbender/http/javascripts/map_obj.js	2009-11-09 17:07:53 UTC (rev 4968)
+++ trunk/mapbender/http/javascripts/map_obj.js	2009-11-09 17:08:22 UTC (rev 4969)
@@ -1,16 +1,15 @@
  * Package: Map
  * Description:
  * This is the central module for displaying the composite map overlay.
  * Help:
  * http://www.mapbender.org/Mapframe
  * Constructor: Map
  * Parameters:
  * frameName		- *[deprecated]* the name of the iframe, for backwards
  * 						compatibility only, use "" for maps in DIVs
@@ -20,1241 +19,1381 @@
  * wms_index		- restrict the WMS in the map to the WMS with this ID
  * 						(useful for overview maps)
-Mapbender.Map = function (frameName, elementName, width, height, wms_index) {
+Mapbender.Map = function(frameName, elementName, width, height, wms_index){
-	var mapMsgObj;
-	eventLocalize.register(function () {
-		localizeMap();
+    var mapMsgObj;
+    eventLocalize.register(function(){
+        localizeMap();
+    eventInit.register(function(){
+        localizeMap();
+    var localizeMap = function(){
+        $.post("../php/mod_map_messages.php", function(obj, status){
+            mapMsgObj = eval('(' + obj + ')');
+    this.history = new Mapbender.History();
+	this.history.events.beforeAdd.register(function () {
+		for (var i = that.history.getCurrentIndex() + 1; i <= that.history.count(); i++) {
+	        $("#" + that.elementName + "_request_" + i).remove();
+     * Method: setExtent
+     * Description:
+     * set the extent of the wms
+     * Parameters:
+     * minx		- x of south west
+     * miny		- y of south west
+     * maxx		- x of north east
+     * maxy		- y of north east
+    this.setExtent = function(minx, miny, maxx, maxy){
+		if (typeof this.extent !== "undefined") {
+            this.oldExtent = new Extent(this.extent);
-	eventInit.register(function () {
-		localizeMap();
-	var localizeMap = function () {
-		$.post("../php/mod_map_messages.php", function(obj, status){
-			mapMsgObj = eval('(' + obj + ')');
-	 * Method: setExtent
-	 * Description:
-	 * set the extent of the wms
-	 * Parameters:
-	 * minx		- x of south west
-	 * miny		- y of south west
-	 * maxx		- x of north east
-	 * maxy		- y of north east
-	this.setExtent = function(minx, miny, maxx, maxy){
-		if (!this.extent) {
-			this.extent = new Mapbender.Extent(minx, miny, maxx, maxy);
-		else {
-			this.extent.set(new Point(minx, miny), new Point(maxx, maxy));
-	this.restrictedExtent = function (extent) {
-		this.restrictedExtent = extent;
-	 * get the width of the mapObj
-	 * @member Map
-	 * @return width of the mapObj
-	 * @type integer
-	this.getWidth = function(){
-		return parseInt(this.width, 10);
-	 * set the width of the mapObj
-	 * @param {integer} widht the width of the mapObj
-	this.setWidth = function(width){
-		this.width = parseInt(width, 10);
-		//apply new width
-		if(this.frameName){
-			document.getElementById(this.frameName).style.width = this.width;
-		var domElement = this.getDomElement();
-		domElement.style.width = this.width;
-	 * get the height of the mapObj
-	 * @member Map
-	 * @type integer
-	this.getHeight = function(){
-		return parseInt(this.height, 10);
-	this.getDomElement = function(){
-			return window.frames[this.frameName].document.getElementById(this.elementName);
-		return document.getElementById(this.elementName);
-	 * set the height of the mapObj
-	 * @param {integer} height the height of the mapObj
-	this.setHeight = function(height){
-		this.height = parseInt(height, 10);
-		//apply new height
-			document.getElementById(this.frameName).style.height = this.height;
-		domElement.style.height = this.height;
-	this.getMousePosition = function (e) {
-		var clickX, clickY;
-		if ($.browser.msie) {
-			clickX = parseInt(window.event.offsetX, 10);
-			clickY = parseInt(window.event.offsetY, 10);
-		else{
-			clickX = e.pageX;
-			clickY = e.pageY;
-		var currentPos = null;
-		if (this.type == "DIV" && !$.browser.msie) {
-			var mapDomElement = this.getDomElement();
-			currentPos = new Point(
-				clickX - parseInt(mapDomElement.style.left, 10),
-				clickY - parseInt(mapDomElement.style.top, 10)
-			// if the mouse position is not on top of the map, return null
-			if (currentPos.x < 0 || currentPos.x > this.width ||
-				currentPos.y < 0 || currentPos.y > this.height) {
-				return null;
+	        // pixel coordinates of new extent in old extent
+	        if (arguments.length === 1) {
+				var oldpixll = this.convertRealToPixel(minx.min);
+				var oldpixur = this.convertRealToPixel(minx.max);
+				this.oldExtentPix = new Extent(oldpixll.x, oldpixll.y, oldpixur.x, oldpixur.y);
-		else {
-				clickX,
-				clickY
-			// sometimes there are divs within the map (like copyright)
-			// then offsetX and offsetY are not valid.
-			if (window.event.srcElement.tagName.toUpperCase() !== "IMG") {
-				var top = parseInt(window.event.srcElement.style.top, 10);
-				var left = parseInt(window.event.srcElement.style.left, 10);
-				currentPos = currentPos.plus(new Point(left,top));
+			else if (arguments.length === 4) {
+				var oldpixll = this.convertRealToPixel(new Point(parseFloat(minx), parseFloat(miny)));
+				var oldpixur = this.convertRealToPixel(new Point(parseFloat(maxx), parseFloat(maxy)));
-		return currentPos;
-	 * converts the extent of the mapobject so that the maximum	extent will be displayed
-	this.calculateExtent = function(ext){
-		var relation_px_x = this.getWidth() / this.getHeight();
-		var relation_px_y = this.getHeight() / this.getWidth();
-		var relation_bbox_x = ext.extentx / ext.extenty;
-		if (relation_bbox_x <= relation_px_x) {
-			ext.minx = ext.centerx - relation_px_x * ext.extenty / 2;
-			ext.maxx = ext.centerx + relation_px_x * ext.extenty / 2;
-		if (relation_bbox_x > relation_px_x) {
-			ext.miny = ext.centery - relation_px_y * ext.extentx / 2;
-			ext.maxy = ext.centery + relation_px_y * ext.extentx / 2;
-		// Check if ext is within restricted extent
-		// If not, calculate a new extent according
-		// to restricted extent.
-		if ( this.restrictedExtent ) {
-			if ( ext.minx  < this.restrictedExtent.minx ) {
-	            ext.minx = this.restrictedExtent.minx;
-	            ext.maxx = ext.minx + (relation_px_x * ext.extenty);
-	        if ( ext.miny < this.restrictedExtent.miny ) {
-	            ext.miny = this.restrictedExtent.miny;
-	            ext.maxy = ext.miny + (relation_px_y * ext.extentx);
-	        if ( ext.maxx > this.restrictedExtent.maxx ) {
-	            ext.maxx = this.restrictedExtent.maxx;
-	            ext.minx = ext.maxx - (relation_px_x * ext.extenty);
-	        if ( ext.maxy > this.restrictedExtent.maxy ) {
-	            ext.maxy = this.restrictedExtent.maxy;
-	            ext.miny = ext.maxy - (relation_px_y * ext.extentx);
-		this.setExtent(ext.minx, ext.miny, ext.maxx, ext.maxy);
-		return ext;
-	var ignoredWms;
-	var undoIgnoreWms = function () {
-		ignoredWms = [];
-	var ignoreWms = function (wms) {
-		ignoredWms.push({
-			id: wms.wms_id,
-			title: wms.wms_title
-	var isIgnoredWms = function (wms) {
-		for (var j = 0; j < ignoredWms.length; j++) {
-			if (ignoredWms[j].id === wms.wms_id) {
-				return true;
+		else {
+			this.oldExtentPix = new Extent(0, this.height, this.width, 0);
-		return false;
-	var getIgnoredWms = function () {
-		return ignoredWms;
-	this.setSrs = function (options) {
-		if (typeof options.srs !== "string") {
-			new Mb_exception("Mapbender.Map.setSrs: SRS is not a string: " + options.srs);
-			return null;
-		if (!options.extent || options.extent.constructor !== Mapbender.Extent) {
-			new Mb_exception("Mapbender.Map.setSrs: Extent is not a Mapbender.Extent: " + options.extent);
-			return null;
-		if (this.epsg !== options.srs) {
-			// check which WMS support the new SRS
-			undoIgnoreWms();
-			for (var i = 0; i < this.wms.length; i++) {
-				var found = false;
-				for (var j = 0; j < this.wms[i].gui_epsg.length; j++) {
-					if (options.srs === this.wms[i].gui_epsg[j] && this.wms[i].gui_epsg_supported[j]) {
-						found = true;
-						break;
-				if (!found) {
-					ignoreWms(this.wms[i]);
-			var ignoredWms = getIgnoredWms();
-			// ...and optionally display a message
-			if (options.displayWarning && ignoredWms.length > 0) {
-				var msg = mapMsgObj.srsNotSupported + ": <br><br>";
-				for (var key in ignoredWms) {
-					msg += "<b>" + ignoredWms[key].title + "</b><br>";
-				try {
-					Mapbender.modules.dialogManager.openDialog({
-						content: msg,
-						modal: false,
-						effectShow: 'puff'
-				catch (e) {
-					new Mb_warning(e.message + ". " + msg);
-			// actually set the new values and return extent
-			this.epsg = options.srs;
-		return this.calculateExtent(options.extent);
-	this.setWms = function (wms_index) {
-		this.wms = [];
-		var index = 0;
-		for (var i = 0; i < wms.length; i++) {
-			var isValidWms = (wms_index === null) || (wms_index == i);
-			if (isValidWms) {
-				// MAJOR CHANGE!
-				// formerly, this was a reference!
-				// Now, this is a copy!
-				// Each map object has its own set of WMS.
-				// I expect some things to break :-)
-				this.wms[index] = cloneObject(wms[i]);
-				this.wms[index].mapURL = false;
-				index++;
+            this.extent = arguments[0];
+            if (!this.extent) {
+                this.extent = new Mapbender.Extent(arguments[0], arguments[1], arguments[2], arguments[3]);
+            else {
+                this.extent.set(new Point(arguments[0], arguments[1]), new Point(arguments[2], arguments[3]));
+     this.restrictedExtent = function (extent) {
+     this.restrictedExtent = extent;
+     * get the width of the mapObj
+     * @member Map
+     * @return width of the mapObj
+     * @type integer
+    this.getWidth = function(){
+        return parseInt(this.width, 10);
+     * set the width of the mapObj
+     * @param {integer} widht the width of the mapObj
+    this.setWidth = function(width){
+        this.width = parseInt(width, 10);
+        //apply new width
+        if (this.frameName) {
+            document.getElementById(this.frameName).style.width = this.width;
+        var domElement = this.getDomElement();
+        domElement.style.width = this.width;
+     * get the height of the mapObj
+     * @member Map
+     * @type integer
+    this.getHeight = function(){
+        return parseInt(this.height, 10);
+    this.getDomElement = function(){
+            return window.frames[this.frameName].document.getElementById(this.elementName);
+        return document.getElementById(this.elementName);
+     * set the height of the mapObj
+     * @param {integer} height the height of the mapObj
+    this.setHeight = function(height){
+        this.height = parseInt(height, 10);
+        //apply new height
+            document.getElementById(this.frameName).style.height = this.height;
+        domElement.style.height = this.height;
+    this.getMousePosition = function(e){
+        var clickX, clickY;
+        if ($.browser.msie) {
+            clickX = parseInt(window.event.offsetX, 10);
+            clickY = parseInt(window.event.offsetY, 10);
+        else {
+            clickX = e.pageX;
+            clickY = e.pageY;
+        var currentPos = null;
+        if (this.type == "DIV" && !$.browser.msie) {
+            var mapDomElement = this.getDomElement();
+            currentPos = new Point(clickX - parseInt(mapDomElement.style.left, 10), clickY - parseInt(mapDomElement.style.top, 10));
+            // if the mouse position is not on top of the map, return null
+            if (currentPos.x < 0 || currentPos.x > this.width ||
+            currentPos.y < 0 ||
+            currentPos.y > this.height) {
+                return null;
+        else {
+            currentPos = new Point(clickX, clickY);
+            // sometimes there are divs within the map (like copyright)
+            // then offsetX and offsetY are not valid.
+            if (window.event.srcElement.tagName.toUpperCase() !== "IMG") {
+                var top = parseInt(window.event.srcElement.style.top, 10);
+                var left = parseInt(window.event.srcElement.style.left, 10);
+                currentPos = currentPos.plus(new Point(left, top));
+        return currentPos;
+     * converts the extent of the mapobject so that the maximum	extent will be displayed
+    this.calculateExtent = function(ext){
+        var relation_px_x = this.getWidth() / this.getHeight();
+        var relation_px_y = this.getHeight() / this.getWidth();
+        var relation_bbox_x = ext.extentx / ext.extenty;
+        if (relation_bbox_x <= relation_px_x) {
+            ext.minx = ext.centerx - relation_px_x * ext.extenty / 2;
+            ext.maxx = ext.centerx + relation_px_x * ext.extenty / 2;
+        if (relation_bbox_x > relation_px_x) {
+            ext.miny = ext.centery - relation_px_y * ext.extentx / 2;
+            ext.maxy = ext.centery + relation_px_y * ext.extentx / 2;
+        // Check if ext is within restricted extent
+        // If not, calculate a new extent according
+        // to restricted extent.
+         if ( this.restrictedExtent ) {
+         if ( ext.minx  < this.restrictedExtent.minx ) {
+         ext.minx = this.restrictedExtent.minx;
+         ext.maxx = ext.minx + (relation_px_x * ext.extenty);
+         if ( ext.miny < this.restrictedExtent.miny ) {
+         ext.miny = this.restrictedExtent.miny;
+         ext.maxy = ext.miny + (relation_px_y * ext.extentx);
+         if ( ext.maxx > this.restrictedExtent.maxx ) {
+         ext.maxx = this.restrictedExtent.maxx;
+         ext.minx = ext.maxx - (relation_px_x * ext.extenty);
+         if ( ext.maxy > this.restrictedExtent.maxy ) {
+         ext.maxy = this.restrictedExtent.maxy;
+         ext.miny = ext.maxy - (relation_px_y * ext.extentx);
+        this.setExtent(ext.minx, ext.miny, ext.maxx, ext.maxy);
+        return ext;
+    var ignoredWms;
+    var undoIgnoreWms = function(){
+        ignoredWms = [];
+    var ignoreWms = function(wms){
+        ignoredWms.push({
+            id: wms.wms_id,
+            title: wms.wms_title
+    var isIgnoredWms = function(wms){
+        for (var j = 0; j < ignoredWms.length; j++) {
+            if (ignoredWms[j].id === wms.wms_id) {
+                return true;
+        return false;
+    var getIgnoredWms = function(){
+        return ignoredWms;
+    this.setSrs = function(options){
+        if (typeof options.srs !== "string") {
+            new Mb_exception("Mapbender.Map.setSrs: SRS is not a string: " + options.srs);
+            return null;
+        if (!options.extent || options.extent.constructor !== Mapbender.Extent) {
+            new Mb_exception("Mapbender.Map.setSrs: Extent is not a Mapbender.Extent: " + options.extent);
+            return null;
+        if (this.epsg !== options.srs) {
+            // check which WMS support the new SRS
+            undoIgnoreWms();
+            for (var i = 0; i < this.wms.length; i++) {
+                var found = false;
+                for (var j = 0; j < this.wms[i].gui_epsg.length; j++) {
+                    if (options.srs === this.wms[i].gui_epsg[j] && this.wms[i].gui_epsg_supported[j]) {
+                        found = true;
+                        break;
+                if (!found) {
+                    ignoreWms(this.wms[i]);
+            var ignoredWms = getIgnoredWms();
+            // ...and optionally display a message
+            if (options.displayWarning && ignoredWms.length > 0) {
+                var msg = mapMsgObj.srsNotSupported + ": <br><br>";
+                for (var key in ignoredWms) {
+                    msg += "<b>" + ignoredWms[key].title + "</b><br>";
+                try {
+                    Mapbender.modules.dialogManager.openDialog({
+                        content: msg,
+                        modal: false,
+                        effectShow: 'puff'
+                catch (e) {
+                    new Mb_warning(e.message + ". " + msg);
+            // actually set the new values and return extent
+            this.epsg = options.srs;
+        return this.calculateExtent(options.extent);
+    this.setWms = function(wms_index){
+        this.wms = [];
+        var index = 0;
+        for (var i = 0; i < wms.length; i++) {
+            var isValidWms = (wms_index === null) || (wms_index == i);
+            if (isValidWms) {
+                // MAJOR CHANGE!
+                // formerly, this was a reference!
+                // Now, this is a copy!
+                // Each map object has its own set of WMS.
+                // I expect some things to break :-)
+                this.wms[index] = cloneObject(wms[i]);
+                this.wms[index].mapURL = false;
+                index++;
+    this.initializeWms = function(){
+        var cnt_layers;
+        var cnt_querylayers;
+        var styles;
+        var layers;
+        var querylayers = "";
+        for (i = 0; i < this.wms.length; i++) {
+            cnt_layers = 0;
+            cnt_querylayers = 0;
+            styles = "";
+            layers = "";
+            querylayers = "";
+            for (var ii = 0; ii < this.wms[i].objLayer.length; ii++) {
+                // layer is visible and not root layer
+                if (this.wms[i].objLayer[ii].gui_layer_visible == 1 && ii > 0) {
+                    if (cnt_layers > 0) {
+                        layers += ",";
+                        styles += ",";
+                    layers += this.wms[i].objLayer[ii].layer_name;
+                    styles += "";
+                    cnt_layers++;
+                // layer is queryable and not root layer
+                if (this.wms[i].objLayer[ii].gui_layer_querylayer == 1 && ii > 0) {
+                    if (cnt_querylayers > 0) {
+                        querylayers += ",";
+                    querylayers += this.wms[i].objLayer[ii].layer_name;
+                    cnt_querylayers++;
+            this.layers[i] = layers;
+            this.styles[i] = styles;
+            this.querylayers[i] = querylayers;
+     * get the extent of the mapObj
+     * @member Map
+     * @return extent of the mapObj as commaseparated minx,minx,maxx,maxy
+     * @type string
+    this.getExtent = function(){
+        return this.extent.toString();
+     * get the extent as minx, maxx, miny, maxy
+     * @return extent and additional informations of the mapObj
+     * @type Object
+    this.getExtentInfos = function(){
+        var c = this.extent.toString().split(",");
+        var ext = new Mapbender.Extent(c[0], c[1], c[2], c[3]);
+        return ext;
+     * Sets the list of layers, styles and querylayers for a specified WMS
+    this.restateLayers = function(wms_id){
+            if (this.wms[i].wms_id == wms_id) {
+                var currentWms = this.wms[i];
+                var cnt_layers = 0;
+                var cnt_querylayers = 0;
+                var layers = "";
+                var styles = "";
+                for (var ii = 0; ii < currentWms.objLayer.length; ii++) {
+                    var currentLayer = currentWms.objLayer[ii];
+                    if (currentLayer.gui_layer_visible == 1 && !currentLayer.has_childs) {
+                            layers += ",";
+                            styles += ",";
+                        layers += currentLayer.layer_name;
+                        styles += "";
+                        cnt_layers++;
+                    if (currentLayer.gui_layer_querylayer == 1 && !currentLayer.has_childs) {
+                        querylayers += currentLayer.layer_name;
+        //		this.setExtent(ext.minx,ext.miny,ext.maxx,ext.maxy);
+     * @param {Object} direction
+    this.pan = function(direction){
+        var arrayBBox = this.getExtent().split(",");
+        var minx = parseFloat(arrayBBox[0]);
+        var miny = parseFloat(arrayBBox[1]);
+        var maxx = parseFloat(arrayBBox[2]);
+        var maxy = parseFloat(arrayBBox[3]);
+        var xtentx = maxx - minx;
+        var xtenty = maxy - miny;
+        var factor = 0.5;
+        switch (direction) {
+            case "NW":
+                minx -= (xtentx * factor);
+                maxx -= (xtentx * factor);
+                miny += (xtenty * factor);
+                maxy += (xtenty * factor);
+                break;
+            case "N":
+                break;
+            case "NE":
+                minx += (xtentx * factor);
+                maxx += (xtentx * factor);
+                break;
+            case "E":
+                break;
+            case "SE":
+                miny -= (xtenty * factor);
+                maxy -= (xtenty * factor);
+                break;
+            case "S":
+                break;
+            case "SW":
+                break;
+            case "W":
+                break;
+        this.setExtent(minx, miny, maxx, maxy);
+        //		this.restrictedExtent;
+        this.setMapRequest();
+    this.setCenter = function(aPoint){
+        this.extent.set(aPoint);
+        this.calculateExtent(this.extent);
+    this.zoomFull = function(){
+        if (this.restrictedExtent) {
+            this.calculateExtent(this.restrictedExtent);
+        else {
+            for (var i = 0; i < this.wms[0].gui_epsg.length; i++) {
+                if (this.epsg == this.wms[0].gui_epsg[i]) {
+                    var bbox_minx = parseFloat(this.wms[0].gui_minx[i]);
+                    var bbox_miny = parseFloat(this.wms[0].gui_miny[i]);
+                    var bbox_maxx = parseFloat(this.wms[0].gui_maxx[i]);
+                    var bbox_maxy = parseFloat(this.wms[0].gui_maxy[i]);
+                    var wmsExtent = new Mapbender.Extent(bbox_minx, bbox_miny, bbox_maxx, bbox_maxy);
+                    this.calculateExtent(wmsExtent);
+                    break;
+     * zoom the map with a zoomfactor and optional to x,y coords
+     * @param {boolean} in_ in = true, out = false
+     * @param {float} factor the zoomfactor 1 equals 100%
+     * @param {float} x center to x-position
+     * @param {float} y center to y-position
+    this.zoom = function(in_, factor, x, y){
+        factor = parseFloat(factor);
+        if (!in_) {
+            factor = 1 / factor;
+        var extent = this.getExtentInfos();
+        var distx = extent.maxx - extent.minx;
+        var disty = extent.maxy - extent.miny;
+        if (typeof x === "object" && x.constructor === Mapbender.Point) {
+            y = x.y;
+            x = x.x;
+        if (x && y) {
+            var centerx = parseFloat(x);
+            var centery = parseFloat(y);
+        else {
+            var centerx = extent.minx + distx / 2;
+            var centery = extent.miny + disty / 2;
+        var new_distx = distx / factor;
+        var new_disty = disty / factor;
+        var minx = centerx - new_distx / 2;
+        var miny = centery - new_disty / 2;
+        var maxx = centerx + new_distx / 2;
+        var maxy = centery + new_disty / 2;
+         if ( minx  < this.restrictedExtent.minx ) {
+         minx = this.restrictedExtent.minx;
+         maxx = minx + (relation_px_x * new_disty);
+         if ( miny < this.restrictedExtent.miny ) {
+         miny = this.restrictedExtent.miny;
+         maxy = miny + (relation_px_y * new_distx);
+         if ( maxx > this.restrictedExtent.maxx ) {
+         maxx = this.restrictedExtent.maxx;
+         minx = maxx - (relation_px_x * new_distx);
+         if ( maxy > this.restrictedExtent.maxy ) {
+         maxy = this.restrictedExtent.maxy;
+         miny = maxy - (relation_px_y * new_disty);
+    var performUnknownCalculation = function(value){
+        return Math.pow(10, (Math.round(Math.log(value) /
+        Math.log(10))));
+    this.convertPixelToReal = function(aPoint){
+        var minX = parseFloat(arrayBBox[0]);
+        var minY = parseFloat(arrayBBox[1]);
+        var maxX = parseFloat(arrayBBox[2]);
+        var maxY = parseFloat(arrayBBox[3]);
+        var xtentx = maxX - minX;
+        var xtenty = maxY - minY;
+        var deltaX = xtentx / this.width;
+        var deltaY = xtenty / this.height;
+        var roundx, roundy;
+        if (deltaX > 0) {
+            roundx = 1 / performUnknownCalculation(deltaX);
+        else {
+            roundx = performUnknownCalculation(deltaX);
+        if (deltaY > 0) {
+            roundy = 1 / performUnknownCalculation(deltaY);
+        else {
+            roundy = performUnknownCalculation(deltaY);
+        var posX = parseFloat(minX + (aPoint.x / this.width) * xtentx);
+        var posY = parseFloat(maxY - (aPoint.y / this.height) * xtenty);
+        posX = Math.round(posX * roundx) / roundx;
+        posY = Math.round(posY * roundy) / roundy;
+        return new Point(posX, posY);
+     * Convert real world coordinates to pixel coordinates
+    this.convertRealToPixel = function(aPoint){
+        var arrayBBox = this.extent.toString().split(",");
+        return new Point(Math.round((aPoint.x - minX) * this.width / (maxX - minX)), Math.round((maxY - aPoint.y) * this.height / (maxY - minY)));
+     * get the srs of the mapObj
+     * @return srs as epsg:number
+     * @type string
+    this.getSRS = function(){
+        return this.epsg;
+     * get all mapRequests
+     * @return array of mapRequests of this map object
+     * @type string[]
+    this.getMapRequests = function(){
+        var allRequests = [];
+        //loop through all wms to get the mapRequests
+            var currentRequest = this.wms[i].getMapRequest(this);
+            if (currentRequest) {
+                allRequests.push(currentRequest);
+        if (allRequests.length > 0) {
+            return allRequests;
+        return false;
+     * Return the map URL of the WMS at index i
+     * @param {Object} currentWmsIndex
+    this.getMapUrl = function(ii){
+        var currentWms = this.wms[ii];
+        var validLayers = currentWms.getLayers(this);
+        if (validLayers.length === 0) {
+            return false;
+        for (var i = 0; i < validLayers.length; i++) {
+            validLayers[i] = encodeURIComponent(validLayers[i]);
+        var layerNames = validLayers.join(",");
+        url = currentWms.wms_getmap;
+        url += mb_getConjunctionCharacter(currentWms.wms_getmap);
+        if (currentWms.wms_version == "1.0.0") {
+            url += "WMTVER=" + currentWms.wms_version + "&REQUEST=map&";
+        else {
+            url += "VERSION=" + currentWms.wms_version + "&REQUEST=GetMap&SERVICE=WMS&";
+        url += "LAYERS=" + layerNames + "&";
+        url += "STYLES=";
+        var layer = layerNames.split(",");
+        for (var j = 0; j < layer.length; j++) {
+            if (j > 0) {
+                url += ",";
+            if (currentWms.getCurrentStyleByLayerName(layer[j]) !== false &&
+            typeof currentWms.getCurrentStyleByLayerName(layer[j]) !== "undefined") {
+                url += currentWms.getCurrentStyleByLayerName(layer[j]);
+        url += "&";
+        url += "SRS=" + this.epsg + "&";
+        url += "BBOX=" + this.getExtent() + "&";
+        url += "WIDTH=" + this.width + "&";
+        url += "HEIGHT=" + this.height + "&";
+        url += "FORMAT=" + currentWms.gui_wms_mapformat + "&";
+        url += "BGCOLOR=0xffffff&";
+        if (currentWms.gui_wms_mapformat.search(/gif/i) > -1 ||
+        currentWms.gui_wms_mapformat.search(/png/i) > -1) {
+            url += "TRANSPARENT=TRUE&";
+        url += "EXCEPTIONS=" + currentWms.gui_wms_exceptionformat + "&";
+        // add vendor-specific
+        for (var v = 0; v < mb_vendorSpecific.length; v++) {
+            var functionName = 'setMapRequest';
+            var vendorSpecificString = eval(mb_vendorSpecific[v]);
+            // if eval doesn't evaluate a function, the result is undefined.
+            // Sometimes it is necessary not to evaluate a function, for
+            // example if you want to change a variable from the current
+            // scope (see mod_addSLD.php)
+            if (typeof(vendorSpecificString) != "undefined") {
+                url += vendorSpecificString + "&";
+        // add Filter
+        if (currentWms.wms_filter !== "") {
+            url += "&SLD=" + currentWms.wms_filter + "?id=" + mb_styleID + "&";
+        // add sld
+        if (currentWms.gui_wms_sldurl !== "") {
+            url += "&SLD=" + escape(currentWms.gui_wms_sldurl) + "&";
+        //remove the last ampersant (&) of the mapurl
+        url = url.substr(0, url.length - 1);
+        return url;
+     * get all featureInfoRequests
+     * @member Map
+     * @param float x the x-value of the click position in pixel
+     * @param float y the y-value of the click position in pixel
+     * @return array of all featureInfoRequests of this map object
+     * @type string[]
+    this.getFeatureInfoRequests = function(clickPoint, ignoreWms){
+        //loop through all wms to get the FeatureInfoRequests
+            var ignoreThisWms = false;
+            if (typeof ignoreWms !== "undefined" &&
+            ignoreWms.constructor === Array) {
+                for (var j = 0; j < ignoreWms.length; j++) {
+                    if (ignoreWms[j] == this.wms[i].wms_id) {
+                        ignoreThisWms = true;
+                        break;
+            if (!ignoreThisWms) {
+                var currentRequest = this.wms[i].getFeatureInfoRequest(this, clickPoint);
+        return false;
+     * calculation of the mapscale
+     * @member Map
+     * @return scale
+     * @type integer
+    this.getScale = function(){
+        var scale;
+        var bbox = this.extent.toString().split(",");
+        var xtenty;
+        if (this.epsg == "EPSG:4326") {
+            var pxLenx = (parseFloat(bbox[2]) - parseFloat(bbox[0])) / this.width;
+            var pxLeny = (parseFloat(bbox[3]) - parseFloat(bbox[1])) / this.height;
+            var lat_from = ((parseFloat(bbox[3]) - parseFloat(bbox[1]) / 2) * Math.PI) / 180;
+            var lat_to = ((parseFloat(bbox[3]) - parseFloat(bbox[1]) / 2 + pxLeny) * Math.PI) / 180;
+            var lon_from = ((parseFloat(bbox[2]) - parseFloat(bbox[0]) / 2) * Math.PI) / 180;
+            var lon_to = ((parseFloat(bbox[2]) - parseFloat(bbox[0]) / 2 + pxLeny) * Math.PI) / 180;
+            var dist = 6371229 * Math.acos(Math.sin(lat_from) * Math.sin(lat_to) + Math.cos(lat_from) * Math.cos(lat_to) * Math.cos(lon_from - lon_to));
+            scale = (dist / Math.SQRT2) * (mb_resolution * 100);
+        else {
+            xtenty = parseFloat(bbox[3]) - parseFloat(bbox[1]);
+            scale = (xtenty / this.height) * (mb_resolution * 100);
+        return parseInt(Math.round(scale), 10);
+    this.checkScale = function(wmsIndex){
+        var thisLayer = this.layers[wmsIndex].split(",");
+        var thisScale = this.getScale();
+        var str_layer = "";
+        var cnt_layer = 0;
+        for (var i = 0; i < this.wms[wmsIndex].objLayer.length; i++) {
+            var currentLayer = this.wms[wmsIndex].objLayer[i];
+            var myLayername = currentLayer.layer_name;
+            var myMinscale = currentLayer.gui_layer_minscale;
+            var myMaxscale = currentLayer.gui_layer_maxscale;
+            for (var ii = 0; ii < thisLayer.length; ii++) {
+                if (thisLayer[ii] == myLayername && !currentLayer.has_childs) {
+                    if (myMinscale !== 0 && thisScale < myMinscale) {
+                        continue;
+                    if (myMaxscale !== 0 && thisScale > myMaxscale) {
+                        continue;
+                    if (cnt_layer > 0) {
+                        str_layer += ",";
+                    str_layer += thisLayer[ii];
+                    cnt_layer++;
+        var str_layerstyles = [];
+        str_layerstyles[0] = str_layer;
+        return str_layerstyles;
+    this.repaintScale = function(x, y, scale){
+        if (x === null && y === null) {
+            x = parseFloat(arrayBBox[0]) +
+            ((parseFloat(arrayBBox[2]) - parseFloat(arrayBBox[0])) /
+            2);
+            y = parseFloat(arrayBBox[1]) +
+            ((parseFloat(arrayBBox[3]) - parseFloat(arrayBBox[1])) /
+            2);
+        var minx = parseFloat(x) - (this.width / (mb_resolution * 100 * 2) * scale);
+        var miny = parseFloat(y) - (this.height / (mb_resolution * 100 * 2) * scale);
+        var maxx = parseFloat(x) + (this.width / (mb_resolution * 100 * 2) * scale);
+        var maxy = parseFloat(y) + (this.height / (mb_resolution * 100 * 2) * scale);
+        this.repaint(new Point(minx, miny), new Point(maxx, maxy));
+    this.repaint = function(min, max){
+        if (typeof min !== "undefined" && typeof max !== "undefined") {
+            this.extent = this.calculateExtent(new Extent(min, max));
+    this.setSingleMapRequest = function(wms_id){
+        eventBeforeMapRequest.trigger({
+            map: this
+        var ts = mb_timestamp();
+        for (var ii = 0; ii < this.wms.length; ii++) {
+            try {
+                if (this.skipWmsIfSrsNotSupported && isIgnoredWms(currentWms)) {
+                    continue;
+            catch (e) {
+                new Mb_warning(e.message);
+            if (currentWms.wms_id != wms_id) {
+                continue;
+            var newMapRequest = getLayerHtmlCode(ii);
+            if (Mapbender.log) {
+                var tmp = eval(Mapbender.log + "('" +
+                newMapURL +
+                ts +
+            var myDivId = this.elementName + "_div_" + ii;
+            var $wmsDiv = $("#" + myDivId);
+            if ($wmsDiv.size() > 0) {
+                $wmsDiv.remove();
+            var $newDiv = $(newMapRequest);
+            $("#" + this.elementName + "_maps").append($newDiv);
+            var myMapId = this.elementName + "_map_" + ii;
+            eventAfterMapRequest.trigger({
+                map: this,
+                myMapId: myMapId,
+                url: [this.getMapUrl(ii)]
+            this.afterMapRequest.trigger({
+                map: this,
+                myMapId: myMapId,
+            return true;
+        return false;
+    this.mb_setFutureObj = function(mod_back_cnt){
+        var cnt = this.mb_MapFutureObj.length;
+        this.mb_MapFutureObj[cnt] = {};
+        this.mb_MapFutureObj[cnt].reqCnt = mod_back_cnt;
+        this.mb_MapFutureObj[cnt].width = this.width;
+        this.mb_MapFutureObj[cnt].height = this.height;
+        this.mb_MapFutureObj[cnt].epsg = this.epsg;
+        this.mb_MapFutureObj[cnt].extent = this.extent;
+        this.mb_MapFutureObj[cnt].layers = [];
+        for (var i = 0; i < this.layers.length; i++) {
+            this.mb_MapFutureObj[cnt].layers[i] = this.layers[i];
+        this.mb_MapFutureObj[cnt].styles = [];
+        for (var i = 0; i < this.styles.length; i++) {
+            this.mb_MapFutureObj[cnt].styles[i] = this.styles[i];
+        this.mb_MapFutureObj[cnt].querylayers = [];
+        for (var i = 0; i < this.querylayers.length; i++) {
+            this.mb_MapFutureObj[cnt].querylayers[i] = this.querylayers[i];
+    var drawMaps = function(idArray, index){
+		var numRequests = that.history.count();
+		var requestCnt = index;
+//		console.log(requestCnt + " - " + numRequests);
+		// existing history item
+		if (requestCnt + 1 < numRequests && numRequests > 1 || $("#" + that.elementName + "_request_" + requestCnt).size() > 0) {
+//			console.log("exist");
+	        $("#" + that.elementName + "_request_" + requestCnt).hide();
+			for (var i = 0; i < requestCnt; i++) {
+		        $("#" + that.elementName + "_request_" + i).hide();
-	this.initializeWms = function () {
-		var cnt_layers;
-		var cnt_querylayers;
-		var styles;
-		var layers;
-		var querylayers = "";
-		for (i = 0; i < this.wms.length; i++) {
-			cnt_layers = 0;
-			cnt_querylayers = 0;
-			styles = "";
-			layers = "";
-			querylayers = "";
-			for (var ii = 0; ii < this.wms[i].objLayer.length; ii++) {
-				// layer is visible and not root layer
-				if (this.wms[i].objLayer[ii].gui_layer_visible == 1 && ii > 0) {
-					if (cnt_layers > 0) {
-						layers += ",";
-						styles += ",";
-					layers += this.wms[i].objLayer[ii].layer_name;
-					styles += "";
-					cnt_layers++;
-				// layer is queryable and not root layer
-				if (this.wms[i].objLayer[ii].gui_layer_querylayer == 1 && ii > 0) {
-					if (cnt_querylayers > 0) {
-						querylayers += ",";
-					querylayers += this.wms[i].objLayer[ii].layer_name;
-					cnt_querylayers++;
+			for (var i = requestCnt + 1; i <= numRequests; i++) {
-			this.layers[i] = layers;
-			this.styles[i] = styles;
-			this.querylayers[i] = querylayers;
-	 * get the extent of the mapObj
-	 * @member Map
-	 * @return extent of the mapObj as commaseparated minx,minx,maxx,maxy
-	 * @type string
-	this.getExtent = function(){
-		return this.extent.toString();
-	 * get the extent as minx, maxx, miny, maxy
-	 * @return extent and additional informations of the mapObj
-	 * @type Object
-	this.getExtentInfos = function(){
-		var c = this.extent.toString().split(",");
-		var ext = new Mapbender.Extent(c[0], c[1], c[2], c[3]);
-		return ext;
-	 * Sets the list of layers, styles and querylayers for a specified WMS
-	this.restateLayers = function(wms_id){
-			if (this.wms[i].wms_id == wms_id) {
-				var currentWms = this.wms[i];
-				var cnt_layers = 0;
-				var cnt_querylayers = 0;
-				var layers = "";
-				var styles = "";
-				for (var ii = 0; ii < currentWms.objLayer.length; ii++) {
-					var currentLayer = currentWms.objLayer[ii];
-					if (currentLayer.gui_layer_visible == 1 && !currentLayer.has_childs) {
-							layers += ",";
-							styles += ",";
-						layers += currentLayer.layer_name;
-						styles += "";
-						cnt_layers++;
-					if (currentLayer.gui_layer_querylayer == 1 && !currentLayer.has_childs) {
-						querylayers += currentLayer.layer_name;
-//		this.setExtent(ext.minx,ext.miny,ext.maxx,ext.maxy);
-	 * @param {Object} direction
-	this.pan = function (direction) {
-		var arrayBBox = this.getExtent().split(",");
-		var minx = parseFloat(arrayBBox[0]);
-		var miny = parseFloat(arrayBBox[1]);
-		var maxx = parseFloat(arrayBBox[2]);
-		var maxy = parseFloat(arrayBBox[3]);
-		var xtentx = maxx - minx;
-		var xtenty =  maxy - miny;
-		var factor = 0.5;
-		switch (direction) {
-			case "NW" :
-				minx -= (xtentx * factor);
-				maxx -= (xtentx * factor);
-				miny += (xtenty * factor);
-				maxy += (xtenty * factor);
-				break;
-			case "N" :
-				break;
-			case "NE" :
-				minx += (xtentx * factor);
-				maxx += (xtentx * factor);
-				break;
-			case "E" :
-				break;
-			case "SE" :
-				miny -= (xtenty * factor);
-				maxy -= (xtenty * factor);
-				break;
-			case "S" :
-				break;
-			case "SW" :
-				break;
-			case "W" :
-				break;
-		this.setExtent(minx, miny, maxx, maxy);
-//		this.restrictedExtent;
-		this.setMapRequest();
-	this.setCenter = function (aPoint) {
-		this.extent.set(aPoint);
-		this.calculateExtent(this.extent);
-	this.zoomFull = function () {
-		if (this.restrictedExtent) {
-			this.calculateExtent(this.restrictedExtent);
+		// new history item
 		else {
-			for (var i = 0; i < this.wms[0].gui_epsg.length; i++) {
-				if (this.epsg == this.wms[0].gui_epsg[i]) {
-					var bbox_minx = parseFloat(this.wms[0].gui_minx[i]);
-					var bbox_miny = parseFloat(this.wms[0].gui_miny[i]);
-					var bbox_maxx = parseFloat(this.wms[0].gui_maxx[i]);
-					var bbox_maxy = parseFloat(this.wms[0].gui_maxy[i]);
-					var wmsExtent = new Mapbender.Extent(bbox_minx, bbox_miny, bbox_maxx, bbox_maxy);
-					this.calculateExtent(wmsExtent);
-					break;
-	 * zoom the map with a zoomfactor and optional to x,y coords
-	 * @param {boolean} in_ in = true, out = false
-	 * @param {float} factor the zoomfactor 1 equals 100%
-	 * @param {float} x center to x-position
-	 * @param {float} y center to y-position
-	this.zoom = function(in_, factor, x, y){
-		factor = parseFloat(factor);
-		if (!in_) {
-			factor = 1 / factor;
-		var extent = this.getExtentInfos();
-		var distx = extent.maxx - extent.minx;
-		var disty = extent.maxy - extent.miny;
-		if (typeof x === "object" && x.constructor === Mapbender.Point) {
-			y = x.y;
-			x = x.x;
-		if (x && y) {
-			var centerx = parseFloat(x);
-			var centery = parseFloat(y);
-		else {
-			var centerx = extent.minx + distx / 2;
-			var centery = extent.miny + disty / 2;
-		var new_distx = distx / factor;
-		var new_disty = disty / factor;
-		var minx = centerx - new_distx / 2;
-		var miny = centery - new_disty / 2;
-		var maxx = centerx + new_distx / 2;
-		var maxy = centery + new_disty / 2;
-			if ( minx  < this.restrictedExtent.minx ) {
-	            minx = this.restrictedExtent.minx;
-	            maxx = minx + (relation_px_x * new_disty);
+//			console.log("new");
+	        var newMapRequest = "";
+	        for (var i = 0; i < idArray.length; i++) {
+	            newMapRequest += getLayerHtmlCode(idArray[i]);
-	        if ( miny < this.restrictedExtent.miny ) {
-	            miny = this.restrictedExtent.miny;
-	            maxy = miny + (relation_px_y * new_distx);
-	        if ( maxx > this.restrictedExtent.maxx ) {
-	            maxx = this.restrictedExtent.maxx;
-	            minx = maxx - (relation_px_x * new_distx);
-	        if ( maxy > this.restrictedExtent.maxy ) {
-	            maxy = this.restrictedExtent.maxy;
-	            miny = maxy - (relation_px_y * new_disty);
-	var performUnknownCalculation = function (value) {
-		return Math.pow(10,(
-			Math.round(
-				Math.log(value)/
-				Math.log(10)
-	this.convertPixelToReal = function (aPoint) {
-		var minX = parseFloat(arrayBBox[0]);
-		var minY = parseFloat(arrayBBox[1]);
-		var maxX = parseFloat(arrayBBox[2]);
-		var maxY = parseFloat(arrayBBox[3]);
-		var xtentx = maxX - minX;
-		var xtenty = maxY - minY;
-		var deltaX = xtentx/this.width;
-		var deltaY = xtenty/this.height;
-		var roundx, roundy;
-		if(deltaX > 0){
-			roundx = 1/performUnknownCalculation(deltaX);
-		else{
-			roundx = performUnknownCalculation(deltaX);
-		if(deltaY > 0){
-			roundy = 1/performUnknownCalculation(deltaY);
-		else{
-			roundy =  performUnknownCalculation(deltaY);
-		var posX = parseFloat(minX + (aPoint.x / this.width) * xtentx);
-		var posY = parseFloat(maxY - (aPoint.y / this.height) * xtenty);
-		posX = Math.round(posX * roundx) / roundx;
-		posY = Math.round(posY * roundy) / roundy;
-		return new Point(posX, posY);
-	 * Convert real world coordinates to pixel coordinates
-	this.convertRealToPixel = function (aPoint) {
-		var arrayBBox = this.extent.toString().split(",");
-		return new Point(
-			Math.round((aPoint.x - minX) * this.width /(maxX - minX)),
-			Math.round((maxY - aPoint.y) * this.height/(maxY - minY))
-	 * get the srs of the mapObj
-	 * @return srs as epsg:number
-	 * @type string
-	this.getSRS = function(){
-		return this.epsg;
-	 * get all mapRequests
-	 * @return array of mapRequests of this map object
-	 * @type string[]
-	this.getMapRequests = function(){
-		var allRequests = [];
-		//loop through all wms to get the mapRequests
-			var currentRequest = this.wms[i].getMapRequest(this);
-			if (currentRequest) {
-				allRequests.push(currentRequest);
-		if (allRequests.length > 0) {
-			return allRequests;
-		return false;
-	 * Return the map URL of the WMS at index i
-	 * @param {Object} currentWmsIndex
-	this.getMapUrl = function(ii){
-		var currentWms = this.wms[ii];
-		var validLayers = currentWms.getLayers(this);
-		if(validLayers.length === 0) {
-			return false;
-		for (var i = 0; i < validLayers.length; i++) {
-			validLayers[i] = encodeURIComponent(validLayers[i]);
-		var layerNames = validLayers.join(",");
-		url = currentWms.wms_getmap;
-		url += mb_getConjunctionCharacter(currentWms.wms_getmap);
-		if (currentWms.wms_version == "1.0.0") {
-			url += "WMTVER=" + currentWms.wms_version + "&REQUEST=map&";
-		else {
-			url += "VERSION=" + currentWms.wms_version + "&REQUEST=GetMap&SERVICE=WMS&";
-		url += "LAYERS=" + layerNames + "&";
-		url += "STYLES=";
-		var layer = layerNames.split(",");
-		for (var j = 0; j < layer.length; j++) {
-			if (j > 0) {
-				url += ",";
+			var $currentRequest = $("<div id='" + that.elementName + "_request_" + (requestCnt) + "'></div>").hide().append($(newMapRequest));
-			if (currentWms.getCurrentStyleByLayerName(layer[j]) !== false &&
-				typeof currentWms.getCurrentStyleByLayerName(layer[j]) !== "undefined") {
-				url += currentWms.getCurrentStyleByLayerName(layer[j]);
+	        $("#" + that.elementName + "_maps").append($currentRequest);
+		        $("#" + that.elementName + "_request_" + i).hide().each(function () {
+					$(this).children().each(function () {
+						this.style.zIndex = this.style.zIndex - 1;
-		url += "&";
-		url += "SRS=" + this.epsg + "&";
-		url += "BBOX=" + this.getExtent() + "&";
-		url += "WIDTH=" + this.width + "&";
-		url += "HEIGHT=" + this.height + "&";
-		url += "FORMAT=" + currentWms.gui_wms_mapformat + "&";
-		url += "BGCOLOR=0xffffff&";
-		if (currentWms.gui_wms_mapformat.search(/gif/i) > -1 ||
-		currentWms.gui_wms_mapformat.search(/png/i) > -1) {
-			url += "TRANSPARENT=TRUE&";
-		url += "EXCEPTIONS=" + currentWms.gui_wms_exceptionformat + "&";
-		// add vendor-specific
-		for (var v = 0; v < mb_vendorSpecific.length; v++) {
-			var functionName = 'setMapRequest';
-			var vendorSpecificString = eval(mb_vendorSpecific[v]);
-			// if eval doesn't evaluate a function, the result is undefined.
-			// Sometimes it is necessary not to evaluate a function, for
-			// example if you want to change a variable from the current
-			// scope (see mod_addSLD.php)
-			if (typeof(vendorSpecificString) != "undefined") {
-				url += vendorSpecificString + "&";
-		// add Filter
-		if (currentWms.wms_filter !== "") {
-			url += "&SLD=" + currentWms.wms_filter + "?id=" + mb_styleID + "&";
-		// add sld
-		if (currentWms.gui_wms_sldurl !== "") {
-			url += "&SLD=" + escape(currentWms.gui_wms_sldurl) + "&";
-		//remove the last ampersant (&) of the mapurl
-		url = url.substr(0, url.length-1);
-		return url;
+    var displayMaps = function(index){
+        var ret = eventBeforeMapRequest.trigger({
+            map: that
+        }, "AND");
+        if (ret === false) {
+            return true;
+        var myMapId = [];
+        var mapUrlArray = [];
+        var visibleWms = [];
+        for (var ii = 0; ii < that.wms.length; ii++) {
+            var currentWms = that.wms[ii];
+            try {
+                if (that.skipWmsIfSrsNotSupported && isIgnoredWms(currentWms)) {
+                    new Mb_notice(currentWms.wms_title + " is ignored.");
+                    continue;
+            catch (e) {
+            if (!(currentWms.gui_wms_visible > 0)) {
+                new Mb_notice(currentWms.title + " is not visible, will not be requested.");
+                continue;
+            myMapId.push(that.elementName + "_map_" + ii);
+            mapUrlArray.push(that.getMapUrl(ii));
+            visibleWms.push(ii);
+        drawMaps(visibleWms, index);
+            map: that,
+            myMapId: myMapId.join(","),
+            url: mapUrlArray
+        that.afterMapRequest.trigger({
+            map: that,
+            url: mapUrlArray
+	var doAnimation = false;
-	 * get all featureInfoRequests
-	 * @member Map
-	 * @param float x the x-value of the click position in pixel
-	 * @param float y the y-value of the click position in pixel
-	 * @return array of all featureInfoRequests of this map object
-	 * @type string[]
-	this.getFeatureInfoRequests = function(clickPoint, ignoreWms){
-		//loop through all wms to get the FeatureInfoRequests
-			var ignoreThisWms = false;
-			if (typeof ignoreWms !== "undefined"
-				&& ignoreWms.constructor === Array) {
-				for (var j = 0; j < ignoreWms.length; j++) {
-					if (ignoreWms[j] == this.wms[i].wms_id) {
-						ignoreThisWms = true;
-						break;
-			if (!ignoreThisWms) {
-				var currentRequest = this.wms[i].getFeatureInfoRequest(this, clickPoint);
-		return false;
+	var animateMaps = function (index) {
+//		console.log(that.oldExtentPix);
+		if (doAnimation) {
+			$("#" + that.elementName + "_request_" + index).children().children().css({
+				visibility: "hidden"
+			}).load(function () {
+				this.style.visibility = "visible";
+			$("#" + that.elementName + "_request_" + index).css({
+				position: "absolute",
+				top: that.oldExtentPix.max.y,
+				left: that.oldExtentPix.min.x
+			}).show().animate({
+					left: "0px",
+					top: "0px"
+					duration: "slow"
-	 * calculation of the mapscale
-	 * @member Map
-	 * @return scale
-	 * @type integer
-	this.getScale = function(){
-		var scale;
-		var bbox = this.extent.toString().split(",");
-		var xtenty;
-		if (this.epsg == "EPSG:4326") {
-			var pxLenx = (parseFloat(bbox[2]) - parseFloat(bbox[0])) / this.width;
-			var pxLeny = (parseFloat(bbox[3]) - parseFloat(bbox[1])) / this.height;
-			var lat_from = ((parseFloat(bbox[3]) - parseFloat(bbox[1]) / 2) * Math.PI) / 180;
-			var lat_to = ((parseFloat(bbox[3]) - parseFloat(bbox[1]) / 2 + pxLeny) * Math.PI) / 180;
-			var lon_from = ((parseFloat(bbox[2]) - parseFloat(bbox[0]) / 2) * Math.PI) / 180;
-			var lon_to = ((parseFloat(bbox[2]) - parseFloat(bbox[0]) / 2 + pxLeny) * Math.PI) / 180;
-			var dist = 6371229 * Math.acos(Math.sin(lat_from) * Math.sin(lat_to) + Math.cos(lat_from) * Math.cos(lat_to) * Math.cos(lon_from - lon_to));
-			scale = (dist / Math.SQRT2) * (mb_resolution * 100);
-		else {
-			xtenty = parseFloat(bbox[3]) - parseFloat(bbox[1]);
-			scale = (xtenty / this.height) * (mb_resolution * 100);
-		return parseInt(Math.round(scale), 10);
-	this.checkScale = function(wmsIndex){
-		var thisLayer = this.layers[wmsIndex].split(",");
-		var thisScale = this.getScale();
-		var str_layer = "";
-		var cnt_layer = 0;
-		for (var i = 0; i < this.wms[wmsIndex].objLayer.length; i++) {
-			var currentLayer = this.wms[wmsIndex].objLayer[i];
-			var myLayername = currentLayer.layer_name;
+			// animate previous request div and images
+			var oldLLPix = that.convertRealToPixel(that.oldExtent.min);
+			var oldURPix = that.convertRealToPixel(that.oldExtent.max);
-			var myMinscale = currentLayer.gui_layer_minscale;
-			var myMaxscale = currentLayer.gui_layer_maxscale;
-			for (var ii = 0; ii < thisLayer.length; ii++) {
-				if (thisLayer[ii] == myLayername && !currentLayer.has_childs) {
-					if (myMinscale !== 0 && thisScale < myMinscale) {
-						continue;
-					if (myMaxscale !== 0 && thisScale > myMaxscale) {
-						continue;
-					if (cnt_layer > 0) {
-						str_layer += ",";
-					str_layer += thisLayer[ii];
-					cnt_layer++;
-		var str_layerstyles = [];
-		str_layerstyles[0] = str_layer;
-		return str_layerstyles;
+			var left = oldLLPix.x;
+			var top = oldURPix.y;
+			var width = oldURPix.x - oldLLPix.x;
+			var height = oldLLPix.y - oldURPix.y;
-	this.repaintScale = function(x, y, scale){
-		if (x === null && y === null) {
-			x = parseFloat(arrayBBox[0]) +
-			((parseFloat(arrayBBox[2]) - parseFloat(arrayBBox[0])) /
-			2);
-			y = parseFloat(arrayBBox[1]) +
-			((parseFloat(arrayBBox[3]) - parseFloat(arrayBBox[1])) /
-			2);
-		var minx = parseFloat(x) - (this.width / (mb_resolution * 100 * 2) * scale);
-		var miny = parseFloat(y) - (this.height / (mb_resolution * 100 * 2) * scale);
-		var maxx = parseFloat(x) + (this.width / (mb_resolution * 100 * 2) * scale);
-		var maxy = parseFloat(y) + (this.height / (mb_resolution * 100 * 2) * scale);
-		this.repaint(new Point(minx, miny), new Point(maxx, maxy));
-	this.repaint = function(min, max){
-		if (typeof min !== "undefined" && typeof max !== "undefined") {
-			this.extent = this.calculateExtent(new Extent(min, max));
-	this.setSingleMapRequest = function (wms_id) {
-		eventBeforeMapRequest.trigger({map:this});
-		var ts = mb_timestamp();
-		for (var ii = 0; ii < this.wms.length; ii++){
-			try {
-				if (this.skipWmsIfSrsNotSupported && isIgnoredWms(currentWms)) {
-					continue;
-			catch (e) {
-				new Mb_warning(e.message);
-			if (currentWms.wms_id != wms_id) {
-				continue;
-			var newMapRequest = getLayerHtmlCode(ii);
-			if (Mapbender.log) {
-				var tmp = eval(Mapbender.log + "('" +
-					newMapURL + "','" + ts + "')");
-			var myDivId = this.elementName + "_div_" + ii;
-			var $wmsDiv = $("#" + myDivId);
-			if ($wmsDiv.size() > 0) {
-				$wmsDiv.remove();
-			var $newDiv = $(newMapRequest);
-			$("#" + this.elementName + "_maps").append($newDiv);
-			var myMapId = this.elementName + "_map_" + ii;
-			eventAfterMapRequest.trigger({
-				map: this,
-				myMapId: myMapId,
-				url: [this.getMapUrl(ii)]
+			$("#" + that.elementName + "_request_" + (index-1)).css({
+				top: "0px",
+				left: "0px"
+				left: left + "px",
+				top: top + "px"
+				duration: "slow"
-			this.afterMapRequest.trigger({
-				map: this,
-				myMapId: myMapId,
-			return true;
-		return false;
-	this.mb_setFutureObj = function(mod_back_cnt){
-		var cnt = this.mb_MapFutureObj.length;
-		this.mb_MapFutureObj[cnt] = {};
-		this.mb_MapFutureObj[cnt].reqCnt = mod_back_cnt;
-		this.mb_MapFutureObj[cnt].width = this.width;
-		this.mb_MapFutureObj[cnt].height = this.height;
-		this.mb_MapFutureObj[cnt].epsg = this.epsg;
-		this.mb_MapFutureObj[cnt].extent = this.extent;
-		this.mb_MapFutureObj[cnt].layers = [];
-		for(var i=0; i<this.layers.length;i++){
-			this.mb_MapFutureObj[cnt].layers[i] = this.layers[i];
-		this.mb_MapFutureObj[cnt].styles = [];
-		for(var i=0; i < this.styles.length;i++){
-			this.mb_MapFutureObj[cnt].styles[i] = this.styles[i];
+		else {
+			$("#" + that.elementName + "_request_" + index).show();
-		this.mb_MapFutureObj[cnt].querylayers = [];
-		for(var i=0; i < this.querylayers.length; i++) {
-			this.mb_MapFutureObj[cnt].querylayers[i] = this.querylayers[i];
-	this.setMapRequest = function(){
-		var ret = eventBeforeMapRequest.trigger({
-				map: this
-			}, "AND");
-		if (ret === false) {
-			return true;
-		var myMapId = [];
-		var newMapRequest = "";
-		var mapUrlArray = [];
-		for (var ii = 0; ii < this.wms.length; ii++) {
-			try {
-					new Mb_notice(currentWms.wms_title + " is ignored.");
-					continue;
+    this.setMapRequest = function(){
+        // initialize history
+        (function(){
+            var extent = new Extent(that.extent);
+			if (typeof that.oldExtent === "undefined") {
+				that.setExtent(extent, false);
+				displayMaps(0);
+				animateMaps(0);
-			catch (e) {
-			if (!(currentWms.gui_wms_visible > 0)) {
-				new Mb_notice(currentWms.title + " is not visible, will not be requested.");
-				continue;
-			myMapId.push(this.elementName + "_map_" + ii);
-			newMapRequest += getLayerHtmlCode(ii);
-			mapUrlArray.push(this.getMapUrl(ii));
-		writeTag(this.frameName, this.elementName+"_maps", newMapRequest);
-			map: this,
-			myMapId: myMapId.join(","),
-			url: mapUrlArray
-			map: this,
-			url: mapUrlArray
-	var getLayerHtmlCode = function (ii) {
-		var currentWms = that.wms[ii];
-		var myDivId = that.elementName + "_div_" + ii;
-		var myMapId = that.elementName + "_map_" + ii;
-		//disable Layer which are out of scale
-		var validLayers = that.checkScale(ii);
-		var layerNames = validLayers.toString();
-		var newMapURL = false;
-		var opacityString = "";
-		if (that.layers[ii] !== "" && layerNames !== ''){
-			// get map URL
-			newMapURL = that.getMapUrl(ii);
-			var currentOpacity = currentWms.gui_wms_mapopacity;
-			if (currentOpacity != 1) {
-				opacityString += "opacity:" + currentOpacity + "; ";
-				opacityString += "Filter: Alpha(Opacity=" + currentOpacity*100 + "); ";
-				opacityString += "-moz-opacity:" + currentOpacity + " ; ";
-				opacityString += "-khtml-opacity:" + currentOpacity;
-		var imageString = "";
-		if (newMapURL) {
-			imageString = "<img id='"+myMapId+"' name='mapimage' ";
-			imageString += "src='" + newMapURL + "' ";
-			imageString += "width='"+that.width+"' ";
-			imageString += "height='"+that.height+"' ";
-			imageString += "border='0'>";
-		var newMapRequest = "<div id='"+myDivId+"' ";
-		newMapRequest += "style=\"position:absolute; top:0px; left:0px; ";
-//		newMapRequest += "style=\"";
-		newMapRequest += "z-index:" + ii + ";" + opacityString + "\">";
-		newMapRequest += imageString;
-		newMapRequest += "</div>";
-		that.mapURL[ii]= newMapURL;
-		currentWms.mapURL = newMapURL;
-		if (Mapbender.log && currentWms.mapURL) {
-		return newMapRequest;
-	this.getWmsIdByTitle = function (title) {
-		for (var i=0; i < this.wms.length; i++) {
-			if (this.wms[i].wms_title == title) {
-				return this.wms[i].wms_id;
-		return null;
-	this.getWmsIndexById = function (wms_id) {
-		for (var i=0; i< this.wms.length; i++){
-			if(this.wms[i].wms_id == wms_id){
-				return i;
-		return null;
-	this.getWmsById = function (wms_id) {
-				return this.wms[i];
-		return null;
-	this.removeWms = function (wmsIndex) {
-		var wms_ID = null;
-		var i;
-		var new_wmsarray = [];
-		var new_layerarray = [];
-		var new_querylayerarray = [];
-		var new_stylesarray = [];
-		var new_mapURLarray = [];
-			if (i != wmsIndex) {
-				new_wmsarray.push(this.wms[i]);
-				new_layerarray.push(this.layers[i]);
-				new_querylayerarray.push(this.querylayers[i]);
-				new_stylesarray.push(this.styles[i]);
-				new_mapURLarray.push(this.mapURL[i]);
 			else {
-				wms_ID = this.wms[i].wms_id;
+	            var oldExtent = new Extent(that.oldExtent);
+	            that.history.addItem({
+	                forward: function(setExtent){
+						var index = that.history.getCurrentIndex();
+//	                    console.log("FORWARD: " + that.history.getCurrentIndex());
+	                    if (typeof setExtent === "undefined" || setExtent === true) {
+							that.setExtent(extent);
+	        			displayMaps(index + 1);
+	        			animateMaps(index + 1);
+	                back: function(){
+//	                    console.log("BACK: " + that.history.getCurrentIndex());
+						that.setExtent(oldExtent);
+			            displayMaps(index);
+	        			animateMaps(index);
-		this.wms = new_wmsarray;
-		this.layers = new_layerarray;
-		this.querylayers = new_querylayerarray;
-		this.styles = new_stylesarray;
-		this.mapURL = new_mapURLarray;
-		var another_new_wmsarray = [];
-		for	(i = 0; i < window.wms.length; i++) {
-			if (window.wms[i].wms_id != wms_ID) {
-				another_new_wmsarray.push(window.wms[i]);
-		window.wms = another_new_wmsarray;
-	 * move a wms or layer
-	 * @param int wms_id id of wms to move
-	 * @param int layer_id id of layer to move
-	 * @return true of successful
-	 * @type boolean
-	this.move = function(wms_id, layer_id, moveUp){
-		var i,j;
-		for(i=0;i<this.wms.length;i++){
-			if (wms_id == this.wms[i].wms_id) {
-				break;
-		//check if only one wms is affected?
-		if (layer_id && layer_id != this.wms[i].objLayer[0].layer_id) {
-			return this.wms[i].moveLayer(layer_id, moveUp);
-		//else swap wms
-		j = i + (moveUp?-1:1);
-		if (!(i != j && i >= 0 && i < this.wms.length && j >= 0 && j < this.wms.length)) {
-			return false;
-		upper = this.wms[i];
-		this.wms[i] = this.wms[j];
-		this.wms[j] = upper;
-		var upperLayers = this.layers[i];
-		var upperStyles = this.styles[i];
-		var upperQuerylayers = this.querylayers[i];
-		this.layers[i] = this.layers[j];
-		this.styles[i] = this.styles[j];
-		this.querylayers[i] = this.querylayers[j];
-		this.layers[j] = upperLayers;
-		this.styles[j] = upperStyles;
-		this.querylayers[j] = upperQuerylayers;
-		return true;
-	this.getMousePos = function(e){
-		if(ie){
-				clickX = window.frames[fName].event.clientX;
-				clickY = window.frames[fName].event.clientY;
-			else{
-				clickX = event.clientX;
-				clickY = event.clientY;
-		else{
-			clickX = e.pageX;
-			clickY = e.pageY;
-		//remove divtag offset
-		clickX -= parseInt(this.getDomElement().style.left, 10);
-		clickY -= parseInt(this.getDomElement().style.top, 10);
-		return new Point(clickX, clickY);
-	var that = this;
-	// private
-	this.width = width;
-	// private
-	this.height = height;
-	this.frameName = frameName;
-	this.type = (frameName !== "") ? "IFRAME" : "DIV";
-	this.elementName = elementName;
-	this.mapURL = [];
-	ignoredWms = [];
-	this.layers = [];
-	this.styles = [];
-	this.querylayers = [];
-	this.geom = "";
-	this.gml = "";
-	this.wms = [];
-	var bbox_minx, bbox_miny, bbox_maxx, bbox_maxy;
-	 * Triggered after the map has been resized
-	this.eventResizeMap = new MapbenderEvent();
-	// Add pointers to WMS objects which are in this map.
-	// If wms_index is set (=map is overview), only this
-	// WMS is being pointed to.
-	this.setWms(wms_index);
-	// set list of visible layers, active querylayers
-	// and styles for each WMS in this map
-	this.initializeWms();
-	for (var i = 0; i < wms[0].gui_epsg.length; i++) {
-		if (wms[0].gui_wms_epsg == wms[0].gui_epsg[i]) {
-			bbox_minx = parseFloat(wms[0].gui_minx[i]);
-			bbox_miny = parseFloat(wms[0].gui_miny[i]);
-			bbox_maxx = parseFloat(wms[0].gui_maxx[i]);
-			bbox_maxy = parseFloat(wms[0].gui_maxy[i]);
-			break;
-	this.setSrs({
-		srs: wms[0].gui_wms_epsg,
-		extent: new Mapbender.Extent(
-			bbox_minx,
-			bbox_miny,
-			bbox_maxx,
-			bbox_maxy
-	this.afterMapRequest = new MapbenderEvent();
+		this.history.forward(false);
+    var getLayerHtmlCode = function(ii){
+        var myDivId = that.elementName + "_div_" + ii;
+        var myMapId = that.elementName + "_map_" + ii;
+        //disable Layer which are out of scale
+        var validLayers = that.checkScale(ii);
+        var layerNames = validLayers.toString();
+        var newMapURL = false;
+        var opacityString = "";
+        if (that.layers[ii] !== "" && layerNames !== '') {
+            // get map URL
+            newMapURL = that.getMapUrl(ii);
+            var currentOpacity = currentWms.gui_wms_mapopacity;
+            if (currentOpacity != 1) {
+                opacityString += "opacity:" + currentOpacity + "; ";
+                opacityString += "Filter: Alpha(Opacity=" + currentOpacity * 100 + "); ";
+                opacityString += "-moz-opacity:" + currentOpacity + " ; ";
+                opacityString += "-khtml-opacity:" + currentOpacity;
+        var imageString = "";
+        if (newMapURL) {
+            imageString = "<img id='" + myMapId + "' name='mapimage' ";
+            imageString += "src='" + newMapURL + "' ";
+            imageString += "width='" + that.width + "' ";
+            imageString += "height='" + that.height + "' ";
+            imageString += "border='0'>";
+        var newMapRequest = "<div id='" + myDivId + "' ";
+        newMapRequest += "style=\"position:absolute; top:0px; left:0px; ";
+        //		newMapRequest += "style=\"";
+        newMapRequest += "z-index:" + (2 * ii + 20) + ";" + opacityString + "\">";
+        newMapRequest += imageString;
+        newMapRequest += "</div>";
+        that.mapURL[ii] = newMapURL;
+        currentWms.mapURL = newMapURL;
+        if (Mapbender.log && currentWms.mapURL) {
+            newMapURL +
+            ts +
+        return newMapRequest;
+    this.getWmsIdByTitle = function(title){
+            if (this.wms[i].wms_title == title) {
+                return this.wms[i].wms_id;
+        return null;
+    this.getWmsIndexById = function(wms_id){
+                return i;
+        return null;
+    this.getWmsById = function(wms_id){
+                return this.wms[i];
+        return null;
+    this.removeWms = function(wmsIndex){
+        var wms_ID = null;
+        var i;
+        var new_wmsarray = [];
+        var new_layerarray = [];
+        var new_querylayerarray = [];
+        var new_stylesarray = [];
+        var new_mapURLarray = [];
+            if (i != wmsIndex) {
+                new_wmsarray.push(this.wms[i]);
+                new_layerarray.push(this.layers[i]);
+                new_querylayerarray.push(this.querylayers[i]);
+                new_stylesarray.push(this.styles[i]);
+                new_mapURLarray.push(this.mapURL[i]);
+            else {
+                wms_ID = this.wms[i].wms_id;
+        this.wms = new_wmsarray;
+        this.layers = new_layerarray;
+        this.querylayers = new_querylayerarray;
+        this.styles = new_stylesarray;
+        this.mapURL = new_mapURLarray;
+        var another_new_wmsarray = [];
+        for (i = 0; i < window.wms.length; i++) {
+            if (window.wms[i].wms_id != wms_ID) {
+                another_new_wmsarray.push(window.wms[i]);
+        window.wms = another_new_wmsarray;
+     * move a wms or layer
+     * @param int wms_id id of wms to move
+     * @param int layer_id id of layer to move
+     * @return true of successful
+     * @type boolean
+    this.move = function(wms_id, layer_id, moveUp){
+        var i, j;
+            if (wms_id == this.wms[i].wms_id) {
+                break;
+        //check if only one wms is affected?
+        if (layer_id && layer_id != this.wms[i].objLayer[0].layer_id) {
+            return this.wms[i].moveLayer(layer_id, moveUp);
+        //else swap wms
+        j = i + (moveUp ? -1 : 1);
+        if (!(i != j && i >= 0 && i < this.wms.length && j >= 0 && j < this.wms.length)) {
+            return false;
+        upper = this.wms[i];
+        this.wms[i] = this.wms[j];
+        this.wms[j] = upper;
+        var upperLayers = this.layers[i];
+        var upperStyles = this.styles[i];
+        var upperQuerylayers = this.querylayers[i];
+        this.layers[i] = this.layers[j];
+        this.styles[i] = this.styles[j];
+        this.querylayers[i] = this.querylayers[j];
+        this.layers[j] = upperLayers;
+        this.styles[j] = upperStyles;
+        this.querylayers[j] = upperQuerylayers;
+        return true;
+    this.getMousePos = function(e){
+        if (ie) {
+                clickX = window.frames[fName].event.clientX;
+                clickY = window.frames[fName].event.clientY;
+            else {
+                clickX = event.clientX;
+                clickY = event.clientY;
+        else {
+            clickX = e.pageX;
+            clickY = e.pageY;
+        //remove divtag offset
+        clickX -= parseInt(this.getDomElement().style.left, 10);
+        clickY -= parseInt(this.getDomElement().style.top, 10);
+        return new Point(clickX, clickY);
+    var that = this;
+    // private
+    this.width = width;
+    // private
+    this.height = height;
+    this.frameName = frameName;
+    this.type = (frameName !== "") ? "IFRAME" : "DIV";
+    this.elementName = elementName;
+    this.mapURL = [];
+    ignoredWms = [];
+    this.layers = [];
+    this.styles = [];
+    this.querylayers = [];
+    this.geom = "";
+    this.gml = "";
+    this.wms = [];
+    var bbox_minx, bbox_miny, bbox_maxx, bbox_maxy;
+     * Triggered after the map has been resized
+    this.eventResizeMap = new MapbenderEvent();
+    // Add pointers to WMS objects which are in this map.
+    // If wms_index is set (=map is overview), only this
+    // WMS is being pointed to.
+    this.setWms(wms_index);
+    // set list of visible layers, active querylayers
+    // and styles for each WMS in this map
+    this.initializeWms();
+    for (var i = 0; i < wms[0].gui_epsg.length; i++) {
+        if (wms[0].gui_wms_epsg == wms[0].gui_epsg[i]) {
+            bbox_minx = parseFloat(wms[0].gui_minx[i]);
+            bbox_miny = parseFloat(wms[0].gui_miny[i]);
+            bbox_maxx = parseFloat(wms[0].gui_maxx[i]);
+            bbox_maxy = parseFloat(wms[0].gui_maxy[i]);
+            break;
+    this.setSrs({
+        srs: wms[0].gui_wms_epsg,
+        extent: new Mapbender.Extent(bbox_minx, bbox_miny, bbox_maxx, bbox_maxy)
+    this.afterMapRequest = new MapbenderEvent();
-Mapbender.Map.prototype.getWfsConfIds = function (wfs_config) {
-	var db_wfs_conf_id = [];
-	var js_wfs_conf_id = [];
-	//search configurations that are selected (and in scale)
-	for (var i=0; i < this.wms.length; i++){
-		for(var ii=0; ii < this.wms[i].objLayer.length; ii++){
-			var o = this.wms[i].objLayer[ii];
-			if(o.gui_layer_wfs_featuretype != '' && o.gui_layer_querylayer == '1'){
-				if (!checkscale || o.checkScale(this)) {
-					db_wfs_conf_id[db_wfs_conf_id.length] = o.gui_layer_wfs_featuretype;
-	for(var i=0; i < db_wfs_conf_id.length; i++){
-		for(var ii=0; ii < wfs_config.length; ii++){
-			if(wfs_config[ii].wfs_conf_id == db_wfs_conf_id[i]){
-				js_wfs_conf_id[js_wfs_conf_id.length] = ii;
-				break;
-	return js_wfs_conf_id;
+Mapbender.Map.prototype.getWfsConfIds = function(wfs_config){
+    var db_wfs_conf_id = [];
+    var js_wfs_conf_id = [];
+    //search configurations that are selected (and in scale)
+            var o = this.wms[i].objLayer[ii];
+            if (o.gui_layer_wfs_featuretype != '' && o.gui_layer_querylayer == '1') {
+                if (!checkscale || o.checkScale(this)) {
+                    db_wfs_conf_id[db_wfs_conf_id.length] = o.gui_layer_wfs_featuretype;
+    for (var i = 0; i < db_wfs_conf_id.length; i++) {
+        for (var ii = 0; ii < wfs_config.length; ii++) {
+            if (wfs_config[ii].wfs_conf_id == db_wfs_conf_id[i]) {
+                js_wfs_conf_id[js_wfs_conf_id.length] = ii;
+                break;
+    return js_wfs_conf_id;
Modified: trunk/mapbender/http/javascripts/mod_box1.js
--- trunk/mapbender/http/javascripts/mod_box1.js	2009-11-09 17:07:53 UTC (rev 4968)
+++ trunk/mapbender/http/javascripts/mod_box1.js	2009-11-09 17:08:22 UTC (rev 4969)
@@ -141,7 +141,8 @@
 		topNode.style.width = "0px";
 		topNode.style.height = "0px";
 		topNode.style.overflow = "hidden";
-		topNode.style.zIndex = parseInt(map_el.style.zIndex, 10) + 1;
+//		topNode.style.zIndex = parseInt(map_el.style.zIndex, 10) + 1;
+		topNode.style.zIndex = 100;
 		topNode.style.visibility = "visible";
 		topNode.style.cursor = "crosshair";
 		topNode.style.backgroundColor = color;
Modified: trunk/mapbender/lib/extent.js
--- trunk/mapbender/lib/extent.js	2009-11-09 17:07:53 UTC (rev 4968)
+++ trunk/mapbender/lib/extent.js	2009-11-09 17:08:22 UTC (rev 4969)
@@ -101,6 +101,13 @@
 		return false;
+	var isExtent = function (param) {
+		if (typeof param === "object" && param.constructor === Mapbender.Extent) {
+			return true;
+		return false;
 	this.getSouthWest = function () {
 		return this.min;
@@ -109,7 +116,10 @@
 		return this.max;
-	if (isPoint(minx) && isPoint(miny) &&
+	if (isExtent(minx)) {
+		this.set(cloneObject(minx.min), cloneObject(minx.max));
+	else if (isPoint(minx) && isPoint(miny) &&
 		typeof maxx === "undefined" &&
 		typeof maxy === "undefined") {
@@ -124,4 +134,4 @@
Added: trunk/mapbender/lib/history.js
--- trunk/mapbender/lib/history.js	                        (rev 0)
+++ trunk/mapbender/lib/history.js	2009-11-09 17:08:22 UTC (rev 4969)
@@ -0,0 +1,63 @@
+Mapbender.History = function () {
+	var historyItemArray = [];
+	var currentIndex = 0;
+	this.events = {
+		beforeAdd : new Mapbender.Event(),
+		beforeBack : new Mapbender.Event(),
+		beforeForward : new Mapbender.Event(),
+		afterBack : new Mapbender.Event(),
+		afterForward : new Mapbender.Event()
+	this.getCurrentIndex = function () {
+		return currentIndex;
+	this.count = function () {
+		return historyItemArray.length;
+	this.addItem = function (obj) {
+		if (typeof obj == "object"
+		&& obj.back && typeof obj.back === "function"
+		&& obj.forward && typeof obj.forward === "function"
+			this.events.beforeAdd.trigger();
+			for (var i = currentIndex; i < historyItemArray.length; i++) {
+				delete historyItemArray[i];
+			historyItemArray.length = currentIndex;
+			historyItemArray.push({
+				back: obj.back,
+				forward: obj.forward,
+				data: obj.data
+			return true;
+		return false;
+	this.back = function (obj) {
+		if (currentIndex > 0) {
+			this.events.beforeBack.trigger();
+			currentIndex --;
+			historyItemArray[currentIndex].back(obj);
+//			console.log("BACK: " + historyItemArray[currentIndex].back);
+			this.events.afterBack.trigger();
+			return true;
+		return false;
+	this.forward = function (obj) {
+		if (currentIndex < historyItemArray.length) {
+			this.events.beforeForward.trigger();
+			historyItemArray[currentIndex].forward(obj);
+//			console.log("FORWARD: " + historyItemArray[currentIndex].forward);
+			currentIndex ++;
+			this.events.afterForward.trigger();
+			return true;
+		return false;
\ No newline at end of file
More information about the Mapbender_commits mailing list
