[Mapbender-commits] r4974 - in trunk/mapbender/http: classes javascripts php
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Wed Nov 11 12:00:37 EST 2009
Author: kmq
Date: 2009-11-11 12:00:34 -0500 (Wed, 11 Nov 2009)
New Revision: 4974
   trunk/mapbender/http/classes/class_wmc.php
   trunk/mapbender/http/javascripts/mod_savewmc.php
   trunk/mapbender/http/php/mod_savewmc_server.php
saving inspire categories in WMCs
Modified: trunk/mapbender/http/classes/class_wmc.php
--- trunk/mapbender/http/classes/class_wmc.php	2009-11-11 16:13:03 UTC (rev 4973)
+++ trunk/mapbender/http/classes/class_wmc.php	2009-11-11 17:00:34 UTC (rev 4974)
@@ -124,6 +124,8 @@
 	var $wmc_descriptionurl_format;
 	var $wmc_descriptionurl_type;
+	var $inspireCats;
 	public function __construct () {
 		$this->userId = Mapbender::session()->get("mb_user_id");
 		$this->wmc_id = time();
@@ -424,7 +426,13 @@
 					$v = array($this->xml, time(), $user->isPublic()?1:0, $this->wmc_abstract, $this->wmc_srs, $this->wmc_extent->minx, $this->wmc_extent->minx,
 						 $this->wmc_extent->maxx, $this->wmc_extent->maxy ,$this->userId, administration::convertOutgoingString($this->wmc_title),$row[2]);
 					$t = array("s", "s","i","s","s","i","i","i","i", "i", "s","s");
+					// need the database Id
 					$wmc_DB_ID = $row[3];
+					$delsql = "DELETE FROM wmc_md_topic_category WHERE fkey_wmc_id = $1;";
+					$delv = array($wmc_DB_ID);
+					$delt = array("s");
+					db_prep_query($delsql, $delv,$delt);
@@ -460,10 +468,13 @@
 			  else {
+				// because the wmc id is created each time a wmc is instantiated $this->wmc_id has nothing to do with the database wmc_id
+				// this is some duct tape to fix it :-(
+				// see also above where wmc_DB_ID is defined if we need to update
+				if(!isset($wmc_DB_ID)) { $wmc_DB_ID = $this->wmc_id; }
+				// update keywords
 			  	foreach($this->keyword as $keyword){
 					// if a keyword does not yet exist, create it
 			  		$keywordExistsSql = "SELECT keyword FROM keyword WHERE keyword = $1";
@@ -477,13 +488,9 @@
-					// because the wmc id is created each time a wmc is instantiated $this->wmc_id has nothing to do with the database wmc_id
-					// this is some duct tape to fix it :-(
-					// see also above where wmc_DB_ID is defined if we need to update
-					if(!isset($wmc_DB_ID)) { $wmc_DB_ID = $this->wmc_id; }
-					$keywordsql = "INSERT into wmc_keyword (fkey_keyword_id,fkey_wmc_id) SELECT keyword.keyword_id,$1 FROM keyword WHERE keyword = $2 AND NOT EXISTS (SELECT fkey_wmc_id FROM wmc_keyword	WHERE fkey_wmc_id = $3 );";
+					$keywordsql = "INSERT INTO wmc_keyword (fkey_keyword_id,fkey_wmc_id) SELECT keyword.keyword_id,$1 FROM keyword WHERE keyword = $2 AND NOT EXISTS (SELECT fkey_wmc_id FROM wmc_keyword	WHERE fkey_wmc_id = $3 );";
 					$v = array($wmc_DB_ID, $keyword,$wmc_DB_ID);
 					$t = array("s","s","s");
 					$res = db_prep_query($keywordsql, $v, $t);
@@ -491,6 +498,17 @@
+				// update categories
+				$this->inspireCats = $this->inspireCats? $this->inspireCats: array();
+				foreach($this->inspireCats as $catId)
+					$catSql = "INSERT INTO wmc_md_topic_category (fkey_wmc_id, fkey_md_topic_category_id) VALUES ($1,$2)";
+					$v = array($wmc_DB_ID, $catId);
+					$t = array("s","s");
+					$res = db_prep_query($catSql, $v, $t);
 				  $result["success"] = true;
 				  $msg = "WMC document '" . $this->wmc_title . "' has been saved.";
Modified: trunk/mapbender/http/javascripts/mod_savewmc.php
--- trunk/mapbender/http/javascripts/mod_savewmc.php	2009-11-11 16:13:03 UTC (rev 4973)
+++ trunk/mapbender/http/javascripts/mod_savewmc.php	2009-11-11 17:00:34 UTC (rev 4974)
@@ -110,7 +110,7 @@
 				$("#saveWMCForm form #inspire_cat :checkbox").each(function(){
 					if(!!$(this).attr('checked'))
-						inspire_cat[$(this).id] = true;
+						inspire_cat[$(this).attr('id')] = true;
@@ -118,6 +118,7 @@
 				attributes.title 	= $("#wmcname").val();
 				attributes.abstract = $("#wmcabstract").val();
 				attributes.keywords = $("#wmckeywords").val();
+				attributes.inspirecat = inspire_cat;
 				if (!!attributes.title) {
 					sendMapDataToServer(attributes, 0, (function(result, status) {
 						//alert(status + ": " + result);
Modified: trunk/mapbender/http/php/mod_savewmc_server.php
--- trunk/mapbender/http/php/mod_savewmc_server.php	2009-11-11 16:13:03 UTC (rev 4973)
+++ trunk/mapbender/http/php/mod_savewmc_server.php	2009-11-11 17:00:34 UTC (rev 4974)
@@ -77,13 +77,24 @@
 		$ajaxResponse->send();
 		exit;
+	foreach($mapObject as $map)
+		if (isset($mapObject->isOverview) && $mapObject->isOverview == "1") { continue; }
+		$wmc->wmc_extent  = $map->extent;
+		$wmc->wmc_srs	  = $map->epsg;
 	// make a keyword array here
 	$wmc->keyword = explode(" ",$attributes->keywords);
-	$wmc->wmc_extent  = $mapObject[0]->extent;
-	$wmc->wmc_srs	  = $mapObject[0]->epsg;
 	$wmc->wmc_abstract = $attributes->abstract;
+	$inspireCat = $attributes->inspirecat;
+	foreach($inspireCat as $cat)
+		$parts = explode("_",$cat);
+		$wmc->inspireCats[] =  $parts[0];
 	$result = $wmc->insert($overwrite);
 	$ajaxResponse->setSuccess(true);
 	$ajaxResponse->setResult($result);
More information about the Mapbender_commits mailing list
