[Mapbender-commits] r4982 - trunk/mapbender/http/javascripts
svn_mapbender at osgeo.org
Fri Nov 13 08:00:36 EST 2009
Author: christoph
Date: 2009-11-13 08:00:35 -0500 (Fri, 13 Nov 2009)
New Revision: 4982
trunk/mapbender/http/javascripts/mod_loadwmc.js
Modified: trunk/mapbender/http/javascripts/mod_loadwmc.js
--- trunk/mapbender/http/javascripts/mod_loadwmc.js 2009-11-13 12:59:30 UTC (rev 4981)
+++ trunk/mapbender/http/javascripts/mod_loadwmc.js 2009-11-13 13:00:35 UTC (rev 4982)
@@ -20,68 +20,115 @@
var checkLayerAvailability = typeof options.checkLayerAvailability !== "undefined"
&& options.checkLayerAvailability === 1 ? true : false;
+options.loadWmc = typeof options.loadWmc === "number" ? options.loadWmc : 1;
+options.mergeWmc = typeof options.mergeWmc === "number" ? options.mergeWmc : 1;
+options.appendWmc = typeof options.appendWmc === "number" ? options.appendWmc : 1;
+options.publishWmc = typeof options.publishWmc === "number" ? options.publishWmc : 0;
+options.showWmc = typeof options.showWmc === "number" ? options.showWmc : 1;
+options.openLayers = typeof options.openLayers === "number" ? options.openLayers : 1;
+options.deleteWmc = typeof options.deleteWmc === "number" ? options.deleteWmc : 1;
+options.uploadWmc = typeof options.uploadWmc === "number" ? options.uploadWmc : 1;
+options.listWmc = typeof options.listWmc === "number" ? options.listWmc : 1;
-$(this).click(function () {
- if (wmcPopup === null || !wmcPopup.isVisible()) {
- mod_loadwmc();
-}).mouseover(function () {
- if (options.src) {
- this.src = options.src.replace(/_off/, "_over");
-}).mouseout(function () {
- this.src = options.src;
+var tagName = this.tagName.toUpperCase();
+if (tagName === "IMG") {
+ $(this).click(function () {
+ if (wmcPopup === null || !wmcPopup.isVisible()) {
+ mod_loadwmc();
+ }).mouseover(function () {
+ if (options.src) {
+ this.src = options.src.replace(/_off/, "_over");
+ }).mouseout(function () {
+ this.src = options.src;
+else {
+ mod_loadwmc();
* is called when the load WMC button is pressed
function mod_loadwmc(){
- var initialHtml = "<div style='display:none' id='" + options.id + "_tabs'>" +
- "<ul>" +
- "<li><a href='#" + options.id + "_wmclist'>List</a></li>" +
- "<li><a href='#" + options.id + "_wmcUpload'>Upload</a></li>" +
- "</ul>" +
- "<div id='" + options.id + "_wmclist' >" +
- "<table width='100%' id='" + options.id + "_wmclist_table'>" +
- "<thead><tr>" +
- "<th>WMC name</td>" +
- "<th>last update</td>" +
- "<th>load</td>" +
- "<th>merge</td>" +
- "<th>append</td>" +
- "<th>public</td>" +
- "<th>show</td>" +
- "<th>OpenLayers</td>" +
- "<th>delete</td>" +
- "</thead></tr>" +
- "</table>" +
- "</div>" +
- "<div id='" + options.id + "_wmcUpload' >" +
- "</div>" +
+ var initialHtml = "<div style='display:none' id='" + options.id + "_tabs'>";
+ // add tabs if both modules are available
+ if (options.listWmc && options.uploadWmc) {
+ initialHtml += "<ul>" +
+ "<li><a href='#" + options.id + "_wmclist'>List</a></li>" +
+ "<li><a href='#" + options.id + "_wmcUpload'>Upload</a></li>" +
+ "</ul>";
+ if (options.listWmc || options.uploadWmc) {
+ // add listWMC if available
+ if (options.listWmc) {
+ initialHtml += "<div id='" + options.id + "_wmclist' >" +
+ "<table width='100%' id='" + options.id + "_wmclist_table'>" +
+ "<thead><tr>" +
+ "<th>WMC name</td>" +
+ "<th>last update</td>" +
+ "<th>created</td>";
+ initialHtml += options.loadWmc ? "<th>load</td>" : "";
+ initialHtml += options.mergeWmc ? "<th>merge</td>" : "";
+ initialHtml += options.appendWmc ? "<th>append</td>" : "";
+ initialHtml += options.publishWmc ? "<th>public</td>" : "";
+ initialHtml += options.showWmc ? "<th>show</td>" : "";
+ initialHtml += options.openLayers ? "<th>OpenLayers</td>" : "";
+ initialHtml += options.deleteWmc ? "<th>delete</td>" : "";
+ initialHtml += "</thead></tr>" +
+ "</table>" +
+ "</div>";
+ // add uploadWMC if available
+ if (options.uploadWmc) {
+ initialHtml += "<div id='" + options.id + "_wmcUpload' >" +
"</div>";
+ else {
+ return;
+ initialHtml += "</div>";
// creates a new pop up (if it doesn't already exist)
// the pop up allows you to load, append, merge,
// display and delete WMC documents
- if (wmcPopup === null) {
- wmcPopup = new mb_popup({
- title:options.currentTitle,
- width:750,
- height:500,
- top:50,
- left:100,
- html:initialHtml
+ if (tagName === "IMG") {
+ if (wmcPopup === null) {
+ wmcPopup = new mb_popup({
+ title: options.currentTitle,
+ width: 750,
+ height: 500,
+ top: 50,
+ left: 100,
+ html: initialHtml
+ // display the pop up
+ if (!wmcPopup.isVisible()) {
+ wmcPopup.setHtml(initialHtml);
+ wmcPopup.show();
- // display the pop up
- if (!wmcPopup.isVisible()) {
- wmcPopup.setHtml(initialHtml);
- wmcPopup.show();
+ else {
+ $("#" + options.id).html(initialHtml);
// get WMC data from server
@@ -116,186 +163,211 @@
var $td;
$tr.append($("<td>" + wmcObj.wmc[i].title + "</td>"));
$tr.append($("<td>" + wmcObj.wmc[i].timestamp + "</td>"));
+ $tr.append($("<td>" + wmcObj.wmc[i].timestamp_create + "</td>"));
- // Load WMC
- var $loadTd = appendTableCell({
- src: "../img/button_gray/wmc_load.png",
- title: "load this WMC",
- method: "loadWmc",
- message: "WMC has been loaded successfully.",
- parameters: {
- id:currentId
- callback: function (args) {
- if (constraintCheckRequired()) {
- checkConstraints(args, function (args) {
- executeJavaScript(args);
- return;
+ if (options.loadWmc) {
+ // Load WMC
+ var $loadTd = appendTableCell({
+ src: "../img/button_gray/wmc_load.png",
+ title: "load this WMC",
+ method: "loadWmc",
+ message: "WMC has been loaded successfully.",
+ parameters: {
+ id: currentId
+ callback: function(args){
+ if (constraintCheckRequired()) {
+ checkConstraints(args, function(args){
+ executeJavaScript(args);
+ return;
- $tr.append($loadTd);
+ $tr.append($loadTd);
- // Merge WMC
- var $mergeTd = appendTableCell({
- src: "../img/button_gray/wmc_merge.png",
- title: "merge WMC",
- method: "mergeWmc",
- message: "WMC has been merged successfully.",
- parameters:{
- id:currentId,
- extensionData:currentWmcExtensionData !== null ?
- currentWmcExtensionData : null,
- mapObject:mb_mapObj,
- generalTitle:"currentState"
- return;
+ if (options.mergeWmc) {
+ // Merge WMC
+ var $mergeTd = appendTableCell({
+ src: "../img/button_gray/wmc_merge.png",
+ title: "merge WMC",
+ method: "mergeWmc",
+ message: "WMC has been merged successfully.",
+ parameters: {
+ id: currentId,
+ extensionData: currentWmcExtensionData !== null ? currentWmcExtensionData : null,
+ mapObject: mb_mapObj,
+ generalTitle: "currentState"
+ return;
- $tr.append($mergeTd);
+ $tr.append($mergeTd);
- // Append WMC
- var $appendTd = appendTableCell({
- src: "../img/button_gray/wmc_append.png",
- title: "append WMC",
- method: "appendWmc",
- message: "WMC has been appended successfully.",
- parameters:{
- id:currentId,
- return;
+ if (options.appendWmc) {
+ // Append WMC
+ var $appendTd = appendTableCell({
+ src: "../img/button_gray/wmc_append.png",
+ title: "append WMC",
+ method: "appendWmc",
+ message: "WMC has been appended successfully.",
+ parameters: {
+ id: currentId,
+ return;
- $tr.append($appendTd);
+ $tr.append($appendTd);
- //WMC is Public
- var $publicTd = appendBoolTableCell({
- isPublic: isPublic,
- disabled: isDisabled,
- method: "setWMCPublic",
- parameters:{
- id:currentId
- callback: executeJavaScript
- $tr.append($publicTd);
+ if (options.publishWmc) {
+ //WMC is Public
+ var $publicTd = appendBoolTableCell({
+ isPublic: isPublic,
+ disabled: isDisabled,
+ method: "setWMCPublic",
+ parameters: {
+ id: currentId
+ callback: executeJavaScript
+ $tr.append($publicTd);
// Display WMC
- var $displayTd = appendTableCell({
- src: "../img/button_gray/wmc_xml.png",
- title: "display WMC XML",
- callback: function() {
- // create Popup
- if (wmcDisplayPopup === null) {
- wmcDisplayPopup = new mb_popup({
- title: "WMC Document",
- width:600,
- height:500,
- top:50,
- left:700,
- url:"../javascripts/mod_displayWmc.php?wmc_id=" + currentId
+ if (options.showWmc) {
+ var $displayTd = appendTableCell({
+ src: "../img/button_gray/wmc_xml.png",
+ title: "display WMC XML",
+ callback: function(){
+ // create Popup
+ if (wmcDisplayPopup === null) {
+ wmcDisplayPopup = new mb_popup({
+ title: "WMC Document",
+ width: 600,
+ height: 500,
+ top: 50,
+ left: 700,
+ url: "../javascripts/mod_displayWmc.php?wmc_id=" + currentId
+ else {
+ wmcDisplayPopup.setUrl("../javascripts/mod_displayWmc.php?wmc_id=" + currentId + "&" + mb_session_name + "=" + mb_nr);
+ wmcDisplayPopup.show();
- else {
- wmcDisplayPopup.setUrl("../javascripts/mod_displayWmc.php?wmc_id=" + currentId + "&" + mb_session_name + "=" + mb_nr);
+ $tr.append($displayTd);
+ if (options.openLayers) {
+ // OpenLayers Export
+ var $openLayersTd = appendTableCell({
+ src: "../img/OpenLayers.trac.png",
+ title: "export to OpenLayers",
+ // create Popup
+ if (wmcOpenlayersPopup === null) {
+ wmcOpenlayersPopup = new mb_popup({
+ title: "OpenLayers",
+ width: 600,
+ height: 500,
+ top: 40,
+ left: 600,
+ url: "../php/mod_wmc2ol.php?wmc_id=" + currentId +
+ mb_session_name +
+ mb_nr
+ else {
+ // set correct URL
+ wmcOpenlayersPopup.setUrl("../php/mod_wmc2ol.php?wmc_id=" + currentId + "&" + mb_session_name + "=" + mb_nr);
+ wmcOpenlayersPopup.show();
- wmcDisplayPopup.show();
- $tr.append($displayTd);
- // OpenLayers Export
- var $openLayersTd = appendTableCell({
- src: "../img/OpenLayers.trac.png",
- title: "export to OpenLayers",
- callback: function () {
- // create Popup
- if (wmcOpenlayersPopup === null) {
- wmcOpenlayersPopup = new mb_popup({
- title: "OpenLayers",
- width: 600,
- height: 500,
- top: 40,
- left: 600,
- url: "../php/mod_wmc2ol.php?wmc_id=" + currentId +
- "&" + mb_session_name + "=" + mb_nr
- else {
- // set correct URL
- wmcOpenlayersPopup.setUrl("../php/mod_wmc2ol.php?wmc_id=" + currentId + "&" + mb_session_name + "=" + mb_nr);
- wmcOpenlayersPopup.show();
- $tr.append($openLayersTd);
+ $tr.append($openLayersTd);
- // delete WMC
- (function () {
- var $deleteTd = appendTableCell({
- src: isDisabled ? "../img/button_gray/del_disabled.png" : "../img/button_gray/del.png",
- title: "delete this WMC",
- method: "deleteWmc",
- if (!isDisabled && confirm("Do you really want to delete WMC '" + currentName + "'?")) {
- var aPos = wmcTable.fnGetPosition($deleteTd.get(0));
- wmcTable.fnDeleteRow(aPos[0]);
+ if (options.deleteWmc) {
+ // delete WMC
+ (function(){
+ var $deleteTd = appendTableCell({
+ src: isDisabled ? "../img/button_gray/del_disabled.png" : "../img/button_gray/del.png",
+ title: "delete this WMC",
+ method: "deleteWmc",
+ if (!isDisabled && confirm("Do you really want to delete WMC '" + currentName + "'?")) {
+ var aPos = wmcTable.fnGetPosition($deleteTd.get(0));
+ wmcTable.fnDeleteRow(aPos[0]);
+ parameters: {
+ id: currentId
- parameters:{
- id:currentId
- $tr.append($deleteTd);
+ $tr.append($deleteTd);
- $("#" + options.id + "_tabs").tabs();
+ $("#" + options.id + "_tabs").tabs();
- $("#" + options.id + "_wmcUpload").upload({
- callback: function (filename, success, message) {
- if (!success) {
- new Mb_exception(message);
- alert(message);
+ $("#" + options.id + "_wmcUpload").upload({
+ callback: function(filename, success, message){
+ if (!success) {
+ new Mb_exception(message);
+ alert(message);
+ executeJavaScript({
+ method: "loadWmcFromFile",
+ parameters: {
+ filename: filename
- executeJavaScript({
- method: "loadWmcFromFile",
- parameters: {
- filename: filename
- wmcTable = $("#" + options.id + "_wmclist_table").dataTable({
- "bPaginate": true,
- "bJQueryUI": true
+ wmcTable = $("#" + options.id + "_wmclist_table").dataTable({
+ "bPaginate": true,
+ "bJQueryUI": true
$("#" + options.id + "_tabs").css("display", "block");
@@ -319,9 +391,66 @@
checkLayerAvailability: checkLayerAvailability
callback: function (obj, result, message) {
- if (typeof callback === "function") {
- callback(args);
+ var html = "";
+ var constraintTypeArray = [];
+ for (var constraintType in obj) {
+ var caseObj = obj[constraintType];
+ if (caseObj.wms.length === 0) {
+ continue;
+ html += "<fieldset>" + caseObj.message + " Dienste trotzdem laden?<br><br>";
+ for (var index in caseObj.wms) {
+ var wms = caseObj.wms[index];
+ html += "<label for='" + constraintType + "_" + wms.index + "'>" +
+ "<input id='" + options.id + "_" + constraintType + "_" + wms.index + "' " +
+ "type='checkbox' />" + wms.title + "</label><br>";
+ html += "</fieldset><br>";
+ constraintTypeArray.push(constraintType);
+ $("<div id='" + options.id + "_constraint_form' title='Warning'>" +
+ "<style> fieldset label { display: block; }</style>" +
+ "<form>" + html + "</form></div>").dialog(
+ bgiframe: true,
+ autoOpen: false,
+ height: 400,
+ width: 500,
+ modal: true,
+ buttons: {
+ "Continue": function(){
+ var skipWmsArray = [];
+ for (var i in constraintTypeArray) {
+ var currentConstraint = constraintTypeArray[i];
+ var selector = options.id + "_" + currentConstraint + "_";
+ var context = $("#" + options.id + "_constraint_form").get(0);
+ $("input[id^='" + selector + "']", context).each(function () {
+ if (!this.checked) {
+ var regexp = new RegExp(selector);
+ var id = parseInt(this.id.replace(regexp, ""), 10);
+ skipWmsArray.push(id);
+ args.parameters.skipWms = skipWmsArray;
+ if (typeof callback === "function") {
+ callback(args);
+ $(this).dialog('close').remove();
+ "Cancel": function(){
+ $("#" + options.id + "_constraint_form").dialog('open');
req.send();
More information about the Mapbender_commits
