[Mapbender-commits] r4989 - branches/2.6/http/javascripts
svn_mapbender at osgeo.org
Mon Nov 16 05:10:10 EST 2009
Author: verenadiewald
Date: 2009-11-16 05:10:02 -0500 (Mon, 16 Nov 2009)
New Revision: 4989
branches/2.6/http/javascripts/map_obj.js
branches/2.6/http/javascripts/wms.js
possibility to add a vendor specific to getFeatureInfoRequest
Modified: branches/2.6/http/javascripts/map_obj.js
--- branches/2.6/http/javascripts/map_obj.js 2009-11-13 13:50:11 UTC (rev 4988)
+++ branches/2.6/http/javascripts/map_obj.js 2009-11-16 10:10:02 UTC (rev 4989)
@@ -648,6 +648,7 @@
// add vendor-specific
for (var v = 0; v < mb_vendorSpecific.length; v++) {
var functionName = 'setMapRequest';
+ var currentWms_wms_title = currentWms.wms_title;
var vendorSpecificString = eval(mb_vendorSpecific[v]);
// if eval doesn't evaluate a function, the result is undefined.
// Sometimes it is necessary not to evaluate a function, for
Modified: branches/2.6/http/javascripts/wms.js
--- branches/2.6/http/javascripts/wms.js 2009-11-13 13:50:11 UTC (rev 4988)
+++ branches/2.6/http/javascripts/wms.js 2009-11-16 10:10:02 UTC (rev 4989)
@@ -220,6 +220,25 @@
if(mb_feature_count > 0){
rq += "&FEATURE_COUNT="+mb_feature_count;
+ rq += "&";
+ // add vendor-specific
+ for (var v = 0; v < mb_vendorSpecific.length; v++) {
+ var functionName = 'setFeatureInfoRequest';
+ var currentWms_wms_title = this.wms_title;
+ var vendorSpecificString = eval(mb_vendorSpecific[v]);
+ // if eval doesn't evaluate a function, the result is undefined.
+ // Sometimes it is necessary not to evaluate a function, for
+ // example if you want to change a variable from the current
+ // scope (see mod_addSLD.php)
+ if (typeof(vendorSpecificString) != "undefined") {
+ rq += vendorSpecificString + "&";
+ if (this.wms_title == removeLayerAndStylesAffectedWMSTitle) {
+ rq = url.replace(/LAYERS=[^&]*&/, '');
+ rq = url.replace(/STYLES=[^&]*&/, '');
return rq;
More information about the Mapbender_commits
