[Mapbender-commits] r4994 - trunk/mapbender/http/html
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Mon Nov 16 10:04:28 EST 2009
Author: uli
Date: 2009-11-16 10:04:27 -0500 (Mon, 16 Nov 2009)
New Revision: 4994
   trunk/mapbender/http/html/mod_treefolderPlain.php
function handleSelectedLayer renamed: local_handleSelectedLayer
Modified: trunk/mapbender/http/html/mod_treefolderPlain.php
--- trunk/mapbender/http/html/mod_treefolderPlain.php	2009-11-16 13:26:09 UTC (rev 4993)
+++ trunk/mapbender/http/html/mod_treefolderPlain.php	2009-11-16 15:04:27 UTC (rev 4994)
@@ -421,7 +421,7 @@
-function handleSelectedLayer(mapObj,wms_id,layername,type,status){
+function local_handleSelectedLayer(mapObj,wms_id,layername,type,status){
 	if(lock_update||lock_check)return;
 	var ind =  getMapObjIndexByName(mapObj);
 	for(var i=0; i< mb_mapObj[ind].wms.length; i++){
@@ -701,9 +701,9 @@
 									if(temp.gui_layer_selectable!='1')
 										controls.push('disabled ');
-									controls.push("onclick=\"handleSelectedLayer('"+mod_treeGDE_map+"','"+ mb_mapObj[i].wms[ii].wms_id+"','"+temp.layer_name+"','visible',this.checked?1:0);");
+									controls.push("onclick=\"local_handleSelectedLayer('"+mod_treeGDE_map+"','"+ mb_mapObj[i].wms[ii].wms_id+"','"+temp.layer_name+"','visible',this.checked?1:0);");
 									if(ficheckbox == 'false')
-										controls.push("handleSelectedLayer('"+mod_treeGDE_map+"','"+ mb_mapObj[i].wms[ii].wms_id+"','"+temp.layer_name+"','querylayer',this.checked?1:0);");
+										controls.push("local_handleSelectedLayer('"+mod_treeGDE_map+"','"+ mb_mapObj[i].wms[ii].wms_id+"','"+temp.layer_name+"','querylayer',this.checked?1:0);");
 									controls.push("handleSelection('"+parentObj+parentLayer+"|"+temp.layer_id+"', 0);");
 									controls.push("updateParent('"+parentObj+parentLayer+"');\" />");
 									if(ficheckbox == 'true'){
@@ -712,7 +712,7 @@
 											controls.push('checked ');
 										if(temp.gui_layer_queryable!='1')
-										controls.push("onclick=\"handleSelectedLayer('"+mod_treeGDE_map+"','"+ mb_mapObj[i].wms[ii].wms_id+"','"+temp.layer_name+"','querylayer',this.checked?1:0);");
+										controls.push("onclick=\"local_handleSelectedLayer('"+mod_treeGDE_map+"','"+ mb_mapObj[i].wms[ii].wms_id+"','"+temp.layer_name+"','querylayer',this.checked?1:0);");
 										controls.push("handleSelection('"+parentObj+parentLayer+"|"+temp.layer_id+"', 1);\" />");
 									if(wmsbuttons == 'true'&&metadatalink == 'true'){
More information about the Mapbender_commits mailing list
