[Mapbender-commits] r5002 - in trunk/mapbender/http: javascripts php
svn_mapbender at osgeo.org
Tue Nov 17 11:24:19 EST 2009
Author: kmq
Date: 2009-11-17 11:24:19 -0500 (Tue, 17 Nov 2009)
New Revision: 5002
Added:
trunk/mapbender/http/javascripts/mod_wps_client.js
trunk/mapbender/http/php/mod_wps.php
create WPS requests. not quite done
Added: trunk/mapbender/http/javascripts/mod_wps_client.js
--- trunk/mapbender/http/javascripts/mod_wps_client.js (rev 0)
+++ trunk/mapbender/http/javascripts/mod_wps_client.js 2009-11-17 16:24:19 UTC (rev 5002)
@@ -0,0 +1,180 @@
+//make this php ?
+$('<div id="wpsClientDialog" title="WPS Client">\n\
+<style> fieldset ul { list-style-type: none; padding: 0em }\n\
+ fieldset li {padding-left: 0em; border-bottom: 1px dotted gray; }\n\
+ fieldset li label { min-width: 17em; display: inline-block;}\n\
+ fieldset li img { height: 1em; width: 1em;}\n\
+ fieldset input { width: 10em; }\n\
+ .validationError { visibility: hidden; color: red;}\n\
+}</style>\n\
+<form>\n\
+ <fieldset>\n\
+ <ul>\n\
+ <li>\n\
+ <label for="wps_interpol">interpolation system</label> \n\
+ <select id="wps_interpol">\n\
+ <option value="psgp">psgp</option>\n\
+ <option value="automap">automap</option>\n\
+ <option value="transGaussian">transGaussian</option>\n\
+ <option value="copula">copula</option>\n\
+ <option value="idw">idw</option>\n\
+ <option value="automatic">automatic</option>\n\
+ </select>\n\
+ </li>\n\
+<li> <label for="wps_maxcalctime">max. calculation time (minutes)</label><input id="wps_maxcalctime" type="text" class="text" /></li>\n\
+</ul>\n\
+ </fieldset>\n\
+ <fieldset>\n\
+<ul>\n\
+ <li> <label for="wps_mean"><input id="wps_mean" type="checkbox" checked="checked" disabled="disabled">mean</label>\n\
+ <img id="wps_cs_mean" src="../img/colorscheme_default.png" />\n\
+ <select id="wps_selectcs_mean">\n\
+ <option value="default" selected="selected" >default</option>\n\
+ <option value="2"> colorscheme 2</option>\n\
+ <option value="3"> colorscheme 3</option>\n\
+ </select>\n\
+ </li>\n\
+ <li><label for="wps_variance"><input id="wps_variance" type="checkbox" checked="checked" >variance</label>\n\
+ <select id="wps_selectcs_variance">\n\
+ </select>\n\
+ </li>\n\
+ <li><label for="wps_propability"><input id="wps_propability" type="checkbox" checked="checked" >propability</label>\n\
+ <img id="wps_cs_propability" src="../img/colorscheme_default.png" />\n\
+ <select id="wps_selectcs_propability">\n\
+ </select>\n\
+ </li>\n\
+ <li> <label for="wps_propability_limit">limit <span class="validationError">need a number</span></label><input id="wps_propability_limit" type="text" class="text"/></li>\n\
+</ul>\n\
+</fieldset>\n\
+<fieldset>\n\
+<ul>\n\
+ <li><label for="wps_clipping"><input id="wps_clipping" type="checkbox" checked="checked" >clipping</label></li>\n\
+ <li><label form="wps_image_format">format</label><select id="wps_image_format"><option selected="selected">image/jpeg</option><option>image/png</option></select></li>\n\
+</ul>\n\
+ </fieldset>\n\
+</form>\n\
+</div>').dialog({
+ bgiframe: true,
+ autoOpen: false,
+ height: 400,
+ width: 400,
+ modal: true,
+ buttons: {
+ "Save": function() {
+ * unklar:
+ $parameters['colorschema'] = isset($parameters['colorschema']) ? $parameters['colorschema'] : "";
+ var attributes = {
+ interpolationMethod: "automatic",
+ calculationTime: 12000,
+ propabilityLimit: 0,
+ clipping: true,
+ imageFormat:'image/jpeg',
+ predictionTypes: "Mean",
+ bbox: "",
+ bboxSRS:"",
+ mean_color: 'default',
+ variance_color: 'default',
+ propability_color: 'default',
+ attributes.interpolationMethod = $('#wps_interpol').val();
+ attributes.calculationTime = $('#wps_maxcalctime').val();
+ attributes.predictionTypes = (!!$('#wps_mean').attr('checked'))? "Mean,":"";
+ attributes.predictionTypes += (!!$('#wps_variance').attr('checked'))? "Variance,":""
+ attributes.predictionTypes += (!!$('#wps_propability').attr('checked'))? "Propability,":""
+ //cut off trailing ,
+ attributes.predictionTypes = attributes.predictionTypes.slice(0,attributes.predictionTypes.length -1)
+ attributes.mean_color = $('#wps_selectcs_mean').val();
+ attributes.variance_color = $('#wps_selectcs_variance').val();
+ attributes.propability_color= $('#wps_selectcs_propability').val();
+ attributes.propabilityLimit = $('#wps_propability_limit').val();
+ attributes.clipping = (!!$('#wps_clipping').attr('checked'))? true: false;
+ attributes.imageFormat = $('#wps_image_format').val();
+ attributes.bbox = mb_mapObj[0].getExtent();
+ attributes.bboxSRS = mb_mapObj[0].getSRS();
+ //validation
+ var numeric = /[0-9]+/
+ if (!attributes.propabilityLimit.match(numeric)){
+ $('[for=wps_propability_limit] span.validationError').css('visibility','visible');
+ return;
+ }else{
+ $('[for=wps_propability_limit] span.validationError').css('visibility','hidden');
+ var req = new Mapbender.Ajax.Request({
+ url: "../php/mod_wps.php",
+ method: "createWPSRequest",
+ parameters : {
+ attributes:attributes,
+ callback: (function(result,success,message){
+ $('<div><textarea><![CDATA['+ result + ']]></textarea></div>').dialog({autoOpen: true, height: 200, width:300});
+ req.send();
+ $(this).dialog('close');
+ $('#wpsClientDialog form')[0].reset()
+ // also reset colorscheme indicators
+ $('#wpsClientDialog form img').attr('src','../img/colorscheme_default.png');
+ $('span.validationError').css('visibility','hidden');
+ "Cancel": function() {
+var change_cs_indicator = function(){
+ var map = {
+ csdefault: '../img/colorscheme_default.png',
+ cs2: '../img/colorscheme_2.png',
+ cs3: '../img/colorscheme_3.png'
+ var key = 'cs'+$(this).val();
+ try{
+ var src = map[key];
+ } catch (e){
+ var src = map['csdefault'];
+ $(this).prev().attr('src',src);
+$('#wps_selectcs_mean').change(change_cs_indicator );
+$('#wps_selectcs_variance').change(change_cs_indicator );
+$('#wps_selectcs_propability').change(change_cs_indicator );
+$('#wps_interpol').change((function(){
+ if($(this).val() == 'idw'){
+ $('#wps_variance').attr('checked','');
+ $('#wps_variance').attr('disabled','disabled');
+ }else{
+ $('#wps_variance').attr('checked','checked');
+ $('#wps_variance').attr('disabled','');
+$('#wpsClient').click(function(){
+ $('#wpsClientDialog').dialog('open');
Added: trunk/mapbender/http/php/mod_wps.php
--- trunk/mapbender/http/php/mod_wps.php (rev 0)
+++ trunk/mapbender/http/php/mod_wps.php 2009-11-17 16:24:19 UTC (rev 5002)
@@ -0,0 +1,87 @@
+<?php
+require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
+require_once(dirname(__FILE__)."/../classes/class_json.php");
+$ajaxResponse = new AjaxResponse($_POST);
+switch($ajaxResponse->getMethod())
+ case "createWPSRequest":
+ $templatefilePath = realpath(dirname(__FILE__)."/../../resources/wps_template.xml");
+ $parameters = $ajaxResponse->getParameter('attributes');
+ try{
+ $result = createWPSRequest($parameters,$templatefilePath);
+ $ajaxResponse->setSuccess(true);
+ $ajaxResponse->setResult($result);
+ }catch(Exception $E){
+ $ajaxResponse->setMessage($E->getMessage);
+ break;
+ default:
+ $ajaxResponse->setSuccess(false);
+ $ajaxResponse->setMessage("method invalid");
+$ajaxResponse->send();
+* @params parameters an assoc array containing parameters with wich to create a WPS request
+* @return a WPS XML document
+function createWPSRequest($parameters,$templatefilePath)
+ // check and give parameters default values
+ // need this collection to be subscriptable
+ $parray['interpolationMethod'] = isset($parameters->interpolationMethod) ? $parameters->interpolationMethod : "automatic";
+ $parray['calculationTime'] = isset($parameters->calculationTime) ? $parameters->calculationTime : "120000";
+ $parray['predictionTypes'] = isset($parameters->predictionTypes) ? $parameters->predictionTypes : "Mean";
+ $parray['propabilityLimit'] = isset($parameters->propabilityLimit) ? $parameters->propabilityLimit : "35i.4";
+ $parray['featureCollectionURL'] = isset($parameters->featureCollectionURL) ? $parameters->featureCollectionURL : ""; //FIXME:
+ $parray['wfsURL'] = isset($parameters->wfsURL) ? $parameters->wfsURL : ""; //FIXME
+ $parray['featureType'] = isset($parameters->featureType) ? $parameters->featureType : ""; //FIXME
+ $parray['time'] = isset($parameters->time) ? $parameters->time : date("c") ; //default to current time
+ $parray['wpsURL'] = isset($parameters->wpsURL) ? $parameters->wpsURL : "";
+ $parray['outlierDetection'] = isset($parameters->outlierDetection) ? $parameters->outlierDetection : "true";
+ $parray['clipping'] = isset($parameters->clipping) ? $parameters->clipping : "true";
+ $parray['colorschema'] = isset($parameters->colorschema) ? $parameters->colorschema : "";
+ $parray['imageFormat'] = isset($parameters->imageFormat) ? $parameters->imageFormat : "image/jpeg";
+ $parray['bboxSRS'] = isset($parameters->bboxSRS) ? $parameters->bboxSRS : "";
+ $parray['bbox'] = isset($parameters->bbox) ? $parameters->bbox : "";
+ $parray['width'] = isset($parameters->width) ? $parameters->width : "";
+ $parray['height'] = isset($parameters->height) ? $parameters->height : "";
+ try {
+ $WMCDoc = DOMDocument::load($templatefilePath);
+ catch (Exception $E) {
+ new mb_exception("WMC XML is broken.");
+ throw new Exception("Could not load WPS Template XML");
+ if(!$WMCDoc){
+ $xpath = new DOMXPath($WMCDoc);
+ $xpath->registerNamespace("xlink","http://www.w3.org/1999/xlink");
+ $xpath->registerNamespace("ows", "http://www.opengis.net/ows/1.1");
+ $xpath->registerNamespace("wps","http://www.opengis.net/wps/1.0.0");
+ $OWS_IdentifierList = $xpath->query("/wps:Execute/wps:DataInputs/wps:Input/ows:Identifier");
+ $result = "";
+ foreach($OWS_IdentifierList as $OWS_Identifier)
+ //FIXME: this requires that our data is checked above
+ $WPS_LiteralDataList = $xpath->query("../wps:Data/wps:LiteralData",$OWS_Identifier);
+ $WPS_LiteralData = $WPS_LiteralDataList->item(0);
+ $WPS_LiteralData->nodeValue = $parray[$OWS_Identifier->nodeValue];
+ $result = $WMCDoc->saveXML();
+ return $result;
More information about the Mapbender_commits
