[Mapbender-commits] r5007 - trunk/mapbender/resources/db/pgsql/UTF-8/update
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Wed Nov 18 09:31:23 EST 2009
Author: verenadiewald
Date: 2009-11-18 09:31:08 -0500 (Wed, 18 Nov 2009)
New Revision: 5007
   trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6_to_2.7rc1_pgsql_UTF-8.sql
set new element vars for non-standard guis
Modified: trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6_to_2.7rc1_pgsql_UTF-8.sql
--- trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6_to_2.7rc1_pgsql_UTF-8.sql	2009-11-18 12:57:22 UTC (rev 5006)
+++ trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6_to_2.7rc1_pgsql_UTF-8.sql	2009-11-18 14:31:08 UTC (rev 5007)
@@ -552,3 +552,92 @@
 -- add publish WMC to admin1
 INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('admin1','wmcPublic',3,1,'Publish WMC','Publish WMC','a','','href = "../php/mod_wmc_publish.php?sessionID" target = "AdminFrame" ',8,1180,190,20,5,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','Publish WMC','a','','','','AdminFrame','');
+-- add required modules for loadwmc and savewmc
+UPDATE gui_element SET e_requires = 'jq_ui_dialog,jq_ui_tabs,jq_upload,jq_datatables' WHERE e_id = 'loadwmc';
+UPDATE gui_element SET e_requires = 'jq_ui_dialog' WHERE e_id = 'savewmc';
+-- set new element vars for existing gui elements of non-standard guis
+-- element var showResultInPopup for gui element gazetteerWFS
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) SELECT gui_element.fkey_gui_id, 'gazetteerWFS', 'showResultInPopup', '1', 'if value is 1 search results will be displayed in popup, otherwise in gazetteer div' ,'var' FROM gui_element WHERE gui_element.e_id = 'gazetteerWFS' AND gui_element.fkey_gui_id NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'showResultInPopup' AND fkey_e_id = 'gazetteerWFS');
+-- element var wfs_spatial_request_conf_filename for gui element gazetteerWFS
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) SELECT gui_element.fkey_gui_id, 'gazetteerWFS', 'wfs_spatial_request_conf_filename', 'wfs_additional_spatial_search.conf', 'location and name of the WFS configuration file for spatialRequest' ,'php_var' FROM gui_element WHERE gui_element.e_id = 'gazetteerWFS' AND gui_element.fkey_gui_id NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'wfs_spatial_request_conf_filename' AND fkey_e_id = 'gazetteerWFS');
+-- element var popupcss for gui element body
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) SELECT gui_element.fkey_gui_id, 'body', 'popupcss', '../css/popup.css', 'file css', 'file/css' FROM gui_element WHERE gui_element.e_id = 'body' AND gui_element.fkey_gui_id NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'popupcss' AND fkey_e_id = 'body');
+-- element var tablesortercss for gui element body
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) SELECT gui_element.fkey_gui_id, 'body', 'tablesortercss', '../css/tablesorter.css', 'file css' ,'file/css' FROM gui_element WHERE gui_element.e_id = 'body' AND gui_element.fkey_gui_id NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'tablesortercss' AND fkey_e_id = 'body');
+-- element var use_load_message for gui element body
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) SELECT gui_element.fkey_gui_id, 'body', 'use_load_message', 'true', '' ,'php_var' FROM gui_element WHERE gui_element.e_id = 'body' AND gui_element.fkey_gui_id NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'use_load_message' AND fkey_e_id = 'body');
+-- element var includeWhileLoading for gui element body
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) SELECT gui_element.fkey_gui_id, 'body', 'includeWhileLoading', '../include/gui1_splash.php', '' ,'php_var' FROM gui_element WHERE gui_element.e_id = 'body' AND gui_element.fkey_gui_id NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'includeWhileLoading' AND fkey_e_id = 'body');
+-- element var cssfileAddWMS for gui element addWMSfromfilteredList_ajax
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) SELECT gui_element.fkey_gui_id, 'addWMSfromfilteredList_ajax', 'cssfileAddWMS', '../css/addwms.css', '' ,'file/css' FROM gui_element WHERE gui_element.e_id = 'addWMSfromfilteredList_ajax' AND gui_element.fkey_gui_id NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'cssfileAddWMS' AND fkey_e_id = 'addWMSfromfilteredList_ajax');
+-- element var capabilitiesInput for gui element addWMSfromfilteredList_ajax
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) SELECT gui_element.fkey_gui_id, 'addWMSfromfilteredList_ajax', 'capabilitiesInput', '1', 'load wms by capabilities url' ,'var' FROM gui_element WHERE gui_element.e_id = 'addWMSfromfilteredList_ajax' AND gui_element.fkey_gui_id NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'capabilitiesInput' AND fkey_e_id = 'addWMSfromfilteredList_ajax');
+-- element var option_dball for gui element addWMSfromfilteredList_ajax
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) SELECT gui_element.fkey_gui_id, 'addWMSfromfilteredList_ajax', 'option_dball', '1', '1 enables option "load all configured wms from db"' ,'var' FROM gui_element WHERE gui_element.e_id = 'addWMSfromfilteredList_ajax' AND gui_element.fkey_gui_id NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'option_dball' AND fkey_e_id = 'addWMSfromfilteredList_ajax');
+-- element var option_dbgroup for gui element addWMSfromfilteredList_ajax
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) SELECT gui_element.fkey_gui_id, 'addWMSfromfilteredList_ajax', 'option_dbgroup', '1', '1 enables option "load configured wms by group"' ,'var' FROM gui_element WHERE gui_element.e_id = 'addWMSfromfilteredList_ajax' AND gui_element.fkey_gui_id NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'option_dbgroup' AND fkey_e_id = 'addWMSfromfilteredList_ajax');
+-- element var option_dbgui for gui element addWMSfromfilteredList_ajax
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) SELECT gui_element.fkey_gui_id, 'addWMSfromfilteredList_ajax', 'option_dbgui', '1', '1 enables option "load configured wms by gui"' ,'var' FROM gui_element WHERE gui_element.e_id = 'addWMSfromfilteredList_ajax' AND gui_element.fkey_gui_id NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'option_dbgui' AND fkey_e_id = 'addWMSfromfilteredList_ajax');
+-- element var featureInfoLayerPopup for gui element featureInfoTunnel
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) SELECT gui_element.fkey_gui_id, 'featureInfoTunnel', 'featureInfoLayerPopup', 'false', '' ,'var' FROM gui_element WHERE gui_element.e_id = 'featureInfoTunnel' AND gui_element.fkey_gui_id NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'featureInfoLayerPopup' AND fkey_e_id = 'featureInfoTunnel');
+-- element var featureInfoPopupHeight for gui element featureInfoTunnel
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) SELECT gui_element.fkey_gui_id, 'featureInfoTunnel', 'featureInfoPopupHeight', '200', '' ,'var' FROM gui_element WHERE gui_element.e_id = 'featureInfoTunnel' AND gui_element.fkey_gui_id NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'featureInfoPopupHeight' AND fkey_e_id = 'featureInfoTunnel');
+-- element var featureInfoPopupWidth for gui element featureInfoTunnel
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) SELECT gui_element.fkey_gui_id, 'featureInfoTunnel', 'featureInfoPopupWidth', '270', '' ,'var' FROM gui_element WHERE gui_element.e_id = 'featureInfoTunnel' AND gui_element.fkey_gui_id NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'featureInfoPopupWidth' AND fkey_e_id = 'featureInfoTunnel');
+-- element var skipWmsIfSrsNotSupported for gui element mapframe1
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) SELECT gui_element.fkey_gui_id, 'mapframe1', 'skipWmsIfSrsNotSupported', '0', 'if set to 1, it skips the WMS request if the current SRS is not supported by the WMS; if set to 0, the WMS is always queried. Default is 0, because of backwards compatibility' ,'var' FROM gui_element WHERE gui_element.e_id = 'mapframe1' AND gui_element.fkey_gui_id NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'skipWmsIfSrsNotSupported' AND fkey_e_id = 'mapframe1');
+-- element var skipWmsIfSrsNotSupported for gui element overview
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) SELECT gui_element.fkey_gui_id, 'overview', 'skipWmsIfSrsNotSupported', '0', 'if set to 1, it skips the WMS request if the current SRS is not supported by the WMS; if set to 0, the WMS is always queried. Default is 0, because of backwards compatibility' ,'var' FROM gui_element WHERE gui_element.e_id = 'overview' AND gui_element.fkey_gui_id NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'skipWmsIfSrsNotSupported' AND fkey_e_id = 'overview');
+-- element var backGroundColor for gui element navFrame
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) SELECT gui_element.fkey_gui_id, 'navFrame','backGroundColor','#c6ced6','set the background-color of the NavFrame' ,'php_var' FROM gui_element WHERE gui_element.e_id = 'navFrame' AND gui_element.fkey_gui_id NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'backGroundColor' AND fkey_e_id = 'navFrame');
+-- element var backGroundHoverColor for gui element navFrame
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) SELECT gui_element.fkey_gui_id, 'navFrame','backGroundHoverColor','#9cacbc','set the background-hover-color of the NavFrame' ,'php_var' FROM gui_element WHERE gui_element.e_id = 'navFrame' AND gui_element.fkey_gui_id NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'backGroundHoverColor' AND fkey_e_id = 'navFrame');
+-- element var overwrite for gui element savewmc
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) SELECT gui_element.fkey_gui_id, 'savewmc', 'overwrite', '0', '' ,'var' FROM gui_element WHERE gui_element.e_id = 'savewmc' AND gui_element.fkey_gui_id NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'overwrite' AND fkey_e_id = 'savewmc');
+-- element var deleteWmc for gui element loadwmc
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) SELECT gui_element.fkey_gui_id, 'loadwmc', 'deleteWmc', '0', '' ,'var' FROM gui_element WHERE gui_element.e_id = 'loadwmc' AND gui_element.fkey_gui_id NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'deleteWmc' AND fkey_e_id = 'loadwmc');
+-- element var publishWmc for gui element loadwmc
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) SELECT gui_element.fkey_gui_id, 'loadwmc', 'publishWmc', '0', '' ,'var' FROM gui_element WHERE gui_element.e_id = 'loadwmc' AND gui_element.fkey_gui_id NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'publishWmc' AND fkey_e_id = 'loadwmc');
+-- element var tooltip_noResultArray for gui element tooltip
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) SELECT gui_element.fkey_gui_id, 'tooltip', 'tooltip_noResultArray', E'["Kein Ergebnis.","<body onload=\'javascript:window.close()\'>"]', '', 'var' FROM gui_element WHERE gui_element.e_id = 'tooltip' AND gui_element.fkey_gui_id NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'tooltip_noResultArray' AND fkey_e_id = 'tooltip');
+-- element var tooltip_disableWfs for gui element tooltip
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) SELECT gui_element.fkey_gui_id, 'tooltip', 'tooltip_disableWfs', '0', 'disable WFS getFeature Request', 'var' FROM gui_element WHERE gui_element.e_id = 'tooltip' AND gui_element.fkey_gui_id NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'tooltip_disableWfs' AND fkey_e_id = 'tooltip');
+-- element var tooltip_disableWms for gui element tooltip
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) SELECT gui_element.fkey_gui_id, 'tooltip', 'tooltip_disableWms', '1', 'disable WMS getFeatureInfo Request', 'var' FROM gui_element WHERE gui_element.e_id = 'tooltip' AND gui_element.fkey_gui_id NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'tooltip_disableWms' AND fkey_e_id = 'tooltip');
+-- element var switchwms for gui element treeGDE
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) SELECT gui_element.fkey_gui_id, 'treeGDE', 'switchwms', 'true', 'enables/disables all layer of a wms' ,'var' FROM gui_element WHERE gui_element.e_id = 'treeGDE' AND gui_element.fkey_gui_id NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'switchwms' AND fkey_e_id = 'treeGDE');
+-- element var favicon for gui element body
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) SELECT gui_element.fkey_gui_id, 'body', 'favicon', '../img/favicon.png', 'favicon' ,'php_var' FROM gui_element WHERE gui_element.e_id = 'body' AND gui_element.fkey_gui_id NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'favicon' AND fkey_e_id = 'body');
More information about the Mapbender_commits mailing list
