[Mapbender-commits] r5021 - trunk/mapbender/http/classes
svn_mapbender at osgeo.org
Fri Nov 20 06:47:10 EST 2009
Author: armin11
Date: 2009-11-20 06:47:10 -0500 (Fri, 20 Nov 2009)
New Revision: 5021
Added:
trunk/mapbender/http/classes/class_georss_geometry.php
georss client
Added: trunk/mapbender/http/classes/class_georss_geometry.php
--- trunk/mapbender/http/classes/class_georss_geometry.php (rev 0)
+++ trunk/mapbender/http/classes/class_georss_geometry.php 2009-11-20 11:47:10 UTC (rev 5021)
@@ -0,0 +1,337 @@
+<?php
+# http://www.mapbender.org/index.php/class_gml2.php
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+#TODO:Check if the following line is enough:
+#require_once(dirname(__FILE__)."/../../core/globalSettings.php");
+require_once(dirname(__FILE__)."/../../conf/mapbender.conf");
+require_once(dirname(__FILE__)."/../classes/class_connector.php");
+require_once(dirname(__FILE__)."/../classes/class_json.php");
+require_once(dirname(__FILE__)."/../classes/class_gml2.php");
+class geoRSS {
+ var $doc;
+ var $importItems = array("title","link","description");
+ var $targetEPSG;
+ function parseFile($req){
+ #$data = implode("",file($req));
+ $x = new connector($req);
+ $data = $x->file;
+ $data = $this->removeWhiteSpace($data);
+ if($data=="")
+ return false;
+ return $this->parseXML($data);
+ #$e = new mb_exception("data = ".$data);
+ * Set the Rss Elements that should go to the property tags of geoJSON
+ * default is "title","link" and "description"
+ public function setImportTags($tags){
+ $this->importItems = $tags;
+ function parseXML($data) {
+ $this->doc = $data;
+ return $this->toGeoJSON();
+ function removeWhiteSpace ($string) {
+ return preg_replace("/\>(\s)+\</", "><", trim($string));
+ function toGeoJSON () {
+ $rssDoc = new SimpleXMLElement($this->doc);
+ $rssDoc->registerXPathNamespace('xls', 'http://www.opengis.net/xls');
+ $rssDoc->registerXPathNamespace('gml', 'http://www.opengis.net/gml');
+ $rssDoc->registerXPathNamespace('georss', 'http://www.georss.org/georss');
+ #for ingrid - portalu georss
+ $rssDoc->registerXPathNamespace('ingrid', 'http://www.portalu.de/opensearch/extension/1.0');
+ // build feature collection
+ $featureCollection = new FeatureCollection();
+ // elements of rss document
+ $rssItems = $rssDoc->xpath("//item");
+ if(count($rssItems)>0){
+ foreach($rssItems as $item){
+ $rssItem_dom = dom_import_simplexml($item);
+ $feature = new geoRSSItem();
+ $feature->targetEPSG = $this->targetEPSG;
+ $feature->parse($rssItem_dom, $this->importItems);
+ if (isset($feature->geometry) && $feature->geometry!==false) {
+ $featureCollection->addFeature($feature);
+ return $featureCollection->toGeoJSON();
+ else{
+ return "{'errorMessage':'Kein Ergebnis'}";
+class geoRSSItem extends Feature{
+ var $targetEPSG;
+ #$this->targetEPSG='4326';
+ public function parse($domNode, $importItems) {
+ $currentSibling = $domNode->firstChild;
+ while ($currentSibling) {
+ $tag = $currentSibling->nodeName;
+ if(in_array($tag, $importItems)){
+ $this->properties[$tag] = $currentSibling->nodeValue;
+ else{
+ switch ($tag) {
+ case "georss:where":
+ $this->parseGML($currentSibling);
+ break;
+ case "georss:point":
+ $this->geometry = new geoRSSPoint();
+ $this->geometry->targetEPSG = $this->targetEPSG;
+ $this->geometry->parsePoint($currentSibling);
+ break;
+ case "georss:line":
+ $this->geometry = new geoRSSLine();
+ $this->geometry->parseLine($currentSibling);
+ break;
+ case "georss:box":
+ $this->geometry = new geoRSSBox();
+ $this->geometry->parseBox($currentSibling);
+ break;
+ case "georss:polygon":
+ $this->geometry = new geoRSSPolygon();
+ $this->geometry->parsePolygon($currentSibling);
+ break;
+ case "geo:point":
+ $this->geometry = new geoPoint();
+ break;
+ case "geo:lat":
+ if(!$this->geometry)
+ $this->geometry->parseLat($currentSibling);
+ break;
+ case "geo:long":
+ $this->geometry->parseLong($currentSibling);
+ break;
+ default:
+ break;
+ $currentSibling = $currentSibling->nextSibling;
+ function parseGML($domNode){
+ $geomType = $currentSibling->nodeName;
+ switch ($geomType) {
+ case "gml:Polygon" :
+ $this->geometry = new GMLPolygon();
+ break;
+ case "gml:LineString" :
+ $this->geometry = new GMLLine();
+ break;
+ case "gml:Point" :
+ $this->geometry = new GMLPoint();
+ break;
+ case "gml:MultiLineString" :
+ $this->geometry = new GMLMultiLine();
+ $this->geometry->parseMultiLine($currentSibling);
+ break;
+ case "gml:MultiPolygon" :
+ $this->geometry = new GMLMultiPolygon();
+ $this->geometry->parseMultiPolygon($currentSibling);
+ break;
+ case "gml:Envelope" :
+ $this->geometry = new GMLEnvelope();
+ $this->geometry->parseEnvelope($currentSibling);
+ default:
+ break;
+class geoRSSPoint extends GMLPoint{
+ var $targetEPSG;
+ public function parsePoint($domNode){
+ list($y, $x) = explode(" ", $domNode->nodeValue);
+ if ($this->targetEPSG != '4326') {
+ $tCoords = transform($x, $y,'4326', $this->targetEPSG);
+ $x = $tCoords["x"];
+ $y = $tCoords["y"];
+ $this->setPoint($x, $y);
+ else {
+class geoPoint extends GMLPoint{
+ var $targetEPSG;
+ switch ($currentSibling->nodeName){
+ case "geo:lat":
+ $this->parseLat($currentSibling);
+ break;
+ case "geo:lon":
+ $this->parseLon($currentSibling);
+ break;
+ public function parseLat($node){
+ if(!$this->point)
+ $this->point=array();
+ $tCoords = transform(0, $node->nodeValue,'4326', $this->targetEPSG);
+ $this->point["y"] = $tCoords["y"];
+ else {
+ $this->point["y"] = $node->nodeValue;
+ public function parseLong($node){
+ if(!$this->point)
+ $tCoords = transform($node->nodeValue, 0, '4326', $this->targetEPSG);
+ $this->point["x"] = $tCoords["x"];
+ else {
+ $this->point["x"] = $node->nodeValue;
+class geoRSSLine extends GMLLine{
+ var $targetEPSG;
+ public function parseLine ($domNode) {
+ $cnt = 0;
+ $y = 0;
+ foreach(explode(' ',$domNode->nodeValue) as $cord){
+ if($cnt % 2)
+ $this->addPoint($cord, $y);
+ $y = $cord;
+ $cnt++;
+class geoRSSPolygon extends GMLPolygon{
+ var $targetEPSG;
+ public function parsePolygon ($domNode) {
+ $cnt = 0;
+ $y = 0;
+ if($cnt % 2)
+ $y = $cord;
+ $cnt++;
+class geoRSSBox extends GMLPolygon{
+ var $targetEPSG;
+ public function parseBox ($domNode) {
+ list($x1,$y1,$x2,$y2) = explode(' ',$domNode->nodeValue);
+ $tCoords = transform($x1, $y1,'4326', $this->targetEPSG);
+ $x1 = $tCoords["x"];
+ $y1 = $tCoords["y"];
+ $tCoords = transform($x2, $y2,'4326', $this->targetEPSG);
+ $x2 = $tCoords["x"];
+ $y2 = $tCoords["y"];
+ $this->addPoint($x1, $y1);
+ $this->addPoint($x1, $y2);
+ $this->addPoint($x2, $y2);
+ $this->addPoint($x2, $y1);
+function transform ($x, $y, $oldEPSG, $newEPSG) {
+ if (is_null($x) || !is_numeric($x) ||
+ is_null($y) || !is_numeric($y) ||
+ is_null($oldEPSG) || !is_numeric($oldEPSG) ||
+ is_null($newEPSG) || !is_numeric($newEPSG)) {
+ return null;
+ if(SYS_DBTYPE=='pgsql'){
+ $con = db_connect(DBSERVER, OWNER, PW);
+ $sqlMinx = "SELECT X(transform(GeometryFromText('POINT(".$x."
+".$y.")',".$oldEPSG."),".$newEPSG.")) as minx";
+ $resMinx = db_query($sqlMinx);
+ $minx = floatval(db_result($resMinx,0,"minx"));
+ $sqlMiny = "SELECT Y(transform(GeometryFromText('POINT(".$x."
+".$y.")',".$oldEPSG."),".$newEPSG.")) as miny";
+ $resMiny = db_query($sqlMiny);
+ $miny = floatval(db_result($resMiny,0,"miny"));
+ }else{
+ $con_string = "host=" . GEOS_DBSERVER . " port=" . GEOS_PORT .
+ " dbname=" . GEOS_DB . "user=" . GEOS_OWNER .
+ "password=" . GEOS_PW;
+ $con = pg_connect($con_string) or die ("Error while connecting
+database");
+ $resMinx = pg_query($con,$sqlMinx);
+ $minx = floatval(pg_fetch_result($resMinx,0,"minx"));
+ $resMiny = pg_query($con,$sqlMiny);
+ $miny = floatval(pg_fetch_result($resMiny,0,"miny"));
+ return array("x" => $minx, "y" => $miny);
More information about the Mapbender_commits
