[Mapbender-commits] r5048 - branches/2.6/http/print
svn_mapbender at osgeo.org
Mon Nov 30 05:08:22 EST 2009
Author: verenadiewald
Date: 2009-11-30 05:08:21 -0500 (Mon, 30 Nov 2009)
New Revision: 5048
branches/2.6/http/print/mod_printPDF.php
branches/2.6/http/print/mod_printPDF_pdf.php
http://trac.osgeo.org/mapbender/ticket/565
Modified: branches/2.6/http/print/mod_printPDF.php
--- branches/2.6/http/print/mod_printPDF.php 2009-11-30 09:23:40 UTC (rev 5047)
+++ branches/2.6/http/print/mod_printPDF.php 2009-11-30 10:08:21 UTC (rev 5048)
@@ -273,6 +273,23 @@
f.map_scale.value = pt.mb_getScale(target);
f.epsg.value = pt.mb_mapObj[ind].epsg;
+ // mypermanentImage (permanent highlight from geometry.js)
+ if(map_el.ownerDocument.images['mapSymbol']){
+ var permanentImage_x = map_el.ownerDocument.getElementById('mapSymbol').style.left;
+ var permanentImage_y = map_el.ownerDocument.getElementById('mapSymbol').style.top;
+ var objImage = map_el.ownerDocument.images['mapSymbol'];
+ var permanentHighlightImage = objImage.src;
+ //change img src from absolute path to relative
+ var permanentHighlightImage = "../"+objImage.src.substr(objImage.src.search(/img.+/));
+ var permanentImage_width = objImage.width;
+ var permanentImage_height = objImage.height;
+ if(permanentImage_x && permanentImage_y){
+ var x_pos = permanentImage_x.slice(0,-2);
+ var y_pos = permanentImage_y.slice(0,-2);
+ document.forms[0].mypermanentImage.value = permanentHighlightImage + '___' +x_pos+'___'+y_pos+'___'+permanentImage_width+'___'+permanentImage_height;
mod_legend_print();
function printMap(){
@@ -394,6 +411,7 @@
<input type="hidden" name="legendurl" />
<input type="hidden" name="map_scale" />
<input type="hidden" name="epsg" />
+<input type="hidden" name="mypermanentImage" value="" />
<input type="hidden" name="conf" value="<?php echo $_REQUEST["conf"]; ?>" />
<input type="hidden" name="comment1" />
<input type="hidden" name="comment2" />
Modified: branches/2.6/http/print/mod_printPDF_pdf.php
--- branches/2.6/http/print/mod_printPDF_pdf.php 2009-11-30 09:23:40 UTC (rev 5047)
+++ branches/2.6/http/print/mod_printPDF_pdf.php 2009-11-30 10:08:21 UTC (rev 5048)
@@ -166,6 +166,25 @@
$coord = mb_split(",",$map_extent);
+# mypermanentImage (highlight symbol from geometry.js)
+if ($_REQUEST["mypermanentImage"]){
+ $array_permanentImage = explode("___", $_REQUEST["mypermanentImage"]);
+ if(count($array_permanentImage)>0){
+ $permanentImage = $array_permanentImage[0] ;
+ if($permanentImage=='false'){
+ $permanentImage='';
+ $permanentImage_x = $array_permanentImage[1] ;
+ $permanentImage_y = $array_permanentImage[2] ;
+ $permanentImage_width = $array_permanentImage[3] ;
+ $permanentImage_height = $array_permanentImage[4] ;
+ $pdf->addPngFromFile($permanentImage, $permanentImage_x + $mapOffset_left , $mapOffset_bottom + $map_height - $permanentImage_y - $permanentImage_height, $permanentImage_width , $permanentImage_height);
if($overview === true){
// analyse overview url and draw rectangle with position
$o_url = new stripRequest($overview_url);
More information about the Mapbender_commits
