[Mapbender-commits] r4781 - in trunk/mapbender: conf core
http/classes http/extensions
svn_mapbender at osgeo.org
Thu Oct 15 09:26:41 EDT 2009
Author: christoph
Date: 2009-10-15 09:26:41 -0400 (Thu, 15 Oct 2009)
New Revision: 4781
Added:
trunk/mapbender/http/extensions/FirePHP.class.php
trunk/mapbender/http/extensions/fb.php
trunk/mapbender/conf/mapbender.conf-dist
trunk/mapbender/core/globalSettings.php
trunk/mapbender/http/classes/class_mb_log.php
http://trac.osgeo.org/mapbender/ticket/544
Modified: trunk/mapbender/conf/mapbender.conf-dist
--- trunk/mapbender/conf/mapbender.conf-dist 2009-10-15 13:08:57 UTC (rev 4780)
+++ trunk/mapbender/conf/mapbender.conf-dist 2009-10-15 13:26:41 UTC (rev 4781)
@@ -32,7 +32,12 @@
define("GEOS_DB", "<database with geos functions>");
define("GEOS_OWNER", "<owner>");
define("GEOS_PW", "<password>");
+ $GEOS_DBSERVER=GEOS_DBSERVER;
+ $GEOS_DB=GEOS_DB;
+ $GEOS_PORT =GEOS_PORT;
+ $GEOS_OWNER=GEOS_OWNER;
+ $GEOS_PW=GEOS_PW;
else {
define("DBSERVER", "<HOST>");
@@ -152,6 +157,7 @@
define("LOG_LEVEL", "error"); //"off","error","warning","notice" or "all"
define("LOG_JS", "on"); // "on", "alert", "console" or "off"
+define("LOG_PHP_WITH_FIREPHP", "off"); // "on" or "off"
# Internationalization
@@ -174,9 +180,5 @@
$OWNER=OWNER;
$PW=PW;
- $GEOS_DBSERVER=GEOS_DBSERVER;
- $GEOS_DB=GEOS_DB;
- $GEOS_PORT =GEOS_PORT;
- $GEOS_OWNER=GEOS_OWNER;
- $GEOS_PW=GEOS_PW;
Modified: trunk/mapbender/core/globalSettings.php
--- trunk/mapbender/core/globalSettings.php 2009-10-15 13:08:57 UTC (rev 4780)
+++ trunk/mapbender/core/globalSettings.php 2009-10-15 13:26:41 UTC (rev 4781)
@@ -16,10 +16,16 @@
# along with this program; if not, write to the Free Software
# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+ob_start();
// initiates the session-handling
session_start();
+require_once(dirname(__FILE__)."/../http/extensions/FirePHP.class.php");
+$firephp = FirePHP::getInstance(true);
require_once(dirname(__FILE__)."/../lib/class_Mapbender.php");
Modified: trunk/mapbender/http/classes/class_mb_log.php
--- trunk/mapbender/http/classes/class_mb_log.php 2009-10-15 13:08:57 UTC (rev 4780)
+++ trunk/mapbender/http/classes/class_mb_log.php 2009-10-15 13:26:41 UTC (rev 4781)
@@ -18,8 +18,7 @@
-require_once(dirname(__FILE__)."/../../conf/mapbender.conf");
-require_once(dirname(__FILE__)."/../../core/system.php");
+require_once dirname(__FILE__) . "/../../core/globalSettings.php";
require_once(dirname(__FILE__)."/../classes/class_mb_notice.php");
require_once(dirname(__FILE__)."/../classes/class_mb_warning.php");
require_once(dirname(__FILE__)."/../classes/class_mb_exception.php");
@@ -41,6 +40,20 @@
$n = "class_mb_exception: please set LOG_LEVEL in mapbender.conf" . $n;
if ($this->isValidLevel($level)) {
+ if (LOG_PHP_WITH_FIREPHP) {
+ global $firephp;
+ switch ($level) {
+ case "error":
+ $firephp->error($n);
+ break;
+ case "warning":
+ $firephp->warn($n);
+ break;
+ case "notice":
+ $firephp->log($n);
+ break;
if (is_dir($this->dir)) {
$logfile = $this->dir . $this->filename_prefix . date("Y_m_d") . ".log";
if ($h = fopen($logfile,"a")) {
Added: trunk/mapbender/http/extensions/FirePHP.class.php
--- trunk/mapbender/http/extensions/FirePHP.class.php (rev 0)
+++ trunk/mapbender/http/extensions/FirePHP.class.php 2009-10-15 13:26:41 UTC (rev 4781)
@@ -0,0 +1,1529 @@
+<?php
+ * *** BEGIN LICENSE BLOCK *****
+ * This file is part of FirePHP (http://www.firephp.org/).
+ * Software License Agreement (New BSD License)
+ * Copyright (c) 2006-2009, Christoph Dorn
+ * All rights reserved.
+ * Redistribution and use in source and binary forms, with or without modification,
+ * are permitted provided that the following conditions are met:
+ * * Redistributions of source code must retain the above copyright notice,
+ * this list of conditions and the following disclaimer.
+ * * Redistributions in binary form must reproduce the above copyright notice,
+ * this list of conditions and the following disclaimer in the documentation
+ * and/or other materials provided with the distribution.
+ * * Neither the name of Christoph Dorn nor the names of its
+ * contributors may be used to endorse or promote products derived from this
+ * software without specific prior written permission.
+ * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND
+ * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
+ * WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
+ * DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR
+ * ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
+ * (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
+ * LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON
+ * ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
+ * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
+ * SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
+ * ***** END LICENSE BLOCK *****
+ * @copyright Copyright (C) 2007-2009 Christoph Dorn
+ * @author Christoph Dorn <christoph at christophdorn.com>
+ * @license http://www.opensource.org/licenses/bsd-license.php
+ * @package FirePHP
+ * Sends the given data to the FirePHP Firefox Extension.
+ * The data can be displayed in the Firebug Console or in the
+ * "Server" request tab.
+ * For more information see: http://www.firephp.org/
+class FirePHP {
+ * FirePHP version
+ * @var string
+ const VERSION = '0.3';
+ * Firebug LOG level
+ * Logs a message to firebug console.
+ * @var string
+ const LOG = 'LOG';
+ * Firebug INFO level
+ * Logs a message to firebug console and displays an info icon before the message.
+ * @var string
+ const INFO = 'INFO';
+ * Firebug WARN level
+ * Logs a message to firebug console, displays an warning icon before the message and colors the line turquoise.
+ * @var string
+ const WARN = 'WARN';
+ * Firebug ERROR level
+ * Logs a message to firebug console, displays an error icon before the message and colors the line yellow. Also increments the firebug error count.
+ * @var string
+ const ERROR = 'ERROR';
+ * Dumps a variable to firebug's server panel
+ * @var string
+ const DUMP = 'DUMP';
+ * Displays a stack trace in firebug console
+ * @var string
+ const TRACE = 'TRACE';
+ * Displays an exception in firebug console
+ * Increments the firebug error count.
+ * @var string
+ const EXCEPTION = 'EXCEPTION';
+ * Displays an table in firebug console
+ * @var string
+ const TABLE = 'TABLE';
+ * Starts a group in firebug console
+ * @var string
+ const GROUP_START = 'GROUP_START';
+ * Ends a group in firebug console
+ * @var string
+ const GROUP_END = 'GROUP_END';
+ * Singleton instance of FirePHP
+ * @var FirePHP
+ protected static $instance = null;
+ * Flag whether we are logging from within the exception handler
+ * @var boolean
+ protected $inExceptionHandler = false;
+ * Flag whether to throw PHP errors that have been converted to ErrorExceptions
+ * @var boolean
+ protected $throwErrorExceptions = true;
+ * Flag whether to convert PHP assertion errors to Exceptions
+ * @var boolean
+ protected $convertAssertionErrorsToExceptions = true;
+ * Flag whether to throw PHP assertion errors that have been converted to Exceptions
+ * @var boolean
+ protected $throwAssertionExceptions = false;
+ * Wildfire protocol message index
+ * @var int
+ protected $messageIndex = 1;
+ * Options for the library
+ * @var array
+ protected $options = array('maxObjectDepth' => 10,
+ 'maxArrayDepth' => 20,
+ 'useNativeJsonEncode' => true,
+ 'includeLineNumbers' => true);
+ * Filters used to exclude object members when encoding
+ * @var array
+ protected $objectFilters = array();
+ * A stack of objects used to detect recursion during object encoding
+ * @var object
+ protected $objectStack = array();
+ * Flag to enable/disable logging
+ * @var boolean
+ protected $enabled = true;
+ * The object constructor
+ function __construct() {
+ * When the object gets serialized only include specific object members.
+ * @return array
+ public function __sleep() {
+ return array('options','objectFilters','enabled');
+ * Gets singleton instance of FirePHP
+ * @param boolean $AutoCreate
+ * @return FirePHP
+ public static function getInstance($AutoCreate=false) {
+ if($AutoCreate===true && !self::$instance) {
+ self::init();
+ return self::$instance;
+ * Creates FirePHP object and stores it for singleton access
+ * @return FirePHP
+ public static function init() {
+ return self::$instance = new self();
+ * Enable and disable logging to Firebug
+ * @param boolean $Enabled TRUE to enable, FALSE to disable
+ * @return void
+ public function setEnabled($Enabled) {
+ $this->enabled = $Enabled;
+ * Check if logging is enabled
+ * @return boolean TRUE if enabled
+ public function getEnabled() {
+ return $this->enabled;
+ * Specify a filter to be used when encoding an object
+ * Filters are used to exclude object members.
+ * @param string $Class The class name of the object
+ * @param array $Filter An array of members to exclude
+ * @return void
+ public function setObjectFilter($Class, $Filter) {
+ $this->objectFilters[strtolower($Class)] = $Filter;
+ * Set some options for the library
+ * Options:
+ * - maxObjectDepth: The maximum depth to traverse objects (default: 10)
+ * - maxArrayDepth: The maximum depth to traverse arrays (default: 20)
+ * - useNativeJsonEncode: If true will use json_encode() (default: true)
+ * - includeLineNumbers: If true will include line numbers and filenames (default: true)
+ * @param array $Options The options to be set
+ * @return void
+ public function setOptions($Options) {
+ $this->options = array_merge($this->options,$Options);
+ * Get options from the library
+ * @return array The currently set options
+ public function getOptions() {
+ return $this->options;
+ * Register FirePHP as your error handler
+ * Will throw exceptions for each php error.
+ * @return mixed Returns a string containing the previously defined error handler (if any)
+ public function registerErrorHandler($throwErrorExceptions=true)
+ //NOTE: The following errors will not be caught by this error handler:
+ // E_ERROR, E_PARSE, E_CORE_ERROR,
+ // E_CORE_WARNING, E_COMPILE_ERROR,
+ // E_COMPILE_WARNING, E_STRICT
+ $this->throwErrorExceptions = $throwErrorExceptions;
+ return set_error_handler(array($this,'errorHandler'));
+ * FirePHP's error handler
+ * Throws exception for each php error that will occur.
+ * @param int $errno
+ * @param string $errstr
+ * @param string $errfile
+ * @param int $errline
+ * @param array $errcontext
+ public function errorHandler($errno, $errstr, $errfile, $errline, $errcontext)
+ // Don't throw exception if error reporting is switched off
+ if (error_reporting() == 0) {
+ return;
+ // Only throw exceptions for errors we are asking for
+ if (error_reporting() & $errno) {
+ $exception = new ErrorException($errstr, 0, $errno, $errfile, $errline);
+ if($this->throwErrorExceptions) {
+ throw $exception;
+ } else {
+ $this->fb($exception);
+ * Register FirePHP as your exception handler
+ * @return mixed Returns the name of the previously defined exception handler,
+ * or NULL on error.
+ * If no previous handler was defined, NULL is also returned.
+ public function registerExceptionHandler()
+ return set_exception_handler(array($this,'exceptionHandler'));
+ * FirePHP's exception handler
+ * Logs all exceptions to your firebug console and then stops the script.
+ * @param Exception $Exception
+ * @throws Exception
+ function exceptionHandler($Exception) {
+ $this->inExceptionHandler = true;
+ header('HTTP/1.1 500 Internal Server Error');
+ $this->fb($Exception);
+ $this->inExceptionHandler = false;
+ * Register FirePHP driver as your assert callback
+ * @param boolean $convertAssertionErrorsToExceptions
+ * @param boolean $throwAssertionExceptions
+ * @return mixed Returns the original setting or FALSE on errors
+ public function registerAssertionHandler($convertAssertionErrorsToExceptions=true, $throwAssertionExceptions=false)
+ $this->convertAssertionErrorsToExceptions = $convertAssertionErrorsToExceptions;
+ $this->throwAssertionExceptions = $throwAssertionExceptions;
+ if($throwAssertionExceptions && !$convertAssertionErrorsToExceptions) {
+ throw $this->newException('Cannot throw assertion exceptions as assertion errors are not being converted to exceptions!');
+ return assert_options(ASSERT_CALLBACK, array($this, 'assertionHandler'));
+ * FirePHP's assertion handler
+ * Logs all assertions to your firebug console and then stops the script.
+ * @param string $file File source of assertion
+ * @param int $line Line source of assertion
+ * @param mixed $code Assertion code
+ public function assertionHandler($file, $line, $code)
+ if($this->convertAssertionErrorsToExceptions) {
+ $exception = new ErrorException('Assertion Failed - Code[ '.$code.' ]', 0, null, $file, $line);
+ if($this->throwAssertionExceptions) {
+ throw $exception;
+ } else {
+ } else {
+ $this->fb($code, 'Assertion Failed', FirePHP::ERROR, array('File'=>$file,'Line'=>$line));
+ * Set custom processor url for FirePHP
+ * @param string $URL
+ public function setProcessorUrl($URL)
+ $this->setHeader('X-FirePHP-ProcessorURL', $URL);
+ * Set custom renderer url for FirePHP
+ public function setRendererUrl($URL)
+ $this->setHeader('X-FirePHP-RendererURL', $URL);
+ * Start a group for following messages.
+ * Options:
+ * Collapsed: [true|false]
+ * Color: [#RRGGBB|ColorName]
+ * @param string $Name
+ * @param array $Options OPTIONAL Instructions on how to log the group
+ * @return true
+ public function group($Name, $Options=null) {
+ if(!$Name) {
+ throw $this->newException('You must specify a label for the group!');
+ if($Options) {
+ if(!is_array($Options)) {
+ throw $this->newException('Options must be defined as an array!');
+ if(array_key_exists('Collapsed', $Options)) {
+ $Options['Collapsed'] = ($Options['Collapsed'])?'true':'false';
+ return $this->fb(null, $Name, FirePHP::GROUP_START, $Options);
+ * Ends a group you have started before
+ * @return true
+ public function groupEnd() {
+ return $this->fb(null, null, FirePHP::GROUP_END);
+ * Log object with label to firebug console
+ * @see FirePHP::LOG
+ * @param mixes $Object
+ * @param string $Label
+ * @return true
+ public function log($Object, $Label=null) {
+ return $this->fb($Object, $Label, FirePHP::LOG);
+ * @see FirePHP::INFO
+ * @return true
+ public function info($Object, $Label=null) {
+ return $this->fb($Object, $Label, FirePHP::INFO);
+ * @see FirePHP::WARN
+ * @return true
+ public function warn($Object, $Label=null) {
+ return $this->fb($Object, $Label, FirePHP::WARN);
+ * @see FirePHP::ERROR
+ * @return true
+ public function error($Object, $Label=null) {
+ return $this->fb($Object, $Label, FirePHP::ERROR);
+ * Dumps key and variable to firebug server panel
+ * @see FirePHP::DUMP
+ * @param string $Key
+ * @param mixed $Variable
+ * @return true
+ public function dump($Key, $Variable) {
+ return $this->fb($Variable, $Key, FirePHP::DUMP);
+ * Log a trace in the firebug console
+ * @see FirePHP::TRACE
+ * @return true
+ public function trace($Label) {
+ return $this->fb($Label, FirePHP::TRACE);
+ * Log a table in the firebug console
+ * @see FirePHP::TABLE
+ * @param string $Table
+ * @return true
+ public function table($Label, $Table) {
+ return $this->fb($Table, $Label, FirePHP::TABLE);
+ * Check if FirePHP is installed on client
+ * @return boolean
+ public function detectClientExtension() {
+ /* Check if FirePHP is installed on client */
+ if(!@preg_match_all('/\sFirePHP\/([\.|\d]*)\s?/si',$this->getUserAgent(),$m) ||
+ !version_compare($m[1][0],'0.0.6','>=')) {
+ return false;
+ return true;
+ * Log varible to Firebug
+ * @see http://www.firephp.org/Wiki/Reference/Fb
+ * @param mixed $Object The variable to be logged
+ * @return true Return TRUE if message was added to headers, FALSE otherwise
+ public function fb($Object) {
+ if(!$this->enabled) {
+ return false;
+ if (headers_sent($filename, $linenum)) {
+ // If we are logging from within the exception handler we cannot throw another exception
+ if($this->inExceptionHandler) {
+ // Simply echo the error out to the page
+ echo '<div style="border: 2px solid red; font-family: Arial; font-size: 12px; background-color: lightgray; padding: 5px;"><span style="color: red; font-weight: bold;">FirePHP ERROR:</span> Headers already sent in <b>'.$filename.'</b> on line <b>'.$linenum.'</b>. Cannot send log data to FirePHP. You must have Output Buffering enabled via ob_start() or output_buffering ini directive.</div>';
+ } else {
+ throw $this->newException('Headers already sent in '.$filename.' on line '.$linenum.'. Cannot send log data to FirePHP. You must have Output Buffering enabled via ob_start() or output_buffering ini directive.');
+ $Type = null;
+ $Label = null;
+ $Options = array();
+ if(func_num_args()==1) {
+ } else
+ if(func_num_args()==2) {
+ switch(func_get_arg(1)) {
+ case self::LOG:
+ case self::INFO:
+ case self::WARN:
+ case self::ERROR:
+ case self::DUMP:
+ case self::TRACE:
+ case self::EXCEPTION:
+ case self::TABLE:
+ case self::GROUP_START:
+ case self::GROUP_END:
+ $Type = func_get_arg(1);
+ break;
+ default:
+ $Label = func_get_arg(1);
+ break;
+ } else
+ if(func_num_args()==3) {
+ $Type = func_get_arg(2);
+ } else
+ if(func_num_args()==4) {
+ $Options = func_get_arg(3);
+ } else {
+ throw $this->newException('Wrong number of arguments to fb() function!');
+ if(!$this->detectClientExtension()) {
+ return false;
+ $meta = array();
+ $skipFinalObjectEncode = false;
+ if($Object instanceof Exception) {
+ $meta['file'] = $this->_escapeTraceFile($Object->getFile());
+ $meta['line'] = $Object->getLine();
+ $trace = $Object->getTrace();
+ if($Object instanceof ErrorException
+ && isset($trace[0]['function'])
+ && $trace[0]['function']=='errorHandler'
+ && isset($trace[0]['class'])
+ && $trace[0]['class']=='FirePHP') {
+ $severity = false;
+ switch($Object->getSeverity()) {
+ case E_WARNING: $severity = 'E_WARNING'; break;
+ case E_NOTICE: $severity = 'E_NOTICE'; break;
+ case E_USER_ERROR: $severity = 'E_USER_ERROR'; break;
+ case E_USER_WARNING: $severity = 'E_USER_WARNING'; break;
+ case E_USER_NOTICE: $severity = 'E_USER_NOTICE'; break;
+ case E_STRICT: $severity = 'E_STRICT'; break;
+ case E_RECOVERABLE_ERROR: $severity = 'E_RECOVERABLE_ERROR'; break;
+ case E_DEPRECATED: $severity = 'E_DEPRECATED'; break;
+ case E_USER_DEPRECATED: $severity = 'E_USER_DEPRECATED'; break;
+ $Object = array('Class'=>get_class($Object),
+ 'Message'=>$severity.': '.$Object->getMessage(),
+ 'File'=>$this->_escapeTraceFile($Object->getFile()),
+ 'Line'=>$Object->getLine(),
+ 'Type'=>'trigger',
+ 'Trace'=>$this->_escapeTrace(array_splice($trace,2)));
+ $skipFinalObjectEncode = true;
+ } else {
+ 'Message'=>$Object->getMessage(),
+ 'Type'=>'throw',
+ 'Trace'=>$this->_escapeTrace($trace));
+ $Type = self::EXCEPTION;
+ } else
+ if($Type==self::TRACE) {
+ $trace = debug_backtrace();
+ if(!$trace) return false;
+ for( $i=0 ; $i<sizeof($trace) ; $i++ ) {
+ if(isset($trace[$i]['class'])
+ && isset($trace[$i]['file'])
+ && ($trace[$i]['class']=='FirePHP'
+ || $trace[$i]['class']=='FB')
+ && (substr($this->_standardizePath($trace[$i]['file']),-18,18)=='FirePHPCore/fb.php'
+ || substr($this->_standardizePath($trace[$i]['file']),-29,29)=='FirePHPCore/FirePHP.class.php')) {
+ /* Skip - FB::trace(), FB::send(), $firephp->trace(), $firephp->fb() */
+ } else
+ && isset($trace[$i+1]['file'])
+ && $trace[$i]['class']=='FirePHP'
+ && substr($this->_standardizePath($trace[$i+1]['file']),-18,18)=='FirePHPCore/fb.php') {
+ /* Skip fb() */
+ } else
+ if($trace[$i]['function']=='fb'
+ || $trace[$i]['function']=='trace'
+ || $trace[$i]['function']=='send') {
+ $Object = array('Class'=>isset($trace[$i]['class'])?$trace[$i]['class']:'',
+ 'Type'=>isset($trace[$i]['type'])?$trace[$i]['type']:'',
+ 'Function'=>isset($trace[$i]['function'])?$trace[$i]['function']:'',
+ 'Message'=>$trace[$i]['args'][0],
+ 'File'=>isset($trace[$i]['file'])?$this->_escapeTraceFile($trace[$i]['file']):'',
+ 'Line'=>isset($trace[$i]['line'])?$trace[$i]['line']:'',
+ 'Args'=>isset($trace[$i]['args'])?$this->encodeObject($trace[$i]['args']):'',
+ 'Trace'=>$this->_escapeTrace(array_splice($trace,$i+1)));
+ $meta['file'] = isset($trace[$i]['file'])?$this->_escapeTraceFile($trace[$i]['file']):'';
+ $meta['line'] = isset($trace[$i]['line'])?$trace[$i]['line']:'';
+ break;
+ } else
+ if($Type==self::TABLE) {
+ if(isset($Object[0]) && is_string($Object[0])) {
+ $Object[1] = $this->encodeTable($Object[1]);
+ } else {
+ $Object = $this->encodeTable($Object);
+ } else
+ if($Type==self::GROUP_START) {
+ if(!$Label) {
+ } else {
+ if($Type===null) {
+ $Type = self::LOG;
+ if($this->options['includeLineNumbers']) {
+ if(!isset($meta['file']) || !isset($meta['line'])) {
+ for( $i=0 ; $trace && $i<sizeof($trace) ; $i++ ) {
+ } else
+ /* Skip fb() */
+ } else
+ if(isset($trace[$i]['file'])
+ && substr($this->_standardizePath($trace[$i]['file']),-18,18)=='FirePHPCore/fb.php') {
+ /* Skip FB::fb() */
+ } else {
+ break;
+ } else {
+ unset($meta['file']);
+ unset($meta['line']);
+ $this->setHeader('X-Wf-Protocol-1','http://meta.wildfirehq.org/Protocol/JsonStream/0.2');
+ $this->setHeader('X-Wf-1-Plugin-1','http://meta.firephp.org/Wildfire/Plugin/FirePHP/Library-FirePHPCore/'.self::VERSION);
+ $structure_index = 1;
+ if($Type==self::DUMP) {
+ $structure_index = 2;
+ $this->setHeader('X-Wf-1-Structure-2','http://meta.firephp.org/Wildfire/Structure/FirePHP/Dump/0.1');
+ } else {
+ $this->setHeader('X-Wf-1-Structure-1','http://meta.firephp.org/Wildfire/Structure/FirePHP/FirebugConsole/0.1');
+ $msg = '{"'.$Label.'":'.$this->jsonEncode($Object, $skipFinalObjectEncode).'}';
+ } else {
+ $msg_meta = $Options;
+ $msg_meta['Type'] = $Type;
+ if($Label!==null) {
+ $msg_meta['Label'] = $Label;
+ if(isset($meta['file']) && !isset($msg_meta['File'])) {
+ $msg_meta['File'] = $meta['file'];
+ if(isset($meta['line']) && !isset($msg_meta['Line'])) {
+ $msg_meta['Line'] = $meta['line'];
+ $msg = '['.$this->jsonEncode($msg_meta).','.$this->jsonEncode($Object, $skipFinalObjectEncode).']';
+ $parts = explode("\n",chunk_split($msg, 5000, "\n"));
+ for( $i=0 ; $i<count($parts) ; $i++) {
+ $part = $parts[$i];
+ if ($part) {
+ if(count($parts)>2) {
+ // Message needs to be split into multiple parts
+ $this->setHeader('X-Wf-1-'.$structure_index.'-'.'1-'.$this->messageIndex,
+ (($i==0)?strlen($msg):'')
+ . '|' . $part . '|'
+ . (($i<count($parts)-2)?'\\':''));
+ } else {
+ strlen($part) . '|' . $part . '|');
+ $this->messageIndex++;
+ if ($this->messageIndex > 99999) {
+ throw $this->newException('Maximum number (99,999) of messages reached!');
+ $this->setHeader('X-Wf-1-Index',$this->messageIndex-1);
+ return true;
+ * Standardizes path for windows systems.
+ * @param string $Path
+ * @return string
+ protected function _standardizePath($Path) {
+ return preg_replace('/\\\\+/','/',$Path);
+ * Escape trace path for windows systems
+ * @param array $Trace
+ * @return array
+ protected function _escapeTrace($Trace) {
+ if(!$Trace) return $Trace;
+ for( $i=0 ; $i<sizeof($Trace) ; $i++ ) {
+ if(isset($Trace[$i]['file'])) {
+ $Trace[$i]['file'] = $this->_escapeTraceFile($Trace[$i]['file']);
+ if(isset($Trace[$i]['args'])) {
+ $Trace[$i]['args'] = $this->encodeObject($Trace[$i]['args']);
+ return $Trace;
+ * Escape file information of trace for windows systems
+ * @param string $File
+ * @return string
+ protected function _escapeTraceFile($File) {
+ /* Check if we have a windows filepath */
+ if(strpos($File,'\\')) {
+ /* First strip down to single \ */
+ $file = preg_replace('/\\\\+/','\\',$File);
+ return $file;
+ return $File;
+ * Send header
+ * @param string_type $Value
+ protected function setHeader($Name, $Value) {
+ return header($Name.': '.$Value);
+ * Get user agent
+ * @return string|false
+ protected function getUserAgent() {
+ if(!isset($_SERVER['HTTP_USER_AGENT'])) return false;
+ return $_SERVER['HTTP_USER_AGENT'];
+ * Returns a new exception
+ * @param string $Message
+ * @return Exception
+ protected function newException($Message) {
+ return new Exception($Message);
+ * Encode an object into a JSON string
+ * Uses PHP's jeson_encode() if available
+ * @param object $Object The object to be encoded
+ * @return string The JSON string
+ public function jsonEncode($Object, $skipObjectEncode=false)
+ if(!$skipObjectEncode) {
+ $Object = $this->encodeObject($Object);
+ if(function_exists('json_encode')
+ && $this->options['useNativeJsonEncode']!=false) {
+ return json_encode($Object);
+ } else {
+ return $this->json_encode($Object);
+ * Encodes a table by encoding each row and column with encodeObject()
+ * @param array $Table The table to be encoded
+ * @return array
+ protected function encodeTable($Table) {
+ if(!$Table) return $Table;
+ $new_table = array();
+ foreach($Table as $row) {
+ if(is_array($row)) {
+ $new_row = array();
+ foreach($row as $item) {
+ $new_row[] = $this->encodeObject($item);
+ $new_table[] = $new_row;
+ return $new_table;
+ * Encodes an object including members with
+ * protected and private visibility
+ * @param Object $Object The object to be encoded
+ * @param int $Depth The current traversal depth
+ * @return array All members of the object
+ protected function encodeObject($Object, $ObjectDepth = 1, $ArrayDepth = 1)
+ $return = array();
+ if (is_resource($Object)) {
+ return '** '.(string)$Object.' **';
+ } else
+ if (is_object($Object)) {
+ if ($ObjectDepth > $this->options['maxObjectDepth']) {
+ return '** Max Object Depth ('.$this->options['maxObjectDepth'].') **';
+ foreach ($this->objectStack as $refVal) {
+ if ($refVal === $Object) {
+ return '** Recursion ('.get_class($Object).') **';
+ array_push($this->objectStack, $Object);
+ $return['__className'] = $class = get_class($Object);
+ $class_lower = strtolower($class);
+ $reflectionClass = new ReflectionClass($class);
+ $properties = array();
+ foreach( $reflectionClass->getProperties() as $property) {
+ $properties[$property->getName()] = $property;
+ $members = (array)$Object;
+ foreach( $properties as $raw_name => $property ) {
+ $name = $raw_name;
+ if($property->isStatic()) {
+ $name = 'static:'.$name;
+ if($property->isPublic()) {
+ $name = 'public:'.$name;
+ } else
+ if($property->isPrivate()) {
+ $name = 'private:'.$name;
+ $raw_name = "\0".$class."\0".$raw_name;
+ } else
+ if($property->isProtected()) {
+ $name = 'protected:'.$name;
+ $raw_name = "\0".'*'."\0".$raw_name;
+ if(!(isset($this->objectFilters[$class_lower])
+ && is_array($this->objectFilters[$class_lower])
+ && in_array($raw_name,$this->objectFilters[$class_lower]))) {
+ if(array_key_exists($raw_name,$members)
+ && !$property->isStatic()) {
+ $return[$name] = $this->encodeObject($members[$raw_name], $ObjectDepth + 1, 1);
+ } else {
+ if(method_exists($property,'setAccessible')) {
+ $property->setAccessible(true);
+ $return[$name] = $this->encodeObject($property->getValue($Object), $ObjectDepth + 1, 1);
+ } else
+ } else {
+ $return[$name] = '** Need PHP 5.3 to get value **';
+ } else {
+ $return[$name] = '** Excluded by Filter **';
+ // Include all members that are not defined in the class
+ // but exist in the object
+ foreach( $members as $raw_name => $value ) {
+ if ($name{0} == "\0") {
+ $parts = explode("\0", $name);
+ $name = $parts[2];
+ if(!isset($properties[$name])) {
+ $name = 'undeclared:'.$name;
+ $return[$name] = $this->encodeObject($value, $ObjectDepth + 1, 1);
+ } else {
+ array_pop($this->objectStack);
+ } elseif (is_array($Object)) {
+ if ($ArrayDepth > $this->options['maxArrayDepth']) {
+ return '** Max Array Depth ('.$this->options['maxArrayDepth'].') **';
+ foreach ($Object as $key => $val) {
+ // Encoding the $GLOBALS PHP array causes an infinite loop
+ // if the recursion is not reset here as it contains
+ // a reference to itself. This is the only way I have come up
+ // with to stop infinite recursion in this case.
+ if($key=='GLOBALS'
+ && is_array($val)
+ && array_key_exists('GLOBALS',$val)) {
+ $val['GLOBALS'] = '** Recursion (GLOBALS) **';
+ $return[$key] = $this->encodeObject($val, 1, $ArrayDepth + 1);
+ } else {
+ if(self::is_utf8($Object)) {
+ return $Object;
+ } else {
+ return utf8_encode($Object);
+ return $return;
+ * Returns true if $string is valid UTF-8 and false otherwise.
+ * @param mixed $str String to be tested
+ * @return boolean
+ protected static function is_utf8($str) {
+ $c=0; $b=0;
+ $bits=0;
+ $len=strlen($str);
+ for($i=0; $i<$len; $i++){
+ $c=ord($str[$i]);
+ if($c > 128){
+ if(($c >= 254)) return false;
+ elseif($c >= 252) $bits=6;
+ elseif($c >= 248) $bits=5;
+ elseif($c >= 240) $bits=4;
+ elseif($c >= 224) $bits=3;
+ elseif($c >= 192) $bits=2;
+ else return false;
+ if(($i+$bits) > $len) return false;
+ while($bits > 1){
+ $i++;
+ $b=ord($str[$i]);
+ if($b < 128 || $b > 191) return false;
+ $bits--;
+ return true;
+ * Converts to and from JSON format.
+ * JSON (JavaScript Object Notation) is a lightweight data-interchange
+ * format. It is easy for humans to read and write. It is easy for machines
+ * to parse and generate. It is based on a subset of the JavaScript
+ * Programming Language, Standard ECMA-262 3rd Edition - December 1999.
+ * This feature can also be found in Python. JSON is a text format that is
+ * completely language independent but uses conventions that are familiar
+ * to programmers of the C-family of languages, including C, C++, C#, Java,
+ * JavaScript, Perl, TCL, and many others. These properties make JSON an
+ * ideal data-interchange language.
+ * This package provides a simple encoder and decoder for JSON notation. It
+ * is intended for use with client-side Javascript applications that make
+ * use of HTTPRequest to perform server communication functions - data can
+ * be encoded into JSON notation for use in a client-side javascript, or
+ * decoded from incoming Javascript requests. JSON format is native to
+ * Javascript, and can be directly eval()'ed with no further parsing
+ * overhead
+ * All strings should be in ASCII or UTF-8 format!
+ * LICENSE: Redistribution and use in source and binary forms, with or
+ * without modification, are permitted provided that the following
+ * conditions are met: Redistributions of source code must retain the
+ * above copyright notice, this list of conditions and the following
+ * disclaimer. Redistributions in binary form must reproduce the above
+ * copyright notice, this list of conditions and the following disclaimer
+ * in the documentation and/or other materials provided with the
+ * distribution.
+ * THIS SOFTWARE IS PROVIDED ``AS IS'' AND ANY EXPRESS OR IMPLIED
+ * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF
+ * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN
+ * NO EVENT SHALL CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT,
+ * INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING,
+ * BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS
+ * OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
+ * ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR
+ * TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE
+ * USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH
+ * DAMAGE.
+ * @category
+ * @package Services_JSON
+ * @author Michal Migurski <mike-json at teczno.com>
+ * @author Matt Knapp <mdknapp[at]gmail[dot]com>
+ * @author Brett Stimmerman <brettstimmerman[at]gmail[dot]com>
+ * @copyright 2005 Michal Migurski
+ * @version CVS: $Id: JSON.php,v 1.31 2006/06/28 05:54:17 migurski Exp $
+ * @link http://pear.php.net/pepr/pepr-proposal-show.php?id=198
+ * Keep a list of objects as we descend into the array so we can detect recursion.
+ private $json_objectStack = array();
+ * convert a string from one UTF-8 char to one UTF-16 char
+ * Normally should be handled by mb_convert_encoding, but
+ * provides a slower PHP-only method for installations
+ * that lack the multibye string extension.
+ * @param string $utf8 UTF-8 character
+ * @return string UTF-16 character
+ * @access private
+ private function json_utf82utf16($utf8)
+ // oh please oh please oh please oh please oh please
+ if(function_exists('mb_convert_encoding')) {
+ return mb_convert_encoding($utf8, 'UTF-16', 'UTF-8');
+ switch(strlen($utf8)) {
+ case 1:
+ // this case should never be reached, because we are in ASCII range
+ // see: http://www.cl.cam.ac.uk/~mgk25/unicode.html#utf-8
+ return $utf8;
+ case 2:
+ // return a UTF-16 character from a 2-byte UTF-8 char
+ return chr(0x07 & (ord($utf8{0}) >> 2))
+ . chr((0xC0 & (ord($utf8{0}) << 6))
+ | (0x3F & ord($utf8{1})));
+ case 3:
+ // return a UTF-16 character from a 3-byte UTF-8 char
+ return chr((0xF0 & (ord($utf8{0}) << 4))
+ | (0x0F & (ord($utf8{1}) >> 2)))
+ . chr((0xC0 & (ord($utf8{1}) << 6))
+ | (0x7F & ord($utf8{2})));
+ // ignoring UTF-32 for now, sorry
+ return '';
+ * encodes an arbitrary variable into JSON format
+ * @param mixed $var any number, boolean, string, array, or object to be encoded.
+ * see argument 1 to Services_JSON() above for array-parsing behavior.
+ * if var is a strng, note that encode() always expects it
+ * to be in ASCII or UTF-8 format!
+ * @return mixed JSON string representation of input var or an error if a problem occurs
+ * @access public
+ private function json_encode($var)
+ if(is_object($var)) {
+ if(in_array($var,$this->json_objectStack)) {
+ return '"** Recursion **"';
+ switch (gettype($var)) {
+ case 'boolean':
+ return $var ? 'true' : 'false';
+ case 'NULL':
+ return 'null';
+ case 'integer':
+ return (int) $var;
+ case 'double':
+ case 'float':
+ return (float) $var;
+ case 'string':
+ // STRINGS ARE EXPECTED TO BE IN ASCII OR UTF-8 FORMAT
+ $ascii = '';
+ $strlen_var = strlen($var);
+ * Iterate over every character in the string,
+ * escaping with a slash or encoding to UTF-8 where necessary
+ for ($c = 0; $c < $strlen_var; ++$c) {
+ $ord_var_c = ord($var{$c});
+ switch (true) {
+ case $ord_var_c == 0x08:
+ $ascii .= '\b';
+ break;
+ case $ord_var_c == 0x09:
+ $ascii .= '\t';
+ break;
+ case $ord_var_c == 0x0A:
+ $ascii .= '\n';
+ break;
+ case $ord_var_c == 0x0C:
+ $ascii .= '\f';
+ break;
+ case $ord_var_c == 0x0D:
+ $ascii .= '\r';
+ break;
+ case $ord_var_c == 0x22:
+ case $ord_var_c == 0x2F:
+ case $ord_var_c == 0x5C:
+ // double quote, slash, slosh
+ $ascii .= '\\'.$var{$c};
+ break;
+ case (($ord_var_c >= 0x20) && ($ord_var_c <= 0x7F)):
+ // characters U-00000000 - U-0000007F (same as ASCII)
+ $ascii .= $var{$c};
+ break;
+ case (($ord_var_c & 0xE0) == 0xC0):
+ // characters U-00000080 - U-000007FF, mask 110XXXXX
+ // see http://www.cl.cam.ac.uk/~mgk25/unicode.html#utf-8
+ $char = pack('C*', $ord_var_c, ord($var{$c + 1}));
+ $c += 1;
+ $utf16 = $this->json_utf82utf16($char);
+ $ascii .= sprintf('\u%04s', bin2hex($utf16));
+ break;
+ case (($ord_var_c & 0xF0) == 0xE0):
+ // characters U-00000800 - U-0000FFFF, mask 1110XXXX
+ ord($var{$c + 1}),
+ ord($var{$c + 2}));
+ $c += 2;
+ break;
+ case (($ord_var_c & 0xF8) == 0xF0):
+ // characters U-00010000 - U-001FFFFF, mask 11110XXX
+ ord($var{$c + 2}),
+ ord($var{$c + 3}));
+ $c += 3;
+ break;
+ case (($ord_var_c & 0xFC) == 0xF8):
+ // characters U-00200000 - U-03FFFFFF, mask 111110XX
+ ord($var{$c + 3}),
+ ord($var{$c + 4}));
+ $c += 4;
+ break;
+ case (($ord_var_c & 0xFE) == 0xFC):
+ // characters U-04000000 - U-7FFFFFFF, mask 1111110X
+ ord($var{$c + 4}),
+ ord($var{$c + 5}));
+ $c += 5;
+ break;
+ return '"'.$ascii.'"';
+ case 'array':
+ * As per JSON spec if any array key is not an integer
+ * we must treat the the whole array as an object. We
+ * also try to catch a sparsely populated associative
+ * array with numeric keys here because some JS engines
+ * will create an array with empty indexes up to
+ * max_index which can cause memory issues and because
+ * the keys, which may be relevant, will be remapped
+ * otherwise.
+ * As per the ECMA and JSON specification an object may
+ * have any string as a property. Unfortunately due to
+ * a hole in the ECMA specification if the key is a
+ * ECMA reserved word or starts with a digit the
+ * parameter is only accessible using ECMAScript's
+ * bracket notation.
+ // treat as a JSON object
+ if (is_array($var) && count($var) && (array_keys($var) !== range(0, sizeof($var) - 1))) {
+ $this->json_objectStack[] = $var;
+ $properties = array_map(array($this, 'json_name_value'),
+ array_keys($var),
+ array_values($var));
+ array_pop($this->json_objectStack);
+ foreach($properties as $property) {
+ if($property instanceof Exception) {
+ return $property;
+ return '{' . join(',', $properties) . '}';
+ // treat it like a regular array
+ $elements = array_map(array($this, 'json_encode'), $var);
+ foreach($elements as $element) {
+ if($element instanceof Exception) {
+ return $element;
+ return '[' . join(',', $elements) . ']';
+ case 'object':
+ $vars = self::encodeObject($var);
+ array_keys($vars),
+ array_values($vars));
+ return $property;
+ default:
+ return null;
+ * array-walking function for use in generating JSON-formatted name-value pairs
+ * @param string $name name of key to use
+ * @param mixed $value reference to an array element to be encoded
+ * @return string JSON-formatted name-value pair, like '"name":value'
+ * @access private
+ private function json_name_value($name, $value)
+ if($name=='GLOBALS'
+ && is_array($value)
+ && array_key_exists('GLOBALS',$value)) {
+ $value['GLOBALS'] = '** Recursion **';
+ $encoded_value = $this->json_encode($value);
+ if($encoded_value instanceof Exception) {
+ return $encoded_value;
+ return $this->json_encode(strval($name)) . ':' . $encoded_value;
Added: trunk/mapbender/http/extensions/fb.php
--- trunk/mapbender/http/extensions/fb.php (rev 0)
+++ trunk/mapbender/http/extensions/fb.php 2009-10-15 13:26:41 UTC (rev 4781)
@@ -0,0 +1,261 @@
+<?php
+/* ***** BEGIN LICENSE BLOCK *****
+require_once dirname(__FILE__).'/FirePHP.class.php';
+ * @return true
+function fb()
+ $instance = FirePHP::getInstance(true);
+ $args = func_get_args();
+ return call_user_func_array(array($instance,'fb'),$args);
+class FB
+ * @see FirePHP->setEnabled()
+ * @return void
+ public static function setEnabled($Enabled) {
+ $instance->setEnabled($Enabled);
+ * @see FirePHP->getEnabled()
+ public static function getEnabled() {
+ return $instance->getEnabled();
+ * @see FirePHP->setObjectFilter()
+ * @param array $Filter An array or members to exclude
+ * @return void
+ public static function setObjectFilter($Class, $Filter) {
+ $instance->setObjectFilter($Class, $Filter);
+ * @see FirePHP->setOptions()
+ * @return void
+ public static function setOptions($Options) {
+ $instance->setOptions($Options);
+ * Get options for the library
+ * @see FirePHP->getOptions()
+ * @return array The options
+ public static function getOptions() {
+ return $instance->getOptions();
+ * Log object to firebug
+ * @return true
+ public static function send()
+ * Options:
+ * @return true
+ public static function group($Name, $Options=null) {
+ return $instance->group($Name, $Options);
+ * @return true
+ public static function groupEnd() {
+ return self::send(null, null, FirePHP::GROUP_END);
+ * @return true
+ public static function log($Object, $Label=null) {
+ return self::send($Object, $Label, FirePHP::LOG);
+ * @return true
+ public static function info($Object, $Label=null) {
+ return self::send($Object, $Label, FirePHP::INFO);
+ * @return true
+ public static function warn($Object, $Label=null) {
+ return self::send($Object, $Label, FirePHP::WARN);
+ * @return true
+ public static function error($Object, $Label=null) {
+ return self::send($Object, $Label, FirePHP::ERROR);
+ * @return true
+ public static function dump($Key, $Variable) {
+ return self::send($Variable, $Key, FirePHP::DUMP);
+ * @return true
+ public static function trace($Label) {
+ return self::send($Label, FirePHP::TRACE);
+ * @return true
+ public static function table($Label, $Table) {
+ return self::send($Table, $Label, FirePHP::TABLE);
More information about the Mapbender_commits
