[Mapbender-commits] r4787 - in branches/2.6: conf http/javascripts
svn_mapbender at osgeo.org
Mon Oct 19 09:00:48 EDT 2009
Author: christoph
Date: 2009-10-19 09:00:47 -0400 (Mon, 19 Oct 2009)
New Revision: 4787
branches/2.6/conf/digitize_default.conf
branches/2.6/http/javascripts/geometry.js
branches/2.6/http/javascripts/mod_digitize_tab.php
http://trac.osgeo.org/mapbender/ticket/546
Modified: branches/2.6/conf/digitize_default.conf
--- branches/2.6/conf/digitize_default.conf 2009-10-19 12:49:17 UTC (rev 4786)
+++ branches/2.6/conf/digitize_default.conf 2009-10-19 13:00:47 UTC (rev 4787)
@@ -61,4 +61,6 @@
var wfsWindowHeight = 300;
// deprecated! check wfs_default.conf to configure this behaviour
-//var spatialRequestResultToDigitize = 1;
\ No newline at end of file
+//var spatialRequestResultToDigitize = 1;
+var featuresMustHaveUniqueId = true;
Modified: branches/2.6/http/javascripts/geometry.js
--- branches/2.6/http/javascripts/geometry.js 2009-10-19 12:49:17 UTC (rev 4786)
+++ branches/2.6/http/javascripts/geometry.js 2009-10-19 13:00:47 UTC (rev 4787)
@@ -109,13 +109,36 @@
return this.get(i).get(j).innerRings.get(k).get(l);
+GeometryArray.prototype.clone = function () {
+ var geomArray = new GeometryArray();
+ return geomArray.union(this, false);
* appends a geometry array to an existing geometryArray
* @param {GeometryArray} geom GeometryArray
-GeometryArray.prototype.union = function(geom){
+GeometryArray.prototype.union = function(geom, uniqueFid){
var oldLen = this.count();
+ // only add geometries that are not already present
+ if (typeof uniqueFid === "boolean" && uniqueFid) {
+ var geom = geom.clone();
+ for (var i = 0; i < this.count(); i++) {
+ var existingFid = this.get(i).e.getElementValueByName("fid");
+ var len = geom.count() - 1;
+ for (var j = len; j >= 0; j--) {
+ var fid = geom.get(j).e.getElementValueByName("fid");
+ if (fid && fid === existingFid) {
+ geom.del(j);
+ continue;
this.importGeoJSON(geom.toString());
var j = 0;
for (var i = oldLen; i < this.count(); i++) {
Modified: branches/2.6/http/javascripts/mod_digitize_tab.php
--- branches/2.6/http/javascripts/mod_digitize_tab.php 2009-10-19 12:49:17 UTC (rev 4786)
+++ branches/2.6/http/javascripts/mod_digitize_tab.php 2009-10-19 13:00:47 UTC (rev 4787)
@@ -35,7 +35,7 @@
$digitize_conf_filename = "digitize_default.conf";
include '../include/dyn_css.php';
-<script language='JavaScript'>
+<script type='text/javascript'>
// Buttons
@@ -131,6 +131,10 @@
try {if(nonTransactionalEditable){}}catch(e) {nonTransactionalEditable = false;}
try {if(addCloneGeometryButton){}}catch(e) {addCloneGeometryButton = false;}
+if (typeof featuresMustHaveUniqueId === "undefined") {
+ var featuresMustHaveUniqueId = false;
function getMousePosition(e) {
var ind = parent.getMapObjIndexByName("<?php echo $e_target; ?>");
currentPos = parent.mb_mapObj[ind].getMousePosition(e);
@@ -170,7 +174,7 @@
function appendGeometryArray(obj) {
executeDigitizePreFunctions();
- d.union(obj);
+ d.union(obj, featuresMustHaveUniqueId);
executeDigitizeSubFunctions();
@@ -1533,7 +1537,8 @@
wfsWindow = open("", "wfsattributes", "width="+wfsWindowWidth+", height="+wfsWindowHeight+", resizable, dependent=yes, scrollbars=yes");
wfsWindow.document.open("text/html");
wfsWindow.focus();
+ wfsWindow.focus();
var str = "";
var strStyle = "";
var defaultIndex = -1;
More information about the Mapbender_commits
