[Mapbender-commits] r4794 - branches/2.6/lib
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Tue Oct 20 06:05:39 EDT 2009
Author: christoph
Date: 2009-10-20 06:05:39 -0400 (Tue, 20 Oct 2009)
New Revision: 4794
   branches/2.6/lib/customTreeController.js
   branches/2.6/lib/customTreeModel.js
   branches/2.6/lib/saveButton.js
   branches/2.6/lib/selectableButton.js
merged from PortalU Ingrid 2.1
Modified: branches/2.6/lib/customTreeController.js
--- branches/2.6/lib/customTreeController.js	2009-10-20 10:04:56 UTC (rev 4793)
+++ branches/2.6/lib/customTreeController.js	2009-10-20 10:05:39 UTC (rev 4794)
@@ -5,16 +5,21 @@
 	var currentlyDraggedNode;
 	this.options = options;
+	this.options.draggable = typeof options.draggable === "undefined" ?
+		true : options.draggable;
+	this.options.collapsed = typeof options.collapsed === "undefined" ?
+		true : options.collapsed;
 	this.myTree = myTree;
-	this.$root = $("<ul></ul>");
+	this.$root = $("<ul class='custom-tree-treeview custom-tree-filetree'></ul>");
 	var that = this;
 	// --------------- BEHAVIOUR (begin) ------------------
 	var addLeafBehaviour = function ($domNode, treeNode) {
-		$label = $domNode.children().eq(0);
+		$label = $domNode.children().eq(1);
 		// enable context menu
 		if (that.options.contextMenu) {
@@ -22,18 +27,57 @@
 		// make leaves draggable
-		makeNodeDraggable($domNode, treeNode);
+		if (that.options.draggable) {
+			makeNodeDraggable($domNode, treeNode);
+		var additionalBehaviour = that.options.leafBehaviour;
+		for (var i = 0; i < additionalBehaviour.length; i++) {
+			var c = additionalBehaviour[i];
+			var additionalHtml = "<" + c.openTag + ">";
+			if (typeof c.closeTag === "string" && c.closeTag !== "") {
+				additionalHtml += "</" + c.closeTag + ">";
+			var $additionalButton = $(additionalHtml);
+			if (typeof c.attr === "object") {
+				$additionalButton.attr(c.attr);
+			if (typeof c.css === "object") {
+				$additionalButton.css(c.css);
+			if (typeof c.behaviour === "object") {
+				(function () {
+					var currentBehaviour = c.behaviour;
+					var $currentButton = $additionalButton;
+					for (var j in currentBehaviour) {
+						var beh = currentBehaviour[j];
+						$currentButton[j](function(){
+							beh({
+								treeNode: treeNode,
+								appId: that.myTree.appId
+			$domNode.children("span").prepend($additionalButton);
 		treeNode.hasChanged = function () {
 			that.myTree.hasChanged = true;
-	var addFolderBehaviour = function ($domNode, treeNode) {
+	var addFolderBehaviour = function ($domNode, treeNode, options) {
+		$hitarea = $domNode.children().eq(0);
 		if (treeNode != that.myTree.root) {
 			// enable folder closing and opening
-			addOpenCloseBehaviour($label);
+			addOpenCloseBehaviour($hitarea, options);
@@ -41,7 +85,9 @@
 			// make inner nodes draggable
 		else {
@@ -142,17 +188,120 @@
+	var openFolder = function ($node) {
+		var $this = $node;
+		if ($this.hasClass("custom-tree-expandable-hitarea")) {
+			$this.removeClass("custom-tree-expandable-hitarea");
+			$this.addClass("custom-tree-collapsable-hitarea");
+		if ($this.hasClass("custom-tree-lastExpandable-hitarea")) {
+			$this.removeClass("custom-tree-lastExpandable-hitarea");
+			$this.addClass("custom-tree-lastCollapsable-hitarea");
+		var $li = $node.parent();
+		if ($li.hasClass("custom-tree-expandable")) {
+			$li.removeClass("custom-tree-expandable");
+			$li.addClass("custom-tree-collapsable");
+		if ($li.hasClass("custom-tree-lastExpandable")) {
+			$li.removeClass("custom-tree-lastExpandable");
+			$li.addClass("custom-tree-lastCollapsable");
+		$this.siblings("ul").show("fast");
+	var closeFolder = function ($node) {
+		if ($this.hasClass("custom-tree-collapsable-hitarea")) {
+			$this.removeClass("custom-tree-collapsable-hitarea");
+			$this.addClass("custom-tree-expandable-hitarea");
+		if ($this.hasClass("custom-tree-lastCollapsable-hitarea")) {
+			$this.removeClass("custom-tree-lastCollapsable-hitarea");
+			$this.addClass("custom-tree-lastExpandable-hitarea");
+		if ($li.hasClass("custom-tree-collapsable")) {
+			$li.removeClass("custom-tree-collapsable");
+			$li.addClass("custom-tree-expandable");
+		if ($li.hasClass("custom-tree-lastCollapsable")) {
+			$li.removeClass("custom-tree-lastCollapsable");
+			$li.addClass("custom-tree-lastExpandable");
+		$this.siblings("ul").hide("fast");
 	// OPEN AND CLOSE BEHAVIOUR
-	var addOpenCloseBehaviour = function ($domNode) {
-		$domNode.toggle(function () {
-			$(this).siblings().hide("fast");
-		}, function () {
-			$(this).siblings().show("fast");
+	var addOpenCloseBehaviour = function ($domNode, options) {
+		if (typeof options === "object" && options.collapsed) {
+			$domNode.siblings("ul").css("display", "none");
+			$domNode.toggle(function () {
+				openFolder($(this));
+			}, function () {
+				closeFolder($(this));
+		else {
+			}, function () {
+	var isFolder = function ($node) {
+		if ($node.children("div.custom-tree-hitarea").size() > 0) {
+			return true;
+		return false;
+	var makeNodeLast = function ($node) {
+		if (isFolder($node)) {
+			$node.addClass("custom-tree-last");
+			if ($node.hasClass("custom-tree-collapsable")) {
+				$node.addClass("custom-tree-lastCollapsable");
+			else if ($node.hasClass("custom-tree-expandable")) {
+				$node.addClass("custom-tree-lastExpandable");
+			var $hitarea = $node.children("div:first");
+			if ($hitarea.hasClass("custom-tree-collapsable-hitarea")) {
+				$hitarea.addClass("custom-tree-lastCollapsable-hitarea");
+			else if ($hitarea.hasClass("custom-tree-expandable-hitarea")) {
+				$hitarea.addClass("custom-tree-lastExpandable-hitarea");
+			return;
+	var makeNodeLastButOne = function ($node) {
+			$node.removeClass("custom-tree-last");
+			if ($node.hasClass("custom-tree-lastCollapsable")) {
+				$node.removeClass("custom-tree-lastCollapsable");
+			else if ($node.hasClass("custom-tree-lastExpandable")) {
+				$node.removeClass("custom-tree-lastExpandable");
+			if ($hitarea.hasClass("custom-tree-lastCollapsable-hitarea")) {
+				$hitarea.removeClass("custom-tree-lastCollapsable-hitarea");
+			else if ($hitarea.hasClass("custom-tree-lastExpandable-hitarea")) {
+				$hitarea.removeClass("custom-tree-lastExpandable-hitarea");
+			return;
 	// DRAGGABLE AND DROPPABLE
@@ -160,6 +309,7 @@
 		$domNode.draggable({
 			"helper": "clone",
 			"start": function(){
+				var $this = $(this);
 				$(this).addClass("currently-dragging");
 				currentlyDraggedNode = treeNode;
@@ -181,10 +331,51 @@
 			"drop": function (e, ui) {
 				$toDomNode = $(this);
 				$fromDomNode = $(ui.draggable);
+				var parent1 = ui.draggable.parent().prev().get(0);
+				var parent2 = this;
+				// has node been inserted in the same branch?
+				if (parent1 === parent2) {
+					// the dragged node is the last of the branch
+					if ($fromDomNode.hasClass("custom-tree-last")) {
+						// do nothing
+					else {
+						var $li = $toDomNode.next().children();
+						if ($li.size() > 1) {
+							var $oldLast = $li.eq($li.size() - 2);
+							makeNodeLastButOne($oldLast);
+						$toDomNode.next().append($fromDomNode);
+						makeNodeLast($fromDomNode);
+				else {
+						// make last but one node last
+						$fromDomNode.removeClass("custom-tree-last");
+						var $prev = $fromDomNode.prev("li");
+						if ($prev.size() > 0) {
+							makeNodeLast($prev);
+					var $oldLast = $toDomNode.next().children("li:last");
+					if ($oldLast.size() > 0) {
 				currentlyDraggedNode.afterMove = function () {
-					$toDomNode.next().append($(ui.draggable));
-					$(".treeLeaf").removeAttr("style");
+					$(".custom-tree-leaf").removeAttr("style");
 					$("*").removeClass("currently-dragging");
 				currentlyDraggedNode.move(treeNode);
@@ -194,10 +385,17 @@
 	// --------------- BEHAVIOUR (end) ------------------
-	var createLeaf = function (treeNode) {
-		var $currentItem = $("<li class='treeLeaf'></li>");
-		var $currentLabel = $("<span>" + treeNode.name + "</span>");
+	var createLeaf = function (treeNode, options) {
+		var $currentItem = $("<li></li>");
+		var $currentIcon = $("<div></div>");
+		var $currentLabel = $("<span class='custom-tree-file'>" + treeNode.name + "</span>");
+		if (typeof options === "object" && options.last) {
+			$currentItem.addClass("custom-tree-last");
+		$currentItem.append($currentIcon);
 		$currentItem.append($currentLabel);
 		addLeafBehaviour($currentItem, treeNode);
@@ -211,16 +409,49 @@
 		return $currentItem;
-	var createFolder = function (treeNode) {
-		var $currentItem = $("<li class='treeNode'></li>");
-		var $currentLabel = $("<div class='treeNodeDrop'><span>" + treeNode.name + "</span></div>");
+	var createFolder = function (treeNode, options) {
+		var $currentItem;
+			$currentItem = $("<li class='custom-tree-expandable'></li>");
+		else {
+			$currentItem = $("<li class='custom-tree-collapsable'></li>");
+		var $currentIcon = $("<div class='custom-tree-hitarea'></div>");
+		var $currentLabel = $("<div class='treeNodeDrop'>" +
+			"<span class='custom-tree-folder'>" + treeNode.name +
+			"</span></div>");
 		var $currentFolder = $("<ul></ul>");
+		if (typeof options === "object") {
+			if (options.collapsed) {
+				if (options.last) {
+					$currentItem.addClass("custom-tree-lastExpandable");
+					$currentIcon.addClass("custom-tree-lastExpandable-hitarea");
+				$currentItem.addClass("custom-tree-expandable");
+				$currentIcon.addClass("custom-tree-expandable-hitarea");
+			else {
+					$currentItem.addClass("custom-tree-lastCollapsable");
+					$currentIcon.addClass("custom-tree-lastCollapsable-hitarea");
+				$currentItem.addClass("custom-tree-collapsable");
+				$currentIcon.addClass("custom-tree-collapsable-hitarea");
+		else {
 		$currentItem.append($currentFolder);
 		treeNode.isFolder = true;
-		addFolderBehaviour($currentItem, treeNode);
+		addFolderBehaviour($currentItem, treeNode, options);
 		treeNode.$domNode = $currentItem;
@@ -233,14 +464,26 @@
 		treeNode.afterAddChild = function (newChild) {
-			$newNode = createFolder(newChild);
-			var $folder = $currentItem.children().eq(1);
+			var $folder = $currentItem.children("ul");
+			var size = $folder.children("li").size();
+			if (size > 0) {
+				makeNodeLastButOne($folder.children("li").eq(size - 1));
+			$newNode = createFolder(newChild, {
+				last: true
 			$folder.append($newNode);
 		treeNode.afterAppend = function (newChild) {
+			if (size > 0) {
+				last: true
@@ -253,20 +496,26 @@
 	 * @param {Object} $domNode
 	 * @param {Object} treeNode
-	var drawNode = function ($domNode, treeNode) {
+	var drawNode = function ($domNode, treeNode, options) {
 		var numOfChildren = treeNode.childNodeList.count();
 		var $newNode;
 		if (numOfChildren === 0 && treeNode != that.myTree.root && !treeNode.isFolder) {
-			$newNode = createLeaf(treeNode);
+			$newNode = createLeaf(treeNode, options);
 		else {
-			$newNode = createFolder(treeNode);
+			$newNode = createFolder(treeNode, options);
 			// visit the child nodes (depth first)
-			var $folder = $newNode.children().eq(1);
+			var $folder = $newNode.children("ul");
 			for (var i = 0; i < numOfChildren; i++) {
-				drawNode.apply(that, [$folder, treeNode.childNodeList.get(i)]);
+				var opt = {
+					collapsed: that.options.collapsed
+				if (i === numOfChildren - 1) {
+					opt.last = true;
+				drawNode.apply(that, [$folder, treeNode.childNodeList.get(i), opt]);
 		// attach node to tree
@@ -275,5 +524,19 @@
 	$("#" + this.options.id).empty();
 	$("#" + this.options.id).append(that.$root);
-	drawNode(that.$root, that.myTree.root);
+	if (options.skipRootNode) {
+		var numOfChildren = that.myTree.root.childNodeList.count();
+		for (var i = 0; i < numOfChildren; i++) {
+			drawNode.apply(that, [that.$root, that.myTree.root.childNodeList.get(i), {
+				last: numOfChildren - 1 === i ? true : false,
+				collapsed: typeof that.options.collapsed !== "undefined" ?
+					that.options.collapsed : true
+	else {
+		drawNode(that.$root, that.myTree.root, {
+			last: true
\ No newline at end of file
Modified: branches/2.6/lib/customTreeModel.js
--- branches/2.6/lib/customTreeModel.js	2009-10-20 10:04:56 UTC (rev 4793)
+++ branches/2.6/lib/customTreeModel.js	2009-10-20 10:05:39 UTC (rev 4794)
@@ -116,7 +116,7 @@
  * w/ nested sets output
-var CustomTree = function () {
+var CustomTree = function (options) {
 	this.root = new CustomTreeNode (null);
 	var that = this;
@@ -126,7 +126,7 @@
 	this.toNestedSets = function () {
 		var nodeArray = toNestedSetsNode.apply(this, [[], this.root, 1]);
 		return nodeArray;
 	var toNestedSetsNode = function (nodeArray, node, nextLeft) {
 		var left = nextLeft;
@@ -188,9 +188,9 @@
 	this.importNestedSets = function (nodeArray) {
-		if(nodeArray===undefined || nodeArray.length<1)
+		if(nodeArray===undefined || nodeArray.length<1) {
 			return false;
 		//numeric sort function
 		var nodeSort = function(a,b){
@@ -236,6 +236,15 @@
 			//new node is the one that take next childs
 			currentNode = newNode;
+		// add WMS for root
+		var wmsIdArray = nodeArray[0].wms;
+		for (var j in wmsIdArray) {
+			var newWmsNode = new CustomTreeNode(this.root);
+			newWmsNode.wmsId = j;
+			newWmsNode.name = wmsIdArray[j];
+			this.root.append(newWmsNode);
 		return true;
@@ -274,6 +283,105 @@
 			currentChild.remove();
+	var addMissingWmsToCustomTree = function (anApplicationId, callback) {
+		// get available WMS ...
+		var queryObj = {
+			command:"getWmsByApplication",
+			parameters: {
+				"applicationId": anApplicationId
+		$.post("../php/mod_customTree_server.php", {
+			queryObj:$.toJSON(queryObj)
+		}, function (json, status) {
+			var replyObj = eval('(' + json + ')');
+			var wmsIdArray = findAllWmsInTree();
+			for (var index in replyObj.data.wmsArray) {
+				var found = false;
+				for (var j = 0; j < wmsIdArray.length; j++) {
+					if (wmsIdArray[j] == index) {
+						found = true;
+						break;
+				if (!found) {
+					var wmsNode = new CustomTreeNode();
+					wmsNode.name = replyObj.data.wmsArray[index];
+					wmsNode.wmsId = index;
+					that.root.append(wmsNode);
+			that.hasChanged = false;
+			callback();
+	var findAllWmsInTree = function () {
+		return findAllWmsInNode(that.root).sort();
+	findAllWmsInNode = function (aNode) {
+		if (!aNode.isFolder) {
+			return [aNode.wmsId];
+		var wmsIdArray = [];
+		for (var i = 0; i < aNode.childNodeList.count(); i++) {
+			var child = aNode.childNodeList.get(i);
+			var newArray = findAllWmsInNode(child);
+			wmsIdArray = wmsIdArray.concat(newArray);
+		return wmsIdArray;
+	var getCustomTreeByApplication = function (applicationName) {
+		that.appId = applicationName;
+		// load a previously saved
+		// customized tree from the database
+		var queryObj = {
+			command:"getCustomTreeByApplication",
+			parameters: {
+				"applicationId":applicationName
+			that.root.name = "(" + applicationName + ")";
+			var nodeArray = replyObj.data.nodeArray;
+			that.importNestedSets(nodeArray);
+			addMissingWmsToCustomTree(applicationName, function () {
+				displayMyTree = new customTreeController(that, {
+					contextMenu: options.contextMenu ? true : false,
+					droppable: options.droppable ? true : false,
+					draggable: typeof options.draggable === "undefined" ?
+						false : options.draggable,
+					id: options.id ?
+						options.id : "myTree" + ((new Date()).getTime()),
+					skipRootNode: typeof options.skipRootNode === "undefined" ?
+						false : options.skipRootNode,
+					leafBehaviour: typeof options.leafBehaviour === "undefined" ?
+						[] : options.leafBehaviour
+	if (typeof options === "object" && options.loadFromApplication) {
+		getCustomTreeByApplication(options.loadFromApplication);
@@ -404,4 +512,4 @@
 		return foundNonFolder;
Modified: branches/2.6/lib/saveButton.js
--- branches/2.6/lib/saveButton.js	2009-10-20 10:04:56 UTC (rev 4793)
+++ branches/2.6/lib/saveButton.js	2009-10-20 10:05:39 UTC (rev 4794)
@@ -32,5 +32,3 @@
Modified: branches/2.6/lib/selectableButton.js
--- branches/2.6/lib/selectableButton.js	2009-10-20 10:04:56 UTC (rev 4793)
+++ branches/2.6/lib/selectableButton.js	2009-10-20 10:05:39 UTC (rev 4794)
@@ -29,6 +29,4 @@
 		$(".ui-selectee").removeClass("ui-selectee");
 		$(".ui-selectable").removeClass("ui-selectable");
More information about the Mapbender_commits mailing list
