[Mapbender-commits] r4811 - branches/2.6/http/php
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Tue Oct 20 07:59:03 EDT 2009
Author: christoph
Date: 2009-10-20 07:59:03 -0400 (Tue, 20 Oct 2009)
New Revision: 4811
   branches/2.6/http/php/mod_meetingPoint.php
correct unix line breaks
Modified: branches/2.6/http/php/mod_meetingPoint.php
--- branches/2.6/http/php/mod_meetingPoint.php	2009-10-20 11:56:24 UTC (rev 4810)
+++ branches/2.6/http/php/mod_meetingPoint.php	2009-10-20 11:59:03 UTC (rev 4811)
@@ -1,372 +1,371 @@
-<?PHP
-# $Id$
-# http://www.mapbender.org/index.php/MeetingPoint
-# Copyright (C) 2002 CCGIS
-# This program is free software; you can redistribute it and/or modify
-# it under the terms of the GNU General Public License as published by
-# the Free Software Foundation; either version 2, or (at your option)
-# any later version.
-# This program is distributed in the hope that it will be useful,
-# but WITHOUT ANY WARRANTY; without even the implied warranty of
-# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
-# GNU General Public License for more details.
-# You should have received a copy of the GNU General Public License
-# along with this program; if not, write to the Free Software
-# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
-require_once(dirname(__FILE__) . "/../php/mb_validateSession.php");
-<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
-<html>
-<head>
-<title>meetingPoint</title>
-<?php
-include '../include/dyn_css.php';
-<script language='JavaScript'>
-<?php
-include('../include/dyn_js.php');
-echo "var mod_meetingPoint_target = '" . $_REQUEST["e_target"] . "';";
-echo "var meetingPoint_write_to = 'meetingPoint';";
-try{
-	if (meetingPoint_export_subject){}
-catch(e){
-	meetingPoint_export_subject = 'Your meeting point. Follow the link!';
-try{
-	if (meetingPoint_export_format){}
-catch(e){
-	meetingPoint_export_format = 'prompt';
-try{
-	if (meetingPoint_max_characters){}
-catch(e){
-	meetingPoint_max_characters = 100;
-try{
-	if (meetingPoint_image){}
-catch(e){
-	meetingPoint_image = "../img/button_digitize/point_off.png";
-try{
-	if (meetingPoint_icon){}
-catch(e){
-	meetingPoint_icon = '../img/redball.gif';
-try{
-	if (meetingPoint_width){}
-catch(e){
-	meetingPoint_width = 14;
-try{
-	if (meetingPoint_height){}
-catch(e){
-	meetingPoint_height = 14;
-try{
-	if (meetingPoint_style){}
-catch(e){
-	meetingPoint_style = 'background-color:white;font-weight: bold;color:black;font-family:Arial;';
-try{
-	if (meetingPoint_please_click){}
-catch(e){
-	meetingPoint_please_click = 'Please click for the meeting point position!';
-var mod_meetingPointRealPoint = null;
-//parent.mb_registerSubFunctions("window.frames['meetingPoint'].mod_meetingPoint_draw()");
-parent.eventAfterMapRequest.register(function () {
-	mod_meetingPoint_draw();
-var ie = document.all?1:0;
-var mod_meetingPoint_win = null;
-var mod_meetingPoint_elName = "meetingPoint";
-var mod_meetingPoint_frameName = "meetingPoint";
-var mod_meetingPoint_button = "my_getCoords";
-var mod_meetingPoint_img_on = new Image(); mod_meetingPoint_img_on.src = meetingPoint_image.replace(/_off/,"_on") ;
-var mod_meetingPoint_img_off = new Image(); mod_meetingPoint_img_off.src = meetingPoint_image;
-var mod_meetingPoint_img_over = new Image(); mod_meetingPoint_img_over.src = meetingPoint_image.replace(/_off/,"_over") ;
-var mod_meetingPoint_fix = "";
-function init_mod_meetingPoint(ind){
-	parent.mb_button[ind] = window.document.getElementById(mod_meetingPoint_button);
-	parent.mb_button[ind].img_over = mod_meetingPoint_img_over.src;
-	parent.mb_button[ind].img_on = mod_meetingPoint_img_on.src;
-	parent.mb_button[ind].img_off = mod_meetingPoint_img_off.src;
-	parent.mb_button[ind].status = 0;
-	parent.mb_button[ind].elName = mod_meetingPoint_button;
-	parent.mb_button[ind].go = new Function ("mod_meetingPoint_run()");
-	parent.mb_button[ind].stop = new Function ("mod_meetingPoint_disable()");
-function mod_meetingPoint_run(){
-	var mapObject = parent.getMapObjByName(mod_meetingPoint_target);
-	if (mapObject) {
-		mapObject.getDomElement().ownerDocument.onclick = function (e) {
-			var clickPos = mapObject.getMousePosition(e);
-			mod_meetingPointRealPoint = mapObject.convertPixelToReal(clickPos);
-			mod_meetingPoint_write(mod_meetingPointRealPoint.x, mod_meetingPointRealPoint.y);
-			parent.mb_disableThisButton(mod_meetingPoint_button);
-function mod_meetingPoint_disable(){
-	if (mapObject) {
-		mapObject.getDomElement().ownerDocument.onclick = null;
-function mod_meetingPoint_click(e){
-	if(ie){
-		clickX = parent.frames[mod_meetingPoint_target].event.clientX;
-		clickY = parent.frames[mod_meetingPoint_target].event.clientY;
-	else{
-		clickX = e.pageX;
-		clickY = e.pageY;
-	var pos = parent.makeClickPos2RealWorldPos(mod_meetingPoint_target, clickX, clickY);
-	mod_meetingPoint_write(pos[0],pos[1]);
-function mod_meetingPoint_write(x,y){
-   document.forms[0].x.value =x;
-   document.forms[0].y.value =y;
-function mod_meetingPoint_hide(){
-	//var ind = parent.getMapObjIndexByName(mod_meetingPoint_target);
-	//parent.frames[mod_meetingPoint_target].document.getElementById('permanent').style.visibility = 'hidden';
-//	parent.$("#" + mapObject.elementName + "_permanent").css({
-//		visibility:"hidden"
+<?PHP
+# $Id$
+# http://www.mapbender.org/index.php/MeetingPoint
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+require_once(dirname(__FILE__) . "/../php/mb_validateSession.php");
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
+<html>
+<head>
+<title>meetingPoint</title>
+<?php
+include '../include/dyn_css.php';
+<script language='JavaScript'>
+<?php
+include('../include/dyn_js.php');
+echo "var mod_meetingPoint_target = '" . $_REQUEST["e_target"] . "';";
+echo "var meetingPoint_write_to = 'meetingPoint';";
+try{
+	if (meetingPoint_export_subject){}
+catch(e){
+	meetingPoint_export_subject = 'Your meeting point. Follow the link!';
+try{
+	if (meetingPoint_export_format){}
+catch(e){
+	meetingPoint_export_format = 'prompt';
+try{
+	if (meetingPoint_max_characters){}
+catch(e){
+	meetingPoint_max_characters = 100;
+try{
+	if (meetingPoint_image){}
+catch(e){
+	meetingPoint_image = "../img/button_digitize/point_off.png";
+try{
+	if (meetingPoint_icon){}
+catch(e){
+	meetingPoint_icon = '../img/redball.gif';
+try{
+	if (meetingPoint_width){}
+catch(e){
+	meetingPoint_width = 14;
+try{
+	if (meetingPoint_height){}
+catch(e){
+	meetingPoint_height = 14;
+try{
+	if (meetingPoint_style){}
+catch(e){
+	meetingPoint_style = 'background-color:white;font-weight: bold;color:black;font-family:Arial;';
+try{
+	if (meetingPoint_please_click){}
+catch(e){
+	meetingPoint_please_click = 'Please click for the meeting point position!';
+var mod_meetingPointRealPoint = null;
+//parent.mb_registerSubFunctions("window.frames['meetingPoint'].mod_meetingPoint_draw()");
+parent.eventAfterMapRequest.register(function () {
+	mod_meetingPoint_draw();
+var ie = document.all?1:0;
+var mod_meetingPoint_win = null;
+var mod_meetingPoint_elName = "meetingPoint";
+var mod_meetingPoint_frameName = "meetingPoint";
+var mod_meetingPoint_button = "my_getCoords";
+var mod_meetingPoint_img_on = new Image(); mod_meetingPoint_img_on.src = meetingPoint_image.replace(/_off/,"_on") ;
+var mod_meetingPoint_img_off = new Image(); mod_meetingPoint_img_off.src = meetingPoint_image;
+var mod_meetingPoint_img_over = new Image(); mod_meetingPoint_img_over.src = meetingPoint_image.replace(/_off/,"_over") ;
+var mod_meetingPoint_fix = "";
+function init_mod_meetingPoint(ind){
+	parent.mb_button[ind] = window.document.getElementById(mod_meetingPoint_button);
+	parent.mb_button[ind].img_over = mod_meetingPoint_img_over.src;
+	parent.mb_button[ind].img_on = mod_meetingPoint_img_on.src;
+	parent.mb_button[ind].img_off = mod_meetingPoint_img_off.src;
+	parent.mb_button[ind].status = 0;
+	parent.mb_button[ind].elName = mod_meetingPoint_button;
+	parent.mb_button[ind].go = new Function ("mod_meetingPoint_run()");
+	parent.mb_button[ind].stop = new Function ("mod_meetingPoint_disable()");
+function mod_meetingPoint_run(){
+	var mapObject = parent.getMapObjByName(mod_meetingPoint_target);
+	if (mapObject) {
+		mapObject.getDomElement().ownerDocument.onclick = function (e) {
+			var clickPos = mapObject.getMousePosition(e);
+			mod_meetingPointRealPoint = mapObject.convertPixelToReal(clickPos);
+			mod_meetingPoint_write(mod_meetingPointRealPoint.x, mod_meetingPointRealPoint.y);
+			parent.mb_disableThisButton(mod_meetingPoint_button);
+function mod_meetingPoint_disable(){
+	if (mapObject) {
+		mapObject.getDomElement().ownerDocument.onclick = null;
+function mod_meetingPoint_click(e){
+	if(ie){
+		clickX = parent.frames[mod_meetingPoint_target].event.clientX;
+		clickY = parent.frames[mod_meetingPoint_target].event.clientY;
+	else{
+		clickX = e.pageX;
+		clickY = e.pageY;
+	var pos = parent.makeClickPos2RealWorldPos(mod_meetingPoint_target, clickX, clickY);
+	mod_meetingPoint_write(pos[0],pos[1]);
+function mod_meetingPoint_write(x,y){
+   document.forms[0].x.value =x;
+   document.forms[0].y.value =y;
+function mod_meetingPoint_hide(){
+	//var ind = parent.getMapObjIndexByName(mod_meetingPoint_target);
+	//parent.frames[mod_meetingPoint_target].document.getElementById('permanent').style.visibility = 'hidden';
+//	parent.$("#" + mapObject.elementName + "_permanent").css({
+//		visibility:"hidden"
-	parent.$("#" + mapObject.elementName + "_permanent").empty();
-function mod_meetingPoint_draw(){
-    var splitext  = document.forms[0].mytext.value;
-    document.forms[0].mytext.value = splitext.substring(0, meetingPoint_max_characters);
-	if (mapObject) {
-		if (mod_meetingPointRealPoint !== null) {
-			//alert(document.forms[0].x.value +" -- "+ document.forms[0].y.value + " - " );
-			var meetingPointClickPos = mapObject.convertRealToPixel(mod_meetingPointRealPoint);
-			var tagSource = "";
-			tagSource += "<div style='z-index:13;position:absolute;left:"+(meetingPointClickPos.x- Math.round(0.5*meetingPoint_width))+"px;top:"+(meetingPointClickPos.y-Math.round(0.5*meetingPoint_height))+"px'>";
-			tagSource += "<img src='"+meetingPoint_icon+"'>";
-			tagSource += "<span style='"+meetingPoint_style+"'>"+document.forms[0].mytext.value+"<span>";
-			tagSource += "</div>";
-			var map_el = mapObject.getDomElement();
-			if (!map_el.ownerDocument.getElementById(mapObject.elementName + "_permanent")) {
-				//create Box Elements
-				var $div = parent.$("<div id='" + mapObject.elementName + "_permanent'><img src='../img/redball.gif'/></div>");
-				$div.css({
-					position: "absolute",
-					top: "0px",
-					left: "0px",
-					zIndex: 13
-				map_el.appendChild($div.get(0));
-			parent.$("#" + mapObject.elementName + "_permanent").html(tagSource);
-/* Check max character value*/
-function checkMaxCharacters() {
-	var stringLength = document.forms[0].mytext.value.length;
-	if (stringLength > meetingPoint_max_characters) {
-		document.forms[0].mytext.value = document.forms[0].mytext.value.slice(0, meetingPoint_max_characters) ;
-		alert("meetingPoint_max_characters is set to " + meetingPoint_max_characters);
-function setMaxCharacterTitle() {
-	var maxCharacterString = "Max characters: " + meetingPoint_max_characters;
-//	document.getElementById("mytext").title = maxCharacterString;
-	document.getElementById("mytext").setAttribute("title",maxCharacterString);
-//	document.forms[0].mytext.title = maxCharacterString;
-	var ind = parent.getMapObjIndexByName(mod_meetingPoint_target);
-	if (document.forms[0].x.value!='' && document.forms[0].y.value != ''){
-		//alert(document.forms[0].x.value +" -- "+ document.forms[0].y.value + " - " + parent.mb_mapObj[ind].width +" iii: "+ ind);
-		parent.frames[mod_meetingPoint_target].document.getElementById('permanent').style.width = parent.mb_mapObj[ind].width;
-		parent.frames[mod_meetingPoint_target].document.getElementById('permanent').style.height = parent.mb_mapObj[ind].height;
-		parent.frames[mod_meetingPoint_target].document.getElementById('permanent').style.top = 0;
-		parent.frames[mod_meetingPoint_target].document.getElementById('permanent').style.left = 0;
-		parent.frames[mod_meetingPoint_target].document.getElementById('permanent').style.visibility = 'visible';
-		var pos = parent.makeRealWorld2mapPos(mod_meetingPoint_target,document.forms[0].x.value, document.forms[0].y.value);
-		tagSource += "<div style='z-index:13;position:absolute;left:"+(pos[0]- Math.round(0.5*meetingPoint_width))+"px;top:"+(pos[1]-Math.round(0.5*meetingPoint_height))+"px'>";
-		//prompt("meetingPoint",tagSource);
-	    parent.writeTag(mod_meetingPoint_target, "permanent", tagSource);
-</script>
-<?php
-echo "var used_charset = '".CHARSET ."';";
-function validate(){
-	var mycheck = true;
-	var checkObj= document.forms[0].mytext.value;
-	if(checkObj == '') {
-    	alert ("Bitte geben Sie einen Text an!");
-    	checkObj.focus();
-        mycheck=false;
-    var checkObj= document.forms[0].x.value;
-    	alert (meetingPoint_please_click);
-        mycheck = false;
-    if(mycheck == true){
-    	my_meetingPoint = document.forms[0].myurl.value + "?";
-    	my_meetingPoint += "name=" + encodeURIComponent(document.forms[0].myuser.value);
-    	my_meetingPoint += "&password=" + encodeURIComponent(document.forms[0].mypw.value);
-    	my_meetingPoint += "&mb_user_myGui=" + encodeURIComponent(document.forms[0].mygui.value);
-    	var ind = parent.getMapObjIndexByName('mapframe1');
-    	var coord = parent.mb_mapObj[ind].extent.split(",");
-    	my_meetingPoint += "&mb_myBBOX=" + parseFloat(coord[0]) + ",";
-		my_meetingPoint +=  parseFloat(coord[1]) + ",";
-		my_meetingPoint +=  parseFloat(coord[2]) + ",";
-		my_meetingPoint +=  parseFloat(coord[3]) ;
-    	my_meetingPoint += "&mb_myPOI=";
-    	my_meetingPoint += encodeURIComponent(document.forms[0].mytext.value);
-    	my_meetingPoint += "|" + document.forms[0].x.value + "|";
-    	my_meetingPoint += document.forms[0].y.value;
-    	if(meetingPoint_export_format == 'email'){
-    		createEmail(my_meetingPoint,meetingPoint_export_subject);
-		}else{
-			prompt(meetingPoint_export_subject,my_meetingPoint);
-function emptyfields(){
-	document.forms[0].mytext.value ='';
-	document.forms[0].x.value ='';
-	document.forms[0].y.value =  '';
-	 mod_meetingPoint_hide();
-function createEmail (url,subject) {
-  var email = "mailto:"
-  email  += "";
-  email  += "?subject=";
-  email  += subject;
-  email  += "&body=";
-  email  += escape(url);
-  var win = window.open(email, 'email', 'top=120,left=120');
-  win.close();
-function goBack(where){
-    document.location.href=where;
-function init(){
-	parent.mb_regButton_frame("init_mod_meetingPoint","meetingPoint",null);
-</script>
-</head>
-<body onload="setMaxCharacterTitle()">
-<form action="" >
-<img  id='my_getCoords' name='my_getCoords' onclick="mod_meetingPoint_run()" onmouseover ="parent.mb_regButton_frame('init_mod_meetingPoint','meetingPoint',null)"  title="Treffpunkt setzen"  src = '../img/button_digitize/point_off.png'>
-<br>
-<input class='strinput' type="hidden" name='myurl' value='<?php  echo LOGIN;  ?>'>
-<input class='strinput' type="hidden" name='mygui' value='<?php  echo $_SESSION["mb_user_gui"];  ?>'>
-<input class='strinput' type="hidden" name='myuser' value='<?php  echo $_SESSION["mb_user_name"];  ?>'>
-<input class='strinput' type="hidden" name='mypw' value='<?php  echo $_SESSION["mb_user_password"];  ?>'>
-<br>
-<!--<input class='strinput' type="textarea" size=2 name='mytext' value='' "maxlength=70" title="max. 70 Zeichen">-->
-<textarea class='strinput' rows="3" name='mytext' id='mytext' onmouseover='checkMaxCharacters()' title='' onkeyup='checkMaxCharacters()'></textarea>
-<br>
-<input class="okbutton" name="Send"   type="button" value="ok" onclick="validate();">
-<input class="ibutton" type="button" value="cancel" onClick="emptyfields();">
-<br>
-<input class="coord" type="hidden" name='x' value='' readonly>
-<input class="coord" type="hidden" name='y' value='' readonly>
-<br>
-</form>
-</body>
-</html>
\ No newline at end of file
+	parent.$("#" + mapObject.elementName + "_permanent").empty();
+function mod_meetingPoint_draw(){
+    var splitext  = document.forms[0].mytext.value;
+    document.forms[0].mytext.value = splitext.substring(0, meetingPoint_max_characters);
+	if (mapObject) {
+		if (mod_meetingPointRealPoint !== null) {
+			//alert(document.forms[0].x.value +" -- "+ document.forms[0].y.value + " - " );
+			var meetingPointClickPos = mapObject.convertRealToPixel(mod_meetingPointRealPoint);
+			var tagSource = "";
+			tagSource += "<div style='z-index:13;position:absolute;left:"+(meetingPointClickPos.x- Math.round(0.5*meetingPoint_width))+"px;top:"+(meetingPointClickPos.y-Math.round(0.5*meetingPoint_height))+"px'>";
+			tagSource += "<img src='"+meetingPoint_icon+"'>";
+			tagSource += "<span style='"+meetingPoint_style+"'>"+document.forms[0].mytext.value+"<span>";
+			tagSource += "</div>";
+			var map_el = mapObject.getDomElement();
+			if (!map_el.ownerDocument.getElementById(mapObject.elementName + "_permanent")) {
+				//create Box Elements
+				var $div = parent.$("<div id='" + mapObject.elementName + "_permanent'><img src='../img/redball.gif'/></div>");
+				$div.css({
+					position: "absolute",
+					top: "0px",
+					left: "0px",
+					zIndex: 13
+				map_el.appendChild($div.get(0));
+			parent.$("#" + mapObject.elementName + "_permanent").html(tagSource);
+/* Check max character value*/
+function checkMaxCharacters() {
+	var stringLength = document.forms[0].mytext.value.length;
+	if (stringLength > meetingPoint_max_characters) {
+		document.forms[0].mytext.value = document.forms[0].mytext.value.slice(0, meetingPoint_max_characters) ;
+		alert("meetingPoint_max_characters is set to " + meetingPoint_max_characters);
+function setMaxCharacterTitle() {
+	var maxCharacterString = "Max characters: " + meetingPoint_max_characters;
+//	document.getElementById("mytext").title = maxCharacterString;
+	document.getElementById("mytext").setAttribute("title",maxCharacterString);
+//	document.forms[0].mytext.title = maxCharacterString;
+	var ind = parent.getMapObjIndexByName(mod_meetingPoint_target);
+	if (document.forms[0].x.value!='' && document.forms[0].y.value != ''){
+		//alert(document.forms[0].x.value +" -- "+ document.forms[0].y.value + " - " + parent.mb_mapObj[ind].width +" iii: "+ ind);
+		parent.frames[mod_meetingPoint_target].document.getElementById('permanent').style.width = parent.mb_mapObj[ind].width;
+		parent.frames[mod_meetingPoint_target].document.getElementById('permanent').style.height = parent.mb_mapObj[ind].height;
+		parent.frames[mod_meetingPoint_target].document.getElementById('permanent').style.top = 0;
+		parent.frames[mod_meetingPoint_target].document.getElementById('permanent').style.left = 0;
+		parent.frames[mod_meetingPoint_target].document.getElementById('permanent').style.visibility = 'visible';
+		var pos = parent.makeRealWorld2mapPos(mod_meetingPoint_target,document.forms[0].x.value, document.forms[0].y.value);
+		tagSource += "<div style='z-index:13;position:absolute;left:"+(pos[0]- Math.round(0.5*meetingPoint_width))+"px;top:"+(pos[1]-Math.round(0.5*meetingPoint_height))+"px'>";
+		//prompt("meetingPoint",tagSource);
+	    parent.writeTag(mod_meetingPoint_target, "permanent", tagSource);
+</script>
+<?php
+echo "var used_charset = '".CHARSET ."';";
+function validate(){
+	var mycheck = true;
+	var checkObj= document.forms[0].mytext.value;
+	if(checkObj == '') {
+    	alert ("Bitte geben Sie einen Text an!");
+    	checkObj.focus();
+        mycheck=false;
+    var checkObj= document.forms[0].x.value;
+    	alert (meetingPoint_please_click);
+        mycheck = false;
+    if(mycheck == true){
+    	my_meetingPoint = document.forms[0].myurl.value + "?";
+    	my_meetingPoint += "name=" + encodeURIComponent(document.forms[0].myuser.value);
+    	my_meetingPoint += "&password=" + encodeURIComponent(document.forms[0].mypw.value);
+    	my_meetingPoint += "&mb_user_myGui=" + encodeURIComponent(document.forms[0].mygui.value);
+    	var ind = parent.getMapObjIndexByName('mapframe1');
+    	var coord = parent.mb_mapObj[ind].extent.split(",");
+    	my_meetingPoint += "&mb_myBBOX=" + parseFloat(coord[0]) + ",";
+		my_meetingPoint +=  parseFloat(coord[1]) + ",";
+		my_meetingPoint +=  parseFloat(coord[2]) + ",";
+		my_meetingPoint +=  parseFloat(coord[3]) ;
+    	my_meetingPoint += "&mb_myPOI=";
+    	my_meetingPoint += encodeURIComponent(document.forms[0].mytext.value);
+    	my_meetingPoint += "|" + document.forms[0].x.value + "|";
+    	my_meetingPoint += document.forms[0].y.value;
+    	if(meetingPoint_export_format == 'email'){
+    		createEmail(my_meetingPoint,meetingPoint_export_subject);
+		}else{
+			prompt(meetingPoint_export_subject,my_meetingPoint);
+function emptyfields(){
+	document.forms[0].mytext.value ='';
+	document.forms[0].x.value ='';
+	document.forms[0].y.value =  '';
+	 mod_meetingPoint_hide();
+function createEmail (url,subject) {
+  var email = "mailto:"
+  email  += "";
+  email  += "?subject=";
+  email  += subject;
+  email  += "&body=";
+  email  += escape(url);
+  var win = window.open(email, 'email', 'top=120,left=120');
+  win.close();
+function goBack(where){
+    document.location.href=where;
+function init(){
+	parent.mb_regButton_frame("init_mod_meetingPoint","meetingPoint",null);
+</script>
+</head>
+<body onload="setMaxCharacterTitle()">
+<form action="" >
+<img  id='my_getCoords' name='my_getCoords' onclick="mod_meetingPoint_run()" onmouseover ="parent.mb_regButton_frame('init_mod_meetingPoint','meetingPoint',null)"  title="Treffpunkt setzen"  src = '../img/button_digitize/point_off.png'>
+<br>
+<input class='strinput' type="hidden" name='myurl' value='<?php  echo LOGIN;  ?>'>
+<input class='strinput' type="hidden" name='mygui' value='<?php  echo $_SESSION["mb_user_gui"];  ?>'>
+<input class='strinput' type="hidden" name='myuser' value='<?php  echo $_SESSION["mb_user_name"];  ?>'>
+<input class='strinput' type="hidden" name='mypw' value='<?php  echo $_SESSION["mb_user_password"];  ?>'>
+<br>
+<!--<input class='strinput' type="textarea" size=2 name='mytext' value='' "maxlength=70" title="max. 70 Zeichen">-->
+<textarea class='strinput' rows="3" name='mytext' id='mytext' onmouseover='checkMaxCharacters()' title='' onkeyup='checkMaxCharacters()'></textarea>
+<br>
+<input class="okbutton" name="Send"   type="button" value="ok" onclick="validate();">
+<input class="ibutton" type="button" value="cancel" onClick="emptyfields();">
+<br>
+<input class="coord" type="hidden" name='x' value='' readonly>
+<input class="coord" type="hidden" name='y' value='' readonly>
+<br>
+</form>
+</body>
+</html>
More information about the Mapbender_commits mailing list
