[Mapbender-commits] r4831 - branches/2.6/http/javascripts
svn_mapbender at osgeo.org
Tue Oct 20 08:17:14 EDT 2009
Author: christoph
Date: 2009-10-20 08:17:14 -0400 (Tue, 20 Oct 2009)
New Revision: 4831
branches/2.6/http/javascripts/mod_loadwmc.js
cursor
Modified: branches/2.6/http/javascripts/mod_loadwmc.js
--- branches/2.6/http/javascripts/mod_loadwmc.js 2009-10-20 12:16:05 UTC (rev 4830)
+++ branches/2.6/http/javascripts/mod_loadwmc.js 2009-10-20 12:17:14 UTC (rev 4831)
@@ -92,7 +92,7 @@
// Load WMC
- $loadWmc = $("<img src='../img/button_gray/wmc_load.png' title='load this WMC'>");
+ var $loadWmc = $("<img src='../img/button_gray/wmc_load.png' style='cursor:pointer' title='load this WMC'>");
$loadWmc.click(function() {
var queryObj = {command:"loadWmc", parameters:{id:currentId}};
$.post(serverSideFileName, {queryObj: $.toJSON(queryObj)}, function (json, status) {
@@ -102,7 +102,7 @@
try {
if (resultObj.javascript && typeof(resultObj.javascript) == "object") {
for (var j=0; j < resultObj.javascript.length; j++) {
-// var e = new Mb_notice("Statement: " + resultObj.javascript[j]);
+// var e = new Mb_notice("Statement: %s", resultObj.javascript[j]);
eval(resultObj.javascript[j]);
@@ -131,7 +131,7 @@
// Merge WMC
- $mergeWmc = $("<img src='../img/button_gray/wmc_merge.png' title='merge WMC'>");
+ var $mergeWmc = $("<img src='../img/button_gray/wmc_merge.png' style='cursor:pointer' title='merge WMC'>");
$mergeWmc.click(function() {
var extensionDataString = null;
if (currentWmcExtensionData !== null) {
@@ -181,7 +181,7 @@
// Append WMC
- $appendWmc = $("<img src='../img/button_gray/wmc_append.png' title='append WMC'>");
+ var $appendWmc = $("<img src='../img/button_gray/wmc_append.png' style='cursor:pointer' title='append WMC'>");
$appendWmc.click(function() {
@@ -231,7 +231,7 @@
// Display WMC
- $displayWmc = $("<img src='../img/button_gray/wmc_xml.png' title='display WMC XML'>");
+ var $displayWmc = $("<img src='../img/button_gray/wmc_xml.png' style='cursor:pointer' title='display WMC XML'>");
$displayWmc.click(function() {
// create Popup
if (wmcDisplayPopup === null) {
@@ -246,7 +246,7 @@
// set correct URL
if (wmcDisplayPopup.isVisible()) {
- wmcDisplayPopup.setUrl("../javascripts/mod_displayWmc.php?wmc_id=" + currentId);
+ wmcDisplayPopup.setUrl("../javascripts/mod_displayWmc.php?wmc_id=" + currentId + "&" + mb_session_name + "=" + mb_nr);
// display the pop up
wmcDisplayPopup.show();
More information about the Mapbender_commits
