[Mapbender-commits] r4861 - branches/2.6/http/php
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Fri Oct 23 07:33:36 EDT 2009
Author: christoph
Date: 2009-10-23 07:33:35 -0400 (Fri, 23 Oct 2009)
New Revision: 4861
   branches/2.6/http/php/mod_customTree.php
   branches/2.6/http/php/mod_customTree_server.php
Modified: branches/2.6/http/php/mod_customTree.php
--- branches/2.6/http/php/mod_customTree.php	2009-10-23 10:18:04 UTC (rev 4860)
+++ branches/2.6/http/php/mod_customTree.php	2009-10-23 11:33:35 UTC (rev 4861)
@@ -7,16 +7,11 @@
 	<head>
 		<meta http-equiv="Content-Type" content="text/html; charset=<?php echo CHARSET;?>" />
 		<title>Untitled Document</title>
+		<link rel="stylesheet" type="text/css" href="../css/customTree.css">
 		<style type="text/css">
 			.ui-selecting {
 			  color:red;
-			.treeNode {
-			  color:green;
-			.treeLeaf {
-			  color:blue;
 			.ui-selected {
 			  border-width:thin;
 			  border-style:solid;
@@ -57,23 +52,7 @@
 			var applicationId;
-			var findAllWmsInTree = function (aTree) {
-				return findAllWmsInNode(aTree.root).sort();
-			findAllWmsInNode = function (aNode) {
-				if (!aNode.isFolder) {
-					return [aNode.wmsId];
-				var wmsIdArray = [];
-				for (var i = 0; i < aNode.childNodeList.count(); i++) {
-					var child = aNode.childNodeList.get(i);
-					var newArray = findAllWmsInNode(child);
-					wmsIdArray = wmsIdArray.concat(newArray);
-				return wmsIdArray;
 			var saveTreeOnUnloadOrChange = function (myTree) {
 				if (myTree.hasChanged) {
 					var saveChanges = confirm("You have changed the tree. All changes will be lost. Save changes?");
@@ -86,89 +65,18 @@
-			var addMissingWmsToCustomTree = function (aTree, anApplicationId) {
-				// get available WMS ...
-				var queryObj = {
-					command:"getWmsByApplication",
-					parameters: {
-						"applicationId": anApplicationId
-				$.post("../php/mod_customTree_server.php", {
-					queryObj:$.toJSON(queryObj)
-				}, function (json, status) {
-					var replyObj = eval('(' + json + ')');
-					var root = aTree.root;
-					var wmsIdArray = findAllWmsInTree(aTree);
-					for (var index in replyObj.data.wmsArray) {
-						var found = false;
-						for (var j = 0; j < wmsIdArray.length; j++) {
-							if (wmsIdArray[j] == index) {
-								found = true;
-								break;
-						if (!found) {
-							var wmsNode = new CustomTreeNode();
-							wmsNode.name = replyObj.data.wmsArray[index];
-							wmsNode.wmsId = index;
-							myTree.root.append(wmsNode);
-					myTree.hasChanged = false;
-					displayMyTree = new customTreeController(myTree, {
-						contextMenu: true,
-						droppable: true,
-						id: "myTree"
-			var getCustomTreeByApplication = function (applicationName) {
-				// load a previously saved
-				// customized tree from the database
-				var queryObj = {
-					command:"getCustomTreeByApplication",
-					parameters: {
-						"applicationId":applicationName
-					myTree = new CustomTree();
-					var root = myTree.root;
-					root.name = "(" + applicationId + ")";
-					var nodeArray = replyObj.data.nodeArray;
-					myTree.importNestedSets(nodeArray);
-					addMissingWmsToCustomTree(myTree, applicationId);
-						droppable: true,
-						id: "myTree"
 			var selectApplication = function (applicationName) {
 				applicationId = applicationName;
-				getCustomTreeByApplication(applicationId);
+				myTree = new CustomTree({
+					loadFromApplication: applicationName,
+					draggable: true,
+					droppable: true,
+					id: "myTree",
+					contextMenu: true
 			var getApplications = function () {
@@ -253,11 +161,13 @@
 							queryObj: $.toJSON(queryObj)
 						}, function(json, status){
+								draggable: true,
+								droppable: true,
+								id: "myTree",
+								contextMenu: true
@@ -288,7 +198,7 @@
 				// dialogue: save changes on unload
 				$(window).unload(function () {
-					saveTreeOnUnloadOrChange(myTree);
+//					saveTreeOnUnloadOrChange(myTree);
Modified: branches/2.6/http/php/mod_customTree_server.php
--- branches/2.6/http/php/mod_customTree_server.php	2009-10-23 10:18:04 UTC (rev 4860)
+++ branches/2.6/http/php/mod_customTree_server.php	2009-10-23 11:33:35 UTC (rev 4861)
@@ -14,7 +14,6 @@
 	echo $output;
 $json = new Mapbender_JSON();
 $queryObj = $json->decode(stripslashes($_REQUEST['queryObj']));
 $resultObj = array();
@@ -49,8 +48,8 @@
 		$allowedApplicationArray = $user->getApplicationsByPermission(0);
 		// get all of the users applications that contain treeGDE
-		$sql = "SELECT fkey_gui_id FROM gui_element WHERE " .
-				"e_id = 'treeGDE' AND fkey_gui_id IN (";
+		$sql = "SELECT DISTINCT gui_id FROM gui WHERE " .
+				"gui_id IN (";
 		$v = array();
 		$t = array();
@@ -130,8 +129,8 @@
 				$currentNode = array(
-					"left" => $row["lft"],
-					"right" => $row["rgt"],
+					"left" => intval($row["lft"]),
+					"right" => intval($row["rgt"]),
 					"name" => $row["my_layer_title"],
 					"wms" => $wmsArray
@@ -155,6 +154,7 @@
 		$t = array("s");
 		$res = db_prep_query($sql, $v, $t);
+		$rowArray = array();
 		for ($i = 0; $i < count($elementArray); $i++) {
 			$currentElement = $elementArray[$i];
@@ -170,8 +170,9 @@
 			$t = array("s", "i", "i", "s", "s");
+			$rowArray[]= $v;
-		$data = array("sql" => $sql, "data" => $v);
+		$data = array("sql" => $sql, "data" => $rowArray);
 		$resultObj["data"] = $data;
 		$resultObj["success"] = "Elements have been updated in the database.";
 		break;
@@ -183,4 +184,4 @@
 sendOutput($resultObj);
\ No newline at end of file
More information about the Mapbender_commits mailing list
