[Mapbender-commits] r4880 - trunk/mapbender/conf
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Fri Oct 30 07:27:04 EDT 2009
Author: christoph
Date: 2009-10-30 07:27:04 -0400 (Fri, 30 Oct 2009)
New Revision: 4880
   trunk/mapbender/conf/digitize_default.conf
Modified: trunk/mapbender/conf/digitize_default.conf
--- trunk/mapbender/conf/digitize_default.conf	2009-10-29 17:28:53 UTC (rev 4879)
+++ trunk/mapbender/conf/digitize_default.conf	2009-10-30 11:27:04 UTC (rev 4880)
@@ -3,9 +3,9 @@
 //   kind of digitizing (e.g. point, line, or polygon)
 // * Do not change the ID (first entry)!!
-addButtonDig("Point", 1, "point_off.png", "", "", 0, 0);
-addButtonDig("Line", 1, "line_off.png", "", "", 28, 0);
-addButtonDig("Polygon", 1, "polygon_off.png", "", "", 56, 0);
+addButtonDig("point", 1, "point_off.png", "", "", 0, 0);
+addButtonDig("line", 1, "line_off.png", "", "", 28, 0);
+addButtonDig("polygon", 1, "polygon_off.png", "", "", 56, 0);
 addButtonDig("dragBasePoint", 1, "move_node_off.png", "", "", 84, 0);
 addButtonDig("setBasePoint", 1, "new_node_off.png", "", "", 112, 0);
 addButtonDig("delBasePoint", 1, "delete_node_off.png", "", "", 140, 0);
@@ -70,3 +70,4 @@
 var featuresMustHaveUniqueId = false;
 var openMetadataEditorAfterNewGeometryHasBeenCreated = false;
+var allowUndoPolygonBySnapping = false;
More information about the Mapbender_commits mailing list
