[Mapbender-commits] r4890 - trunk/mapbender/http/javascripts
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Fri Oct 30 07:36:31 EDT 2009
Author: christoph
Date: 2009-10-30 07:36:31 -0400 (Fri, 30 Oct 2009)
New Revision: 4890
   trunk/mapbender/http/javascripts/mod_digitize_tab.php
Modified: trunk/mapbender/http/javascripts/mod_digitize_tab.php
--- trunk/mapbender/http/javascripts/mod_digitize_tab.php	2009-10-30 11:36:00 UTC (rev 4889)
+++ trunk/mapbender/http/javascripts/mod_digitize_tab.php	2009-10-30 11:36:31 UTC (rev 4890)
@@ -74,6 +74,63 @@
 var mapDomElement;
 var mapType = "";
+var DigitizeHistory = function () {
+	var historyItemArray = [];
+	var currentIndex = 0;
+	this.addItem = function (obj) {
+		if (typeof obj == "object"
+		&& obj.back && typeof obj.back === "function"
+		&& obj.forward && typeof obj.forward === "function"
+			for (var i = currentIndex; i < historyItemArray.length; i++) {
+				delete historyItemArray[i];
+			historyItemArray.length = currentIndex;
+			historyItemArray.push({
+				back: obj.back,
+				forward: obj.forward
+			return true;
+		return false;
+	this.back = function () {
+//		console.log("HistoryItems: %s", historyItemArray);
+		if (currentIndex > 0) {
+			currentIndex --;
+			historyItemArray[currentIndex].back();
+//			console.log("B-----");
+//			console.log(s);
+//			console.log("EXECUTING %s", historyItemArray[currentIndex].back);
+//			console.log("GeomArray (post): %s", d);
+//			console.log("Index: %s", currentIndex);
+			executeDigitizeSubFunctions();
+			return true;
+		return false;
+	this.forward = function () {
+		if (currentIndex < historyItemArray.length) {
+			historyItemArray[currentIndex].forward();
+//			console.log("F-----");
+//			console.log("EXECUTING %s", historyItemArray[currentIndex].forward);
+//			console.log(s);
+			currentIndex ++;
+			return true;
+		return false;
+var digitizeHistory = new DigitizeHistory();
 parent.eventInit.register(function () {
 	var mapIndex = parent.getMapObjIndexByName(mod_digitize_target);
 	mapDomElement = parent.mb_mapObj[mapIndex].getDomElement();
@@ -89,6 +146,9 @@
 	eventCloseGeometry = new parent.Mapbender.Event();
+	eventCloseGeometry.register(function () {
+		d.close();
 	if (openMetadataEditorAfterNewGeometryHasBeenCreated) {
 		eventCloseGeometry.register(function (obj) {
 			if (typeof obj !== "object") {
@@ -119,9 +179,9 @@
 var mod_digitizeEvent = false;
 var nonTransactionalHighlight;
-var button_point = "Point";
-var button_line = "Line";
-var button_polygon = "Polygon";
+var button_point;
+var button_line;
+var button_polygon;
 var button_move = "dragBasePoint";
 var button_insert = "setBasePoint";
 var button_delete = "delBasePoint";
@@ -150,6 +210,10 @@
 	var featuresMustHaveUniqueId = false;
+if (typeof allowUndoPolygonBySnapping === "undefined") {
+	var allowUndoPolygonBySnapping = false;
 if (typeof openMetadataEditorAfterNewGeometryHasBeenCreated === "undefined") {
 	var openMetadataEditorAfterNewGeometryHasBeenCreated = false;
@@ -224,6 +288,9 @@
 	Geometry = parent.Geometry;
 	Point = parent.Point;
 	geomType = parent.geomType;
+	button_point = parent.geomType.point; //"Point";
+	button_line = parent.geomType.line; //"Line";
+	button_polygon = parent.geomType.polygon; //"Polygon";
@@ -261,15 +328,8 @@
 	if (e) {
 		// track mouse position
 		var currentPos = getMousePosition(e);
 		s.check(currentPos);
-	else {
-//		s.clean();
-	var el = mapDomElement;
-	el.onmousedown = mod_digitize_start;
 function mod_digitize_timeout(){
@@ -279,16 +339,54 @@
 	el.onmousemove = null;
+var isLastLinePointSnapped = function (newPoint) {
+	return d.get(-1).geomType === parent.geomType.line
+		&& d.getGeometry(-1,-1).count() > 1
+		&& d.getGeometry(-1,-1).get(-1).equals(newPoint);
+var innerPointSnapped = function (newPoint) {
+	if (d.count() === 0) {
+		return null;
+	var start = 1;
+	if (d.getGeometry(-1, -1).count() < 3) {
+		start = 0;
+	for (var i = start; i < d.getGeometry(-1, -1).count(); i++) {
+		if (d.getGeometry(-1,-1).get(i).equals(newPoint)) {
+			return i;
+	return null;
+var isFirstPolygonPointSnapped = function (newPoint) {
+	return d.get(-1).geomType == parent.geomType.polygon
+		&& d.getGeometry(-1,-1).count() >= 3
+		&& d.getGeometry(-1,-1).get(0).equals(newPoint);
+var editingPolygonAndThreePointsHaveBeenInserted = function () {
+	return d.get(-1).geomType == parent.geomType.polygon && d.getGeometry(-1,-1).count() == 2;
+var editingLineAndTwoPointsHaveBeenInserted = function () {
+	return d.get(-1).geomType == parent.geomType.line && d.getGeometry(-1,-1).count() >= 1;
 function mod_digitize_start(e){
-	// check if a proper geometry is selected
-	if (d.getGeometry(-1,-1).isComplete() || d.count() == 0){
-		if (mod_digitizeEvent != false) {
-			alert(msgObj.errorMessageNoGeometrySelected);
+	if (mod_digitizeEvent !== button_point
+		&& mod_digitizeEvent !== button_line
+		&& mod_digitizeEvent !== button_polygon) {
+		alert(msgObj.errorMessageNoGeometrySelected);
 		return false;
+	// get the last point the user digitized
 	var realWorldPos;
 	if (s.isSnapped()) {
 		realWorldPos = s.getSnappedPoint();
@@ -298,59 +396,150 @@
 		realWorldPos = parent.mapToReal(mod_digitize_target,currentPos);
-	if (d.get(-1).geomType == parent.geomType.polygon && d.getGeometry(-1,-1).count() > 1 && d.getGeometry(-1,-1).get(0).equals(realWorldPos)) {
-		// close the polygon
-		d.close();
-		eventCloseGeometry.trigger({
-			index: d.count() - 1,
-			geometry: d.get(-1)
-		parent.mb_disableThisButton(button_polygon);
-		return true;
-	else if (d.get(-1).geomType == parent.geomType.line && d.getGeometry(-1,-1).count() > 1 && d.getGeometry(-1,-1).get(-1).equals(realWorldPos)) {
-		// close the line
-		d.close();
-		parent.mb_disableThisButton(button_line);
-		return true;
-	else {
-		// set the calculated real world position as point of the geometry
-		d.getGeometry(-1,-1).addPoint(realWorldPos);
-		var mapIndex = parent.getMapObjIndexByName(mod_digitize_target);
-		d.getGeometry(-1,-1).setEpsg(parent.mb_mapObj[mapIndex].epsg);
-		if(d.get(-1).geomType == parent.geomType.point){
-			d.close();
+	(function () {
+		var geometryType = mod_digitizeEvent;
+		var currentPoint = realWorldPos;
+		var currentEpsg = parent.mb_mapObj[parent.getMapObjIndexByName(mod_digitize_target)].epsg;
+		// A new geometry has to be created
+		if (d.count() === 0 || (d.get(-1).count()> 0 && d.getGeometry(-1, -1).isComplete())) {
+			digitizeHistory.addItem({
+				// remove the entire multigeometry
+				back: function () {
+					s.removePoint(d.getPoint(-1, -1, -1));
+					d.del(-1);
+				// add the multigeometry to the geometry array
+				forward: function () {
+					parent.mb_enableButton(geometryType);
+					d.addMember(geometryType);
+					d.get(-1).addGeometry();
+					d.getGeometry(-1,-1).setEpsg(currentEpsg);
+					d.getGeometry(-1,-1).addPoint(realWorldPos);
+					if (geometryType == parent.geomType.point){
+						eventCloseGeometry.trigger({
+							index: d.count() - 1,
+							geometry: d.get(-1)
+						parent.mb_disableThisButton(geometryType);
+					else {
+						s.add(d.getPoint(-1, -1, -1));
-			parent.mb_disableThisButton(button_point);
-			return true;
-		// add first point of polygon to snapping list (if three points have been inserted).
-		else if (d.get(-1).geomType == parent.geomType.polygon && d.getGeometry(-1,-1).count() == 3) {
-			s.add(d.getPoint(-1, -1, 0));
+		// a point is added to an existing multigeometry
+		else {
+			var innerPointIndex = innerPointSnapped(realWorldPos);
+			// editing polygon and first point is snapped -> close polygon
+			if (isFirstPolygonPointSnapped(realWorldPos)) {
+						d.getGeometry(-1, -1).reopen();
+						parent.mb_enableButton(d.get(-1).geomType);
+						// activate button
+						// close the polygon
+						parent.mb_disableThisButton(button_polygon);
+			// editing line and last point is snapped -> close line
+			else if (isLastLinePointSnapped(realWorldPos)) {
+						parent.mb_disableThisButton(button_line);
+			// another point is snapped (undo)
+			else if (innerPointIndex !== null && allowUndoPolygonBySnapping) {
+				while (d.getGeometry(-1, -1).count() > innerPointIndex) {
+					digitizeHistory.back();
+				// avoids the forward!
+				return;
+			// just add the point
+			else {
+				if (editingPolygonAndThreePointsHaveBeenInserted()) {
+//							s.removePoint(d.getPoint(-1, -1, 0));
+							d.getGeometry(-1, -1).del(-1);
+//							s.add(d.getPoint(-1, -1, 0));
+				else if (editingLineAndTwoPointsHaveBeenInserted()) {
+				else {
+		digitizeHistory.forward();
-		// add last point of line to snapping list (if at least two points have been inserted).
-		else if (d.get(-1).geomType == parent.geomType.line && d.getGeometry(-1,-1).count() >= 2) {
-			if (mod_digitizeEvent != button_move) {
-				s.store(d);
-			s.add(d.getPoint(-1, -1, -1));
-	executeDigitizeSubFunctions();
+//		if (mod_digitizeEvent != button_move) {
+//			s.store(d);
 	return true;
 // --- polygon, line, point insertion (begin) ----------------------------------------------------------------------------------------------
@@ -697,7 +886,7 @@
 			var currentStatus = buttonDig_id[i].status;
 			var currentTitle = "";
 			switch (buttonDig_id[i]) {
-				case "Point":
+				case "point":
 					if (currentStatus == 1) {
 						currentTitle = msgObj.buttonLabelPointOn;
@@ -705,7 +894,7 @@
 						currentTitle = msgObj.buttonLabelPointOff;
 					break;
-				case "Line":
+				case "line":
 						currentTitle = msgObj.buttonLabelLineOn;
@@ -713,7 +902,7 @@
 						currentTitle = msgObj.buttonLabelLineOff;
 					break;
-				case "Polygon":
+				case "polygon":
 						currentTitle = msgObj.buttonLabelPolygonOn;
@@ -809,113 +998,75 @@
 		el.onmousemove = mod_digitize_go;
+		el.onmousedown = mod_digitize_start;
 		mod_digitizeEvent = obj.id;
 		if (mod_digitizeEvent == button_point || mod_digitizeEvent == button_line || mod_digitizeEvent == button_polygon || mod_digitizeEvent == button_insert ) {
-			s.store(d);
+			// complete a previously unfinished geometry
+			(function () {
+				var currentGeometryDoesNotCorrespondToTheCurrentButton =
+					(d.count() > 0 && d.get(-1).count() > 0 &&
+					!d.get(-1).get(-1).isComplete() &&
+					mod_digitizeEvent !== d.get(-1).geomType);
+				var currentGeometryType = mod_digitizeEvent;
+				if (currentGeometryDoesNotCorrespondToTheCurrentButton) {
+						back: function(){
+							d.del(-1);
+						forward: function(){
+							d.close();
+							d.addMember(currentGeometryType);
+//			s.store(d);
 		executeDigitizePreFunctions();
 		obj.title = obj.title_on;
-		if (obj.id == button_point) {
+		if (obj.id == button_polygon) {
+			// close previous open polygons
 			if (d.count() > 0 && d.get(-1).count() > 0 && !d.get(-1).get(-1).isComplete()) {
-				if (d.get(-1).geomType != parent.geomType.point) {
-					d.close();
+				if (d.get(-1).geomType !== parent.geomType.polygon) {
+//					d.close();
+//					executeDigitizeSubFunctions();
 				else {
-			if (d.count() == 0 || (d.count() > 0 && d.get(-1).count() > 0 && d.get(-1).get(-1).isComplete())) {
-				d.addMember(parent.geomType.point);
-				d.get(-1).addGeometry();
-			else {
-// delete existing line or polygon
-				d.del(-1);
-		else if (obj.id == button_polygon) {
-			if (d.count() > 0 && d.get(-1).count() > 0 && !d.get(-1).get(-1).isComplete()) {
-				if (d.get(-1).geomType != parent.geomType.polygon) {
-					d.close();
-				else {
-				// new geometry
-				d.addMember(parent.geomType.polygon);
-			else {
-// continue a line as a polygon
-					var geometryTemplate = parent.cloneObject(d.get(-1));
-					d.del(-1);
-					for (var i = 0; i < geometryTemplate.count(); i++) {
-						for (var j = 0; j < geometryTemplate.get(i).count(); j++) {
-							d.get(-1).get(-1).addPoint(geometryTemplate.get(i).get(j));
 		else if (obj.id == button_line) {
 				if (d.get(-1).geomType != parent.geomType.line) {
-					d.close();
+//					d.close();
 				else {
+//					s.add(d.getPoint(-1, -1, -1));
-				d.addMember(parent.geomType.line);
-			else {
-// continue a polygon as a line
-				if (d.get(-1).geomType != parent.geomType.line) {
-					d.del(-1);
 		else if (obj.id == button_clear) {
 			var clear = confirm(msgObj.messageConfirmDeleteAllGeomFromList);
 			if (clear) {
 				d = new parent.GeometryArray();
+				s.resetPoints();
 				parent.mb_disableThisButton(button_clear);
+				digitizeHistory = new DigitizeHistory();
 		else if (obj.id == button_merge) {
@@ -1010,36 +1161,15 @@
+	else {
+		alert("unknown type: " + obj.id);
 function digitizeDisable(obj) {
-	if (obj.id == button_point || obj.id == button_line ||
-		obj.id == button_polygon){
-		obj.title = obj.title_off;
-		// remove geometries without basepoints
-		if (d.get(-1).get(-1).count() == 0) {
-			d.delGeometry(-1,-1);
-		mod_digitize_timeout();
-	else if (obj.id == button_clear) {
-	else if (obj.id == button_merge) {
-	else if (obj.id == button_split) {
-	else if (obj.id == button_difference) {
+	obj.title = obj.title_off;
+	mod_digitize_timeout();
 // --- button handling (end) ----------------------------------------------------------------------------------------------
@@ -2245,6 +2375,8 @@
 	</script>
 	</head>
 	<body onload="registerFunctions();displayButtons();">
+		<img id="digitizeBack" style="position:absolute;top:28;left:84" src="../img/button_digitize/back_on.png" title="" onclick="digitizeHistory.back()" name="digitizeBack"/>
+		<img id="digitizeForward" style="position:absolute;top:28;left:112" src="../img/button_digitize/forward_on.png" title="" onclick="digitizeHistory.forward()" name="digitizeForward"/>
 		<div id='digButtons'></div>
 		<div id='listOfGeometries' class='digitizeGeometryList'></div>
 	</body>
More information about the Mapbender_commits mailing list
