[Mapbender-commits] r4607 - branches/ur_dev/install
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Thu Sep 10 04:06:18 EDT 2009
Author: uli
Date: 2009-09-10 04:06:17 -0400 (Thu, 10 Sep 2009)
New Revision: 4607
   branches/ur_dev/install/class_dia.php
   branches/ur_dev/install/update.php
Modified: branches/ur_dev/install/class_dia.php
--- branches/ur_dev/install/class_dia.php	2009-09-09 15:11:22 UTC (rev 4606)
+++ branches/ur_dev/install/class_dia.php	2009-09-10 08:06:17 UTC (rev 4607)
@@ -18,6 +18,8 @@
 		$this->xp->registerNamespace('dia', 'http://www.lysator.liu.se/~alla/dia/');
 		return true;
 		$tables = $xp->query("//dia:layer[@name='Background']/dia:object[@type='UML - Class']");
 		fwrite(STDOUT, "Found ".$tables->length." composites\n");
 		$i = 0;
@@ -60,13 +62,33 @@
 	public function getTables(){
-		$tables = $xp->query("//dia:layer[@name='Background']/dia:object[@type='UML - Class']");
-		foreach ($tables as $table){
+		$arrayTableNames = array();
+		$tables = $this->getTabeleBasicNode();
+		foreach($tables as $table){
+			array_push($arrayTableNames, $this->removeHash($table->firstChild->nodeValue));
+		return $arrayTableNames;
+	private function removeHash($string){
+		//this could be a problem if the columnname contains a #
+		return str_replace("#","",$string);
+	private function getTabeleBasicNode(){
+		$xpString = "//dia:layer[@name='Background']/dia:object[@type='UML - Class']";
+		$xpString .= "/dia:attribute[@name='name']";
+		return $this->xp->query($xpString);
 	public function getColumns($tablename){
+		$arrayTableColumns = array();
+			if($this->removeHash($table->firstChild->nodeValue) == $tablename){
+		return $arrayTableColumns;
 	public function getColumnType($tablename, $columnname){
Modified: branches/ur_dev/install/update.php
--- branches/ur_dev/install/update.php	2009-09-09 15:11:22 UTC (rev 4606)
+++ branches/ur_dev/install/update.php	2009-09-10 08:06:17 UTC (rev 4607)
@@ -21,7 +21,10 @@
 $dia = new Dia();
 $dia->load($filename);
 //fwrite(STDOUT, "Hello $name");
+$tables = $dia->getTables();
+foreach($tables as $table){
+	fwrite(STDOUT, "Found Tables: ".$table."\n");
 // Exit correctly
 exit(0);
More information about the Mapbender_commits mailing list
