[Mapbender-commits] r4631 - branches/2.6/resources/db/pgsql
svn_mapbender at osgeo.org
Tue Sep 15 07:17:58 EDT 2009
Author: tbaschetti
Date: 2009-09-15 07:17:58 -0400 (Tue, 15 Sep 2009)
New Revision: 4631
Removed:
branches/2.6/resources/db/pgsql/pgsql_serial_set_sequences_7x_2.5.sql
drop support for PostgreSQL 7.x
Deleted: branches/2.6/resources/db/pgsql/pgsql_serial_set_sequences_7x_2.5.sql
--- branches/2.6/resources/db/pgsql/pgsql_serial_set_sequences_7x_2.5.sql 2009-09-15 11:16:43 UTC (rev 4630)
+++ branches/2.6/resources/db/pgsql/pgsql_serial_set_sequences_7x_2.5.sql 2009-09-15 11:17:58 UTC (rev 4631)
@@ -1,37 +0,0 @@
--- Set Sequence for serial values
-SELECT pg_catalog.setval('gui_treegde_id_seq', (Select max(id) from gui_treegde), true);
-SELECT pg_catalog.setval('layer_layer_id_seq', (Select max(layer_id) from layer), true);
-SELECT pg_catalog.setval('mb_group_mb_group_id_seq', (Select max(mb_group_id) from mb_group), true);
-SELECT pg_catalog.setval('mb_log_id_seq', (Select max(id) from mb_log), true);
-SELECT pg_catalog.setval('mb_user_mb_user_id_seq', (Select max(mb_user_id) from mb_user), true);
-SELECT pg_catalog.setval('wfs_wfs_id_seq', (Select max(wfs_id) from wfs), true);
-SELECT pg_catalog.setval('wfs_conf_wfs_conf_id_seq', (Select max(wfs_conf_id) from wfs_conf), true);
-SELECT pg_catalog.setval('wfs_conf_element_wfs_conf_element_id_seq', (Select max(wfs_conf_element_id) from wfs_conf_element), true);
-SELECT pg_catalog.setval('wfs_element_element_id_seq', (Select max(element_id) from wfs_element), true);
-SELECT pg_catalog.setval('wfs_featuretype_featuretype_id_seq', (Select max(featuretype_id) from wfs_featuretype), true);
-SELECT pg_catalog.setval('wms_wms_id_seq', (Select max(wms_id) from wms), true);
--- new sequences from Mapbender version 2.4.1
-SELECT pg_catalog.setval('keyword_id_seq', (Select max(keyword_id) from keyword), true);
-SELECT pg_catalog.setval('md_topic_category_id_seq', (Select max(md_topic_category_id) from md_topic_category), true);
--- new sequences from Mapbender version 2.5
-SELECT pg_catalog.setval('trs_id_seq', (Select max(trs_id) from translations), true);
-SELECT pg_catalog.setval('kml_id_seq', (Select max(kml_id) from gui_kml), true);
-SELECT pg_catalog.setval('sld_user_layer_id_seq', (Select max(sld_user_layer_id) from sld_user_layer), true);
More information about the Mapbender_commits
