[Mapbender-commits] r4639 - trunk/mapbender/http/classes
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Wed Sep 16 11:53:18 EDT 2009
Author: christoph
Date: 2009-09-16 11:53:16 -0400 (Wed, 16 Sep 2009)
New Revision: 4639
Added:
   trunk/mapbender/http/classes/class_georss.php
   trunk/mapbender/http/classes/class_georss_factory.php
   trunk/mapbender/http/classes/class_georss_item.php
   trunk/mapbender/http/classes/class_rss.php
   trunk/mapbender/http/classes/class_rss_factory.php
   trunk/mapbender/http/classes/class_rss_item.php
RSS classes
Added: trunk/mapbender/http/classes/class_georss.php
--- trunk/mapbender/http/classes/class_georss.php	                        (rev 0)
+++ trunk/mapbender/http/classes/class_georss.php	2009-09-16 15:53:16 UTC (rev 4639)
@@ -0,0 +1,22 @@
+<?php
+# License:
+# Copyright (c) 2009, Open Source Geospatial Foundation
+# This program is dual licensed under the GNU General Public License
+# and Simplified BSD license.
+# http://svn.osgeo.org/mapbender/trunk/mapbender/license/license.txt
+require_once(dirname(__FILE__)."/../../core/globalSettings.php");
+require_once(dirname(__FILE__)."/../classes/class_rss.php");
+require_once(dirname(__FILE__)."/../classes/class_georss_item.php");
+ * Creates an RSS Feed.
+class GeoRss extends Rss {
+	protected function getNamespaceString () {
+		return parent::getNamespaceString() .
+			' xmlns:georss="http://www.georss.org/georss"';
\ No newline at end of file
Added: trunk/mapbender/http/classes/class_georss_factory.php
--- trunk/mapbender/http/classes/class_georss_factory.php	                        (rev 0)
+++ trunk/mapbender/http/classes/class_georss_factory.php	2009-09-16 15:53:16 UTC (rev 4639)
@@ -0,0 +1,64 @@
+<?php
+# License:
+require_once dirname(__FILE__) . "/../../core/globalSettings.php";
+require_once dirname(__FILE__) . "/../classes/class_rss_factory.php";
+require_once dirname(__FILE__) . "/../classes/class_georss.php";
+class GeoRssFactory extends RssFactory {
+	public function createFromUrl ($url) {
+		$rss = $this->parseDocument($url, new GeoRss());
+		if (is_null($rss)) {
+			return null;
+		return $this->parseItems($url, $rss);
+	protected function parseItems ($url, $rss) {
+		$domxpath = $this->createDomXpathFromUrl($url, $rss);
+		if (is_null($domxpath)) {
+			return null;
+		$nodeList = $domxpath->query("/rss/channel/item");
+		foreach ($nodeList as $node) {
+			$item = new GeoRssItem();
+			$item = $this->parseItem($node, $item);
+			$rss->append($item);
+		return $rss;
+	protected function parseItem ($node, $item) {
+		$item = parent::parseItem($node, $item);
+		foreach ($node->childNodes as $childNode) {
+			switch ($childNode->tagName) {
+				case "georss:box":
+					$coordinateString = trim($childNode->nodeValue);
+					$coordinateArray = explode(" ", $coordinateString);
+					if (count($coordinateArray) === 4) {
+						$bbox = new Mapbender_bbox(
+							floatval($coordinateArray[0]),
+							floatval($coordinateArray[1]),
+							floatval($coordinateArray[2]),
+							floatval($coordinateArray[3]),
+							"EPSG:4326"
+						$item->setBbox($bbox);
+					break;
+		return $item;
Added: trunk/mapbender/http/classes/class_georss_item.php
--- trunk/mapbender/http/classes/class_georss_item.php	                        (rev 0)
+++ trunk/mapbender/http/classes/class_georss_item.php	2009-09-16 15:53:16 UTC (rev 4639)
@@ -0,0 +1,42 @@
+<?php
+# License:
+require_once dirname(__FILE__) . "/../classes/class_bbox.php";
+class GeoRssItem extends RssItem {
+	private $bbox;
+	public function setBbox ($bbox) {
+		if (is_a($bbox, "Mapbender_bbox")) {
+			$this->bbox = $bbox;
+			return true;
+		new mb_exception(__FILE__ .
+			": setBbox(): parameter not a Mapbender_bbox!");
+		return false;
+	public function getBbox () {
+		return $this->bbox;
+	protected function getItemString () {
+		$str = parent::getItemString();
+		if (is_a($this->bbox, "Mapbender_bbox")) {
+			$str .= "<georss:box>" .
+					$this->bbox->min->x . " " .
+					$this->bbox->min->y . " " .
+					$this->bbox->max->x . " " .
+					$this->bbox->max->y .
+	            "</georss:box>\n";
+		return $str;
Added: trunk/mapbender/http/classes/class_rss.php
--- trunk/mapbender/http/classes/class_rss.php	                        (rev 0)
+++ trunk/mapbender/http/classes/class_rss.php	2009-09-16 15:53:16 UTC (rev 4639)
@@ -0,0 +1,140 @@
+<?php
+# License:
+require_once dirname(__FILE__) . "/../classes/class_rss_item.php";
+class Rss {
+    var $channel_url;
+    var $channel_title;
+    var $channel_description;
+    var $channel_lang;
+    var $channel_copyright;
+    var $channel_date;
+    var $channel_creator;
+    var $channel_subject;
+    var $image_url;
+    protected $items = array();
+    protected $nritems;
+	const MAX_ENTRIES = 10;
+	public function append ($item) {
+		$this->items[]= $item;
+		$this->nritems++;
+    public function __construct() {
+        $this->nritems=0;
+        $this->channel_url='';
+        $this->channel_title='';
+        $this->channel_description='';
+        $this->channel_lang='';
+        $this->channel_copyright='';
+        $this->channel_date='';
+        $this->channel_creator='';
+        $this->channel_subject='';
+        $this->image_url='';
+    public function setChannel($url, $title, $description, $lang, $copyright, $creator, $subject) {
+        $this->channel_url=$url;
+        $this->channel_title=$title;
+        $this->channel_description=$description;
+        $this->channel_lang=$lang;
+        $this->channel_copyright=$copyright;
+        $this->channel_date=date("Y-m-d").'T'.date("H:i:s").'+01:00';
+        $this->channel_creator=$creator;
+        $this->channel_subject=$subject;
+    public function setImage($url) {
+        $this->image_url=$url;
+    public function setItem($rssItem) {
+    	if (is_a($rssItem, "RssItem")) {
+    		$this->items[]= $rssItem;
+	        $this->nritems++;
+			return true;
+			": setItem(): parameter is not an RSS item!");
+	public function getItem ($index) {
+		if (!is_numeric($index)) {
+			return null;
+		$i = intval($index);
+		if ($i >= 0 && $i < count($this->items)) {
+			return $this->items[$i];
+		return null;
+    public function __toString () {
+        $output =  '<?xml version="1.0" encoding="' . CHARSET . '"?>'."\n";
+        $output .= '<rss ' . $this->getNamespaceString() . ' version="2.0">'."\n";
+//        $output .= '<rdf:RDF ' . $this->getNamespaceString() . '>'."\n";
+//        $output .= '<channel rdf:about="'.htmlentities($this->channel_url, ENT_QUOTES, CHARSET)	.'">'."\n";
+        $output .= '<channel>'."\n";
+        $output .= '<title>'.$this->channel_title.'</title>'."\n";
+        $output .= '<link>'.htmlentities(
+				$this->channel_url,
+				ENT_QUOTES,
+				CHARSET
+			).'</link>'."\n";
+        $output .= '<description>'.$this->channel_description.'</description>'."\n";
+#        $output .= '<dc:language>'.$this->channel_lang.'</dc:language>'."\n";
+#        $output .= '<dc:rights>'.$this->channel_copyright.'</dc:rights>'."\n";
+#        $output .= '<dc:date>'.$this->channel_date.'</dc:date>'."\n";
+#        $output .= '<dc:creator>'.$this->channel_creator.'</dc:creator>'."\n";
+#        $output .= '<dc:subject>'.$this->channel_subject.'</dc:subject>'."\n";
+#        $output .= '<items>'."\n";
+#        $output .= '<rdf:Seq>';
+#        for($k=0; $k<$this->nritems; $k++) {
+#            $output .= '<rdf:li rdf:resource="'.
+#				htmlentities(
+#					$this->items[$k]->getUrl(),
+#					ENT_QUOTES,
+#					CHARSET
+#				.'"/>'."\n";
+#        $output .= '</rdf:Seq>'."\n";
+#        $output .= '</items>'."\n";
+#        $output .= '<image rdf:resource="'.$this->image_url.'"/>'."\n";
+        $output .= '</channel>'."\n";
+        for($k=0; $k<$this->nritems; $k++) {
+            $output .= $this->items[$k];
+//        $output .= '</rdf:RDF>'."\n";
+        $output .= '</rss>'."\n";
+        return $output;
+		return "";
+#		return 'xmlns:rdf="http://www.w3.org/1999/02/22-rdf-syntax-ns#" ' .
+#			'xmlns="http://purl.org/rss/1.0/" ' .
+#			'xmlns:slash="http://purl.org/rss/1.0/modules/slash/" ' .
+#			'xmlns:taxo="http://purl.org/rss/1.0/modules/taxonomy/" ' .
+#			'xmlns:dc="http://purl.org/dc/elements/1.1/" ' .
+#			'xmlns:syn="http://purl.org/rss/1.0/modules/syndication/" ' .
+#			'xmlns:admin="http://webns.net/mvcb/" ' .
+#			'xmlns:feedburner="http://rssnamespace.org/feedburner/ext/1.0"';
Added: trunk/mapbender/http/classes/class_rss_factory.php
--- trunk/mapbender/http/classes/class_rss_factory.php	                        (rev 0)
+++ trunk/mapbender/http/classes/class_rss_factory.php	2009-09-16 15:53:16 UTC (rev 4639)
@@ -0,0 +1,100 @@
+<?php
+# License:
+require_once dirname(__FILE__) . "/../classes/class_rss.php";
+class RssFactory {
+		$rss = $this->parseDocument($url, new Rss());
+			return null;
+	protected function parseDocument ($url, $rss) {
+			return null;
+		$nodeList = $domxpath->query("/rss/channel/title");
+		if ($nodeList->length === 1) {
+			$rss->channel_title = trim($nodeList->item(0)->nodeValue);
+		else {
+			new mb_warning(__FILE__ . ": load(): Could not find title in RSS feed.");
+		$nodeList = $domxpath->query("/rss/channel/description");
+			$rss->channel_description = trim($nodeList->item(0)->nodeValue);
+		else {
+			new mb_warning(__FILE__ . ": load(): Could not find description in RSS feed.");
+		$nodeList = $domxpath->query("/rss/channel/link");
+			$rss->channel_url = trim($nodeList->item(0)->nodeValue);
+		else {
+			new mb_warning(__FILE__ . ": load(): Could not find url in RSS feed.");
+		return $rss;
+	protected function createDomXpathFromUrl ($url) {
+		$dom = new DOMDocument();
+		$dom->preserveWhitespace = false;
+		$success = $dom->load($url);
+		if (!$success) {
+			new mb_exception(__FILE__ . ": load(): Could not load " . $url);
+			return null;
+		return new DOMXPath($dom);
+			return null;
+			$item = new RssItem();
+		return $rss;
+				case "title":
+					$item->setTitle(trim($childNode->nodeValue));
+					break;
+				case "description":
+					$item->setDescription(trim($childNode->nodeValue));
+					break;
+				case "link":
+					$item->setUrl(trim($childNode->nodeValue));
+					break;
+		return $item;
Added: trunk/mapbender/http/classes/class_rss_item.php
--- trunk/mapbender/http/classes/class_rss_item.php	                        (rev 0)
+++ trunk/mapbender/http/classes/class_rss_item.php	2009-09-16 15:53:16 UTC (rev 4639)
@@ -0,0 +1,50 @@
+<?php
+# License:
+class RssItem {
+	protected $title;
+	protected $description;
+	protected $url;
+	public function __construct () {
+	public function setUrl ($url) {
+        $this->url = $url;
+	public function getUrl () {
+        return $this->url;
+	public function setTitle ($title) {
+        $this->title = $title;
+	public function setDescription ($description) {
+        $this->description = $description;
+        return '<item>'."\n" .
+        	$this->getItemString() . '</item>'."\n";
+#        return '<item rdf:about="' . $this->url . '">'."\n" .
+#        	$this->getItemString() . '</item>'."\n";
+        return '<title>' . $this->title . '</title>' . "\n" .
+			'<link>' . htmlentities($this->url, ENT_QUOTES, CHARSET) . '</link>' . "\n" .
+			'<description>' . $this->description . '</description>' . "\n" .
+//			'<feedburner:origLink>' . $this->url . '</feedburner:origLink>' .
+			"\n";
More information about the Mapbender_commits mailing list
