[Mapbender-commits] r4649 - in trunk/mapbender/http: . test
svn_mapbender at osgeo.org
Thu Sep 17 11:23:16 EDT 2009
Author: christoph
Date: 2009-09-17 11:23:16 -0400 (Thu, 17 Sep 2009)
New Revision: 4649
Added:
trunk/mapbender/http/test/
trunk/mapbender/http/test/test_rss_load.php
trunk/mapbender/http/test/test_rss_load.xml
Added: trunk/mapbender/http/test/test_rss_load.php
--- trunk/mapbender/http/test/test_rss_load.php (rev 0)
+++ trunk/mapbender/http/test/test_rss_load.php 2009-09-17 15:23:16 UTC (rev 4649)
@@ -0,0 +1,240 @@
+<?php
+ require_once dirname(__FILE__) . "/../classes/class_universal_rss_factory.php";
+ define("GEORSS", "test_rss_load.xml");
+ define("RANDOM_GEORSS", "../tmp/rss.xml");
+ define("TITLE", "ingrid OpenSearch: wms datatype:metadata ranking:score");
+ define("URL", "http://213.144.28.233:80/opensearch/query?q=wms+datatype:metadata+ranking:score&h=10&p=1&xml=1&georss=1&ingrid=1");
+ define("DESCRIPTION", "Search results");
+ define("BBOX", "12.0016 54.0477 12.2862 54.2481");
+ define("CLASSNAME", "GeoRss");
+ $someRssFactory = new UniversalRssFactory();
+ // create existing GeoRss from URL
+ $success = true;
+ $geoRss = $someRssFactory->createFromUrl(GEORSS);
+ if (intval($_GET["test"]) == 1) {
+ echo "<br><br>";
+ echo "Read GeoRSS at: " . GEORSS . "<br>";
+ if (is_null($geoRss)) {
+ $success = false;
+ echo "FAIL :-(";
+ die;
+ echo "OK :-)";
+ // correct RSS class
+ $success = true;
+ echo "<br><br>";
+ echo "Class should be: " . CLASSNAME . "<br>";
+ echo "Class is: " . get_class($geoRss) . "<br>";
+ if (get_class($geoRss) !== CLASSNAME) {
+ $success = false;
+ echo "FAIL :-(";
+ die;
+ echo "OK :-)";
+ // correct title
+ $success = true;
+ echo "<br><br>";
+ echo "Title should be: " . TITLE . "<br>";
+ echo "Title is: " . $geoRss->channel_title . "<br>";
+ if ($geoRss->channel_title !== TITLE) {
+ $success = false;
+ echo "FAIL :-(";
+ die;
+ echo "OK :-)";
+ // correct description
+ $success = true;
+ echo "<br><br>";
+ echo "Description should be: " . DESCRIPTION . "<br>";
+ echo "Description is: " . $geoRss->channel_description . "<br>";
+ if ($geoRss->channel_description !== DESCRIPTION) {
+ $success = false;
+ echo "FAIL :-(";
+ die;
+ echo "OK :-)";
+ // correct URL
+ $success = true;
+ echo "<br><br>";
+ echo "URL should be: " . URL . "<br>";
+ echo "URL is: " . htmlentities($geoRss->channel_url, ENT_QUOTES, CHARSET) . "<br>";
+ if (htmlentities($geoRss->channel_url, ENT_QUOTES, CHARSET) !== URL) {
+ $success = false;
+ echo "FAIL :-(";
+ die;
+ echo "OK :-)";
+ // correct bbox
+ $success = true;
+ echo "<br><br>";
+ echo "Bounding box of item #3 should be: " . BBOX . "<br>";
+ $box = $geoRss->getItem(2)->getBbox();
+ $boxString =
+ $box->min->x . " " . $box->min->y . " " .
+ $box->max->x . " " . $box->max->y;
+ echo "Bounding box of item #3 is: " . $boxString . "<br>";
+ if ($boxString !== BBOX) {
+ $success = false;
+ echo "FAIL :-(";
+ die;
+ echo "OK :-)";
+ // create RSS at
+ $success = true;
+ echo "<br><br>";
+ $aSecondRssFactory = new RssFactory();
+ $randomRss = str_replace(".xml", "_" . rand() . ".xml", RANDOM_GEORSS);
+ echo "Create random GeoRSS at: " . $randomRss . "<br>";
+ $anotherRss = $aSecondRssFactory->createAt($randomRss);
+ if (is_null($anotherRss)) {
+ $success = false;
+ echo "FAIL :-(";
+ die;
+ echo "OK :-)";
+ // create RSS from URL
+ $success = true;
+ echo "<br><br>";
+ $yetAnotherRss = $someRssFactory->createFromUrl($randomRss);
+ echo "Random RSS should be of type: Rss<br>";
+ echo "Random RSS is of type: " . get_class($yetAnotherRss) . "<br>";
+ if (get_class($yetAnotherRss) !== "Rss") {
+ $success = false;
+ echo "FAIL :-(";
+ die;
+ echo "OK :-)";
+ // create GeoRSS at
+ $success = true;
+ echo "<br><br>";
+ $anotherRssFactory = new GeoRssFactory();
+ $randomGeoRss = str_replace(".xml", "_" . rand() . ".xml", RANDOM_GEORSS);
+ echo "Create random GeoRSS at: " . $randomGeoRss . "<br>";
+ $anotherGeoRss = $anotherRssFactory->createAt($randomGeoRss);
+ if (is_null($anotherGeoRss)) {
+ $success = false;
+ echo "FAIL :-(";
+ die;
+ echo "OK :-)";
+ // create GeoRSS from URL
+ $success = true;
+ echo "<br><br>";
+ $yetAnotherGeoRss = $someRssFactory->createFromUrl($randomGeoRss);
+ echo "Random GeoRSS should be of type: GeoRss<br>";
+ echo "Random GeoRSS is of type: " . get_class($yetAnotherGeoRss) . "<br>";
+ if (get_class($yetAnotherGeoRss) !== "GeoRss") {
+ $success = false;
+ echo "FAIL :-(";
+ die;
+ echo "OK :-)";
+ // append item to GeoRSS
+ $success = true;
+ echo "<br><br>";
+ echo "Save random GeoRSS<br>";
+ $yetAnotherGeoRss->setTitle("testTitel");
+ $yetAnotherGeoRss->setDescription("testDescription");
+ $yetAnotherGeoRss->setUrl("testUrl");
+ $item = $yetAnotherGeoRss->append();
+ $item->setBbox(new Mapbender_bbox(8,49,9,50,"EPSG:4326"));
+ $success = $yetAnotherGeoRss->saveAsFile();
+ if ($success) {
+ echo "OK :-)";
+ else {
+ $success = false;
+ echo "FAIL :-(";
+ die;
+ // reload random GeoRSS
+ $success = true;
+ echo "<br><br>";
+ echo "Reload random GeoRSS<br>";
+ $reloadedRss = $someRssFactory->createFromUrl($randomGeoRss);
+ if (is_null($reloadedRss)) {
+ $success = false;
+ echo "FAIL :-(";
+ die;
+ echo "OK :-)";
+ // correct title
+ $success = true;
+ echo "<br><br>";
+ echo "Title should be: testTitel<br>";
+ echo "Title is: " . $reloadedRss->channel_title . "<br>";
+ if ($reloadedRss->channel_title !== "testTitel") {
+ $success = false;
+ echo "FAIL :-(";
+ die;
+ echo "OK :-)";
+ $success = true;
+ echo "<br><br>";
+ echo "Description should be: testDescription<br>";
+ echo "Description is: " . $reloadedRss->channel_description . "<br>";
+ if ($reloadedRss->channel_description !== "testDescription") {
+ $success = false;
+ echo "FAIL :-(";
+ die;
+ echo "OK :-)";
+ // correct URL
+ $success = true;
+ echo "<br><br>";
+ echo "URL should be: testUrl<br>";
+ echo "URL is: " . htmlentities($reloadedRss->channel_url, ENT_QUOTES, CHARSET) . "<br>";
+ if (htmlentities($reloadedRss->channel_url, ENT_QUOTES, CHARSET) !== "testUrl") {
+ $success = false;
+ echo "FAIL :-(";
+ die;
+ echo "OK :-)";
+ // correct bbox
+ $success = true;
+ echo "<br><br>";
+ echo "Bounding box of item #3 should be: 8 49 9 50<br>";
+ $box = $reloadedRss->getItem(0)->getBbox();
+ $boxString =
+ if ($boxString !== "8 49 9 50") {
+ $success = false;
+ echo "FAIL :-(";
+ die;
+ echo "OK :-)";
+ else {
+ header("Content-type:application/xml");
+ echo $geoRss;
\ No newline at end of file
Added: trunk/mapbender/http/test/test_rss_load.xml
--- trunk/mapbender/http/test/test_rss_load.xml (rev 0)
+++ trunk/mapbender/http/test/test_rss_load.xml 2009-09-17 15:23:16 UTC (rev 4649)
@@ -0,0 +1,410 @@
+<?xml version="1.0" encoding="UTF-8"?>
+<rss xmlns:opensearch="http://a9.com/-/spec/opensearch/1.1/" xmlns:relevance="http://a9.com/-/opensearch/extensions/relevance/1.0/" xmlns:ingrid="http://www.portalu.de/opensearch/extension/1.0" xmlns:georss="http://www.georss.org/georss" version="2.0">
+ <channel>
+ <title>
+ ingrid OpenSearch: wms datatype:metadata ranking:score
+ </title>
+ <link>
+ http://213.144.28.233:80/opensearch/query?q=wms+datatype:metadata+ranking:score&h=10&p=1&xml=1&georss=1&ingrid=1
+ </link>
+ <description>
+ Search results
+ </description>
+ <opensearch:totalResults>
+ 1328
+ </opensearch:totalResults>
+ <opensearch:startIndex>
+ 1
+ </opensearch:startIndex>
+ <opensearch:itemsPerPage>
+ 10
+ </opensearch:itemsPerPage>
+ <opensearch:Query role="request" searchTerms="wms datatype:metadata ranking:score"/>
+ <item>
+ <title>
+ WMS Landschaftsinformationssammlung LINFOS NRW
+ </title>
+ <link>
+ http://213.144.28.233:80/opensearch/detail?plugid=/kug-group:kug-iplug-udk-db_nw&docid=811&docuuid=1E370B70-B07A-438C-AD6E-7834B20081D3
+ </link>
+ <description>
+ Der Web Map Service (WMS) Landschaftinformationssammlung (LINFOS) ist die Schnittstelle zum Abrufen von Kartenauszügen aus dem naturschutzrelevanten Datenbestand des Landesamtes für Natur, Umwelt und Verbraucherschutz für das Land Nordrhein-Westfalen.
+ Die LINFOS-Daten sind in folgende Kataster gegliedert:
+ - Naturräume
+ - schutzwürdige Biotope
+ - Fundortkataster
+ - Schutzgebiete
+ - Biotopverbundflächen
+ - Geowissenschaftlich schutzwürdige Objekte
+ - u.a.
+ Die Kataster beschreiben für jedes naturschutzfachliche Objekt den Raumbezug (wo), die fachliche Beschreibung (was), die Herkunft der Information (wer) und die Aktualitätsinformationen (wann). Objekte verschiedener Kataster nehmen in komplexer Weise aufeinander Bezug (ein Naturschutzgebiet ist ein schutzwürdiger Biotop in dem Fundorte von Rote Liste Arten liegen u.s.w.).
+ </description>
+ <relevance:score>
+ 1.0
+ </relevance:score>
+ <ingrid:plugid>
+ /kug-group:kug-iplug-udk-db_nw
+ </ingrid:plugid>
+ <ingrid:docid>
+ 811
+ </ingrid:docid>
+ <ingrid:docuuid>
+ 1E370B70-B07A-438C-AD6E-7834B20081D3
+ </ingrid:docuuid>
+ <ingrid:provider>
+ nw_munlv
+ </ingrid:provider>
+ <ingrid:partner>
+ nw
+ </ingrid:partner>
+ <ingrid:source>
+ Umweltdatenkatalog Nordrhein-Westfalen
+ </ingrid:source>
+ <ingrid:udk-class>
+ 3
+ </ingrid:udk-class>
+ <ingrid:wms-url>
+ http://www.gis2.nrw.de/wmsconnector/wms/linfos?REQUEST=GetCapabilities&amp;VERSION=1.1.0&amp;SERVICE=WMS
+ </ingrid:wms-url>
+ <georss:box>
+ 5.8665 50.3239 9.4615 52.5314
+ </georss:box>
+ </item>
+ <item>
+ <title>
+ WMS ROK komplett
+ </title>
+ <link>
+ http://www.geoportal.rlp.de/mapbender/x_geoportal/mod_layerMetadata.php?id=27418
+ </link>
+ <description>
+ Struktur- und Genehmigungsdirektion Nord - Raumordnungskataster - WMS-Gruppe alle angebotenen Informationen
+ </description>
+ <relevance:score>
+ 1.0
+ <ingrid:plugid>
+ /kug-group:iplug-rp-gdi-ows
+ </ingrid:plugid>
+ <ingrid:docid>
+ 1060
+ </ingrid:docid>
+ <ingrid:docuuid>
+ 27418
+ </ingrid:docuuid>
+ <ingrid:provider>
+ rp_kgstgdi
+ <ingrid:partner>
+ rp
+ </ingrid:partner>
+ <ingrid:source>
+ WMS Register GDI Rheinland-Pfalz
+ </ingrid:source>
+ <ingrid:wms-url>
+ http://www.geoportal.rlp.de/mapbender/x_geoportal/wms.php?layer_id=27418&amp;REQUEST=GetCapabilities&amp;VERSION=1.1.1&amp;SERVICE=WMS
+ </ingrid:wms-url>
+ </item>
+ <item>
+ <title>
+ WMS-Dienst ALK
+ </title>
+ <link>
+ http://213.144.28.233:80/opensearch/detail?plugid=/kug-group:kug-iplug-udk-db_mvlocal&docid=28&docuuid=D012B07C-F390-4103-A68E-ED33560E39F4
+ </link>
+ <description>
+ WMS-Dienst auf ALK-Daten
+ </description>
+ <relevance:score>
+ 1.0
+ <ingrid:plugid>
+ /kug-group:kug-iplug-udk-db_mvlocal
+ </ingrid:plugid>
+ <ingrid:docid>
+ 28
+ </ingrid:docid>
+ <ingrid:docuuid>
+ D012B07C-F390-4103-A68E-ED33560E39F4
+ </ingrid:docuuid>
+ <ingrid:provider>
+ mv_lung
+ <ingrid:partner>
+ mv
+ </ingrid:partner>
+ <ingrid:source>
+ Umweltdatenkatalog Mecklenburg-Vorpommern
+ </ingrid:source>
+ 3
+ <georss:box>
+ 12.0016 54.0477 12.2862 54.2481
+ </georss:box>
+ </item>
+ <item>
+ <title>
+ OSM WMS
+ </title>
+ <link>
+ http://213.144.28.233:80/opensearch/detail?plugid=/kug-group:iplug-rp-gdi-md-light&docid=39&docuuid=http://www.geoportal.rlp.de/mapbender/x_geoportal/md/inspire_light?md_id=99
+ </link>
+ <description>
+ OSM WMS UBA
+ </description>
+ <relevance:score>
+ 1.0
+ <ingrid:plugid>
+ /kug-group:iplug-rp-gdi-md-light
+ </ingrid:plugid>
+ <ingrid:docid>
+ 39
+ </ingrid:docid>
+ <ingrid:docuuid>
+ http://www.geoportal.rlp.de/mapbender/x_geoportal/md/inspire_light?md_id=99
+ </ingrid:docuuid>
+ <ingrid:provider>
+ rp_geoportal
+ <ingrid:partner>
+ rp
+ </ingrid:partner>
+ <ingrid:source>
+ Geo Metadaten light GDI Rheinland-Pfalz
+ </ingrid:source>
+ <ingrid:wms-url>
+ http://osm.prtr.bund.de/cgi-bin/mapserv?map=/data/umn/osm/osm_s_10k_opt_agg.map&amp;VERSION=1.1.1&amp;REQUEST=GetCapabilities&amp;SERVICE=WMS
+ </ingrid:wms-url>
+ </item>
+ <item>
+ <title>
+ wms-Dienst Schutzgebiete nach Naturschutzrecht Rheinland-Pfalz
+ </title>
+ <link>
+ http://213.144.28.233:80/opensearch/detail?plugid=/kug-group:iplug-rp-udk-db&docid=269&docuuid=3CC65A88-A31C-43CE-8FBE-E30BAAB7C1E7
+ </link>
+ <description>
+ Abgebildet werden alle Geodaten der Schutzgebiete nach Naturschutzrecht in Rheinland-Pfalz. Dazu gehören Naturschutzgebiete, Landschaftsschutzgebiete, Naturparke, Biosphärenreservate, Fauna-Flora-Habitat-Gebiete und Vogelschutzgebiete.
+ </description>
+ <relevance:score>
+ 1.0
+ <ingrid:plugid>
+ /kug-group:iplug-rp-udk-db
+ </ingrid:plugid>
+ <ingrid:docid>
+ 269
+ </ingrid:docid>
+ <ingrid:docuuid>
+ 3CC65A88-A31C-43CE-8FBE-E30BAAB7C1E7
+ </ingrid:docuuid>
+ <ingrid:provider>
+ rp_mufv
+ <ingrid:partner>
+ rp
+ </ingrid:partner>
+ <ingrid:source>
+ Umweltdatenkatalog Rheinland-Pfalz
+ </ingrid:source>
+ 3
+ <ingrid:wms-url>
+ http://map.naturschutz.rlp.de:80/wmsconnector/com.esri.wms.Esrimap/lanis_schutz
+ </ingrid:wms-url>
+ </item>
+ <item>
+ <title>
+ MUFV WMS Server
+ </title>
+ <link>
+ http://www.geoportal.rlp.de/mapbender/x_geoportal/mod_layerMetadata.php?id=27708
+ </link>
+ <description>
+ </description>
+ <relevance:score>
+ 0.9991625
+ <ingrid:plugid>
+ </ingrid:plugid>
+ <ingrid:docid>
+ 1199
+ </ingrid:docid>
+ <ingrid:docuuid>
+ 27708
+ </ingrid:docuuid>
+ <ingrid:provider>
+ rp_kgstgdi
+ <ingrid:partner>
+ rp
+ </ingrid:partner>
+ <ingrid:source>
+ </ingrid:source>
+ <ingrid:wms-url>
+ http://www.geoportal.rlp.de/mapbender/x_geoportal/wms.php?layer_id=27708&amp;REQUEST=GetCapabilities&amp;VERSION=1.1.1&amp;SERVICE=WMS
+ </ingrid:wms-url>
+ </item>
+ <item>
+ <title>
+ PEGELONLINE WMS Aktuell
+ </title>
+ <link>
+ http://www.geoportal.rlp.de/mapbender/x_geoportal/mod_layerMetadata.php?id=26393
+ </link>
+ <description>
+ PEGELONLINE WMS Aktuell stellt kostenfrei tagesaktuelle Messwerte verschiedener gewässerkundlicher Parameter (z.B. Wasserstände) der Binnen- und Küstenpegel der Wasserstraßen des Bundes zur Ansicht. PEGELONLINE WMS Aktuell wird von der Wasser- und Schifffahrtsverwaltung des Bundes betrieben. Alle Zeitangaben liegen in mitteleuropäischer Zeit (MEZ) vor.
+ </description>
+ <relevance:score>
+ 0.9984253
+ <ingrid:plugid>
+ </ingrid:plugid>
+ <ingrid:docid>
+ 943
+ </ingrid:docid>
+ <ingrid:docuuid>
+ 26393
+ </ingrid:docuuid>
+ <ingrid:provider>
+ rp_kgstgdi
+ <ingrid:partner>
+ rp
+ </ingrid:partner>
+ <ingrid:source>
+ </ingrid:source>
+ <ingrid:wms-url>
+ http://www.geoportal.rlp.de/mapbender/x_geoportal/wms.php?layer_id=26393&amp;REQUEST=GetCapabilities&amp;VERSION=1.1.1&amp;SERVICE=WMS
+ </ingrid:wms-url>
+ </item>
+ <item>
+ <title>
+ WMS-Dienst Gemarkungen
+ </title>
+ <link>
+ http://213.144.28.233:80/opensearch/detail?plugid=/kug-group:kug-iplug-udk-db_mvlocal&docid=30&docuuid=495A9EAA-E079-45C7-9159-B3F64DA83B37
+ </link>
+ <description>
+ WMS-Dienst der Gemarkungen der Hansestadt Rostock im Datenportal GeoPort.
+ </description>
+ <relevance:score>
+ 0.99787986
+ <ingrid:plugid>
+ </ingrid:plugid>
+ <ingrid:docid>
+ 30
+ </ingrid:docid>
+ <ingrid:docuuid>
+ 495A9EAA-E079-45C7-9159-B3F64DA83B37
+ </ingrid:docuuid>
+ <ingrid:provider>
+ mv_lung
+ <ingrid:partner>
+ mv
+ </ingrid:partner>
+ <ingrid:source>
+ </ingrid:source>
+ 3
+ <georss:box>
+ </georss:box>
+ </item>
+ <item>
+ <title>
+ wms Naturschutzgebiete M-V
+ </title>
+ <link>
+ http://213.144.28.233:80/opensearch/detail?plugid=/kug-group:kug-iplug-udk-db_mvlocal&docid=995&docuuid=8F114BB0-C368-44A6-9EBA-C9AF0347C6E3
+ </link>
+ <description>
+ Naturschutzgebiete in Mecklenburg-Vorpommern (Stand 06/2006)
+ 22.02.2008: Beschreibung geändert
+ 25.02.2008: Reihenfolge der Operationen: GetCapabilities, GetMap, GetLegendGraphic, GetFeatureInfo
+ 26.02.2008: Kontrolle
+ 28.02.2008: Kontrolle
+ 12.03.2008: Kontrolle, nsg-Thema Namensänderung
+ 30.03.2008: Kontrolle
+ </description>
+ <relevance:score>
+ 0.99787986
+ <ingrid:plugid>
+ </ingrid:plugid>
+ <ingrid:docid>
+ 995
+ </ingrid:docid>
+ <ingrid:docuuid>
+ 8F114BB0-C368-44A6-9EBA-C9AF0347C6E3
+ </ingrid:docuuid>
+ <ingrid:provider>
+ mv_lung
+ <ingrid:partner>
+ mv
+ </ingrid:partner>
+ <ingrid:source>
+ </ingrid:source>
+ 3
+ <ingrid:wms-url>
+ http://www.umweltkarten.mv-regierung.de/script/lungwms.php?REQUEST=GetCapabilities&amp;version=1.1.1&amp;SERVICE=WMS
+ </ingrid:wms-url>
+ <georss:box>
+ 10.5937 53.11 14.4122 54.6848
+ </georss:box>
+ </item>
+ <item>
+ <title>
+ WMS Layer Geoportal.rlp
+ </title>
+ <link>
+ http://www.geoportal.rlp.de/mapbender/x_geoportal/mod_layerMetadata.php?id=24639
+ </link>
+ <description>
+ Geoportal Rheinland Pfalz, Umgebungsrechtecke der einzelnen, im Portal registrierten Layer.
+ </description>
+ <relevance:score>
+ 0.9976459
+ <ingrid:plugid>
+ </ingrid:plugid>
+ <ingrid:docid>
+ 529
+ </ingrid:docid>
+ <ingrid:docuuid>
+ 24639
+ </ingrid:docuuid>
+ <ingrid:provider>
+ rp_kgstgdi
+ <ingrid:partner>
+ rp
+ </ingrid:partner>
+ <ingrid:source>
+ </ingrid:source>
+ <ingrid:wms-url>
+ http://www.geoportal.rlp.de/mapbender/x_geoportal/wms.php?layer_id=24639&amp;REQUEST=GetCapabilities&amp;VERSION=1.1.1&amp;SERVICE=WMS
+ </ingrid:wms-url>
+ </item>
+ </channel>
+</rss>
More information about the Mapbender_commits
