[Mapbender-commits] r4667 - branches/print_dev/resources/db/update
svn_mapbender at osgeo.org
Mon Sep 21 05:40:49 EDT 2009
Author: mschulz
Date: 2009-09-21 05:40:47 -0400 (Mon, 21 Sep 2009)
New Revision: 4667
branches/print_dev/resources/db/update/update_gui2_print.sql
added printbox.js module entry
Modified: branches/print_dev/resources/db/update/update_gui2_print.sql
--- branches/print_dev/resources/db/update/update_gui2_print.sql 2009-09-20 19:13:39 UTC (rev 4666)
+++ branches/print_dev/resources/db/update/update_gui2_print.sql 2009-09-21 09:40:47 UTC (rev 4667)
@@ -21,6 +21,6 @@
</form>
<div id="printPDF_result">
</div>
-</div>','div','../print/mod_printPDF_div.js','','mapframe1','','http://www.mapbender.org/index.php/Print');
+</div>','div','../print/mod_printPDF_div.js','../print/printbox.js','mapframe1','','http://www.mapbender.org/index.php/Print');
INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui2', 'printPDF', 'mbPrintConfigFilenames', '["testConfigTemplate.json"]', '' ,'var');
INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui2', 'printPDF', 'mbPrintConfigTitles', '["Standard"]', '' ,'var');
More information about the Mapbender_commits
