[Mapbender-commits] r4684 - trunk/mapbender/resources/db/update
svn_mapbender at osgeo.org
Thu Sep 24 05:50:35 EDT 2009
Author: vera
Date: 2009-09-24 05:50:34 -0400 (Thu, 24 Sep 2009)
New Revision: 4684
trunk/mapbender/resources/db/update/update_2.7.sql
greek updates for table translations
Modified: trunk/mapbender/resources/db/update/update_2.7.sql
--- trunk/mapbender/resources/db/update/update_2.7.sql 2009-09-24 09:06:38 UTC (rev 4683)
+++ trunk/mapbender/resources/db/update/update_2.7.sql 2009-09-24 09:50:34 UTC (rev 4684)
@@ -299,4 +299,11 @@
INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui', 'featureInfo1', 'considerScalehints', '0', '' ,'var');
INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui1', 'featureInfo1', 'considerScalehints', '0', '' ,'var');
INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui2', 'featureInfo1', 'considerScalehints', '0', '' ,'var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui_digitize', 'featureInfo1', 'considerScalehints', '0', '' ,'var');
\ No newline at end of file
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui_digitize', 'featureInfo1', 'considerScalehints', '0', '' ,'var');
+-- greek updates for translations table
+update translations set msgstr = 'Περίγραμμα/Κορνίζα πλοήγησης' where msgid = 'Navigation Frame' and locale = 'gr'
+update translations set msgstr = 'Φόρτωση κειμένου διαδυκτιακού χάρτη' where msgid = 'Load a web map context document' and locale = 'gr'
+update translations set msgstr = 'Αποθήκευση χώρου εργασίας με μορφή κείμενου διαδυκτιακού χάρτη' where msgid = 'Save workspace as web map context document' and locale = 'gr'
More information about the Mapbender_commits
