[Mapbender-commits] r4689 - trunk/mapbender/lib
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Fri Sep 25 06:31:22 EDT 2009
Author: christoph
Date: 2009-09-25 06:31:22 -0400 (Fri, 25 Sep 2009)
New Revision: 4689
   trunk/mapbender/lib/ajax.php
   trunk/mapbender/lib/button.js
   trunk/mapbender/lib/core.js
   trunk/mapbender/lib/point.js
Modified: trunk/mapbender/lib/ajax.php
--- trunk/mapbender/lib/ajax.php	2009-09-25 10:29:41 UTC (rev 4688)
+++ trunk/mapbender/lib/ajax.php	2009-09-25 10:31:22 UTC (rev 4689)
@@ -56,7 +56,7 @@
 			$this->method = $requestArray["method"];
 			if ($requestArray["params"]) {
-				$obj = $this->json->decode(stripslashes($requestArray["params"]));
+				$obj = $this->json->decode($requestArray["params"]);
 				$this->paramObject = $obj;
Modified: trunk/mapbender/lib/button.js
--- trunk/mapbender/lib/button.js	2009-09-25 10:29:41 UTC (rev 4688)
+++ trunk/mapbender/lib/button.js	2009-09-25 10:31:22 UTC (rev 4689)
@@ -191,11 +191,11 @@
 	req.send();
-eventLocalize.register(function () {
+Mapbender.events.localize.register(function () {
 	mb_localizeButtons();
-eventInit.register(function () {
+Mapbender.events.init.register(function () {
Modified: trunk/mapbender/lib/core.js
--- trunk/mapbender/lib/core.js	2009-09-25 10:29:41 UTC (rev 4688)
+++ trunk/mapbender/lib/core.js	2009-09-25 10:31:22 UTC (rev 4689)
@@ -15,7 +15,7 @@
  * Triggered after a map is requested.
-var eventAfterMapRequest = new MapbenderEvent();
+var eventAfterMapRequest = Mapbender.events.afterMapRequest = new MapbenderEvent();
  * Triggered after aall map images have been loaded.
Modified: trunk/mapbender/lib/point.js
--- trunk/mapbender/lib/point.js	2009-09-25 10:29:41 UTC (rev 4688)
+++ trunk/mapbender/lib/point.js	2009-09-25 10:31:22 UTC (rev 4689)
@@ -12,7 +12,7 @@
  * @param {Float} x x value of the {@link Point}
  * @param {Float} y y value of the {@link Point}
- function Point(x, y, z){
+ Mapbender.Point = Point = function (x, y, z){
  	 * x value of the {@link Point}
More information about the Mapbender_commits mailing list
