[Mapbender-commits] r4693 - trunk/mapbender/http/javascripts
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Fri Sep 25 06:47:39 EDT 2009
Author: christoph
Date: 2009-09-25 06:47:39 -0400 (Fri, 25 Sep 2009)
New Revision: 4693
   trunk/mapbender/http/javascripts/geometry.js
   trunk/mapbender/http/javascripts/map_obj.js
   trunk/mapbender/http/javascripts/mod_changeEPSG.js
   trunk/mapbender/http/javascripts/mod_setBBOX1.php
Modified: trunk/mapbender/http/javascripts/geometry.js
--- trunk/mapbender/http/javascripts/geometry.js	2009-09-25 10:45:42 UTC (rev 4692)
+++ trunk/mapbender/http/javascripts/geometry.js	2009-09-25 10:47:39 UTC (rev 4693)
@@ -115,7 +115,17 @@
  * @param {GeometryArray} geom GeometryArray
 GeometryArray.prototype.union = function(geom){
-	return this.importGeoJSON(geom.toString());
+	var oldLen = this.count();
+	this.importGeoJSON(geom.toString());
+	var j = 0;
+	for (var i = oldLen; i < this.count(); i++) {
+		if (typeof geom.get(j).wfs_conf !== "undefined") {
+			this.get(i).wfs_conf = geom.get(j).wfs_conf;
+		j++;
+	return this;
@@ -360,6 +370,19 @@
 	this.close();
+GeometryArray.prototype.importMultiPoint = function(currentGeometry, featureEpsg){
+	var coordinates = currentGeometry.coordinates;
+	this.addMember(geomType.point);
+	for (var m = 0; m < coordinates.length; m++) {
+		this.get(-1).addGeometry();
+		var currentPoint = coordinates[m];
+		this.getGeometry(-1,-1).addPointByCoordinates(currentPoint[0], currentPoint[1], currentPoint[2]);
+		this.getGeometry(-1,-1).setEpsg(featureEpsg);
+	this.close();
 GeometryArray.prototype.importPolygon = function(currentGeometry, featureEpsg){
@@ -429,6 +452,10 @@
 				this.importPoint(currentGeometry, featureEpsg);
 				break;
+			case "MultiPoint":
+				this.importMultiPoint(currentGeometry, featureEpsg);
+				break;
 			case "LineString":
 				this.importLine(currentGeometry, featureEpsg);
 				break;
Modified: trunk/mapbender/http/javascripts/map_obj.js
--- trunk/mapbender/http/javascripts/map_obj.js	2009-09-25 10:45:42 UTC (rev 4692)
+++ trunk/mapbender/http/javascripts/map_obj.js	2009-09-25 10:47:39 UTC (rev 4693)
@@ -237,45 +237,47 @@
 			new Mb_exception("Mapbender.Map.setSrs: Extent is not a Mapbender.Extent: " + options.extent);
 			return null;
-		// check which WMS support the new SRS
-		undoIgnoreWms();
-		for (var i = 0; i < this.wms.length; i++) {
-			var found = false;
-			for (var j = 0; j < this.wms[i].gui_epsg.length; j++) {
-				if (options.srs === this.wms[i].gui_epsg[j] && this.wms[i].gui_epsg_supported[j]) {
-					found = true;
-					break;
+		if (this.epsg !== options.srs) {
+			// check which WMS support the new SRS
+			undoIgnoreWms();
+			for (var i = 0; i < this.wms.length; i++) {
+				var found = false;
+				for (var j = 0; j < this.wms[i].gui_epsg.length; j++) {
+					if (options.srs === this.wms[i].gui_epsg[j] && this.wms[i].gui_epsg_supported[j]) {
+						found = true;
+						break;
+				if (!found) {
+					ignoreWms(this.wms[i]);
-			if (!found) {
-				ignoreWms(this.wms[i]);
+			var ignoredWms = getIgnoredWms();
+			// ...and optionally display a message
+			if (options.displayWarning && ignoredWms.length > 0) {
+				var msg = "The following WMS do not support the current SRS: <br><br>";
+				for (var key in ignoredWms) {
+					msg += "<b>" + ignoredWms[key].title + "</b><br>";
+				try {
+					Mapbender.modules.dialogManager.openDialog({
+						content: msg,
+						modal: false,
+						effectShow: 'puff'
+				catch (e) {
+					new Mb_warning(e.message + ". " + msg);
+			// actually set the new values and return extent
+			this.epsg = options.srs;
-		var ignoredWms = getIgnoredWms();
-		// ...and optionally display a message
-		if (options.displayWarning && ignoredWms.length > 0) {
-			var msg = "The following WMS do not support the current SRS: <br><br>";
-			for (var key in ignoredWms) {
-				msg += "<b>" + ignoredWms[key].title + "</b><br>";
-			try {
-				Mapbender.modules.dialogManager.openDialog({
-					content: msg,
-					modal: false,
-					effectShow: 'puff'
-			catch (e) {
-				new Mb_warning(e.message + ". " + msg);
-		// actually set the new values and return extent
-		this.epsg = options.srs;
 		return this.calculateExtent(options.extent);
@@ -507,6 +509,11 @@
 		var distx = extent.maxx - extent.minx;
 		var disty = extent.maxy - extent.miny;
+		if (typeof x === "object" && x.constructor === Mapbender.Point) {
+			y = x.y;
+			x = x.x;
 		if (x && y) {
 			var centerx = parseFloat(x);
 			var centery = parseFloat(y);
Modified: trunk/mapbender/http/javascripts/mod_changeEPSG.js
--- trunk/mapbender/http/javascripts/mod_changeEPSG.js	2009-09-25 10:45:42 UTC (rev 4692)
+++ trunk/mapbender/http/javascripts/mod_changeEPSG.js	2009-09-25 10:47:39 UTC (rev 4693)
@@ -81,38 +81,70 @@
 			new Mb_exception("setSrs: must specify an SRS.");
 			return;
+		var recalculateExtentOnly;
+		if (typeof options === "object" && typeof options.recalculateExtentOnly === "object") {
+			recalculateExtentOnly = options.recalculateExtentOnly;
+			if (typeof recalculateExtentOnly.target !== "string") {
+				new Mb_exception("setSrs: must specify a target if recalculateExtentOnly is set.");
+				return;
+			if (typeof recalculateExtentOnly.extent !== "object") {
+				new Mb_exception("setSrs: must specify an extent if recalculateExtentOnly is set.");
+				return;
 		var srsArray = [];
-		// calculate extents for all maps...
-		for (var i = 0; i < mb_mapObj.length; i++) {
+		if (recalculateExtentOnly) {
+			recalculateExtentOnly.map = Mapbender.modules[recalculateExtentOnly.target];
+			if (typeof recalculateExtentOnly.map !== "object" || recalculateExtentOnly.map === null) {
+				new Mb_exception("setSrs: invalid target set for recalculateExtentOnly.");
+				return;
 			var currentSrs = {
-				"frameName" : mb_mapObj[i].elementName,
-				"epsg" : mb_mapObj[i].epsg,
-				"extent" : mb_mapObj[i].extent.toString(),
-				"width" : mb_mapObj[i].width,
-				"height" : mb_mapObj[i].height
+				"frameName": recalculateExtentOnly.map.elementName,
+				"epsg": srsValue,
+				"extent": recalculateExtentOnly.extent.toString(),
+				"width": recalculateExtentOnly.map.width,
+				"height": recalculateExtentOnly.map.height
 			srsArray.push(currentSrs);
-		// ... and all WMS.
+		// calculate extents for all maps...
-		for (var i = 0; i < wms.length; i++) {
-			var ext = wms[i].getBoundingBoxBySrs(mb_mapObj[0].epsg);
-			if (ext === null) {
-				continue;
+		else {
+			for (var i = 0; i < mb_mapObj.length; i++) {
+				var currentSrs = {
+					"frameName": mb_mapObj[i].elementName,
+					"epsg": mb_mapObj[i].epsg,
+					"extent": mb_mapObj[i].extent.toString(),
+					"width": mb_mapObj[i].width,
+					"height": mb_mapObj[i].height
+				srsArray.push(currentSrs);
-			var currentSrs = {
-				"wms" : wms[i].wms_id,
-				"epsg" : mb_mapObj[0].epsg,
-				"extent" : ext.toString(),
-				"width" : mb_mapObj[0].width,
-				"height" : mb_mapObj[0].height
-			srsArray.push(currentSrs);
+		// ... and all WMS.
+		if (!recalculateExtentOnly) {
+			for (var i = 0; i < wms.length; i++) {
+				var ext = wms[i].getBoundingBoxBySrs(mb_mapObj[0].epsg);
+				if (ext === null) {
+					continue;
+					"wms" : wms[i].wms_id,
+					"epsg" : mb_mapObj[0].epsg,
+					"extent" : ext.toString(),
+					"width" : mb_mapObj[0].width,
+					"height" : mb_mapObj[0].height
 		// perform transformation
@@ -122,7 +154,7 @@
 			method: "changeEpsg",
 			parameters: {
 				srs: srsArray,
-				newSrs: srsValue
+				newSrs: recalculateExtentOnly ? recalculateExtentOnly.map.epsg : srsValue
 			callback: function (obj, success, message) {
 				if (!success) {
@@ -133,7 +165,7 @@
 				var newExtent = obj;
 				for (var i = 0; i < newExtent.length; i++) {
-					if (newExtent[i].wms) {
+					if (newExtent[i].wms && !recalculateExtentOnly) {
 						for (var j = 0; j < wms.length; j++) {
 							if (parseInt(wms[j].wms_id, 10) === parseInt(newExtent[i].wms, 10)) {
 								wms[j].setBoundingBoxBySrs(
@@ -154,7 +186,7 @@
 					// use the previous extent of the overview
-					if(newExtent[i].frameName == options.target){
+					if(!recalculateExtentOnly && newExtent[i].frameName == options.target){
 						var map = Mapbender.modules[options.target];
Modified: trunk/mapbender/http/javascripts/mod_setBBOX1.php
--- trunk/mapbender/http/javascripts/mod_setBBOX1.php	2009-09-25 10:45:42 UTC (rev 4692)
+++ trunk/mapbender/http/javascripts/mod_setBBOX1.php	2009-09-25 10:47:39 UTC (rev 4693)
@@ -24,23 +24,51 @@
 	var targetArray = targetString.split(",");
 	var bboxString = "<?php echo Mapbender::session()->get("mb_myBBOX") ?>";
 	var srs = "<?php echo Mapbender::session()->get("mb_myBBOXEpsg") ?>";
+	var performTransformation =
+		("<?php
+			echo Mapbender::session()->get("mb_myBBOXEpsg_transform")
+		?>" === "1") ? true : false;
 	// the user wants to set an SRS that is different from the
 	// application's SRS!
+	// OR
+	// the user wants to set a bounding box specified in
+	// another SRS to be displayed in the current SRS
 	if (typeof Mapbender.modules[targetArray[0]] === "object"
 		&& srs !== "" && srs !== Mapbender.modules[targetArray[0]].epsg) {
 		if (typeof Mapbender.modules.changeEPSG !== "object") {
 			new Mb_exception("setBBOX requires changeEPSG!");
 			return;
-		Mapbender.modules.changeEPSG.setSrs({
-			srs: srs,
-			callback: function () {
-				setBbox(targetArray, bboxString);
+		if (performTransformation || bboxString === "") {
+			Mapbender.modules.changeEPSG.setSrs({
+				srs: srs,
+				callback: function () {
+					setBbox(targetArray, bboxString);
+		else {
+			var bboxArray = bboxString.split(",");
+				srs: srs,
+				recalculateExtentOnly : {
+					target : targetArray[0],
+					extent : new Mapbender.Extent(
+						bboxArray[0],
+						bboxArray[1],
+						bboxArray[2],
+						bboxArray[3]
 	// the user doesn't want to change the SRS.
More information about the Mapbender_commits mailing list
