[Mapbender-commits] r4712 - trunk/mapbender/resources/db
svn_mapbender at osgeo.org
Sat Sep 26 10:28:22 EDT 2009
Author: christoph
Date: 2009-09-26 10:28:22 -0400 (Sat, 26 Sep 2009)
New Revision: 4712
trunk/mapbender/resources/db/install.sh
added update to 2.7rc1
Modified: trunk/mapbender/resources/db/install.sh
--- trunk/mapbender/resources/db/install.sh 2009-09-26 14:26:54 UTC (rev 4711)
+++ trunk/mapbender/resources/db/install.sh 2009-09-26 14:28:22 UTC (rev 4712)
@@ -45,7 +45,7 @@
echo "database character encoding? (i)so-8859-1 or (u)tf-8?"
read DBENCODING
done
#ask for database template
if [ "$DBVERSION" = "p" ]
then
@@ -65,16 +65,16 @@
#nicer vars
then
- DBVERSION="pgsql"
+ DBVERSION="pgsql"
else
- DBVERSION="mysql"
+ DBVERSION="mysql"
fi
if [ "$DBENCODING" = "i" ]
then
- DBENCODING="ISO-8859-1"
+ DBENCODING="ISO-8859-1"
else
- DBENCODING="UTF-8"
+ DBENCODING="UTF-8"
fi
echo ""
@@ -84,8 +84,8 @@
echo ""
echo "database port (e.g. 5432 for postgres, 3306 for mysql)?"
read DBPORT
echo ""
echo "database user?"
read DBUSER
@@ -148,7 +148,7 @@
echo "update to 2.6"
mysql $DBNAME -p$DBPASSWORD -u $DBUSER -h $DBHOST -P $DBPORT < mysql/$DBENCODING/update/update_2.6rc1_to_2.6_mysql_$DBENCODING.sql >> log_update.txt 2>> err_update.txt
#Create Database (Postgres)
@@ -166,7 +166,7 @@
createdb -U $DBUSER -h $DBHOST -p $DBPORT -E $DBENCODING $DBNAME -T $DBTEMPLATE
echo "creating schema"
psql -U $DBUSER -h $DBHOST -p $DBPORT -f pgsql/pgsql_schema_2.5.sql $DBNAME > log_schema.txt 2> err_schema.txt
- echo "loading data"
+ echo "loading data"
psql -U $DBUSER -h $DBHOST -p $DBPORT -f pgsql/$DBENCODING/pgsql_data_2.5.sql $DBNAME > log_data.txt 2> err_data.txt
echo "setting sequences"
psql -U $DBUSER -h $DBHOST -p $DBPORT -f pgsql/pgsql_serial_set_sequences_2.5.sql $DBNAME > log_sequences.txt 2> err_squences.txt
@@ -178,8 +178,9 @@
psql -U $DBUSER -h $DBHOST -p $DBPORT -f pgsql/$DBENCODING/update/update_2.5.1_to_2.6rc1_pgsql_$DBENCODING.sql $DBNAME >> log_update.txt 2>> err_update.txt
psql -U $DBUSER -h $DBHOST -p $DBPORT -f pgsql/$DBENCODING/update/update_2.6rc1_to_2.6_pgsql_$DBENCODING.sql $DBNAME >> log_update.txt 2>> err_update.txt
+ echo "update to 2.7"
+ psql -U $DBUSER -h $DBHOST -p $DBPORT -f pgsql/$DBENCODING/update/update_2.6_to_2.7rc1_pgsql_$DBENCODING.sql $DBNAME >> log_update.txt 2>> err_update.txt
function set_permissions(){
@@ -217,7 +218,7 @@
fi
echo ""
echo "please check and edit the entries in your mapbender.conf manually!"
fi
More information about the Mapbender_commits
