[Mapbender-commits] r4723 - trunk/mapbender/http/javascripts
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Sat Sep 26 11:34:52 EDT 2009
Author: christoph
Date: 2009-09-26 11:34:51 -0400 (Sat, 26 Sep 2009)
New Revision: 4723
Added:
   trunk/mapbender/http/javascripts/mod_pan.js
Removed:
   trunk/mapbender/http/javascripts/mod_pan.php
Added: trunk/mapbender/http/javascripts/mod_pan.js
--- trunk/mapbender/http/javascripts/mod_pan.js	                        (rev 0)
+++ trunk/mapbender/http/javascripts/mod_pan.js	2009-09-26 15:34:51 UTC (rev 4723)
@@ -0,0 +1,106 @@
+ * Package: selArea
+ * Description:
+ * Zoom by rectangle
+ * Files:
+ *  - http/javascripts/mod_selArea.js
+ * SQL:
+ * > <SQL for element>
+ * > <SQL for element var>
+ * Help:
+ * http://www.mapbender.org/SelArea1
+ * Maintainer:
+ * http://www.mapbender.org/User:Christoph_Baudson
+ * License:
+ * Copyright (c) 2009, Open Source Geospatial Foundation
+ * This program is dual licensed under the GNU General Public License
+ * and Simplified BSD license.
+ * http://svn.osgeo.org/mapbender/trunk/mapbender/license/license.txt
+var that = this;
+Mapbender.events.init.register(function () {
+	var mb_panActive = false;
+	var startPos, stopPos;
+	var map = Mapbender.modules[options.target];
+	var button = new Mapbender.Button({
+		domElement: that,
+		over: options.src.replace(/_off/, "_over"),
+		on: options.src.replace(/_off/, "_on"),
+		off: options.src,
+		name: options.id,
+		go: function () {
+			if (!map) {
+				new Mb_exception(options.id + ": " +
+					options.target + " is not a map!");
+				return;
+			$(map.getDomElement()).css("cursor", "move")
+				.mousedown(function (e) {
+				mb_panActive = true;
+				startPos = map.getMousePosition(e);
+				stopPos = new Point(startPos);
+				return false;
+			}).mousemove(function (e) {
+				if (!mb_panActive) {
+					return false;
+				stopPos = map.getMousePosition(e);
+				var dif = stopPos.minus(startPos);
+				mb_arrangeElement(map.frameName, options.target+"_maps", dif.x, dif.y);
+				for(var i = 0; i < mb_PanSubElements.length; i++) {
+					mb_arrangeElement(map.frameName, mb_PanSubElements[i], dif.x, dif.y);
+				if (!$.browser.msie){
+					return true;
+				return false;
+			}).mouseup(function (e) {
+					return false;
+				if (!map) {
+					return false;
+				mb_panActive = false;
+				var widthHeight = new Mapbender.Point(
+					map.getWidth(),
+					map.getHeight()
+				var center = widthHeight.times(0.5).minus(dif);
+				var realCenter = map.convertPixelToReal(center);
+				mb_arrangeElement(map.frameName, options.target + "_maps", 0, 0);
+				for (var i = 0; i < mb_PanSubElements.length; i++) {
+					mb_arrangeElement(map.frameName, mb_PanSubElements[i], 0, 0);
+				map.zoom(false, 1.0, realCenter);
+				return false;
+		stop: function () {
+			if (!map) {
+				return false;
+				.css("cursor", "pointer")
+				.unbind("mousedown")
+				.unbind("mouseup")
+				.unbind("mousemove");
Deleted: trunk/mapbender/http/javascripts/mod_pan.php
--- trunk/mapbender/http/javascripts/mod_pan.php	2009-09-26 15:33:14 UTC (rev 4722)
+++ trunk/mapbender/http/javascripts/mod_pan.php	2009-09-26 15:34:51 UTC (rev 4723)
@@ -1,116 +0,0 @@
-<?php
-# $Id$
-# http://www.mapbender.org/index.php/mod_pan.php
-# Copyright (C) 2002 CCGIS
-# This program is free software; you can redistribute it and/or modify
-# it under the terms of the GNU General Public License as published by
-# the Free Software Foundation; either version 2, or (at your option)
-# any later version.
-# This program is distributed in the hope that it will be useful,
-# but WITHOUT ANY WARRANTY; without even the implied warranty of
-# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
-# GNU General Public License for more details.
-# You should have received a copy of the GNU General Public License
-# along with this program; if not, write to the Free Software
-# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
-require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
-echo "var mod_pan_target = '".$e_target[0]."';";
-var mod_pan_elName = "<?php echo $e_id; ?>";
-var mod_pan_frameName = "";
-var mod_pan_MapObj = null;
-var mod_pan_img_on = new Image(); mod_pan_img_on.src = "<?php  echo preg_replace("/_off/","_on",$e_src);  ?>";
-var mod_pan_img_off = new Image(); mod_pan_img_off.src = "<?php  echo $e_src;  ?>";
-var mod_pan_img_over = new Image(); mod_pan_img_over.src = "<?php  echo preg_replace("/_off/","_over",$e_src);  ?>";
-var mb_panActive = false;
-eventInit.register(function () {
-	mb_regButton(function (ind){
-		mod_pan_MapObj = getMapObjByName(mod_pan_target);
-		mb_button[ind] = document.getElementById(mod_pan_elName);
-		mb_button[ind].img_over = mod_pan_img_over.src;
-		mb_button[ind].img_on = mod_pan_img_on.src;
-		mb_button[ind].img_off = mod_pan_img_off.src;
-		mb_button[ind].status = 0;
-		mb_button[ind].elName = mod_pan_elName;
-		mb_button[ind].fName = mod_pan_frameName;
-		mb_button[ind].go = function () {
-			var p = mod_pan_MapObj.getDomElement();
-			p.style.cursor = "move";
-			p.onmousedown = mod_pan_start;
-			p.onmouseup = mod_pan_stop;
-			p.onmousemove = mod_pan_run;
-		mb_button[ind].stop = function () {
-			p.style.cursor = "pointer";
-			p.onmousedown = null;
-			p.onmouseup = null;
-			p.onmousemove = null;
-function mod_pan_start(e){
-	mb_panActive = true;
-	var pos = mod_pan_MapObj.getMousePosition(e);
-	var el = mod_pan_MapObj.getDomElement();
-	mb_start_x=pos.x;
-	mb_start_y=pos.y;
-	mb_end_x = pos.x;
-	mb_end_y = pos.y;
-	return false;
-function mod_pan_run(e){
-	if(mb_panActive){
-		mb_end_x = pos.x;
-		mb_end_y = pos.y;
-		mod_pan_move_map();
-		if(ie){
-			return false;
-		else{
-			return true;
-function mod_pan_stop(e){
-	if(mb_panActive){
-		mb_panActive = false;
-		var dif_x = mb_end_x - mb_start_x;
-		var dif_y = mb_end_y - mb_start_y;
-		var width = mod_pan_MapObj.width;
-		var height = mod_pan_MapObj.height;
-		var center_x = (width / 2)  - dif_x;
-		var center_y = (height / 2) - dif_y;
-		var real_center = makeClickPos2RealWorldPos(mod_pan_target,center_x, center_y);
-		mb_arrangeElement(mod_pan_MapObj.frameName, mod_pan_target+"_maps", 0, 0);
-		for(var i=0; i<mb_PanSubElements.length; i++){
-			mb_arrangeElement(mod_pan_MapObj.frameName, mb_PanSubElements[i], 0, 0);
-	   zoom(mod_pan_target,false, 1.0, real_center[0], real_center[1]);
-function mod_pan_move_map(){
-	mb_arrangeElement(mod_pan_MapObj.frameName, mod_pan_target+"_maps", dif_x, dif_y);
-		mb_arrangeElement(mod_pan_MapObj.frameName, mb_PanSubElements[i], dif_x, dif_y);
-	return false;
More information about the Mapbender_commits mailing list
