[Mapbender-commits] r4726 - in trunk/mapbender/resources/locale:
bg_BG/LC_MESSAGES de_DE/LC_MESSAGES el_GR/LC_MESSAGES
es_ES/LC_MESSAGES fr_FR/LC_MESSAGES hu_HU/LC_MESSAGES
it_IT/LC_MESSAGES pt_PT/LC_MESSAGES
svn_mapbender at osgeo.org
Sat Sep 26 12:01:22 EDT 2009
Author: astrid_emde
Date: 2009-09-26 12:01:21 -0400 (Sat, 26 Sep 2009)
New Revision: 4726
trunk/mapbender/resources/locale/bg_BG/LC_MESSAGES/Mapbender.po
trunk/mapbender/resources/locale/de_DE/LC_MESSAGES/Mapbender.po
trunk/mapbender/resources/locale/el_GR/LC_MESSAGES/Mapbender.po
trunk/mapbender/resources/locale/es_ES/LC_MESSAGES/Mapbender.po
trunk/mapbender/resources/locale/fr_FR/LC_MESSAGES/Mapbender.po
trunk/mapbender/resources/locale/hu_HU/LC_MESSAGES/Mapbender.po
trunk/mapbender/resources/locale/it_IT/LC_MESSAGES/Mapbender.po
trunk/mapbender/resources/locale/pt_PT/LC_MESSAGES/Mapbender.po
new po entries for mod_wfs_gazetteer_client
Modified: trunk/mapbender/resources/locale/bg_BG/LC_MESSAGES/Mapbender.po
--- trunk/mapbender/resources/locale/bg_BG/LC_MESSAGES/Mapbender.po 2009-09-26 15:53:14 UTC (rev 4725)
+++ trunk/mapbender/resources/locale/bg_BG/LC_MESSAGES/Mapbender.po 2009-09-26 16:01:21 UTC (rev 4726)
@@ -8,7 +8,7 @@
msgstr ""
"Project-Id-Version: PACKAGE VERSION\n"
"Report-Msgid-Bugs-To: \n"
-"POT-Creation-Date: 2009-04-14 17:45+0200\n"
+"POT-Creation-Date: 2009-09-26 17:37+0200\n"
"PO-Revision-Date: YEAR-MO-DA HO:MI+ZONE\n"
"Last-Translator: FULL NAME <EMAIL at ADDRESS>\n"
"Language-Team: LANGUAGE <LL at li.org>\n"
@@ -471,3 +471,27 @@
#: ../http/html/mod_treefolderPlain.php:499
msgid "Are you sure you want to remove"
msgstr ""
+#: ../http/javascripts/mod_wfs_gazetteer_client.php:411
+msgid "show metadata"
+msgstr ""
+#: ../http/javascripts/mod_wfs_gazetteer_client.php:420
+msgid "remove WFS Conf"
+msgstr ""
+#: ../http/javascripts/mod_wfs_gazetteer_client.php:455
+msgid "Point"
+msgstr ""
+#: ../http/javascripts/mod_wfs_gazetteer_client.php:459
+msgid "Line"
+msgstr ""
+#: ../http/javascripts/mod_wfs_gazetteer_client.php:463
+msgid "Polygon"
+msgstr ""
+#: ../http/javascripts/mod_wfs_gazetteer_client.php:621
+msgid "Different EPSG of map and wfs featuretype, no spatial request possible!"
+msgstr ""
Modified: trunk/mapbender/resources/locale/de_DE/LC_MESSAGES/Mapbender.po
--- trunk/mapbender/resources/locale/de_DE/LC_MESSAGES/Mapbender.po 2009-09-26 15:53:14 UTC (rev 4725)
+++ trunk/mapbender/resources/locale/de_DE/LC_MESSAGES/Mapbender.po 2009-09-26 16:01:21 UTC (rev 4726)
@@ -8,7 +8,7 @@
msgstr ""
@@ -483,7 +483,8 @@
#: ../http/html/mod_treefolderPlain.php:452
msgid "You have to select the WMS you want to move down!"
-msgstr "Sie müssen den Dienst, den Sie nach unten schieben wollen, selektieren."
+msgstr ""
+"Sie müssen den Dienst, den Sie nach unten schieben wollen, selektieren."
#: ../http/html/mod_treefolderPlain.php:484
msgid "You have to select the WMS you want to delete!"
@@ -491,7 +492,9 @@
#: ../http/html/mod_treefolderPlain.php:488
msgid "It is not possible to delete a single layer, please select a WMS!"
-msgstr "Es ist nicht möglich einen einzelnen Layer zu entfernen. Bitte selektieren Sie einen WMS!"
+msgstr ""
+"Es ist nicht möglich einen einzelnen Layer zu entfernen. Bitte selektieren "
+"Sie einen WMS!"
#: ../http/html/mod_treefolderPlain.php:496
msgid "Last WMS can not be removed."
@@ -513,3 +516,26 @@
msgid "Get area"
msgstr "Fläche berechnen"
+msgstr "Metadaten anzeigen"
+msgstr "WFS Konfiguration entfernen"
+msgid "Point"
+msgstr "Punkt"
+msgid "Line"
+msgstr "Linie"
+msgid "Polygon"
+msgstr "Polygon"
+msgstr "Unterschiedliche EPSG von Karte und WFS FeatureType. Es ist keine räumliche möglich."
Modified: trunk/mapbender/resources/locale/el_GR/LC_MESSAGES/Mapbender.po
--- trunk/mapbender/resources/locale/el_GR/LC_MESSAGES/Mapbender.po 2009-09-26 15:53:14 UTC (rev 4725)
+++ trunk/mapbender/resources/locale/el_GR/LC_MESSAGES/Mapbender.po 2009-09-26 16:01:21 UTC (rev 4726)
@@ -8,7 +8,7 @@
msgstr ""
@@ -51,9 +51,10 @@
#: printPDF.conf:73
msgid ""
"This copy has been generated automatically and is valid without signature."
-msgstr "Αύτο το αντίγραφο δημιουργήθηκε αυτόματα και θεωρείται γνήσιο αν και χωρίς υπογραφή "
-"Αυτό το αντίγραφο δημιουργήθηκε αθτόματα και ως εκ τούτου δεν είναι έγκυρο "
-"χωρίς υπογραφή"
+msgstr ""
+"Αύτο το αντίγραφο δημιουργήθηκε αυτόματα και θεωρείται γνήσιο αν και χωρίς "
+"υπογραφή Αυτό το αντίγραφο δημιουργήθηκε αθτόματα και ως εκ τούτου δεν είναι "
+"έγκυρο χωρίς υπογραφή"
#: printPDF.conf:74
msgid ""
@@ -75,7 +76,8 @@
#: printPDF.conf:
msgid "This copy is protected by law (Par. 3 Abs. 1 VermKatG NW)."
-msgstr "Αυτό το αντίγραφο προστατεύεται από τον Νόμο (Παρ. 3 Abs. 1 VermKatG NW)."
+msgstr ""
+"Αυτό το αντίγραφο προστατεύεται από τον Νόμο (Παρ. 3 Abs. 1 VermKatG NW)."
#: printPDF.conf:
msgid ""
@@ -374,13 +376,17 @@
#: http/javascripts/mod_addWMSfromfilteredList_ajax.php:343
msgid "Enter a Capabilities-URL of a WMS or select one or more WMS from list."
-msgstr "Εισάγετε το URL με τισ δυνατότητες του WMS ή επιλέξτε ένα ή περισσότερα WMS από την λίστα "
+msgstr ""
+"Εισάγετε το URL με τισ δυνατότητες του WMS ή επιλέξτε ένα ή περισσότερα WMS "
+"από την λίστα "
#: http/javascripts/mod_addWMSfromfilteredList_ajax.php:344
msgid ""
"Notice: Be aware of the scale hints. Possibly you need to zoom in to display "
"the added service."
-msgstr "Σημείωση: Δώστε προσοχή στην κλίμακα προβολής. Πιθανόν να χρειαστεί zoom in για να γίνει η προβολή "
+msgstr ""
+"Σημείωση: Δώστε προσοχή στην κλίμακα προβολής. Πιθανόν να χρειαστεί zoom in "
+"για να γίνει η προβολή "
#: http/javascripts/mod_addWMSfromfilteredList_ajax.php:350
msgid "Capabilities-URL"
@@ -475,3 +481,27 @@
#: http/javascripts/mod_measure.php:329
msgid "Get area"
msgstr "Επιλογή της περιοχής"
+msgstr ""
+msgstr ""
+msgid "Point"
+msgstr ""
+msgid "Line"
+msgstr ""
+msgid "Polygon"
+msgstr ""
+msgstr ""
Modified: trunk/mapbender/resources/locale/es_ES/LC_MESSAGES/Mapbender.po
--- trunk/mapbender/resources/locale/es_ES/LC_MESSAGES/Mapbender.po 2009-09-26 15:53:14 UTC (rev 4725)
+++ trunk/mapbender/resources/locale/es_ES/LC_MESSAGES/Mapbender.po 2009-09-26 16:01:21 UTC (rev 4726)
@@ -8,7 +8,7 @@
msgstr ""
@@ -491,3 +491,27 @@
msgstr ""
+msgstr ""
+msgstr ""
+msgid "Point"
+msgstr ""
+msgid "Line"
+msgstr ""
+msgid "Polygon"
+msgstr ""
+msgstr ""
Modified: trunk/mapbender/resources/locale/fr_FR/LC_MESSAGES/Mapbender.po
--- trunk/mapbender/resources/locale/fr_FR/LC_MESSAGES/Mapbender.po 2009-09-26 15:53:14 UTC (rev 4725)
+++ trunk/mapbender/resources/locale/fr_FR/LC_MESSAGES/Mapbender.po 2009-09-26 16:01:21 UTC (rev 4726)
@@ -8,7 +8,7 @@
msgstr ""
@@ -492,3 +492,27 @@
msgstr ""
+msgstr ""
+msgstr ""
+msgid "Point"
+msgstr ""
+msgid "Line"
+msgstr ""
+msgid "Polygon"
+msgstr ""
+msgstr ""
Modified: trunk/mapbender/resources/locale/hu_HU/LC_MESSAGES/Mapbender.po
--- trunk/mapbender/resources/locale/hu_HU/LC_MESSAGES/Mapbender.po 2009-09-26 15:53:14 UTC (rev 4725)
+++ trunk/mapbender/resources/locale/hu_HU/LC_MESSAGES/Mapbender.po 2009-09-26 16:01:21 UTC (rev 4726)
@@ -8,7 +8,7 @@
msgstr ""
@@ -511,3 +511,27 @@
msgstr ""
+msgstr ""
+msgstr ""
+msgid "Point"
+msgstr ""
+msgid "Line"
+msgstr ""
+msgid "Polygon"
+msgstr ""
+msgstr ""
Modified: trunk/mapbender/resources/locale/it_IT/LC_MESSAGES/Mapbender.po
--- trunk/mapbender/resources/locale/it_IT/LC_MESSAGES/Mapbender.po 2009-09-26 15:53:14 UTC (rev 4725)
+++ trunk/mapbender/resources/locale/it_IT/LC_MESSAGES/Mapbender.po 2009-09-26 16:01:21 UTC (rev 4726)
@@ -8,7 +8,7 @@
msgstr ""
@@ -489,3 +489,27 @@
msgstr ""
+msgstr ""
+msgstr ""
+msgid "Point"
+msgstr ""
+msgid "Line"
+msgstr ""
+msgid "Polygon"
+msgstr ""
+msgstr ""
Modified: trunk/mapbender/resources/locale/pt_PT/LC_MESSAGES/Mapbender.po
--- trunk/mapbender/resources/locale/pt_PT/LC_MESSAGES/Mapbender.po 2009-09-26 15:53:14 UTC (rev 4725)
+++ trunk/mapbender/resources/locale/pt_PT/LC_MESSAGES/Mapbender.po 2009-09-26 16:01:21 UTC (rev 4726)
@@ -8,7 +8,7 @@
msgstr ""
@@ -449,3 +449,27 @@
msgstr ""
+msgstr ""
+msgstr ""
+msgid "Point"
+msgstr ""
+msgid "Line"
+msgstr ""
+msgid "Polygon"
+msgstr ""
+msgstr ""
More information about the Mapbender_commits
