[Mapbender-commits] r4739 - trunk/mapbender/test/http/classes
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Sat Sep 26 14:39:16 EDT 2009
Author: kmq
Date: 2009-09-26 14:39:15 -0400 (Sat, 26 Sep 2009)
New Revision: 4739
Added:
   trunk/mapbender/test/http/classes/UserTest.php
   trunk/mapbender/test/http/classes/GroupTest.php
tests for the classes group and user
Modified: trunk/mapbender/test/http/classes/GroupTest.php
--- trunk/mapbender/test/http/classes/GroupTest.php	2009-09-26 18:37:47 UTC (rev 4738)
+++ trunk/mapbender/test/http/classes/GroupTest.php	2009-09-26 18:39:15 UTC (rev 4739)
@@ -6,14 +6,16 @@
     var $someGroup_name = "demo";
     var $someGroup_description = "Demo Group zum Test";
 	public function testCreate()
       $group = new Group(null);
-      $group->name = $someGroup_name;
-      $group->description = $someGroup_description;
+      $group->name = $this->someGroup_name;
+      $group->description = $this->someGroup_description;
-      $create_message="Group creation failed";
+      $this->assertNotNull($group);
       try{
         $create_result = $group->create();
@@ -21,11 +23,13 @@
         $this->assertEquals($E->getMessage(), 'Could not insert new group');
-      $this->assertTrue($create_result,$create_message);
-      $change_result = $group->change(array());
+      $this->assertNotNull($create_result);
+      $change_result = $group->change(null);
       $this->assertTrue($change_result);
       try{
         $commit_result =  $group->commit();
@@ -36,19 +40,22 @@
       $this->assertTrue($commit_result);
-    public function testRemove()
+    * @depends testCreate
+    public function testDelete()
-      $group = Group::byName($someGroup_name);
+      $group = Group::byName($this->someGroup_name);
-      $group->remove();
+      $remove_result = $group->remove();
+      $this->assertTrue($remove_result);
       $group = null;
       $this->assertNull($group);
\ No newline at end of file
Added: trunk/mapbender/test/http/classes/UserTest.php
--- trunk/mapbender/test/http/classes/UserTest.php	                        (rev 0)
+++ trunk/mapbender/test/http/classes/UserTest.php	2009-09-26 18:39:15 UTC (rev 4739)
@@ -0,0 +1,61 @@
+<?php
+require_once 'PHPUnit/Framework.php';
+require_once '../../../http/classes/class_user.php';
+class UserTest extends PHPUnit_Framework_TestCase
+    var $someUser_name = "demo";
+    var $someUser_description = "Demo User zum Testen";
+    public function testCreate()
+      $user = new User(null);
+      $user->name = $this->someUser_name;
+      $user->description = $this->someUser_description;
+      $user->public = 1;
+      $this->assertNotNull($user);
+      try{
+        $create_result = $user->create();
+      catch(Exception $E)
+        $this->assertEquals($E->getMessage(), 'Could not set initial values of new User');
+      $change_result = $user->change(null);
+      $this->assertTrue($change_result);
+      try{
+        $commit_result =  $user->commit();
+        $this->assertEquals($E->getMessage(), 'Database error updating User');
+      $this->assertTrue($commit_result);
+      $user = User::byName($this->someUser_name);
+      $remove_result = $user->remove();
+      $user = null;
+      $this->assertNull($user);
More information about the Mapbender_commits mailing list
