[Mapbender-commits] r4746 - trunk/mapbender/http/extensions
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Sun Sep 27 04:00:45 EDT 2009
Author: kmq
Date: 2009-09-27 04:00:45 -0400 (Sun, 27 Sep 2009)
New Revision: 4746
Added:
   trunk/mapbender/http/extensions/jquery.listeditor.js
added jquery listeditor
Added: trunk/mapbender/http/extensions/jquery.listeditor.js
--- trunk/mapbender/http/extensions/jquery.listeditor.js	                        (rev 0)
+++ trunk/mapbender/http/extensions/jquery.listeditor.js	2009-09-27 08:00:45 UTC (rev 4746)
@@ -0,0 +1,69 @@
+// @param url the RPC endpoint to get the list for the selectbox from
+jQuery.fn.listeditor = function(url,options) {
+  var me = this;
+  me.url = url || null;
+  me.options = options || {};
+  me.options.editor = options.editor || [];
+  return me.each(function(){
+    return new ListEditor($(this),url,options);
+var ListEditor = function(element,url,options) {
+  var me = this;
+  //check if this is already a listeditor and if so, exit
+  if(element.next().is('table.listeditor')){ return this; };
+  this.table = $('<table class="listeditor"></table>');
+  this.select = $('<select class="listeditor"></select>');
+  this.element = this.table;
+  var addButton = $("<a>Add</a>").click(function(event){
+    me.addEntry($(this).prev().val());
+    event.preventDefault()
+  element.after(addButton).after(this.select).after(this.table);
+  populateSelect(url,this.select);
+ListEditor.prototype.addEntry = function(text){
+  var rows = $("tr",this.element);
+  for(var i = 0;i<rows.length;i++)
+     if($("td:first",rows[i]).text() == $(this.select).val())
+       // list already contains this entry
+       return;
+   this.element.append("<tr><td>"+ text +"</td></tr>");
+ListEditor.prototype.val = function(text){
+  var list = [];
+  //TODO: this should be a singe selector
+  $("td:first",rows).each(function(){list.push(($(this).text()))}) ;
+  return list;
+var populateSelect = function(url,select) {
+  var me = this;
+  options = { url: url,
+              method: 'list',
+              callback: (function (result,success, message){
+                for( entry in result.list)
+                  var selectOption = $('<option value="'+ result.list[entry].name +'">'+ result.list[entry].name +'</option>');
+                  select.append(selectOption);
+  var req = Mapbender.Ajax.Request(options);
+  req.send();
More information about the Mapbender_commits mailing list
