[Mapbender-commits] r4761 - in branches/print_dev/http: classes css
extensions javascripts php
svn_mapbender at osgeo.org
Mon Sep 28 10:33:01 EDT 2009
Author: mschulz
Date: 2009-09-28 10:33:00 -0400 (Mon, 28 Sep 2009)
New Revision: 4761
Added:
branches/print_dev/http/classes/class_RPCEndpoint.php
branches/print_dev/http/classes/class_georss.php
branches/print_dev/http/classes/class_georss_factory.php
branches/print_dev/http/classes/class_georss_item.php
branches/print_dev/http/classes/class_gml_multipoint.php
branches/print_dev/http/classes/class_group.php
branches/print_dev/http/classes/class_rss.php
branches/print_dev/http/classes/class_rss_factory.php
branches/print_dev/http/classes/class_rss_item.php
branches/print_dev/http/css/customTree.css
branches/print_dev/http/css/mod_AdminTabs.css
branches/print_dev/http/extensions/jquery-ui-1.7.2.custom.min.js
branches/print_dev/http/javascripts/ConfEditor.js
branches/print_dev/http/javascripts/ConfObject.js
branches/print_dev/http/javascripts/group.php
branches/print_dev/http/javascripts/gui.php
branches/print_dev/http/javascripts/mod_AdminTabs.js
branches/print_dev/http/javascripts/mod_addWMSfromTree.js
branches/print_dev/http/javascripts/mod_admin.js
branches/print_dev/http/javascripts/mod_admin.php
branches/print_dev/http/javascripts/mod_changeEPSG.js
branches/print_dev/http/javascripts/mod_coordsLookup.js
branches/print_dev/http/javascripts/mod_dialogManager.js
branches/print_dev/http/javascripts/mod_group.js
branches/print_dev/http/javascripts/mod_gui.js
branches/print_dev/http/javascripts/mod_overview.js
branches/print_dev/http/javascripts/mod_overviewToggle.js
branches/print_dev/http/javascripts/mod_selArea.js
branches/print_dev/http/javascripts/mod_user.js
branches/print_dev/http/javascripts/mod_zoomIn1.js
branches/print_dev/http/javascripts/mod_zoomOut1.js
branches/print_dev/http/javascripts/user.php
branches/print_dev/http/php/mod_abo_show.php
branches/print_dev/http/php/mod_coordsLookup_server.php
branches/print_dev/http/php/mod_monitorCapabilities_read.php
branches/print_dev/http/php/mod_monitorCapabilities_read_single.php
branches/print_dev/http/php/mod_monitorCapabilities_read_single_diff.php
branches/print_dev/http/php/mod_wmc2ol.php
branches/print_dev/http/php/wms.php
merged from trunk
Added: branches/print_dev/http/classes/class_RPCEndpoint.php
--- branches/print_dev/http/classes/class_RPCEndpoint.php (rev 0)
+++ branches/print_dev/http/classes/class_RPCEndpoint.php 2009-09-28 14:33:00 UTC (rev 4761)
@@ -0,0 +1,262 @@
+<?php
+interface RPCObject{
+ public function create();
+ public function change($changes);
+ public function commit();
+ public function remove();
+ public function load();
+ public function getFields();
+ public static function getList($filter);
+ public static function byName($name);
+class RPCEndpoint {
+ var $ObjectConf;
+ var $ajaxResponse;
+ var $method;
+ public function __construct ($ObjectConf,$ajaxResponse){
+ $this->ObjectConf = $ObjectConf;
+ $this->ajaxResponse = $ajaxResponse;
+ $this->method = $this->ajaxResponse->getMethod();
+ // When we upgrade to 5.3.0 this needs to desperately upgraded to
+ // "Added support for dynamic access of static members using $foo::myFunc(). (Etienne Kneuss)"
+ // from http://php.net/ChangeLog-5.php
+ // so we can get rid of this sillyness here
+ public function RPCObjectByName($name){
+ switch($this->ObjectConf['ClassName']){
+ case 'User':
+ return User::byName($name);
+ case 'Group':
+ return Group::byName($name);
+ case 'gui':
+ return gui::byName($name);
+ default:
+ // or throw exception ?
+ return null;
+ public function RPCObjectGetList(){
+ case 'User':
+ return User::getList("");
+ case 'Group':
+ return Group::getList("");
+ case 'gui':
+ return gui::getList("");
+ default:
+ return null;
+ public function run(){
+ switch($this->method)
+ case 'create':
+ try{
+ $this->rpc_create($this->ajaxResponse->getParameter('fields'));
+ }catch(Exception $E){
+ $this->ajaxResponse->setMessage("Create failed. Error: " . $E);
+ break;
+ case 'update':
+ try{
+ $this->rpc_update($this->ajaxResponse->getParameter('name'),$this->ajaxResponse->getParameter('fields'));
+ $this->ajaxResponse->setMessage("Update failed. Error: " . $E);
+ break;
+ case 'remove':
+ try{
+ $this->rpc_remove($this->ajaxResponse->getParameter('name'));
+ $this->ajaxResponse->setMessage("Delete failed. Error: " . $E);
+ break;
+ case 'load':
+ try{
+ $this->rpc_load($this->ajaxResponse->getParameter('name'));
+ $this->ajaxResponse->setMessage("Load failed. Error: " . $E);
+ break;
+ case 'list':
+ try{
+ $this->rpc_list();
+ $this->ajaxResponse->setMessage("List failed. Error: " + $E);
+ break;
+ default:
+ $this->ajaxResponse->setSuccess(false);
+ $this->ajaxResponse->setMessage(_mb("invalid method"));
+ $this->ajaxResponse->send();
+ public function rpc_create($fields){
+ // test if an obect of that name already exists
+ $instance = $this->RPCObjectByName($fields->name);
+ if($instance){
+ $this->ajaxResponse->setMessage(_mb("Already Exists "). $this->ObjectConf['internalName'] . " Error: " . $E);
+ return;
+ // create an empty one
+ $instance = $this->RPCObjectByName(null);
+ $instance->name = $fields->name;
+ try{
+ $instance->create();
+ catch(Exception $E)
+ $this->ajaxResponse->setMessage(_mb("Could not create instance "). $this->ObjectConf['internalName'] . " Error: ". $E );
+ try {
+ $instance->change($fields);
+ catch (Exception $E)
+ $this->ajaxResponse->setMessage(_mb("Could not create "). $this->ObjectConf['internalName'] . " Error: " . $E);
+ try{
+ $instance->commit();
+ $this->ajaxResponse->setMessage(_mb("Could not change "). $this->ObjectConf['internalName'] . " Error: " . $E);
+ public function rpc_update($name,$fields){
+ $instance = $this->RPCObjectByName($name);
+ if($instance == null)
+ $this->ajaxResponse->setMessage($this->ObjectConf['internalName'] . _mb(" does not exist: ". $name));
+ return;
+ try{
+ $this->ajaxResponse->setMessage(_mb("Could not change "). $this->ObjectConf['internalName'] . " Error: " .$E);
+ try{
+ $this->ajaxResponse->setResult('name',$instance->name);
+ public function rpc_remove($name){
+ $this->ajaxResponse->setSuccess(true);
+ $this->ajaxResponse->setMessage(_mb("No such "). $this->ObjectConf['internalName']);
+ break;
+ try{
+ $instance->remove();
+ $this->ajaxResponse->setMessage(_mb("Could not remove "). $this->ObjectConf['internalName'] . " Error: ". $E);
+ public function rpc_load($name){
+ $this->ajaxResponse->setMessage(_mb("No such ". $this->ObjectConf['internalName'] .": $name"));
+ $this->ajaxResponse->setResult("data",array("error"=>true ));
+ return;
+ try{
+ $instance->load();
+ $result = $instance->getFields();
+ $this->ajaxResponse->setMessage(_mb("Could not load data: "). $this->ObjectConf['internalName'] ." Error: " . $E);
+ $this->ajaxResponse->setResult("error",true);
+ $this->ajaxResponse->setResult("data",$result);
+ public function rpc_list(){
+ $result = array();
+ $instances = array();
+ $instances = $this->RPCObjectGetList('');
+ if(!$instances)
+ $this->ajaxResponse->setMessage(_mb("Error fetching list of "). $this->ObjectConf['internalName']);
+ return;
+ foreach( $instances as $instance)
+ $result[] = array("name" => $instance->name, "value" => $instance->name);
+ $this->ajaxResponse->setResult("list",$result);
+ $this->ajaxResponse->setResult("type", array("display" => $this->ObjectConf['DisplayName'],
+ "internal" => $this->ObjectConf['InternalName']));
Added: branches/print_dev/http/classes/class_georss.php
--- branches/print_dev/http/classes/class_georss.php (rev 0)
+++ branches/print_dev/http/classes/class_georss.php 2009-09-28 14:33:00 UTC (rev 4761)
@@ -0,0 +1,26 @@
+<?php
+# License:
+# Copyright (c) 2009, Open Source Geospatial Foundation
+# This program is dual licensed under the GNU General Public License
+# and Simplified BSD license.
+# http://svn.osgeo.org/mapbender/trunk/mapbender/license/license.txt
+require_once(dirname(__FILE__)."/../../core/globalSettings.php");
+require_once(dirname(__FILE__)."/../classes/class_rss.php");
+require_once(dirname(__FILE__)."/../classes/class_georss_item.php");
+ * Creates an RSS Feed.
+class GeoRss extends Rss {
+ protected function createItem () {
+ return new GeoRssItem();
+ protected function getNamespaceString () {
+ return parent::getNamespaceString() .
+ ' xmlns:georss="http://www.georss.org/georss"';
\ No newline at end of file
Added: branches/print_dev/http/classes/class_georss_factory.php
--- branches/print_dev/http/classes/class_georss_factory.php (rev 0)
+++ branches/print_dev/http/classes/class_georss_factory.php 2009-09-28 14:33:00 UTC (rev 4761)
@@ -0,0 +1,51 @@
+<?php
+# License:
+require_once dirname(__FILE__) . "/../../core/globalSettings.php";
+require_once dirname(__FILE__) . "/../classes/class_rss_factory.php";
+require_once dirname(__FILE__) . "/../classes/class_georss.php";
+class GeoRssFactory extends RssFactory {
+ protected function createRss () {
+ $rss = new GeoRss();
+ return $rss;
+ protected function createRssItem () {
+ $rssItem = new GeoRssItem();
+ return $rssItem;
+ protected function parseItem ($node, $item) {
+ $item = parent::parseItem($node, $item);
+ foreach ($node->childNodes as $childNode) {
+ switch ($childNode->tagName) {
+ case "georss:box":
+ $coordinateString = trim($childNode->nodeValue);
+ $coordinateArray = explode(" ", $coordinateString);
+ if (count($coordinateArray) === 4) {
+ $bbox = new Mapbender_bbox(
+ floatval($coordinateArray[0]),
+ floatval($coordinateArray[1]),
+ floatval($coordinateArray[2]),
+ floatval($coordinateArray[3]),
+ "EPSG:4326"
+ $item->setBbox($bbox);
+ break;
+ return $item;
Added: branches/print_dev/http/classes/class_georss_item.php
--- branches/print_dev/http/classes/class_georss_item.php (rev 0)
+++ branches/print_dev/http/classes/class_georss_item.php 2009-09-28 14:33:00 UTC (rev 4761)
@@ -0,0 +1,42 @@
+<?php
+# License:
+require_once dirname(__FILE__) . "/../classes/class_bbox.php";
+class GeoRssItem extends RssItem {
+ private $bbox;
+ public function setBbox ($bbox) {
+ if (is_a($bbox, "Mapbender_bbox")) {
+ $this->bbox = $bbox;
+ return true;
+ new mb_exception(__FILE__ .
+ ": setBbox(): parameter not a Mapbender_bbox!");
+ return false;
+ public function getBbox () {
+ return $this->bbox;
+ protected function getItemString () {
+ $str = parent::getItemString();
+ if (is_a($this->bbox, "Mapbender_bbox")) {
+ $str .= "<georss:box>" .
+ $this->bbox->min->x . " " .
+ $this->bbox->min->y . " " .
+ $this->bbox->max->x . " " .
+ $this->bbox->max->y .
+ "</georss:box>\n";
+ return $str;
Added: branches/print_dev/http/classes/class_gml_multipoint.php
--- branches/print_dev/http/classes/class_gml_multipoint.php (rev 0)
+++ branches/print_dev/http/classes/class_gml_multipoint.php 2009-09-28 14:33:00 UTC (rev 4761)
@@ -0,0 +1,93 @@
+<?php
+# $Id: class_gml2.php 3099 2008-10-02 15:29:23Z nimix $
+# http://www.mapbender.org/index.php/class_gml2.php
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+require_once(dirname(__FILE__)."/../classes/class_json.php");
+require_once(dirname(__FILE__)."/../classes/class_gml_geometry.php");
+class GMLMultiPoint extends GmlGeometry {
+ var $pointArray = array();
+ public function __construct() {
+ public function addPoint ($x, $y) {
+ array_push($this->pointArray, array("x" => $x, "y" => $y));
+ public function toGml2 () {
+ $str = "<gml:MultiPoint srsName='$srsName'>";
+ foreach ($this->pointArray as $point) {
+ $str .= "<gml:pointMember><gml:Point><gml:coordinates>";
+ $str .= $point["x"] . "," . $point["y"];
+ $str .= "</gml:coordinates></gml:Point>";
+ $str .= "<gml:pointMember><gml:MultiPoint>";
+ return $str;
+ public function toGml3 () {
+ $str .= "<gml:pointMember><gml:Point>";
+ $str .= "<gml:pos>" . $point["x"] . " " . $point["y"] . "</gml:pos>";
+ $str .= "</gml:Point><gml:pointMember>";
+ $str .= "<gml:MultiPoint>";
+ return $str;
+ public function isEmpty () {
+ return !(count($this->pointArray) > 0);
+ public function toGeoJSON () {
+ $numberlineArray = count($this->pointArray);
+ $str = "";
+ if ($numberlineArray > 0) {
+ $str .= "{\"type\": \"MultiPoint\", \"coordinates\":[";
+ for ($cnt =0; $cnt < $numberlineArray; $cnt++){
+ if ($cnt > 0) {
+ $str .= ",";
+ if (in_array($this->srs, $this->latLonSrs)) {
+ $str .= "[" . $this->pointArray[$cnt]["y"] . "," .
+ $this->pointArray[$cnt]["x"]."]";
+ else {
+ $str .= "[" . $this->pointArray[$cnt]["x"] . "," .
+ $this->pointArray[$cnt]["y"]."]";
+ $str .= "]}";
+ else {
+ $e = new mb_exception("GMLMultiPoint: toGeoJSON: this multiPoint is null.");
+ return $str;
Added: branches/print_dev/http/classes/class_group.php
--- branches/print_dev/http/classes/class_group.php (rev 0)
+++ branches/print_dev/http/classes/class_group.php 2009-09-28 14:33:00 UTC (rev 4761)
@@ -0,0 +1,236 @@
+<?php
+# $Id: class_kml_geometry.php 1966 2008-01-15 08:25:15Z christoph $
+# http://www.mapbender.org/index.php/class_wmc.php
+require_once(dirname(__FILE__)."/../classes/class_RPCEndpoint.php");
+ * A Mapbender user as described in the table mb_group.
+class Group implements RPCObject {
+ * @var Integer The Group ID
+ var $id;
+ var $name;
+ var $owner = 0;
+ var $description ="";
+ static $displayName = "Group";
+ static $internalName = "group";
+ * Constructor
+ * @param groupId Integer the ID of the group that is represented by
+ * this object. If null, create an empty object
+ public function __construct ($groupId) {
+ if($groupId == null){
+ // new group
+ return;
+ $this->id = $groupId;
+ try{
+ $this->load();
+ new mb_exception($E->getMessage());
+ * @return String the ID of this group
+ public function __toString () {
+ return (string) $this->id;
+ * @return Assoc Array containing the fields to send to the user
+ public function getFields() {
+ $result = array(
+ "name" => $this->name,
+ "owner" => $this->owner,
+ "description" => $this->description
+ return $result;
+ public function create() {
+ if($this->name == ""){ $e = new Exception("Can' t create group without name");}
+ $sql_group_create = "INSERT INTO mb_group (mb_group_name) VALUES ('". $this->name ."');";
+ $v = array($this->name);
+ $t = array("s");
+ db_begin();
+ $insert_result = db_query($sql_group_create);
+ if($insert_result == false)
+ db_rollback();
+ $e = new Exception("Could not insert new group");
+ $id = db_insertid($insert_result,'mb_group','mb_group_id');
+ if($id != 0)
+ $this->id = $id;
+ $commit_result = $this->commit();
+ if($commit_result == false)
+ try {
+ db_rollback();
+ $newE = new Exception("Could not set inital values of new group");
+ throw $newE;
+ db_commit();
+ * @param $changes JSON keys and their values of what to change in the object
+ public function change($changes) {
+ //FIXME: validate input
+ $this->name = $changes->name ? $changes->name : $this->name;
+ $this->owner = $changes->owner ? $changes->owner : $this->owner;
+ $this->description = $changes->description ? $changes->description : $this->description;
+ $this->id = $changes->id ? $changes->id->value : $this->id;
+ return true;
+ public function commit() {
+ $sql_update = "UPDATE mb_group SET ".
+ "mb_group_name = $1, ".
+ "mb_group_owner = $2, ".
+ "mb_group_description = $3 ".
+ "WHERE mb_group_id = $4;";
+ $v = array($this->name,
+ $this->owner,
+ $this->description,
+ $this->id);
+ $t = array("s", "i", "s", "i");
+ $update_result = db_prep_query($sql_update,$v,$t);
+ if(!$update_result)
+ throw new Exception("Database error updating Group");
+ return true;
+ public function remove() {
+ $sql_group_remove = "DELETE FROM mb_group WHERE mb_group_id = $1";
+ $v = array($this->id);
+ $t = array("i");
+ $result = db_prep_query($sql_group_remove,$v,$t);
+ if($result == false)
+ $e = new mb_exception("Database error deleting group");
+ return true;
+ public function load() {
+ $sql_group = "SELECT * from mb_group WHERE mb_group_id = $1; ";
+ $t = array("i");
+ $res_group = db_prep_query($sql_group,$v,$t);
+ if($row = db_fetch_array($res_group)){
+ $this->name = $row['mb_group_name'];
+ $this->owner = $row['mb_group_owner'];
+ $this->description = $row['mb_group_description'];
+ }else{
+ throw new Exception("no such Group");
+ return true;
+ * @return Array of Groups
+ * @param $filter UNUSED! string that must be contained in the username
+ public static function getList($filter) {
+ $groups = Array();
+ $sql_grouplist = "SELECT mb_group_id FROM mb_group";
+ $res_groups = db_query($sql_grouplist);
+ while($row = db_fetch_array($res_groups))
+ try{
+ $groups[] = new Group($row['mb_group_id']);
+ continue;
+ //FIXME: should catch some errors here
+ return $groups;
+ * tries to initialize a Groupobject by Name
+ * @return A group Object
+ * @param $name the name of the group to find
+ public static function byName($name) {
+ if($name == null) { return new Group(null); }
+ $sql_group = "SELECT mb_group_id FROM mb_group WHERE mb_group_name = '$name'";
+ $res_group = db_query($sql_group);
+ return new Group($row['mb_group_id']);
+ return null;
Added: branches/print_dev/http/classes/class_rss.php
--- branches/print_dev/http/classes/class_rss.php (rev 0)
+++ branches/print_dev/http/classes/class_rss.php 2009-09-28 14:33:00 UTC (rev 4761)
@@ -0,0 +1,181 @@
+<?php
+# License:
+require_once dirname(__FILE__) . "/../classes/class_administration.php";
+require_once dirname(__FILE__) . "/../classes/class_rss_item.php";
+class Rss {
+ var $filename;
+ var $channel_url;
+ var $channel_title;
+ var $channel_description;
+ var $channel_lang;
+ var $channel_copyright;
+ var $channel_date;
+ var $channel_creator;
+ var $channel_subject;
+ var $image_url;
+ protected $items = array();
+ protected $nritems;
+ const MAX_ENTRIES = 10;
+ return new RssItem();
+ public function append () {
+ if (func_num_args() === 0) {
+ $item = $this->createItem();
+ else {
+ $item = func_get_arg(0);
+ $this->items[]= $item;
+ $this->nritems++;
+ return $item;
+ public function saveAsFile() {
+ if (func_num_args() === 1) {
+ $pathAndFilename = func_get_arg(0);
+ else {
+ if ($this->filename) {
+ $pathAndFilename = $this->filename;
+ else {
+ ": saveAsFile(): must specify a filename!");
+ return false;
+ return administration::saveFile($pathAndFilename, $this->__toString());
+ $this->nritems=0;
+ $this->channel_url=LOGIN;
+ $this->channel_title="Mapbender GeoRSS";
+ $this->channel_description="New and updated WMS";
+ $this->channel_lang='';
+ $this->channel_copyright='';
+ $this->channel_date='';
+ $this->channel_creator='';
+ $this->channel_subject='';
+ $this->image_url='';
+ public function setTitle ($title) {
+ $this->channel_title=$title;
+ public function setDescription ($description) {
+ $this->channel_description=$description;
+ public function setUrl ($url) {
+ $this->channel_url=$url;
+ public function setChannel($url, $title, $description, $lang, $copyright, $creator, $subject) {
+ $this->channel_lang=$lang;
+ $this->channel_copyright=$copyright;
+ $this->channel_date=date("Y-m-d").'T'.date("H:i:s").'+01:00';
+ $this->channel_creator=$creator;
+ $this->channel_subject=$subject;
+ public function setImage($url) {
+ $this->image_url=$url;
+ public function setItem($rssItem) {
+ if (is_a($rssItem, "RssItem")) {
+ $this->items[]= $rssItem;
+ $this->nritems++;
+ return true;
+ ": setItem(): parameter is not an RSS item!");
+ public function getItem ($index) {
+ if (!is_numeric($index)) {
+ return null;
+ $i = intval($index);
+ if ($i >= 0 && $i < count($this->items)) {
+ return $this->items[$i];
+ return null;
+ $output = '<?xml version="1.0" encoding="' . CHARSET . '"?>'."\n";
+ $output .= '<rss ' . $this->getNamespaceString() . ' version="2.0">'."\n";
+// $output .= '<rdf:RDF ' . $this->getNamespaceString() . '>'."\n";
+// $output .= '<channel rdf:about="'.htmlentities($this->channel_url, ENT_QUOTES, CHARSET) .'">'."\n";
+ $output .= '<channel>'."\n";
+ $output .= '<title>'.$this->channel_title.'</title>'."\n";
+ $output .= '<link>'.htmlentities(
+ $this->channel_url,
+ ENT_QUOTES,
+ CHARSET
+ ).'</link>'."\n";
+ $output .= '<description>'.$this->channel_description.'</description>'."\n";
+# $output .= '<dc:language>'.$this->channel_lang.'</dc:language>'."\n";
+# $output .= '<dc:rights>'.$this->channel_copyright.'</dc:rights>'."\n";
+# $output .= '<dc:date>'.$this->channel_date.'</dc:date>'."\n";
+# $output .= '<dc:creator>'.$this->channel_creator.'</dc:creator>'."\n";
+# $output .= '<dc:subject>'.$this->channel_subject.'</dc:subject>'."\n";
+# $output .= '<items>'."\n";
+# $output .= '<rdf:Seq>';
+# for($k=0; $k<$this->nritems; $k++) {
+# $output .= '<rdf:li rdf:resource="'.
+# htmlentities(
+# $this->items[$k]->getUrl(),
+# ENT_QUOTES,
+# CHARSET
+# .'"/>'."\n";
+# $output .= '</rdf:Seq>'."\n";
+# $output .= '</items>'."\n";
+# $output .= '<image rdf:resource="'.$this->image_url.'"/>'."\n";
+ for($k=0; $k<$this->nritems; $k++) {
+ $output .= $this->items[$k];
+ $output .= '</channel>'."\n";
+// $output .= '</rdf:RDF>'."\n";
+ $output .= '</rss>'."\n";
+ return $output;
+ return "";
+# return 'xmlns:rdf="http://www.w3.org/1999/02/22-rdf-syntax-ns#" ' .
+# 'xmlns="http://purl.org/rss/1.0/" ' .
+# 'xmlns:slash="http://purl.org/rss/1.0/modules/slash/" ' .
+# 'xmlns:taxo="http://purl.org/rss/1.0/modules/taxonomy/" ' .
+# 'xmlns:dc="http://purl.org/dc/elements/1.1/" ' .
+# 'xmlns:syn="http://purl.org/rss/1.0/modules/syndication/" ' .
+# 'xmlns:admin="http://webns.net/mvcb/" ' .
+# 'xmlns:feedburner="http://rssnamespace.org/feedburner/ext/1.0"';
Added: branches/print_dev/http/classes/class_rss_factory.php
--- branches/print_dev/http/classes/class_rss_factory.php (rev 0)
+++ branches/print_dev/http/classes/class_rss_factory.php 2009-09-28 14:33:00 UTC (rev 4761)
@@ -0,0 +1,131 @@
+<?php
+# License:
+require_once dirname(__FILE__) . "/../classes/class_rss.php";
+class RssFactory {
+ $rss = new Rss();
+ return $rss;
+ $rssItem = new RssItem();
+ return $rssItem;
+ public function loadOrCreate ($pathAndFilename) {
+ $rss = $this->createFromUrl($pathAndFilename);
+ if (is_null($rss)) {
+ $rss = $this->createAt($pathAndFilename);
+ return null;
+ return $rss;
+ public function createAt ($pathAndFilename) {
+ $rss = $this->createRss();
+ if ($rss->saveAsFile($pathAndFilename)) {
+ $rss->filename = $pathAndFilename;
+ return $rss;
+ return null;
+ public function createFromUrl ($url) {
+ $rss = $this->parseDocument($url, $this->createRss());
+ return null;
+ $rss->filename = $url;
+ return $this->parseItems($url, $rss);
+ protected function parseDocument ($url, $rss) {
+ $domxpath = $this->createDomXpathFromUrl($url, $rss);
+ if (is_null($domxpath)) {
+ return null;
+ $nodeList = $domxpath->query("/rss/channel/title");
+ if ($nodeList->length === 1) {
+ $rss->channel_title = trim($nodeList->item(0)->nodeValue);
+ else {
+ new mb_warning(__FILE__ . ": load(): Could not find title in RSS feed.");
+ $nodeList = $domxpath->query("/rss/channel/description");
+ $rss->channel_description = trim($nodeList->item(0)->nodeValue);
+ else {
+ new mb_warning(__FILE__ . ": load(): Could not find description in RSS feed.");
+ $nodeList = $domxpath->query("/rss/channel/link");
+ $rss->channel_url = trim($nodeList->item(0)->nodeValue);
+ else {
+ new mb_warning(__FILE__ . ": load(): Could not find url in RSS feed.");
+ return $rss;
+ protected function createDomXpathFromUrl ($url) {
+ $dom = new DOMDocument();
+ $dom->preserveWhitespace = false;
+ $success = $dom->load($url);
+ if (!$success) {
+ new mb_exception(__FILE__ . ": load(): Could not load " . $url);
+ return null;
+ return new DOMXPath($dom);
+ protected function parseItems ($url, $rss) {
+ return null;
+ $nodeList = $domxpath->query("/rss/channel/item");
+ foreach ($nodeList as $node) {
+ $item = $this->createRssItem();
+ $item = $this->parseItem($node, $item);
+ $rss->append($item);
+ return $rss;
+ case "title":
+ $item->setTitle(trim($childNode->nodeValue));
+ break;
+ case "description":
+ $item->setDescription(trim($childNode->nodeValue));
+ break;
+ case "link":
+ $item->setUrl(trim($childNode->nodeValue));
+ break;
+ return $item;
Added: branches/print_dev/http/classes/class_rss_item.php
--- branches/print_dev/http/classes/class_rss_item.php (rev 0)
+++ branches/print_dev/http/classes/class_rss_item.php 2009-09-28 14:33:00 UTC (rev 4761)
@@ -0,0 +1,50 @@
+<?php
+# License:
+class RssItem {
+ protected $title;
+ protected $description;
+ protected $url;
+ public function __construct () {
+ $this->url = $url;
+ public function getUrl () {
+ return $this->url;
+ $this->title = $title;
+ $this->description = $description;
+ return '<item>'."\n" .
+ $this->getItemString() . '</item>'."\n";
+# return '<item rdf:about="' . $this->url . '">'."\n" .
+# $this->getItemString() . '</item>'."\n";
+ return '<title>' . $this->title . '</title>' . "\n" .
+ '<link>' . htmlentities($this->url, ENT_QUOTES, CHARSET) . '</link>' . "\n" .
+ '<description>' . $this->description . '</description>' . "\n";
+// '<feedburner:origLink>' . $this->url . '</feedburner:origLink>' .
+// "\n";
Added: branches/print_dev/http/css/customTree.css
--- branches/print_dev/http/css/customTree.css (rev 0)
+++ branches/print_dev/http/css/customTree.css 2009-09-28 14:33:00 UTC (rev 4761)
@@ -0,0 +1,81 @@
+.custom-tree-treeview, .custom-tree-treeview ul {
+ list-style-image:none;
+ list-style-position:outside;
+ list-style-type:none;
+ margin:0;
+ padding:0;
+.custom-tree-treeview ul {
+ background-color:transparent;
+ margin-top:1px;
+.custom-tree-treeview .custom-tree-hitarea {
+ background:transparent url(../img/treeview-default.gif) no-repeat scroll -64px -25px;
+ cursor:pointer;
+ float:left;
+ height:16px;
+ margin-left:-16px;
+ width:16px;
+* html .custom-tree-hitarea {
+ display:inline;
+ float:none;
+.custom-tree-filetree li {
+ padding:3px 0 2px 16px;
+.custom-tree-treeview a.selected {
+ background-color:#EEEEEE;
+.custom-tree-treeview li {
+ background:transparent url(../img/treeview-default-line.gif) no-repeat scroll 0 0;
+.custom-tree-treeview li.custom-tree-collapsable, .custom-tree-treeview li.custom-tree-expandable {
+ background-position:0 -176px;
+.custom-tree-treeview .custom-tree-expandable-hitarea {
+ background-position:-80px -3px;
+.custom-tree-treeview li.custom-tree-last {
+ background-position:0 -1766px;
+.custom-tree-treeview li.custom-tree-lastCollapsable, .custom-tree-treeview li.custom-tree-lastExpandable {
+ background-image:url(../img/treeview-default.gif);
+.custom-tree-treeview li.custom-tree-lastCollapsable {
+ background-position:0 -111px;
+.custom-tree-treeview li.custom-tree-lastExpandable {
+ background-position:-32px -67px;
+.custom-tree-treeview div.custom-tree-lastCollapsable-hitarea, .custom-tree-treeview div.custom-tree-lastExpandable-hitarea {
+ background-position:0 50%;
+.custom-tree-filetree span.custom-tree-folder, .custom-tree-filetree {
+ display:block;
+.custom-tree-filetree span.custom-tree-folder {
+ background:transparent url(../img//expanded_folder.png) no-repeat scroll 0 0;
+.custom-tree-filetree li.custom-tree-expandable span.custom-tree-folder {
+ background:transparent url(../img/closed_folder.png) no-repeat scroll 0 0;
+span.custom-tree-folder {
+ padding: 3px 0 3px 18px;
+ margin: -3px 0 0 0;
+span.custom-tree-file img {
+ vertical-align: bottom;
+ margin: 0 2px 0 0;
Added: branches/print_dev/http/css/mod_AdminTabs.css
--- branches/print_dev/http/css/mod_AdminTabs.css (rev 0)
+++ branches/print_dev/http/css/mod_AdminTabs.css 2009-09-28 14:33:00 UTC (rev 4761)
@@ -0,0 +1,95 @@
+.mbFrame
+ border: 1px solid black;
+ul
+ list-style-type: none;
+/* left menu */
+.mbList
+ padding-left: 1em;
+ padding-top: 1em;
+ margin-top: 2em;
+ width: 15em;
+ min-height: 20em;
+ float:left;
+.mbList li
+ cursor: pointer;
+.mbList li.listCommand
+ font-style: italic;
+.mbList li#listFilter
+ margin-bottom: 1em;
+/* content area */
+div.formContainer
+ margin-top: 2em;
+ min-height: 30em;
+ float:left;
+ width:50em;
+div.formContainer ul
+ margin-right: auto;
+div.formContainer form ul li
+ padding-top: 0.2em;
+ border-bottom: 1px dotted gray;
+ vertical-align: top;
+div.formContainer form ul > li>label
+ width: 11em;
+ display: block;
+div.formContainer form ul > li>label:after
+ content: ' : ';
+div.formContainer form ul > li>select, div.formContainer form >ul>li>input
+ width: 12em;
+ border: none;
+ margin-top: 0px;
+ margin-bottom: auto;
+div.formContainer form input[type=submit]
+ margin-left: 26em;
+input[type="checkbox"]
+ border: none;
Property changes on: branches/print_dev/http/css/mod_AdminTabs.css
___________________________________________________________________
Added: svn:executable
Added: branches/print_dev/http/extensions/jquery-ui-1.7.2.custom.min.js
--- branches/print_dev/http/extensions/jquery-ui-1.7.2.custom.min.js (rev 0)
+++ branches/print_dev/http/extensions/jquery-ui-1.7.2.custom.min.js 2009-09-28 14:33:00 UTC (rev 4761)
@@ -0,0 +1,298 @@
+ * jQuery UI 1.7.2
+ * Copyright (c) 2009 AUTHORS.txt (http://jqueryui.com/about)
+ * Dual licensed under the MIT (MIT-LICENSE.txt)
+ * and GPL (GPL-LICENSE.txt) licenses.
+ * http://docs.jquery.com/UI
+jQuery.ui||(function(c){var i=c.fn.remove,d=c.browser.mozilla&&(parseFloat(c.browser.version)<1.9);c.ui={version:"1.7.2",plugin:{add:function(k,l,n){var m=c.ui[k].prototype;for(var j in n){m.plugins[j]=m.plugins[j]||[];m.plugins[j].push([l,n[j]])}},call:function(j,l,k){var n=j.plugins[l];if(!n||!j.element[0].parentNode){return}for(var m=0;m<n.length;m++){if(j.options[n[m][0]]){n[m][1].apply(j.element,k)}}}},contains:function(k,j){return document.compareDocumentPosition?k.compareDocumentPosition(j)&16:k!==j&&k.contains(j)},hasScroll:function(m,k){if(c(m).css("overflow")=="hidden"){return false}var j=(k&&k=="left")?"scrollLeft":"scrollTop",l=false;if(m[j]>0){return true}m[j]=1;l=(m[j]>0);m[j]=0;return l},isOverAxis:function(k,j,l){return(k>j)&&(k<(j+l))},isOver:function(o,k,n,m,j,l){return c.ui.isOverAxis(o,n,j)&&c.ui.isOverAxis(k,m,l)},keyCode:{BACKSPACE:8,CAPS_LOCK:20,COMMA:188,CONTROL:17,DELETE:46,DOWN:40,END:35,ENTER:13,ESCAPE:27,HOME:36,INSERT:45,LEFT:37,NUMPAD_ADD:107,NUMPAD_DECIMAL:110,NUMPAD_DIVIDE:111,NUMPAD_ENTER:108,NUMPAD_MULTIPLY:106,NUMPAD_SUBTRACT:109,PAGE_DOWN:34,PAGE_UP:33,PERIOD:190,RIGHT:39,SHIFT:16,SPACE:32,TAB:9,UP:38}};if(d){var f=c.attr,e=c.fn.removeAttr,h="http://www.w3.org/2005/07/aaa",a=/^aria-/,b=/^wairole:/;c.attr=function(k,j,l){var m=l!==undefined;return(j=="role"?(m?f.call(this,k,j,"wairole:"+l):(f.apply(this,arguments)||"").replace(b,"")):(a.test(j)?(m?k.setAttributeNS(h,j.replace(a,"aaa:"),l):f.call(this,k,j.replace(a,"aaa:"))):f.apply(this,arguments)))};c.fn.removeAttr=function(j){return(a.test(j)?this.each(function(){this.removeAttributeNS(h,j.replace(a,""))}):e.call(this,j))}}c.fn.extend({remove:function(){c("*",this).add(this).each(function(){c(this).triggerHandler("remove")});return i.apply(this,arguments)},enableSelection:function(){return this.attr("unselectable","off").css("MozUserSelect","").unbind("selectstart.ui")},disableSelection:function(){return this.attr("unselectable","on").css("MozUserSelect","none").bind("selectstart.ui",function(){return false})},scrollParent:function(){var j;if((c.browser.msie&&(/(static|relative)/).test(this.css("position")))||(/absolute/).test(this.css("position"))){j=this.parents().filter(function(){return(/(relative|absolute|fixed)/).test(c.curCSS(this,"position",1))&&(/(auto|scroll)/).test(c.curCSS(this,"overflow",1)+c.curCSS(this,"overflow-y",1)+c.curCSS(this,"overflow-x",1))}).eq(0)}else{j=this.parents().filter(function(){return(/(auto|scroll)/).test(c.curCSS(this,"overflow",1)+c.curCSS(this,"overflow-y",1)+c.curCSS(this,"overflow-x",1))}).eq(0)}return(/fixed/).test(this.css("position"))||!j.length?c(document):j}});c.extend(c.expr[":"],{data:function(l,k,j){return !!c.data(l,j[3])},focusable:function(k){var l=k.nodeName.toLowerCase(),j=c.attr(k,"tabindex");return(/input|select|textarea|button|object/.test(l)?!k.disabled:"a"==l||"area"==l?k.href||!isNaN(j):!isNaN(j))&&!c(k)["area"==l?"parents":"closest"](":hidden").length},tabbable:function(k){var j=c.attr(k,"tabindex");return(isNaN(j)||j>=0)&&c(k).is(":focusable")}});function g(m,n,o,l){function k(q){var p=c[m][n][q]||[];return(typeof p=="string"?p.split(/,?\s+/):p)}var j=k("getter");if(l.length==1&&typeof l[0]=="string"){j=j.concat(k("getterSetter"))}return(c.inArray(o,j)!=-1)}c.widget=function(k,j){var l=k.split(".")[0];k=k.split(".")[1];c.fn[k]=function(p){var n=(typeof p=="string"),o=Array.prototype.slice.call(arguments,1);if(n&&p.substring(0,1)=="_"){return this}if(n&&g(l,k,p,o)){var m=c.data(this[0],k);return(m?m[p].apply(m,o):undefined)}return this.each(function(){var q=c.data(this,k);(!q&&!n&&c.data(this,k,new c[l][k](this,p))._init());(q&&n&&c.isFunction(q[p])&&q[p].apply(q,o))})};c[l]=c[l]||{};c[l][k]=function(o,n){var m=this;this.namespace=l;this.widgetName=k;this.widgetEventPrefix=c[l][k].eventPrefix||k;this.widgetBaseClass=l+"-"+k;this.options=c.extend({},c.widget.defaults,c[l][k].defaults,c.metadata&&c.metadata.get(o)[k],n);this.element=c(o).bind("setData."+k,function(q,p,r){if(q.target==o){return m._setData(p,r)}}).bind("getData."+k,function(q,p){if(q.target==o){return m._getData(p)}}).bind("remove",function(){return m.destroy()})};c[l][k].prototype=c.extend({},c.widget.prototype,j);c[l][k].getterSetter="option"};c.widget.prototype={_init:function(){},destroy:function(){this.element.removeData(this.widgetName).removeClass(this.widgetBaseClass+"-disabled "+this.namespace+"-state-disabled").removeAttr("aria-disabled")},option:function(l,m){var k=l,j=this;if(typeof l=="string"){if(m===undefined){return this._getData(l)}k={};k[l]=m}c.each(k,function(n,o){j._setData(n,o)})},_getData:function(j){return this.options[j]},_setData:function(j,k){this.options[j]=k;if(j=="disabled"){this.element[k?"addClass":"removeClass"](this.widgetBaseClass+"-disabled "+this.namespace+"-state-disabled").attr("aria-disabled",k)}},enable:function(){this._setData("disabled",false)},disable:function(){this._setData("disabled",true)},_trigger:function(l,m,n){var p=this.options[l],j=(l==this.widgetEventPrefix?l:this.widgetEventPrefix+l);m=c.Event(m);m.type=j;if(m.originalEvent){for(var k=c.event.props.length,o;k;){o=c.event.props[--k];m[o]=m.originalEvent[o]}}this.element.trigger(m,n);return !(c.isFunction(p)&&p.call(this.element[0],m,n)===false||m.isDefaultPrevented())}};c.widget.defaults={disabled:false};c.ui.mouse={_mouseInit:function(){var j=this;this.element.bind("mousedown."+this.widgetName,function(k){return j._mouseDown(k)}).bind("click."+this.widgetName,function(k){if(j._preventClickEvent){j._preventClickEvent=false;k.stopImmediatePropagation();return false}});if(c.browser.msie){this._mouseUnselectable=this.element.attr("unselectable");this.element.attr("unselectable","on")}this.started=false},_mouseDestroy:function(){this.element.unbind("."+this.widgetName);(c.browser.msie&&this.element.attr("unselectable",this._mouseUnselectable))},_mouseDown:function(l){l.originalEvent=l.originalEvent||{};if(l.originalEvent.mouseHandled){return}(this._mouseStarted&&this._mouseUp(l));this._mouseDownEvent=l;var k=this,m=(l.which==1),j=(typeof this.options.cancel=="string"?c(l.target).parents().add(l.target).filter(this.options.cancel).length:false);if(!m||j||!this._mouseCapture(l)){return true}this.mouseDelayMet=!this.options.delay;if(!this.mouseDelayMet){this._mouseDelayTimer=setTimeout(function(){k.mouseDelayMet=true},this.options.delay)}if(this._mouseDistanceMet(l)&&this._mouseDelayMet(l)){this._mouseStarted=(this._mouseStart(l)!==false);if(!this._mouseStarted){l.preventDefault();return true}}this._mouseMoveDelegate=function(n){return k._mouseMove(n)};this._mouseUpDelegate=function(n){return k._mouseUp(n)};c(document).bind("mousemove."+this.widgetName,this._mouseMoveDelegate).bind("mouseup."+this.widgetName,this._mouseUpDelegate);(c.browser.safari||l.preventDefault());l.originalEvent.mouseHandled=true;return true},_mouseMove:function(j){if(c.browser.msie&&!j.button){return this._mouseUp(j)}if(this._mouseStarted){this._mouseDrag(j);return j.preventDefault()}if(this._mouseDistanceMet(j)&&this._mouseDelayMet(j)){this._mouseStarted=(this._mouseStart(this._mouseDownEvent,j)!==false);(this._mouseStarted?this._mouseDrag(j):this._mouseUp(j))}return !this._mouseStarted},_mouseUp:function(j){c(document).unbind("mousemove."+this.widgetName,this._mouseMoveDelegate).unbind("mouseup."+this.widgetName,this._mouseUpDelegate);if(this._mouseStarted){this._mouseStarted=false;this._preventClickEvent=(j.target==this._mouseDownEvent.target);this._mouseStop(j)}return false},_mouseDistanceMet:function(j){return(Math.max(Math.abs(this._mouseDownEvent.pageX-j.pageX),Math.abs(this._mouseDownEvent.pageY-j.pageY))>=this.options.distance)},_mouseDelayMet:function(j){return this.mouseDelayMet},_mouseStart:function(j){},_mouseDrag:function(j){},_mouseStop:function(j){},_mouseCapture:function(j){return true}};c.ui.mouse.defaults={cancel:null,distance:1,delay:0}})(jQuery);;/*
+ * jQuery UI Draggable 1.7.2
+ * http://docs.jquery.com/UI/Draggables
+ * Depends:
+ * ui.core.js
+(function(a){a.widget("ui.draggable",a.extend({},a.ui.mouse,{_init:function(){if(this.options.helper=="original"&&!(/^(?:r|a|f)/).test(this.element.css("position"))){this.element[0].style.position="relative"}(this.options.addClasses&&this.element.addClass("ui-draggable"));(this.options.disabled&&this.element.addClass("ui-draggable-disabled"));this._mouseInit()},destroy:function(){if(!this.element.data("draggable")){return}this.element.removeData("draggable").unbind(".draggable").removeClass("ui-draggable ui-draggable-dragging ui-draggable-disabled");this._mouseDestroy()},_mouseCapture:function(b){var c=this.options;if(this.helper||c.disabled||a(b.target).is(".ui-resizable-handle")){return false}this.handle=this._getHandle(b);if(!this.handle){return false}return true},_mouseStart:function(b){var c=this.options;this.helper=this._createHelper(b);this._cacheHelperProportions();if(a.ui.ddmanager){a.ui.ddmanager.current=this}this._cacheMargins();this.cssPosition=this.helper.css("position");this.scrollParent=this.helper.scrollParent();this.offset=this.element.offset();this.offset={top:this.offset.top-this.margins.top,left:this.offset.left-this.margins.left};a.extend(this.offset,{click:{left:b.pageX-this.offset.left,top:b.pageY-this.offset.top},parent:this._getParentOffset(),relative:this._getRelativeOffset()});this.originalPosition=this._generatePosition(b);this.originalPageX=b.pageX;this.originalPageY=b.pageY;if(c.cursorAt){this._adjustOffsetFromHelper(c.cursorAt)}if(c.containment){this._setContainment()}this._trigger("start",b);this._cacheHelperProportions();if(a.ui.ddmanager&&!c.dropBehaviour){a.ui.ddmanager.prepareOffsets(this,b)}this.helper.addClass("ui-draggable-dragging");this._mouseDrag(b,true);return true},_mouseDrag:function(b,d){this.position=this._generatePosition(b);this.positionAbs=this._convertPositionTo("absolute");if(!d){var c=this._uiHash();this._trigger("drag",b,c);this.position=c.position}if(!this.options.axis||this.options.axis!="y"){this.helper[0].style.left=this.position.left+"px"}if(!this.options.axis||this.options.axis!="x"){this.helper[0].style.top=this.position.top+"px"}if(a.ui.ddmanager){a.ui.ddmanager.drag(this,b)}return false},_mouseStop:function(c){var d=false;if(a.ui.ddmanager&&!this.options.dropBehaviour){d=a.ui.ddmanager.drop(this,c)}if(this.dropped){d=this.dropped;this.dropped=false}if((this.options.revert=="invalid"&&!d)||(this.options.revert=="valid"&&d)||this.options.revert===true||(a.isFunction(this.options.revert)&&this.options.revert.call(this.element,d))){var b=this;a(this.helper).animate(this.originalPosition,parseInt(this.options.revertDuration,10),function(){b._trigger("stop",c);b._clear()})}else{this._trigger("stop",c);this._clear()}return false},_getHandle:function(b){var c=!this.options.handle||!a(this.options.handle,this.element).length?true:false;a(this.options.handle,this.element).find("*").andSelf().each(function(){if(this==b.target){c=true}});return c},_createHelper:function(c){var d=this.options;var b=a.isFunction(d.helper)?a(d.helper.apply(this.element[0],[c])):(d.helper=="clone"?this.element.clone():this.element);if(!b.parents("body").length){b.appendTo((d.appendTo=="parent"?this.element[0].parentNode:d.appendTo))}if(b[0]!=this.element[0]&&!(/(fixed|absolute)/).test(b.css("position"))){b.css("position","absolute")}return b},_adjustOffsetFromHelper:function(b){if(b.left!=undefined){this.offset.click.left=b.left+this.margins.left}if(b.right!=undefined){this.offset.click.left=this.helperProportions.width-b.right+this.margins.left}if(b.top!=undefined){this.offset.click.top=b.top+this.margins.top}if(b.bottom!=undefined){this.offset.click.top=this.helperProportions.height-b.bottom+this.margins.top}},_getParentOffset:function(){this.offsetParent=this.helper.offsetParent();var b=this.offsetParent.offset();if(this.cssPosition=="absolute"&&this.scrollParent[0]!=document&&a.ui.contains(this.scrollParent[0],this.offsetParent[0])){b.left+=this.scrollParent.scrollLeft();b.top+=this.scrollParent.scrollTop()}if((this.offsetParent[0]==document.body)||(this.offsetParent[0].tagName&&this.offsetParent[0].tagName.toLowerCase()=="html"&&a.browser.msie)){b={top:0,left:0}}return{top:b.top+(parseInt(this.offsetParent.css("borderTopWidth"),10)||0),left:b.left+(parseInt(this.offsetParent.css("borderLeftWidth"),10)||0)}},_getRelativeOffset:function(){if(this.cssPosition=="relative"){var b=this.element.position();return{top:b.top-(parseInt(this.helper.css("top"),10)||0)+this.scrollParent.scrollTop(),left:b.left-(parseInt(this.helper.css("left"),10)||0)+this.scrollParent.scrollLeft()}}else{return{top:0,left:0}}},_cacheMargins:function(){this.margins={left:(parseInt(this.element.css("marginLeft"),10)||0),top:(parseInt(this.element.css("marginTop"),10)||0)}},_cacheHelperProportions:function(){this.helperProportions={width:this.helper.outerWidth(),height:this.helper.outerHeight()}},_setContainment:function(){var e=this.options;if(e.containment=="parent"){e.containment=this.helper[0].parentNode}if(e.containment=="document"||e.containment=="window"){this.containment=[0-this.offset.relative.left-this.offset.parent.left,0-this.offset.relative.top-this.offset.parent.top,a(e.containment=="document"?document:window).width()-this.helperProportions.width-this.margins.left,(a(e.containment=="document"?document:window).height()||document.body.parentNode.scrollHeight)-this.helperProportions.height-this.margins.top]}if(!(/^(document|window|parent)$/).test(e.containment)&&e.containment.constructor!=Array){var c=a(e.containment)[0];if(!c){return}var d=a(e.containment).offset();var b=(a(c).css("overflow")!="hidden");this.containment=[d.left+(parseInt(a(c).css("borderLeftWidth"),10)||0)+(parseInt(a(c).css("paddingLeft"),10)||0)-this.margins.left,d.top+(parseInt(a(c).css("borderTopWidth"),10)||0)+(parseInt(a(c).css("paddingTop"),10)||0)-this.margins.top,d.left+(b?Math.max(c.scrollWidth,c.offsetWidth):c.offsetWidth)-(parseInt(a(c).css("borderLeftWidth"),10)||0)-(parseInt(a(c).css("paddingRight"),10)||0)-this.helperProportions.width-this.margins.left,d.top+(b?Math.max(c.scrollHeight,c.offsetHeight):c.offsetHeight)-(parseInt(a(c).css("borderTopWidth"),10)||0)-(parseInt(a(c).css("paddingBottom"),10)||0)-this.helperProportions.height-this.margins.top]}else{if(e.containment.constructor==Array){this.containment=e.containment}}},_convertPositionTo:function(f,h){if(!h){h=this.position}var c=f=="absolute"?1:-1;var e=this.options,b=this.cssPosition=="absolute"&&!(this.scrollParent[0]!=document&&a.ui.contains(this.scrollParent[0],this.offsetParent[0]))?this.offsetParent:this.scrollParent,g=(/(html|body)/i).test(b[0].tagName);return{top:(h.top+this.offset.relative.top*c+this.offset.parent.top*c-(a.browser.safari&&this.cssPosition=="fixed"?0:(this.cssPosition=="fixed"?-this.scrollParent.scrollTop():(g?0:b.scrollTop()))*c)),left:(h.left+this.offset.relative.left*c+this.offset.parent.left*c-(a.browser.safari&&this.cssPosition=="fixed"?0:(this.cssPosition=="fixed"?-this.scrollParent.scrollLeft():g?0:b.scrollLeft())*c))}},_generatePosition:function(e){var h=this.options,b=this.cssPosition=="absolute"&&!(this.scrollParent[0]!=document&&a.ui.contains(this.scrollParent[0],this.offsetParent[0]))?this.offsetParent:this.scrollParent,i=(/(html|body)/i).test(b[0].tagName);if(this.cssPosition=="relative"&&!(this.scrollParent[0]!=document&&this.scrollParent[0]!=this.offsetParent[0])){this.offset.relative=this._getRelativeOffset()}var d=e.pageX;var c=e.pageY;if(this.originalPosition){if(this.containment){if(e.pageX-this.offset.click.left<this.containment[0]){d=this.containment[0]+this.offset.click.left}if(e.pageY-this.offset.click.top<this.containment[1]){c=this.containment[1]+this.offset.click.top}if(e.pageX-this.offset.click.left>this.containment[2]){d=this.containment[2]+this.offset.click.left}if(e.pageY-this.offset.click.top>this.containment[3]){c=this.containment[3]+this.offset.click.top}}if(h.grid){var g=this.originalPageY+Math.round((c-this.originalPageY)/h.grid[1])*h.grid[1];c=this.containment?(!(g-this.offset.click.top<this.containment[1]||g-this.offset.click.top>this.containment[3])?g:(!(g-this.offset.click.top<this.containment[1])?g-h.grid[1]:g+h.grid[1])):g;var f=this.originalPageX+Math.round((d-this.originalPageX)/h.grid[0])*h.grid[0];d=this.containment?(!(f-this.offset.click.left<this.containment[0]||f-this.offset.click.left>this.containment[2])?f:(!(f-this.offset.click.left<this.containment[0])?f-h.grid[0]:f+h.grid[0])):f}}return{top:(c-this.offset.click.top-this.offset.relative.top-this.offset.parent.top+(a.browser.safari&&this.cssPosition=="fixed"?0:(this.cssPosition=="fixed"?-this.scrollParent.scrollTop():(i?0:b.scrollTop())))),left:(d-this.offset.click.left-this.offset.relative.left-this.offset.parent.left+(a.browser.safari&&this.cssPosition=="fixed"?0:(this.cssPosition=="fixed"?-this.scrollParent.scrollLeft():i?0:b.scrollLeft())))}},_clear:function(){this.helper.removeClass("ui-draggable-dragging");if(this.helper[0]!=this.element[0]&&!this.cancelHelperRemoval){this.helper.remove()}this.helper=null;this.cancelHelperRemoval=false},_trigger:function(b,c,d){d=d||this._uiHash();a.ui.plugin.call(this,b,[c,d]);if(b=="drag"){this.positionAbs=this._convertPositionTo("absolute")}return a.widget.prototype._trigger.call(this,b,c,d)},plugins:{},_uiHash:function(b){return{helper:this.helper,position:this.position,absolutePosition:this.positionAbs,offset:this.positionAbs}}}));a.extend(a.ui.draggable,{version:"1.7.2",eventPrefix:"drag",defaults:{addClasses:true,appendTo:"parent",axis:false,cancel:":input,option",connectToSortable:false,containment:false,cursor:"auto",cursorAt:false,delay:0,distance:1,grid:false,handle:false,helper:"original",iframeFix:false,opacity:false,refreshPositions:false,revert:false,revertDuration:500,scope:"default",scroll:true,scrollSensitivity:20,scrollSpeed:20,snap:false,snapMode:"both",snapTolerance:20,stack:false,zIndex:false}});a.ui.plugin.add("draggable","connectToSortable",{start:function(c,e){var d=a(this).data("draggable"),f=d.options,b=a.extend({},e,{item:d.element});d.sortables=[];a(f.connectToSortable).each(function(){var g=a.data(this,"sortable");if(g&&!g.options.disabled){d.sortables.push({instance:g,shouldRevert:g.options.revert});g._refreshItems();g._trigger("activate",c,b)}})},stop:function(c,e){var d=a(this).data("draggable"),b=a.extend({},e,{item:d.element});a.each(d.sortables,function(){if(this.instance.isOver){this.instance.isOver=0;d.cancelHelperRemoval=true;this.instance.cancelHelperRemoval=false;if(this.shouldRevert){this.instance.options.revert=true}this.instance._mouseStop(c);this.instance.options.helper=this.instance.options._helper;if(d.options.helper=="original"){this.instance.currentItem.css({top:"auto",left:"auto"})}}else{this.instance.cancelHelperRemoval=false;this.instance._trigger("deactivate",c,b)}})},drag:function(c,f){var e=a(this).data("draggable"),b=this;var d=function(i){var n=this.offset.click.top,m=this.offset.click.left;var g=this.positionAbs.top,k=this.positionAbs.left;var j=i.height,l=i.width;var p=i.top,h=i.left;return a.ui.isOver(g+n,k+m,p,h,j,l)};a.each(e.sortables,function(g){this.instance.positionAbs=e.positionAbs;this.instance.helperProportions=e.helperProportions;this.instance.offset.click=e.offset.click;if(this.instance._intersectsWith(this.instance.containerCache)){if(!this.instance.isOver){this.instance.isOver=1;this.instance.currentItem=a(b).clone().appendTo(this.instance.element).data("sortable-item",true);this.instance.options._helper=this.instance.options.helper;this.instance.options.helper=function(){return f.helper[0]};c.target=this.instance.currentItem[0];this.instance._mouseCapture(c,true);this.instance._mouseStart(c,true,true);this.instance.offset.click.top=e.offset.click.top;this.instance.offset.click.left=e.offset.click.left;this.instance.offset.parent.left-=e.offset.parent.left-this.instance.offset.parent.left;this.instance.offset.parent.top-=e.offset.parent.top-this.instance.offset.parent.top;e._trigger("toSortable",c);e.dropped=this.instance.element;e.currentItem=e.element;this.instance.fromOutside=e}if(this.instance.currentItem){this.instance._mouseDrag(c)}}else{if(this.instance.isOver){this.instance.isOver=0;this.instance.cancelHelperRemoval=true;this.instance.options.revert=false;this.instance._trigger("out",c,this.instance._uiHash(this.instance));this.instance._mouseStop(c,true);this.instance.options.helper=this.instance.options._helper;this.instance.currentItem.remove();if(this.instance.placeholder){this.instance.placeholder.remove()}e._trigger("fromSortable",c);e.dropped=false}}})}});a.ui.plugin.add("draggable","cursor",{start:function(c,d){var b=a("body"),e=a(this).data("draggable").options;if(b.css("cursor")){e._cursor=b.css("cursor")}b.css("cursor",e.cursor)},stop:function(b,c){var d=a(this).data("draggable").options;if(d._cursor){a("body").css("cursor",d._cursor)}}});a.ui.plugin.add("draggable","iframeFix",{start:function(b,c){var d=a(this).data("draggable").options;a(d.iframeFix===true?"iframe":d.iframeFix).each(function(){a('<div class="ui-draggable-iframeFix" style="background: #fff;"></div>').css({width:this.offsetWidth+"px",height:this.offsetHeight+"px",position:"absolute",opacity:"0.001",zIndex:1000}).css(a(this).offset()).appendTo("body")})},stop:function(b,c){a("div.ui-draggable-iframeFix").each(function(){this.parentNode.removeChild(this)})}});a.ui.plugin.add("draggable","opacity",{start:function(c,d){var b=a(d.helper),e=a(this).data("draggable").options;if(b.css("opacity")){e._opacity=b.css("opacity")}b.css("opacity",e.opacity)},stop:function(b,c){var d=a(this).data("draggable").options;if(d._opacity){a(c.helper).css("opacity",d._opacity)}}});a.ui.plugin.add("draggable","scroll",{start:function(c,d){var b=a(this).data("draggable");if(b.scrollParent[0]!=document&&b.scrollParent[0].tagName!="HTML"){b.overflowOffset=b.scrollParent.offset()}},drag:function(d,e){var c=a(this).data("draggable"),f=c.options,b=false;if(c.scrollParent[0]!=document&&c.scrollParent[0].tagName!="HTML"){if(!f.axis||f.axis!="x"){if((c.overflowOffset.top+c.scrollParent[0].offsetHeight)-d.pageY<f.scrollSensitivity){c.scrollParent[0].scrollTop=b=c.scrollParent[0].scrollTop+f.scrollSpeed}else{if(d.pageY-c.overflowOffset.top<f.scrollSensitivity){c.scrollParent[0].scrollTop=b=c.scrollParent[0].scrollTop-f.scrollSpeed}}}if(!f.axis||f.axis!="y"){if((c.overflowOffset.left+c.scrollParent[0].offsetWidth)-d.pageX<f.scrollSensitivity){c.scrollParent[0].scrollLeft=b=c.scrollParent[0].scrollLeft+f.scrollSpeed}else{if(d.pageX-c.overflowOffset.left<f.scrollSensitivity){c.scrollParent[0].scrollLeft=b=c.scrollParent[0].scrollLeft-f.scrollSpeed}}}}else{if(!f.axis||f.axis!="x"){if(d.pageY-a(document).scrollTop()<f.scrollSensitivity){b=a(document).scrollTop(a(document).scrollTop()-f.scrollSpeed)}else{if(a(window).height()-(d.pageY-a(document).scrollTop())<f.scrollSensitivity){b=a(document).scrollTop(a(document).scrollTop()+f.scrollSpeed)}}}if(!f.axis||f.axis!="y"){if(d.pageX-a(document).scrollLeft()<f.scrollSensitivity){b=a(document).scrollLeft(a(document).scrollLeft()-f.scrollSpeed)}else{if(a(window).width()-(d.pageX-a(document).scrollLeft())<f.scrollSensitivity){b=a(document).scrollLeft(a(document).scrollLeft()+f.scrollSpeed)}}}}if(b!==false&&a.ui.ddmanager&&!f.dropBehaviour){a.ui.ddmanager.prepareOffsets(c,d)}}});a.ui.plugin.add("draggable","snap",{start:function(c,d){var b=a(this).data("draggable"),e=b.options;b.snapElements=[];a(e.snap.constructor!=String?(e.snap.items||":data(draggable)"):e.snap).each(function(){var g=a(this);var f=g.offset();if(this!=b.element[0]){b.snapElements.push({item:this,width:g.outerWidth(),height:g.outerHeight(),top:f.top,left:f.left})}})},drag:function(u,p){var g=a(this).data("draggable"),q=g.options;var y=q.snapTolerance;var x=p.offset.left,w=x+g.helperProportions.width,f=p.offset.top,e=f+g.helperProportions.height;for(var v=g.snapElements.length-1;v>=0;v--){var s=g.snapElements[v].left,n=s+g.snapElements[v].width,m=g.snapElements[v].top,A=m+g.snapElements[v].height;if(!((s-y<x&&x<n+y&&m-y<f&&f<A+y)||(s-y<x&&x<n+y&&m-y<e&&e<A+y)||(s-y<w&&w<n+y&&m-y<f&&f<A+y)||(s-y<w&&w<n+y&&m-y<e&&e<A+y))){if(g.snapElements[v].snapping){(g.options.snap.release&&g.options.snap.release.call(g.element,u,a.extend(g._uiHash(),{snapItem:g.snapElements[v].item})))}g.snapElements[v].snapping=false;continue}if(q.snapMode!="inner"){var c=Math.abs(m-e)<=y;var z=Math.abs(A-f)<=y;var j=Math.abs(s-w)<=y;var k=Math.abs(n-x)<=y;if(c){p.position.top=g._convertPositionTo("relative",{top:m-g.helperProportions.height,left:0}).top-g.margins.top}if(z){p.position.top=g._convertPositionTo("relative",{top:A,left:0}).top-g.margins.top}if(j){p.position.left=g._convertPositionTo("relative",{top:0,left:s-g.helperProportions.width}).left-g.margins.left}if(k){p.position.left=g._convertPositionTo("relative",{top:0,left:n}).left-g.margins.left}}var h=(c||z||j||k);if(q.snapMode!="outer"){var c=Math.abs(m-f)<=y;var z=Math.abs(A-e)<=y;var j=Math.abs(s-x)<=y;var k=Math.abs(n-w)<=y;if(c){p.position.top=g._convertPositionTo("relative",{top:m,left:0}).top-g.margins.top}if(z){p.position.top=g._convertPositionTo("relative",{top:A-g.helperProportions.height,left:0}).top-g.margins.top}if(j){p.position.left=g._convertPositionTo("relative",{top:0,left:s}).left-g.margins.left}if(k){p.position.left=g._convertPositionTo("relative",{top:0,left:n-g.helperProportions.width}).left-g.margins.left}}if(!g.snapElements[v].snapping&&(c||z||j||k||h)){(g.options.snap.snap&&g.options.snap.snap.call(g.element,u,a.extend(g._uiHash(),{snapItem:g.snapElements[v].item})))}g.snapElements[v].snapping=(c||z||j||k||h)}}});a.ui.plugin.add("draggable","stack",{start:function(b,c){var e=a(this).data("draggable").options;var d=a.makeArray(a(e.stack.group)).sort(function(g,f){return(parseInt(a(g).css("zIndex"),10)||e.stack.min)-(parseInt(a(f).css("zIndex"),10)||e.stack.min)});a(d).each(function(f){this.style.zIndex=e.stack.min+f});this[0].style.zIndex=e.stack.min+d.length}});a.ui.plugin.add("draggable","zIndex",{start:function(c,d){var b=a(d.helper),e=a(this).data("draggable").options;if(b.css("zIndex")){e._zIndex=b.css("zIndex")}b.css("zIndex",e.zIndex)},stop:function(b,c){var d=a(this).data("draggable").options;if(d._zIndex){a(c.helper).css("zIndex",d._zIndex)}}})})(jQuery);;/*
+ * jQuery UI Droppable 1.7.2
+ * http://docs.jquery.com/UI/Droppables
+ * Depends:
+ * ui.core.js
+ * ui.draggable.js
+(function(a){a.widget("ui.droppable",{_init:function(){var c=this.options,b=c.accept;this.isover=0;this.isout=1;this.options.accept=this.options.accept&&a.isFunction(this.options.accept)?this.options.accept:function(e){return e.is(b)};this.proportions={width:this.element[0].offsetWidth,height:this.element[0].offsetHeight};a.ui.ddmanager.droppables[this.options.scope]=a.ui.ddmanager.droppables[this.options.scope]||[];a.ui.ddmanager.droppables[this.options.scope].push(this);(this.options.addClasses&&this.element.addClass("ui-droppable"))},destroy:function(){var b=a.ui.ddmanager.droppables[this.options.scope];for(var c=0;c<b.length;c++){if(b[c]==this){b.splice(c,1)}}this.element.removeClass("ui-droppable ui-droppable-disabled").removeData("droppable").unbind(".droppable")},_setData:function(b,c){if(b=="accept"){this.options.accept=c&&a.isFunction(c)?c:function(e){return e.is(c)}}else{a.widget.prototype._setData.apply(this,arguments)}},_activate:function(c){var b=a.ui.ddmanager.current;if(this.options.activeClass){this.element.addClass(this.options.activeClass)}(b&&this._trigger("activate",c,this.ui(b)))},_deactivate:function(c){var b=a.ui.ddmanager.current;if(this.options.activeClass){this.element.removeClass(this.options.activeClass)}(b&&this._trigger("deactivate",c,this.ui(b)))},_over:function(c){var b=a.ui.ddmanager.current;if(!b||(b.currentItem||b.element)[0]==this.element[0]){return}if(this.options.accept.call(this.element[0],(b.currentItem||b.element))){if(this.options.hoverClass){this.element.addClass(this.options.hoverClass)}this._trigger("over",c,this.ui(b))}},_out:function(c){var b=a.ui.ddmanager.current;if(!b||(b.currentItem||b.element)[0]==this.element[0]){return}if(this.options.accept.call(this.element[0],(b.currentItem||b.element))){if(this.options.hoverClass){this.element.removeClass(this.options.hoverClass)}this._trigger("out",c,this.ui(b))}},_drop:function(c,d){var b=d||a.ui.ddmanager.current;if(!b||(b.currentItem||b.element)[0]==this.element[0]){return false}var e=false;this.element.find(":data(droppable)").not(".ui-draggable-dragging").each(function(){var f=a.data(this,"droppable");if(f.options.greedy&&a.ui.intersect(b,a.extend(f,{offset:f.element.offset()}),f.options.tolerance)){e=true;return false}});if(e){return false}if(this.options.accept.call(this.element[0],(b.currentItem||b.element))){if(this.options.activeClass){this.element.removeClass(this.options.activeClass)}if(this.options.hoverClass){this.element.removeClass(this.options.hoverClass)}this._trigger("drop",c,this.ui(b));return this.element}return false},ui:function(b){return{draggable:(b.currentItem||b.element),helper:b.helper,position:b.position,absolutePosition:b.positionAbs,offset:b.positionAbs}}});a.extend(a.ui.droppable,{version:"1.7.2",eventPrefix:"drop",defaults:{accept:"*",activeClass:false,addClasses:true,greedy:false,hoverClass:false,scope:"default",tolerance:"intersect"}});a.ui.intersect=function(q,j,o){if(!j.offset){return false}var e=(q.positionAbs||q.position.absolute).left,d=e+q.helperProportions.width,n=(q.positionAbs||q.position.absolute).top,m=n+q.helperProportions.height;var g=j.offset.left,c=g+j.proportions.width,p=j.offset.top,k=p+j.proportions.height;switch(o){case"fit":return(g<e&&d<c&&p<n&&m<k);break;case"intersect":return(g<e+(q.helperProportions.width/2)&&d-(q.helperProportions.width/2)<c&&p<n+(q.helperProportions.height/2)&&m-(q.helperProportions.height/2)<k);break;case"pointer":var h=((q.positionAbs||q.position.absolute).left+(q.clickOffset||q.offset.click).left),i=((q.positionAbs||q.position.absolute).top+(q.clickOffset||q.offset.click).top),f=a.ui.isOver(i,h,p,g,j.proportions.height,j.proportions.width);return f;break;case"touch":return((n>=p&&n<=k)||(m>=p&&m<=k)||(n<p&&m>k))&&((e>=g&&e<=c)||(d>=g&&d<=c)||(e<g&&d>c));break;default:return false;break}};a.ui.ddmanager={current:null,droppables:{"default":[]},prepareOffsets:function(e,g){var b=a.ui.ddmanager.droppables[e.options.scope];var f=g?g.type:null;var h=(e.currentItem||e.element).find(":data(droppable)").andSelf();droppablesLoop:for(var d=0;d<b.length;d++){if(b[d].options.disabled||(e&&!b[d].options.accept.call(b[d].element[0],(e.currentItem||e.element)))){continue}for(var c=0;c<h.length;c++){if(h[c]==b[d].element[0]){b[d].proportions.height=0;continue droppablesLoop}}b[d].visible=b[d].element.css("display")!="none";if(!b[d].visible){continue}b[d].offset=b[d].element.offset();b[d].proportions={width:b[d].element[0].offsetWidth,height:b[d].element[0].offsetHeight};if(f=="mousedown"){b[d]._activate.call(b[d],g)}}},drop:function(b,c){var d=false;a.each(a.ui.ddmanager.droppables[b.options.scope],function(){if(!this.options){return}if(!this.options.disabled&&this.visible&&a.ui.intersect(b,this,this.options.tolerance)){d=this._drop.call(this,c)}if(!this.options.disabled&&this.visible&&this.options.accept.call(this.element[0],(b.currentItem||b.element))){this.isout=1;this.isover=0;this._deactivate.call(this,c)}});return d},drag:function(b,c){if(b.options.refreshPositions){a.ui.ddmanager.prepareOffsets(b,c)}a.each(a.ui.ddmanager.droppables[b.options.scope],function(){if(this.options.disabled||this.greedyChild||!this.visible){return}var e=a.ui.intersect(b,this,this.options.tolerance);var g=!e&&this.isover==1?"isout":(e&&this.isover==0?"isover":null);if(!g){return}var f;if(this.options.greedy){var d=this.element.parents(":data(droppable):eq(0)");if(d.length){f=a.data(d[0],"droppable");f.greedyChild=(g=="isover"?1:0)}}if(f&&g=="isover"){f.isover=0;f.isout=1;f._out.call(f,c)}this[g]=1;this[g=="isout"?"isover":"isout"]=0;this[g=="isover"?"_over":"_out"].call(this,c);if(f&&g=="isout"){f.isout=0;f.isover=1;f._over.call(f,c)}})}}})(jQuery);;/*
+ * jQuery UI Resizable 1.7.2
+ * http://docs.jquery.com/UI/Resizables
+ * Depends:
+ * ui.core.js
+(function(c){c.widget("ui.resizable",c.extend({},c.ui.mouse,{_init:function(){var e=this,j=this.options;this.element.addClass("ui-resizable");c.extend(this,{_aspectRatio:!!(j.aspectRatio),aspectRatio:j.aspectRatio,originalElement:this.element,_proportionallyResizeElements:[],_helper:j.helper||j.ghost||j.animate?j.helper||"ui-resizable-helper":null});if(this.element[0].nodeName.match(/canvas|textarea|input|select|button|img/i)){if(/relative/.test(this.element.css("position"))&&c.browser.opera){this.element.css({position:"relative",top:"auto",left:"auto"})}this.element.wrap(c('<div class="ui-wrapper" style="overflow: hidden;"></div>').css({position:this.element.css("position"),width:this.element.outerWidth(),height:this.element.outerHeight(),top:this.element.css("top"),left:this.element.css("left")}));this.element=this.element.parent().data("resizable",this.element.data("resizable"));this.elementIsWrapper=true;this.element.css({marginLeft:this.originalElement.css("marginLeft"),marginTop:this.originalElement.css("marginTop"),marginRight:this.originalElement.css("marginRight"),marginBottom:this.originalElement.css("marginBottom")});this.originalElement.css({marginLeft:0,marginTop:0,marginRight:0,marginBottom:0});this.originalResizeStyle=this.originalElement.css("resize");this.originalElement.css("resize","none");this._proportionallyResizeElements.push(this.originalElement.css({position:"static",zoom:1,display:"block"}));this.originalElement.css({margin:this.originalElement.css("margin")});this._proportionallyResize()}this.handles=j.handles||(!c(".ui-resizable-handle",this.element).length?"e,s,se":{n:".ui-resizable-n",e:".ui-resizable-e",s:".ui-resizable-s",w:".ui-resizable-w",se:".ui-resizable-se",sw:".ui-resizable-sw",ne:".ui-resizable-ne",nw:".ui-resizable-nw"});if(this.handles.constructor==String){if(this.handles=="all"){this.handles="n,e,s,w,se,sw,ne,nw"}var k=this.handles.split(",");this.handles={};for(var f=0;f<k.length;f++){var h=c.trim(k[f]),d="ui-resizable-"+h;var g=c('<div class="ui-resizable-handle '+d+'"></div>');if(/sw|se|ne|nw/.test(h)){g.css({zIndex:++j.zIndex})}if("se"==h){g.addClass("ui-icon ui-icon-gripsmall-diagonal-se")}this.handles[h]=".ui-resizable-"+h;this.element.append(g)}}this._renderAxis=function(p){p=p||this.element;for(var m in this.handles){if(this.handles[m].constructor==String){this.handles[m]=c(this.handles[m],this.element).show()}if(this.elementIsWrapper&&this.originalElement[0].nodeName.match(/textarea|input|select|button/i)){var n=c(this.handles[m],this.element),o=0;o=/sw|ne|nw|se|n|s/.test(m)?n.outerHeight():n.outerWidth();var l=["padding",/ne|nw|n/.test(m)?"Top":/se|sw|s/.test(m)?"Bottom":/^e$/.test(m)?"Right":"Left"].join("");p.css(l,o);this._proportionallyResize()}if(!c(this.handles[m]).length){continue}}};this._renderAxis(this.element);this._handles=c(".ui-resizable-handle",this.element).disableSelection();this._handles.mouseover(function(){if(!e.resizing){if(this.className){var i=this.className.match(/ui-resizable-(se|sw|ne|nw|n|e|s|w)/i)}e.axis=i&&i[1]?i[1]:"se"}});if(j.autoHide){this._handles.hide();c(this.element).addClass("ui-resizable-autohide").hover(function(){c(this).removeClass("ui-resizable-autohide");e._handles.show()},function(){if(!e.resizing){c(this).addClass("ui-resizable-autohide");e._handles.hide()}})}this._mouseInit()},destroy:function(){this._mouseDestroy();var d=function(f){c(f).removeClass("ui-resizable ui-resizable-disabled ui-resizable-resizing").removeData("resizable").unbind(".resizable").find(".ui-resizable-handle").remove()};if(this.elementIsWrapper){d(this.element);var e=this.element;e.parent().append(this.originalElement.css({position:e.css("position"),width:e.outerWidth(),height:e.outerHeight(),top:e.css("top"),left:e.css("left")})).end().remove()}this.originalElement.css("resize",this.originalResizeStyle);d(this.originalElement)},_mouseCapture:function(e){var f=false;for(var d in this.handles){if(c(this.handles[d])[0]==e.target){f=true}}return this.options.disabled||!!f},_mouseStart:function(f){var i=this.options,e=this.element.position(),d=this.element;this.resizing=true;this.documentScroll={top:c(document).scrollTop(),left:c(document).scrollLeft()};if(d.is(".ui-draggable")||(/absolute/).test(d.css("position"))){d.css({position:"absolute",top:e.top,left:e.left})}if(c.browser.opera&&(/relative/).test(d.css("position"))){d.css({position:"relative",top:"auto",left:"auto"})}this._renderProxy();var j=b(this.helper.css("left")),g=b(this.helper.css("top"));if(i.containment){j+=c(i.containment).scrollLeft()||0;g+=c(i.containment).scrollTop()||0}this.offset=this.helper.offset();this.position={left:j,top:g};this.size=this._helper?{width:d.outerWidth(),height:d.outerHeight()}:{width:d.width(),height:d.height()};this.originalSize=this._helper?{width:d.outerWidth(),height:d.outerHeight()}:{width:d.width(),height:d.height()};this.originalPosition={left:j,top:g};this.sizeDiff={width:d.outerWidth()-d.width(),height:d.outerHeight()-d.height()};this.originalMousePosition={left:f.pageX,top:f.pageY};this.aspectRatio=(typeof i.aspectRatio=="number")?i.aspectRatio:((this.originalSize.width/this.originalSize.height)||1);var h=c(".ui-resizable-"+this.axis).css("cursor");c("body").css("cursor",h=="auto"?this.axis+"-resize":h);d.addClass("ui-resizable-resizing");this._propagate("start",f);return true},_mouseDrag:function(d){var g=this.helper,f=this.options,l={},p=this,i=this.originalMousePosition,m=this.axis;var q=(d.pageX-i.left)||0,n=(d.pageY-i.top)||0;var h=this._change[m];if(!h){return false}var k=h.apply(this,[d,q,n]),j=c.browser.msie&&c.browser.version<7,e=this.sizeDiff;if(this._aspectRatio||d.shiftKey){k=this._updateRatio(k,d)}k=this._respectSize(k,d);this._propagate("resize",d);g.css({top:this.position.top+"px",left:this.position.left+"px",width:this.size.width+"px",height:this.size.height+"px"});if(!this._helper&&this._proportionallyResizeElements.length){this._proportionallyResize()}this._updateCache(k);this._trigger("resize",d,this.ui());return false},_mouseStop:function(g){this.resizing=false;var h=this.options,l=this;if(this._helper){var f=this._proportionallyResizeElements,d=f.length&&(/textarea/i).test(f[0].nodeName),e=d&&c.ui.hasScroll(f[0],"left")?0:l.sizeDiff.height,j=d?0:l.sizeDiff.width;var m={width:(l.size.width-j),height:(l.size.height-e)},i=(parseInt(l.element.css("left"),10)+(l.position.left-l.originalPosition.left))||null,k=(parseInt(l.element.css("top"),10)+(l.position.top-l.originalPosition.top))||null;if(!h.animate){this.element.css(c.extend(m,{top:k,left:i}))}l.helper.height(l.size.height);l.helper.width(l.size.width);if(this._helper&&!h.animate){this._proportionallyResize()}}c("body").css("cursor","auto");this.element.removeClass("ui-resizable-resizing");this._propagate("stop",g);if(this._helper){this.helper.remove()}return false},_updateCache:function(d){var e=this.options;this.offset=this.helper.offset();if(a(d.left)){this.position.left=d.left}if(a(d.top)){this.position.top=d.top}if(a(d.height)){this.size.height=d.height}if(a(d.width)){this.size.width=d.width}},_updateRatio:function(g,f){var h=this.options,i=this.position,e=this.size,d=this.axis;if(g.height){g.width=(e.height*this.aspectRatio)}else{if(g.width){g.height=(e.width/this.aspectRatio)}}if(d=="sw"){g.left=i.left+(e.width-g.width);g.top=null}if(d=="nw"){g.top=i.top+(e.height-g.height);g.left=i.left+(e.width-g.width)}return g},_respectSize:function(k,f){var i=this.helper,h=this.options,q=this._aspectRatio||f.shiftKey,p=this.axis,s=a(k.width)&&h.maxWidth&&(h.maxWidth<k.width),l=a(k.height)&&h.maxHeight&&(h.maxHeight<k.height),g=a(k.width)&&h.minWidth&&(h.minWidth>k.width),r=a(k.height)&&h.minHeight&&(h.minHeight>k.height);if(g){k.width=h.minWidth}if(r){k.height=h.minHeight}if(s){k.width=h.maxWidth}if(l){k.height=h.maxHeight}var e=this.originalPosition.left+this.originalSize.width,n=this.position.top+this.size.height;var j=/sw|nw|w/.test(p),d=/nw|ne|n/.test(p);if(g&&j){k.left=e-h.minWidth}if(s&&j){k.left=e-h.maxWidth}if(r&&d){k.top=n-h.minHeight}if(l&&d){k.top=n-h.maxHeight}var m=!k.width&&!k.height;if(m&&!k.left&&k.top){k.top=null}else{if(m&&!k.top&&k.left){k.left=null}}return k},_proportionallyResize:function(){var j=this.options;if(!this._proportionallyResizeElements.length){return}var f=this.helper||this.element;for(var e=0;e<this._proportionallyResizeElements.length;e++){var g=this._proportionallyResizeElements[e];if(!this.borderDif){var d=[g.css("borderTopWidth"),g.css("borderRightWidth"),g.css("borderBottomWidth"),g.css("borderLeftWidth")],h=[g.css("paddingTop"),g.css("paddingRight"),g.css("paddingBottom"),g.css("paddingLeft")];this.borderDif=c.map(d,function(k,m){var l=parseInt(k,10)||0,n=parseInt(h[m],10)||0;return l+n})}if(c.browser.msie&&!(!(c(f).is(":hidden")||c(f).parents(":hidden").length))){continue}g.css({height:(f.height()-this.borderDif[0]-this.borderDif[2])||0,width:(f.width()-this.borderDif[1]-this.borderDif[3])||0})}},_renderProxy:function(){var e=this.element,h=this.options;this.elementOffset=e.offset();if(this._helper){this.helper=this.helper||c('<div style="overflow:hidden;"></div>');var d=c.browser.msie&&c.browser.version<7,f=(d?1:0),g=(d?2:-1);this.helper.addClass(this._helper).css({width:this.element.outerWidth()+g,height:this.element.outerHeight()+g,position:"absolute",left:this.elementOffset.left-f+"px",top:this.elementOffset.top-f+"px",zIndex:++h.zIndex});this.helper.appendTo("body").disableSelection()}else{this.helper=this.element}},_change:{e:function(f,e,d){return{width:this.originalSize.width+e}},w:function(g,e,d){var i=this.options,f=this.originalSize,h=this.originalPosition;return{left:h.left+e,width:f.width-e}},n:function(g,e,d){var i=this.options,f=this.originalSize,h=this.originalPosition;return{top:h.top+d,height:f.height-d}},s:function(f,e,d){return{height:this.originalSize.height+d}},se:function(f,e,d){return c.extend(this._change.s.apply(this,arguments),this._change.e.apply(this,[f,e,d]))},sw:function(f,e,d){return c.extend(this._change.s.apply(this,arguments),this._change.w.apply(this,[f,e,d]))},ne:function(f,e,d){return c.extend(this._change.n.apply(this,arguments),this._change.e.apply(this,[f,e,d]))},nw:function(f,e,d){return c.extend(this._change.n.apply(this,arguments),this._change.w.apply(this,[f,e,d]))}},_propagate:function(e,d){c.ui.plugin.call(this,e,[d,this.ui()]);(e!="resize"&&this._trigger(e,d,this.ui()))},plugins:{},ui:function(){return{originalElement:this.originalElement,element:this.element,helper:this.helper,position:this.position,size:this.size,originalSize:this.originalSize,originalPosition:this.originalPosition}}}));c.extend(c.ui.resizable,{version:"1.7.2",eventPrefix:"resize",defaults:{alsoResize:false,animate:false,animateDuration:"slow",animateEasing:"swing",aspectRatio:false,autoHide:false,cancel:":input,option",containment:false,delay:0,distance:1,ghost:false,grid:false,handles:"e,s,se",helper:false,maxHeight:null,maxWidth:null,minHeight:10,minWidth:10,zIndex:1000}});c.ui.plugin.add("resizable","alsoResize",{start:function(e,f){var d=c(this).data("resizable"),g=d.options;_store=function(h){c(h).each(function(){c(this).data("resizable-alsoresize",{width:parseInt(c(this).width(),10),height:parseInt(c(this).height(),10),left:parseInt(c(this).css("left"),10),top:parseInt(c(this).css("top"),10)})})};if(typeof(g.alsoResize)=="object"&&!g.alsoResize.parentNode){if(g.alsoResize.length){g.alsoResize=g.alsoResize[0];_store(g.alsoResize)}else{c.each(g.alsoResize,function(h,i){_store(h)})}}else{_store(g.alsoResize)}},resize:function(f,h){var e=c(this).data("resizable"),i=e.options,g=e.originalSize,k=e.originalPosition;var j={height:(e.size.height-g.height)||0,width:(e.size.width-g.width)||0,top:(e.position.top-k.top)||0,left:(e.position.left-k.left)||0},d=function(l,m){c(l).each(function(){var p=c(this),q=c(this).data("resizable-alsoresize"),o={},n=m&&m.length?m:["width","height","top","left"];c.each(n||["width","height","top","left"],function(r,t){var s=(q[t]||0)+(j[t]||0);if(s&&s>=0){o[t]=s||null}});if(/relative/.test(p.css("position"))&&c.browser.opera){e._revertToRelativePosition=true;p.css({position:"absolute",top:"auto",left:"auto"})}p.css(o)})};if(typeof(i.alsoResize)=="object"&&!i.alsoResize.nodeType){c.each(i.alsoResize,function(l,m){d(l,m)})}else{d(i.alsoResize)}},stop:function(e,f){var d=c(this).data("resizable");if(d._revertToRelativePosition&&c.browser.opera){d._revertToRelativePosition=false;el.css({position:"relative"})}c(this).removeData("resizable-alsoresize-start")}});c.ui.plugin.add("resizable","animate",{stop:function(h,m){var n=c(this).data("resizable"),i=n.options;var g=n._proportionallyResizeElements,d=g.length&&(/textarea/i).test(g[0].nodeName),e=d&&c.ui.hasScroll(g[0],"left")?0:n.sizeDiff.height,k=d?0:n.sizeDiff.width;var f={width:(n.size.width-k),height:(n.size.height-e)},j=(parseInt(n.element.css("left"),10)+(n.position.left-n.originalPosition.left))||null,l=(parseInt(n.element.css("top"),10)+(n.position.top-n.originalPosition.top))||null;n.element.animate(c.extend(f,l&&j?{top:l,left:j}:{}),{duration:i.animateDuration,easing:i.animateEasing,step:function(){var o={width:parseInt(n.element.css("width"),10),height:parseInt(n.element.css("height"),10),top:parseInt(n.element.css("top"),10),left:parseInt(n.element.css("left"),10)};if(g&&g.length){c(g[0]).css({width:o.width,height:o.height})}n._updateCache(o);n._propagate("resize",h)}})}});c.ui.plugin.add("resizable","containment",{start:function(e,q){var s=c(this).data("resizable"),i=s.options,k=s.element;var f=i.containment,j=(f instanceof c)?f.get(0):(/parent/.test(f))?k.parent().get(0):f;if(!j){return}s.containerElement=c(j);if(/document/.test(f)||f==document){s.containerOffset={left:0,top:0};s.containerPosition={left:0,top:0};s.parentData={element:c(document),left:0,top:0,width:c(document).width(),height:c(document).height()||document.body.parentNode.scrollHeight}}else{var m=c(j),h=[];c(["Top","Right","Left","Bottom"]).each(function(p,o){h[p]=b(m.css("padding"+o))});s.containerOffset=m.offset();s.containerPosition=m.position();s.containerSize={height:(m.innerHeight()-h[3]),width:(m.innerWidth()-h[1])};var n=s.containerOffset,d=s.containerSize.height,l=s.containerSize.width,g=(c.ui.hasScroll(j,"left")?j.scrollWidth:l),r=(c.ui.hasScroll(j)?j.scrollHeight:d);s.parentData={element:j,left:n.left,top:n.top,width:g,height:r}}},resize:function(f,p){var s=c(this).data("resizable"),h=s.options,e=s.containerSize,n=s.containerOffset,l=s.size,m=s.position,q=s._aspectRatio||f.shiftKey,d={top:0,left:0},g=s.containerElement;if(g[0]!=document&&(/static/).test(g.css("position"))){d=n}if(m.left<(s._helper?n.left:0)){s.size.width=s.size.width+(s._helper?(s.position.left-n.left):(s.position.left-d.left));if(q){s.size.height=s.size.width/h.aspectRatio}s.position.left=h.helper?n.left:0}if(m.top<(s._helper?n.top:0)){s.size.height=s.size.height+(s._helper?(s.position.top-n.top):s.position.top);if(q){s.size.width=s.size.height*h.aspectRatio}s.position.top=s._helper?n.top:0}s.offset.left=s.parentData.left+s.position.left;s.offset.top=s.parentData.top+s.position.top;var k=Math.abs((s._helper?s.offset.left-d.left:(s.offset.left-d.left))+s.sizeDiff.width),r=Math.abs((s._helper?s.offset.top-d.top:(s.offset.top-n.top))+s.sizeDiff.height);var j=s.containerElement.get(0)==s.element.parent().get(0),i=/relative|absolute/.test(s.containerElement.css("position"));if(j&&i){k-=s.parentData.left}if(k+s.size.width>=s.parentData.width){s.size.width=s.parentData.width-k;if(q){s.size.height=s.size.width/s.aspectRatio}}if(r+s.size.height>=s.parentData.height){s.size.height=s.parentData.height-r;if(q){s.size.width=s.size.height*s.aspectRatio}}},stop:function(e,m){var p=c(this).data("resizable"),f=p.options,k=p.position,l=p.containerOffset,d=p.containerPosition,g=p.containerElement;var i=c(p.helper),q=i.offset(),n=i.outerWidth()-p.sizeDiff.width,j=i.outerHeight()-p.sizeDiff.height;if(p._helper&&!f.animate&&(/relative/).test(g.css("position"))){c(this).css({left:q.left-d.left-l.left,width:n,height:j})}if(p._helper&&!f.animate&&(/static/).test(g.css("position"))){c(this).css({left:q.left-d.left-l.left,width:n,height:j})}}});c.ui.plugin.add("resizable","ghost",{start:function(f,g){var d=c(this).data("resizable"),h=d.options,e=d.size;d.ghost=d.originalElement.clone();d.ghost.css({opacity:0.25,display:"block",position:"relative",height:e.height,width:e.width,margin:0,left:0,top:0}).addClass("ui-resizable-ghost").addClass(typeof h.ghost=="string"?h.ghost:"");d.ghost.appendTo(d.helper)},resize:function(e,f){var d=c(this).data("resizable"),g=d.options;if(d.ghost){d.ghost.css({position:"relative",height:d.size.height,width:d.size.width})}},stop:function(e,f){var d=c(this).data("resizable"),g=d.options;if(d.ghost&&d.helper){d.helper.get(0).removeChild(d.ghost.get(0))}}});c.ui.plugin.add("resizable","grid",{resize:function(d,l){var n=c(this).data("resizable"),g=n.options,j=n.size,h=n.originalSize,i=n.originalPosition,m=n.axis,k=g._aspectRatio||d.shiftKey;g.grid=typeof g.grid=="number"?[g.grid,g.grid]:g.grid;var f=Math.round((j.width-h.width)/(g.grid[0]||1))*(g.grid[0]||1),e=Math.round((j.height-h.height)/(g.grid[1]||1))*(g.grid[1]||1);if(/^(se|s|e)$/.test(m)){n.size.width=h.width+f;n.size.height=h.height+e}else{if(/^(ne)$/.test(m)){n.size.width=h.width+f;n.size.height=h.height+e;n.position.top=i.top-e}else{if(/^(sw)$/.test(m)){n.size.width=h.width+f;n.size.height=h.height+e;n.position.left=i.left-f}else{n.size.width=h.width+f;n.size.height=h.height+e;n.position.top=i.top-e;n.position.left=i.left-f}}}}});var b=function(d){return parseInt(d,10)||0};var a=function(d){return !isNaN(parseInt(d,10))}})(jQuery);;/*
+ * jQuery UI Selectable 1.7.2
+ * http://docs.jquery.com/UI/Selectables
+ * Depends:
+ * ui.core.js
+(function(a){a.widget("ui.selectable",a.extend({},a.ui.mouse,{_init:function(){var b=this;this.element.addClass("ui-selectable");this.dragged=false;var c;this.refresh=function(){c=a(b.options.filter,b.element[0]);c.each(function(){var d=a(this);var e=d.offset();a.data(this,"selectable-item",{element:this,$element:d,left:e.left,top:e.top,right:e.left+d.outerWidth(),bottom:e.top+d.outerHeight(),startselected:false,selected:d.hasClass("ui-selected"),selecting:d.hasClass("ui-selecting"),unselecting:d.hasClass("ui-unselecting")})})};this.refresh();this.selectees=c.addClass("ui-selectee");this._mouseInit();this.helper=a(document.createElement("div")).css({border:"1px dotted black"}).addClass("ui-selectable-helper")},destroy:function(){this.element.removeClass("ui-selectable ui-selectable-disabled").removeData("selectable").unbind(".selectable");this._mouseDestroy()},_mouseStart:function(d){var b=this;this.opos=[d.pageX,d.pageY];if(this.options.disabled){return}var c=this.options;this.selectees=a(c.filter,this.element[0]);this._trigger("start",d);a(c.appendTo).append(this.helper);this.helper.css({"z-index":100,position:"absolute",left:d.clientX,top:d.clientY,width:0,height:0});if(c.autoRefresh){this.refresh()}this.selectees.filter(".ui-selected").each(function(){var e=a.data(this,"selectable-item");e.startselected=true;if(!d.metaKey){e.$element.removeClass("ui-selected");e.selected=false;e.$element.addClass("ui-unselecting");e.unselecting=true;b._trigger("unselecting",d,{unselecting:e.element})}});a(d.target).parents().andSelf().each(function(){var e=a.data(this,"selectable-item");if(e){e.$element.removeClass("ui-unselecting").addClass("ui-selecting");e.unselecting=false;e.selecting=true;e.selected=true;b._trigger("selecting",d,{selecting:e.element});return false}})},_mouseDrag:function(i){var c=this;this.dragged=true;if(this.options.disabled){return}var e=this.options;var d=this.opos[0],h=this.opos[1],b=i.pageX,g=i.pageY;if(d>b){var f=b;b=d;d=f}if(h>g){var f=g;g=h;h=f}this.helper.css({left:d,top:h,width:b-d,height:g-h});this.selectees.each(function(){var j=a.data(this,"selectable-item");if(!j||j.element==c.element[0]){return}var k=false;if(e.tolerance=="touch"){k=(!(j.left>b||j.right<d||j.top>g||j.bottom<h))}else{if(e.tolerance=="fit"){k=(j.left>d&&j.right<b&&j.top>h&&j.bottom<g)}}if(k){if(j.selected){j.$element.removeClass("ui-selected");j.selected=false}if(j.unselecting){j.$element.removeClass("ui-unselecting");j.unselecting=false}if(!j.selecting){j.$element.addClass("ui-selecting");j.selecting=true;c._trigger("selecting",i,{selecting:j.element})}}else{if(j.selecting){if(i.metaKey&&j.startselected){j.$element.removeClass("ui-selecting");j.selecting=false;j.$element.addClass("ui-selected");j.selected=true}else{j.$element.removeClass("ui-selecting");j.selecting=false;if(j.startselected){j.$element.addClass("ui-unselecting");j.unselecting=true}c._trigger("unselecting",i,{unselecting:j.element})}}if(j.selected){if(!i.metaKey&&!j.startselected){j.$element.removeClass("ui-selected");j.selected=false;j.$element.addClass("ui-unselecting");j.unselecting=true;c._trigger("unselecting",i,{unselecting:j.element})}}}});return false},_mouseStop:function(d){var b=this;this.dragged=false;var c=this.options;a(".ui-unselecting",this.element[0]).each(function(){var e=a.data(this,"selectable-item");e.$element.removeClass("ui-unselecting");e.unselecting=false;e.startselected=false;b._trigger("unselected",d,{unselected:e.element})});a(".ui-selecting",this.element[0]).each(function(){var e=a.data(this,"selectable-item");e.$element.removeClass("ui-selecting").addClass("ui-selected");e.selecting=false;e.selected=true;e.startselected=true;b._trigger("selected",d,{selected:e.element})});this._trigger("stop",d);this.helper.remove();return false}}));a.extend(a.ui.selectable,{version:"1.7.2",defaults:{appendTo:"body",autoRefresh:true,cancel:":input,option",delay:0,distance:0,filter:"*",tolerance:"touch"}})})(jQuery);;/*
+ * jQuery UI Sortable 1.7.2
+ * http://docs.jquery.com/UI/Sortables
+ * Depends:
+ * ui.core.js
+(function(a){a.widget("ui.sortable",a.extend({},a.ui.mouse,{_init:function(){var b=this.options;this.containerCache={};this.element.addClass("ui-sortable");this.refresh();this.floating=this.items.length?(/left|right/).test(this.items[0].item.css("float")):false;this.offset=this.element.offset();this._mouseInit()},destroy:function(){this.element.removeClass("ui-sortable ui-sortable-disabled").removeData("sortable").unbind(".sortable");this._mouseDestroy();for(var b=this.items.length-1;b>=0;b--){this.items[b].item.removeData("sortable-item")}},_mouseCapture:function(e,f){if(this.reverting){return false}if(this.options.disabled||this.options.type=="static"){return false}this._refreshItems(e);var d=null,c=this,b=a(e.target).parents().each(function(){if(a.data(this,"sortable-item")==c){d=a(this);return false}});if(a.data(e.target,"sortable-item")==c){d=a(e.target)}if(!d){return false}if(this.options.handle&&!f){var g=false;a(this.options.handle,d).find("*").andSelf().each(function(){if(this==e.target){g=true}});if(!g){return false}}this.currentItem=d;this._removeCurrentsFromItems();return true},_mouseStart:function(e,f,b){var g=this.options,c=this;this.currentContainer=this;this.refreshPositions();this.helper=this._createHelper(e);this._cacheHelperProportions();this._cacheMargins();this.scrollParent=this.helper.scrollParent();this.offset=this.currentItem.offset();this.offset={top:this.offset.top-this.margins.top,left:this.offset.left-this.margins.left};this.helper.css("position","absolute");this.cssPosition=this.helper.css("position");a.extend(this.offset,{click:{left:e.pageX-this.offset.left,top:e.pageY-this.offset.top},parent:this._getParentOffset(),relative:this._getRelativeOffset()});this.originalPosition=this._generatePosition(e);this.originalPageX=e.pageX;this.originalPageY=e.pageY;if(g.cursorAt){this._adjustOffsetFromHelper(g.cursorAt)}this.domPosition={prev:this.currentItem.prev()[0],parent:this.currentItem.parent()[0]};if(this.helper[0]!=this.currentItem[0]){this.currentItem.hide()}this._createPlaceholder();if(g.containment){this._setContainment()}if(g.cursor){if(a("body").css("cursor")){this._storedCursor=a("body").css("cursor")}a("body").css("cursor",g.cursor)}if(g.opacity){if(this.helper.css("opacity")){this._storedOpacity=this.helper.css("opacity")}this.helper.css("opacity",g.opacity)}if(g.zIndex){if(this.helper.css("zIndex")){this._storedZIndex=this.helper.css("zIndex")}this.helper.css("zIndex",g.zIndex)}if(this.scrollParent[0]!=document&&this.scrollParent[0].tagName!="HTML"){this.overflowOffset=this.scrollParent.offset()}this._trigger("start",e,this._uiHash());if(!this._preserveHelperProportions){this._cacheHelperProportions()}if(!b){for(var d=this.containers.length-1;d>=0;d--){this.containers[d]._trigger("activate",e,c._uiHash(this))}}if(a.ui.ddmanager){a.ui.ddmanager.current=this}if(a.ui.ddmanager&&!g.dropBehaviour){a.ui.ddmanager.prepareOffsets(this,e)}this.dragging=true;this.helper.addClass("ui-sortable-helper");this._mouseDrag(e);return true},_mouseDrag:function(f){this.position=this._generatePosition(f);this.positionAbs=this._convertPositionTo("absolute");if(!this.lastPositionAbs){this.lastPositionAbs=this.positionAbs}if(this.options.scroll){var g=this.options,b=false;if(this.scrollParent[0]!=document&&this.scrollParent[0].tagName!="HTML"){if((this.overflowOffset.top+this.scrollParent[0].offsetHeight)-f.pageY<g.scrollSensitivity){this.scrollParent[0].scrollTop=b=this.scrollParent[0].scrollTop+g.scrollSpeed}else{if(f.pageY-this.overflowOffset.top<g.scrollSensitivity){this.scrollParent[0].scrollTop=b=this.scrollParent[0].scrollTop-g.scrollSpeed}}if((this.overflowOffset.left+this.scrollParent[0].offsetWidth)-f.pageX<g.scrollSensitivity){this.scrollParent[0].scrollLeft=b=this.scrollParent[0].scrollLeft+g.scrollSpeed}else{if(f.pageX-this.overflowOffset.left<g.scrollSensitivity){this.scrollParent[0].scrollLeft=b=this.scrollParent[0].scrollLeft-g.scrollSpeed}}}else{if(f.pageY-a(document).scrollTop()<g.scrollSensitivity){b=a(document).scrollTop(a(document).scrollTop()-g.scrollSpeed)}else{if(a(window).height()-(f.pageY-a(document).scrollTop())<g.scrollSensitivity){b=a(document).scrollTop(a(document).scrollTop()+g.scrollSpeed)}}if(f.pageX-a(document).scrollLeft()<g.scrollSensitivity){b=a(document).scrollLeft(a(document).scrollLeft()-g.scrollSpeed)}else{if(a(window).width()-(f.pageX-a(document).scrollLeft())<g.scrollSensitivity){b=a(document).scrollLeft(a(document).scrollLeft()+g.scrollSpeed)}}}if(b!==false&&a.ui.ddmanager&&!g.dropBehaviour){a.ui.ddmanager.prepareOffsets(this,f)}}this.positionAbs=this._convertPositionTo("absolute");if(!this.options.axis||this.options.axis!="y"){this.helper[0].style.left=this.position.left+"px"}if(!this.options.axis||this.options.axis!="x"){this.helper[0].style.top=this.position.top+"px"}for(var d=this.items.length-1;d>=0;d--){var e=this.items[d],c=e.item[0],h=this._intersectsWithPointer(e);if(!h){continue}if(c!=this.currentItem[0]&&this.placeholder[h==1?"next":"prev"]()[0]!=c&&!a.ui.contains(this.placeholder[0],c)&&(this.options.type=="semi-dynamic"?!a.ui.contains(this.element[0],c):true)){this.direction=h==1?"down":"up";if(this.options.tolerance=="pointer"||this._intersectsWithSides(e)){this._rearrange(f,e)}else{break}this._trigger("change",f,this._uiHash());break}}this._contactContainers(f);if(a.ui.ddmanager){a.ui.ddmanager.drag(this,f)}this._trigger("sort",f,this._uiHash());this.lastPositionAbs=this.positionAbs;return false},_mouseStop:function(c,d){if(!c){return}if(a.ui.ddmanager&&!this.options.dropBehaviour){a.ui.ddmanager.drop(this,c)}if(this.options.revert){var b=this;var e=b.placeholder.offset();b.reverting=true;a(this.helper).animate({left:e.left-this.offset.parent.left-b.margins.left+(this.offsetParent[0]==document.body?0:this.offsetParent[0].scrollLeft),top:e.top-this.offset.parent.top-b.margins.top+(this.offsetParent[0]==document.body?0:this.offsetParent[0].scrollTop)},parseInt(this.options.revert,10)||500,function(){b._clear(c)})}else{this._clear(c,d)}return false},cancel:function(){var b=this;if(this.dragging){this._mouseUp();if(this.options.helper=="original"){this.currentItem.css(this._storedCSS).removeClass("ui-sortable-helper")}else{this.currentItem.show()}for(var c=this.containers.length-1;c>=0;c--){this.containers[c]._trigger("deactivate",null,b._uiHash(this));if(this.containers[c].containerCache.over){this.containers[c]._trigger("out",null,b._uiHash(this));this.containers[c].containerCache.over=0}}}if(this.placeholder[0].parentNode){this.placeholder[0].parentNode.removeChild(this.placeholder[0])}if(this.options.helper!="original"&&this.helper&&this.helper[0].parentNode){this.helper.remove()}a.extend(this,{helper:null,dragging:false,reverting:false,_noFinalSort:null});if(this.domPosition.prev){a(this.domPosition.prev).after(this.currentItem)}else{a(this.domPosition.parent).prepend(this.currentItem)}return true},serialize:function(d){var b=this._getItemsAsjQuery(d&&d.connected);var c=[];d=d||{};a(b).each(function(){var e=(a(d.item||this).attr(d.attribute||"id")||"").match(d.expression||(/(.+)[-=_](.+)/));if(e){c.push((d.key||e[1]+"[]")+"="+(d.key&&d.expression?e[1]:e[2]))}});return c.join("&")},toArray:function(d){var b=this._getItemsAsjQuery(d&&d.connected);var c=[];d=d||{};b.each(function(){c.push(a(d.item||this).attr(d.attribute||"id")||"")});return c},_intersectsWith:function(m){var e=this.positionAbs.left,d=e+this.helperProportions.width,k=this.positionAbs.top,j=k+this.helperProportions.height;var f=m.left,c=f+m.width,n=m.top,i=n+m.height;var o=this.offset.click.top,h=this.offset.click.left;var g=(k+o)>n&&(k+o)<i&&(e+h)>f&&(e+h)<c;if(this.options.tolerance=="pointer"||this.options.forcePointerForContainers||(this.options.tolerance!="pointer"&&this.helperProportions[this.floating?"width":"height"]>m[this.floating?"width":"height"])){return g}else{return(f<e+(this.helperProportions.width/2)&&d-(this.helperProportions.width/2)<c&&n<k+(this.helperProportions.height/2)&&j-(this.helperProportions.height/2)<i)}},_intersectsWithPointer:function(d){var e=a.ui.isOverAxis(this.positionAbs.top+this.offset.click.top,d.top,d.height),c=a.ui.isOverAxis(this.positionAbs.left+this.offset.click.left,d.left,d.width),g=e&&c,b=this._getDragVerticalDirection(),f=this._getDragHorizontalDirection();if(!g){return false}return this.floating?(((f&&f=="right")||b=="down")?2:1):(b&&(b=="down"?2:1))},_intersectsWithSides:function(e){var c=a.ui.isOverAxis(this.positionAbs.top+this.offset.click.top,e.top+(e.height/2),e.height),d=a.ui.isOverAxis(this.positionAbs.left+this.offset.click.left,e.left+(e.width/2),e.width),b=this._getDragVerticalDirection(),f=this._getDragHorizontalDirection();if(this.floating&&f){return((f=="right"&&d)||(f=="left"&&!d))}else{return b&&((b=="down"&&c)||(b=="up"&&!c))}},_getDragVerticalDirection:function(){var b=this.positionAbs.top-this.lastPositionAbs.top;return b!=0&&(b>0?"down":"up")},_getDragHorizontalDirection:function(){var b=this.positionAbs.left-this.lastPositionAbs.left;return b!=0&&(b>0?"right":"left")},refresh:function(b){this._refreshItems(b);this.refreshPositions()},_connectWith:function(){var b=this.options;return b.connectWith.constructor==String?[b.connectWith]:b.connectWith},_getItemsAsjQuery:function(b){var l=this;var g=[];var e=[];var h=this._connectWith();if(h&&b){for(var d=h.length-1;d>=0;d--){var k=a(h[d]);for(var c=k.length-1;c>=0;c--){var f=a.data(k[c],"sortable");if(f&&f!=this&&!f.options.disabled){e.push([a.isFunction(f.options.items)?f.options.items.call(f.element):a(f.options.items,f.element).not(".ui-sortable-helper"),f])}}}}e.push([a.isFunction(this.options.items)?this.options.items.call(this.element,null,{options:this.options,item:this.currentItem}):a(this.options.items,this.element).not(".ui-sortable-helper"),this]);for(var d=e.length-1;d>=0;d--){e[d][0].each(function(){g.push(this)})}return a(g)},_removeCurrentsFromItems:function(){var d=this.currentItem.find(":data(sortable-item)");for(var c=0;c<this.items.length;c++){for(var b=0;b<d.length;b++){if(d[b]==this.items[c].item[0]){this.items.splice(c,1)}}}},_refreshItems:function(b){this.items=[];this.containers=[this];var h=this.items;var p=this;var f=[[a.isFunction(this.options.items)?this.options.items.call(this.element[0],b,{item:this.currentItem}):a(this.options.items,this.element),this]];var l=this._connectWith();if(l){for(var e=l.length-1;e>=0;e--){var m=a(l[e]);for(var d=m.length-1;d>=0;d--){var g=a.data(m[d],"sortable");if(g&&g!=this&&!g.options.disabled){f.push([a.isFunction(g.options.items)?g.options.items.call(g.element[0],b,{item:this.currentItem}):a(g.options.items,g.element),g]);this.containers.push(g)}}}}for(var e=f.length-1;e>=0;e--){var k=f[e][1];var c=f[e][0];for(var d=0,n=c.length;d<n;d++){var o=a(c[d]);o.data("sortable-item",k);h.push({item:o,instance:k,width:0,height:0,left:0,top:0})}}},refreshPositions:function(b){if(this.offsetParent&&this.helper){this.offset.parent=this._getParentOffset()}for(var d=this.items.length-1;d>=0;d--){var e=this.items[d];if(e.instance!=this.currentContainer&&this.currentContainer&&e.item[0]!=this.currentItem[0]){continue}var c=this.options.toleranceElement?a(this.options.toleranceElement,e.item):e.item;if(!b){e.width=c.outerWidth();e.height=c.outerHeight()}var f=c.offset();e.left=f.left;e.top=f.top}if(this.options.custom&&this.options.custom.refreshContainers){this.options.custom.refreshContainers.call(this)}else{for(var d=this.containers.length-1;d>=0;d--){var f=this.containers[d].element.offset();this.containers[d].containerCache.left=f.left;this.containers[d].containerCache.top=f.top;this.containers[d].containerCache.width=this.containers[d].element.outerWidth();this.containers[d].containerCache.height=this.containers[d].element.outerHeight()}}},_createPlaceholder:function(d){var b=d||this,e=b.options;if(!e.placeholder||e.placeholder.constructor==String){var c=e.placeholder;e.placeholder={element:function(){var f=a(document.createElement(b.currentItem[0].nodeName)).addClass(c||b.currentItem[0].className+" ui-sortable-placeholder").removeClass("ui-sortable-helper")[0];if(!c){f.style.visibility="hidden"}return f},update:function(f,g){if(c&&!e.forcePlaceholderSize){return}if(!g.height()){g.height(b.currentItem.innerHeight()-parseInt(b.currentItem.css("paddingTop")||0,10)-parseInt(b.currentItem.css("paddingBottom")||0,10))}if(!g.width()){g.width(b.currentItem.innerWidth()-parseInt(b.currentItem.css("paddingLeft")||0,10)-parseInt(b.currentItem.css("paddingRight")||0,10))}}}}b.placeholder=a(e.placeholder.element.call(b.element,b.currentItem));b.currentItem.after(b.placeholder);e.placeholder.update(b,b.placeholder)},_contactContainers:function(d){for(var c=this.containers.length-1;c>=0;c--){if(this._intersectsWith(this.containers[c].containerCache)){if(!this.containers[c].containerCache.over){if(this.currentContainer!=this.containers[c]){var h=10000;var g=null;var e=this.positionAbs[this.containers[c].floating?"left":"top"];for(var b=this.items.length-1;b>=0;b--){if(!a.ui.contains(this.containers[c].element[0],this.items[b].item[0])){continue}var f=this.items[b][this.containers[c].floating?"left":"top"];if(Math.abs(f-e)<h){h=Math.abs(f-e);g=this.items[b]}}if(!g&&!this.options.dropOnEmpty){continue}this.currentContainer=this.containers[c];g?this._rearrange(d,g,null,true):this._rearrange(d,null,this.containers[c].element,true);this._trigger("change",d,this._uiHash());this.containers[c]._trigger("change",d,this._uiHash(this));this.options.placeholder.update(this.currentContainer,this.placeholder)}this.containers[c]._trigger("over",d,this._uiHash(this));this.containers[c].containerCache.over=1}}else{if(this.containers[c].containerCache.over){this.containers[c]._trigger("out",d,this._uiHash(this));this.containers[c].containerCache.over=0}}}},_createHelper:function(c){var d=this.options;var b=a.isFunction(d.helper)?a(d.helper.apply(this.element[0],[c,this.currentItem])):(d.helper=="clone"?this.currentItem.clone():this.currentItem);if(!b.parents("body").length){a(d.appendTo!="parent"?d.appendTo:this.currentItem[0].parentNode)[0].appendChild(b[0])}if(b[0]==this.currentItem[0]){this._storedCSS={width:this.currentItem[0].style.width,height:this.currentItem[0].style.height,position:this.currentItem.css("position"),top:this.currentItem.css("top"),left:this.currentItem.css("left")}}if(b[0].style.width==""||d.forceHelperSize){b.width(this.currentItem.width())}if(b[0].style.height==""||d.forceHelperSize){b.height(this.currentItem.height())}return b},_adjustOffsetFromHelper:function(b){if(b.left!=undefined){this.offset.click.left=b.left+this.margins.left}if(b.right!=undefined){this.offset.click.left=this.helperProportions.width-b.right+this.margins.left}if(b.top!=undefined){this.offset.click.top=b.top+this.margins.top}if(b.bottom!=undefined){this.offset.click.top=this.helperProportions.height-b.bottom+this.margins.top}},_getParentOffset:function(){this.offsetParent=this.helper.offsetParent();var b=this.offsetParent.offset();if(this.cssPosition=="absolute"&&this.scrollParent[0]!=document&&a.ui.contains(this.scrollParent[0],this.offsetParent[0])){b.left+=this.scrollParent.scrollLeft();b.top+=this.scrollParent.scrollTop()}if((this.offsetParent[0]==document.body)||(this.offsetParent[0].tagName&&this.offsetParent[0].tagName.toLowerCase()=="html"&&a.browser.msie)){b={top:0,left:0}}return{top:b.top+(parseInt(this.offsetParent.css("borderTopWidth"),10)||0),left:b.left+(parseInt(this.offsetParent.css("borderLeftWidth"),10)||0)}},_getRelativeOffset:function(){if(this.cssPosition=="relative"){var b=this.currentItem.position();return{top:b.top-(parseInt(this.helper.css("top"),10)||0)+this.scrollParent.scrollTop(),left:b.left-(parseInt(this.helper.css("left"),10)||0)+this.scrollParent.scrollLeft()}}else{return{top:0,left:0}}},_cacheMargins:function(){this.margins={left:(parseInt(this.currentItem.css("marginLeft"),10)||0),top:(parseInt(this.currentItem.css("marginTop"),10)||0)}},_cacheHelperProportions:function(){this.helperProportions={width:this.helper.outerWidth(),height:this.helper.outerHeight()}},_setContainment:function(){var e=this.options;if(e.containment=="parent"){e.containment=this.helper[0].parentNode}if(e.containment=="document"||e.containment=="window"){this.containment=[0-this.offset.relative.left-this.offset.parent.left,0-this.offset.relative.top-this.offset.parent.top,a(e.containment=="document"?document:window).width()-this.helperProportions.width-this.margins.left,(a(e.containment=="document"?document:window).height()||document.body.parentNode.scrollHeight)-this.helperProportions.height-this.margins.top]}if(!(/^(document|window|parent)$/).test(e.containment)){var c=a(e.containment)[0];var d=a(e.containment).offset();var b=(a(c).css("overflow")!="hidden");this.containment=[d.left+(parseInt(a(c).css("borderLeftWidth"),10)||0)+(parseInt(a(c).css("paddingLeft"),10)||0)-this.margins.left,d.top+(parseInt(a(c).css("borderTopWidth"),10)||0)+(parseInt(a(c).css("paddingTop"),10)||0)-this.margins.top,d.left+(b?Math.max(c.scrollWidth,c.offsetWidth):c.offsetWidth)-(parseInt(a(c).css("borderLeftWidth"),10)||0)-(parseInt(a(c).css("paddingRight"),10)||0)-this.helperProportions.width-this.margins.left,d.top+(b?Math.max(c.scrollHeight,c.offsetHeight):c.offsetHeight)-(parseInt(a(c).css("borderTopWidth"),10)||0)-(parseInt(a(c).css("paddingBottom"),10)||0)-this.helperProportions.height-this.margins.top]}},_convertPositionTo:function(f,h){if(!h){h=this.position}var c=f=="absolute"?1:-1;var e=this.options,b=this.cssPosition=="absolute"&&!(this.scrollParent[0]!=document&&a.ui.contains(this.scrollParent[0],this.offsetParent[0]))?this.offsetParent:this.scrollParent,g=(/(html|body)/i).test(b[0].tagName);return{top:(h.top+this.offset.relative.top*c+this.offset.parent.top*c-(a.browser.safari&&this.cssPosition=="fixed"?0:(this.cssPosition=="fixed"?-this.scrollParent.scrollTop():(g?0:b.scrollTop()))*c)),left:(h.left+this.offset.relative.left*c+this.offset.parent.left*c-(a.browser.safari&&this.cssPosition=="fixed"?0:(this.cssPosition=="fixed"?-this.scrollParent.scrollLeft():g?0:b.scrollLeft())*c))}},_generatePosition:function(e){var h=this.options,b=this.cssPosition=="absolute"&&!(this.scrollParent[0]!=document&&a.ui.contains(this.scrollParent[0],this.offsetParent[0]))?this.offsetParent:this.scrollParent,i=(/(html|body)/i).test(b[0].tagName);if(this.cssPosition=="relative"&&!(this.scrollParent[0]!=document&&this.scrollParent[0]!=this.offsetParent[0])){this.offset.relative=this._getRelativeOffset()}var d=e.pageX;var c=e.pageY;if(this.originalPosition){if(this.containment){if(e.pageX-this.offset.click.left<this.containment[0]){d=this.containment[0]+this.offset.click.left}if(e.pageY-this.offset.click.top<this.containment[1]){c=this.containment[1]+this.offset.click.top}if(e.pageX-this.offset.click.left>this.containment[2]){d=this.containment[2]+this.offset.click.left}if(e.pageY-this.offset.click.top>this.containment[3]){c=this.containment[3]+this.offset.click.top}}if(h.grid){var g=this.originalPageY+Math.round((c-this.originalPageY)/h.grid[1])*h.grid[1];c=this.containment?(!(g-this.offset.click.top<this.containment[1]||g-this.offset.click.top>this.containment[3])?g:(!(g-this.offset.click.top<this.containment[1])?g-h.grid[1]:g+h.grid[1])):g;var f=this.originalPageX+Math.round((d-this.originalPageX)/h.grid[0])*h.grid[0];d=this.containment?(!(f-this.offset.click.left<this.containment[0]||f-this.offset.click.left>this.containment[2])?f:(!(f-this.offset.click.left<this.containment[0])?f-h.grid[0]:f+h.grid[0])):f}}return{top:(c-this.offset.click.top-this.offset.relative.top-this.offset.parent.top+(a.browser.safari&&this.cssPosition=="fixed"?0:(this.cssPosition=="fixed"?-this.scrollParent.scrollTop():(i?0:b.scrollTop())))),left:(d-this.offset.click.left-this.offset.relative.left-this.offset.parent.left+(a.browser.safari&&this.cssPosition=="fixed"?0:(this.cssPosition=="fixed"?-this.scrollParent.scrollLeft():i?0:b.scrollLeft())))}},_rearrange:function(g,f,c,e){c?c[0].appendChild(this.placeholder[0]):f.item[0].parentNode.insertBefore(this.placeholder[0],(this.direction=="down"?f.item[0]:f.item[0].nextSibling));this.counter=this.counter?++this.counter:1;var d=this,b=this.counter;window.setTimeout(function(){if(b==d.counter){d.refreshPositions(!e)}},0)},_clear:function(d,e){this.reverting=false;var f=[],b=this;if(!this._noFinalSort&&this.currentItem[0].parentNode){this.placeholder.before(this.currentItem)}this._noFinalSort=null;if(this.helper[0]==this.currentItem[0]){for(var c in this._storedCSS){if(this._storedCSS[c]=="auto"||this._storedCSS[c]=="static"){this._storedCSS[c]=""}}this.currentItem.css(this._storedCSS).removeClass("ui-sortable-helper")}else{this.currentItem.show()}if(this.fromOutside&&!e){f.push(function(g){this._trigger("receive",g,this._uiHash(this.fromOutside))})}if((this.fromOutside||this.domPosition.prev!=this.currentItem.prev().not(".ui-sortable-helper")[0]||this.domPosition.parent!=this.currentItem.parent()[0])&&!e){f.push(function(g){this._trigger("update",g,this._uiHash())})}if(!a.ui.contains(this.element[0],this.currentItem[0])){if(!e){f.push(function(g){this._trigger("remove",g,this._uiHash())})}for(var c=this.containers.length-1;c>=0;c--){if(a.ui.contains(this.containers[c].element[0],this.currentItem[0])&&!e){f.push((function(g){return function(h){g._trigger("receive",h,this._uiHash(this))}}).call(this,this.containers[c]));f.push((function(g){return function(h){g._trigger("update",h,this._uiHash(this))}}).call(this,this.containers[c]))}}}for(var c=this.containers.length-1;c>=0;c--){if(!e){f.push((function(g){return function(h){g._trigger("deactivate",h,this._uiHash(this))}}).call(this,this.containers[c]))}if(this.containers[c].containerCache.over){f.push((function(g){return function(h){g._trigger("out",h,this._uiHash(this))}}).call(this,this.containers[c]));this.containers[c].containerCache.over=0}}if(this._storedCursor){a("body").css("cursor",this._storedCursor)}if(this._storedOpacity){this.helper.css("opacity",this._storedOpacity)}if(this._storedZIndex){this.helper.css("zIndex",this._storedZIndex=="auto"?"":this._storedZIndex)}this.dragging=false;if(this.cancelHelperRemoval){if(!e){this._trigger("beforeStop",d,this._uiHash());for(var c=0;c<f.length;c++){f[c].call(this,d)}this._trigger("stop",d,this._uiHash())}return false}if(!e){this._trigger("beforeStop",d,this._uiHash())}this.placeholder[0].parentNode.removeChild(this.placeholder[0]);if(this.helper[0]!=this.currentItem[0]){this.helper.remove()}this.helper=null;if(!e){for(var c=0;c<f.length;c++){f[c].call(this,d)}this._trigger("stop",d,this._uiHash())}this.fromOutside=false;return true},_trigger:function(){if(a.widget.prototype._trigger.apply(this,arguments)===false){this.cancel()}},_uiHash:function(c){var b=c||this;return{helper:b.helper,placeholder:b.placeholder||a([]),position:b.position,absolutePosition:b.positionAbs,offset:b.positionAbs,item:b.currentItem,sender:c?c.element:null}}}));a.extend(a.ui.sortable,{getter:"serialize toArray",version:"1.7.2",eventPrefix:"sort",defaults:{appendTo:"parent",axis:false,cancel:":input,option",connectWith:false,containment:false,cursor:"auto",cursorAt:false,delay:0,distance:1,dropOnEmpty:true,forcePlaceholderSize:false,forceHelperSize:false,grid:false,handle:false,helper:"original",items:"> *",opacity:false,placeholder:false,revert:false,scroll:true,scrollSensitivity:20,scrollSpeed:20,scope:"default",tolerance:"intersect",zIndex:1000}})})(jQuery);;/*
+ * jQuery UI Accordion 1.7.2
+ * Copyright (c) 2009 AUTHORS.txt (http://jqueryui.com/about)
+ * Dual licensed under the MIT (MIT-LICENSE.txt)
+ * and GPL (GPL-LICENSE.txt) licenses.
+ * http://docs.jquery.com/UI/Accordion
+ * Depends:
+ * ui.core.js
+(function(a){a.widget("ui.accordion",{_init:function(){var d=this.options,b=this;this.running=0;if(d.collapsible==a.ui.accordion.defaults.collapsible&&d.alwaysOpen!=a.ui.accordion.defaults.alwaysOpen){d.collapsible=!d.alwaysOpen}if(d.navigation){var c=this.element.find("a").filter(d.navigationFilter);if(c.length){if(c.filter(d.header).length){this.active=c}else{this.active=c.parent().parent().prev();c.addClass("ui-accordion-content-active")}}}this.element.addClass("ui-accordion ui-widget ui-helper-reset");if(this.element[0].nodeName=="UL"){this.element.children("li").addClass("ui-accordion-li-fix")}this.headers=this.element.find(d.header).addClass("ui-accordion-header ui-helper-reset ui-state-default ui-corner-all").bind("mouseenter.accordion",function(){a(this).addClass("ui-state-hover")}).bind("mouseleave.accordion",function(){a(this).removeClass("ui-state-hover")}).bind("focus.accordion",function(){a(this).addClass("ui-state-focus")}).bind("blur.accordion",function(){a(this).removeClass("ui-state-focus")});this.headers.next().addClass("ui-accordion-content ui-helper-reset ui-widget-content ui-corner-bottom");this.active=this._findActive(this.active||d.active).toggleClass("ui-state-default").toggleClass("ui-state-active").toggleClass("ui-corner-all").toggleClass("ui-corner-top");this.active.next().addClass("ui-accordion-content-active");a("<span/>").addClass("ui-icon "+d.icons.header).prependTo(this.headers);this.active.find(".ui-icon").toggleClass(d.icons.header).toggleClass(d.icons.headerSelected);if(a.browser.msie){this.element.find("a").css("zoom","1")}this.resize();this.element.attr("role","tablist");this.headers.attr("role","tab").bind("keydown",function(e){return b._keydown(e)}).next().attr("role","tabpanel");this.headers.not(this.active||"").attr("aria-expanded","false").attr("tabIndex","-1").next().hide();if(!this.active.length){this.headers.eq(0).attr("tabIndex","0")}else{this.active.attr("aria-expanded","true").attr("tabIndex","0")}if(!a.browser.safari){this.headers.find("a").attr("tabIndex","-1")}if(d.event){this.headers.bind((d.event)+".accordion",function(e){return b._clickHandler.call(b,e,this)})}},destroy:function(){var c=this.options;this.element.removeClass("ui-accordion ui-widget ui-helper-reset").removeAttr("role").unbind(".accordion").removeData("accordion");this.headers.unbind(".accordion").removeClass("ui-accordion-header ui-helper-reset ui-state-default ui-corner-all ui-state-active ui-corner-top").removeAttr("role").removeAttr("aria-expanded").removeAttr("tabindex");this.headers.find("a").removeAttr("tabindex");this.headers.children(".ui-icon").remove();var b=this.headers.next().css("display","").removeAttr("role").removeClass("ui-helper-reset ui-widget-content ui-corner-bottom ui-accordion-content ui-accordion-content-active");if(c.autoHeight||c.fillHeight){b.css("height","")}},_setData:function(b,c){if(b=="alwaysOpen"){b="collapsible";c=!c}a.widget.prototype._setData.apply(this,arguments)},_keydown:function(e){var g=this.options,f=a.ui.keyCode;if(g.disabled||e.altKey||e.ctrlKey){return}var d=this.headers.length;var b=this.headers.index(e.target);var c=false;switch(e.keyCode){case f.RIGHT:case f.DOWN:c=this.headers[(b+1)%d];break;case f.LEFT:case f.UP:c=this.headers[(b-1+d)%d];break;case f.SPACE:case f.ENTER:return this._clickHandler({target:e.target},e.target)}if(c){a(e.target).attr("tabIndex","-1");a(c).attr("tabIndex","0");c.focus();return false}return true},resize:function(){var e=this.options,d;if(e.fillSpace){if(a.browser.msie){var b=this.element.parent().css("overflow");this.element.parent().css("overflow","hidden")}d=this.element.parent().height();if(a.browser.msie){this.element.parent().css("overflow",b)}this.headers.each(function(){d-=a(this).outerHeight()});var c=0;this.headers.next().each(function(){c=Math.max(c,a(this).innerHeight()-a(this).height())}).height(Math.max(0,d-c)).css("overflow","auto")}else{if(e.autoHeight){d=0;this.headers.next().each(function(){d=Math.max(d,a(this).outerHeight())}).height(d)}}},activate:function(b){var c=this._findActive(b)[0];this._clickHandler({target:c},c)},_findActive:function(b){return b?typeof b=="number"?this.headers.filter(":eq("+b+")"):this.headers.not(this.headers.not(b)):b===false?a([]):this.headers.filter(":eq(0)")},_clickHandler:function(b,f){var d=this.options;if(d.disabled){return false}if(!b.target&&d.collapsible){this.active.removeClass("ui-state-active ui-corner-top").addClass("ui-state-default ui-corner-all").find(".ui-icon").removeClass(d.icons.headerSelected).addClass(d.icons.header);this.active.next().addClass("ui-accordion-content-active");var h=this.active.next(),e={options:d,newHeader:a([]),oldHeader:d.active,newContent:a([]),oldContent:h},c=(this.active=a([]));this._toggle(c,h,e);return false}var g=a(b.currentTarget||f);var i=g[0]==this.active[0];if(this.running||(!d.collapsible&&i)){return false}this.active.removeClass("ui-state-active ui-corner-top").addClass("ui-state-default ui-corner-all").find(".ui-icon").removeClass(d.icons.headerSelected).addClass(d.icons.header);this.active.next().addClass("ui-accordion-content-active");if(!i){g.removeClass("ui-state-default ui-corner-all").addClass("ui-state-active ui-corner-top").find(".ui-icon").removeClass(d.icons.header).addClass(d.icons.headerSelected);g.next().addClass("ui-accordion-content-active")}var c=g.next(),h=this.active.next(),e={options:d,newHeader:i&&d.collapsible?a([]):g,oldHeader:this.active,newContent:i&&d.collapsible?a([]):c.find("> *"),oldContent:h.find("> *")},j=this.headers.index(this.active[0])>this.headers.index(g[0]);this.active=i?a([]):g;this._toggle(c,h,e,i,j);return false},_toggle:function(b,i,g,j,k){var d=this.options,m=this;this.toShow=b;this.toHide=i;this.data=g;var c=function(){if(!m){return}return m._completed.apply(m,arguments)};this._trigger("changestart",null,this.data);this.running=i.size()===0?b.size():i.size();if(d.animated){var f={};if(d.collapsible&&j){f={toShow:a([]),toHide:i,complete:c,down:k,autoHeight:d.autoHeight||d.fillSpace}}else{f={toShow:b,toHide:i,complete:c,down:k,autoHeight:d.autoHeight||d.fillSpace}}if(!d.proxied){d.proxied=d.animated}if(!d.proxiedDuration){d.proxiedDuration=d.duration}d.animated=a.isFunction(d.proxied)?d.proxied(f):d.proxied;d.duration=a.isFunction(d.proxiedDuration)?d.proxiedDuration(f):d.proxiedDuration;var l=a.ui.accordion.animations,e=d.duration,h=d.animated;if(!l[h]){l[h]=function(n){this.slide(n,{easing:h,duration:e||700})}}l[h](f)}else{if(d.collapsible&&j){b.toggle()}else{i.hide();b.show()}c(true)}i.prev().attr("aria-expanded","false").attr("tabIndex","-1").blur();b.prev().attr("aria-expanded","true").attr("tabIndex","0").focus()},_completed:function(b){var c=this.options;this.running=b?0:--this.running;if(this.running){return}if(c.clearStyle){this.toShow.add(this.toHide).css({height:"",overflow:""})}this._trigger("change",null,this.data)}});a.extend(a.ui.accordion,{version:"1.7.2",defaults:{active:null,alwaysOpen:true,animated:"slide",autoHeight:true,clearStyle:false,collapsible:false,event:"click",fillSpace:false,header:"> li > :first-child,> :not(li):even",icons:{header:"ui-icon-triangle-1-e",headerSelected:"ui-icon-triangle-1-s"},navigation:false,navigationFilter:function(){return this.href.toLowerCase()==location.href.toLowerCase()}},animations:{slide:function(j,h){j=a.extend({easing:"swing",duration:300},j,h);if(!j.toHide.size()){j.toShow.animate({height:"show"},j);return}if(!j.toShow.size()){j.toHide.animate({height:"hide"},j);return}var c=j.toShow.css("overflow"),g,d={},f={},e=["height","paddingTop","paddingBottom"],b;var i=j.toShow;b=i[0].style.width;i.width(parseInt(i.parent().width(),10)-parseInt(i.css("paddingLeft"),10)-parseInt(i.css("paddingRight"),10)-(parseInt(i.css("borderLeftWidth"),10)||0)-(parseInt(i.css("borderRightWidth"),10)||0));a.each(e,function(k,m){f[m]="hide";var l=(""+a.css(j.toShow[0],m)).match(/^([\d+-.]+)(.*)$/);d[m]={value:l[1],unit:l[2]||"px"}});j.toShow.css({height:0,overflow:"hidden"}).show();j.toHide.filter(":hidden").each(j.complete).end().filter(":visible").animate(f,{step:function(k,l){if(l.prop=="height"){g=(l.now-l.start)/(l.end-l.start)}j.toShow[0].style[l.prop]=(g*d[l.prop].value)+d[l.prop].unit},duration:j.duration,easing:j.easing,complete:function(){if(!j.autoHeight){j.toShow.css("height","")}j.toShow.css("width",b);j.toShow.css({overflow:c});j.complete()}})},bounceslide:function(b){this.slide(b,{easing:b.down?"easeOutBounce":"swing",duration:b.down?1000:200})},easeslide:function(b){this.slide(b,{easing:"easeinout",duration:700})}}})})(jQuery);;/*
+ * jQuery UI Dialog 1.7.2
+ * http://docs.jquery.com/UI/Dialog
+ * Depends:
+ * ui.core.js
+ * ui.draggable.js
+ * ui.resizable.js
+(function(c){var b={dragStart:"start.draggable",drag:"drag.draggable",dragStop:"stop.draggable",maxHeight:"maxHeight.resizable",minHeight:"minHeight.resizable",maxWidth:"maxWidth.resizable",minWidth:"minWidth.resizable",resizeStart:"start.resizable",resize:"drag.resizable",resizeStop:"stop.resizable"},a="ui-dialog ui-widget ui-widget-content ui-corner-all ";c.widget("ui.dialog",{_init:function(){this.originalTitle=this.element.attr("title");var l=this,m=this.options,j=m.title||this.originalTitle||" ",e=c.ui.dialog.getTitleId(this.element),k=(this.uiDialog=c("<div/>")).appendTo(document.body).hide().addClass(a+m.dialogClass).css({position:"absolute",overflow:"hidden",zIndex:m.zIndex}).attr("tabIndex",-1).css("outline",0).keydown(function(n){(m.closeOnEscape&&n.keyCode&&n.keyCode==c.ui.keyCode.ESCAPE&&l.close(n))}).attr({role:"dialog","aria-labelledby":e}).mousedown(function(n){l.moveToTop(false,n)}),g=this.element.show().removeAttr("title").addClass("ui-dialog-content ui-widget-content").appendTo(k),f=(this.uiDialogTitlebar=c("<div></div>")).addClass("ui-dialog-titlebar ui-widget-header ui-corner-all ui-helper-clearfix").prependTo(k),i=c('<a href="#"/>').addClass("ui-dialog-titlebar-close ui-corner-all").attr("role","button").hover(function(){i.addClass("ui-state-hover")},function(){i.removeClass("ui-state-hover")}).focus(function(){i.addClass("ui-state-focus")}).blur(function(){i.removeClass("ui-state-focus")}).mousedown(function(n){n.stopPropagation()}).click(function(n){l.close(n);return false}).appendTo(f),h=(this.uiDialogTitlebarCloseText=c("<span/>")).addClass("ui-icon ui-icon-closethick").text(m.closeText).appendTo(i),d=c("<span/>").addClass("ui-dialog-title").attr("id",e).html(j).prependTo(f);f.find("*").add(f).disableSelection();(m.draggable&&c.fn.draggable&&this._makeDraggable());(m.resizable&&c.fn.resizable&&this._makeResizable());this._createButtons(m.buttons);this._isOpen=false;(m.bgiframe&&c.fn.bgiframe&&k.bgiframe());(m.autoOpen&&this.open())},destroy:function(){(this.overlay&&this.overlay.destroy());this.uiDialog.hide();this.element.unbind(".dialog").removeData("dialog").removeClass("ui-dialog-content ui-widget-content").hide().appendTo("body");this.uiDialog.remove();(this.originalTitle&&this.element.attr("title",this.originalTitle))},close:function(f){var d=this;if(false===d._trigger("beforeclose",f)){return}(d.overlay&&d.overlay.destroy());d.uiDialog.unbind("keypress.ui-dialog");(d.options.hide?d.uiDialog.hide(d.options.hide,function(){d._trigger("close",f)}):d.uiDialog.hide()&&d._trigger("close",f));c.ui.dialog.overlay.resize();d._isOpen=false;if(d.options.modal){var e=0;c(".ui-dialog").each(function(){if(this!=d.uiDialog[0]){e=Math.max(e,c(this).css("z-index"))}});c.ui.dialog.maxZ=e}},isOpen:function(){return this._isOpen},moveToTop:function(f,e){if((this.options.modal&&!f)||(!this.options.stack&&!this.options.modal)){return this._trigger("focus",e)}if(this.options.zIndex>c.ui.dialog.maxZ){c.ui.dialog.maxZ=this.options.zIndex}(this.overlay&&this.overlay.$el.css("z-index",c.ui.dialog.overlay.maxZ=++c.ui.dialog.maxZ));var d={scrollTop:this.element.attr("scrollTop"),scrollLeft:this.element.attr("scrollLeft")};this.uiDialog.css("z-index",++c.ui.dialog.maxZ);this.element.attr(d);this._trigger("focus",e)},open:function(){if(this._isOpen){return}var e=this.options,d=this.uiDialog;this.overlay=e.modal?new c.ui.dialog.overlay(this):null;(d.next().length&&d.appendTo("body"));this._size();this._position(e.position);d.show(e.show);this.moveToTop(true);(e.modal&&d.bind("keypress.ui-dialog",function(h){if(h.keyCode!=c.ui.keyCode.TAB){return}var g=c(":tabbable",this),i=g.filter(":first")[0],f=g.filter(":last")[0];if(h.target==f&&!h.shiftKey){setTimeout(function(){i.focus()},1)}else{if(h.target==i&&h.shiftKey){setTimeout(function(){f.focus()},1)}}}));c([]).add(d.find(".ui-dialog-content :tabbable:first")).add(d.find(".ui-dialog-buttonpane :tabbable:first")).add(d).filter(":first").focus();this._trigger("open");this._isOpen=true},_createButtons:function(g){var f=this,d=false,e=c("<div></div>").addClass("ui-dialog-buttonpane ui-widget-content ui-helper-clearfix");this.uiDialog.find(".ui-dialog-buttonpane").remove();(typeof g=="object"&&g!==null&&c.each(g,function(){return !(d=true)}));if(d){c.each(g,function(h,i){c('<button type="button"></button>').addClass("ui-state-default ui-corner-all").text(h).click(function(){i.apply(f.element[0],arguments)}).hover(function(){c(this).addClass("ui-state-hover")},function(){c(this).removeClass("ui-state-hover")}).focus(function(){c(this).addClass("ui-state-focus")}).blur(function(){c(this).removeClass("ui-state-focus")}).appendTo(e)});e.appendTo(this.uiDialog)}},_makeDraggable:function(){var d=this,f=this.options,e;this.uiDialog.draggable({cancel:".ui-dialog-content",handle:".ui-dialog-titlebar",containment:"document",start:function(){e=f.height;c(this).height(c(this).height()).addClass("ui-dialog-dragging");(f.dragStart&&f.dragStart.apply(d.element[0],arguments))},drag:function(){(f.drag&&f.drag.apply(d.element[0],arguments))},stop:function(){c(this).removeClass("ui-dialog-dragging").height(e);(f.dragStop&&f.dragStop.apply(d.element[0],arguments));c.ui.dialog.overlay.resize()}})},_makeResizable:function(g){g=(g===undefined?this.options.resizable:g);var d=this,f=this.options,e=typeof g=="string"?g:"n,e,s,w,se,sw,ne,nw";this.uiDialog.resizable({cancel:".ui-dialog-content",alsoResize:this.element,maxWidth:f.maxWidth,maxHeight:f.maxHeight,minWidth:f.minWidth,minHeight:f.minHeight,start:function(){c(this).addClass("ui-dialog-resizing");(f.resizeStart&&f.resizeStart.apply(d.element[0],arguments))},resize:function(){(f.resize&&f.resize.apply(d.element[0],arguments))},handles:e,stop:function(){c(this).removeClass("ui-dialog-resizing");f.height=c(this).height();f.width=c(this).width();(f.resizeStop&&f.resizeStop.apply(d.element[0],arguments));c.ui.dialog.overlay.resize()}}).find(".ui-resizable-se").addClass("ui-icon ui-icon-grip-diagonal-se")},_position:function(i){var e=c(window),f=c(document),g=f.scrollTop(),d=f.scrollLeft(),h=g;if(c.inArray(i,["center","top","right","bottom","left"])>=0){i=[i=="right"||i=="left"?i:"center",i=="top"||i=="bottom"?i:"middle"]}if(i.constructor!=Array){i=["center","middle"]}if(i[0].constructor==Number){d+=i[0]}else{switch(i[0]){case"left":d+=0;break;case"right":d+=e.width()-this.uiDialog.outerWidth();break;default:case"center":d+=(e.width()-this.uiDialog.outerWidth())/2}}if(i[1].constructor==Number){g+=i[1]}else{switch(i[1]){case"top":g+=0;break;case"bottom":g+=e.height()-this.uiDialog.outerHeight();break;default:case"middle":g+=(e.height()-this.uiDialog.outerHeight())/2}}g=Math.max(g,h);this.uiDialog.css({top:g,left:d})},_setData:function(e,f){(b[e]&&this.uiDialog.data(b[e],f));switch(e){case"buttons":this._createButtons(f);break;case"closeText":this.uiDialogTitlebarCloseText.text(f);break;case"dialogClass":this.uiDialog.removeClass(this.options.dialogClass).addClass(a+f);break;case"draggable":(f?this._makeDraggable():this.uiDialog.draggable("destroy"));break;case"height":this.uiDialog.height(f);break;case"position":this._position(f);break;case"resizable":var d=this.uiDialog,g=this.uiDialog.is(":data(resizable)");(g&&!f&&d.resizable("destroy"));(g&&typeof f=="string"&&d.resizable("option","handles",f));(g||this._makeResizable(f));break;case"title":c(".ui-dialog-title",this.uiDialogTitlebar).html(f||" ");break;case"width":this.uiDialog.width(f);break}c.widget.prototype._setData.apply(this,arguments)},_size:function(){var e=this.options;this.element.css({height:0,minHeight:0,width:"auto"});var d=this.uiDialog.css({height:"auto",width:e.width}).height();this.element.css({minHeight:Math.max(e.minHeight-d,0),height:e.height=="auto"?"auto":Math.max(e.height-d,0)})}});c.extend(c.ui.dialog,{version:"1.7.2",defaults:{autoOpen:true,bgiframe:false,buttons:{},closeOnEscape:true,closeText:"close",dialogClass:"",draggable:true,hide:null,height:"auto",maxHeight:false,maxWidth:false,minHeight:150,minWidth:150,modal:false,position:"center",resizable:true,show:null,stack:true,title:"",width:300,zIndex:1000},getter:"isOpen",uuid:0,maxZ:0,getTitleId:function(d){return"ui-dialog-title-"+(d.attr("id")||++this.uuid)},overlay:function(d){this.$el=c.ui.dialog.overlay.create(d)}});c.extend(c.ui.dialog.overlay,{instances:[],maxZ:0,events:c.map("focus,mousedown,mouseup,keydown,keypress,click".split(","),function(d){return d+".dialog-overlay"}).join(" "),create:function(e){if(this.instances.length===0){setTimeout(function(){if(c.ui.dialog.overlay.instances.length){c(document).bind(c.ui.dialog.overlay.events,function(f){var g=c(f.target).parents(".ui-dialog").css("zIndex")||0;return(g>c.ui.dialog.overlay.maxZ)})}},1);c(document).bind("keydown.dialog-overlay",function(f){(e.options.closeOnEscape&&f.keyCode&&f.keyCode==c.ui.keyCode.ESCAPE&&e.close(f))});c(window).bind("resize.dialog-overlay",c.ui.dialog.overlay.resize)}var d=c("<div></div>").appendTo(document.body).addClass("ui-widget-overlay").css({width:this.width(),height:this.height()});(e.options.bgiframe&&c.fn.bgiframe&&d.bgiframe());this.instances.push(d);return d},destroy:function(d){this.instances.splice(c.inArray(this.instances,d),1);if(this.instances.length===0){c([document,window]).unbind(".dialog-overlay")}d.remove();var e=0;c.each(this.instances,function(){e=Math.max(e,this.css("z-index"))});this.maxZ=e},height:function(){if(c.browser.msie&&c.browser.version<7){var e=Math.max(document.documentElement.scrollHeight,document.body.scrollHeight);var d=Math.max(document.documentElement.offsetHeight,document.body.offsetHeight);if(e<d){return c(window).height()+"px"}else{return e+"px"}}else{return c(document).height()+"px"}},width:function(){if(c.browser.msie&&c.browser.version<7){var d=Math.max(document.documentElement.scrollWidth,document.body.scrollWidth);var e=Math.max(document.documentElement.offsetWidth,document.body.offsetWidth);if(d<e){return c(window).width()+"px"}else{return d+"px"}}else{return c(document).width()+"px"}},resize:function(){var d=c([]);c.each(c.ui.dialog.overlay.instances,function(){d=d.add(this)});d.css({width:0,height:0}).css({width:c.ui.dialog.overlay.width(),height:c.ui.dialog.overlay.height()})}});c.extend(c.ui.dialog.overlay.prototype,{destroy:function(){c.ui.dialog.overlay.destroy(this.$el)}})})(jQuery);;/*
+ * jQuery UI Slider 1.7.2
+ * http://docs.jquery.com/UI/Slider
+ * Depends:
+ * ui.core.js
+(function(a){a.widget("ui.slider",a.extend({},a.ui.mouse,{_init:function(){var b=this,c=this.options;this._keySliding=false;this._handleIndex=null;this._detectOrientation();this._mouseInit();this.element.addClass("ui-slider ui-slider-"+this.orientation+" ui-widget ui-widget-content ui-corner-all");this.range=a([]);if(c.range){if(c.range===true){this.range=a("<div></div>");if(!c.values){c.values=[this._valueMin(),this._valueMin()]}if(c.values.length&&c.values.length!=2){c.values=[c.values[0],c.values[0]]}}else{this.range=a("<div></div>")}this.range.appendTo(this.element).addClass("ui-slider-range");if(c.range=="min"||c.range=="max"){this.range.addClass("ui-slider-range-"+c.range)}this.range.addClass("ui-widget-header")}if(a(".ui-slider-handle",this.element).length==0){a('<a href="#"></a>').appendTo(this.element).addClass("ui-slider-handle")}if(c.values&&c.values.length){while(a(".ui-slider-handle",this.element).length<c.values.length){a('<a href="#"></a>').appendTo(this.element).addClass("ui-slider-handle")}}this.handles=a(".ui-slider-handle",this.element).addClass("ui-state-default ui-corner-all");this.handle=this.handles.eq(0);this.handles.add(this.range).filter("a").click(function(d){d.preventDefault()}).hover(function(){if(!c.disabled){a(this).addClass("ui-state-hover")}},function(){a(this).removeClass("ui-state-hover")}).focus(function(){if(!c.disabled){a(".ui-slider .ui-state-focus").removeClass("ui-state-focus");a(this).addClass("ui-state-focus")}else{a(this).blur()}}).blur(function(){a(this).removeClass("ui-state-focus")});this.handles.each(function(d){a(this).data("index.ui-slider-handle",d)});this.handles.keydown(function(i){var f=true;var e=a(this).data("index.ui-slider-handle");if(b.options.disabled){return}switch(i.keyCode){case a.ui.keyCode.HOME:case a.ui.keyCode.END:case a.ui.keyCode.UP:case a.ui.keyCode.RIGHT:case a.ui.keyCode.DOWN:case a.ui.keyCode.LEFT:f=false;if(!b._keySliding){b._keySliding=true;a(this).addClass("ui-state-active");b._start(i,e)}break}var g,d,h=b._step();if(b.options.values&&b.options.values.length){g=d=b.values(e)}else{g=d=b.value()}switch(i.keyCode){case a.ui.keyCode.HOME:d=b._valueMin();break;case a.ui.keyCode.END:d=b._valueMax();break;case a.ui.keyCode.UP:case a.ui.keyCode.RIGHT:if(g==b._valueMax()){return}d=g+h;break;case a.ui.keyCode.DOWN:case a.ui.keyCode.LEFT:if(g==b._valueMin()){return}d=g-h;break}b._slide(i,e,d);return f}).keyup(function(e){var d=a(this).data("index.ui-slider-handle");if(b._keySliding){b._stop(e,d);b._change(e,d);b._keySliding=false;a(this).removeClass("ui-state-active")}});this._refreshValue()},destroy:function(){this.handles.remove();this.range.remove();this.element.removeClass("ui-slider ui-slider-horizontal ui-slider-vertical ui-slider-disabled ui-widget ui-widget-content ui-corner-all").removeData("slider").unbind(".slider");this._mouseDestroy()},_mouseCapture:function(d){var e=this.options;if(e.disabled){return false}this.elementSize={width:this.element.outerWidth(),height:this.element.outerHeight()};this.elementOffset=this.element.offset();var h={x:d.pageX,y:d.pageY};var j=this._normValueFromMouse(h);var c=this._valueMax()-this._valueMin()+1,f;var k=this,i;this.handles.each(function(l){var m=Math.abs(j-k.values(l));if(c>m){c=m;f=a(this);i=l}});if(e.range==true&&this.values(1)==e.min){f=a(this.handles[++i])}this._start(d,i);k._handleIndex=i;f.addClass("ui-state-active").focus();var g=f.offset();var b=!a(d.target).parents().andSelf().is(".ui-slider-handle");this._clickOffset=b?{left:0,top:0}:{left:d.pageX-g.left-(f.width()/2),top:d.pageY-g.top-(f.height()/2)-(parseInt(f.css("borderTopWidth"),10)||0)-(parseInt(f.css("borderBottomWidth"),10)||0)+(parseInt(f.css("marginTop"),10)||0)};j=this._normValueFromMouse(h);this._slide(d,i,j);return true},_mouseStart:function(b){return true},_mouseDrag:function(d){var b={x:d.pageX,y:d.pageY};var c=this._normValueFromMouse(b);this._slide(d,this._handleIndex,c);return false},_mouseStop:function(b){this.handles.removeClass("ui-state-active");this._stop(b,this._handleIndex);this._change(b,this._handleIndex);this._handleIndex=null;this._clickOffset=null;return false},_detectOrientation:function(){this.orientation=this.options.orientation=="vertical"?"vertical":"horizontal"},_normValueFromMouse:function(d){var c,h;if("horizontal"==this.orientation){c=this.elementSize.width;h=d.x-this.elementOffset.left-(this._clickOffset?this._clickOffset.left:0)}else{c=this.elementSize.height;h=d.y-this.elementOffset.top-(this._clickOffset?this._clickOffset.top:0)}var f=(h/c);if(f>1){f=1}if(f<0){f=0}if("vertical"==this.orientation){f=1-f}var e=this._valueMax()-this._valueMin(),i=f*e,b=i%this.options.step,g=this._valueMin()+i-b;if(b>(this.options.step/2)){g+=this.options.step}return parseFloat(g.toFixed(5))},_start:function(d,c){var b={handle:this.handles[c],value:this.value()};if(this.options.values&&this.options.values.length){b.value=this.values(c);b.values=this.values()}this._trigger("start",d,b)},_slide:function(f,e,d){var g=this.handles[e];if(this.options.values&&this.options.values.length){var b=this.values(e?0:1);if((this.options.values.length==2&&this.options.range===true)&&((e==0&&d>b)||(e==1&&d<b))){d=b}if(d!=this.values(e)){var c=this.values();c[e]=d;var h=this._trigger("slide",f,{handle:this.handles[e],value:d,values:c});var b=this.values(e?0:1);if(h!==false){this.values(e,d,(f.type=="mousedown"&&this.options.animate),true)}}}else{if(d!=this.value()){var h=this._trigger("slide",f,{handle:this.handles[e],value:d});if(h!==false){this._setData("value",d,(f.type=="mousedown"&&this.options.animate))}}}},_stop:function(d,c){var b={handle:this.handles[c],value:this.value()};if(this.options.values&&this.options.values.length){b.value=this.values(c);b.values=this.values()}this._trigger("stop",d,b)},_change:function(d,c){var b={handle:this.handles[c],value:this.value()};if(this.options.values&&this.options.values.length){b.value=this.values(c);b.values=this.values()}this._trigger("change",d,b)},value:function(b){if(arguments.length){this._setData("value",b);this._change(null,0)}return this._value()},values:function(b,e,c,d){if(arguments.length>1){this.options.values[b]=e;this._refreshValue(c);if(!d){this._change(null,b)}}if(arguments.length){if(this.options.values&&this.options.values.length){return this._values(b)}else{return this.value()}}else{return this._values()}},_setData:function(b,d,c){a.widget.prototype._setData.apply(this,arguments);switch(b){case"disabled":if(d){this.handles.filter(".ui-state-focus").blur();this.handles.removeClass("ui-state-hover");this.handles.attr("disabled","disabled")}else{this.handles.removeAttr("disabled")}case"orientation":this._detectOrientation();this.element.removeClass("ui-slider-horizontal ui-slider-vertical").addClass("ui-slider-"+this.orientation);this._refreshValue(c);break;case"value":this._refreshValue(c);break}},_step:function(){var b=this.options.step;return b},_value:function(){var b=this.options.value;if(b<this._valueMin()){b=this._valueMin()}if(b>this._valueMax()){b=this._valueMax()}return b},_values:function(b){if(arguments.length){var c=this.options.values[b];if(c<this._valueMin()){c=this._valueMin()}if(c>this._valueMax()){c=this._valueMax()}return c}else{return this.options.values}},_valueMin:function(){var b=this.options.min;return b},_valueMax:function(){var b=this.options.max;return b},_refreshValue:function(c){var f=this.options.range,d=this.options,l=this;if(this.options.values&&this.options.values.length){var i,h;this.handles.each(function(p,n){var o=(l.values(p)-l._valueMin())/(l._valueMax()-l._valueMin())*100;var m={};m[l.orientation=="horizontal"?"left":"bottom"]=o+"%";a(this).stop(1,1)[c?"animate":"css"](m,d.animate);if(l.options.range===true){if(l.orientation=="horizontal"){(p==0)&&l.range.stop(1,1)[c?"animate":"css"]({left:o+"%"},d.animate);(p==1)&&l.range[c?"animate":"css"]({width:(o-lastValPercent)+"%"},{queue:false,duration:d.animate})}else{(p==0)&&l.range.stop(1,1)[c?"animate":"css"]({bottom:(o)+"%"},d.animate);(p==1)&&l.range[c?"animate":"css"]({height:(o-lastValPercent)+"%"},{queue:false,duration:d.animate})}}lastValPercent=o})}else{var j=this.value(),g=this._valueMin(),k=this._valueMax(),e=k!=g?(j-g)/(k-g)*100:0;var b={};b[l.orientation=="horizontal"?"left":"bottom"]=e+"%";this.handle.stop(1,1)[c?"animate":"css"](b,d.animate);(f=="min")&&(this.orientation=="horizontal")&&this.range.stop(1,1)[c?"animate":"css"]({width:e+"%"},d.animate);(f=="max")&&(this.orientation=="horizontal")&&this.range[c?"animate":"css"]({width:(100-e)+"%"},{queue:false,duration:d.animate});(f=="min")&&(this.orientation=="vertical")&&this.range.stop(1,1)[c?"animate":"css"]({height:e+"%"},d.animate);(f=="max")&&(this.orientation=="vertical")&&this.range[c?"animate":"css"]({height:(100-e)+"%"},{queue:false,duration:d.animate})}}}));a.extend(a.ui.slider,{getter:"value values",version:"1.7.2",eventPrefix:"slide",defaults:{animate:false,delay:0,distance:0,max:100,min:0,orientation:"horizontal",range:false,step:1,value:0,values:null}})})(jQuery);;/*
+ * jQuery UI Tabs 1.7.2
+ * http://docs.jquery.com/UI/Tabs
+ * Depends:
+ * ui.core.js
+(function(a){a.widget("ui.tabs",{_init:function(){if(this.options.deselectable!==undefined){this.options.collapsible=this.options.deselectable}this._tabify(true)},_setData:function(b,c){if(b=="selected"){if(this.options.collapsible&&c==this.options.selected){return}this.select(c)}else{this.options[b]=c;if(b=="deselectable"){this.options.collapsible=c}this._tabify()}},_tabId:function(b){return b.title&&b.title.replace(/\s/g,"_").replace(/[^A-Za-z0-9\-_:\.]/g,"")||this.options.idPrefix+a.data(b)},_sanitizeSelector:function(b){return b.replace(/:/g,"\\:")},_cookie:function(){var b=this.cookie||(this.cookie=this.options.cookie.name||"ui-tabs-"+a.data(this.list[0]));return a.cookie.apply(null,[b].concat(a.makeArray(arguments)))},_ui:function(c,b){return{tab:c,panel:b,index:this.anchors.index(c)}},_cleanup:function(){this.lis.filter(".ui-state-processing").removeClass("ui-state-processing").find("span:data(label.tabs)").each(function(){var b=a(this);b.html(b.data("label.tabs")).removeData("label.tabs")})},_tabify:function(n){this.list=this.element.children("ul:first");this.lis=a("li:has(a[href])",this.list);this.anchors=this.lis.map(function(){return a("a",this)[0]});this.panels=a([]);var p=this,d=this.options;var c=/^#.+/;this.anchors.each(function(r,o){var q=a(o).attr("href");var s=q.split("#")[0],u;if(s&&(s===location.toString().split("#")[0]||(u=a("base")[0])&&s===u.href)){q=o.hash;o.href=q}if(c.test(q)){p.panels=p.panels.add(p._sanitizeSelector(q))}else{if(q!="#"){a.data(o,"href.tabs",q);a.data(o,"load.tabs",q.replace(/#.*$/,""));var w=p._tabId(o);o.href="#"+w;var v=a("#"+w);if(!v.length){v=a(d.panelTemplate).attr("id",w).addClass("ui-tabs-panel ui-widget-content ui-corner-bottom").insertAfter(p.panels[r-1]||p.list);v.data("destroy.tabs",true)}p.panels=p.panels.add(v)}else{d.disabled.push(r)}}});if(n){this.element.addClass("ui-tabs ui-widget ui-widget-content ui-corner-all");this.list.addClass("ui-tabs-nav ui-helper-reset ui-helper-clearfix ui-widget-header ui-corner-all");this.lis.addClass("ui-state-default ui-corner-top");this.panels.addClass("ui-tabs-panel ui-widget-content ui-corner-bottom");if(d.selected===undefined){if(location.hash){this.anchors.each(function(q,o){if(o.hash==location.hash){d.selected=q;return false}})}if(typeof d.selected!="number"&&d.cookie){d.selected=parseInt(p._cookie(),10)}if(typeof d.selected!="number"&&this.lis.filter(".ui-tabs-selected").length){d.selected=this.lis.index(this.lis.filter(".ui-tabs-selected"))}d.selected=d.selected||0}else{if(d.selected===null){d.selected=-1}}d.selected=((d.selected>=0&&this.anchors[d.selected])||d.selected<0)?d.selected:0;d.disabled=a.unique(d.disabled.concat(a.map(this.lis.filter(".ui-state-disabled"),function(q,o){return p.lis.index(q)}))).sort();if(a.inArray(d.selected,d.disabled)!=-1){d.disabled.splice(a.inArray(d.selected,d.disabled),1)}this.panels.addClass("ui-tabs-hide");this.lis.removeClass("ui-tabs-selected ui-state-active");if(d.selected>=0&&this.anchors.length){this.panels.eq(d.selected).removeClass("ui-tabs-hide");this.lis.eq(d.selected).addClass("ui-tabs-selected ui-state-active");p.element.queue("tabs",function(){p._trigger("show",null,p._ui(p.anchors[d.selected],p.panels[d.selected]))});this.load(d.selected)}a(window).bind("unload",function(){p.lis.add(p.anchors).unbind(".tabs");p.lis=p.anchors=p.panels=null})}else{d.selected=this.lis.index(this.lis.filter(".ui-tabs-selected"))}this.element[d.collapsible?"addClass":"removeClass"]("ui-tabs-collapsible");if(d.cookie){this._cookie(d.selected,d.cookie)}for(var g=0,m;(m=this.lis[g]);g++){a(m)[a.inArray(g,d.disabled)!=-1&&!a(m).hasClass("ui-tabs-selected")?"addClass":"removeClass"]("ui-state-disabled")}if(d.cache===false){this.anchors.removeData("cache.tabs")}this.lis.add(this.anchors).unbind(".tabs");if(d.event!="mouseover"){var f=function(o,i){if(i.is(":not(.ui-state-disabled)")){i.addClass("ui-state-"+o)}};var j=function(o,i){i.removeClass("ui-state-"+o)};this.lis.bind("mouseover.tabs",function(){f("hover",a(this))});this.lis.bind("mouseout.tabs",function(){j("hover",a(this))});this.anchors.bind("focus.tabs",function(){f("focus",a(this).closest("li"))});this.anchors.bind("blur.tabs",function(){j("focus",a(this).closest("li"))})}var b,h;if(d.fx){if(a.isArray(d.fx)){b=d.fx[0];h=d.fx[1]}else{b=h=d.fx}}function e(i,o){i.css({display:""});if(a.browser.msie&&o.opacity){i[0].style.removeAttribute("filter")}}var k=h?function(i,o){a(i).closest("li").removeClass("ui-state-default").addClass("ui-tabs-selected ui-state-active");o.hide().removeClass("ui-tabs-hide").animate(h,h.duration||"normal",function(){e(o,h);p._trigger("show",null,p._ui(i,o[0]))})}:function(i,o){a(i).closest("li").removeClass("ui-state-default").addClass("ui-tabs-selected ui-state-active");o.removeClass("ui-tabs-hide");p._trigger("show",null,p._ui(i,o[0]))};var l=b?function(o,i){i.animate(b,b.duration||"normal",function(){p.lis.removeClass("ui-tabs-selected ui-state-active").addClass("ui-state-default");i.addClass("ui-tabs-hide");e(i,b);p.element.dequeue("tabs")})}:function(o,i,q){p.lis.removeClass("ui-tabs-selected ui-state-active").addClass("ui-state-default");i.addClass("ui-tabs-hide");p.element.dequeue("tabs")};this.anchors.bind(d.event+".tabs",function(){var o=this,r=a(this).closest("li"),i=p.panels.filter(":not(.ui-tabs-hide)"),q=a(p._sanitizeSelector(this.hash));if((r.hasClass("ui-tabs-selected")&&!d.collapsible)||r.hasClass("ui-state-disabled")||r.hasClass("ui-state-processing")||p._trigger("select",null,p._ui(this,q[0]))===false){this.blur();return false}d.selected=p.anchors.index(this);p.abort();if(d.collapsible){if(r.hasClass("ui-tabs-selected")){d.selected=-1;if(d.cookie){p._cookie(d.selected,d.cookie)}p.element.queue("tabs",function(){l(o,i)}).dequeue("tabs");this.blur();return false}else{if(!i.length){if(d.cookie){p._cookie(d.selected,d.cookie)}p.element.queue("tabs",function(){k(o,q)});p.load(p.anchors.index(this));this.blur();return false}}}if(d.cookie){p._cookie(d.selected,d.cookie)}if(q.length){if(i.length){p.element.queue("tabs",function(){l(o,i)})}p.element.queue("tabs",function(){k(o,q)});p.load(p.anchors.index(this))}else{throw"jQuery UI Tabs: Mismatching fragment identifier."}if(a.browser.msie){this.blur()}});this.anchors.bind("click.tabs",function(){return false})},destroy:function(){var b=this.options;this.abort();this.element.unbind(".tabs").removeClass("ui-tabs ui-widget ui-widget-content ui-corner-all ui-tabs-collapsible").removeData("tabs");this.list.removeClass("ui-tabs-nav ui-helper-reset ui-helper-clearfix ui-widget-header ui-corner-all");this.anchors.each(function(){var c=a.data(this,"href.tabs");if(c){this.href=c}var d=a(this).unbind(".tabs");a.each(["href","load","cache"],function(e,f){d.removeData(f+".tabs")})});this.lis.unbind(".tabs").add(this.panels).each(function(){if(a.data(this,"destroy.tabs")){a(this).remove()}else{a(this).removeClass(["ui-state-default","ui-corner-top","ui-tabs-selected","ui-state-active","ui-state-hover","ui-state-focus","ui-state-disabled","ui-tabs-panel","ui-widget-content","ui-corner-bottom","ui-tabs-hide"].join(" "))}});if(b.cookie){this._cookie(null,b.cookie)}},add:function(e,d,c){if(c===undefined){c=this.anchors.length}var b=this,g=this.options,i=a(g.tabTemplate.replace(/#\{href\}/g,e).replace(/#\{label\}/g,d)),h=!e.indexOf("#")?e.replace("#",""):this._tabId(a("a",i)[0]);i.addClass("ui-state-default ui-corner-top").data("destroy.tabs",true);var f=a("#"+h);if(!f.length){f=a(g.panelTemplate).attr("id",h).data("destroy.tabs",true)}f.addClass("ui-tabs-panel ui-widget-content ui-corner-bottom ui-tabs-hide");if(c>=this.lis.length){i.appendTo(this.list);f.appendTo(this.list[0].parentNode)}else{i.insertBefore(this.lis[c]);f.insertBefore(this.panels[c])}g.disabled=a.map(g.disabled,function(k,j){return k>=c?++k:k});this._tabify();if(this.anchors.length==1){i.addClass("ui-tabs-selected ui-state-active");f.removeClass("ui-tabs-hide");this.element.queue("tabs",function(){b._trigger("show",null,b._ui(b.anchors[0],b.panels[0]))});this.load(0)}this._trigger("add",null,this._ui(this.anchors[c],this.panels[c]))},remove:function(b){var d=this.options,e=this.lis.eq(b).remove(),c=this.panels.eq(b).remove();if(e.hasClass("ui-tabs-selected")&&this.anchors.length>1){this.select(b+(b+1<this.anchors.length?1:-1))}d.disabled=a.map(a.grep(d.disabled,function(g,f){return g!=b}),function(g,f){return g>=b?--g:g});this._tabify();this._trigger("remove",null,this._ui(e.find("a")[0],c[0]))},enable:function(b){var c=this.options;if(a.inArray(b,c.disabled)==-1){return}this.lis.eq(b).removeClass("ui-state-disabled");c.disabled=a.grep(c.disabled,function(e,d){return e!=b});this._trigger("enable",null,this._ui(this.anchors[b],this.panels[b]))},disable:function(c){var b=this,d=this.options;if(c!=d.selected){this.lis.eq(c).addClass("ui-state-disabled");d.disabled.push(c);d.disabled.sort();this._trigger("disable",null,this._ui(this.anchors[c],this.panels[c]))}},select:function(b){if(typeof b=="string"){b=this.anchors.index(this.anchors.filter("[href$="+b+"]"))}else{if(b===null){b=-1}}if(b==-1&&this.options.collapsible){b=this.options.selected}this.anchors.eq(b).trigger(this.options.event+".tabs")},load:function(e){var c=this,g=this.options,b=this.anchors.eq(e)[0],d=a.data(b,"load.tabs");this.abort();if(!d||this.element.queue("tabs").length!==0&&a.data(b,"cache.tabs")){this.element.dequeue("tabs");return}this.lis.eq(e).addClass("ui-state-processing");if(g.spinner){var f=a("span",b);f.data("label.tabs",f.html()).html(g.spinner)}this.xhr=a.ajax(a.extend({},g.ajaxOptions,{url:d,success:function(i,h){a(c._sanitizeSelector(b.hash)).html(i);c._cleanup();if(g.cache){a.data(b,"cache.tabs",true)}c._trigger("load",null,c._ui(c.anchors[e],c.panels[e]));try{g.ajaxOptions.success(i,h)}catch(j){}c.element.dequeue("tabs")}}))},abort:function(){this.element.queue([]);this.panels.stop(false,true);if(this.xhr){this.xhr.abort();delete this.xhr}this._cleanup()},url:function(c,b){this.anchors.eq(c).removeData("cache.tabs").data("load.tabs",b)},length:function(){return this.anchors.length}});a.extend(a.ui.tabs,{version:"1.7.2",getter:"length",defaults:{ajaxOptions:null,cache:false,cookie:null,collapsible:false,disabled:[],event:"click",fx:null,idPrefix:"ui-tabs-",panelTemplate:"<div></div>",spinner:"<em>Loading…</em>",tabTemplate:'<li><a href="#{href}"><span>#{label}</span></a></li>'}});a.extend(a.ui.tabs.prototype,{rotation:null,rotate:function(d,f){var b=this,g=this.options;var c=b._rotate||(b._rotate=function(h){clearTimeout(b.rotation);b.rotation=setTimeout(function(){var i=g.selected;b.select(++i<b.anchors.length?i:0)},d);if(h){h.stopPropagation()}});var e=b._unrotate||(b._unrotate=!f?function(h){if(h.clientX){b.rotate(null)}}:function(h){t=g.selected;c()});if(d){this.element.bind("tabsshow",c);this.anchors.bind(g.event+".tabs",e);c()}else{clearTimeout(b.rotation);this.element.unbind("tabsshow",c);this.anchors.unbind(g.event+".tabs",e);delete this._rotate;delete this._unrotate}}})})(jQuery);;/*
+ * jQuery UI Datepicker 1.7.2
+ * http://docs.jquery.com/UI/Datepicker
+ * Depends:
+ * ui.core.js
+(function($){$.extend($.ui,{datepicker:{version:"1.7.2"}});var PROP_NAME="datepicker";function Datepicker(){this.debug=false;this._curInst=null;this._keyEvent=false;this._disabledInputs=[];this._datepickerShowing=false;this._inDialog=false;this._mainDivId="ui-datepicker-div";this._inlineClass="ui-datepicker-inline";this._appendClass="ui-datepicker-append";this._triggerClass="ui-datepicker-trigger";this._dialogClass="ui-datepicker-dialog";this._disableClass="ui-datepicker-disabled";this._unselectableClass="ui-datepicker-unselectable";this._currentClass="ui-datepicker-current-day";this._dayOverClass="ui-datepicker-days-cell-over";this.regional=[];this.regional[""]={closeText:"Done",prevText:"Prev",nextText:"Next",currentText:"Today",monthNames:["January","February","March","April","May","June","July","August","September","October","November","December"],monthNamesShort:["Jan","Feb","Mar","Apr","May","Jun","Jul","Aug","Sep","Oct","Nov","Dec"],dayNames:["Sunday","Monday","Tuesday","Wednesday","Thursday","Friday","Saturday"],dayNamesShort:["Sun","Mon","Tue","Wed","Thu","Fri","Sat"],dayNamesMin:["Su","Mo","Tu","We","Th","Fr","Sa"],dateFormat:"mm/dd/yy",firstDay:0,isRTL:false};this._defaults={showOn:"focus",showAnim:"show",showOptions:{},defaultDate:null,appendText:"",buttonText:"...",buttonImage:"",buttonImageOnly:false,hideIfNoPrevNext:false,navigationAsDateFormat:false,gotoCurrent:false,changeMonth:false,changeYear:false,showMonthAfterYear:false,yearRange:"-10:+10",showOtherMonths:false,calculateWeek:this.iso8601Week,shortYearCutoff:"+10",minDate:null,maxDate:null,duration:"normal",beforeShowDay:null,beforeShow:null,onSelect:null,onChangeMonthYear:null,onClose:null,numberOfMonths:1,showCurrentAtPos:0,stepMonths:1,stepBigMonths:12,altField:"",altFormat:"",constrainInput:true,showButtonPanel:false};$.extend(this._defaults,this.regional[""]);this.dpDiv=$('<div id="'+this._mainDivId+'" class="ui-datepicker ui-widget ui-widget-content ui-helper-clearfix ui-corner-all ui-helper-hidden-accessible"></div>')}$.extend(Datepicker.prototype,{markerClassName:"hasDatepicker",log:function(){if(this.debug){console.log.apply("",arguments)}},setDefaults:function(settings){extendRemove(this._defaults,settings||{});return this},_attachDatepicker:function(target,settings){var inlineSettings=null;for(var attrName in this._defaults){var attrValue=target.getAttribute("date:"+attrName);if(attrValue){inlineSettings=inlineSettings||{};try{inlineSettings[attrName]=eval(attrValue)}catch(err){inlineSettings[attrName]=attrValue}}}var nodeName=target.nodeName.toLowerCase();var inline=(nodeName=="div"||nodeName=="span");if(!target.id){target.id="dp"+(++this.uuid)}var inst=this._newInst($(target),inline);inst.settings=$.extend({},settings||{},inlineSettings||{});if(nodeName=="input"){this._connectDatepicker(target,inst)}else{if(inline){this._inlineDatepicker(target,inst)}}},_newInst:function(target,inline){var id=target[0].id.replace(/([:\[\]\.])/g,"\\\\$1");return{id:id,input:target,selectedDay:0,selectedMonth:0,selectedYear:0,drawMonth:0,drawYear:0,inline:inline,dpDiv:(!inline?this.dpDiv:$('<div class="'+this._inlineClass+' ui-datepicker ui-widget ui-widget-content ui-helper-clearfix ui-corner-all"></div>'))}},_connectDatepicker:function(target,inst){var input=$(target);inst.append=$([]);inst.trigger=$([]);if(input.hasClass(this.markerClassName)){return}var appendText=this._get(inst,"appendText");var isRTL=this._get(inst,"isRTL");if(appendText){inst.append=$('<span class="'+this._appendClass+'">'+appendText+"</span>");input[isRTL?"before":"after"](inst.append)}var showOn=this._get(inst,"showOn");if(showOn=="focus"||showOn=="both"){input.focus(this._showDatepicker)}if(showOn=="button"||showOn=="both"){var buttonText=this._get(inst,"buttonText");var buttonImage=this._get(inst,"buttonImage");inst.trigger=$(this._get(inst,"buttonImageOnly")?$("<img/>").addClass(this._triggerClass).attr({src:buttonImage,alt:buttonText,title:buttonText}):$('<button type="button"></button>').addClass(this._triggerClass).html(buttonImage==""?buttonText:$("<img/>").attr({src:buttonImage,alt:buttonText,title:buttonText})));input[isRTL?"before":"after"](inst.trigger);inst.trigger.click(function(){if($.datepicker._datepickerShowing&&$.datepicker._lastInput==target){$.datepicker._hideDatepicker()}else{$.datepicker._showDatepicker(target)}return false})}input.addClass(this.markerClassName).keydown(this._doKeyDown).keypress(this._doKeyPress).bind("setData.datepicker",function(event,key,value){inst.settings[key]=value}).bind("getData.datepicker",function(event,key){return this._get(inst,key)});$.data(target,PROP_NAME,inst)},_inlineDatepicker:function(target,inst){var divSpan=$(target);if(divSpan.hasClass(this.markerClassName)){return}divSpan.addClass(this.markerClassName).append(inst.dpDiv).bind("setData.datepicker",function(event,key,value){inst.settings[key]=value}).bind("getData.datepicker",function(event,key){return this._get(inst,key)});$.data(target,PROP_NAME,inst);this._setDate(inst,this._getDefaultDate(inst));this._updateDatepicker(inst);this._updateAlternate(inst)},_dialogDatepicker:function(input,dateText,onSelect,settings,pos){var inst=this._dialogInst;if(!inst){var id="dp"+(++this.uuid);this._dialogInput=$('<input type="text" id="'+id+'" size="1" style="position: absolute; top: -100px;"/>');this._dialogInput.keydown(this._doKeyDown);$("body").append(this._dialogInput);inst=this._dialogInst=this._newInst(this._dialogInput,false);inst.settings={};$.data(this._dialogInput[0],PROP_NAME,inst)}extendRemove(inst.settings,settings||{});this._dialogInput.val(dateText);this._pos=(pos?(pos.length?pos:[pos.pageX,pos.pageY]):null);if(!this._pos){var browserWidth=window.innerWidth||document.documentElement.clientWidth||document.body.clientWidth;var browserHeight=window.innerHeight||document.documentElement.clientHeight||document.body.clientHeight;var scrollX=document.documentElement.scrollLeft||document.body.scrollLeft;var scrollY=document.documentElement.scrollTop||document.body.scrollTop;this._pos=[(browserWidth/2)-100+scrollX,(browserHeight/2)-150+scrollY]}this._dialogInput.css("left",this._pos[0]+"px").css("top",this._pos[1]+"px");inst.settings.onSelect=onSelect;this._inDialog=true;this.dpDiv.addClass(this._dialogClass);this._showDatepicker(this._dialogInput[0]);if($.blockUI){$.blockUI(this.dpDiv)}$.data(this._dialogInput[0],PROP_NAME,inst);return this},_destroyDatepicker:function(target){var $target=$(target);var inst=$.data(target,PROP_NAME);if(!$target.hasClass(this.markerClassName)){return}var nodeName=target.nodeName.toLowerCase();$.removeData(target,PROP_NAME);if(nodeName=="input"){inst.append.remove();inst.trigger.remove();$target.removeClass(this.markerClassName).unbind("focus",this._showDatepicker).unbind("keydown",this._doKeyDown).unbind("keypress",this._doKeyPress)}else{if(nodeName=="div"||nodeName=="span"){$target.removeClass(this.markerClassName).empty()}}},_enableDatepicker:function(target){var $target=$(target);var inst=$.data(target,PROP_NAME);if(!$target.hasClass(this.markerClassName)){return}var nodeName=target.nodeName.toLowerCase();if(nodeName=="input"){target.disabled=false;inst.trigger.filter("button").each(function(){this.disabled=false}).end().filter("img").css({opacity:"1.0",cursor:""})}else{if(nodeName=="div"||nodeName=="span"){var inline=$target.children("."+this._inlineClass);inline.children().removeClass("ui-state-disabled")}}this._disabledInputs=$.map(this._disabledInputs,function(value){return(value==target?null:value)})},_disableDatepicker:function(target){var $target=$(target);var inst=$.data(target,PROP_NAME);if(!$target.hasClass(this.markerClassName)){return}var nodeName=target.nodeName.toLowerCase();if(nodeName=="input"){target.disabled=true;inst.trigger.filter("button").each(function(){this.disabled=true}).end().filter("img").css({opacity:"0.5",cursor:"default"})}else{if(nodeName=="div"||nodeName=="span"){var inline=$target.children("."+this._inlineClass);inline.children().addClass("ui-state-disabled")}}this._disabledInputs=$.map(this._disabledInputs,function(value){return(value==target?null:value)});this._disabledInputs[this._disabledInputs.length]=target},_isDisabledDatepicker:function(target){if(!target){return false}for(var i=0;i<this._disabledInputs.length;i++){if(this._disabledInputs[i]==target){return true}}return false},_getInst:function(target){try{return $.data(target,PROP_NAME)}catch(err){throw"Missing instance data for this datepicker"}},_optionDatepicker:function(target,name,value){var inst=this._getInst(target);if(arguments.length==2&&typeof name=="string"){return(name=="defaults"?$.extend({},$.datepicker._defaults):(inst?(name=="all"?$.extend({},inst.settings):this._get(inst,name)):null))}var settings=name||{};if(typeof name=="string"){settings={};settings[name]=value}if(inst){if(this._curInst==inst){this._hideDatepicker(null)}var date=this._getDateDatepicker(target);extendRemove(inst.settings,settings);this._setDateDatepicker(target,date);this._updateDatepicker(inst)}},_changeDatepicker:function(target,name,value){this._optionDatepicker(target,name,value)},_refreshDatepicker:function(target){var inst=this._getInst(target);if(inst){this._updateDatepicker(inst)}},_setDateDatepicker:function(target,date,endDate){var inst=this._getInst(target);if(inst){this._setDate(inst,date,endDate);this._updateDatepicker(inst);this._updateAlternate(inst)}},_getDateDatepicker:function(target){var inst=this._getInst(target);if(inst&&!inst.inline){this._setDateFromField(inst)}return(inst?this._getDate(inst):null)},_doKeyDown:function(event){var inst=$.datepicker._getInst(event.target);var handled=true;var isRTL=inst.dpDiv.is(".ui-datepicker-rtl");inst._keyEvent=true;if($.datepicker._datepickerShowing){switch(event.keyCode){case 9:$.datepicker._hideDatepicker(null,"");break;case 13:var sel=$("td."+$.datepicker._dayOverClass+", td."+$.datepicker._currentClass,inst.dpDiv);if(sel[0]){$.datepicker._selectDay(event.target,inst.selectedMonth,inst.selectedYear,sel[0])}else{$.datepicker._hideDatepicker(null,$.datepicker._get(inst,"duration"))}return false;break;case 27:$.datepicker._hideDatepicker(null,$.datepicker._get(inst,"duration"));break;case 33:$.datepicker._adjustDate(event.target,(event.ctrlKey?-$.datepicker._get(inst,"stepBigMonths"):-$.datepicker._get(inst,"stepMonths")),"M");break;case 34:$.datepicker._adjustDate(event.target,(event.ctrlKey?+$.datepicker._get(inst,"stepBigMonths"):+$.datepicker._get(inst,"stepMonths")),"M");break;case 35:if(event.ctrlKey||event.metaKey){$.datepicker._clearDate(event.target)}handled=event.ctrlKey||event.metaKey;break;case 36:if(event.ctrlKey||event.metaKey){$.datepicker._gotoToday(event.target)}handled=event.ctrlKey||event.metaKey;break;case 37:if(event.ctrlKey||event.metaKey){$.datepicker._adjustDate(event.target,(isRTL?+1:-1),"D")}handled=event.ctrlKey||event.metaKey;if(event.originalEvent.altKey){$.datepicker._adjustDate(event.target,(event.ctrlKey?-$.datepicker._get(inst,"stepBigMonths"):-$.datepicker._get(inst,"stepMonths")),"M")}break;case 38:if(event.ctrlKey||event.metaKey){$.datepicker._adjustDate(event.target,-7,"D")}handled=event.ctrlKey||event.metaKey;break;case 39:if(event.ctrlKey||event.metaKey){$.datepicker._adjustDate(event.target,(isRTL?-1:+1),"D")}handled=event.ctrlKey||event.metaKey;if(event.originalEvent.altKey){$.datepicker._adjustDate(event.target,(event.ctrlKey?+$.datepicker._get(inst,"stepBigMonths"):+$.datepicker._get(inst,"stepMonths")),"M")}break;case 40:if(event.ctrlKey||event.metaKey){$.datepicker._adjustDate(event.target,+7,"D")}handled=event.ctrlKey||event.metaKey;break;default:handled=false}}else{if(event.keyCode==36&&event.ctrlKey){$.datepicker._showDatepicker(this)}else{handled=false}}if(handled){event.preventDefault();event.stopPropagation()}},_doKeyPress:function(event){var inst=$.datepicker._getInst(event.target);if($.datepicker._get(inst,"constrainInput")){var chars=$.datepicker._possibleChars($.datepicker._get(inst,"dateFormat"));var chr=String.fromCharCode(event.charCode==undefined?event.keyCode:event.charCode);return event.ctrlKey||(chr<" "||!chars||chars.indexOf(chr)>-1)}},_showDatepicker:function(input){input=input.target||input;if(input.nodeName.toLowerCase()!="input"){input=$("input",input.parentNode)[0]}if($.datepicker._isDisabledDatepicker(input)||$.datepicker._lastInput==input){return}var inst=$.datepicker._getInst(input);var beforeShow=$.datepicker._get(inst,"beforeShow");extendRemove(inst.settings,(beforeShow?beforeShow.apply(input,[input,inst]):{}));$.datepicker._hideDatepicker(null,"");$.datepicker._lastInput=input;$.datepicker._setDateFromField(inst);if($.datepicker._inDialog){input.value=""}if(!$.datepicker._pos){$.datepicker._pos=$.datepicker._findPos(input);$.datepicker._pos[1]+=input.offsetHeight}var isFixed=false;$(input).parents().each(function(){isFixed|=$(this).css("position")=="fixed";return !isFixed});if(isFixed&&$.browser.opera){$.datepicker._pos[0]-=document.documentElement.scrollLeft;$.datepicker._pos[1]-=document.documentElement.scrollTop}var offset={left:$.datepicker._pos[0],top:$.datepicker._pos[1]};$.datepicker._pos=null;inst.rangeStart=null;inst.dpDiv.css({position:"absolute",display:"block",top:"-1000px"});$.datepicker._updateDatepicker(inst);offset=$.datepicker._checkOffset(inst,offset,isFixed);inst.dpDiv.css({position:($.datepicker._inDialog&&$.blockUI?"static":(isFixed?"fixed":"absolute")),display:"none",left:offset.left+"px",top:offset.top+"px"});if(!inst.inline){var showAnim=$.datepicker._get(inst,"showAnim")||"show";var duration=$.datepicker._get(inst,"duration");var postProcess=function(){$.datepicker._datepickerShowing=true;if($.browser.msie&&parseInt($.browser.version,10)<7){$("iframe.ui-datepicker-cover").css({width:inst.dpDiv.width()+4,height:inst.dpDiv.height()+4})}};if($.effects&&$.effects[showAnim]){inst.dpDiv.show(showAnim,$.datepicker._get(inst,"showOptions"),duration,postProcess)}else{inst.dpDiv[showAnim](duration,postProcess)}if(duration==""){postProcess()}if(inst.input[0].type!="hidden"){inst.input[0].focus()}$.datepicker._curInst=inst}},_updateDatepicker:function(inst){var dims={width:inst.dpDiv.width()+4,height:inst.dpDiv.height()+4};var self=this;inst.dpDiv.empty().append(this._generateHTML(inst)).find("iframe.ui-datepicker-cover").css({width:dims.width,height:dims.height}).end().find("button, .ui-datepicker-prev, .ui-datepicker-next, .ui-datepicker-calendar td a").bind("mouseout",function(){$(this).removeClass("ui-state-hover");if(this.className.indexOf("ui-datepicker-prev")!=-1){$(this).removeClass("ui-datepicker-prev-hover")}if(this.className.indexOf("ui-datepicker-next")!=-1){$(this).removeClass("ui-datepicker-next-hover")}}).bind("mouseover",function(){if(!self._isDisabledDatepicker(inst.inline?inst.dpDiv.parent()[0]:inst.input[0])){$(this).parents(".ui-datepicker-calendar").find("a").removeClass("ui-state-hover");$(this).addClass("ui-state-hover");if(this.className.indexOf("ui-datepicker-prev")!=-1){$(this).addClass("ui-datepicker-prev-hover")}if(this.className.indexOf("ui-datepicker-next")!=-1){$(this).addClass("ui-datepicker-next-hover")}}}).end().find("."+this._dayOverClass+" a").trigger("mouseover").end();var numMonths=this._getNumberOfMonths(inst);var cols=numMonths[1];var width=17;if(cols>1){inst.dpDiv.addClass("ui-datepicker-multi-"+cols).css("width",(width*cols)+"em")}else{inst.dpDiv.removeClass("ui-datepicker-multi-2 ui-datepicker-multi-3 ui-datepicker-multi-4").width("")}inst.dpDiv[(numMonths[0]!=1||numMonths[1]!=1?"add":"remove")+"Class"]("ui-datepicker-multi");inst.dpDiv[(this._get(inst,"isRTL")?"add":"remove")+"Class"]("ui-datepicker-rtl");if(inst.input&&inst.input[0].type!="hidden"&&inst==$.datepicker._curInst){$(inst.input[0]).focus()}},_checkOffset:function(inst,offset,isFixed){var dpWidth=inst.dpDiv.outerWidth();var dpHeight=inst.dpDiv.outerHeight();var inputWidth=inst.input?inst.input.outerWidth():0;var inputHeight=inst.input?inst.input.outerHeight():0;var viewWidth=(window.innerWidth||document.documentElement.clientWidth||document.body.clientWidth)+$(document).scrollLeft();var viewHeight=(window.innerHeight||document.documentElement.clientHeight||document.body.clientHeight)+$(document).scrollTop();offset.left-=(this._get(inst,"isRTL")?(dpWidth-inputWidth):0);offset.left-=(isFixed&&offset.left==inst.input.offset().left)?$(document).scrollLeft():0;offset.top-=(isFixed&&offset.top==(inst.input.offset().top+inputHeight))?$(document).scrollTop():0;offset.left-=(offset.left+dpWidth>viewWidth&&viewWidth>dpWidth)?Math.abs(offset.left+dpWidth-viewWidth):0;offset.top-=(offset.top+dpHeight>viewHeight&&viewHeight>dpHeight)?Math.abs(offset.top+dpHeight+inputHeight*2-viewHeight):0;return offset},_findPos:function(obj){while(obj&&(obj.type=="hidden"||obj.nodeType!=1)){obj=obj.nextSibling}var position=$(obj).offset();return[position.left,position.top]},_hideDatepicker:function(input,duration){var inst=this._curInst;if(!inst||(input&&inst!=$.data(input,PROP_NAME))){return}if(inst.stayOpen){this._selectDate("#"+inst.id,this._formatDate(inst,inst.currentDay,inst.currentMonth,inst.currentYear))}inst.stayOpen=false;if(this._datepickerShowing){duration=(duration!=null?duration:this._get(inst,"duration"));var showAnim=this._get(inst,"showAnim");var postProcess=function(){$.datepicker._tidyDialog(inst)};if(duration!=""&&$.effects&&$.effects[showAnim]){inst.dpDiv.hide(showAnim,$.datepicker._get(inst,"showOptions"),duration,postProcess)}else{inst.dpDiv[(duration==""?"hide":(showAnim=="slideDown"?"slideUp":(showAnim=="fadeIn"?"fadeOut":"hide")))](duration,postProcess)}if(duration==""){this._tidyDialog(inst)}var onClose=this._get(inst,"onClose");if(onClose){onClose.apply((inst.input?inst.input[0]:null),[(inst.input?inst.input.val():""),inst])}this._datepickerShowing=false;this._lastInput=null;if(this._inDialog){this._dialogInput.css({position:"absolute",left:"0",top:"-100px"});if($.blockUI){$.unblockUI();$("body").append(this.dpDiv)}}this._inDialog=false}this._curInst=null},_tidyDialog:function(inst){inst.dpDiv.removeClass(this._dialogClass).unbind(".ui-datepicker-calendar")},_checkExternalClick:function(event){if(!$.datepicker._curInst){return}var $target=$(event.target);if(($target.parents("#"+$.datepicker._mainDivId).length==0)&&!$target.hasClass($.datepicker.markerClassName)&&!$target.hasClass($.datepicker._triggerClass)&&$.datepicker._datepickerShowing&&!($.datepicker._inDialog&&$.blockUI)){$.datepicker._hideDatepicker(null,"")}},_adjustDate:function(id,offset,period){var target=$(id);var inst=this._getInst(target[0]);if(this._isDisabledDatepicker(target[0])){return}this._adjustInstDate(inst,offset+(period=="M"?this._get(inst,"showCurrentAtPos"):0),period);this._updateDatepicker(inst)},_gotoToday:function(id){var target=$(id);var inst=this._getInst(target[0]);if(this._get(inst,"gotoCurrent")&&inst.currentDay){inst.selectedDay=inst.currentDay;inst.drawMonth=inst.selectedMonth=inst.currentMonth;inst.drawYear=inst.selectedYear=inst.currentYear}else{var date=new Date();inst.selectedDay=date.getDate();inst.drawMonth=inst.selectedMonth=date.getMonth();inst.drawYear=inst.selectedYear=date.getFullYear()}this._notifyChange(inst);this._adjustDate(target)},_selectMonthYear:function(id,select,period){var target=$(id);var inst=this._getInst(target[0]);inst._selectingMonthYear=false;inst["selected"+(period=="M"?"Month":"Year")]=inst["draw"+(period=="M"?"Month":"Year")]=parseInt(select.options[select.selectedIndex].value,10);this._notifyChange(inst);this._adjustDate(target)},_clickMonthYear:function(id){var target=$(id);var inst=this._getInst(target[0]);if(inst.input&&inst._selectingMonthYear&&!$.browser.msie){inst.input[0].focus()}inst._selectingMonthYear=!inst._selectingMonthYear},_selectDay:function(id,month,year,td){var target=$(id);if($(td).hasClass(this._unselectableClass)||this._isDisabledDatepicker(target[0])){return}var inst=this._getInst(target[0]);inst.selectedDay=inst.currentDay=$("a",td).html();inst.selectedMonth=inst.currentMonth=month;inst.selectedYear=inst.currentYear=year;if(inst.stayOpen){inst.endDay=inst.endMonth=inst.endYear=null}this._selectDate(id,this._formatDate(inst,inst.currentDay,inst.currentMonth,inst.currentYear));if(inst.stayOpen){inst.rangeStart=this._daylightSavingAdjust(new Date(inst.currentYear,inst.currentMonth,inst.currentDay));this._updateDatepicker(inst)}},_clearDate:function(id){var target=$(id);var inst=this._getInst(target[0]);inst.stayOpen=false;inst.endDay=inst.endMonth=inst.endYear=inst.rangeStart=null;this._selectDate(target,"")},_selectDate:function(id,dateStr){var target=$(id);var inst=this._getInst(target[0]);dateStr=(dateStr!=null?dateStr:this._formatDate(inst));if(inst.input){inst.input.val(dateStr)}this._updateAlternate(inst);var onSelect=this._get(inst,"onSelect");if(onSelect){onSelect.apply((inst.input?inst.input[0]:null),[dateStr,inst])}else{if(inst.input){inst.input.trigger("change")}}if(inst.inline){this._updateDatepicker(inst)}else{if(!inst.stayOpen){this._hideDatepicker(null,this._get(inst,"duration"));this._lastInput=inst.input[0];if(typeof(inst.input[0])!="object"){inst.input[0].focus()}this._lastInput=null}}},_updateAlternate:function(inst){var altField=this._get(inst,"altField");if(altField){var altFormat=this._get(inst,"altFormat")||this._get(inst,"dateFormat");var date=this._getDate(inst);dateStr=this.formatDate(altFormat,date,this._getFormatConfig(inst));$(altField).each(function(){$(this).val(dateStr)})}},noWeekends:function(date){var day=date.getDay();return[(day>0&&day<6),""]},iso8601Week:function(date){var checkDate=new Date(date.getFullYear(),date.getMonth(),date.getDate());var firstMon=new Date(checkDate.getFullYear(),1-1,4);var firstDay=firstMon.getDay()||7;firstMon.setDate(firstMon.getDate()+1-firstDay);if(firstDay<4&&checkDate<firstMon){checkDate.setDate(checkDate.getDate()-3);return $.datepicker.iso8601Week(checkDate)}else{if(checkDate>new Date(checkDate.getFullYear(),12-1,28)){firstDay=new Date(checkDate.getFullYear()+1,1-1,4).getDay()||7;if(firstDay>4&&(checkDate.getDay()||7)<firstDay-3){return 1}}}return Math.floor(((checkDate-firstMon)/86400000)/7)+1},parseDate:function(format,value,settings){if(format==null||value==null){throw"Invalid arguments"}value=(typeof value=="object"?value.toString():value+"");if(value==""){return null}var shortYearCutoff=(settings?settings.shortYearCutoff:null)||this._defaults.shortYearCutoff;var dayNamesShort=(settings?settings.dayNamesShort:null)||this._defaults.dayNamesShort;var dayNames=(settings?settings.dayNames:null)||this._defaults.dayNames;var monthNamesShort=(settings?settings.monthNamesShort:null)||this._defaults.monthNamesShort;var monthNames=(settings?settings.monthNames:null)||this._defaults.monthNames;var year=-1;var month=-1;var day=-1;var doy=-1;var literal=false;var lookAhead=function(match){var matches=(iFormat+1<format.length&&format.charAt(iFormat+1)==match);if(matches){iFormat++}return matches};var getNumber=function(match){lookAhead(match);var origSize=(match=="@"?14:(match=="y"?4:(match=="o"?3:2)));var size=origSize;var num=0;while(size>0&&iValue<value.length&&value.charAt(iValue)>="0"&&value.charAt(iValue)<="9"){num=num*10+parseInt(value.charAt(iValue++),10);size--}if(size==origSize){throw"Missing number at position "+iValue}return num};var getName=function(match,shortNames,longNames){var names=(lookAhead(match)?longNames:shortNames);var size=0;for(var j=0;j<names.length;j++){size=Math.max(size,names[j].length)}var name="";var iInit=iValue;while(size>0&&iValue<value.length){name+=value.charAt(iValue++);for(var i=0;i<names.length;i++){if(name==names[i]){return i+1}}size--}throw"Unknown name at position "+iInit};var checkLiteral=function(){if(value.charAt(iValue)!=format.charAt(iFormat)){throw"Unexpected literal at position "+iValue}iValue++};var iValue=0;for(var iFormat=0;iFormat<format.length;iFormat++){if(literal){if(format.charAt(iFormat)=="'"&&!lookAhead("'")){literal=false}else{checkLiteral()}}else{switch(format.charAt(iFormat)){case"d":day=getNumber("d");break;case"D":getName("D",dayNamesShort,dayNames);break;case"o":doy=getNumber("o");break;case"m":month=getNumber("m");break;case"M":month=getName("M",monthNamesShort,monthNames);break;case"y":year=getNumber("y");break;case"@":var date=new Date(getNumber("@"));year=date.getFullYear();month=date.getMonth()+1;day=date.getDate();break;case"'":if(lookAhead("'")){checkLiteral()}else{literal=true}break;default:checkLiteral()}}}if(year==-1){year=new Date().getFullYear()}else{if(year<100){year+=new Date().getFullYear()-new Date().getFullYear()%100+(year<=shortYearCutoff?0:-100)}}if(doy>-1){month=1;day=doy;do{var dim=this._getDaysInMonth(year,month-1);if(day<=dim){break}month++;day-=dim}while(true)}var date=this._daylightSavingAdjust(new Date(year,month-1,day));if(date.getFullYear()!=year||date.getMonth()+1!=month||date.getDate()!=day){throw"Invalid date"}return date},ATOM:"yy-mm-dd",COOKIE:"D, dd M yy",ISO_8601:"yy-mm-dd",RFC_822:"D, d M y",RFC_850:"DD, dd-M-y",RFC_1036:"D, d M y",RFC_1123:"D, d M yy",RFC_2822:"D, d M yy",RSS:"D, d M y",TIMESTAMP:"@",W3C:"yy-mm-dd",formatDate:function(format,date,settings){if(!date){return""}var dayNamesShort=(settings?settings.dayNamesShort:null)||this._defaults.dayNamesShort;var dayNames=(settings?settings.dayNames:null)||this._defaults.dayNames;var monthNamesShort=(settings?settings.monthNamesShort:null)||this._defaults.monthNamesShort;var monthNames=(settings?settings.monthNames:null)||this._defaults.monthNames;var lookAhead=function(match){var matches=(iFormat+1<format.length&&format.charAt(iFormat+1)==match);if(matches){iFormat++}return matches};var formatNumber=function(match,value,len){var num=""+value;if(lookAhead(match)){while(num.length<len){num="0"+num}}return num};var formatName=function(match,value,shortNames,longNames){return(lookAhead(match)?longNames[value]:shortNames[value])};var output="";var literal=false;if(date){for(var iFormat=0;iFormat<format.length;iFormat++){if(literal){if(format.charAt(iFormat)=="'"&&!lookAhead("'")){literal=false}else{output+=format.charAt(iFormat)}}else{switch(format.charAt(iFormat)){case"d":output+=formatNumber("d",date.getDate(),2);break;case"D":output+=formatName("D",date.getDay(),dayNamesShort,dayNames);break;case"o":var doy=date.getDate();for(var m=date.getMonth()-1;m>=0;m--){doy+=this._getDaysInMonth(date.getFullYear(),m)}output+=formatNumber("o",doy,3);break;case"m":output+=formatNumber("m",date.getMonth()+1,2);break;case"M":output+=formatName("M",date.getMonth(),monthNamesShort,monthNames);break;case"y":output+=(lookAhead("y")?date.getFullYear():(date.getYear()%100<10?"0":"")+date.getYear()%100);break;case"@":output+=date.getTime();break;case"'":if(lookAhead("'")){output+="'"}else{literal=true}break;default:output+=format.charAt(iFormat)}}}}return output},_possibleChars:function(format){var chars="";var literal=false;for(var iFormat=0;iFormat<format.length;iFormat++){if(literal){if(format.charAt(iFormat)=="'"&&!lookAhead("'")){literal=false}else{chars+=format.charAt(iFormat)}}else{switch(format.charAt(iFormat)){case"d":case"m":case"y":case"@":chars+="0123456789";break;case"D":case"M":return null;case"'":if(lookAhead("'")){chars+="'"}else{literal=true}break;default:chars+=format.charAt(iFormat)}}}return chars},_get:function(inst,name){return inst.settings[name]!==undefined?inst.settings[name]:this._defaults[name]},_setDateFromField:function(inst){var dateFormat=this._get(inst,"dateFormat");var dates=inst.input?inst.input.val():null;inst.endDay=inst.endMonth=inst.endYear=null;var date=defaultDate=this._getDefaultDate(inst);var settings=this._getFormatConfig(inst);try{date=this.parseDate(dateFormat,dates,settings)||defaultDate}catch(event){this.log(event);date=defaultDate}inst.selectedDay=date.getDate();inst.drawMonth=inst.selectedMonth=date.getMonth();inst.drawYear=inst.selectedYear=date.getFullYear();inst.currentDay=(dates?date.getDate():0);inst.currentMonth=(dates?date.getMonth():0);inst.currentYear=(dates?date.getFullYear():0);this._adjustInstDate(inst)},_getDefaultDate:function(inst){var date=this._determineDate(this._get(inst,"defaultDate"),new Date());var minDate=this._getMinMaxDate(inst,"min",true);var maxDate=this._getMinMaxDate(inst,"max");date=(minDate&&date<minDate?minDate:date);date=(maxDate&&date>maxDate?maxDate:date);return date},_determineDate:function(date,defaultDate){var offsetNumeric=function(offset){var date=new Date();date.setDate(date.getDate()+offset);return date};var offsetString=function(offset,getDaysInMonth){var date=new Date();var year=date.getFullYear();var month=date.getMonth();var day=date.getDate();var pattern=/([+-]?[0-9]+)\s*(d|D|w|W|m|M|y|Y)?/g;var matches=pattern.exec(offset);while(matches){switch(matches[2]||"d"){case"d":case"D":day+=parseInt(matches[1],10);break;case"w":case"W":day+=parseInt(matches[1],10)*7;break;case"m":case"M":month+=parseInt(matches[1],10);day=Math.min(day,getDaysInMonth(year,month));break;case"y":case"Y":year+=parseInt(matches[1],10);day=Math.min(day,getDaysInMonth(year,month));break}matches=pattern.exec(offset)}return new Date(year,month,day)};date=(date==null?defaultDate:(typeof date=="string"?offsetString(date,this._getDaysInMonth):(typeof date=="number"?(isNaN(date)?defaultDate:offsetNumeric(date)):date)));date=(date&&date.toString()=="Invalid Date"?defaultDate:date);if(date){date.setHours(0);date.setMinutes(0);date.setSeconds(0);date.setMilliseconds(0)}return this._daylightSavingAdjust(date)},_daylightSavingAdjust:function(date){if(!date){return null}date.setHours(date.getHours()>12?date.getHours()+2:0);return date},_setDate:function(inst,date,endDate){var clear=!(date);var origMonth=inst.selectedMonth;var origYear=inst.selectedYear;date=this._determineDate(date,new Date());inst.selectedDay=inst.currentDay=date.getDate();inst.drawMonth=inst.selectedMonth=inst.currentMonth=date.getMonth();inst.drawYear=inst.selectedYear=inst.currentYear=date.getFullYear();if(origMonth!=inst.selectedMonth||origYear!=inst.selectedYear){this._notifyChange(inst)}this._adjustInstDate(inst);if(inst.input){inst.input.val(clear?"":this._formatDate(inst))}},_getDate:function(inst){var startDate=(!inst.currentYear||(inst.input&&inst.input.val()=="")?null:this._daylightSavingAdjust(new Date(inst.currentYear,inst.currentMonth,inst.currentDay)));return startDate},_generateHTML:function(inst){var today=new Date();today=this._daylightSavingAdjust(new Date(today.getFullYear(),today.getMonth(),today.getDate()));var isRTL=this._get(inst,"isRTL");var showButtonPanel=this._get(inst,"showButtonPanel");var hideIfNoPrevNext=this._get(inst,"hideIfNoPrevNext");var navigationAsDateFormat=this._get(inst,"navigationAsDateFormat");var numMonths=this._getNumberOfMonths(inst);var showCurrentAtPos=this._get(inst,"showCurrentAtPos");var stepMonths=this._get(inst,"stepMonths");var stepBigMonths=this._get(inst,"stepBigMonths");var isMultiMonth=(numMonths[0]!=1||numMonths[1]!=1);var currentDate=this._daylightSavingAdjust((!inst.currentDay?new Date(9999,9,9):new Date(inst.currentYear,inst.currentMonth,inst.currentDay)));var minDate=this._getMinMaxDate(inst,"min",true);var maxDate=this._getMinMaxDate(inst,"max");var drawMonth=inst.drawMonth-showCurrentAtPos;var drawYear=inst.drawYear;if(drawMonth<0){drawMonth+=12;drawYear--}if(maxDate){var maxDraw=this._daylightSavingAdjust(new Date(maxDate.getFullYear(),maxDate.getMonth()-numMonths[1]+1,maxDate.getDate()));maxDraw=(minDate&&maxDraw<minDate?minDate:maxDraw);while(this._daylightSavingAdjust(new Date(drawYear,drawMonth,1))>maxDraw){drawMonth--;if(drawMonth<0){drawMonth=11;drawYear--}}}inst.drawMonth=drawMonth;inst.drawYear=drawYear;var prevText=this._get(inst,"prevText");prevText=(!navigationAsDateFormat?prevText:this.formatDate(prevText,this._daylightSavingAdjust(new Date(drawYear,drawMonth-stepMonths,1)),this._getFormatConfig(inst)));var prev=(this._canAdjustMonth(inst,-1,drawYear,drawMonth)?'<a class="ui-datepicker-prev ui-corner-all" onclick="DP_jQuery.datepicker._adjustDate(\'#'+inst.id+"', -"+stepMonths+", 'M');\" title=\""+prevText+'"><span class="ui-icon ui-icon-circle-triangle-'+(isRTL?"e":"w")+'">'+prevText+"</span></a>":(hideIfNoPrevNext?"":'<a class="ui-datepicker-prev ui-corner-all ui-state-disabled" title="'+prevText+'"><span class="ui-icon ui-icon-circle-triangle-'+(isRTL?"e":"w")+'">'+prevText+"</span></a>"));var nextText=this._get(inst,"nextText");nextText=(!navigationAsDateFormat?nextText:this.formatDate(nextText,this._daylightSavingAdjust(new Date(drawYear,drawMonth+stepMonths,1)),this._getFormatConfig(inst)));var next=(this._canAdjustMonth(inst,+1,drawYear,drawMonth)?'<a class="ui-datepicker-next ui-corner-all" onclick="DP_jQuery.datepicker._adjustDate(\'#'+inst.id+"', +"+stepMonths+", 'M');\" title=\""+nextText+'"><span class="ui-icon ui-icon-circle-triangle-'+(isRTL?"w":"e")+'">'+nextText+"</span></a>":(hideIfNoPrevNext?"":'<a class="ui-datepicker-next ui-corner-all ui-state-disabled" title="'+nextText+'"><span class="ui-icon ui-icon-circle-triangle-'+(isRTL?"w":"e")+'">'+nextText+"</span></a>"));var currentText=this._get(inst,"currentText");var gotoDate=(this._get(inst,"gotoCurrent")&&inst.currentDay?currentDate:today);currentText=(!navigationAsDateFormat?currentText:this.formatDate(currentText,gotoDate,this._getFormatConfig(inst)));var controls=(!inst.inline?'<button type="button" class="ui-datepicker-close ui-state-default ui-priority-primary ui-corner-all" onclick="DP_jQuery.datepicker._hideDatepicker();">'+this._get(inst,"closeText")+"</button>":"");var buttonPanel=(showButtonPanel)?'<div class="ui-datepicker-buttonpane ui-widget-content">'+(isRTL?controls:"")+(this._isInRange(inst,gotoDate)?'<button type="button" class="ui-datepicker-current ui-state-default ui-priority-secondary ui-corner-all" onclick="DP_jQuery.datepicker._gotoToday(\'#'+inst.id+"');\">"+currentText+"</button>":"")+(isRTL?"":controls)+"</div>":"";var firstDay=parseInt(this._get(inst,"firstDay"),10);firstDay=(isNaN(firstDay)?0:firstDay);var dayNames=this._get(inst,"dayNames");var dayNamesShort=this._get(inst,"dayNamesShort");var dayNamesMin=this._get(inst,"dayNamesMin");var monthNames=this._get(inst,"monthNames");var monthNamesShort=this._get(inst,"monthNamesShort");var beforeShowDay=this._get(inst,"beforeShowDay");var showOtherMonths=this._get(inst,"showOtherMonths");var calculateWeek=this._get(inst,"calculateWeek")||this.iso8601Week;var endDate=inst.endDay?this._daylightSavingAdjust(new Date(inst.endYear,inst.endMonth,inst.endDay)):currentDate;var defaultDate=this._getDefaultDate(inst);var html="";for(var row=0;row<numMonths[0];row++){var group="";for(var col=0;col<numMonths[1];col++){var selectedDate=this._daylightSavingAdjust(new Date(drawYear,drawMonth,inst.selectedDay));var cornerClass=" ui-corner-all";var calender="";if(isMultiMonth){calender+='<div class="ui-datepicker-group ui-datepicker-group-';switch(col){case 0:calender+="first";cornerClass=" ui-corner-"+(isRTL?"right":"left");break;case numMonths[1]-1:calender+="last";cornerClass=" ui-corner-"+(isRTL?"left":"right");break;default:calender+="middle";cornerClass="";break}calender+='">'}calender+='<div class="ui-datepicker-header ui-widget-header ui-helper-clearfix'+cornerClass+'">'+(/all|left/.test(cornerClass)&&row==0?(isRTL?next:prev):"")+(/all|right/.test(cornerClass)&&row==0?(isRTL?prev:next):"")+this._generateMonthYearHeader(inst,drawMonth,drawYear,minDate,maxDate,selectedDate,row>0||col>0,monthNames,monthNamesShort)+'</div><table class="ui-datepicker-calendar"><thead><tr>';var thead="";for(var dow=0;dow<7;dow++){var day=(dow+firstDay)%7;thead+="<th"+((dow+firstDay+6)%7>=5?' class="ui-datepicker-week-end"':"")+'><span title="'+dayNames[day]+'">'+dayNamesMin[day]+"</span></th>"}calender+=thead+"</tr></thead><tbody>";var daysInMonth=this._getDaysInMonth(drawYear,drawMonth);if(drawYear==inst.selectedYear&&drawMonth==inst.selectedMonth){inst.selectedDay=Math.min(inst.selectedDay,daysInMonth)}var leadDays=(this._getFirstDayOfMonth(drawYear,drawMonth)-firstDay+7)%7;var numRows=(isMultiMonth?6:Math.ceil((leadDays+daysInMonth)/7));var printDate=this._daylightSavingAdjust(new Date(drawYear,drawMonth,1-leadDays));for(var dRow=0;dRow<numRows;dRow++){calender+="<tr>";var tbody="";for(var dow=0;dow<7;dow++){var daySettings=(beforeShowDay?beforeShowDay.apply((inst.input?inst.input[0]:null),[printDate]):[true,""]);var otherMonth=(printDate.getMonth()!=drawMonth);var unselectable=otherMonth||!daySettings[0]||(minDate&&printDate<minDate)||(maxDate&&printDate>maxDate);tbody+='<td class="'+((dow+firstDay+6)%7>=5?" ui-datepicker-week-end":"")+(otherMonth?" ui-datepicker-other-month":"")+((printDate.getTime()==selectedDate.getTime()&&drawMonth==inst.selectedMonth&&inst._keyEvent)||(defaultDate.getTime()==printDate.getTime()&&defaultDate.getTime()==selectedDate.getTime())?" "+this._dayOverClass:"")+(unselectable?" "+this._unselectableClass+" ui-state-disabled":"")+(otherMonth&&!showOtherMonths?"":" "+daySettings[1]+(printDate.getTime()>=currentDate.getTime()&&printDate.getTime()<=endDate.getTime()?" "+this._currentClass:"")+(printDate.getTime()==today.getTime()?" ui-datepicker-today":""))+'"'+((!otherMonth||showOtherMonths)&&daySettings[2]?' title="'+daySettings[2]+'"':"")+(unselectable?"":" onclick=\"DP_jQuery.datepicker._selectDay('#"+inst.id+"',"+drawMonth+","+drawYear+', this);return false;"')+">"+(otherMonth?(showOtherMonths?printDate.getDate():" "):(unselectable?'<span class="ui-state-default">'+printDate.getDate()+"</span>":'<a class="ui-state-default'+(printDate.getTime()==today.getTime()?" ui-state-highlight":"")+(printDate.getTime()>=currentDate.getTime()&&printDate.getTime()<=endDate.getTime()?" ui-state-active":"")+'" href="#">'+printDate.getDate()+"</a>"))+"</td>";printDate.setDate(printDate.getDate()+1);printDate=this._daylightSavingAdjust(printDate)}calender+=tbody+"</tr>"}drawMonth++;if(drawMonth>11){drawMonth=0;drawYear++}calender+="</tbody></table>"+(isMultiMonth?"</div>"+((numMonths[0]>0&&col==numMonths[1]-1)?'<div class="ui-datepicker-row-break"></div>':""):"");group+=calender}html+=group}html+=buttonPanel+($.browser.msie&&parseInt($.browser.version,10)<7&&!inst.inline?'<iframe src="javascript:false;" class="ui-datepicker-cover" frameborder="0"></iframe>':"");inst._keyEvent=false;return html},_generateMonthYearHeader:function(inst,drawMonth,drawYear,minDate,maxDate,selectedDate,secondary,monthNames,monthNamesShort){minDate=(inst.rangeStart&&minDate&&selectedDate<minDate?selectedDate:minDate);var changeMonth=this._get(inst,"changeMonth");var changeYear=this._get(inst,"changeYear");var showMonthAfterYear=this._get(inst,"showMonthAfterYear");var html='<div class="ui-datepicker-title">';var monthHtml="";if(secondary||!changeMonth){monthHtml+='<span class="ui-datepicker-month">'+monthNames[drawMonth]+"</span> "}else{var inMinYear=(minDate&&minDate.getFullYear()==drawYear);var inMaxYear=(maxDate&&maxDate.getFullYear()==drawYear);monthHtml+='<select class="ui-datepicker-month" onchange="DP_jQuery.datepicker._selectMonthYear(\'#'+inst.id+"', this, 'M');\" onclick=\"DP_jQuery.datepicker._clickMonthYear('#"+inst.id+"');\">";for(var month=0;month<12;month++){if((!inMinYear||month>=minDate.getMonth())&&(!inMaxYear||month<=maxDate.getMonth())){monthHtml+='<option value="'+month+'"'+(month==drawMonth?' selected="selected"':"")+">"+monthNamesShort[month]+"</option>"}}monthHtml+="</select>"}if(!showMonthAfterYear){html+=monthHtml+((secondary||changeMonth||changeYear)&&(!(changeMonth&&changeYear))?" ":"")}if(secondary||!changeYear){html+='<span class="ui-datepicker-year">'+drawYear+"</span>"}else{var years=this._get(inst,"yearRange").split(":");var year=0;var endYear=0;if(years.length!=2){year=drawYear-10;endYear=drawYear+10}else{if(years[0].charAt(0)=="+"||years[0].charAt(0)=="-"){year=drawYear+parseInt(years[0],10);endYear=drawYear+parseInt(years[1],10)}else{year=parseInt(years[0],10);endYear=parseInt(years[1],10)}}year=(minDate?Math.max(year,minDate.getFullYear()):year);endYear=(maxDate?Math.min(endYear,maxDate.getFullYear()):endYear);html+='<select class="ui-datepicker-year" onchange="DP_jQuery.datepicker._selectMonthYear(\'#'+inst.id+"', this, 'Y');\" onclick=\"DP_jQuery.datepicker._clickMonthYear('#"+inst.id+"');\">";for(;year<=endYear;year++){html+='<option value="'+year+'"'+(year==drawYear?' selected="selected"':"")+">"+year+"</option>"}html+="</select>"}if(showMonthAfterYear){html+=(secondary||changeMonth||changeYear?" ":"")+monthHtml}html+="</div>";return html},_adjustInstDate:function(inst,offset,period){var year=inst.drawYear+(period=="Y"?offset:0);var month=inst.drawMonth+(period=="M"?offset:0);var day=Math.min(inst.selectedDay,this._getDaysInMonth(year,month))+(period=="D"?offset:0);var date=this._daylightSavingAdjust(new Date(year,month,day));var minDate=this._getMinMaxDate(inst,"min",true);var maxDate=this._getMinMaxDate(inst,"max");date=(minDate&&date<minDate?minDate:date);date=(maxDate&&date>maxDate?maxDate:date);inst.selectedDay=date.getDate();inst.drawMonth=inst.selectedMonth=date.getMonth();inst.drawYear=inst.selectedYear=date.getFullYear();if(period=="M"||period=="Y"){this._notifyChange(inst)}},_notifyChange:function(inst){var onChange=this._get(inst,"onChangeMonthYear");if(onChange){onChange.apply((inst.input?inst.input[0]:null),[inst.selectedYear,inst.selectedMonth+1,inst])}},_getNumberOfMonths:function(inst){var numMonths=this._get(inst,"numberOfMonths");return(numMonths==null?[1,1]:(typeof numMonths=="number"?[1,numMonths]:numMonths))},_getMinMaxDate:function(inst,minMax,checkRange){var date=this._determineDate(this._get(inst,minMax+"Date"),null);return(!checkRange||!inst.rangeStart?date:(!date||inst.rangeStart>date?inst.rangeStart:date))},_getDaysInMonth:function(year,month){return 32-new Date(year,month,32).getDate()},_getFirstDayOfMonth:function(year,month){return new Date(year,month,1).getDay()},_canAdjustMonth:function(inst,offset,curYear,curMonth){var numMonths=this._getNumberOfMonths(inst);var date=this._daylightSavingAdjust(new Date(curYear,curMonth+(offset<0?offset:numMonths[1]),1));if(offset<0){date.setDate(this._getDaysInMonth(date.getFullYear(),date.getMonth()))}return this._isInRange(inst,date)},_isInRange:function(inst,date){var newMinDate=(!inst.rangeStart?null:this._daylightSavingAdjust(new Date(inst.selectedYear,inst.selectedMonth,inst.selectedDay)));newMinDate=(newMinDate&&inst.rangeStart<newMinDate?inst.rangeStart:newMinDate);var minDate=newMinDate||this._getMinMaxDate(inst,"min");var maxDate=this._getMinMaxDate(inst,"max");return((!minDate||date>=minDate)&&(!maxDate||date<=maxDate))},_getFormatConfig:function(inst){var shortYearCutoff=this._get(inst,"shortYearCutoff");shortYearCutoff=(typeof shortYearCutoff!="string"?shortYearCutoff:new Date().getFullYear()%100+parseInt(shortYearCutoff,10));return{shortYearCutoff:shortYearCutoff,dayNamesShort:this._get(inst,"dayNamesShort"),dayNames:this._get(inst,"dayNames"),monthNamesShort:this._get(inst,"monthNamesShort"),monthNames:this._get(inst,"monthNames")}},_formatDate:function(inst,day,month,year){if(!day){inst.currentDay=inst.selectedDay;inst.currentMonth=inst.selectedMonth;inst.currentYear=inst.selectedYear}var date=(day?(typeof day=="object"?day:this._daylightSavingAdjust(new Date(year,month,day))):this._daylightSavingAdjust(new Date(inst.currentYear,inst.currentMonth,inst.currentDay)));return this.formatDate(this._get(inst,"dateFormat"),date,this._getFormatConfig(inst))}});function extendRemove(target,props){$.extend(target,props);for(var name in props){if(props[name]==null||props[name]==undefined){target[name]=props[name]}}return target}function isArray(a){return(a&&(($.browser.safari&&typeof a=="object"&&a.length)||(a.constructor&&a.constructor.toString().match(/\Array\(\)/))))}$.fn.datepicker=function(options){if(!$.datepicker.initialized){$(document).mousedown($.datepicker._checkExternalClick).find("body").append($.datepicker.dpDiv);$.datepicker.initialized=true}var otherArgs=Array.prototype.slice.call(arguments,1);if(typeof options=="string"&&(options=="isDisabled"||options=="getDate")){return $.datepicker["_"+options+"Datepicker"].apply($.datepicker,[this[0]].concat(otherArgs))}if(options=="option"&&arguments.length==2&&typeof arguments[1]=="string"){return $.datepicker["_"+options+"Datepicker"].apply($.datepicker,[this[0]].concat(otherArgs))}return this.each(function(){typeof options=="string"?$.datepicker["_"+options+"Datepicker"].apply($.datepicker,[this].concat(otherArgs)):$.datepicker._attachDatepicker(this,options)})};$.datepicker=new Datepicker();$.datepicker.initialized=false;$.datepicker.uuid=new Date().getTime();$.datepicker.version="1.7.2";window.DP_jQuery=$})(jQuery);;/*
+ * jQuery UI Progressbar 1.7.2
+ * Copyright (c) 2009 AUTHORS.txt (http://jqueryui.com/about)
+ * Dual licensed under the MIT (MIT-LICENSE.txt)
+ * and GPL (GPL-LICENSE.txt) licenses.
+ * http://docs.jquery.com/UI/Progressbar
+ * Depends:
+ * ui.core.js
+(function(a){a.widget("ui.progressbar",{_init:function(){this.element.addClass("ui-progressbar ui-widget ui-widget-content ui-corner-all").attr({role:"progressbar","aria-valuemin":this._valueMin(),"aria-valuemax":this._valueMax(),"aria-valuenow":this._value()});this.valueDiv=a('<div class="ui-progressbar-value ui-widget-header ui-corner-left"></div>').appendTo(this.element);this._refreshValue()},destroy:function(){this.element.removeClass("ui-progressbar ui-widget ui-widget-content ui-corner-all").removeAttr("role").removeAttr("aria-valuemin").removeAttr("aria-valuemax").removeAttr("aria-valuenow").removeData("progressbar").unbind(".progressbar");this.valueDiv.remove();a.widget.prototype.destroy.apply(this,arguments)},value:function(b){if(b===undefined){return this._value()}this._setData("value",b);return this},_setData:function(b,c){switch(b){case"value":this.options.value=c;this._refreshValue();this._trigger("change",null,{});break}a.widget.prototype._setData.apply(this,arguments)},_value:function(){var b=this.options.value;if(b<this._valueMin()){b=this._valueMin()}if(b>this._valueMax()){b=this._valueMax()}return b},_valueMin:function(){var b=0;return b},_valueMax:function(){var b=100;return b},_refreshValue:function(){var b=this.value();this.valueDiv[b==this._valueMax()?"addClass":"removeClass"]("ui-corner-right");this.valueDiv.width(b+"%");this.element.attr("aria-valuenow",b)}});a.extend(a.ui.progressbar,{version:"1.7.2",defaults:{value:0}})})(jQuery);;/*
+ * jQuery UI Effects 1.7.2
+ * http://docs.jquery.com/UI/Effects/
+jQuery.effects||(function(d){d.effects={version:"1.7.2",save:function(g,h){for(var f=0;f<h.length;f++){if(h[f]!==null){g.data("ec.storage."+h[f],g[0].style[h[f]])}}},restore:function(g,h){for(var f=0;f<h.length;f++){if(h[f]!==null){g.css(h[f],g.data("ec.storage."+h[f]))}}},setMode:function(f,g){if(g=="toggle"){g=f.is(":hidden")?"show":"hide"}return g},getBaseline:function(g,h){var i,f;switch(g[0]){case"top":i=0;break;case"middle":i=0.5;break;case"bottom":i=1;break;default:i=g[0]/h.height}switch(g[1]){case"left":f=0;break;case"center":f=0.5;break;case"right":f=1;break;default:f=g[1]/h.width}return{x:f,y:i}},createWrapper:function(f){if(f.parent().is(".ui-effects-wrapper")){return f.parent()}var g={width:f.outerWidth(true),height:f.outerHeight(true),"float":f.css("float")};f.wrap('<div class="ui-effects-wrapper" style="font-size:100%;background:transparent;border:none;margin:0;padding:0"></div>');var j=f.parent();if(f.css("position")=="static"){j.css({position:"relative"});f.css({position:"relative"})}else{var i=f.css("top");if(isNaN(parseInt(i,10))){i="auto"}var h=f.css("left");if(isNaN(parseInt(h,10))){h="auto"}j.css({position:f.css("position"),top:i,left:h,zIndex:f.css("z-index")}).show();f.css({position:"relative",top:0,left:0})}j.css(g);return j},removeWrapper:function(f){if(f.parent().is(".ui-effects-wrapper")){return f.parent().replaceWith(f)}return f},setTransition:function(g,i,f,h){h=h||{};d.each(i,function(k,j){unit=g.cssUnit(j);if(unit[0]>0){h[j]=unit[0]*f+unit[1]}});return h},animateClass:function(h,i,k,j){var f=(typeof k=="function"?k:(j?j:null));var g=(typeof k=="string"?k:null);return this.each(function(){var q={};var o=d(this);var p=o.attr("style")||"";if(typeof p=="object"){p=p.cssText}if(h.toggle){o.hasClass(h.toggle)?h.remove=h.toggle:h.add=h.toggle}var l=d.extend({},(document.defaultView?document.defaultView.getComputedStyle(this,null):this.currentStyle));if(h.add){o.addClass(h.add)}if(h.remove){o.removeClass(h.remove)}var m=d.extend({},(document.defaultView?document.defaultView.getComputedStyle(this,null):this.currentStyle));if(h.add){o.removeClass(h.add)}if(h.remove){o.addClass(h.remove)}for(var r in m){if(typeof m[r]!="function"&&m[r]&&r.indexOf("Moz")==-1&&r.indexOf("length")==-1&&m[r]!=l[r]&&(r.match(/color/i)||(!r.match(/color/i)&&!isNaN(parseInt(m[r],10))))&&(l.position!="static"||(l.position=="static"&&!r.match(/left|top|bottom|right/)))){q[r]=m[r]}}o.animate(q,i,g,function(){if(typeof d(this).attr("style")=="object"){d(this).attr("style")["cssText"]="";d(this).attr("style")["cssText"]=p}else{d(this).attr("style",p)}if(h.add){d(this).addClass(h.add)}if(h.remove){d(this).removeClass(h.remove)}if(f){f.apply(this,arguments)}})})}};function c(g,f){var i=g[1]&&g[1].constructor==Object?g[1]:{};if(f){i.mode=f}var h=g[1]&&g[1].constructor!=Object?g[1]:(i.duration?i.duration:g[2]);h=d.fx.off?0:typeof h==="number"?h:d.fx.speeds[h]||d.fx.speeds._default;var j=i.callback||(d.isFunction(g[1])&&g[1])||(d.isFunction(g[2])&&g[2])||(d.isFunction(g[3])&&g[3]);return[g[0],i,h,j]}d.fn.extend({_show:d.fn.show,_hide:d.fn.hide,__toggle:d.fn.toggle,_addClass:d.fn.addClass,_removeClass:d.fn.removeClass,_toggleClass:d.fn.toggleClass,effect:function(g,f,h,i){return d.effects[g]?d.effects[g].call(this,{method:g,options:f||{},duration:h,callback:i}):null},show:function(){if(!arguments[0]||(arguments[0].constructor==Number||(/(slow|normal|fast)/).test(arguments[0]))){return this._show.apply(this,arguments)}else{return this.effect.apply(this,c(arguments,"show"))}},hide:function(){if(!arguments[0]||(arguments[0].constructor==Number||(/(slow|normal|fast)/).test(arguments[0]))){return this._hide.apply(this,arguments)}else{return this.effect.apply(this,c(arguments,"hide"))}},toggle:function(){if(!arguments[0]||(arguments[0].constructor==Number||(/(slow|normal|fast)/).test(arguments[0]))||(d.isFunction(arguments[0])||typeof arguments[0]=="boolean")){return this.__toggle.apply(this,arguments)}else{return this.effect.apply(this,c(arguments,"toggle"))}},addClass:function(g,f,i,h){return f?d.effects.animateClass.apply(this,[{add:g},f,i,h]):this._addClass(g)},removeClass:function(g,f,i,h){return f?d.effects.animateClass.apply(this,[{remove:g},f,i,h]):this._removeClass(g)},toggleClass:function(g,f,i,h){return((typeof f!=="boolean")&&f)?d.effects.animateClass.apply(this,[{toggle:g},f,i,h]):this._toggleClass(g,f)},morph:function(f,h,g,j,i){return d.effects.animateClass.apply(this,[{add:h,remove:f},g,j,i])},switchClass:function(){return this.morph.apply(this,arguments)},cssUnit:function(f){var g=this.css(f),h=[];d.each(["em","px","%","pt"],function(j,k){if(g.indexOf(k)>0){h=[parseFloat(g),k]}});return h}});d.each(["backgroundColor","borderBottomColor","borderLeftColor","borderRightColor","borderTopColor","color","outlineColor"],function(g,f){d.fx.step[f]=function(h){if(h.state==0){h.start=e(h.elem,f);h.end=b(h.end)}h.elem.style[f]="rgb("+[Math.max(Math.min(parseInt((h.pos*(h.end[0]-h.start[0]))+h.start[0],10),255),0),Math.max(Math.min(parseInt((h.pos*(h.end[1]-h.start[1]))+h.start[1],10),255),0),Math.max(Math.min(parseInt((h.pos*(h.end[2]-h.start[2]))+h.start[2],10),255),0)].join(",")+")"}});function b(g){var f;if(g&&g.constructor==Array&&g.length==3){return g}if(f=/rgb\(\s*([0-9]{1,3})\s*,\s*([0-9]{1,3})\s*,\s*([0-9]{1,3})\s*\)/.exec(g)){return[parseInt(f[1],10),parseInt(f[2],10),parseInt(f[3],10)]}if(f=/rgb\(\s*([0-9]+(?:\.[0-9]+)?)\%\s*,\s*([0-9]+(?:\.[0-9]+)?)\%\s*,\s*([0-9]+(?:\.[0-9]+)?)\%\s*\)/.exec(g)){return[parseFloat(f[1])*2.55,parseFloat(f[2])*2.55,parseFloat(f[3])*2.55]}if(f=/#([a-fA-F0-9]{2})([a-fA-F0-9]{2})([a-fA-F0-9]{2})/.exec(g)){return[parseInt(f[1],16),parseInt(f[2],16),parseInt(f[3],16)]}if(f=/#([a-fA-F0-9])([a-fA-F0-9])([a-fA-F0-9])/.exec(g)){return[parseInt(f[1]+f[1],16),parseInt(f[2]+f[2],16),parseInt(f[3]+f[3],16)]}if(f=/rgba\(0, 0, 0, 0\)/.exec(g)){return a.transparent}return a[d.trim(g).toLowerCase()]}function e(h,f){var g;do{g=d.curCSS(h,f);if(g!=""&&g!="transparent"||d.nodeName(h,"body")){break}f="backgroundColor"}while(h=h.parentNode);return b(g)}var a={aqua:[0,255,255],azure:[240,255,255],beige:[245,245,220],black:[0,0,0],blue:[0,0,255],brown:[165,42,42],cyan:[0,255,255],darkblue:[0,0,139],darkcyan:[0,139,139],darkgrey:[169,169,169],darkgreen:[0,100,0],darkkhaki:[189,183,107],darkmagenta:[139,0,139],darkolivegreen:[85,107,47],darkorange:[255,140,0],darkorchid:[153,50,204],darkred:[139,0,0],darksalmon:[233,150,122],darkviolet:[148,0,211],fuchsia:[255,0,255],gold:[255,215,0],green:[0,128,0],indigo:[75,0,130],khaki:[240,230,140],lightblue:[173,216,230],lightcyan:[224,255,255],lightgreen:[144,238,144],lightgrey:[211,211,211],lightpink:[255,182,193],lightyellow:[255,255,224],lime:[0,255,0],magenta:[255,0,255],maroon:[128,0,0],navy:[0,0,128],olive:[128,128,0],orange:[255,165,0],pink:[255,192,203],purple:[128,0,128],violet:[128,0,128],red:[255,0,0],silver:[192,192,192],white:[255,255,255],yellow:[255,255,0],transparent:[255,255,255]};d.easing.jswing=d.easing.swing;d.extend(d.easing,{def:"easeOutQuad",swing:function(g,h,f,j,i){return d.easing[d.easing.def](g,h,f,j,i)},easeInQuad:function(g,h,f,j,i){return j*(h/=i)*h+f},easeOutQuad:function(g,h,f,j,i){return -j*(h/=i)*(h-2)+f},easeInOutQuad:function(g,h,f,j,i){if((h/=i/2)<1){return j/2*h*h+f}return -j/2*((--h)*(h-2)-1)+f},easeInCubic:function(g,h,f,j,i){return j*(h/=i)*h*h+f},easeOutCubic:function(g,h,f,j,i){return j*((h=h/i-1)*h*h+1)+f},easeInOutCubic:function(g,h,f,j,i){if((h/=i/2)<1){return j/2*h*h*h+f}return j/2*((h-=2)*h*h+2)+f},easeInQuart:function(g,h,f,j,i){return j*(h/=i)*h*h*h+f},easeOutQuart:function(g,h,f,j,i){return -j*((h=h/i-1)*h*h*h-1)+f},easeInOutQuart:function(g,h,f,j,i){if((h/=i/2)<1){return j/2*h*h*h*h+f}return -j/2*((h-=2)*h*h*h-2)+f},easeInQuint:function(g,h,f,j,i){return j*(h/=i)*h*h*h*h+f},easeOutQuint:function(g,h,f,j,i){return j*((h=h/i-1)*h*h*h*h+1)+f},easeInOutQuint:function(g,h,f,j,i){if((h/=i/2)<1){return j/2*h*h*h*h*h+f}return j/2*((h-=2)*h*h*h*h+2)+f},easeInSine:function(g,h,f,j,i){return -j*Math.cos(h/i*(Math.PI/2))+j+f},easeOutSine:function(g,h,f,j,i){return j*Math.sin(h/i*(Math.PI/2))+f},easeInOutSine:function(g,h,f,j,i){return -j/2*(Math.cos(Math.PI*h/i)-1)+f},easeInExpo:function(g,h,f,j,i){return(h==0)?f:j*Math.pow(2,10*(h/i-1))+f},easeOutExpo:function(g,h,f,j,i){return(h==i)?f+j:j*(-Math.pow(2,-10*h/i)+1)+f},easeInOutExpo:function(g,h,f,j,i){if(h==0){return f}if(h==i){return f+j}if((h/=i/2)<1){return j/2*Math.pow(2,10*(h-1))+f}return j/2*(-Math.pow(2,-10*--h)+2)+f},easeInCirc:function(g,h,f,j,i){return -j*(Math.sqrt(1-(h/=i)*h)-1)+f},easeOutCirc:function(g,h,f,j,i){return j*Math.sqrt(1-(h=h/i-1)*h)+f},easeInOutCirc:function(g,h,f,j,i){if((h/=i/2)<1){return -j/2*(Math.sqrt(1-h*h)-1)+f}return j/2*(Math.sqrt(1-(h-=2)*h)+1)+f},easeInElastic:function(g,i,f,m,l){var j=1.70158;var k=0;var h=m;if(i==0){return f}if((i/=l)==1){return f+m}if(!k){k=l*0.3}if(h<Math.abs(m)){h=m;var j=k/4}else{var j=k/(2*Math.PI)*Math.asin(m/h)}return -(h*Math.pow(2,10*(i-=1))*Math.sin((i*l-j)*(2*Math.PI)/k))+f},easeOutElastic:function(g,i,f,m,l){var j=1.70158;var k=0;var h=m;if(i==0){return f}if((i/=l)==1){return f+m}if(!k){k=l*0.3}if(h<Math.abs(m)){h=m;var j=k/4}else{var j=k/(2*Math.PI)*Math.asin(m/h)}return h*Math.pow(2,-10*i)*Math.sin((i*l-j)*(2*Math.PI)/k)+m+f},easeInOutElastic:function(g,i,f,m,l){var j=1.70158;var k=0;var h=m;if(i==0){return f}if((i/=l/2)==2){return f+m}if(!k){k=l*(0.3*1.5)}if(h<Math.abs(m)){h=m;var j=k/4}else{var j=k/(2*Math.PI)*Math.asin(m/h)}if(i<1){return -0.5*(h*Math.pow(2,10*(i-=1))*Math.sin((i*l-j)*(2*Math.PI)/k))+f}return h*Math.pow(2,-10*(i-=1))*Math.sin((i*l-j)*(2*Math.PI)/k)*0.5+m+f},easeInBack:function(g,h,f,k,j,i){if(i==undefined){i=1.70158}return k*(h/=j)*h*((i+1)*h-i)+f},easeOutBack:function(g,h,f,k,j,i){if(i==undefined){i=1.70158}return k*((h=h/j-1)*h*((i+1)*h+i)+1)+f},easeInOutBack:function(g,h,f,k,j,i){if(i==undefined){i=1.70158}if((h/=j/2)<1){return k/2*(h*h*(((i*=(1.525))+1)*h-i))+f}return k/2*((h-=2)*h*(((i*=(1.525))+1)*h+i)+2)+f},easeInBounce:function(g,h,f,j,i){return j-d.easing.easeOutBounce(g,i-h,0,j,i)+f},easeOutBounce:function(g,h,f,j,i){if((h/=i)<(1/2.75)){return j*(7.5625*h*h)+f}else{if(h<(2/2.75)){return j*(7.5625*(h-=(1.5/2.75))*h+0.75)+f}else{if(h<(2.5/2.75)){return j*(7.5625*(h-=(2.25/2.75))*h+0.9375)+f}else{return j*(7.5625*(h-=(2.625/2.75))*h+0.984375)+f}}}},easeInOutBounce:function(g,h,f,j,i){if(h<i/2){return d.easing.easeInBounce(g,h*2,0,j,i)*0.5+f}return d.easing.easeOutBounce(g,h*2-i,0,j,i)*0.5+j*0.5+f}})})(jQuery);;/*
+ * jQuery UI Effects Blind 1.7.2
+ * http://docs.jquery.com/UI/Effects/Blind
+ * Depends:
+ * effects.core.js
+(function(a){a.effects.blind=function(b){return this.queue(function(){var d=a(this),c=["position","top","left"];var h=a.effects.setMode(d,b.options.mode||"hide");var g=b.options.direction||"vertical";a.effects.save(d,c);d.show();var j=a.effects.createWrapper(d).css({overflow:"hidden"});var e=(g=="vertical")?"height":"width";var i=(g=="vertical")?j.height():j.width();if(h=="show"){j.css(e,0)}var f={};f[e]=h=="show"?i:0;j.animate(f,b.duration,b.options.easing,function(){if(h=="hide"){d.hide()}a.effects.restore(d,c);a.effects.removeWrapper(d);if(b.callback){b.callback.apply(d[0],arguments)}d.dequeue()})})}})(jQuery);;/*
+ * jQuery UI Effects Bounce 1.7.2
+ * http://docs.jquery.com/UI/Effects/Bounce
+ * Depends:
+ * effects.core.js
+(function(a){a.effects.bounce=function(b){return this.queue(function(){var e=a(this),l=["position","top","left"];var k=a.effects.setMode(e,b.options.mode||"effect");var n=b.options.direction||"up";var c=b.options.distance||20;var d=b.options.times||5;var g=b.duration||250;if(/show|hide/.test(k)){l.push("opacity")}a.effects.save(e,l);e.show();a.effects.createWrapper(e);var f=(n=="up"||n=="down")?"top":"left";var p=(n=="up"||n=="left")?"pos":"neg";var c=b.options.distance||(f=="top"?e.outerHeight({margin:true})/3:e.outerWidth({margin:true})/3);if(k=="show"){e.css("opacity",0).css(f,p=="pos"?-c:c)}if(k=="hide"){c=c/(d*2)}if(k!="hide"){d--}if(k=="show"){var h={opacity:1};h[f]=(p=="pos"?"+=":"-=")+c;e.animate(h,g/2,b.options.easing);c=c/2;d--}for(var j=0;j<d;j++){var o={},m={};o[f]=(p=="pos"?"-=":"+=")+c;m[f]=(p=="pos"?"+=":"-=")+c;e.animate(o,g/2,b.options.easing).animate(m,g/2,b.options.easing);c=(k=="hide")?c*2:c/2}if(k=="hide"){var h={opacity:0};h[f]=(p=="pos"?"-=":"+=")+c;e.animate(h,g/2,b.options.easing,function(){e.hide();a.effects.restore(e,l);a.effects.removeWrapper(e);if(b.callback){b.callback.apply(this,arguments)}})}else{var o={},m={};o[f]=(p=="pos"?"-=":"+=")+c;m[f]=(p=="pos"?"+=":"-=")+c;e.animate(o,g/2,b.options.easing).animate(m,g/2,b.options.easing,function(){a.effects.restore(e,l);a.effects.removeWrapper(e);if(b.callback){b.callback.apply(this,arguments)}})}e.queue("fx",function(){e.dequeue()});e.dequeue()})}})(jQuery);;/*
+ * jQuery UI Effects Clip 1.7.2
+ * http://docs.jquery.com/UI/Effects/Clip
+ * Depends:
+ * effects.core.js
+(function(a){a.effects.clip=function(b){return this.queue(function(){var f=a(this),j=["position","top","left","height","width"];var i=a.effects.setMode(f,b.options.mode||"hide");var k=b.options.direction||"vertical";a.effects.save(f,j);f.show();var c=a.effects.createWrapper(f).css({overflow:"hidden"});var e=f[0].tagName=="IMG"?c:f;var g={size:(k=="vertical")?"height":"width",position:(k=="vertical")?"top":"left"};var d=(k=="vertical")?e.height():e.width();if(i=="show"){e.css(g.size,0);e.css(g.position,d/2)}var h={};h[g.size]=i=="show"?d:0;h[g.position]=i=="show"?0:d/2;e.animate(h,{queue:false,duration:b.duration,easing:b.options.easing,complete:function(){if(i=="hide"){f.hide()}a.effects.restore(f,j);a.effects.removeWrapper(f);if(b.callback){b.callback.apply(f[0],arguments)}f.dequeue()}})})}})(jQuery);;/*
+ * jQuery UI Effects Drop 1.7.2
+ * http://docs.jquery.com/UI/Effects/Drop
+ * Depends:
+ * effects.core.js
+(function(a){a.effects.drop=function(b){return this.queue(function(){var e=a(this),d=["position","top","left","opacity"];var i=a.effects.setMode(e,b.options.mode||"hide");var h=b.options.direction||"left";a.effects.save(e,d);e.show();a.effects.createWrapper(e);var f=(h=="up"||h=="down")?"top":"left";var c=(h=="up"||h=="left")?"pos":"neg";var j=b.options.distance||(f=="top"?e.outerHeight({margin:true})/2:e.outerWidth({margin:true})/2);if(i=="show"){e.css("opacity",0).css(f,c=="pos"?-j:j)}var g={opacity:i=="show"?1:0};g[f]=(i=="show"?(c=="pos"?"+=":"-="):(c=="pos"?"-=":"+="))+j;e.animate(g,{queue:false,duration:b.duration,easing:b.options.easing,complete:function(){if(i=="hide"){e.hide()}a.effects.restore(e,d);a.effects.removeWrapper(e);if(b.callback){b.callback.apply(this,arguments)}e.dequeue()}})})}})(jQuery);;/*
+ * jQuery UI Effects Explode 1.7.2
+ * http://docs.jquery.com/UI/Effects/Explode
+ * Depends:
+ * effects.core.js
+(function(a){a.effects.explode=function(b){return this.queue(function(){var k=b.options.pieces?Math.round(Math.sqrt(b.options.pieces)):3;var e=b.options.pieces?Math.round(Math.sqrt(b.options.pieces)):3;b.options.mode=b.options.mode=="toggle"?(a(this).is(":visible")?"hide":"show"):b.options.mode;var h=a(this).show().css("visibility","hidden");var l=h.offset();l.top-=parseInt(h.css("marginTop"),10)||0;l.left-=parseInt(h.css("marginLeft"),10)||0;var g=h.outerWidth(true);var c=h.outerHeight(true);for(var f=0;f<k;f++){for(var d=0;d<e;d++){h.clone().appendTo("body").wrap("<div></div>").css({position:"absolute",visibility:"visible",left:-d*(g/e),top:-f*(c/k)}).parent().addClass("ui-effects-explode").css({position:"absolute",overflow:"hidden",width:g/e,height:c/k,left:l.left+d*(g/e)+(b.options.mode=="show"?(d-Math.floor(e/2))*(g/e):0),top:l.top+f*(c/k)+(b.options.mode=="show"?(f-Math.floor(k/2))*(c/k):0),opacity:b.options.mode=="show"?0:1}).animate({left:l.left+d*(g/e)+(b.options.mode=="show"?0:(d-Math.floor(e/2))*(g/e)),top:l.top+f*(c/k)+(b.options.mode=="show"?0:(f-Math.floor(k/2))*(c/k)),opacity:b.options.mode=="show"?1:0},b.duration||500)}}setTimeout(function(){b.options.mode=="show"?h.css({visibility:"visible"}):h.css({visibility:"visible"}).hide();if(b.callback){b.callback.apply(h[0])}h.dequeue();a("div.ui-effects-explode").remove()},b.duration||500)})}})(jQuery);;/*
+ * jQuery UI Effects Fold 1.7.2
+ * http://docs.jquery.com/UI/Effects/Fold
+ * Depends:
+ * effects.core.js
+(function(a){a.effects.fold=function(b){return this.queue(function(){var e=a(this),k=["position","top","left"];var h=a.effects.setMode(e,b.options.mode||"hide");var o=b.options.size||15;var n=!(!b.options.horizFirst);var g=b.duration?b.duration/2:a.fx.speeds._default/2;a.effects.save(e,k);e.show();var d=a.effects.createWrapper(e).css({overflow:"hidden"});var i=((h=="show")!=n);var f=i?["width","height"]:["height","width"];var c=i?[d.width(),d.height()]:[d.height(),d.width()];var j=/([0-9]+)%/.exec(o);if(j){o=parseInt(j[1],10)/100*c[h=="hide"?0:1]}if(h=="show"){d.css(n?{height:0,width:o}:{height:o,width:0})}var m={},l={};m[f[0]]=h=="show"?c[0]:o;l[f[1]]=h=="show"?c[1]:0;d.animate(m,g,b.options.easing).animate(l,g,b.options.easing,function(){if(h=="hide"){e.hide()}a.effects.restore(e,k);a.effects.removeWrapper(e);if(b.callback){b.callback.apply(e[0],arguments)}e.dequeue()})})}})(jQuery);;/*
+ * jQuery UI Effects Highlight 1.7.2
+ * http://docs.jquery.com/UI/Effects/Highlight
+ * Depends:
+ * effects.core.js
+(function(a){a.effects.highlight=function(b){return this.queue(function(){var e=a(this),d=["backgroundImage","backgroundColor","opacity"];var h=a.effects.setMode(e,b.options.mode||"show");var c=b.options.color||"#ffff99";var g=e.css("backgroundColor");a.effects.save(e,d);e.show();e.css({backgroundImage:"none",backgroundColor:c});var f={backgroundColor:g};if(h=="hide"){f.opacity=0}e.animate(f,{queue:false,duration:b.duration,easing:b.options.easing,complete:function(){if(h=="hide"){e.hide()}a.effects.restore(e,d);if(h=="show"&&a.browser.msie){this.style.removeAttribute("filter")}if(b.callback){b.callback.apply(this,arguments)}e.dequeue()}})})}})(jQuery);;/*
+ * jQuery UI Effects Pulsate 1.7.2
+ * http://docs.jquery.com/UI/Effects/Pulsate
+ * Depends:
+ * effects.core.js
+(function(a){a.effects.pulsate=function(b){return this.queue(function(){var d=a(this);var g=a.effects.setMode(d,b.options.mode||"show");var f=b.options.times||5;var e=b.duration?b.duration/2:a.fx.speeds._default/2;if(g=="hide"){f--}if(d.is(":hidden")){d.css("opacity",0);d.show();d.animate({opacity:1},e,b.options.easing);f=f-2}for(var c=0;c<f;c++){d.animate({opacity:0},e,b.options.easing).animate({opacity:1},e,b.options.easing)}if(g=="hide"){d.animate({opacity:0},e,b.options.easing,function(){d.hide();if(b.callback){b.callback.apply(this,arguments)}})}else{d.animate({opacity:0},e,b.options.easing).animate({opacity:1},e,b.options.easing,function(){if(b.callback){b.callback.apply(this,arguments)}})}d.queue("fx",function(){d.dequeue()});d.dequeue()})}})(jQuery);;/*
+ * jQuery UI Effects Scale 1.7.2
+ * http://docs.jquery.com/UI/Effects/Scale
+ * Depends:
+ * effects.core.js
+(function(a){a.effects.puff=function(b){return this.queue(function(){var f=a(this);var c=a.extend(true,{},b.options);var h=a.effects.setMode(f,b.options.mode||"hide");var g=parseInt(b.options.percent,10)||150;c.fade=true;var e={height:f.height(),width:f.width()};var d=g/100;f.from=(h=="hide")?e:{height:e.height*d,width:e.width*d};c.from=f.from;c.percent=(h=="hide")?g:100;c.mode=h;f.effect("scale",c,b.duration,b.callback);f.dequeue()})};a.effects.scale=function(b){return this.queue(function(){var g=a(this);var d=a.extend(true,{},b.options);var j=a.effects.setMode(g,b.options.mode||"effect");var h=parseInt(b.options.percent,10)||(parseInt(b.options.percent,10)==0?0:(j=="hide"?0:100));var i=b.options.direction||"both";var c=b.options.origin;if(j!="effect"){d.origin=c||["middle","center"];d.restore=true}var f={height:g.height(),width:g.width()};g.from=b.options.from||(j=="show"?{height:0,width:0}:f);var e={y:i!="horizontal"?(h/100):1,x:i!="vertical"?(h/100):1};g.to={height:f.height*e.y,width:f.width*e.x};if(b.options.fade){if(j=="show"){g.from.opacity=0;g.to.opacity=1}if(j=="hide"){g.from.opacity=1;g.to.opacity=0}}d.from=g.from;d.to=g.to;d.mode=j;g.effect("size",d,b.duration,b.callback);g.dequeue()})};a.effects.size=function(b){return this.queue(function(){var c=a(this),n=["position","top","left","width","height","overflow","opacity"];var m=["position","top","left","overflow","opacity"];var j=["width","height","overflow"];var p=["fontSize"];var k=["borderTopWidth","borderBottomWidth","paddingTop","paddingBottom"];var f=["borderLeftWidth","borderRightWidth","paddingLeft","paddingRight"];var g=a.effects.setMode(c,b.options.mode||"effect");var i=b.options.restore||false;var e=b.options.scale||"both";var o=b.options.origin;var d={height:c.height(),width:c.width()};c.from=b.options.from||d;c.to=b.options.to||d;if(o){var h=a.effects.getBaseline(o,d);c.from.top=(d.height-c.from.height)*h.y;c.from.left=(d.width-c.from.width)*h.x;c.to.top=(d.height-c.to.height)*h.y;c.to.left=(d.width-c.to.width)*h.x}var l={from:{y:c.from.height/d.height,x:c.from.width/d.width},to:{y:c.to.height/d.height,x:c.to.width/d.width}};if(e=="box"||e=="both"){if(l.from.y!=l.to.y){n=n.concat(k);c.from=a.effects.setTransition(c,k,l.from.y,c.from);c.to=a.effects.setTransition(c,k,l.to.y,c.to)}if(l.from.x!=l.to.x){n=n.concat(f);c.from=a.effects.setTransition(c,f,l.from.x,c.from);c.to=a.effects.setTransition(c,f,l.to.x,c.to)}}if(e=="content"||e=="both"){if(l.from.y!=l.to.y){n=n.concat(p);c.from=a.effects.setTransition(c,p,l.from.y,c.from);c.to=a.effects.setTransition(c,p,l.to.y,c.to)}}a.effects.save(c,i?n:m);c.show();a.effects.createWrapper(c);c.css("overflow","hidden").css(c.from);if(e=="content"||e=="both"){k=k.concat(["marginTop","marginBottom"]).concat(p);f=f.concat(["marginLeft","marginRight"]);j=n.concat(k).concat(f);c.find("*[width]").each(function(){child=a(this);if(i){a.effects.save(child,j)}var q={height:child.height(),width:child.width()};child.from={height:q.height*l.from.y,width:q.width*l.from.x};child.to={height:q.height*l.to.y,width:q.width*l.to.x};if(l.from.y!=l.to.y){child.from=a.effects.setTransition(child,k,l.from.y,child.from);child.to=a.effects.setTransition(child,k,l.to.y,child.to)}if(l.from.x!=l.to.x){child.from=a.effects.setTransition(child,f,l.from.x,child.from);child.to=a.effects.setTransition(child,f,l.to.x,child.to)}child.css(child.from);child.animate(child.to,b.duration,b.options.easing,function(){if(i){a.effects.restore(child,j)}})})}c.animate(c.to,{queue:false,duration:b.duration,easing:b.options.easing,complete:function(){if(g=="hide"){c.hide()}a.effects.restore(c,i?n:m);a.effects.removeWrapper(c);if(b.callback){b.callback.apply(this,arguments)}c.dequeue()}})})}})(jQuery);;/*
+ * jQuery UI Effects Shake 1.7.2
+ * http://docs.jquery.com/UI/Effects/Shake
+ * Depends:
+ * effects.core.js
+(function(a){a.effects.shake=function(b){return this.queue(function(){var e=a(this),l=["position","top","left"];var k=a.effects.setMode(e,b.options.mode||"effect");var n=b.options.direction||"left";var c=b.options.distance||20;var d=b.options.times||3;var g=b.duration||b.options.duration||140;a.effects.save(e,l);e.show();a.effects.createWrapper(e);var f=(n=="up"||n=="down")?"top":"left";var p=(n=="up"||n=="left")?"pos":"neg";var h={},o={},m={};h[f]=(p=="pos"?"-=":"+=")+c;o[f]=(p=="pos"?"+=":"-=")+c*2;m[f]=(p=="pos"?"-=":"+=")+c*2;e.animate(h,g,b.options.easing);for(var j=1;j<d;j++){e.animate(o,g,b.options.easing).animate(m,g,b.options.easing)}e.animate(o,g,b.options.easing).animate(h,g/2,b.options.easing,function(){a.effects.restore(e,l);a.effects.removeWrapper(e);if(b.callback){b.callback.apply(this,arguments)}});e.queue("fx",function(){e.dequeue()});e.dequeue()})}})(jQuery);;/*
+ * jQuery UI Effects Slide 1.7.2
+ * http://docs.jquery.com/UI/Effects/Slide
+ * Depends:
+ * effects.core.js
+(function(a){a.effects.slide=function(b){return this.queue(function(){var e=a(this),d=["position","top","left"];var i=a.effects.setMode(e,b.options.mode||"show");var h=b.options.direction||"left";a.effects.save(e,d);e.show();a.effects.createWrapper(e).css({overflow:"hidden"});var f=(h=="up"||h=="down")?"top":"left";var c=(h=="up"||h=="left")?"pos":"neg";var j=b.options.distance||(f=="top"?e.outerHeight({margin:true}):e.outerWidth({margin:true}));if(i=="show"){e.css(f,c=="pos"?-j:j)}var g={};g[f]=(i=="show"?(c=="pos"?"+=":"-="):(c=="pos"?"-=":"+="))+j;e.animate(g,{queue:false,duration:b.duration,easing:b.options.easing,complete:function(){if(i=="hide"){e.hide()}a.effects.restore(e,d);a.effects.removeWrapper(e);if(b.callback){b.callback.apply(this,arguments)}e.dequeue()}})})}})(jQuery);;/*
+ * jQuery UI Effects Transfer 1.7.2
+ * http://docs.jquery.com/UI/Effects/Transfer
+ * Depends:
+ * effects.core.js
+(function(a){a.effects.transfer=function(b){return this.queue(function(){var f=a(this),h=a(b.options.to),e=h.offset(),g={top:e.top,left:e.left,height:h.innerHeight(),width:h.innerWidth()},d=f.offset(),c=a('<div class="ui-effects-transfer"></div>').appendTo(document.body).addClass(b.options.className).css({top:d.top,left:d.left,height:f.innerHeight(),width:f.innerWidth(),position:"absolute"}).animate(g,b.duration,b.options.easing,function(){c.remove();(b.callback&&b.callback.apply(f[0],arguments));f.dequeue()})})}})(jQuery);;
\ No newline at end of file
Added: branches/print_dev/http/javascripts/ConfEditor.js
--- branches/print_dev/http/javascripts/ConfEditor.js (rev 0)
+++ branches/print_dev/http/javascripts/ConfEditor.js 2009-09-28 14:33:00 UTC (rev 4761)
@@ -0,0 +1,163 @@
+var ConfEditor = function(){
+ConfEditor.prototype.load = function(key){
+ var objectParams = {options: this.options,
+ fields: this.defaultFields,
+ url: this.rpcEndpoint,
+ name: key};
+ this.confObject = new ConfObject(objectParams);
+ this.confObject.setEditor(this);
+ // if key is not specified the default values are used
+ // and the save method is set to be an alias for create
+ if(!key)
+ for(field in this.confObject.fields)
+ this.confObject.fields[field].value = this.confObject.fields[field].defaultValue;
+ ConfEditor.prototype.save = ConfEditor.prototype.create;
+ this.display();
+ return;
+ //else we try to load the object by the specified key
+ try{
+ this.confObject.load(key);
+ }catch(E){
+ alert("ConfEditor: unable to Load : "+ key +". ("+ E +")");
+ConfEditor.prototype.remove = function(){
+ if(this.confObject)
+ //TODO: do something nicer
+ try{
+ this.confObject.remove();
+ }catch(E){
+ alert(E);
+ }else{
+ //TODO: notify user
+ alert("can't remove: no user loaded");
+ConfEditor.prototype.commit = function(){
+ if(this.confObject.name){
+ try{
+ switch(this.confObject.fields[field].type)
+ case 'text':
+ try{
+ this.confObject.fields[field].value = $('#' + this.options.id + this.confObject.fields[field].name ).val();
+ }catch(E){
+ alert("Error trying to set " +E);
+ break;
+ case 'bool':
+ var selector = '#' + this.options.id + this.confObject.fields[field].name + ':checked '
+ var el = $(selector);
+ //FIXME: need the value of the checkbox
+ this.confObject.fields[field].value = $('#' + this.options.id + this.confObject.fields[field].name ).is('checked');
+ break;
+ this.confObject.update();
+ }catch(E){
+ alert("ConfEditor: unable to Commit : ("+ E +")");
+ }else{
+ alert("cant save : no user loaded");
+ConfEditor.prototype.create = function(){
+ //see comments in display
+ try{
+ this.confObject.fields[field].value = $('#' + this.options.id + this.confObject.fields[field].name).val();
+ }catch(E){
+ alert("Error trying to read fieldvalue " +E);
+ try{
+ this.confObject.create();
+ }catch(E){
+ alert("ConfEditor: unable to Create: ("+ E +")");
+ this.refresh();
+ ConfEditor.prototype.save = ConfEditor.prototype.commit;
+ConfEditor.prototype.save = ConfEditor.prototype.commit;
+ConfEditor.prototype.refresh = function() {
+ if(this.confObject){
+ this.confObject.load(this.confObject.name);
+ }else{
+ alert("can't refresh : no user loaded");
+ConfEditor.prototype.display = function(){
+ $('#' + this.options.id + 'nameheader').text(this.confObject.name);
+ //FIXME: this needs to differentiate between the different possible fieldtypes
+ case 'text':
+ try{
+ $('#' + this.options.id + this.confObject.fields[field].name).val(this.confObject.fields[field].value);
+ }catch(E){
+ break;
+ case 'bool':
+ if(this.confObject.fields[field].value === true)
+ $('#' + this.options.id + this.confObject.fields[field].name).val(true);
+ }else{
+ $('#' + this.options.id + this.confObject.fields[field].name).val(false);
+ConfEditor.prototype.reset = function(){
+ //see comments in display();
+ var objectParams = {options: this.options, fields: this.defaultFields, url: this.rpcEndpoint};
+ this.confObject = this.confObject || new ConfObject(objectParams);
+ try{
+ $('#' + this.options.id + this.confObject.fields[field].name).val(this.confObject.fields[field].defaultValue);
+ }catch(E){
+ConfEditor.prototype.setList = function(newList) {
+ this.list = newList || null;
Added: branches/print_dev/http/javascripts/ConfObject.js
--- branches/print_dev/http/javascripts/ConfObject.js (rev 0)
+++ branches/print_dev/http/javascripts/ConfObject.js 2009-09-28 14:33:00 UTC (rev 4761)
@@ -0,0 +1,108 @@
+var ConfObject = function(params) {
+ this.options = params.options || null;
+ this.fields = params.fields || {};
+ this.url = params.url || "";
+ this.name = params.name || null;
+ConfObject.prototype.load = function(key) {
+ var me = this;
+ var options = {
+ url : me.url,
+ method : "load",
+ parameters : {
+ name : key
+ callback:(function(result,success,message){
+ if(result.data.error){
+ throw("Could not load ConfObject, server said: " + message);
+ return;
+ for(key in result.data)
+ me.fields[key].value = result.data[key];
+ me.editor.display();
+ var req = Mapbender.Ajax.Request(options);
+ req.send();
+ConfObject.prototype.remove = function(){
+ var me = this;
+ var req = Mapbender.Ajax.Request({
+ url : me.url,
+ method : "remove",
+ parameters : {
+ name : me.name
+ callback : function(result,success,message){
+ me.editor.list.load();
+ req.send();
+ConfObject.prototype.update = function(){
+ var me = this;
+ var lightFields = {};
+ for(field in me.fields)
+ lightFields[field] = me.fields[field].value;
+ var options = {
+ url : me.url,
+ method : "update",
+ parameters : {
+ name : me.name,
+ fields : lightFields
+ if(result.error){
+ alert("Could not load ConfObject, server said: " + message);
+ return;
+ me.name = result.name ||me.name;
+ req.send();
+ConfObject.prototype.create = function(){
+ var me = this;
+ var lightfields = {}
+ lightfields[field] = me.fields[field].value;
+ me.name = me.fields.name.value;
+ var options = {
+ url : me.url,
+ method : "create",
+ parameters : {
+ name : me.name,
+ fields : lightfields
+ if(result.error){
+ alert("Could not create ConfObject, server said: " + message);
+ return;
+ req.send();
+ConfObject.prototype.setEditor = function(newEditor) {
+ this.editor = newEditor || null;
Added: branches/print_dev/http/javascripts/group.php
--- branches/print_dev/http/javascripts/group.php (rev 0)
+++ branches/print_dev/http/javascripts/group.php 2009-09-28 14:33:00 UTC (rev 4761)
@@ -0,0 +1,16 @@
+<?php
+require_once(dirname(__FILE___)."/../classes/class_mb_exception.php");
+require_once(dirname(__FILE___)."/../classes/class_group.php");
+require_once(dirname(__FILE___)."/../classes/class_RPCEndpoint.php");
+require_once(dirname(__FILE___)."/../classes/class_json.php");
+$ajaxResponse = new AjaxResponse($_REQUEST);
+$ObjectConf = array("DisplayName" => "Group",
+ "internalName" => "group",
+ "ClassName" => "Group");
+$rpc = new RPCEndpoint($ObjectConf,$ajaxResponse);
+$rpc->run();
Added: branches/print_dev/http/javascripts/gui.php
--- branches/print_dev/http/javascripts/gui.php (rev 0)
+++ branches/print_dev/http/javascripts/gui.php 2009-09-28 14:33:00 UTC (rev 4761)
@@ -0,0 +1,16 @@
+<?php
+require_once(dirname(__FILE___)."/../classes/class_gui.php");
+$ObjectConf = array("DisplayName" => "Gui",
+ "internalName" => "gui",
+ "ClassName" => "gui");
+$rpc->run();
Added: branches/print_dev/http/javascripts/mod_AdminTabs.js
--- branches/print_dev/http/javascripts/mod_AdminTabs.js (rev 0)
+++ branches/print_dev/http/javascripts/mod_AdminTabs.js 2009-09-28 14:33:00 UTC (rev 4761)
@@ -0,0 +1,172 @@
+//FIXME: "type" shoudl be set by the dataobject recieved form the server
+var MBconfObjectList = function(url,element){
+// This Object displays availabe Configuration Objects in a given
+// category in a HTML ul element
+// and updates a corresponding editor with the Objects configuration
+// Options
+var me = this;
+this.type = "ObjectType";
+this.element = element;
+this.allEntries = {};
+this.displayEntries = {};
+this.editor = null;
+this.url = url; //RPC endpoint for getting objects
+MBconfObjectList.prototype.load = function(){
+ var that = this;
+ var options = {
+ url: that.url,
+ method: "list",
+ callback :(function(result,success,message){
+ var users = result.list;
+ that.type = result.type.display || that.type;
+ that.allEntries = users;
+ that.displayEntries = that.allEntries;
+ that.display();
+ var request = new Mapbender.Ajax.Request(options);
+ request.send();
+MBconfObjectList.prototype.display = function(search){
+ if(!search) {search = "";}
+ while(this.element.firstChild)
+ this.element.removeChild(this.element.firstChild);
+ $(this.element).html("");
+ var listEntry = $("<li></li>");
+ listEntry.addClass("listFilter");;
+ var listFilter = $('<input type="text" >');
+ listFilter.attr('title','filter users by name');
+ listFilter.attr('value',search);
+ listFilter.bind('change keyup',this.addOnFilterChangeHandler());
+ //listEntry.appendChild(listFilter);
+ listEntry.append(listFilter);
+ $(this.element).append(listEntry);
+ for(entry in this.displayEntries)
+ var name = this.displayEntries[entry].name;
+ var value = this.displayEntries[entry].value;
+ listEntry = $("<li></li>");
+ listEntry.html(name);
+ listEntry.bind('click', this.addOnClickHandler(this.displayEntries[entry]));
+ listEntry = $('<li></li>');
+ listEntry.addClass('listCommand');
+ listEntry.html('Add ' + this.type);
+ listEntry.bind('click',this.addOnClickHandler(value));
+ listFilter.focus();
+MBconfObjectList.prototype.setEditor = function(newEditor){
+ //TODO: check newEditor for validity
+ this.editor = newEditor;
+ //TODO: assuming the editor.setList also tries to set the
+ // lists editor to itself, would cause some silly recursion.
+ // how do I deal with this
+ this.editor.setList(this);
+MBconfObjectList.prototype.addOnClickHandler = function(key){
+ if(this.editor === null || this.editor === undefined) { return (function(){});}
+ var editor = this.editor;
+ var handler = (function(){
+ editor.load(key.value);
+ return handler;
+MBconfObjectList.prototype.addOnFilterChangeHandler = function(){
+ var list = this;
+ return (function(evt) {
+ var e = evt;
+ var needle = e.target.value;
+ list.displayEntries = {};
+ //TODO: optimize
+ for(entry in list.allEntries)
+ if(list.allEntries[entry].value.indexOf(needle) != -1)
+ list.displayEntries[entry] = list.allEntries[entry];
+ list.display(needle);
+var me = this;
+var Tabs = $('<ul><li>The Admintabs</li></ul>');
+Tabs.css("position","absolute");
+Tabs.css("top","1em");
+Tabs.css("left","1em");
+var h = $(me).append(Tabs);
+var AdminTabs = function() {
+ var adminModules = [];
+ this.register = function(moduleId) {
+ for(var c = 0; c < adminModules.length;c++)
+ if(adminModules[c] == moduleId) { return; }
+ adminModules.push(moduleId);
+ initmodule(moduleId);
+ /* moduleId
+ * param @moduleId the Id of the module that should be initialized (same as the modules options.id)
+ var initmodule = function(moduleId) {
+ var tab = $('<li><a href="#'+moduleId+'container">'+ Mapbender.modules[moduleId].caption +'</a></li>');
+ Tabs.append(tab);
+ var container = $("<div></div>");
+ container.attr("id",moduleId + 'container');
+ $(me).append(container);
+ // append ul element to AdminArea and make it a list
+ var listElement = $("<ul></ul>");
+ listElement.addClass("mbList");
+ container.append(listElement);
+ var List = new MBconfObjectList('../javascripts/'+Mapbender.modules[moduleId].rpcEndpoint ,listElement);
+ List.setEditor(Mapbender.modules[moduleId]);
+ List.editor.setList(List);
+ List.load();
+ // make module a child of AdminArea
+ $(container).append($('#' + moduleId+'frame'));
+ $.getScript("../extensions/jquery-ui-1.7.1.w.o.effects.min.js",(function(){
+ $('#' + options.id).tabs();
+Mapbender.modules[options.id] = new AdminTabs();
Added: branches/print_dev/http/javascripts/mod_addWMSfromTree.js
--- branches/print_dev/http/javascripts/mod_addWMSfromTree.js (rev 0)
+++ branches/print_dev/http/javascripts/mod_addWMSfromTree.js 2009-09-28 14:33:00 UTC (rev 4761)
@@ -0,0 +1,246 @@
+ * Package: AddWmsFromTree
+ * Description:
+ * Add a WMS from a container. The WMS are displayed in a customized tree
+ * (if one exists)
+ * Files:
+ * - http/javascripts/mod_addWMSfromTree.js
+ * SQL:
+ * > INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment,
+ * > e_title, e_element, e_src, e_attributes, e_left, e_top, e_width,
+ * > e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file,
+ * > e_mb_mod, e_target, e_requires, e_url) VALUES ('<app_id>',
+ * > 'addWMSfromTree',2,1,'Add a WMS from a container. The WMS are displayed in a customized tree (if one exists)',
+ * > 'Add WMS from tree','div','','',1,1,1,1,5,'overflow:scroll','','div',
+ * > '../javascripts/mod_addWMSfromTree.js',
+ * > '../extensions/jquery-ui-1.7.2.custom.min.js,../../lib/customTreeModel.js,../../lib/customTreeController.js',
+ * > 'mapframe1','mapframe1','');
+ * > INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name,
+ * > var_value, context, var_type) VALUES ('<app_id>', 'addWMSfromTree',
+ * > 'addwms_showWMS', '<max_number_of_layers>', '0 : do not make layer visible; n > 0 : make visible if #layers < n' ,'var');
+ * > 'applicationName', '<container_name>', 'Use the custom tree of this container' ,'var');
+ * > var_value, context, var_type) VALUES ('<app_id>', 'body',
+ * > 'custom_tree_css', '../css/customTree.css', '' ,'var');
+ * Help:
+ * http://www.mapbender.org/AddWmsFromTree
+ * Maintainer:
+ * http://www.mapbender.org/User:Christoph_Baudson
+ * Parameters:
+ * addwms_showWMS - Integer. 0 : do not make layer visible;
+ * - n > 0 : make visible if #layers < n
+ * applicationName - String. Use the custom tree of this container
+ * License:
+ * Copyright (c) 2009, Open Source Geospatial Foundation
+ * This program is dual licensed under the GNU General Public License
+ * and Simplified BSD license.
+ * http://svn.osgeo.org/mapbender/trunk/mapbender/license/license.txt
+(function () {
+ var addwms_showWMS = typeof options.addwms_showWMS !== "undefined" ?
+ options.addwms_showWMS : 0;
+ var applicationName = options.applicationName;
+ if (typeof applicationName === "undefined") {
+ new Mb_exception("No applicationName given in " + options.id);
+ else {
+ var loadWmsAndZoomCallback = function (opt) {
+ if (typeof opt === "object" && opt.success) {
+ var wmsId = parseInt(opt.wmsId, 10);
+ var map = getMapObjByName(options.target[0]);
+ var wms = map.getWmsById(wmsId);
+ if (wms === null) {
+ opt.msg = "Ein unbekannter Fehler ist aufgetreten.";
+ else {
+ // activate
+ if (typeof opt.visible === "number" && opt.visible === 1) {
+ if (typeof addwms_showWMS === "number"
+ && addwms_showWMS < wms.objLayer.length) {
+ if (addwms_showWMS > 0) {
+ try {
+ var msg = "Der hinzugeladene Kartendienst " +
+ "verfügt über mehr als " + addwms_showWMS +
+ " Ebenen. Die Ebenen des Dienstes werden " +
+ "<b>nicht</b> aktiviert.";
+ Mapbender.modules.dialogManager.openDialog({
+ content: msg,
+ modal: false,
+ effectShow: 'puff'
+ catch (e) {
+ new Mb_warning(e.message + ". " + msg);
+ handleSelectedWms(map.elementName, wmsId, "visible", 0);
+ else {
+ mb_restateLayers(map.elementName, wmsId);
+ // zoom to bbox
+ var bbox_minx, bbox_miny, bbox_maxx, bbox_maxy;
+ for (var i = 0; i < wms.gui_epsg.length; i++) {
+ if (map.epsg == wms.gui_epsg[i]) {
+ bbox_minx = parseFloat(wms.gui_minx[i]);
+ bbox_miny = parseFloat(wms.gui_miny[i]);
+ bbox_maxx = parseFloat(wms.gui_maxx[i]);
+ bbox_maxy = parseFloat(wms.gui_maxy[i]);
+ if (bbox_minx === null || bbox_miny === null || bbox_maxx === null || bbox_maxy === null) {
+ continue;
+ map.calculateExtent(new Extent(
+ bbox_minx,
+ bbox_miny,
+ bbox_maxx,
+ bbox_maxy
+ map.setMapRequest();
+ break;
+ loadWmsCallback(opt);
+ var loadWmsCallback = function (opt) {
+ var msg = typeof opt.msg === "string" ? opt.msg : "";
+ if (typeof opt !== "object" || !opt.success) {
+ msg = "Ein unbekannter Fehler ist aufgetreten. ";
+ else {
+ if (wms !== null) {
+ msg = "Der folgende Dienst wurde zu 'Aktive Dienste' " +
+ "hinzugefügt:<br><br>";
+ msg += "<b>" + wms.wms_title + "</b><br><br>";
+ else {
+ try {
+ content: msg,
+ modal: false,
+ catch (e) {
+ var additionalBehaviour = [
+ openTag: "img",
+ attr: {
+ src: "../img/tree_info.png",
+ title: "Metadaten anzeigen"
+ css: {
+ cursor: "pointer"
+ behaviour: {
+ click: function (opt) {
+ var metadataPopup = new mb_popup({
+ title : "Metadata",
+ url : "../php/mod_layerMetadata.php?wmsid=" +
+ opt.treeNode.wmsId,
+ width : 450,
+ height : 600,
+ left : 400,
+ top : 100
+ metadataPopup.show();
+ openTag: "img",
+ attr: {
+ src: "../img/tree_zoom.png",
+ title: "WMS zu aktiven Diensten hinzufügen und auf Ausschnitt zoomen"
+ css: {
+ cursor: "pointer"
+ behaviour: {
+ mod_addWMSById_ajax(opt.appId, opt.treeNode.wmsId, {
+ zoomToExtent: 1,
+ visible: 1,
+ callback: loadWmsAndZoomCallback
+ openTag: "img",
+ closeTag: "",
+ attr: {
+ src: "../img/tree_add_wms.png",
+ title: "WMS zu aktiven Diensten hinzufügen"
+ css: {
+ cursor: "pointer"
+ behaviour: {
+ click: function (param) {
+ mod_addWMSById_ajax(param.appId, param.treeNode.wmsId, {
+ callback: function (opt) {
+ handleSelectedWms(map.elementName, wmsId, "querylayer", 0);
+ var myTree = new CustomTree({
+ loadFromApplication: applicationName,
+ id: options.id,
+ draggable: false,
+ droppable: false,
+ skipRootNode: true,
+ leafBehaviour: additionalBehaviour
Added: branches/print_dev/http/javascripts/mod_admin.js
--- branches/print_dev/http/javascripts/mod_admin.js (rev 0)
+++ branches/print_dev/http/javascripts/mod_admin.js 2009-09-28 14:33:00 UTC (rev 4761)
@@ -0,0 +1,89 @@
+var Mapbender = Mapbender || {};
+function object(o){
+ function F() {}
+ F.prototype = o;
+ return new F();
+Mapbender.Admin = {};
+ * Alist of registered modules
+Mapbender.Admin.modules = {};
+ * Represents a Configuration Module. All Available Modules have to be registered here
+Mapbender.Admin.Module = function(options){
+ options = options || {};
+ * The title displayed to the user
+ this.title = options.title || "";
+ * The relative path to the File that contains the
+ * derived MBconfigObject, and MBConfigObjectEditor
+ this.path = options.path || "";
+ * The path where to send RPCs
+ this.endpoint = options.endpoint || "";
+ * wether the Module should active in the current page
+ this.active = options.active || false;
+ this.class = options.class || "";
+ this.load = function()
+Mapbender.Admin.Module.prototype.constructor = Mapbender.Admin.Module;
+//TODO: move these into their respective files
+Mapbender.Admin.modules.User = new Mapbender.Admin.Module({title: "User",
+ path: "mod_user.php",
+ endpoint : "user.php",
+ class: "MBUserEditor",
+ confObject: Mapbender.Admin.confUser});
+Mapbender.Admin.modules.Group = new Mapbender.Admin.Module({title: "Groups",
+ path: "mod_group.php",
+ endpoint: "group.php",
+ class: "MBGroupEditor"});
+ * Scans the current Page for any modules to be activated
+Mapbender.Admin.scan = function(){
+ for(module in Mapbender.Admin.modules)
+ if(!Mapbender.Admin.modules.hasOwnProperty(module)) { continue; }
+ var selector = "." + Mapbender.Admin.modules[module].class;
+ var elements = $(selector);
+ for(var i =0; i < elements.length; i++)
+ elements[i].style.backgroundColor = "red";
Added: branches/print_dev/http/javascripts/mod_admin.php
--- branches/print_dev/http/javascripts/mod_admin.php (rev 0)
+++ branches/print_dev/http/javascripts/mod_admin.php 2009-09-28 14:33:00 UTC (rev 4761)
@@ -0,0 +1,73 @@
+<!-- TODO: Need my header! -->
+<html>
+<head>
+<script src="../extensions/jquery-1.3.2.min.js" type="text/javascript"></script>
+<script src="../extensions/jquery-ui-1.7.1.w.o.effects.min.js" type="text/javascript"></script>
+<script src="../extensions/jqjson.js" type="text/javascript"></script>
+<script src="mod_admin.js" type="text/javascript"></script>
+<script src="Object.js" type="text/javascript"></script>
+<script src="Editor.js" type="text/javascript"></script>
+<script src="List.js" type="text/javascript"></script>
+<script type="text/javascript">
+//<![CDATA[
+var Mapbender = {};
+<?php
+echo "var global_mb_log_js = '".LOG_JS."';";
+echo "var global_mb_log_level = '".LOG_LEVEL."';";
+echo "var global_log_levels = '".LOG_LEVEL_LIST."';";
+require_once "../../lib/ajax.js";
+require_once "../../lib/exception.js";
+require_once "../../lib/event.js";
+</script>
+<script src="mod_admin.js" type="text/javascript" ></script>
+<script type="text/javascript" >
+//<![CDATA[
+function body_onload(evt){
+ Mapbender.Admin.scan();
+</script>
+</head>
+<body onload="body_onload(event)">
+Check which adminGUI elements are defined for this GUI and put them on the page
+like this:
+require_once("mod_user.php");
+echo mod_user_editor();
+which would output something like this:
+bla
+<div class="MBUserEditor">
+</div>
+The javascript on the clientside then scans for each of these modules, loads
+their javascript executes:
+$(".MBUserEditor").Mapbender.Admin.UserEditor();
+<?php
+include_once("mod_user.php");
+echo $mod_user_html;
+</body>
+</html>
Added: branches/print_dev/http/javascripts/mod_changeEPSG.js
--- branches/print_dev/http/javascripts/mod_changeEPSG.js (rev 0)
+++ branches/print_dev/http/javascripts/mod_changeEPSG.js 2009-09-28 14:33:00 UTC (rev 4761)
@@ -0,0 +1,249 @@
+ * Package: changeEPSG
+ * Description:
+ * Select a spatial reference system EPSG code. All maps are transformed to
+ * that system.
+ * Files:
+ * - http/javascripts/mod_changeEPSG.js
+ * - http/php/mod_changeEPSG_server.php
+ * SQL:
+ * > e_mb_mod, e_target, e_requires, e_url) VALUES ('<gui_id>','changeEPSG',
+ * > 2,1,'change EPSG, Postgres required, overview is targed for full extent',
+ * > 'Change Projection','select','','',432,25,107,24,1,'',
+ * > '<option value="">...</option>
+ * > <option value="EPSG:4326">EPSG:4326</option>
+ * > <option value="EPSG:31466">EPSG:31466</option>
+ * > <option value="EPSG:31467">EPSG:31467</option>
+ * > <option value="EPSG:31468">EPSG:31468</option>
+ * > <option value="EPSG:31469">EPSG:31469</option>','select',
+ * > 'mod_changeEPSG.js','','overview','','');
+ * Help:
+ * http://www.mapbender.org/ChangeEpsg
+ * Maintainer:
+ * License:
+var that = this;
+var exists = false;
+eventAfterMapRequest.register(function () {
+ $("#"+options.id+" option").each(function () {
+ if (this.value == mb_mapObj[0].epsg) {
+ isEPSG = true;
+ $(this).attr("selected", "selected");
+$(this).change(function () {
+ var srsValue = $("#"+options.id).get(0).value;
+ if (srsValue === "") {
+ return;
+ Mapbender.modules[options.id].setSrs({
+ srs: srsValue
+var ChangeEpsg = function () {
+ * Method: setSrs
+ * Description:
+ * Sets the SRS for all maps and WMS in the current application.
+ * The new bounding boxes are calculated with PostGIS!
+ * After this, the maps are immediately requested in the new SRS.
+ * Parameters:
+ * options.srs - (String) An SRS identifier, for example "EPSG:4326"
+ * options.callback - (Function) A callback function. Should include the
+ this.setSrs = function (options) {
+ var srsValue;
+ if (typeof options === "object" && typeof options.srs === "string") {
+ srsValue = options.srs;
+ if (typeof srsValue === "undefined") {
+ new Mb_exception("setSrs: must specify an SRS.");
+ return;
+ var recalculateExtentOnly;
+ if (typeof options === "object" && typeof options.recalculateExtentOnly === "object") {
+ recalculateExtentOnly = options.recalculateExtentOnly;
+ if (typeof recalculateExtentOnly.target !== "string") {
+ new Mb_exception("setSrs: must specify a target if recalculateExtentOnly is set.");
+ return;
+ if (typeof recalculateExtentOnly.extent !== "object") {
+ new Mb_exception("setSrs: must specify an extent if recalculateExtentOnly is set.");
+ return;
+ var srsArray = [];
+ if (recalculateExtentOnly) {
+ recalculateExtentOnly.map = Mapbender.modules[recalculateExtentOnly.target];
+ if (typeof recalculateExtentOnly.map !== "object" || recalculateExtentOnly.map === null) {
+ new Mb_exception("setSrs: invalid target set for recalculateExtentOnly.");
+ return;
+ var currentSrs = {
+ "frameName": recalculateExtentOnly.map.elementName,
+ "epsg": srsValue,
+ "extent": recalculateExtentOnly.extent.toString(),
+ "width": recalculateExtentOnly.map.width,
+ "height": recalculateExtentOnly.map.height
+ srsArray.push(currentSrs);
+ // calculate extents for all maps...
+ else {
+ for (var i = 0; i < mb_mapObj.length; i++) {
+ "frameName": mb_mapObj[i].elementName,
+ "epsg": mb_mapObj[i].epsg,
+ "extent": mb_mapObj[i].extent.toString(),
+ "width": mb_mapObj[i].width,
+ "height": mb_mapObj[i].height
+ // ... and all WMS.
+ if (!recalculateExtentOnly) {
+ for (var i = 0; i < wms.length; i++) {
+ var ext = wms[i].getBoundingBoxBySrs(mb_mapObj[0].epsg);
+ if (ext === null) {
+ continue;
+ "wms" : wms[i].wms_id,
+ "epsg" : mb_mapObj[0].epsg,
+ "extent" : ext.toString(),
+ "width" : mb_mapObj[0].width,
+ "height" : mb_mapObj[0].height
+ // perform transformation
+ var req = new Mapbender.Ajax.Request({
+ url: "../php/mod_changeEPSG_server.php",
+ method: "changeEpsg",
+ parameters: {
+ srs: srsArray,
+ newSrs: recalculateExtentOnly ? recalculateExtentOnly.map.epsg : srsValue
+ callback: function (obj, success, message) {
+ if (!success) {
+ new Mapbender.Exception(message);
+ return;
+ var newExtent = obj;
+ for (var i = 0; i < newExtent.length; i++) {
+ if (newExtent[i].wms && !recalculateExtentOnly) {
+ for (var j = 0; j < wms.length; j++) {
+ if (parseInt(wms[j].wms_id, 10) === parseInt(newExtent[i].wms, 10)) {
+ wms[j].setBoundingBoxBySrs(
+ newExtent[i].newSrs,
+ new Extent(
+ parseFloat(newExtent[i].minx),
+ parseFloat(newExtent[i].miny),
+ parseFloat(newExtent[i].maxx),
+ parseFloat(newExtent[i].maxy)
+ break;
+ continue;
+ // use the previous extent of the overview
+ if(!recalculateExtentOnly && newExtent[i].frameName == options.target){
+ var map = Mapbender.modules[options.target];
+ var goback = false;
+ for (var ii = 0; ii < map.mb_MapHistoryObj.length; ii++) {
+ if (map.mb_MapHistoryObj[ii].epsg == newExtent[i].newSrs) {
+ exists = ii;
+ goback = true;
+ if (goback) {
+ map.setSrs({
+ srs: newExtent[i].newSrs,
+ extent: map.mb_MapHistoryObj[exists].extent,
+ displayWarning: false
+ else{
+ map.setSrs({
+ extent: new Mapbender.Extent(
+ else {
+ var map = Mapbender.modules[newExtent[i].frameName];
+ map.setSrs({
+ displayWarning: true
+ if (typeof options.callback === "function") {
+ options.callback();
+ mb_mapObj[i].setMapRequest();
+ req.send();
+Mapbender.modules[options.id] = $.extend(new ChangeEpsg(), Mapbender.modules[options.id]);
Added: branches/print_dev/http/javascripts/mod_coordsLookup.js
--- branches/print_dev/http/javascripts/mod_coordsLookup.js (rev 0)
+++ branches/print_dev/http/javascripts/mod_coordsLookup.js 2009-09-28 14:33:00 UTC (rev 4761)
@@ -0,0 +1,200 @@
+ * Package: coordsLookup
+ * Description:
+ * The user enters a coordinate tuple and selects the corresponding SRS
+ * from a select box. After submitting this form, Mapbender transforms
+ * the coordinate tuple to the current SRS and zooms to the location.
+ * Files:
+ * - http/javascripts/mod_coordsLookup.js
+ * - http/php/mod_coordsLookup_server.php
+ * SQL:
+ * > e_mb_mod, e_target, e_requires, e_url) VALUES ('<app_id>','coordsLookup',
+ * > 10,1,'','Coordinate lookup','div','','',1000,0,NULL ,NULL ,NULL ,
+ * > 'z-index:9999;','','div','mod_coordsLookup.js','',
+ * > 'mapframe1','','');
+ * > var_value, context, var_type) VALUES ('<app_id>', 'coordsLookup',
+ * > 'perimeters', '[50,200,1000,10000]', '' ,'var');
+ * > var_value, context, var_type) VALUES('<app_id>', 'coordsLookup',
+ * > 'projections', '[''EPSG:31467'',''EPSG:31468'',''EPSG:31469'']', '' ,
+ * > 'var');
+ * Help:
+ * http://www.mapbender.org/coordsLookup
+ * Maintainer:
+ * Parameters:
+ * perimeters - Array of perimeters in m, like [50,200,1000,10000]
+ * projections - Array of EPSG names, like ['EPSG:31467','EPSG:31468']
+ * License:
+// http://trac.osgeo.org/proj4js/wiki/UserGuide
+// 3802000 / 5825000
+var CoordsLookup = function() {
+ var that = this;
+ if(
+ typeof options.target === 'undefined' || options.target.length === 0 ||
+ typeof options.projections === 'undefined' || options.projections.length === 0 ||
+ typeof options.perimeters === 'undefined' || options.perimeters.length === 0
+ return;
+ this.buildForm = function() {
+// Container elements
+ this.formContainer = $(document.createElement('form')).attr({'id':'coords-lookup-form'}).appendTo('#' + options.id);
+ this.coordsInputContainer = $(document.createElement('p')).appendTo(this.formContainer);
+ this.projectionSelectContainer = $(document.createElement('p')).appendTo(this.formContainer);
+ this.perimeterSelectContainer = $(document.createElement('p')).appendTo(this.formContainer);
+ this.triggerButtonContainer = $(document.createElement('p')).appendTo(this.formContainer);
+// Coordinates input with label
+ this.coordsInputLabel = $(document.createElement('label')).attr({'for':'coord-x'}).text('Koordinaten:').appendTo(this.coordsInputContainer);
+ this.coordXInput = $(document.createElement('input')).attr({'id':'coord-x','size':8}).appendTo(this.coordsInputContainer);
+ this.coordYInput = $(document.createElement('input')).attr({'id':'coord-y','size':8}).appendTo(this.coordsInputContainer);
+ $(this.coordsInputLabel).after($(document.createElement('br')));
+ $(this.coordXInput).after(' / ');
+// Projection select
+ this.projectionSelect = $(document.createElement('select')).attr({'id':'projection-select'}).appendTo(this.projectionSelectContainer);
+// Perimeter select
+ this.perimeterSelect = $(document.createElement('select')).attr({'id':'perimeter-select'}).appendTo(this.perimeterSelectContainer);
+// Trigger button
+ this.triggerButton = $(document.createElement('input')).attr({'id':'trigger-button','type':'button','value':'Auf Koordinaten zoomen'}).appendTo(this.triggerButtonContainer);
+ this.initForm = function() {
+// Fill projection select with options
+ for(var i = 0; i < options.projections.length; i++) {
+ $(new Option(options.projections[i],options.projections[i])).appendTo(this.projectionSelect);
+ $(new Option('Projektionssystem','',true,true)).prependTo(this.projectionSelect);
+// Fill perimeter select with options
+ for(var i = 0; i < options.perimeters.length; i++) {
+ var optionValue = options.perimeters[i] + '';
+ optionValue = (optionValue.length < 4) ? (optionValue + ' m') : optionValue.replace(/(\d+)(\d{3})/, '$1' + '.' + '$2' + ' m');
+ $(new Option(optionValue,options.perimeters[i])).appendTo(this.perimeterSelect);
+ $(new Option('Umkreis','',true,true)).prependTo(this.perimeterSelect);
+// Set action for trigger button
+ $(this.triggerButton).click(function() {
+ Mapbender.modules[options.id].zoomToCoordinates();
+ this.zoomToCoordinates = function() {
+ this.coords = {};
+ this.coords.x = this.coordXInput.val().replace(',','.');
+ this.coords.y = this.coordYInput.val().replace(',','.');
+ this.coords.sourceProjection = (this.projectionSelect.val()) ?
+ this.projectionSelect.val() : null;
+ this.coords.targetProjection = Mapbender.modules[options.target].getSRS();
+ this.coords.perimeter = (this.perimeterSelect.val()) ?
+ parseFloat(this.perimeterSelect.val()) : null;
+ if(
+ this.coords.x.length === 0 || isNaN(this.coords.x) ||
+ this.coords.y.length === 0 || isNaN(this.coords.y)
+ alert('Invalid coordinates!');
+ return;
+ if (this.coords.sourceProjection === null) {
+ alert('Invalid SRS!');
+ return;
+ if(this.coords.sourceProjection && (this.coords.sourceProjection != this.coords.targetProjection)) {
+ this.transformProjection();
+ this.transformProjection = function() {
+ var parameters = {
+ fromSrs: this.coords.sourceProjection,
+ toSrs: this.coords.targetProjection
+ if (this.coords.perimeter === null) {
+ parameters.x = this.coords.x;
+ parameters.y = this.coords.y;
+ else {
+ parameters.bbox = (
+ parseFloat(this.coords.x) - parseFloat(this.coords.perimeter)
+ parseFloat(this.coords.y) - parseFloat(this.coords.perimeter)
+ parseFloat(this.coords.x) + parseFloat(this.coords.perimeter)
+ parseFloat(this.coords.y) + parseFloat(this.coords.perimeter));
+ url: "../php/mod_coordsLookup_server.php",
+ method: "transform",
+ parameters: parameters,
+ if (!success) {
+ return;
+ if (obj.points) {
+ if (obj.points.length === 1) {
+ map.setCenter(new Point(
+ obj.points[0].x,
+ obj.points[0].y
+ else if (obj.points.length === 2) {
+ var newExtent = new Extent(
+ obj.points[0].x,
+ obj.points[0].y,
+ obj.points[1].x,
+ obj.points[1].y
+ map.calculateExtent(newExtent);
+ req.send();
+ this.buildForm();
+ this.initForm();
+Mapbender.events.init.register(function() {
+ Mapbender.modules[options.id] = $.extend(new CoordsLookup(),Mapbender.modules[options.id]);
Added: branches/print_dev/http/javascripts/mod_dialogManager.js
--- branches/print_dev/http/javascripts/mod_dialogManager.js (rev 0)
+++ branches/print_dev/http/javascripts/mod_dialogManager.js 2009-09-28 14:33:00 UTC (rev 4761)
@@ -0,0 +1,163 @@
+ * Package:
+ * Dialog Manager
+ * Description:
+ * Module to managing dialog windows with multiple options for customization.
+ * Files:
+ * - http/javascripts/mod_dialogManager.js
+ * - http/extensions/jquery-1.3.2.min.js (minium v1.3.2)
+* - http/extensions/jquery-ui-1.7.2.custom (minimum v1.7.2, complete folder including CSS)
+ * SQL:
+ * INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('<GUI name>','dialogManager',5,1,'','','div','','',-1,-1,NULL ,NULL ,NULL ,'','','div','../x_test/portalu/mod_dialogManager.js','','','','');
+ * Help:
+ * http://www.mapbender.org/Dialog_Manager
+ * Maintainer:
+ * http://www.mapbender.org/User:Lars_Beck
+ * Parameters:
+ * <normal element var name> - <type and description>
+ * <optional element var name> - *[optional]* <type and description>
+ * <deprecated element var name> - *[deprecated]* <type and description>
+ * License:
+var defaultOptions = {};
+defaultOptions.content = (typeof options.dialogContent !== 'undefined') ? options.dialogContent : '';
+defaultOptions.url = (typeof options.dialogURL !== 'undefined') ? options.dialogURL : null;
+defaultOptions.dimensions = (typeof options.dialogDimensions !== 'undefined') ? options.dialogDimensions : [550,400];
+defaultOptions.position = (typeof options.dialogPosition !== 'undefined') ? options.dialogPosition : 'center';
+defaultOptions.isModal = (typeof options.dialogIsModal !== 'undefined') ? options.dialogIsModal : true;
+defaultOptions.isResizeable = (typeof options.dialogIsResizeable !== 'undefined') ? options.dialogIsResizeable : false;
+defaultOptions.isDraggable = (typeof options.dialogIsDraggable !== 'undefined') ? options.dialogIsDraggable : false;
+defaultOptions.title = (typeof options.dialogTitle !== 'undefined') ? options.dialogTitle : null;
+defaultOptions.effectShow = (typeof options.dialogEffectShow !== 'undefined') ? options.dialogEffectShow : null;
+defaultOptions.effectHide = (typeof options.dialogEffectHide !== 'undefined') ? options.dialogEffectHide : null;
+var DialogManager = function() {
+ this.dialogOptions = {};
+ this.currentDialogs = [];
+ this.openDialog = function(customOptions) {
+ if(typeof customOptions === 'undefined') {
+ customOptions = {};
+ dialogManager = this;
+ this.createDialogID();
+ this.dialogOptions.content = (typeof customOptions.content !== 'undefined') ? customOptions.content : defaultOptions.content;
+ this.dialogOptions.dimensions = (typeof customOptions.dimensions !== 'undefined') ? customOptions.dimensions : defaultOptions.dimensions;
+ this.dialogOptions.position = (typeof customOptions.position !== 'undefined') ? customOptions.position : defaultOptions.position;
+ this.dialogOptions.isModal = (typeof customOptions.isModal !== 'undefined') ? customOptions.isModal : defaultOptions.isModal;
+ this.dialogOptions.isResizeable = (typeof customOptions.isResizeable !== 'undefined') ? customOptions.isResizeable : defaultOptions.isResizeable;
+ this.dialogOptions.isDraggable = (typeof customOptions.isDraggable !== 'undefined') ? customOptions.isDraggable : defaultOptions.isDraggable;
+ this.dialogOptions.title = (typeof customOptions.title !== 'undefined') ? customOptions.title : defaultOptions.title;
+ this.dialogOptions.effectShow = (typeof customOptions.effectShow !== 'undefined') ? customOptions.effectShow : defaultOptions.effectShow;
+ this.dialogOptions.effectHide = (typeof customOptions.effectHide !== 'undefined') ? customOptions.effectHide : defaultOptions.effectHide;
+ if(typeof customOptions.url !== 'undefined') {
+ this.dialogOptions.content = '<iframe src="' + customOptions.url + '" width="100%" height="100%" frameborder="0" scrolling="auto"></iframe>';
+ this.dialog = $(document.createElement('div'))
+ .attr('id',this.dialogID)
+ .html(this.dialogOptions.content)
+ .appendTo('body')
+ .dialog({
+ width: this.dialogOptions.dimensions.shift(),
+ height: this.dialogOptions.dimensions.shift(),
+ position: this.dialogOptions.position,
+ modal: this.dialogOptions.isModal,
+ resizeable: this.dialogOptions.isResizable,
+ draggable: this.dialogOptions.isResizable,
+ title: this.dialogOptions.title,
+ show: this.dialogOptions.effectShow,
+ hide: this.dialogOptions.effectHide,
+ open: function() {
+ dialogManager.addToCurrentDialogs(this.id);
+ close: function() {
+ dialogManager.removeFromCurrentDialogs(this.id);
+ return this.dialog;
+ this.closeDialog = function(openDialog) {
+ $(openDialog).dialog('close');
+ this.createDialogID = function() {
+ this.dialogID = 'mb-dialog-' + parseInt(new Date().getTime());
+ this.addToCurrentDialogs = function() {
+ this.currentDialogs.push(this.dialogID);
+ this.removeFromCurrentDialogs = function(dialogID) {
+ for(var i = 0; i < this.currentDialogs.length; i++) {
+ if(this.currentDialogs[i] === dialogID) {
+ if (i === 0) {
+ this.currentDialogs.shift();
+ else if (i === (this.currentDialogs.length - 1)) {
+ this.currentDialogs.pop();
+ else {
+ var partA = this.currentDialogs.slice(0,(i - 1));
+ var partB = this.currentDialogs.slice(i + 1,(this.currentDialogs.length - 1));
+ this.currentDialogs = (partA + partB);
+ return;
+$(document).ready(function() {
+ Mapbender.modules[options.id] = $.extend(new DialogManager(),Mapbender.modules[options.id]);
+$('#dialog-trigger-a').click(function() {
+ Mapbender.modules.dialogManager.openDialog();
+$('#dialog-trigger-b').click(function() {
+ 'url': 'http://www.google.de/',
+ 'dimensions': [800,600],
+ 'position': [5,5],
+ 'title': 'Google',
+ 'isModal': false,
+ 'effectShow': 'blind'
+$('#dialog-trigger-c').click(function() {
+ 'content': 'Verbrechen lohnt sich nicht.',
+ 'title': 'Hinweis',
+ 'effectShow': 'puff',
+ 'effectHide': 'puff'
Added: branches/print_dev/http/javascripts/mod_group.js
--- branches/print_dev/http/javascripts/mod_group.js (rev 0)
+++ branches/print_dev/http/javascripts/mod_group.js 2009-09-28 14:33:00 UTC (rev 4761)
@@ -0,0 +1,46 @@
+var me = this;
+var GroupEditor = function(){
+ // chose the id to be of the form: options.id + <fieldname>
+ this.form = $('\n\
+ <div id="'+options.id +'frame" class="mbFrame formContainer ConfEditor">\n\
+ <h2 id="'+ options.id +'nameheader">GroupNameGoesHere</h2>\n\
+ <form method="post" id="'+ options.id +'form" >\n\
+ <ul>\n\
+ <li><label for="'+ options.id +'name">Name</label><input id="'+ options.id +'name" type="text" /></li>\n\
+ <li><label for="'+ options.id +'description">Description</label><input id="'+ options.id +'description" type="text" /></li>\n\
+ <li><label for="'+ options.id +'owner">Owner</label><input id="'+ options.id +'owner" type="text" /></li>\n\
+ </ul>\n\
+ <p>\n\
+ <input id="'+options.id +'save" type="button" value="save" onclick="Mapbender.modules[\''+ options.id +'\'].save(); return false;" />\n\
+ <input id="'+options.id +'delete" type="button" value="delete" onclick="Mapbender.modules[\''+ options.id +'\'].remove(); return false;" />\n\
+ </p>\n\
+ </form>\n\
+ </div>');
+ this.defaultFields = {};
+ this.defaultFields.name = { name: "name", defaultValue : "New Group", value: "", display: "Group Name", type: "text"};
+ this.defaultFields.owner = { name: "owner", defaultValue : "", value:"", display: "Owner", type: "text"};
+ this.defaultFields.description = { name: "description", defaultValue : "", value:"", display: "Description", type: "text"};
+ this.name = this.defaultFields.name.value;
+ this.rpcEndpoint = "../javascripts/group.php";
+ this.options = options;
+ this.caption = "Groups";
+ $(me).replaceWith(this.form);
+ me = this.form;
+ this.reset();
+GroupEditor.prototype = new ConfEditor();
+GroupEditor.prototype.constructor = GroupEditor;
+Mapbender.modules[options.id] = new GroupEditor();
+if(Mapbender.modules['AdminTabs'])
+ Mapbender.modules['AdminTabs'].register(options.id);
Added: branches/print_dev/http/javascripts/mod_gui.js
--- branches/print_dev/http/javascripts/mod_gui.js (rev 0)
+++ branches/print_dev/http/javascripts/mod_gui.js 2009-09-28 14:33:00 UTC (rev 4761)
@@ -0,0 +1,47 @@
+var me = this;
+var GuiEditor = function(){
+this.form = $('\n\
+ <h2 id="'+ options.id +'nameheader">GuiNameGoesHere</h2>\n\
+ <ul>\n\
+ <li><label for="'+ options.id +'public">Public</label><input id="'+ options.id +'public" name="public" type="checkbox" /></li>\n\
+ </ul>\n\
+ <p>\n\
+ </p>\n\
+ </form>\n\
+</div>');
+ this.defaultFields.name = { name: "name", defaultValue: "New Gui", value: "", display: "User Name", type: "text"};
+ this.defaultFields.description = { name: "description", defaultValue: "", value: "", display: "Description", type: "text"};
+ this.defaultFields.public= { name: "public", defaultValue: true, value: "", display: "Public", type: "bool"};
+ this.rpcEndpoint = "../javascripts/gui.php";
+ this.caption = "GUI";
+ me = this.form;
+ this.reset();
+GuiEditor.prototype = new ConfEditor();
+GuiEditor.prototype.constructor = GuiEditor;
+Mapbender.modules[options.id] = new GuiEditor();
Added: branches/print_dev/http/javascripts/mod_overview.js
--- branches/print_dev/http/javascripts/mod_overview.js (rev 0)
+++ branches/print_dev/http/javascripts/mod_overview.js 2009-09-28 14:33:00 UTC (rev 4761)
@@ -0,0 +1,161 @@
+ * Package: Overview
+ * Description:
+ * Use the overview map to navigate the main map window. You can select a new
+ * rectangle in the overview map, the details will be displayed in the main
+ * map window. Recenter the main map window section by just clicking a new
+ * position in the overview map (the scale will not change).
+ * Files:
+ * - http/javascripts/mod_overview.js
+ * SQL:
+ * > e_mb_mod, e_target, e_requires, e_url) VALUES ('<app_id>','overview',
+ * > 2,1,'OverviewFrame','Overview','div','','',15,25,150,150,2,
+ * > 'overflow:hidden;',
+ * > '<div id="overview_maps" style="position:absolute;left:0px;right:0px;"></div>',
+ * > 'div','mod_overview.js','mod_box1.js','mapframe1','mapframe1',
+ * > 'http://www.mapbender.org/index.php/Overview');
+ * > var_value, context, var_type) VALUES ('<app_id>', 'overview',
+ * > 'overview_wms', '0', 'wms that shows up as overview' ,'var');
+ * > 'skipWmsIfSrsNotSupported', '0',
+ * > 'if set to 1, it skips the WMS request if the current SRS is not supported by the WMS; if set to 0, the WMS is always queried. Default is 0, because of backwards compatibility' ,
+ * > 'var');
+ * Help:
+ * http://www.mapbender.org/Overview
+ * Maintainer:
+ * Parameters:
+ * overview_wms - wms that shows up as overview
+ * skipWmsIfSrsNotSupported - *[optional]* if set to 1, it skips the WMS
+ * request if the current SRS is not supported by the WMS; if set
+ * to 0, the WMS is always queried. Default is 0, because of
+ * backwards compatibility
+ * License:
+if (typeof options.overview_wms === "undefined") {
+ options.overview_wms = 0;
+options.overview_wms = parseInt(options.overview_wms, 10);
+if (!options.target) {
+ new Mb_exception(options.id + " needs a target.");
+ return;
+var box;
+var map;
+Mapbender.events.initMaps.register(function () {
+ Mapbender.modules[options.id] = $.extend(new Mapbender.Map(
+ options.id,
+ options.width,
+ options.height,
+ ), Mapbender.modules[options.id]);
+ map = Mapbender.modules[options.id];
+ map.isOverview = true;
+ map.skipWmsIfSrsNotSupported =
+ options.skipWmsIfSrsNotSupported === 1 ? true : false;
+ // this line is for backwards compatibility
+ mb_mapObj.push(map);
+ // add select area behaviour
+ box = new Mapbender.Box({
+ target: options.id
+ $(map.getDomElement()).mousedown(function (e) {
+ box.start(e);
+ return false;
+ }).mouseup(function (e) {
+ var targetMap = Mapbender.modules[options.target];
+ if (!targetMap) {
+ return false;
+ box.stop(e, function (extent) {
+ if (typeof extent === "undefined") {
+ return false;
+ if (extent.constructor === Mapbender.Extent) {
+ targetMap.calculateExtent(extent);
+ targetMap.setMapRequest();
+ else if (extent.constructor === Mapbender.Point) {
+ targetMap.setCenter(extent);
+ return false;
+// update the rectangle indicating the current extent
+// of the target map after each map request
+Mapbender.events.afterMapRequest.register(function () {
+ if (!targetMap) {
+ return;
+ var min = map.convertRealToPixel(targetMap.extent.min);
+ var max = map.convertRealToPixel(targetMap.extent.max);
+ if (min.x < 0) {
+ min.x = 0;
+ if (max.x > map.getWidth()) {
+ max.x = map.getWidth();
+ if (min.y > map.getHeight()) {
+ min.y = map.getHeight();
+ if (max.y < 0) {
+ max.y = 0;
+ var diffX = max.x - min.x;
+ if (diffX < 8) {
+ var centerX = 0.5 * (max.x + min.x);
+ min.x = centerX - 4;
+ max.x = centerX + 4;
+ var diffY = min.y - max.y;
+ if (diffY < 8) {
+ var centerY = 0.5 * (max.y + min.y);
+ min.y = centerY + 4;
+ max.y = centerY - 4;
+ var extent = new Mapbender.Extent(min, max);
+ box.draw(extent);
Added: branches/print_dev/http/javascripts/mod_overviewToggle.js
--- branches/print_dev/http/javascripts/mod_overviewToggle.js (rev 0)
+++ branches/print_dev/http/javascripts/mod_overviewToggle.js 2009-09-28 14:33:00 UTC (rev 4761)
@@ -0,0 +1,132 @@
+ * Package: overviewToggle
+ * Description:
+ * shows and hides the overview module with a jQuery animation
+ * Files:
+ * - http/javascripts/mod_overviewToggle.js
+ * SQL:
+ * > 'overviewToggle',5,1,'','','div','','class="ui-widget-header" ',
+ * > -1,-1,NULL ,NULL ,NULL ,
+ * > 'display:none;height:24px;width:35px;text-align:right;vertical-align:middle',
+ * > '<img style=''position:absolute;top:0px;left:0px'' src=''../img/ovtoggle.png'' /><span style=''padding:3px''>></span>',
+ * > 'div','../javascripts/mod_overviewToggle.js','','overview','','');
+ * > 'overviewToggle_css', '../css/dialog/jquery-ui-1.7.2.custom.css',
+ * > '' ,'file/css');
+ * Help:
+ * http://www.mapbender.org/OverviewToggle
+ * Maintainer:
+ * License:
+var ovSwitchTarget = options.target[0];
+var ovSwitchId = options.id;
+var overview_visible = false;
+eventInit.register(function () {
+ var $ov = $("#" + ovSwitchTarget);
+ var $this = $("#" + ovSwitchId);
+ var $ovToggleButton = $("#" + ovSwitchId + " > span");
+ var overviewInitialWidth = $ov.width();
+ var overviewInitialHeight = $ov.height();
+ var overviewInitialTop = parseInt($ov.css("top"), 10);
+ var overviewLeft = parseInt($ov.css("left"), 10);
+ var overviewInitialOuterWidth = $ov.outerWidth();
+ $ov.css({
+ display:"block",
+ top: (overviewInitialTop + 26) + "px",
+ width: "0px",
+ borderWidth: "0px",
+ borderStyle: "solid",
+ borderColor: "#176798"
+ if (!overview_visible) {
+ $ov.css({
+ height: 0,
+ left: overviewLeft + "px"
+ $this.css({
+ display:"block",
+ left: overviewLeft + "px",
+ top: overviewInitialTop + "px",
+ zIndex: $ov.css("zIndex")
+ //set display to block as the frame is invisible anyway (width 0)
+ $ov.show();
+ $ovToggleButton.mouseover(function () {
+ this.style.cursor = "pointer";
+ }).mouseout(function () {
+ this.style.cursor = "default";
+ }).click(function(){
+ if(overview_visible){
+ // Hide
+ $ov.animate({
+ height: 0
+ }, "fast", "linear", function () {
+ $ov.css({
+ width: "0px",
+ $this.animate({
+ width: 35
+ $ovToggleButton.text(">");
+ overview_visible = false;
+ else{
+ // Show
+ $this.animate({
+ width: overviewInitialWidth
+ $ov.css({
+ width: overviewInitialWidth,
+ borderWidth: "1px",
+ $ov.animate({
+ height: overviewInitialHeight
+ $ovToggleButton.text("<");
+ overview_visible = true;
Added: branches/print_dev/http/javascripts/mod_selArea.js
--- branches/print_dev/http/javascripts/mod_selArea.js (rev 0)
+++ branches/print_dev/http/javascripts/mod_selArea.js 2009-09-28 14:33:00 UTC (rev 4761)
@@ -0,0 +1,81 @@
+ * Package: selArea
+ * Description:
+ * Zoom by rectangle
+ * Files:
+ * - http/javascripts/mod_selArea.js
+ * SQL:
+ * > <SQL for element>
+ * > <SQL for element var>
+ * Help:
+ * http://www.mapbender.org/SelArea1
+ * Maintainer:
+ * License:
+var that = this;
+Mapbender.events.init.register(function () {
+ var box;
+ var button = new Mapbender.Button({
+ domElement: that,
+ over: options.src.replace(/_off/, "_over"),
+ on: options.src.replace(/_off/, "_on"),
+ off: options.src,
+ name: options.id,
+ go: function () {
+ if (!map) {
+ new Mb_exception(options.id + ": " +
+ options.target + " is not a map!");
+ return;
+ target: options.target
+ box.start(e);
+ return false;
+ return false;
+ map.calculateExtent(extent);
+ map.setCenter(extent);
+ return false;
+ stop: function () {
+ if (!map) {
+ return;
+ .unbind("mousedown")
+ .unbind("mouseup")
+ .unbind("mousemove");
+ box = null;
Added: branches/print_dev/http/javascripts/mod_user.js
--- branches/print_dev/http/javascripts/mod_user.js (rev 0)
+++ branches/print_dev/http/javascripts/mod_user.js 2009-09-28 14:33:00 UTC (rev 4761)
@@ -0,0 +1,66 @@
+var me = this;
+var UserEditor = function(){
+this.form = $('\n\
+ <h2 id="'+ options.id +'nameheader">UserNameGoesHere</h2>\n\
+ <ul>\n\
+ <li><label for="'+ options.id +'Name">Username</label><input id="'+ options.id +'name" type="text" /></li>\n\
+ <li><label for="'+ options.id +'Password">Password</label><input id="'+ options.id +'password" type="password" /></li>\n\
+ <li><label for="'+ options.id +'Description">Description</label><input id="'+ options.id +'description" type="text" /></li>\n\
+ <li><label for="'+ options.id +'Owner">Owner</label><input id="'+ options.id +'owner" type="text" /></li>\n\
+ <li><label for="'+ options.id +'LoginCount">Number of Logins</label><input id="'+ options.id +'loginCount" type="text" /></li>\n\
+ <li><label for="'+ options.id +'Email">Email</label><input id="'+ options.id +'email" type="text" /></li>\n\
+ <li><label for="'+ options.id +'Phone">Phone</label><input id="'+ options.id +'phone" type="text" /></li>\n\
+ <li><label for="'+ options.id +'Department">Department</label><input id="'+ options.id +'department" type="text" /></li>\n\
+ </ul>\n\
+ <p>\n\
+ </p>\n\
+ </form>\n\
+</div>');
+ this.defaultFields.name = { name: "name", defaultValue: "New User", value: "", display: "User Name", type: "text"};
+ this.defaultFields.password = { name: "password", defaultValue: "********", value: "", display: "Password", type: "text"};
+ this.defaultFields.owner = { name: "owner", defaultValue: "", value: "", display: "Owner", type: "text"};
+ this.defaultFields.loginCount = { name: "loginCount", defaultValue: "", value: "", display: "Login Count", type: "text"};
+ this.defaultFields.email= { name: "email", defaultValue: "", value: "", display: "Email", type: "text"};
+ this.defaultFields.phone= { name: "phone", defaultValue: "", value: "", display: "Phone", type: "text"};
+ this.defaultFields.department= { name: "department", defaultValue: "", value: "", display: "Department", type: "text"};
+ this.defaultFields.resolution= { name: "resolution", defaultValue: "", value: "", display: "Resolution", type: "text"};
+ this.defaultFields.organization= { name: "organization", defaultValue: "", value: "", display: "Organization", type: "text"};
+ this.defaultFields.position= { name: "position", defaultValue: "", value: "", display: "position", type: "text"};
+ this.defaultFields.phone1= { name: "phone1", defaultValue: "", value: "", display: "Phone Extra", type: "text"};
+ this.defaultFields.fax= { name: "fax", defaultValue: "", value: "", display: "Fax", type: "text"};
+ this.defaultFields.deliveryPoint= { name: "deliveryPoint",defaultValue: "", value: "", display: "Delivery Point", type: "text"};
+ this.defaultFields.city= { name: "city", defaultValue: "", value: "", display: "City", type: "text"};
+ this.defaultFields.postalCode= { name: "postalCode", defaultValue: "", value: "", display: "Postal Code", type: "text"};
+ this.defaultFields.country= { name: "country", defaultValue: "", value: "", display: "Country", type: "text"};
+ this.defaultFields.url= { name: "url", defaultValue: "", value: "", display: "URL", type: "text"};
+ this.rpcEndpoint = "../javascripts/user.php";
+ this.caption = "Users";
+ me = this.form;
+ this.reset();
+UserEditor.prototype = new ConfEditor();
+UserEditor.prototype.constructor = UserEditor;
+Mapbender.modules[options.id] = new UserEditor();
Added: branches/print_dev/http/javascripts/mod_zoomIn1.js
--- branches/print_dev/http/javascripts/mod_zoomIn1.js (rev 0)
+++ branches/print_dev/http/javascripts/mod_zoomIn1.js 2009-09-28 14:33:00 UTC (rev 4761)
@@ -0,0 +1,44 @@
+ * Package: ZoomIn1
+ * Description:
+ * Click button, which minimizes the real world bounding box of the visible map section, doubles the scale (halfes the scale number). Image size is not affected.
+ * Files:
+ * - http/javascripts/mod_zoomIn1.js
+ * SQL:
+ * > INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public,
+ * > e_comment, e_title, e_element, e_src, e_attributes, e_left,
+ * > e_top, e_width, e_height, e_z_index, e_more_styles, e_content,
+ * > e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url)
+ * > VALUES('gui', 'zoomIn1', 2, 1, 'zoomIn button','Zoom in',
+ * > 'img','../img/button_gray/zoomIn2_off.png','',220,10,24,24,1,
+ * > '','','','mod_zoomIn1.js','','mapframe1','',
+ * > 'http://www.mapbender.org/index.php/ZoomIn');
+ * Maintainer:
+ * License:
+$(this).click(function () {
+ if (!options.target
+ || !Mapbender.modules[options.target]
+ || typeof Mapbender.modules[options.target].zoom !== "function") {
+ return;
+ Mapbender.modules[options.target].zoom(true, 2.0);
+}).mouseover(function () {
+ if (options.src) {
+ this.src = options.src.replace(/_off/, "_over");
+}).mouseout(function () {
+ this.src = options.src;
Added: branches/print_dev/http/javascripts/mod_zoomOut1.js
--- branches/print_dev/http/javascripts/mod_zoomOut1.js (rev 0)
+++ branches/print_dev/http/javascripts/mod_zoomOut1.js 2009-09-28 14:33:00 UTC (rev 4761)
@@ -0,0 +1,50 @@
+ * Package: ZoomOut1
+ * Description:
+ * Click button, which doubles the real world bounding box of the visible
+ * map section, halfes the scale (doubles the scale number). Image size
+ * is not affected.
+ * Files:
+ * - http/javascripts/mod_zoomOut1.js
+ * SQL:
+ * > e_mb_mod, e_target, e_requires, e_url) VALUES ('<app_id>','zoomOut1',
+ * > 2,1,'zoomOut button','Zoom out','img',
+ * > '../img/button_gray/zoomOut2_off.png','',245,10,24,24,1,'','','',
+ * > 'mod_zoomOut1.js','','mapframe1','',
+ * > 'http://www.mapbender.org/index.php/ZoomOut');
+ * Help:
+ * http://www.mapbender.org/ZoomOut
+ * Maintainer:
+ * License:
+ if (!options.target) {
+ return;
+ if (!Mapbender.modules[options.target]) {
+ return;
+ Mapbender.modules[options.target].zoom(false, 2.0);
Added: branches/print_dev/http/javascripts/user.php
--- branches/print_dev/http/javascripts/user.php (rev 0)
+++ branches/print_dev/http/javascripts/user.php 2009-09-28 14:33:00 UTC (rev 4761)
@@ -0,0 +1,18 @@
+<?php
+require_once(dirname(__FILE___)."/../classes/class_user.php");
+$ObjectConf = array("DisplayName" => "User",
+ "internalname" => "user",
+ "ClassName" => "User");
+$rpc->run();
Added: branches/print_dev/http/php/mod_abo_show.php
--- branches/print_dev/http/php/mod_abo_show.php (rev 0)
+++ branches/print_dev/http/php/mod_abo_show.php 2009-09-28 14:33:00 UTC (rev 4761)
@@ -0,0 +1,330 @@
+<?php
+# $Id: mod_monitorCapabilities_read.php 517 2006-11-21 12:37:01Z christoph $
+# http://www.mapbender.org/index.php/Monitor_Capabilities
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
+require_once(dirname(__FILE__)."/../classes/class_administration.php");
+require_once(dirname(__FILE__)."/../classes/class_user.php");
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
+<html>
+<head>
+<meta http-equiv="cache-control" content="no-cache">
+<meta http-equiv="pragma" content="no-cache">
+<meta http-equiv="expires" content="0">
+<?php
+echo '<meta http-equiv="Content-Type" content="text/html; charset='.CHARSET.'">';
+</head>
+<body>
+<?php
+$admin = new administration();
+$user = new User();
+$mail_admin_recipient = _mb("Mapbender Service Provider"); // "Diensteanbieter Geoportal.rlp"
+$mail_admin_topic = _mb("Confirmation of subscribers notification"); // "Versandmitteilung Abo-Sammelmail"
+$mail_admin_body = "You have sent the following mail to %d subscribers of your services"; // "Sie haben folgende Mail an %1\$s Abonnenten Ihrer Dienste versandt"
+$mail_user_recipient = _mb("Mapbender monitoring subscriber"); // "Abo Nutzer Geoportal.rlp"
+$mail_user_topic = _mb("Mapbender subscribers notification"); // "GeoPortal.rlp Mitteilung WMS Abonennten"
+$email_body_info = _mb("The following services are affected"); // "Die versandten Informationen betreffen folgende im Geoportal.rlp registrierten Dienste"
+$email_form_text = _mb("e-mail form for notifications to the subscribers of the following WMS"); // "EMail Formular für die Benachrichtung der Abonnenten folgender WMS Dienste"
+$email_body_footer = _mb("Subscriber notification for Mapbender service providers"); // "Abo-Benachrichtigungsfunktion für Anbieter von Diensten im GeoPortal.rlp (http://www.geoportal.rlp.de)"
+$email_sent_text = _mb("Notifications have been sent. You will receive a confirmation mail shortly."); // "Die Emails wurden versendet. Sie erhalten in Kürze eine Kontrollmail!"
+$email_create_text = _mb("Create mail form"); // "EMail Formular generieren"
+$wms_list_text = _mb("The subscribers to these WMS have been notified"); // "Liste der WMS-IDs deren Nutzer benachrichtigt wurden"
+$further_inquiry_text = _mb("For further inquiries contact"); // "Rückfragen bitte an"
+$mail_header = _mb("Subscriber notification"); // "EMail Benachrichtigung der Abonnenten"
+$number_of_subscribers_text = _mb("# subscribers"); // "# Anzahl Abonnenten"
+$notify_text = _mb("Notify"); // "Mailversand"
+$mail_send_text = _mb("Send mail"); // "Mail versenden"
+// WMS selected for notifications
+$checkboxes = intval($_POST['cbs']);
+if ($checkboxes > 0 || isset($_POST['wmslist'])){
+ //initialize list
+ $wms_id_list = "";
+ #get values for checked wms
+ for ($i=0; $i < $checkboxes; $i++) {
+ if (isset($_POST['cb'.$i])) {
+ $mail_wmsid = intval($_POST['cb'.$i]);
+ if ($user->isWmsOwner($mail_wmsid)) {
+ $wms_id_list .= "," . $mail_wmsid;
+ $wms_id_list=ltrim($wms_id_list, ",");
+ if (!isset($_POST['wmslist'])){
+ //do descriptive header
+ echo "<h3>" .
+ htmlentities(
+ $email_form_text,
+ ENT_QUOTES,
+ CHARSET
+ ) . ":</h3>";
+ //Show wmslist to be noticed
+ echo $wms_id_list;
+ //generate form to send email
+ echo "<form name = 'form2' method='post' action='".$PHP_SELF."'>";
+ //textfield for text to send
+ echo "<br><textarea name='emailtext' cols='120' rows='20'></textarea>";
+ //submit button for send email
+ echo "<br><input type=submit value='" . $mail_send_text . "'><br/>";
+ #Liste der WMS_ID's in hidden-Feld übergeben
+ echo "<input type=hidden name='wmslist' id='wmslist' value='".$wms_id_list."'>";
+ //if button send mail is pressed - send mails
+ else {
+ //create body for serviceurl list:
+ $body_urllist = "\n\n" .
+ $email_body_info .
+ ":\n";
+ if (preg_match("/^[0-9]+(,[0-9]+)*$/", $_POST['wmslist'])) {
+ $wms_array = explode(',',$_POST['wmslist']);
+ $metadataUrl = preg_replace("/(.*)frames\/login.php/", "$1php/mod_layerMetadata.php?id=", LOGIN);
+ for ($i=0; $i<count($wms_array); $i++) {
+ // get layer id
+ $sql = "select layer_id from layer where fkey_wms_id= $1 and layer_pos = 0";
+ $v = array($wms_array[$i]);
+ $t = array('i');
+ $res = db_prep_query($sql,$v,$t);
+ $layerid_body=db_result($res,0,0);
+ $body_urllist .= $metadataUrl . $layerid_body . "\n";
+ $body_urllist.="\n" .
+ $email_body_footer .
+ "\n";
+ //get user email adresses of abo-user
+ $sql = "select mb_user_email from mb_user, ";
+ $sql .= "(select distinct fkey_mb_user_id from mb_user_abo_ows " .
+ "where fkey_wms_id in (".$_POST['wmslist'].")) as abo_user ";
+ $sql .= "where abo_user.fkey_mb_user_id=mb_user.mb_user_id";
+ $res=db_query($sql);
+ $cnt = 0;
+ //Initialisieren des Arrays
+ $user_email=array();
+ //Herauslesen der Ergebnisse
+ //echo "wmslist ist gesetzt!\n<br>";
+ echo "<h3>" .
+ htmlentities(
+ $wms_list_text,
+ ENT_QUOTES,
+ CHARSET
+ ) . ":</h3> ".$_POST['wmslist']."\n<br><br>";
+ //echo "wms_id_list: ".$wms_id_list."\n<br>";
+ //get email of wms owner
+ $mail_wms_owner=$admin->getEmailByUserId($user->id);
+ while($row = db_fetch_array($res)){
+ //echo $cnt;
+ $user_email[$cnt] = $row["mb_user_email"];
+ $admin->sendEmail(
+ $mail_wms_owner,
+ $mail_wms_owner,
+ $user_email[$cnt],
+ $mail_user_recipient,
+ $mail_user_topic . " " . date("F j, Y, G:i:s"),
+ utf8_decode(strip_tags($_POST['emailtext']) . "\n\n" . $further_inquiry_text .
+ ": " . $mail_wms_owner . "\n" . $body_urllist));
+ $cnt++;
+ //controll mail for wms_owner
+ MAILADMIN,
+ MAILADMINNAME,
+ $mail_wms_owner,
+ $mail_admin_recipient,
+ $mail_admin_topic . " " . date("F j, Y, G:i:s"),
+ utf8_decode(_mb($mail_admin_body, $cnt).
+ "\n\n" .
+ strip_tags($_POST['emailtext']) . $body_urllist));
+ echo "<br>" .
+ htmlentities(
+ $email_sent_text,
+ ENT_QUOTES,
+ CHARSET
+ ) . "<br>";
+ echo "</form>\n";
+else {
+ // monitoring results
+ $sql = "SELECT DISTINCT mb_monitor.fkey_wms_id FROM mb_monitor, wms " .
+ "WHERE mb_monitor.fkey_wms_id = wms.wms_id AND wms.wms_owner = $1";
+ $res = db_prep_query($sql, array($user->id), array("i"));
+ $wms = array();
+ $wms[] = $row["fkey_wms_id"];
+ $status = array();
+ $upload_id = array();
+ for ($i=0; $i<count($wms); $i++) {
+ $wms_id[$wms[$i]] = $wms[$i];
+ // get layer id
+ $sql = "select layer_id from layer where fkey_wms_id= $1 and layer_pos=0";
+ $v = array($wms[$i]);
+ $t = array('i');
+ $layer_id[$wms[$i]] = db_result($res,0,0);
+ #Schleife zur Zaehlung der user die den jeweiligen Dienst abonniert haben
+ $sql = "select count(*) from mb_user_abo_ows where fkey_wms_id=$1";
+ $t = array('i');
+ $abo_count[$wms[$i]] = db_result($res,0,0);
+ $sql = "SELECT fkey_upload_id,last_status, status_comment, " .
+ "upload_url, availability, average_resp_time " .
+ "FROM mb_wms_availability WHERE fkey_wms_id = $1";
+ $v = array($wms_id[$wms[$i]]);
+ $t = array('i');
+ $avg_response_time[$wms[$i]] = round(db_result($res,0,"average_resp_time"),1);
+ $status[$wms[$i]] = intval(db_result($res,0,"last_status"));
+ $comment[$wms[$i]] = db_result($res,0,"status_comment");
+ $upload_url[$wms[$i]] = db_result($res,0,"upload_url");
+ $percentage[$wms[$i]]=db_result($res,0,"availability");
+ $upload_id[$wms[$i]] = db_result($res,0,"fkey_upload_id");
+ $newArray = $status;
+ if ($_GET['sortby']) {
+ if ($_GET['sortby'] == "wms") {
+ $newArray = $wms_id;
+ asort($newArray);
+ elseif ($_GET['sortby'] == "status") {
+ asort($newArray);
+ elseif ($_GET['sortby'] == "avgresp") {
+ $newArray = $avg_response_time;
+ asort($newArray);
+ elseif ($_GET['sortby'] == "avail") {
+ $newArray = $percentage;
+ arsort($newArray);
+ elseif ($_GET['sortby'] == "last") {
+ $newArray = $upload_id;
+ $str = "<span style='font-size:30'>" .
+ $mail_header .
+ "</span><hr><br>\n" .
+ "<form name = 'form1' method='post' action='" . $PHP_SELF . "?sortby=" .
+ $_GET['sortby']."'>\n\t" .
+ "\n\t<input type=submit value='" . $email_create_text .
+ "'>\n<br/><br/>\n" .
+ "<table cellpadding=10 cellspacing=0 border=0>" .
+ "<tr bgcolor='#dddddd'>" .
+ "<th align='left'>" . $notify_text . "</a></th>" .
+ "<th align='left'><a href='" . $PHP_SELF . "?sortby=wms'>wms</a></th>" .
+ "<th align='left' colspan = 2><a href='" . $PHP_SELF .
+ "?sortby=status'>current status</a></th>" .
+ "?sortby=avgresp'>avg. response time</a></th>" .
+ "?sortby=avail'>overall availability</a></th>" .
+ "<th align='left'>" . $number_of_subscribers_text . "</th><th></th>" .
+ "</tr>";
+ $cnt = 0;
+ foreach ($newArray as $k => $value) {
+ $img = "stop.bmp";
+ if ($status[$k]==0) $img = "wait.bmp";
+ elseif ($status[$k]==1) $img = "go.bmp";
+ #if ($updated[$k] == "0" && $status[$k] == 0) $fill = "checked"; else $fill = "disabled";
+ if (fmod($cnt, 2) == 1) {
+ $str .= "\n\t\t<tr bgcolor='#e6e6e6'>";
+ else {
+ $str .= "\n\t\t<tr bgcolor='#f0f0f0'>";
+ #generieren der checkboxen für jeden wms namen: cb123, wert 123, der andere input fuer upl_id123 mit wert des upload_ids aus der monitor tabelle - unnoetig
+ $str .= "\n\t\t\t<td><input name='cb".$cnt."' value='" . $wms_id[$k] . "' type=checkbox />";
+ #<input type=hidden name='upl_id".$cnt."' value='".$upload_id[$k]."'>
+ $str .= "</td>";
+ $str .= "\n\t\t\t<td valign='top'><a href='../php/mod_layerMetadata.php?id=" . $layer_id[$k] ."' onclick='window.open(this.href,'Metadaten','width=500,height=600,left=100,top=200,scrollbars=yes ,dependent=yes'); return false' target='_blank' >Dienst ID: ". $wms_id[$k] ."</a><br>" . $admin->getWmsTitleByWmsId($wms_id[$k]) . "</td>";
+ #$str .= "\n\t\t\t<td valign='top'><b>" . $wms_id[$k] . "</b><br>" . $admin->getWmsTitleByWmsId($wms_id[$k]) . "</td>";
+ $str .= "\n\t\t\t<td valign='top'><a href='".$upload_url[$k]."' target=_blank><img title='Connect to service' border=0 src = '../img/trafficlights/". $img. "'></a></td>";
+ $str .= "\n\t\t\t<td valign='top'>" . $comment[$k] . "<br><div style='font-size:12'>".date("F j, Y, G:i:s", $upload_id[$k])."</div></td>";
+ $str .= "\n\t\t\t<td valign='top' align = 'left'>";
+ if ($avg_response_time[$k] == NULL) {
+ $str .= "n/a";
+ else {
+ $str .= $avg_response_time[$k] . " s";
+ $str .= "</td>";
+ $str .= "\n\t\t\t<td valign='top'><b>" . $percentage[$k] . " %</b> <span style='font-size:12'>(" . $total[$k] . " cycles)</span><br>";
+ $str .= "<table bgcolor='black' border=1 cellspacing=1 cellpadding=0><tr>";
+ $val = $percentage[$k];
+ for ($i=0; $i<10; $i++) {
+ if ($val>=10) {
+ $str .= "<td height=10 width='10' bgcolor='red'></td>";
+ $val-=10;
+ elseif($val>0){
+ $str .= "<td height=10 width='" . round($val) . "' bgcolor='red'></td>";
+ if (round($val) < 10) {
+ $str .= "<td height=10 width='" . (9-round($val)) . "' bgcolor='white'></td>";
+ $val=-1;
+ else {
+ $str .= "<td height=10 width='10' bgcolor='white'></td>";
+ $str .= "</tr></table></td>";
+ $str .= "\n\t\t\t<td>".$abo_count[$k]."</td>";
+ $str .= "\n\t\t<td><input type=button value='details' onclick=\"var newWindow = window.open('../php/mod_monitorCapabilities_read_single.php?wmsid=".$wms_id[$k]."','wms','width=500,height=700,scrollbars');newWindow.href.location='test.php'\"></td></tr>";
+ $cnt++;
+ $str .= "\n\t</table>\n\t<br/><input type=hidden name=cbs value='".$cnt."'>\n</form>";
+ echo $str;
+</body></html>
Added: branches/print_dev/http/php/mod_coordsLookup_server.php
--- branches/print_dev/http/php/mod_coordsLookup_server.php (rev 0)
+++ branches/print_dev/http/php/mod_coordsLookup_server.php 2009-09-28 14:33:00 UTC (rev 4761)
@@ -0,0 +1,139 @@
+<?php
+# $Id: mod_changeEPSG.php 2413 2008-04-23 16:21:04Z christoph $
+# http://www.mapbender.org/index.php/mod_changeEPSG.php
+require(dirname(__FILE__)."/mb_validateSession.php");
+$epsgObj = array();
+$ajaxResponse = new AjaxResponse($_POST);
+function transform ($x, $y, $oldEPSG, $newEPSG) {
+ if (is_null($x) || !is_numeric($x) ||
+ is_null($y) || !is_numeric($y) ||
+ is_null($oldEPSG) || !is_numeric($oldEPSG) ||
+ is_null($newEPSG) || !is_numeric($newEPSG)) {
+ return null;
+ if(SYS_DBTYPE=='pgsql'){
+ $con = db_connect(DBSERVER, OWNER, PW);
+ $sqlMinx = "SELECT X(transform(GeometryFromText('POINT(".$x." ".$y.")',".$oldEPSG."),".$newEPSG.")) as minx";
+ $resMinx = db_query($sqlMinx);
+ $minx = floatval(db_result($resMinx,0,"minx"));
+ $sqlMiny = "SELECT Y(transform(GeometryFromText('POINT(".$x." ".$y.")',".$oldEPSG."),".$newEPSG.")) as miny";
+ $resMiny = db_query($sqlMiny);
+ $miny = floatval(db_result($resMiny,0,"miny"));
+ }else{
+ $con_string = "host=" . GEOS_DBSERVER . " port=" . GEOS_PORT .
+ " dbname=" . GEOS_DB . "user=" . GEOS_OWNER .
+ "password=" . GEOS_PW;
+ $con = pg_connect($con_string) or die ("Error while connecting database");
+ $resMinx = pg_query($con,$sqlMinx);
+ $minx = floatval(pg_fetch_result($resMinx,0,"minx"));
+ $resMiny = pg_query($con,$sqlMiny);
+ $miny = floatval(pg_fetch_result($resMiny,0,"miny"));
+ return array("x" => $minx, "y" => $miny);
+switch ($ajaxResponse->getMethod()) {
+ case "transform" :
+ if (!Mapbender::postgisAvailable()) {
+ $ajaxResponse->setSuccess(false);
+ $ajaxResponse->setMessage(_mb("PostGIS is not available. Please contact the administrator."));
+ $ajaxResponse->send();
+ $fromSrs = $ajaxResponse->getParameter("fromSrs");
+ $toSrs = $ajaxResponse->getParameter("toSrs");
+ $x = $ajaxResponse->getParameter("x");
+ $y = $ajaxResponse->getParameter("y");
+ $bboxStr = $ajaxResponse->getParameter("bbox");
+ $bbox = explode(",", $bboxStr);
+ $response = null;
+ $oldEPSG = preg_replace("/EPSG:/","", $fromSrs);
+ $newEPSG = preg_replace("/EPSG:/","", $toSrs);
+ if (!is_null($bbox) && is_array($bbox) && count($bbox) === 4) {
+ $response = array(
+ "newSrs" => $toSrs,
+ "points" => array()
+ for ($i = 0; $i < count($bbox); $i+=2) {
+ $pt = transform(
+ floatval($bbox[$i]),
+ floatval($bbox[$i+1]),
+ $oldEPSG,
+ $newEPSG
+ if (!is_null($pt)) {
+ $response["points"][]= array(
+ "x" => $pt["x"],
+ "y" => $pt["y"]
+ else {
+ $response = null;
+ break;
+ else {
+ $pt = transform($x, $y, $oldEPSG, $newEPSG);
+ "points" => array(array(
+ "x" => $pt["x"],
+ "y" => $pt["y"]
+ if (is_null($response)) {
+ $ajaxResponse->setMessage(_mb("An unknown error occured."));
+ else {
+ $ajaxResponse->setSuccess(true);
+ $ajaxResponse->setResult($response);
+ break;
+ default :
+ break;
+$ajaxResponse->send();
\ No newline at end of file
Added: branches/print_dev/http/php/mod_monitorCapabilities_read.php
--- branches/print_dev/http/php/mod_monitorCapabilities_read.php (rev 0)
+++ branches/print_dev/http/php/mod_monitorCapabilities_read.php 2009-09-28 14:33:00 UTC (rev 4761)
@@ -0,0 +1,308 @@
+<?php
+# $Id: mod_monitorCapabilities_read.php 1283 2007-10-25 15:20:25Z baudson $
+require_once(dirname(__FILE__)."/../classes/class_wms.php");
+<html>
+<head>
+<?php
+</head>
+<body>
+<?php
+// update selected wms
+for ($i=0; $i < $checkboxes; $i++) {
+ echo $i;
+ if (!isset($_POST['cb'.$i]) ||
+ !isset($_POST['upl_id'.$i])
+ continue;
+ $upd_wmsid = intval($_POST['cb'.$i]);
+ $upload_id = intval($_POST['upl_id'.$i]);
+ if ($upd_wmsid) {
+ // get upload URL
+ $sql = "SELECT wms_upload_url, wms_owner FROM wms WHERE wms_id = $1";
+ $v = array($upd_wmsid);
+ $t = array("i");
+ $res = db_prep_query($sql, $v, $t);
+ $row = db_fetch_array($res);
+ $uploadUrl = $row["wms_upload_url"];
+ $wmsOwner = $row["wms_owner"];
+ if ($wmsOwner !== $user->id) {
+ echo "<br>Skipped: " . $upd_wmsid . "<br>";
+ continue;
+ // update WMS from upload URL
+ $mywms = new wms();
+ $mywms->createObjFromXML($uploadUrl);
+ $mywms->optimizeWMS();
+ echo "<br />";
+ $mywms->updateObjInDB($upd_wmsid);
+ echo "<br>Updated: " . $upd_wmsid . "<br>";
+ // start new monitoring for this WMS
+ $now = time();
+ $sql = "UPDATE mb_monitor SET status = '-2', status_comment = 'Monitoring is still in progress...', " .
+ "timestamp_begin = $1, timestamp_end = $2 WHERE upload_id = $3 AND fkey_wms_id = $4";
+ $v = array($now, $now, $upload_id, $upd_wmsid);
+ $t = array('s', 's', 's', 'i');
+ $currentFilename = "wms_monitor_report_" . $upload_id . "_" .
+ $upd_wmsid . "_" . $wmsOwner . ".xml";
+ $exec = PHP_PATH . "php5 ../../tools/mod_monitorCapabilities_write.php " .
+ $currentFilename. " 0";
+ echo exec($exec);
+ echo "<br>Please note: The updated services need to be monitored again in order to update the database.<br><br>";
+$sql = "SELECT DISTINCT mb_monitor.fkey_wms_id FROM mb_monitor, wms " .
+$res = db_prep_query($sql, array($_SESSION["mb_user_id"]), array("i"));
+$wms = array();
+while($row = db_fetch_array($res)){
+$wms_id = array();
+$status = array();
+$upload_id = array();
+$avg_response_time = array();
+$comment = array();
+$timestamp_begin = array();
+$timestamp_end = array();
+$upload_url = array();
+$updated = array();
+$mapurl = array();
+$image = array();
+for ($i = 0; $i < count($wms); $i++) {
+ // get upload id
+ $sql = "SELECT MAX(upload_id) FROM mb_monitor WHERE fkey_wms_id = $1";
+ $t = array('i');
+ $upload_id[$wms[$i]] = db_result($res,0,0);
+ $sql = "SELECT AVG(timestamp_begin), AVG(timestamp_end) FROM mb_monitor " .
+ "WHERE fkey_wms_id = $1 AND NOT status = '-1' AND NOT status = '-2'";
+ $t = array('i');
+ if (db_result($res,0,1) == 0 && db_result($res,0,0) == 0) {
+ $avg_response_time[$wms[$i]] = NULL;
+ else {
+ $avg_response_time[$wms[$i]] = round(db_result($res,0,1)-db_result($res,0,0), 1);
+ $sql = "SELECT status, status_comment, timestamp_begin, timestamp_end, " .
+ "upload_url, updated, image, map_url, caps_diff FROM mb_monitor, wms " .
+ "WHERE upload_id = $1 AND fkey_wms_id = $2 AND wms_owner = $3 ORDER BY status, " .
+ "status_comment, timestamp_end, fkey_wms_id";
+ $v = array($upload_id[$wms[$i]], $wms_id[$wms[$i]], $user->id);
+ $t = array('s', 'i', 'i');
+ $status[$wms[$i]] = intval(db_result($res,0,"status"));
+ $timestamp_begin[$wms[$i]] = db_result($res,0,"timestamp_begin");
+ $timestamp_end[$wms[$i]] = db_result($res,0,"timestamp_end");
+ $updated[$wms[$i]] = db_result($res,0,"updated");
+ $mapurl[$wms[$i]] = db_result($res,0,"map_url");
+ $image[$wms[$i]] = db_result($res,0,"image");
+ $caps_diff[$wms[$i]] = db_result($res,0,"caps_diff");
+ if ($status[$wms[$i]] == -2 &&
+ intval(time())-intval($timestamp_begin[$wms[$i]]) > intval(TIME_LIMIT))
+ $comment[$wms[$i]] = "Monitoring process timed out.";
+ $new_sql = "UPDATE mb_monitor SET status = '-1', status_comment = 'Monitoring process timed out.', timestamp_end = $1 WHERE fkey_wms_id = $2 AND upload_id = $3";
+ $new_v = array((intval($upload_id[$wms[$i]])+intval(TIME_LIMIT)), $wms_id[$wms[$i]], $upload_id[$wms[$i]]);
+ $new_t = array('s', 'i', 's');
+ $new_res = db_prep_query($new_sql,$new_v,$new_t);
+ $sql = "SELECT COUNT(upload_id) FROM mb_monitor WHERE fkey_wms_id = $1 AND NOT status = '-2'";
+ $t = array('i');
+ $total[$wms[$i]] = db_result($res, 0, 0);
+ $sql = "SELECT COUNT(upload_id) FROM mb_monitor WHERE fkey_wms_id = $1 AND status = '-1'";
+ $t = array('i');
+ $fail = db_result($res, 0, 0);
+ $percentage[$wms[$i]] = 100 - round(100*floatval($fail)/floatval($total[$wms[$i]]), 1);
+$newArray = $status;
+if ($_GET['sortby']) {
+ asort($newArray);
+ asort($newArray);
+ asort($newArray);
+ elseif ($_GET['image'] == "last") {
+ $newArray = $image;
+$str = "<span style='font-size:30'>monitoring results</span><hr><br>\n";
+$str .= "<form name = 'form1' method='post' action='".$PHP_SELF."?sortby=".$_GET['sortby']."'>\n\t";
+$str .= "\n\t<input type=submit value='update selected WMS'>\n";
+$str .= "\n\t<input type=button onclick=\"self.location.href='".$PHP_SELF."?sortby=".$_GET['sortby']."'\" value='refresh'>\n<br/><br/>\n ";
+$str .= "<table cellpadding=10 cellspacing=0 border=0>";
+$str .= "<tr bgcolor='#dddddd'><th></th><th align='left'><a href='".$PHP_SELF."?sortby=wms'>wms</a></th>";
+$str .= "<th align='left' colspan = 2><a href='".$PHP_SELF."?sortby=status'>current status</a></th>";
+$str .= "<th align='left'><a href='".$PHP_SELF."?sortby=image'>image</a></th>";
+$str .= "<th align='left'><a href='".$PHP_SELF."?sortby=avgresp'>avg. response time</a></th>";
+$str .= "<th align='left'><a href='".$PHP_SELF."?sortby=avail'>overall availability</a></th><th></th><th>Diff</th></tr>";
+$cnt = 0;
+foreach ($newArray as $k => $value) {
+ if ($updated[$k] == "0" && $status[$k] == 0) $fill = "checked"; else $fill = "disabled";
+ else {
+ $str .= "\n\t\t\t<td><input name='cb".$cnt."' value='" . $wms_id[$k] . "' type=checkbox ".$fill." /><input type=hidden name='upl_id".$cnt."' value='".$upload_id[$k]."'></td>";
+ $str .= "\n\t\t\t<td valign='top'><b>" . $wms_id[$k] . "</b><br>" . $admin->getWmsTitleByWmsId($wms_id[$k]) . "</td>";
+ $str .= "\n\t\t\t<td valign='top'>";
+ $str .= "<table bgcolor='black' border=1 cellspacing=1 cellpadding=0><tr><td height=20 width=20 align=center valign=middle bgcolor='";
+ if ($image[$k] == -1) {
+ $str .= "red";
+ elseif ($image[$k] == 0) {
+ $str .= "yellow";
+ elseif ($image[$k] == 1) {
+ $str .= "green";
+ if ($image[$k] != -1) {
+ $str .= "'><a href='".$mapurl[$k]."'>o</a></td></tr></table></td>";
+ else {
+ $str .= "'><a href='".$mapurl[$k]."'>x</a></td></tr></table></td>";
+ $str .= "n/a";
+ else {
+ $str .= "</td>";
+ if ($val>=10) {
+ $val-=10;
+ elseif($val>0){
+ $val=-1;
+ else {
+# $str .= "\n\t\t\t<td><a href='output_".$wms_id[$k]."_".$max.".txt' target=_blank>log</a></td>";
+ $str .= "\n\t\t<td><input type=button value='details' onclick=\"var newWindow = window.open('../php/mod_monitorCapabilities_read_single.php?wmsid=".$wms_id[$k]."','wms','width=500,height=700,scrollbars');newWindow.href.location='test.php'\"></td>";
+ $str .= "\n\t\t\t<td>";
+ if ($caps_diff[$k] != "")
+ $str .= "<a href='mod_monitorCapabilities_read_single_diff.php?wmsid=".$wms_id[$k]."&upload_id=".$upload_id[$k]."' target=_blank>view</a>";
+ $str .= "</td></tr>";
+ $cnt++;
+$str .= "\n\t</table>\n\t<br/><input type=hidden name=cbs value='".$cnt."'>\n</form>";
+echo $str;
+</body></html>
Added: branches/print_dev/http/php/mod_monitorCapabilities_read_single.php
--- branches/print_dev/http/php/mod_monitorCapabilities_read_single.php (rev 0)
+++ branches/print_dev/http/php/mod_monitorCapabilities_read_single.php 2009-09-28 14:33:00 UTC (rev 4761)
@@ -0,0 +1,102 @@
+<?php
+# $Id: mod_monitorCapabilities_read_single.php 76 2006-08-15 12:25:34Z heuser $
+#require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
+require_once(dirname(__FILE__)."/../../conf/mapbender.conf");
+session_start();
+import_request_variables("PG");
+$con = db_connect($DBSERVER,$OWNER,$PW);
+db_select_db(DB,$con);
+<html>
+<head>
+<?php
+</head>
+<body>
+<?php
+if ($_GET['wmsid']) {
+ $wms_id = intval($_GET['wmsid']);
+else {
+ echo "Invalid WMS ID.";
+ die;
+$sql = "SELECT upload_id, status, status_comment, timestamp_begin, timestamp_end, upload_url, updated FROM mb_monitor ";
+$sql .= "WHERE fkey_wms_id = $1 AND NOT status = '-2' ORDER BY upload_id DESC";
+$v = array($wms_id);
+$t = array('i');
+$res = db_prep_query($sql,$v,$t);
+$cnt=0;
+while ($row = db_fetch_array($res)) {
+ $upload_id[$cnt] = db_result($res,$cnt,"upload_id");
+ $status[$cnt] = intval(db_result($res,$cnt,"status"));
+ $comment[$cnt] = db_result($res,$cnt,"status_comment");
+ $timestamp_begin = db_result($res,$cnt,"timestamp_begin");
+ $timestamp_end = db_result($res,$cnt,"timestamp_end");
+ $upload_url[$cnt] = db_result($res,$cnt,"upload_url");
+ if ($status[$cnt] == '0' || $status[$cnt] == '1') {
+ $response_time[$cnt] = strval($timestamp_end-$timestamp_begin) . " s";
+ else {
+ $response_time[$cnt] = "n/a";
+ $cnt++;
+$str .= "<b>" . $wms_id . "</b><br>" . $admin->getWmsTitleByWmsId($wms_id) . "<br><br><br>\n";
+$str .= "<tr bgcolor='#dddddd'><th align='left'>date</th><th align='left' colspan = 2>status</th><th align='center'>response time</th></tr>";
+for ($k=0; $k<count($upload_id); $k++) {
+ if (fmod($k, 2) == 1) {
+ else {
+ $str .= "\n\t\t\t<td>".date("F j, Y, G:i:s", $upload_id[$k])."</td>";
+ $str .= "\n\t\t\t<td><a href='".$upload_url[$k]."' target=_blank><img title='Connect to service' border=0 src = '../img/trafficlights/". $img. "'></a></td>";
+ $str .= "\n\t\t\t<td>" . $comment[$k] . "</td>";
+ $str .= "\n\t\t\t<td align='center'>" . $response_time[$k] . "</td>";
+$str .= "\n\t</table>\n\t";
+echo $str;
+</body></html>
Added: branches/print_dev/http/php/mod_monitorCapabilities_read_single_diff.php
--- branches/print_dev/http/php/mod_monitorCapabilities_read_single_diff.php (rev 0)
+++ branches/print_dev/http/php/mod_monitorCapabilities_read_single_diff.php 2009-09-28 14:33:00 UTC (rev 4761)
@@ -0,0 +1,85 @@
+<?php
+# $Id: mod_monitorCapabilities_read_single_diff.php 3342 2008-12-16 12:31:26Z mschulz $
+<html>
+<head>
+<title>Mapbender - monitor diff results</title>
+<?php
+<style type="text/css">
+* {font-family: Arial, "Courier New", monospace; font-size: small;}
+.diff-context {background: #eee;}
+.diff-deletedline {background: #eaa;}
+.diff-addedline {background: #aea;}
+.diff-blockheader {background: #ccc;}
+</style>
+</head>
+<body>
+<?php
+else {
+ die;
+if ($_GET['upload_id']) {
+ $upload_id = intval($_GET['upload_id']);
+else {
+ echo "Invalid upload ID.";
+ die;
+$sql = "SELECT caps_diff FROM mb_monitor ";
+$sql .= "WHERE fkey_wms_id = $1 AND upload_id = $2";
+$v = array($wms_id,$upload_id);
+$t = array('i','i');
+ $caps_diff = db_result($res,0,"caps_diff");
+$str .= "<table cellpadding=3 cellspacing=0 border=0>";
+$str .= "<tr><td align='center' colspan='2'>Local</td><td align='center' colspan='2'>Remote</td></tr>";
+$str .= $caps_diff;
+echo $str;
+</body></html>
Added: branches/print_dev/http/php/mod_wmc2ol.php
--- branches/print_dev/http/php/mod_wmc2ol.php (rev 0)
+++ branches/print_dev/http/php/mod_wmc2ol.php 2009-09-28 14:33:00 UTC (rev 4761)
@@ -0,0 +1,447 @@
+<?php
+require_once(dirname(__FILE__)."/../../globalSettings.php.php");
+$userId = Mapbender::session()->get("mb_user_id");
+//check for parameter wmc_id
+if (!isset($_GET["wmc_id"])) {
+ echo 'Error: wmc_id not requested<br>';
+ die;
+ //must leave script
+function _e ($str) {
+ return htmlentities($str, ENT_QUOTES, CHARSET);
+if (!$userId) {
+ $userId = PUBLIC_USER;
+//the next functions should come from class administration, but they are not included as they are needed
+//TODO
+function getLayerPermission($wms_id, $layer_id, $user_id){
+ //$layer_id = $this->getLayerIdByLayerName($wms_id,$layer_name);
+ $array_guis = getGuisByPermission($user_id,true);
+ $v = array();
+ $t = array();
+ $sql = "SELECT * FROM gui_layer WHERE fkey_gui_id IN (";
+ $c = 1;
+ //generate guilist assigned to specific user
+ for($i=0; $i<count($array_guis); $i++){
+ if($i>0){ $sql .= ",";}
+ $sql .= "$".$c;
+ $c++;
+ array_push($v, $array_guis[$i]);
+ array_push($t, 's');
+ $sql .= ") AND fkey_layer_id = $".$c." AND gui_layer_status = 1"; //status 1 must be
+ array_push($v,$layer_id);
+ array_push($t,'i');
+ if($row = db_fetch_array($res)){
+ return true;
+ else{
+ return false;
+function getGuisByPermission($mb_user_id,$ignoreublic){
+ $arrayGuis = array();
+ $mb_user_groups = array();
+ $sql_groups = "SELECT fkey_mb_group_id FROM mb_user_mb_group WHERE fkey_mb_user_id = $1 ";
+ $v = array($mb_user_id);
+ $t = array("i");
+ $res_groups = db_prep_query($sql_groups,$v,$t);
+ $cnt_groups = 0;
+ while($row = db_fetch_array($res_groups)){
+ $mb_user_groups[$cnt_groups] = $row["fkey_mb_group_id"];
+ $cnt_groups++;
+ if($cnt_groups > 0){
+ $v = array();
+ $t = array();
+ $sql_g = "SELECT gui.gui_id FROM gui JOIN gui_mb_group ";
+ $sql_g .= " ON gui.gui_id = gui_mb_group.fkey_gui_id WHERE gui_mb_group.fkey_mb_group_id IN (";
+ for($i=0; $i<count($mb_user_groups);$i++){
+ if($i > 0){$sql_g .= ",";}
+ $sql_g .= "$".strval($i+1);
+ array_push($v,$mb_user_groups[$i]);
+ array_push($t,"i");
+ $sql_g .= ") GROUP BY gui.gui_id";
+ $res_g = db_prep_query($sql_g,$v,$t);
+ while($row = db_fetch_array($res_g)){
+ array_push($arrayGuis,$row["gui_id"]);
+ $sql_guis = "SELECT gui.gui_id FROM gui JOIN gui_mb_user ON gui.gui_id = gui_mb_user.fkey_gui_id";
+ $sql_guis .= " WHERE (gui_mb_user.fkey_mb_user_id = $1) ";
+ if (!isset($ignore_public) OR $ignore_public== false){
+ $sql_guis .= " AND gui.gui_public = 1 ";
+ $sql_guis .= " GROUP BY gui.gui_id";
+ $t = array("i");
+ $res_guis = db_prep_query($sql_guis,$v,$t);
+ $guis = array();
+ while($row = db_fetch_array($res_guis)){
+ if(!in_array($row['gui_id'],$arrayGuis)){
+ return $arrayGuis;
+//end of functions which m,ay be included from class_administration in next versions
+//Function to create an OpenLayers Javascript from a mapbender wmc document
+function createOlFromWMC_id($wmc_id){
+ global $userId;
+ //Get WMC out of mb Database
+ $sql = "SELECT wmc FROM mb_user_wmc WHERE wmc_id = $1";
+ $res = db_prep_query($sql, array($wmc_id), array("s"));
+ $wmc = db_fetch_row($res);
+ //Read out WMC into XML object
+ $xml=simplexml_load_string($wmc[0], "SimpleXMLElement", LIBXML_NOBLANKS);
+ //generate general html data
+ $html='';
+ $html.="<html xmlns='http://www.w3.org/1999/xhtml'>\n";
+ $html.="<head>\n";
+ //define global variables for extent out of WMC File
+ $windowWidth=$xml->General->Window->attributes()->width;
+ $windowHeight=$xml->General->Window->attributes()->height;
+ $htmlWidth=$windowWidth+40;
+ $htmlHeight=$windowHeight+70;
+ //define CSS
+ $html.="<style type='text/css'>\n";
+ $html.=" #map {\n";
+ $html.="width: ".$windowWidth."px;\n";
+ $html.="height: ".$windowHeight."px;\n";
+ $html.="border: 1px solid black;\n";
+ $html.="overflow:visible;\n";
+ $html.="}\n";
+ $html.=" #srs {\n";
+ $html.="font-size: 80%;\n";
+ $html.="color: #444;\n";
+ $html.="}\n";
+ $html.=" #showpos {\n";
+ $html.="}\n";
+ $html.="</style>\n";
+ //Generate Title
+ $html.="<title>".$xml->General->Title."</title>\n";
+ //include OL libs from local source - must be minimized
+ $html.="<script src='../extensions/OpenLayers-2.8/OpenLayers.js'></script>\n";
+ $html.="<script type='text/javascript'>\n";
+ //check for queryable layers
+ $layer_array_queryable=array();
+ $layer_array=$xml->LayerList->Layer;
+ $html.="var map;\n";
+ $someLayerQueryable=false;
+ for ($i=0; $i<count($layer_array); $i++) {
+ $html.="var layer".$i.";\n";
+ $mb_extensions=$xml->LayerList->Layer[$i]->Extension->children('http://www.mapbender.org/context');
+ $layer_array_queryable[$i]=$mb_extensions->querylayer;
+ if (($layer_array_queryable[$i]=='1') and ($xml->LayerList->Layer[$i]->attributes()->hidden=='0')){
+ $someLayerQueryable=true;
+ //define special BBOX
+ $out_box=0.3;
+ //get min/max extents for olbox
+ $minx = $xml->General->BoundingBox->attributes()->minx;
+ $miny = $xml->General->BoundingBox['miny'];
+ $maxx = $xml->General->BoundingBox['maxx'];
+ $maxy = $xml->General->BoundingBox['maxy'];
+ $centralx=floor(($maxx+$minx)/2);
+ $centraly=floor(($maxy+$miny)/2);
+ $dx=$maxx-$minx;//in meters
+ $dy=$maxy-$miny;//in meters
+ //define zoom levels
+ $numberZoomLevels=20;
+ //define central position in projected system
+ $html.="var lat = $centralx;\n";
+ $html.="var lon = $centraly;\n";
+ $centralPointx=($maxx+$minx)/2;
+ $centralPointy=($maxy+$miny)/2;
+ //startzoom faktor - check if usefull
+ $html.="var zoom = 10;\n";
+ //start function for initialize client
+ $html.="function init(){\n";
+ //define ol map object
+ $html.="map = new OpenLayers.Map( 'map' );\n";
+ $html.=" var markers;\n";
+ //define options for ol map object
+ $html.="var options = {\n";
+ $html.=" projection: \"".$xml->General->BoundingBox['SRS']."\",\n";
+ if ($xml->General->BoundingBox['SRS']=='EPSG:4326'){
+ echo 'Please choose an other coordinatereferencesystem. Converting Scales to Geographic Coordinates is not yet implemented!';
+ return;
+ $html.=" units: \"m\",\n";
+ $html.="numZoomLevels: ".$numberZoomLevels.",\n";
+ $html.="minResolution: 0.01\n";
+ $html.="};\n";
+ //New for given GET Params mb_myBBOX and mb_myBBOXEpsg******************************************
+ //Before defining the bounds check if mb_myBBOX and mb_myBBOXEpsg are defined.
+ //Check for given mb_myBBOX
+ if(isset($_REQUEST["mb_myBBOX"])){
+ //Check for numerical values for BBOX
+ $array_bbox=explode(',',$_REQUEST["mb_myBBOX"]);
+ if ((is_numeric($array_bbox[0])) and (is_numeric($array_bbox[1])) and (is_numeric($array_bbox[2])) and (is_numeric($array_bbox[3])) ) {
+ if(isset($_REQUEST["mb_myBBOXEpsg"])){
+ //Check epsg
+ $targetEpsg=intval($_REQUEST["mb_myBBOXEpsg"]);
+ if (($targetEpsg >= 1) and ($targetEpsg <= 50001)) {
+ #echo "is in the codespace of the epsg registry\n";
+ } else {
+ #echo "is outside\n";
+ echo "alert('The REQUEST parameter mb_myBBOXEpsg is not in the epsg realm - please define another EPSG Code.');";
+ return;
+ //Check if epsg is equal to BBOXEpsg
+ //Get epsg code out of WMC
+ $xml_epsg=str_replace('EPSG:','',$xml->General->BoundingBox['SRS']);
+ if ($_REQUEST["mb_myBBOXEpsg"]!=$xml_epsg){
+ //Transform the given BBOX to epsg of WMC
+ $sql= "select asewkt(transform(GeometryFromText ( 'LINESTRING ( ".$array_bbox[0]." ".$array_bbox[1].",".$array_bbox[2]." ".$array_bbox[3]." )', $targetEpsg ),".intval($xml_epsg)."))";
+ $e = new mb_notice("mod_wms2ol.php: sql (transform)=".$sql);
+ $res = db_query($sql);
+ //read out result
+ $text_bbox = db_fetch_row($res);
+ $e = new mb_notice("mod_wms2ol.php: text_bbox=".$text_bbox[0]);
+ $pattern = '~LINESTRING\((.*)\)~i';
+ preg_match($pattern, $text_bbox[0], $subpattern);
+ $e = new mb_notice("mod_wms2ol.php: subpattern=".$subpattern[1]);
+ //exchange blancspaces
+ $new_bbox = str_replace(" ", ",", $subpattern[1]);
+ //set new BBOX
+ $array_bbox_new=explode(',',$new_bbox);
+ $minx_new=$array_bbox_new[0];
+ $miny_new=$array_bbox_new[1];
+ $maxx_new=$array_bbox_new[2];
+ $maxy_new=$array_bbox_new[3];
+ $centralx=($maxx_new+$minx_new)/2;
+ $centraly=($maxy_new+$miny_new)/2;
+ else
+ //Set the new BBOX unaltered
+ $minx=$array_bbox[0];
+ $miny=$array_bbox[1];
+ $maxx=$array_bbox[2];
+ $maxy=$array_bbox[3];
+ else
+ echo "alert('The REQUEST parameters for mb_myBBOX are not numeric - please give numeric values!');";
+ return;
+ //define variable bounds
+ $html.="var bounds = new OpenLayers.Bounds(".$minx.",".$miny.",".$maxx.",".$maxy.");\n";
+ //if some layer defined, create base layer -> first layer in wmc
+ if (count($layer_array) != 0){
+ $i=0;
+ $html.="layer0 = new OpenLayers.Layer.WMS( \"".$xml->LayerList->Layer[$i]->Title."\",\n";
+ $extensions=$xml->LayerList->Layer[$i]->Extension->children('http://www.mapbender.org/context');
+ $layer_id=dom_import_simplexml($extensions->layer_id)->nodeValue;
+ $wms_id=$extensions->wms_id;
+// ?! $has_permission=getLayerPermission($wms_id,$layer_id,2);//problem: guest user must have fix id
+ $has_permission=getLayerPermission($wms_id,$layer_id,$userId);//problem: guest user must have fix id
+ //echo $layer_id."<br>";
+ if ($has_permission || $layer_id==''){
+ $html.="\"".$xml->LayerList->Layer[$i]->Server->OnlineResource->attributes('http://www.w3.org/1999/xlink')->href."\",\n";
+ $html.="{\n";
+ $html.="layers: \"".$xml->LayerList->Layer[$i]->Name."\",\n";
+ //get FormatList and the current active format -> TODO: make a function for getting actual format for request
+ $format='png';
+ foreach ($xml->LayerList->Layer[$i]->FormatList->Format as $current_format) {
+ if ($current_format->attributes()->current=='1'){
+ $format=$current_format;
+ $format=str_replace('image/','',$format);
+ $html.="format: \"".$format."\",\n";
+ $html.="transparent: \"On\"\n";
+ $html.="},\n";
+ $html.="{\n";
+ $html.="maxExtent: new OpenLayers.Bounds(".$minx.",".$miny.",".$maxx.",".$maxy."),\n";
+ // then check map.baseLayer.resolutions[0] for
+ // a reasonable value.
+ $html.="projection: \"".$xml->General->BoundingBox['SRS']."\",\n";
+ $html.="units: \"m\",\n";
+ $minScale=dom_import_simplexml($extensions->gui_minscale)->nodeValue;
+ $maxScale=dom_import_simplexml($extensions->gui_maxscale)->nodeValue;
+ if (!$maxScale){
+ $maxScale='10000000';
+ if (!$minScale){
+ $minScale='0.1';
+ $html.="minScale: ".$minScale.",\n";
+ $html.="maxScale: ".$maxScale.",\n";
+ $html.="singleTile: true\n";
+ //Only neccesary for working with scales.
+ $html.=" } );\n";
+ $html.=" map.addLayer(layer0);\n";
+ } else {
+ echo "Guest don't have permission on Base-Layer or ".$layer_id." therefor OpenLayers client will not be generated!<br>";
+ //create the overlay layers for which the user guest has permissions
+ for ($i=1; $i<count($layer_array); $i++) {
+ $has_permission=getLayerPermission($wms_id,$layer_id,$userId);//problem: guest user must have fix id TODO
+ if (($xml->LayerList->Layer[$i]->attributes()->hidden=='0' && $has_permission) ||
+ ($layer_id=='' && $xml->LayerList->Layer[$i]->attributes()->hidden=='0')){
+ $html.="layer".$i." = new OpenLayers.Layer.WMS( \"".$xml->LayerList->Layer[$i]->Title."\",\n";
+ $html.="{\n";
+ //Get FormatList and the current active format
+ $format='png';
+ $html.="transparent: \"TRUE\"\n";
+ $html.="},\n";
+ $html.="{\n";
+ $html.="singleTile: true,\n";
+ //$extensions=$xml->LayerList->Layer[$i]->Extension->children('http://www.mapbender.org/context');
+ if (!$maxScale){
+ if (!$minScale){
+ $minScale='0.1';
+ $html.="'isBaseLayer': false\n";
+ $html.=" } );\n";
+ $html.=" map.addLayer(layer".$i.");\n";
+ //do some global things
+ //vector layer for logo or link
+ //$html.="var vector = new OpenLayers.Layer.Vector('Simple Geometry',\n";
+ //$html.="{attribution:'test'});\n";
+ //$html.="map.addLayer(vector);\n";
+ //$html.="map.addControl(new OpenLayers.Control.Attribution({'div':OpenLayers.Util.getElement('attribution')}));\n";
+ //Check if central marker should be set and draw one
+ if(isset($_REQUEST["mb_drawCentre"])&isset($centralx)&isset($centraly)){
+ if ($_REQUEST["mb_drawCentre"]='1'){
+ $html.="var markers = new OpenLayers.Layer.Markers(\"Markers\", {'calculateInRange': function() { return true; }});\n";
+ $html.="var size = new OpenLayers.Size(15,20);\n";
+ $html.="calculateOffset = function(size) {return new OpenLayers.Pixel(-(size.w/2), -size.h); };\n";
+ $html.="var icon = new OpenLayers.Icon('../extensions/OpenLayers-2.8/img/marker.png',size, null, calculateOffset);\n";
+ $html.="markers.addMarker(new OpenLayers.Marker(new OpenLayers.LonLat(".$centralx.",".$centraly."),icon));\n";
+ $html.="map.addLayer(markers);\n";
+ else {
+ echo "alert('The REQUEST parameter mb_drawCentre is outside of his realm!');";
+ return;
+ //Zoom to extent of given mb_myBBOX
+ $html.="var newBounds = new OpenLayers.Bounds(".$minx_new.",".$miny_new.",".$maxx_new.",".$maxy_new.");\n";
+ $html.="map.setCenter(new OpenLayers.LonLat(".$centralx.",".$centraly."),zoom);\n";
+ $html.="map.zoomToExtent(newBounds);\n";
+ } else {
+ $html.="map.zoomToExtent(bounds);\n";
+ if(isset($_REQUEST["showCoords"])){
+ if($_REQUEST["showCoords"]=='1'){
+ $html.="var mp = new OpenLayers.Control.MousePosition({'div':OpenLayers.Util.getElement('showpos'),'numDigits':2});\n";
+ $html.="mp.numDigits = 2;\n";
+ $html.="map.addControl(mp);";
+ //Generate the possibility to do GetFeatureInfo if this was activated in wmc
+ if ($someLayerQueryable){
+ $html.="map.events.register('click', map, function (e) {\n";
+ //loop for all layers
+ for ($i=0; $i<count($layer_array); $i++){
+ if ($layer_array_queryable[$i]=='1'){
+ $html.="var url".$i." = layer".$i.".getFullRequestString({\n";
+ $html.=" REQUEST: \"GetFeatureInfo\",\n";
+ $html.="EXCEPTIONS: \"application/vnd.ogc.se_xml\",\n";
+ $html.="BBOX: layer".$i.".map.getExtent().toBBOX(),\n";
+ $html.="X: e.xy.x,\n";
+ $html.="Y: e.xy.y,\n";
+ $html.="INFO_FORMAT: 'text/html',\n";
+ $html.="QUERY_LAYERS: layer".$i.".params.LAYERS,\n";
+ $html.=" WIDTH: layer".$i.".map.size.w,\n";
+ $html.="HEIGHT: layer".$i.".map.size.h});\n";
+ $html.="window.open(url".$i.",target=\"_blank\",\"width=300,height=400,left=100,top=200\");\n";
+ $html.="OpenLayers.Event.stop(e);\n";
+ $html.=" });\n";
+ //end GetfeatureInfo
+ $html.="}\n";//End of function
+ $html.="</script>\n";
+ $html.=" </head>\n";
+ $html.="<body onload='init()'>\n";
+ $html.="<div id='tags'></div>\n";
+ $html.="<div id='map' class='smallmap'></div>\n";//class dont exists
+ $html.="<div id='docs'>\n";
+ $html.="\n";
+ $html.="</div>\n";
+ //Show coords if wished
+ if($_REQUEST["mb_showCoords"]=='1'){
+// $html.="<div id='srs' class='csrs'>Koordinaten in <a href = '../../../mediawiki/index.php/".$xml->General->BoundingBox['SRS']."' target='_blank'>".$xml->General->BoundingBox['SRS']."</a>:</div>\n";
+ $html.="<div id='srs' class='csrs'>Koordinaten in ".$xml->General->BoundingBox['SRS'].":</div>\n";
+ $html.="<div id='showpos'></div>\n";
+ $html.="<div id='attribution'></div>\n";
+ $html.="</body>\n";
+ $html.="</html>\n";
+ //Print out HTML code
+ echo $html;
+//end of function createOlfromWMC_id()
+createOlfromWMC_id($_GET["wmc_id"]);
Added: branches/print_dev/http/php/wms.php
--- branches/print_dev/http/php/wms.php (rev 0)
+++ branches/print_dev/http/php/wms.php 2009-09-28 14:33:00 UTC (rev 4761)
@@ -0,0 +1,1093 @@
+<?php
+# $Id: mb_listGUIs.php 11 2006-07-31 16:22:36Z rothstein $
+# http://www.mapbender.org/index.php/mb_listGUIs.php
+require_once(dirname(__FILE__)."/../../core/globalSettings.php");
+require_once(dirname(__FILE__)."/../classes/class_layer_monitor.php");
+// make all parameters available as upper case
+foreach($_GET as $key => $val) {
+ $_GET[strtoupper($key)] = $val;
+$requestType = $_GET["REQUEST"];
+$version = $_GET["VERSION"];
+$service = strtoupper($_GET["SERVICE"]);
+$layerId = $_GET["LAYER_ID"];
+$updateSequence = intval($_GET["UPDATESEQUENCE"]);
+$mapbenderMetadataUrl = preg_replace("/(.*)frames\/login.php/", "$1php/mod_layerMetadata.php?id=", LOGIN);
+ * Creates an XML Exception according to WMS 1.1.1
+ * @return an XML String
+ * @param $errorCode String
+ * @param $errorMessage String
+function createExceptionXml ($errorCode, $errorMessage) {
+ // see http://de2.php.net/manual/de/domimplementation.createdocumenttype.php
+ $imp = new DOMImplementation;
+ $dtd = $imp->createDocumentType("ServiceExceptionReport", "", "http://schemas.opengis.net/wms/1.1.1/exception_1_1_1.dtd");
+ $doc = $imp->createDocument("", "", $dtd);
+ $doc->encoding = 'UTF-8';
+ $doc->standalone = false;
+ $el = $doc->createElement("ServiceExceptionReport");
+ $exc = $doc->createElement("ServiceException", $errorMessage);
+ if ($errorCode) {
+ $exc->setAttribute("code", $errorCode);
+ $el->appendChild($exc);
+ $doc->appendChild($el);
+ return $doc->saveXML();
+// check if service param is set
+if (!isset($service) || $service === "" || $service != "WMS") {
+ header("Content-type: application/xhtml+xml; charset=UTF-8");
+ echo createExceptionXml("", "Parameter SERVICE invalid");
+ die;
+// check if request param is set
+if (!isset($requestType) || $requestType === "" ||
+ ($service == "WMS" && $requestType != "GetCapabilities")) {
+ echo createExceptionXml("", "Parameter REQUEST invalid");
+ die;
+// check if version param is set
+if (!isset($version) || $version === "" ||
+ ($service == "WMS" && $version != "1.1.1")) {
+ // optional parameter, set to 1.1.1 if not set
+ $version = "1.1.1";
+// check if layer id is set
+if (!isset($layerId) || !is_numeric($layerId)) {
+ // TO DO: create exception XML
+ "Layer not defined",
+ "Unknown layer id " . $layerId
+ die;
+// check if layer is stored in database
+$wms_sql = "SELECT * FROM wms AS w, layer AS l " .
+ "where l.layer_id = $1 AND l.fkey_wms_id = w.wms_id LIMIT 1";
+$v = array($layerId);
+$t = array("i");
+$res_wms_sql = db_prep_query($wms_sql, $v, $t);
+$wms_row = db_fetch_array($res_wms_sql);
+if (!$wms_row["wms_id"]) {
+ die;
+// check if update sequence is valid
+$updateSequenceDb = intval($wms_row["wms_timestamp"]);
+if ($updateSequence) {
+ if ($updateSequence > $updateSequenceDb) {
+ // Exception: code=InvalidUpdateSequence
+ echo createExceptionXml("InvalidUpdateSequence", "Invalid update sequence");
+ die;
+ else if ($updateSequence == $updateSequenceDb) {
+ // Exception: code=CurrentUpdateSequence
+ echo createExceptionXml("CurrentUpdateSequence", "Current update sequence");
+ die;
+// increment layer count
+$monitor = new Layer_load_count();
+$monitor->increment($layerId);
+// START TO CREATE CAPABILITIES DOC
+// (return most recent Capabilities XML)
+$doc = new DOMDocument('1.0');
+$doc->encoding = 'UTF-8';
+$doc->standalone = false;
+#Check for existing content in database
+#to be adopted TODO armin
+function validate ($contactInformation_column) {
+ if ($contactInformation_column <> "" AND $contactInformation_column <> NULL) {
+ $contactinformationcheck = true;
+ else {
+ $contactinformationcheck = false;
+ return $contactinformationcheck;
+#Creating the "WMT_MS_Capabilities" node
+$wmt_ms_capabilities = $doc->createElement("WMT_MS_Capabilities");
+$wmt_ms_capabilities->setAttribute("updateSequence", $wms_row["wms_timestamp"]);
+$wmt_ms_capabilities = $doc->appendChild($wmt_ms_capabilities);
+$wmt_ms_capabilities->setAttribute('version', '1.1.1');
+#Creatig the "Service" node
+$service = $doc->createElement("Service");
+$service = $wmt_ms_capabilities->appendChild($service);
+#Creating the "Name" Node
+$name = $doc->createElement("Name");
+$name = $service->appendChild($name);
+$nameText = $doc->createTextNode("OGC:WMS");
+$nameText = $name->appendChild($nameText);
+#Creating the "Title" node
+if($wms_row['wms_title'] <> "" AND $wms_row['wms_title'] <> NULL) {
+ $title = $doc->createElement("Title");
+ $title = $service->appendChild($title);
+ $titleText = $doc->createTextNode($wms_row['wms_title']);
+ $titleText = $title->appendChild($titleText);
+#Creating the "Abstract" node
+if($wms_row['wms_abstract'] <> "" AND $wms_row['wms_abstract'] <> NULL) {
+ $abstract = $doc->createElement("Abstract");
+ $abstract = $service->appendChild($abstract);
+ $abstractText = $doc->createTextNode($wms_row['wms_abstract']);
+ $abstractText = $abstract->appendChild($abstractText);
+# switch URLs for OWSPROXY
+if($wms_row['wms_owsproxy'] <> "" AND $wms_row['wms_owsproxy'] <> NULL) {
+ $tmpOR = "http://".$_SERVER["HTTP_HOST"]."/owsproxy/".session_id()."/".$wms_row["wms_owsproxy"]."?";
+ $tmpOR = str_replace(SERVERIP, SERVERNAME, $tmpOR);
+ $wms_row['wms_getcapabilities'] = $tmpOR;
+ $wms_row['wms_getmap'] = $tmpOR;
+ $wms_row['wms_getfeatureinfo'] = $tmpOR;
+#Creating the "OnlineResource" node
+//if($wms_row['wms_getcapabilities'] <> "" AND $wms_row['wms_getcapabilities'] <> NULL) {
+ $onlineResource = $doc->createElement("OnlineResource");
+ $onlineResource = $service->appendChild($onlineResource);
+ $onlineResource->setAttribute("xmlns:xlink", "http://www.w3.org/1999/xlink" );
+// $onlineResource->setAttribute("xlink:href", $wms_row['wms_getcapabilities']);
+ $onlRes = $_SERVER["HTTP_HOST"] . $_SERVER["PHP_SELF"] . "?layer_id=" . $layerId."&".session_name()."=".session_id();
+ if (isset($_SERVER["HTTPS"])) {
+ $onlRes = "https://" . $onlRes;
+ else {
+ $onlRes = "http://" . $onlRes;
+ $onlineResource->setAttribute("xlink:href", $onlRes);
+ $onlineResource->setAttribute("xlink:type", "simple");
+#Insert contact information
+#Creating "Contact Information" node
+if (validate($wms_row['contactperson']) &&
+ validate($wms_row['contactorganization']) &&
+ validate($wms_row['contactposition']) &&
+ validate($wms_row['address']) &&
+ validate($wms_row['city']) &&
+ validate($wms_row['stateorprovince']) &&
+ validate($wms_row['postcode']) /*AND validate($wms_row['country'])*/ &&
+ validate($wms_row['contactvoicetelephone']) &&
+ validate($wms_row['contactfacsimiletelephone']) &&
+ validate($wms_row['contactelectronicmailaddress']))
+$contactInformation = $doc->createElement("ContactInformation");
+$contactInformation = $service->appendChild($contactInformation);
+#Creating "Contact Person Primary" node
+if(validate($wms_row['contactperson']) AND validate($wms_row['contactorganization']))
+$contactPersonPrimary = $doc->createElement("ContactPersonPrimary");
+$contactPersonPrimary = $contactInformation->appendChild($contactPersonPrimary);
+#Creating the "ContactPerson" node
+if(validate($wms_row['contactperson']))
+ $contactPerson = $doc->createElement("ContactPerson");
+ $contactPerson = $contactPersonPrimary->appendChild($contactPerson);
+ $contactPersonText = $doc->createTextNode($wms_row['contactperson']);
+ $contactPersonText = $contactPerson->appendChild($contactPersonText);
+#Creating the "ContactOrganization" node
+if(validate($wms_row['contactorganization']))
+ $contactOrganization = $doc->createElement("ContactOrganization");
+ $contactOrganization = $contactPersonPrimary->appendChild($contactOrganization);
+ $contactOrganizationText = $doc->createTextNode($wms_row['contactorganization']);
+ $contactOrganizationText = $contactOrganization->appendChild($contactOrganizationText);
+#Creating the "ContactPosition" node
+if(validate($wms_row['contactposition']))
+ $contactPosition = $doc->createElement("ContactPosition");
+ $contactPosition = $contactInformation->appendChild($contactPosition);
+ $contactPositionText = $doc->createTextNode($wms_row['contactposition']);
+ $contactPositionText = $contactPosition->appendChild($contactPositionText);
+#Creating "ContactAddress" node
+if(validate($wms_row['address']) AND validate($wms_row['city']) AND validate($wms_row['stateorprovince']) AND validate($wms_row['postcode']) /*AND validate($wms_row['country'])*/)
+$contactAddress = $doc->createElement("ContactAddress");
+$contactAddress = $contactInformation->appendChild($contactAddress);
+#Creating the "AddressType" and "Address" textnode
+if(validate($wms_row['address']))
+ $addressType = $doc->createElement("AddressType");
+ $addressType = $contactAddress->appendChild($addressType);
+ $addresstypeText = $doc->createTextNode("postal");
+ $addresstypeText = $addressType->appendChild($addresstypeText);
+ $address = $doc->createElement("Address");
+ $address = $contactAddress->appendChild($address);
+ $addressText = $doc->createTextNode($wms_row['address']);
+ $addressText = $address->appendChild($addressText);
+#Creatig the "City" node
+if(validate($wms_row['city']))
+ $city = $doc->createElement("City");
+ $city = $contactAddress->appendChild($city);
+ $cityText = $doc->createTextNode($wms_row['city']);
+ $cityText = $city->appendChild($cityText);
+#Creatig the "StateOrProvince" node
+if(validate($wms_row['stateorprovince']))
+ $stateOrProvince = $doc->createElement("StateOrProvince");
+ $stateOrProvince = $contactAddress->appendChild($stateOrProvince);
+ $stateOrProvinceText = $doc->createTextNode($wms_row['stateorprovince']);
+ $stateOrProvinceText = $stateOrProvince->appendChild($stateOrProvinceText);
+#Creatig the "PostCode" node
+if(validate($wms_row['postcode']))
+ $postCode = $doc->createElement("PostCode");
+ $postCode = $contactAddress->appendChild($postCode);
+ $postCodeText = $doc->createTextNode($wms_row['postcode']);
+ $postCodeText = $postCode->appendChild($postCodeText);
+#Creatig the "Country" node
+if(isset($wms_row['country']) AND validate($wms_row['country']))
+ $country = $doc->createElement("Country");
+ $country = $contactAddress->appendChild($country);
+ $countryText = $doc->createTextNode($wms_row['country']);
+ $countryText = $country->appendChild($countryText);
+#Creatig the "ContactVoiceTelephone" node
+if(validate($wms_row['contactvoicetelephone']))
+ $contactVoiceTelephone = $doc->createElement("ContactVoiceTelephone");
+ $contactVoiceTelephone = $contactInformation->appendChild($contactVoiceTelephone);
+ $contactVoiceTelephoneText = $doc->createTextNode($wms_row['contactvoicetelephone']);
+ $contactVoiceTelephoneText = $contactVoiceTelephone->appendChild($contactVoiceTelephoneText);
+#Creatig the "ContactFacsimileTelephone" node
+if(validate($wms_row['contactfacsimiletelephone']))
+ $contactFacsimileTelephone = $doc->createElement("ContactFacsimileTelephone");
+ $contactFacsimileTelephone = $contactInformation->appendChild($contactFacsimileTelephone);
+ $contactFacsimileTelephoneText = $doc->createTextNode($wms_row['contactfacsimiletelephone']);
+ $contactFacsimileTelephoneText = $contactFacsimileTelephone->appendChild($contactFacsimileTelephoneText);
+#Creatig the "ContactElectronicMailAddress" node
+if(validate($wms_row['contactelectronicmailaddress']))
+ $contactElectronicMailAddress = $doc->createElement("ContactElectronicMailAddress");
+ $contactElectronicMailAddress = $contactInformation->appendChild($contactElectronicMailAddress);
+ $contactElectronicMailAddressText = $doc->createTextNode($wms_row['contactelectronicmailaddress']);
+ $contactElectronicMailAddressText = $contactElectronicMailAddress->appendChild($contactElectronicMailAddressText);
+#Creatig the "Fees" node
+if(validate($wms_row['fees']))
+ $fees = $doc->createElement("Fees");
+ $fees = $service->appendChild($fees);
+ $feesText = $doc->createTextNode($wms_row['fees']);
+ $feesText = $fees->appendChild($feesText);
+#Creating the "AccessConstraints" node
+if(validate($wms_row['accessconstraints']))
+ $accessConstraints = $doc->createElement("AccessConstraints");
+ $accessConstraints = $service->appendChild($accessConstraints);
+ $accessConstraintsText = $doc->createTextNode($wms_row['accessconstraints']);
+ $accessConstraintsText = $accessConstraints->appendChild($accessConstraintsText);
+#Creatig the "Capability" node
+$capability = $doc->createElement("Capability");
+$capability = $wmt_ms_capabilities->appendChild($capability);
+#Creatig the "Request" node
+$request = $doc->createElement("Request");
+$request = $capability->appendChild($request);
+#GetCapabilities
+#Creatig the "GetCapabilities" node
+$getCapabilities = $doc->createElement("GetCapabilities");
+$getCapabilities = $request->appendChild($getCapabilities);
+#Creatig the "Format" node
+$wms_format_sql ="SELECT data_format FROM wms_format WHERE fkey_wms_id = $1 AND data_type = 'capability'";
+$v = array($wms_row['wms_id']);
+$t = array("i");
+$res_wms_format_sql = db_prep_query($wms_format_sql, $v, $t);
+while ($wms_format_row = db_fetch_array($res_wms_format_sql)) {
+ $format = $doc->createElement("Format");
+ $format = $getCapabilities->appendChild($format);
+ $formatText = $doc->createTextNode($wms_format_row['data_format']);
+ $formatText = $format->appendChild($formatText);
+#cause the format for capabilities is not read :
+ $formatText = $doc->createTextNode('application/vnd.ogc.wms_xml');
+#Creating the "DCPType" node
+$DCPType = $doc->createElement("DCPType");
+$DCPType = $getCapabilities->appendChild($DCPType);
+#Creating the "HTTP" node
+$HTTP = $doc->createElement("HTTP");
+$HTTP = $DCPType->appendChild($HTTP);
+#Creating the "Get" node
+$get = $doc->createElement("Get");
+$get = $HTTP->appendChild($get);
+//if ($wms_row['wms_getcapabilities'] <> "" AND $wms_row['wms_getcapabilities'] <> NULL) {
+ $onlineResource = $get->appendChild($onlineResource);
+ $onlineResource->setAttribute("xmlns:xlink", "http://www.w3.org/1999/xlink");
+ $onlRes = $_SERVER["HTTP_HOST"] . $_SERVER["PHP_SELF"] . "?layer_id=" . $layerId;
+ else {
+#Creating the "Post" node
+$post = $doc->createElement("Post");
+$post = $HTTP->appendChild($post);
+ $onlineResource = $post->appendChild($onlineResource);
+ else {
+#GetMap
+#Creatig the "GetMap" node
+$getMap = $doc->createElement("GetMap");
+$getMap = $request->appendChild($getMap);
+$wms_format_sql ="SELECT data_format FROM wms_format WHERE fkey_wms_id = $1 AND data_type = 'map'";
+$t = array("i");
+ $format = $getMap->appendChild($format);
+$DCPType = $getMap->appendChild($DCPType);
+if ($wms_row['wms_getmap'] <> "" AND $wms_row['wms_getmap'] <> NULL) {
+ $onlineResource->setAttribute("xlink:href", $wms_row['wms_getmap']);
+if($wms_row['wms_getmap'] <> "" AND $wms_row['wms_getmap'] <> NULL) {
+#GetFeatureInfo
+#Creatig the "GetFeatureInfo" node
+$getFeatureInfo = $doc->createElement("GetFeatureInfo");
+$getFeatureInfo = $request->appendChild($getFeatureInfo);
+$wms_format_sql ="SELECT data_format FROM wms_format WHERE fkey_wms_id = $1 AND data_type = 'featureinfo'";
+$t = array("i");
+ $format = $getFeatureInfo->appendChild($format);
+$DCPType = $getFeatureInfo->appendChild($DCPType);
+if($wms_row['wms_getfeatureinfo'] <> "" AND $wms_row['wms_getfeatureinfo'] <> NULL)
+ $onlineResource->setAttribute("xlink:href", $wms_row['wms_getfeatureinfo']);
+if($wms_row['wms_getfeatureinfo'] <> "" AND $wms_row['wms_getfeatureinfo'] <> NULL) {
+#Creating the "Exeption" node
+$exception = $doc->createElement("Exception");
+$exception = $capability->appendChild($exception);
+$wms_format_sql ="SELECT data_format FROM wms_format WHERE fkey_wms_id = $1 AND data_type = 'exception'";
+$t = array("i");
+ $format = $exception->appendChild($format);
+#Querying layer table
+$layer_sql = "SELECT * FROM layer WHERE layer.fkey_wms_id = $1 AND layer.layer_parent = ''";
+$t = array("i");
+$res_layer_sql = db_prep_query($layer_sql, $v, $t);
+$layer_row = db_fetch_array($res_layer_sql);
+#Creating layer node
+$layer = $doc->createElement("Layer");
+$layer = $capability->appendChild($layer);
+#Write layer to parent layer array
+$parentLayerArray[$layer_row['layer_pos']] = $layer;
+#Creating Name node
+if ($layer_row['layer_name'] <> "" AND $layer_row['layer_name'] <> NULL) {
+ $name = $doc->createElement("Name");
+ $name = $layer->appendChild($name);
+ $nameText = $doc->createTextNode($layer_row['layer_name']);
+ $nameText = $name->appendChild($nameText);
+#Creating Title node
+if ($layer_row['layer_title'] <> "" AND $layer_row['layer_title'] <> NULL) {
+ $title = $layer->appendChild($title);
+ $titleText = $doc->createTextNode($layer_row['layer_title']);
+if($layer_row['layer_abstract'] <> "" AND $layer_row['layer_abstract'] <> NULL) {
+ $abstract = $layer->appendChild($abstract);
+ $abstractText = $doc->createTextNode($layer_row['layer_abstract']);
+#Request the specific wms- and layerkeywords
+$keyword_sql = "SELECT DISTINCT keyword FROM keyword, layer_keyword, layer " .
+ "WHERE keyword.keyword_id = layer_keyword.fkey_keyword_id " .
+ "AND layer_keyword.fkey_layer_id = layer.layer_id " .
+ "AND layer.fkey_wms_id = $1";
+$t = array("i");
+$res_keyword_sql = db_prep_query($keyword_sql, $v, $t);
+#Creating list of keyword nodes
+#Iterating over a List of Keywords
+$keywordlistExist = 0;
+while ($keyword_sql = db_fetch_array($res_keyword_sql))
+ #Creating the "KeywordList" node
+ if ($keywordlistExist == 0) {
+ $keywordList = $doc->createElement("KeywordList");
+ $keywordList = $layer->appendChild($keywordList);
+ $keywordlistExist = 1;
+ #Creating the "Keyword" node
+ $keyword_dom = $doc->createElement("Keyword");
+ $keyword_dom = $keywordList->appendChild($keyword_dom);
+ $keyword_domText = $doc->createTextNode($keyword_sql['keyword']);
+ $keyword_domText = $keyword_dom->appendChild($keyword_domText);
+#SQL statement to get additional layer information from layer epsg
+$epsg_sql = "SELECT layer_epsg.epsg, layer_epsg.minx, layer_epsg.miny, " .
+ "layer_epsg.maxy, layer_epsg.maxx " .
+ "FROM layer_epsg WHERE layer_epsg.fkey_layer_id = $1";
+$v = array($layer_row['layer_id']);
+$t = array("i");
+$res_espg_sql = db_prep_query($epsg_sql, $v, $t);
+$latLonBoundingBoxCreated = false;
+$BoundingBoxCreated = false;
+while ($epsg_row = db_fetch_array($res_espg_sql)) {
+ #Creating SRS node
+ $srs = $doc->createElement("SRS");
+ $srs = $layer->appendChild($srs);
+ $srsText = $doc->createTextNode($epsg_row['epsg']);
+ $srsText = $srs->appendChild($srsText);
+$t = array("i");
+ #set only epsg 4326 for latlonbbox
+ if ($epsg_row['epsg'] == "EPSG:4326") {
+ $latlon['minx'] = $epsg_row['minx'];
+ $latlon['miny'] = $epsg_row['miny'];
+ $latlon['maxx'] = $epsg_row['maxx'];
+ $latlon['maxy'] = $epsg_row['maxy'];
+ #Creating LatLongBoundingBox node
+ $latLonBoundingBox = $doc->createElement("LatLonBoundingBox");
+ $latLonBoundingBox = $layer->appendChild($latLonBoundingBox);
+ $latLonBoundingBox->setAttribute('minx', $latlon['minx']);
+ $latLonBoundingBox->setAttribute('miny', $latlon['miny']);
+ $latLonBoundingBox->setAttribute('maxx', $latlon['maxx']);
+ $latLonBoundingBox->setAttribute('maxy', $latlon['maxy']);
+ break;
+$t = array("i");
+ #set only first epsg for bbox
+ $bbox['epsg'] = $epsg_row['epsg'];
+ $bbox['minx'] = $epsg_row['minx'];
+ $bbox['miny'] = $epsg_row['miny'];
+ $bbox['maxx'] = $epsg_row['maxx'];
+ $bbox['maxy'] = $epsg_row['maxy'];
+ #Creating BoundingBox node
+ $boundingBox = $doc->createElement("BoundingBox");
+ $boundingBox = $layer->appendChild($boundingBox);
+ $boundingBox->setAttribute('SRS', $bbox['epsg']);
+ $boundingBox->setAttribute('minx', $bbox['minx']);
+ $boundingBox->setAttribute('miny', $bbox['miny']);
+ $boundingBox->setAttribute('maxx', $bbox['maxx']);
+ $boundingBox->setAttribute('maxy', $bbox['maxy']);
+#Append epsg string to srs node
+$srsText = $doc->createTextNode($epsgText);
+$srsText = $srs->appendChild($srsText);
+####### duplicate root layer
+#if layer is root layer itself!
+#<armin>
+##if ($layer_row['layer_pos']=='0'){
+#</armin>
+##$clonedLayer = $layer->cloneNode(true);
+##$clonedLayer->setAttribute("queryable", "0");
+##$clonedLayer->setAttribute("cascaded", "0");
+##$layer->appendChild($clonedLayer);
+#<armin>
+#</armin>
+############## sublayer
+#SQL statement to get all layers
+$sub_layer_sql = "SELECT * FROM layer WHERE fkey_wms_id = $1 AND layer_parent <> ''";
+$t = array("i");
+if (isset($layerId) && $layerId > 0) {
+ $sub_layer_sql .= " AND layer_id = $2";
+ array_push($v, $layerId);
+ array_push($t, "i");
+$sub_layer_sql .= " ORDER BY layer_pos";
+$res_sub_layer_sql = db_prep_query($sub_layer_sql, $v, $t);
+#<armin>
+$res_sub_layer_sql_2 = db_prep_query($sub_layer_sql, $v, $t);
+$sub_layer_row_2 = db_fetch_array($res_sub_layer_sql_2);
+if (!isset($sub_layer_row_2['layer_pos'])) {
+ $clonedLayer = $layer->cloneNode(true);
+ $clonedLayer->setAttribute("queryable", "0");
+ $clonedLayer->setAttribute("cascaded", "0");
+ $layer->appendChild($clonedLayer);
+#</armin>
+while ($sub_layer_row = db_fetch_array($res_sub_layer_sql)) {
+ #Creating layer node
+ $sub_layer = $doc->createElement("Layer");
+ $parent = $parentLayerArray[$sub_layer_row['layer_parent']];
+ $sub_layer = $parent->appendChild($sub_layer);
+ if($sub_layer_row['layer_queryable'] <> "" AND $sub_layer_row['layer_queryable'] <> NULL) {
+ $sub_layer->setAttribute('queryable', $sub_layer_row['layer_queryable']);
+ #Getting information about the hierarchie of layers
+ $cascadeSQL = "SELECT COUNT(*) FROM layer WHERE fkey_wms_id = ".$wms_row[0] .
+ " AND layer_parent = ".$sub_layer_row['layer_pos']."";
+ $res_cascadeSQL = db_query($cascadeSQL);
+ $cascade = 0;
+ $cascade_row = db_fetch_row($res_cascadeSQL);
+ if($cascade_row[0] > 0)
+ $cascade = 1;
+ $sub_layer->setAttribute('cascaded', $cascade);
+ #Write layer to parent layer array
+ $parentLayerArray[$sub_layer_row['layer_pos']] = $sub_layer;
+ #Creating name node
+ if($sub_layer_row['layer_name'] <> "" AND $sub_layer_row['layer_name'] <> NULL)
+ $name = $sub_layer->appendChild($name);
+ $nameText = $doc->createTextNode($sub_layer_row['layer_name']);
+ #Creating Title node
+ if($sub_layer_row['layer_title'] <> "" AND $sub_layer_row['layer_title'] <> NULL)
+ $title = $sub_layer->appendChild($title);
+ $titleText = $doc->createTextNode($sub_layer_row['layer_title']);
+ #Creating the "Abstract" node
+ if($sub_layer_row['layer_abstract'] <> "" AND $sub_layer_row['layer_abstract'] <> NULL)
+ $abstract = $sub_layer->appendChild($abstract);
+ $abstractText = $doc->createTextNode($sub_layer_row['layer_abstract']);
+ #Request the specific wms- and layerkeywords
+ $keyword_sql = "SELECT DISTINCT keyword FROM layer LEFT JOIN layer_keyword ON layer_keyword.fkey_layer_id = layer.layer_id LEFT JOIN keyword ON keyword.keyword_id = layer_keyword.fkey_keyword_id WHERE layer.fkey_wms_id = ".$wms_row['wms_id']." AND layer.layer_id = ".$sub_layer_row['layer_id']."";
+ $res_keyword_sql = db_query($keyword_sql);
+ #Creating list of keyword nodes
+ #Iterating over a List of Keywords
+ $keywordlistExist = 0;
+ while ($keyword_sql = db_fetch_array($res_keyword_sql))
+ $keywordList = $sub_layer->appendChild($keywordList);
+ // inherit srs from parent layer
+ $layer_srs_sql = "SELECT DISTINCT epsg FROM layer_epsg " .
+ "WHERE fkey_layer_id = ".$sub_layer_row['layer_id'] .
+ " OR fkey_layer_id = " . $layer_row['layer_id'];
+ $res_layer_srs_sql = db_query($layer_srs_sql);
+ while ($layer_srs_row = db_fetch_array($res_layer_srs_sql)) {
+ $srs = $sub_layer->appendChild($srs);
+ $srsText = $doc->createTextNode($layer_srs_row['epsg']);
+ #SQL statement to get additional layer information from layer epsg
+ $epsg_sql = "SELECT layer_epsg.epsg, layer_epsg.minx, layer_epsg.miny, " .
+ "layer_epsg.maxy, layer_epsg.maxx FROM layer_epsg " .
+ "WHERE layer_epsg.fkey_layer_id = ".$sub_layer_row['layer_id'];
+ $res_espg_sql = db_query($epsg_sql);
+ while ($epsg_row = db_fetch_array($res_espg_sql)) {
+ #set epsg 4326 for latlonbbox
+ if ($epsg_row['epsg'] == "EPSG:4326" AND $latLonBoundingBoxCreated == false) {
+ $latLonBoundingBox = $sub_layer->appendChild($latLonBoundingBox);
+ $boundingBox = $sub_layer->appendChild($boundingBox);
+ # Creating Metadata Node
+ $metadataUrl = $doc->createElement("MetadataURL");
+ $metadataUrl = $sub_layer->appendChild($metadataUrl);
+ $metadataUrl->setAttribute('type', "TC211");
+ $format = $metadataUrl->appendChild($format);
+ $formatText = $doc->createTextNode('text/html');
+ if ($wms_row['wms_owsproxy'] <> "" AND $wms_row['wms_owsproxy'] <> NULL) {
+ $onlineResource = $metadataUrl->appendChild($onlineResource);
+ $onlineResource->setAttribute("xlink:href", OWSPROXY."/".session_id()."/".$wms_row["wms_owsproxy"]."?");
+ else {
+ if ($sub_layer_row['layer_metadataurl'] <> "" AND $sub_layer_row['layer_metadataurl'] <> NULL) {
+ $onlineResource->setAttribute("xlink:href", $sub_layer_row['layer_metadataurl']);
+else
+ # Creating DataURL Node
+ $dataUrl = $doc->createElement("DataURL");
+ $dataUrl = $sub_layer->appendChild($dataUrl);
+ $format = $dataUrl->appendChild($format);
+ if($wms_row['wms_owsproxy'] <> "" AND $wms_row['wms_owsproxy'] <> NULL)
+ $onlineResource = $dataUrl->appendChild($onlineResource);
+ else
+ if($sub_layer_row['layer_dataurl'] <> "" AND $sub_layer_row['layer_dataurl'] <> NULL)
+ $onlineResource->setAttribute("xlink:href", $sub_layer_row['layer_dataurl']);
+else
+ $onlineResource->setAttribute("xlink:href", $mapbenderMetadataUrl.$sub_layer_row['layer_id']);
+ #Creating Style Node
+ $style = $doc->createElement("Style");
+ $style = $sub_layer->appendChild($style);
+ $name = $style->appendChild($name);
+ $nameText = $doc->createTextNode('default');
+ $title = $style->appendChild($title);
+ $titleText = $doc->createTextNode('default');
+ if($wms_row['wms_getlegendurl'] <> "" AND $wms_row['wms_getlegendurl'] <> NULL){
+ $legendUrl = $doc->createElement("LegendURL");
+ $legendUrl = $style->appendChild($legendUrl);
+ $legendUrl->setAttribute("width", "10" );
+ $legendUrl->setAttribute("height", "8" );
+ $format = $legendUrl->appendChild($format);
+ $formatText = $doc->createTextNode('image/png');
+ $onlineResource = $legendUrl->appendChild($onlineResource);
+ $onlineResource->setAttribute("xlink:href", OWSPROXY."/".session_id()."/".$wms_row["wms_owsproxy"]."?version=1.1.1&service=WMS&request=GetLegendGraphic&layer=".$sub_layer_row['layer_name']."&format=image/png");
+ else
+ $onlineResource->setAttribute("xlink:href", $wms_row['wms_getlegendurl']."version=1.1.1&service=WMS&request=GetLegendGraphic&layer=".$sub_layer_row['layer_name']."&format=image/png");
+ #Creating "ScaleHint" node
+ if ($sub_layer_row['layer_minscale'] <> "" AND $sub_layer_row['layer_minscale'] <> NULL) {
+ $scaleHint = $doc->createElement("ScaleHint");
+ $scaleHint = $sub_layer->appendChild($scaleHint);
+ $scaleHint->setAttribute('min', (floatval($sub_layer_row['layer_minscale'])/2004.3976484406788493955738891127));
+ $scaleHint->setAttribute('max', (floatval($sub_layer_row['layer_maxscale'])/2004.3976484406788493955738891127));
+header("Content-type: application/xhtml+xml; charset=UTF-8");
+echo $doc->saveXml();
More information about the Mapbender_commits
