[Mapbender-commits] r5868 - trunk/mapbender/http/plugins
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Tue Apr 6 08:59:22 EDT 2010
Author: christoph
Date: 2010-04-06 08:59:21 -0400 (Tue, 06 Apr 2010)
New Revision: 5868
   trunk/mapbender/http/plugins/jq_upload.js
   trunk/mapbender/http/plugins/jq_upload.php
Modified: trunk/mapbender/http/plugins/jq_upload.js
--- trunk/mapbender/http/plugins/jq_upload.js	2010-04-06 09:47:59 UTC (rev 5867)
+++ trunk/mapbender/http/plugins/jq_upload.js	2010-04-06 12:59:21 UTC (rev 5868)
@@ -1,4 +1,7 @@
 $.fn.upload = function (args) {
+	if (typeof $.fn.upload.initialized === "undefined") {
+		$.fn.upload.initialized = [];
 	return this.each(function () {
 		if (this.id === "upload") {
 			return;
@@ -6,7 +9,21 @@
 		var options = args || {};
 		var $this = $(this);
+		var that = this;
 		var id = this.id;
+		var exists = false;
+		$($.fn.upload.initialized).each(function () {
+			if (that === this) {
+				exists = true;
+		if (exists) {
+			return;
+		$.fn.upload.initialized.push(this);
 		var time = 0;
 		var timeout = options.timeout || 7000;
 		var timeinterval = options.interval || 200;
@@ -19,6 +36,7 @@
 			var t = setInterval(function () {
 				var returnValue = window.frames[id + "_target"].id;
 				time += timeinterval;
 				if (typeof returnValue !== "undefined") {
 					clearInterval(t);
 					time = 0;
@@ -44,6 +62,7 @@
 							options.callback(null, false, msg);
+					$("#" + id + "_submit").removeAttr("disabled");
 					return;
 				if (time >= timeout) {
@@ -52,11 +71,12 @@
 					msg = "File upload failed, timeout reached (" +
 						timeout + " ms)";
-					new parent.window.opener.parent.Mb_exception(msg);
+					new Mb_exception(msg);
 					if (typeof options.callback === "function") {
 					return;
 			}, timeinterval);
@@ -69,20 +89,23 @@
 		).submit(function () {
 			var filename = $("input[name=myfile]", $this).val();
 			if (filename !== "") {
+				$("#" + id + "_submit").attr("disabled", "disabled");
 				startUpload();
 			return true;
-		$form.append($(
+		$form.append(
 			"<p id='" + id + "_form' align='center'><br/>" +
 				"<input name='myfile' type='file' size='"+width+"' />" +
-				(displaySubmit ? "<input type='submit' value='Upload' />": "") +
+				(displaySubmit ? "<input id='" + id + "_submit' type='submit' value='Upload' />": "") +
-			"</p>" +
-			"<iframe name='" + id + "_target' src='../html/mod_blank.html' " +
-			"style='width:0;height:0;border:0px solid #fff;'></iframe>"
+			"</p>"
+		var iframeStr = "<iframe name='" + id + "_target' id='" + id + "_target' src='#' " +
+			"style='width:0;height:0;border:0px solid #fff;'></iframe>";
+		$("body").eq(0).append(iframeStr);
 		$this.append($form);
Modified: trunk/mapbender/http/plugins/jq_upload.php
--- trunk/mapbender/http/plugins/jq_upload.php	2010-04-06 09:47:59 UTC (rev 5867)
+++ trunk/mapbender/http/plugins/jq_upload.php	2010-04-06 12:59:21 UTC (rev 5868)
@@ -2,7 +2,6 @@
 	require_once(dirname(__FILE__) . "/../php/mb_validateSession.php");
 	$id = $_GET["id"];
 	if (!preg_match("/[a-zA-Z0-9-_]+/", $id)) {
    		$message = "cancelled";
@@ -26,7 +25,8 @@
 		// check if file type is valid
 		foreach ($allowedFileTypes as $item) {
 			$cancel = true;
-			$message = _mb("Files with this extension are not allowed. Must be %s.", implode(", ", $allowedFileTypes));
+//			$message = _mb("Files with this extension are not allowed. Must be %s.", implode(", ", $allowedFileTypes));
+			$message = _mb("Dateien in diesem Format werden nicht unterstützt, wählen Sie eines der folgenden Bildformate: %s.", implode(", ", $allowedFileTypes));
 			if(preg_match("/\.$item\$/i", $clientFilename)) {
 				$cancel = false;
 				break;
@@ -40,15 +40,18 @@
 				$disallowedFileTypes
 		foreach ($disallowedFileTypes as $item) {
 				$cancel = true;
-				$message = _mb("Files with extension %s are not allowed. Must be %s.", $item, implode(", ", $allowedFileTypes));
+//				$message = _mb("Files with extension %s are not allowed. Must be %s.", $item, implode(", ", $allowedFileTypes));
+				$message = _mb("Dateien in dem Format %s werden nicht unterstützt, wählen Sie eines der folgenden Bildformate: %s.", $item, implode(", ", $allowedFileTypes));
 				break;
 		$maxSize = intval(ini_get("upload_max_filesize"))*1024;
 		if (defined("UPLOAD_MAX_SIZE_KB") && UPLOAD_MAX_SIZE_KB < $maxSize) {
@@ -56,7 +59,8 @@
 		if (count($_FILES) === 0 || filesize($uploadedFile) > UPLOAD_MAX_SIZE_KB * 1024) {
 			$cancel = true;
-			$message = _mb("File size limit (%s KB) exceeded.", UPLOAD_MAX_SIZE_KB);
+//			$message = _mb("File size limit (%s KB) exceeded.", UPLOAD_MAX_SIZE_KB);
+			$message = _mb("Datei zu groß (maximal %s KB).", UPLOAD_MAX_SIZE_KB);
 		$extension = "";
@@ -69,11 +73,13 @@
 		if (!$cancel) {
 			if (!copy($uploadedFile, $serverFullFilename)) {
 				$status = "cancelled";
-				$message = _mb("File could not be stored on server. Please contact the administrator.");
+//				$message = _mb("File could not be stored on server. Please contact the administrator.");
+				$message = _mb("Die Datei konnte nicht hochgeladen werden. Bitte wenden Sie sich an den Administrator.");
 			else {
 				$status = "finished";
-				$message = _mb("File has been uploaded.");
+//				$message = _mb("File has been uploaded.");
+				$message = _mb("Die Datei wurde erfolgreich hochgeladen.");
 		else {
@@ -81,16 +87,16 @@
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
 <html>
 	<head>
 		<script type="text/javascript">
-			window.id = "<?php
+			var id = "<?php
 				echo $id . "_" . $serverFullFilename . "_" . $status . "_" . $message;
-			window.filename = "<?php echo $clientFilename;  ?>";
+			var filename = "<?php echo $clientFilename;  ?>";
 		</script>
 	</head>
 	<body>
 	</body>
 </html>
\ No newline at end of file
More information about the Mapbender_commits mailing list
