[Mapbender-commits] r5893 - in branches/3_dev: core/lib core/lib/js http/plugins
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Sat Apr 10 11:04:17 EDT 2010
Author: mh
Date: 2010-04-10 11:04:16 -0400 (Sat, 10 Apr 2010)
New Revision: 5893
Added:
   branches/3_dev/http/plugins/mb_login_server.php
   branches/3_dev/core/lib/class_Ajax.php
   branches/3_dev/core/lib/class_User.php
   branches/3_dev/core/lib/js/ajax.js
   branches/3_dev/http/plugins/mb_login.js
Modified: branches/3_dev/core/lib/class_Ajax.php
--- branches/3_dev/core/lib/class_Ajax.php	2010-04-10 14:57:07 UTC (rev 5892)
+++ branches/3_dev/core/lib/class_Ajax.php	2010-04-10 15:04:16 UTC (rev 5893)
@@ -108,7 +108,7 @@
 	private $error = null;
 	private $message = "";
-	public function __construct ($ajaxRequest) {
+	public function __construct ($ajaxRequest, $sessionStarted = true) {
 		$this->json = new Mapbender_JSON();
 		if (is_array($ajaxRequest)) {
@@ -123,18 +123,20 @@
 			$this->message = _mb("Fatal error: Could not detect ID of AJAX request.");
 			$this->send();
+		if ($sessionStarted === true) {
+			if (!Mapbender::session()->get("mb_user_id") ||
+				!Mapbender::session()->get("mb_user_ip") ||
+				Mapbender::session()->get("mb_user_ip") != $_SERVER['REMOTE_ADDR']) {
+				$this->setSuccess(false);
+				$this->error = array(
+					"code" => -2,
+					"message" => _mb("The session has expired. Please log in again.")
-		if (!Mapbender::session()->get("mb_user_id") ||
-			!Mapbender::session()->get("mb_user_ip") ||
-			Mapbender::session()->get("mb_user_ip") != $_SERVER['REMOTE_ADDR']) {
-			$this->setSuccess(false);
-			$this->error = array(
-				"code" => -2,
-				"message" => _mb("The session has expired. Please log in again.")
 	 * Set a message to be sent back to the client.
Modified: branches/3_dev/core/lib/class_User.php
--- branches/3_dev/core/lib/class_User.php	2010-04-10 14:57:07 UTC (rev 5892)
+++ branches/3_dev/core/lib/class_User.php	2010-04-10 15:04:16 UTC (rev 5893)
@@ -68,7 +68,35 @@
+	public function loginCountExceeded () {
+		$sql_count = "SELECT mb_user_login_count FROM mb_user WHERE mb_user_name = $1";
+		$params = array($name);
+		$types = array('s');
+		$res_count = db_prep_query($sql_count, $params, $types);
+		if ($row = db_fetch_array($res_count)) {
+			if ($row["mb_user_login_count"] > MAXLOGIN) {
+				return true;
+		return false;
+	public function resetLoginCount () {
+		$sql_del_cnt =  "UPDATE mb_user SET mb_user_login_count = 0 WHERE mb_user_id = $1";
+		$v = array($this->id);
+		$t = array("i");
+		return db_prep_query($sql_del_cnt, $v, $t);
+	public function incrementLoginCount () {
+		$sql_set_cnt = "UPDATE mb_user SET mb_user_login_count = (mb_user_login_count + 1) WHERE mb_user_id = $1";
+		$t = array('s');
+		return db_prep_query($sql_set_cnt,$v,$t);
     * @return Assoc Array containing the fields to send to the user
     public function getFields() {
Modified: branches/3_dev/core/lib/js/ajax.js
--- branches/3_dev/core/lib/js/ajax.js	2010-04-10 14:57:07 UTC (rev 5892)
+++ branches/3_dev/core/lib/js/ajax.js	2010-04-10 15:04:16 UTC (rev 5893)
@@ -211,7 +211,7 @@
 				message = Mapbender.Ajax.Messages.fatalError;
 			if (resultObj.error.code == -1) {
-				internalError = true;
+				//internalError = true;
 			else if (resultObj.error.code == -2) {
 				sessionExpired = true;
Modified: branches/3_dev/http/plugins/mb_login.js
--- branches/3_dev/http/plugins/mb_login.js	2010-04-10 14:57:07 UTC (rev 5892)
+++ branches/3_dev/http/plugins/mb_login.js	2010-04-10 15:04:16 UTC (rev 5893)
@@ -11,12 +11,31 @@
 					$loginDiv.dialog({
 						buttons: {
 							"Login": function () {
-								$("form", $loginDiv).get(0).submit();
+								var name = $("form", $loginDiv).get(0).name.value;
+								var password = $("form", $loginDiv).get(0).password.value;
+								var req = new Mapbender.Ajax.Request({
+									url: "./plugins/mb_login_server.php",
+									method: "login",
+									parameters: {
+										name: name,
+										password: password
+									callback: function (obj, result, message) {
+										if (!result) {
+											alert(message);
+											return;
+										alert(message);
+								req.send();
+								return false;
 						modal: true,
 						resizable: false,
-						draggable: false
+						draggable: false,
+						width: 400
Added: branches/3_dev/http/plugins/mb_login_server.php
--- branches/3_dev/http/plugins/mb_login_server.php	                        (rev 0)
+++ branches/3_dev/http/plugins/mb_login_server.php	2010-04-10 15:04:16 UTC (rev 5893)
@@ -0,0 +1,99 @@
+<?php
+# License:
+# Copyright (c) 2009, Open Source Geospatial Foundation
+# This program is dual licensed under the GNU General Public License
+# and Simplified BSD license.
+# http://svn.osgeo.org/mapbender/trunk/mapbender/license/license.txt
+require_once dirname(__FILE__) . "/../../core/globalSettings.php";
+require_once dirname(__FILE__)."/../../core/lib/class_Mapbender.php";
+require_once dirname(__FILE__)."/../../core/lib/class_User.php";
+function auth_user ($name,$pw) {
+	$setEncPw = false;
+	$sql = "SELECT * FROM mb_user WHERE mb_user_name = $1 AND mb_user_password = $2";
+	$v = array($name, md5($pw));
+	$t = array('s', 's');
+	$res = db_prep_query($sql,$v,$t);
+	if($row = db_fetch_array($res)){
+		return $row;
+	else if(SYS_DBTYPE == 'pgsql' && $setEncPw == true){
+		// 	unencrypted pw in postgres without md5-support?
+		$v = array($name,$pw);
+		$t = array('s','s');
+		$resn = db_prep_query($sql,$v,$t);
+		if($rown = db_fetch_array($resn)){
+			$sqlu = "UPDATE mb_user SET mb_user_password = $1 WHERE mb_user_id = $2";
+			$vu = array(md5($pw),$rown["mb_user_id"]);
+			$tu = array('s','i');
+			$rowu = db_prep_query($sqlu,$vu,$tu);
+			return $rown;
+	return null;
+function setSession() {
+	session_start();
+	session_write_close();
+function killSession() {
+	Mapbender::session()->kill();
+$ajaxResponse = new AjaxResponse($_POST, false);
+switch ($ajaxResponse->getMethod()) {
+  case "login" :
+    $name = $ajaxResponse->getParameter("name");
+  	$password = $ajaxResponse->getParameter("password");
+  	$resultObj = array();
+  	$user = User::byName($name);
+  	if (is_null($user)) {
+  		$ajaxResponse->setSuccess(false);
+  		$ajaxResponse->setMessage(_mb("Login failed."));
+  		break;
+  	if ($user->loginCountExceeded()) {
+  		$ajaxResponse->setMessage(_mb("Permission denied. Login failed %d times. Your account has been deactivated. Please contact your administrator!", MAXLOGIN));
+  		break;
+	$row = auth_user($name, $password);
+	// if given user data is found in database, set session data (db_fetch_array returns false if no row is found)
+	if($row){
+		setSession();
+		include dirname(__FILE__)."/../../conf/session.conf";
+	if (Mapbender::session()->get("mb_user_id")) {
+		if ($row["mb_user_login_count"] <= MAXLOGIN) {
+			$user->resetLoginCount();
+			$applicationArray = $user->getApplicationsByPermission();
+			Mapbender::session()->set("mb_user_guis", $applicationArray);
+//			Mapbender::session()->set("mb_login", $login);
+  		$ajaxResponse->setSuccess(true);
+  		$ajaxResponse->setMessage(_mb("Login success."));
+  		break;
+	$user->incrementLoginCount();
+	break;
+  default:
+    $ajaxResponse->setMessage(_mb("An unknown error occured."));
+    break;
+$ajaxResponse->send();
\ No newline at end of file
More information about the Mapbender_commits mailing list
