[Mapbender-commits] r5918 - in branches/2.5/resources/db: mysql/iso/update mysql/utf8/update postgresql/iso/update postgresql/utf8/update
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Sun Apr 11 09:05:41 EDT 2010
Author: tbaschetti
Date: 2010-04-11 09:05:40 -0400 (Sun, 11 Apr 2010)
New Revision: 5918
   branches/2.5/resources/db/mysql/iso/update/update_checkPermission.sql
   branches/2.5/resources/db/mysql/utf8/update/update_checkPermission.sql
   branches/2.5/resources/db/postgresql/iso/update/update_checkPermission.sql
   branches/2.5/resources/db/postgresql/utf8/update/update_checkPermission.sql
added missing "
Modified: branches/2.5/resources/db/mysql/iso/update/update_checkPermission.sql
--- branches/2.5/resources/db/mysql/iso/update/update_checkPermission.sql	2010-04-11 11:45:57 UTC (rev 5917)
+++ branches/2.5/resources/db/mysql/iso/update/update_checkPermission.sql	2010-04-11 13:05:40 UTC (rev 5918)
@@ -1,19 +1,19 @@
 -- http://trac.osgeo.org/mapbender/ticket/632
 -- in later releases these are integrated in the according sql_updates, no extra update_checkPermission.sql
 /*loadWMSinternal zu Admin-Guis hinzufuegen*/
-INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content,	e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) 	VALUES('admin2_de','loadWMSinternal',2,0,'Capabilities hochladen interne Datei, nicht aktiv schalten!',	'','','','href = "../php/mod_loadwms.php',	NULL ,NULL ,NULL ,NULL ,NULL ,'','Capabilities hochladen interne Funktion','','','','','',	'http://www.mapbender.org/index.php/Add_new_maps_to_Mapbender');
-INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content,	e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) 	VALUES('admin_de_services','loadWMSinternal',2,0,'Capabilities hochladen interne Datei, nicht aktiv schalten!',	'','','','href = "../php/mod_loadwms.php',	NULL ,NULL ,NULL ,NULL ,NULL ,'','Capabilities hochladen interne Funktion','','','','','',	'http://www.mapbender.org/index.php/Add_new_maps_to_Mapbender');
+INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content,	e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) 	VALUES('admin2_de','loadWMSinternal',2,0,'Capabilities hochladen interne Datei, nicht aktiv schalten!',	'','','','href = "../php/mod_loadwms.php"',NULL ,NULL ,NULL ,NULL ,NULL ,'','Capabilities hochladen interne Funktion','','','','','','http://www.mapbender.org/index.php/Add_new_maps_to_Mapbender');
+INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content,	e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) 	VALUES('admin_de_services','loadWMSinternal',2,0,'Capabilities hochladen interne Datei, nicht aktiv schalten!',	'','','','href = "../php/mod_loadwms.php"',NULL ,NULL ,NULL ,NULL ,NULL ,'','Capabilities hochladen interne Funktion','','','','','','http://www.mapbender.org/index.php/Add_new_maps_to_Mapbender');
 /*loadWMSinternal added to admin-guis*/
-INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content,	e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) 	VALUES('admin1','loadWMSinternal',2,0,'load Capabilities internal file, has not to be active!','','','','href = "../php/mod_loadwms.php',	NULL ,NULL ,NULL ,NULL ,NULL ,'','load capabilities internal function','','','','','',	'http://www.mapbender.org/index.php/Add_new_maps_to_Mapbender');
-INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content,	e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) 	VALUES('admin_en_services','loadWMSinternal',2,0,'load Capabilities internal file, has not to be active!','','','','href = "../php/mod_loadwms.php',	NULL ,NULL ,NULL ,NULL ,NULL ,'','load capabilities internal function','','','','','',	'http://www.mapbender.org/index.php/Add_new_maps_to_Mapbender');
-INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content,	e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) 	VALUES('admin2_en','loadWMSinternal',2,0,'load Capabilities internal file, has not to be active!','','','','href = "../php/mod_loadwms.php',	NULL ,NULL ,NULL ,NULL ,NULL ,'','load capabilities internal function','','','','','',	'http://www.mapbender.org/index.php/Add_new_maps_to_Mapbender');
+INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content,	e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) 	VALUES('admin1','loadWMSinternal',2,0,'load Capabilities internal file, has not to be active!','','','','href = "../php/mod_loadwms.php"',NULL ,NULL ,NULL ,NULL ,NULL ,'','load capabilities internal function','','','','','','http://www.mapbender.org/index.php/Add_new_maps_to_Mapbender');
+INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content,	e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) 	VALUES('admin_en_services','loadWMSinternal',2,0,'load Capabilities internal file, has not to be active!','','','','href = "../php/mod_loadwms.php"',NULL ,NULL ,NULL ,NULL ,NULL ,'','load capabilities internal function','','','','','','http://www.mapbender.org/index.php/Add_new_maps_to_Mapbender');
+INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content,	e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) 	VALUES('admin2_en','loadWMSinternal',2,0,'load Capabilities internal file, has not to be active!','','','','href = "../php/mod_loadwms.php"',NULL ,NULL ,NULL ,NULL ,NULL ,'','load capabilities internal function','','','','','','http://www.mapbender.org/index.php/Add_new_maps_to_Mapbender');
 /*loadCSWinternal zu Admin-Guis hinzufuegen*/
-INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content,	e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) 	VALUES('admin2_de','loadCSWinternal',2,0,'CatalogCapabilities hochladen interne Datei, nicht aktiv schalten!',	'','','','href = "../php/mod_loadCatalog.php',	NULL ,NULL ,NULL ,NULL ,NULL ,'','Capabilities hochladen interne Funktion','','','','','',	'http://www.mapbender.org/index.php/newGUI');
-INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content,	e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) 	VALUES('admin_de_services','loadCSWinternal',2,0,'CatalogCapabilities hochladen interne Datei, nicht aktiv schalten!',	'','','','href = "../php/mod_loadCatalog.php',	NULL ,NULL ,NULL ,NULL ,NULL ,'','Capabilities hochladen interne Funktion','','','','','',	'http://www.mapbender.org/index.php/newGUI');
+INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content,	e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) 	VALUES('admin2_de','loadCSWinternal',2,0,'CatalogCapabilities hochladen interne Datei, nicht aktiv schalten!',	'','','','href = "../php/mod_loadCatalog.php"',NULL ,NULL ,NULL ,NULL ,NULL ,'','Capabilities hochladen interne Funktion','','','','','',	'http://www.mapbender.org/index.php/newGUI');
+INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content,	e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) 	VALUES('admin_de_services','loadCSWinternal',2,0,'CatalogCapabilities hochladen interne Datei, nicht aktiv schalten!',	'','','','href = "../php/mod_loadCatalog.php"',	NULL ,NULL ,NULL ,NULL ,NULL ,'','Capabilities hochladen interne Funktion','','','','','','http://www.mapbender.org/index.php/newGUI');
 /*loadCSWinternal added to admin-guis*/
-INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content,	e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) 	VALUES('admin1','loadCSWinternal',2,0,'load Catalog Capabilities internal file, has not to be active!','','','','href = "../php/mod_loadCatalog.php',	NULL ,NULL ,NULL ,NULL ,NULL ,'','load capabilities internal function','','','','','',	'http://www.mapbender.org/index.php/newGUI');
-INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content,	e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) 	VALUES('admin_en_services','loadCSWinternal',2,0,'load Catalog Capabilities internal file, has not to be active!','','','','href = "../php/mod_loadCatalog.php',	NULL ,NULL ,NULL ,NULL ,NULL ,'','load capabilities internal function','','','','','',	'http://www.mapbender.org/index.php/newGUI');
-INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content,	e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) 	VALUES('admin2_en','loadCSWinternal',2,0,'load Catalog Capabilities internal file, has not to be active!','','','','href = "../php/mod_loadCatalog.php',	NULL ,NULL ,NULL ,NULL ,NULL ,'','load capabilities internal function','','','','','',	'http://www.mapbender.org/index.php/newGUI');
+INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content,	e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) 	VALUES('admin1','loadCSWinternal',2,0,'load Catalog Capabilities internal file, has not to be active!','','','','href = "../php/mod_loadCatalog.php"',NULL ,NULL ,NULL ,NULL ,NULL ,'','load capabilities internal function','','','','','','http://www.mapbender.org/index.php/newGUI');
+INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content,	e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) 	VALUES('admin_en_services','loadCSWinternal',2,0,'load Catalog Capabilities internal file, has not to be active!','','','','href = "../php/mod_loadCatalog.php',NULL ,NULL ,NULL ,NULL ,NULL ,'','load capabilities internal function','','','','','','http://www.mapbender.org/index.php/newGUI');
+INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content,	e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) 	VALUES('admin2_en','loadCSWinternal',2,0,'load Catalog Capabilities internal file, has not to be active!','','','','href = "../php/mod_loadCatalog.php"',NULL ,NULL ,NULL ,NULL ,NULL ,'','load capabilities internal function','','','','','','http://www.mapbender.org/index.php/newGUI');
Modified: branches/2.5/resources/db/mysql/utf8/update/update_checkPermission.sql
--- branches/2.5/resources/db/mysql/utf8/update/update_checkPermission.sql	2010-04-11 11:45:57 UTC (rev 5917)
+++ branches/2.5/resources/db/mysql/utf8/update/update_checkPermission.sql	2010-04-11 13:05:40 UTC (rev 5918)
@@ -1,19 +1,19 @@
Modified: branches/2.5/resources/db/postgresql/iso/update/update_checkPermission.sql
--- branches/2.5/resources/db/postgresql/iso/update/update_checkPermission.sql	2010-04-11 11:45:57 UTC (rev 5917)
+++ branches/2.5/resources/db/postgresql/iso/update/update_checkPermission.sql	2010-04-11 13:05:40 UTC (rev 5918)
@@ -1,19 +1,19 @@
Modified: branches/2.5/resources/db/postgresql/utf8/update/update_checkPermission.sql
--- branches/2.5/resources/db/postgresql/utf8/update/update_checkPermission.sql	2010-04-11 11:45:57 UTC (rev 5917)
+++ branches/2.5/resources/db/postgresql/utf8/update/update_checkPermission.sql	2010-04-11 13:05:40 UTC (rev 5918)
@@ -1,19 +1,19 @@
More information about the Mapbender_commits mailing list
