[Mapbender-commits] r5944 - trunk/mapbender/http/plugins
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Mon Apr 12 04:52:00 EDT 2010
Author: verenadiewald
Date: 2010-04-12 04:51:38 -0400 (Mon, 12 Apr 2010)
New Revision: 5944
   trunk/mapbender/http/plugins/jq_upload.js
   trunk/mapbender/http/plugins/jq_upload.php
set ___ as separator for returnString -> taking _ as separator can lead to problems with underscores in directory names
Modified: trunk/mapbender/http/plugins/jq_upload.js
--- trunk/mapbender/http/plugins/jq_upload.js	2010-04-11 15:13:55 UTC (rev 5943)
+++ trunk/mapbender/http/plugins/jq_upload.js	2010-04-12 08:51:38 UTC (rev 5944)
@@ -41,7 +41,7 @@
 					clearInterval(t);
 					time = 0;
-					var returnValueArray = returnValue.split("_");
+					var returnValueArray = returnValue.split("___");
 					var filename = returnValueArray[returnValueArray.length - 3];
 					var origFilename = window.frames[id+"_target"].filename;
 					var msg = "";
@@ -49,14 +49,14 @@
 					if (returnValue.match(/_finished/)) {
 						window.frames[id + "_target"].id = undefined;
 						if (typeof options.callback === "function") {
-							var msgArray = returnValue.split("_");
+							var msgArray = returnValue.split("___");
 							msg = msgArray.pop();
 							options.callback({filename:filename,origFilename: origFilename}, true, msg);
 					else if (returnValue.match(/_cancelled/)) {
 							options.callback(null, false, msg);
Modified: trunk/mapbender/http/plugins/jq_upload.php
--- trunk/mapbender/http/plugins/jq_upload.php	2010-04-11 15:13:55 UTC (rev 5943)
+++ trunk/mapbender/http/plugins/jq_upload.php	2010-04-12 08:51:38 UTC (rev 5944)
@@ -70,6 +70,7 @@
 		$serverFilename .= $extension;
 		$serverFullFilename = $uploadDir . "/" . $serverFilename;
+		$e = new mb_exception($serverFullFilename);
 		if (!$cancel) {
 			if (!copy($uploadedFile, $serverFullFilename)) {
 				$status = "cancelled";
@@ -92,7 +93,7 @@
 	<head>
 		<script type="text/javascript">
 			var id = "<?php
-				echo $id . "_" . $serverFullFilename . "_" . $status . "_" . $message;
+				echo $id . "___" . $serverFullFilename . "___" . $status . "___" . $message;
 			var filename = "<?php echo $clientFilename;  ?>";
 		</script>
More information about the Mapbender_commits mailing list
