[Mapbender-commits] r5946 - in branches/3_dev: core/lib http/frames http/plugins
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Mon Apr 12 07:22:29 EDT 2010
Author: christoph
Date: 2010-04-12 07:22:27 -0400 (Mon, 12 Apr 2010)
New Revision: 5946
   branches/3_dev/core/lib/class_User.php
   branches/3_dev/http/frames/index.php
   branches/3_dev/http/frames/login.php
   branches/3_dev/http/plugins/mb_loginForm.js
   branches/3_dev/http/plugins/mb_login_server.php
Modified: branches/3_dev/core/lib/class_User.php
--- branches/3_dev/core/lib/class_User.php	2010-04-12 10:27:23 UTC (rev 5945)
+++ branches/3_dev/core/lib/class_User.php	2010-04-12 11:22:27 UTC (rev 5946)
@@ -473,26 +473,24 @@
-    * tries to initialize a userobject by Name
-    * @return A user Object
-    * @param $name the name of the user to find
+	 * tries to initialize a userobject by Name
+	 * @return A user Object
+	 * @param $name the name of the user to find
     public static function byName($name) {
-      if($name == null) { return new User(null); }
-      $sql_user = "SELECT mb_user_id FROM mb_user WHERE mb_user_name = '$name'";
-      $res_user = db_query($sql_user);
-      if($row = db_fetch_array($res_user))
-	$user = new User($row['mb_user_id']);
-	$user->load();
-        return  $user;
-      return null;
+      	if ($name == null) {
+			return new User(null);
+		$sql_user = "SELECT mb_user_id FROM mb_user WHERE mb_user_name = $1";
+		$res_user = db_prep_query($sql_user, array($name), array("s"));
+		if ($row = db_fetch_array($res_user)) {
+			$user = new User($row['mb_user_id']);
+			$user->load();
+        	return  $user;
+		return null;
Modified: branches/3_dev/http/frames/index.php
--- branches/3_dev/http/frames/index.php	2010-04-12 10:27:23 UTC (rev 5945)
+++ branches/3_dev/http/frames/index.php	2010-04-12 11:22:27 UTC (rev 5946)
@@ -72,15 +72,11 @@
 	$gui_id = DEFAULT_APPLICATION;
 	$firephp->log("Using default application: " . $gui_id);
-$firephp->log($user);
 include dirname(__FILE__)."/../../conf/session.conf";
 Mapbender::session()->set("mb_user_gui", $gui_id);
 Mapbender::session()->set("mb_user_guis", $user->getApplicationsByPermission());
-//require_once dirname(__FILE__)."/../../core/validateSession.php";
-// what if there is no PUBLIC_USER or DEFAULT_APPLICATION?
 <!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
 <html>
Modified: branches/3_dev/http/frames/login.php
--- branches/3_dev/http/frames/login.php	2010-04-12 10:27:23 UTC (rev 5945)
+++ branches/3_dev/http/frames/login.php	2010-04-12 11:22:27 UTC (rev 5946)
@@ -5,272 +5,87 @@
 # and Simplified BSD license.
 # http://svn.osgeo.org/mapbender/trunk/mapbender/license/license.txt
-require_once(dirname(__FILE__)."/../../core/globalSettings.php");
+require_once(dirname(__FILE__)."/../../conf/mapbender.conf");
+require_once(dirname(__FILE__)."/../../core/lib/class_Mapbender.php");
 require_once(dirname(__FILE__)."/../../core/lib/class_Session.php");
+require_once(dirname(__FILE__)."/../../core/lib/class_Database.php");
 require_once(dirname(__FILE__)."/../../core/lib/class_User.php");
-function mb_getGUIs ($userId) {
-	$user = new User($userId);
-	if (!is_null($user)) {
-		return $user->getApplicationsByPermission();
+function redirectToApplication ($session = false, $appName = DEFAULT_APPLICATION) {
+	$param = array();
+	if ($session !== false) {
+		$param[]= session_name() . "=" . session_id();
-	return array();
+	$param[]= "gui_id=" . urlencode($appName);
+	$url = $_SERVER["HTTP_HOST"] . dirname($_SERVER["PHP_SELF"]) . "/index.php?" . implode("&", $param);
-function mb_listGUIs($arrayGUIs){
-	if(count($arrayGUIs) === 0) {
-		echo "<h1>Error</h1>";
-		echo "<p>There are no GUIs available for this user.</p>";
-		printf("<p><a href=\"../php/mod_logout.php?%s\"><img src=\"../img/button_gray/logout_off.png\" onmouseover=\"this.src='../img/button_gray/logout_over.png'\" onmouseout=\"this.src='../img/button_gray/logout_off.png'\" title=\"Logout\"></a></p>",SID);
-		return;
+	session_write_close();
+	if (isset($_SERVER["HTTPS"]) && $_SERVER["HTTPS"] == "on") {
+		header ("Location: https://".$url);
-	$user = new User(Mapbender::session()->get('mb_user_id'));
-	$result = $user->getGuiCategoryList($arrayGUIs);
-	$category = NULL;
-	echo "<h1><font align='left' color='#000000'>Ma</font><font color='#0000CE'>p</font><font color='#C00000'>b</font><font color='#000000'>ender </font> - "._mb('available Applications')."</h1>";
-	echo "\n<div id=\"cat_tabs\">";
-	echo "<ul>";
-	$total_guis = 0;
-	$total_cats = 0;
-	$divString = "\t<div>";
-	foreach ($result as $row){
-		if($category !== $row["category_name"]) {
-			$category = $row["category_name"];
-			/* first echo the tab div with the tab <ul>'s */
-			echo "\t<li><a href=\"#cat_tabs-$total_cats\"";
-			if(strlen($row["category_description"]) > 0) {
-				printf(" title=\"%s\"",$row["category_description"]);
-			} else {
-				printf(" title=\"%s\"","");
-			echo ">";
-			if(strlen($row["category_name"]) > 0) {
-				echo $category;
-			else {
-				echo _mb("ohne Katgeorie");
-			echo "</a></li>\n";
-			/* then concatenate a string containing the tab div's content */
-			$divString .= "\t</div>\n\t<div id=\"cat_tabs-$total_cats\">\n";
-			$total_cats++;
-		$class = ($total_guis %2 === 0) ? " class=\"alternate\"" : NULL;
-		$url   = sprintf("index.php?%s&gui_id=%s",strip_tags(SID),$row["gui_id"]);
-		$divString .= "\t\t<p><a href=\"$url\"><strong>".$row["gui_name"]."</strong> - <em>".$row["gui_description"]."</em></a></p>\n";
-		$total_guis++;
+	else {
+		header ("Location: http://".$url);
-	echo "</ul>\n";
-	echo $divString."\n</div>";
+	die;
-function auth_user($name,$pw){
-	$setEncPw = false;
-	$sql = "SELECT * FROM mb_user WHERE mb_user_name = $1 AND mb_user_password = $2";
-	$v = array($name,md5($pw));
-	$t = array('s','s');
-	$res = db_prep_query($sql,$v,$t);
-	if($row = db_fetch_array($res)){
-		return $row;
-	else if(SYS_DBTYPE == 'pgsql' && $setEncPw == true){
-		// 	unencrypted pw in postgres without md5-support?
-		$v = array($name,$pw);
-		$resn = db_prep_query($sql,$v,$t);
-		if($rown = db_fetch_array($resn)){
-			$sqlu = "UPDATE mb_user SET mb_user_password = $1 WHERE mb_user_id = $2";
-			$vu = array(md5($pw),$rown["mb_user_id"]);
-			$tu = array('s','i');
-			$rowu = db_prep_query($sqlu,$vu,$tu);
-			return $rown;
-	else if(SYS_DBTYPE == 'mysql' && $setEncPw == true){
-		$sql = "SELECT * FROM mb_user WHERE mb_user_name = $1 AND mb_user_password = password($2)";
-			return $rown;
-function setSession(){
-	session_start();
-	session_write_close();
-function killSession(){
-	Mapbender::session()->kill();
-<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
-<html>
-<head>
-    License:
-    Copyright (c) 2009, Open Source Geospatial Foundation
-    This program is dual licensed under the GNU General Public License
-    and Simplified BSD license.
-    http://svn.osgeo.org/mapbender/trunk/mapbender/license/license.txt
-<meta http-equiv="cache-control" content="no-cache">
-<meta http-equiv="pragma" content="no-cache">
-<meta http-equiv="expires" content="0">
-<META http-equiv="Content-Style-Type" content="text/css">
-<META http-equiv="Content-Script-Type" content="text/javascript">
-<meta http-equiv="Content-Type" content="text/html; charset=<?php echo CHARSET;?>">
-<title>Login</title>
-	<link type="text/css" href="../extensions/jquery-ui-1.8.custom/development-bundle/themes/base/jquery.ui.all.css" rel="stylesheet" />
-	<script type="text/javascript" src="../extensions/jquery-ui-1.8.custom/development-bundle/jquery-1.4.2.js"></script>
-	<script type="text/javascript" src="../extensions/jquery-ui-1.8.custom/development-bundle/external/jquery.bgiframe-2.1.1.js"></script>
-	<script type="text/javascript" src="../extensions/jquery-ui-1.8.custom/development-bundle/ui/jquery.ui.core.js"></script>
-	<script type="text/javascript" src="../extensions/jquery-ui-1.8.custom/development-bundle/ui/jquery.ui.widget.js"></script>
-	<script type="text/javascript" src="../extensions/jquery-ui-1.8.custom/development-bundle/ui/jquery.ui.mouse.js"></script>
-	<script type="text/javascript" src="../extensions/jquery-ui-1.8.custom/development-bundle/ui/jquery.ui.draggable.js"></script>
-	<script type="text/javascript" src="../extensions/jquery-ui-1.8.custom/development-bundle/ui/jquery.ui.position.js"></script>
-	<script type="text/javascript" src="../extensions/jquery-ui-1.8.custom/development-bundle/ui/jquery.ui.resizable.js"></script>
-	<script type="text/javascript" src="../extensions/jquery-ui-1.8.custom/development-bundle/ui/jquery.ui.dialog.js"></script>
-	<script type="text/javascript" src="../extensions/jquery-ui-1.8.custom/development-bundle/ui/jquery.ui.tabs.js"></script>
-<?php
-echo "<link rel=\"stylesheet\" type=\"text/css\" href=\"../css/login.css\">";
 $name = $_REQUEST["name"];
 $password = $_REQUEST["password"];
-if(!isset($name) || $name == ''){
-	echo <<<HTML
-<script type='text/javascript'>
-		function setFocus() {
-			if(document.loginForm){
-				document.loginForm.name.focus();
-</script>
-HTML;
+if (!isset($name) || $name == '' || !isset($password) || $password == '') {
+	Mapbender::session()->kill();
+	redirectToApplication();
-else{
-	echo <<<HTML
-		function setFocus(){
-				document.loginForm.password.focus();
-</script>
-HTML;
-echo <<<HTML
-	$(document).ready(function() {
-		$("#cat_tabs").tabs();
-</script>
-HTML;
-echo "</head>";
-echo "<body onload='setFocus()'>";
+if (isset($name) && $name != '' && isset($password) && $password != '') {
+	// establish database connection
+	$con = db_connect($DBSERVER, $OWNER, $PW);
+	db_select_db(DB, $con);
-if(!isset($name) || $name == '' || !isset($password) || $password == ''){
-	killSession();
-	echo "<form name='loginForm' action ='" . $PHP_SELF . "' method='POST'>";
-	echo "<table>";
-	echo "<tr><td>" . _mb("Name") . ": </td><td><input type='text' name='name' class='login_text' value=''></td></tr>";
-	echo "<tr><td>" . _mb("Password") . ": </td><td><input type='password' name='password' class='login_text'></td></tr>";
-	echo "<tr><td></td><td><input type='submit' class='myButton' value='login' title='anmelden'>";
-	echo "&nbsp;&nbsp;<a href='../frames/forgottenPassword.php' title='" .
-		_mb("Forgot your password?") . "' target='_blank'>" .
-		_mb("Forgot your password?") . "</a>";
-	echo "</td></tr></table>";
-	echo "</form>";
-if(isset($name) && $name != '' && isset($password) && $password != ''){
-	$sql_count = "SELECT mb_user_login_count FROM mb_user WHERE mb_user_name = $1";
-	$params = array($name);
-	$types = array('s');
-	$res_count = db_prep_query($sql_count,$params,$types);
-	if($row = db_fetch_array($res_count)){
-		if($row["mb_user_login_count"] > MAXLOGIN){
-			echo "Permission denied. Login failed ".MAXLOGIN." times. Your account has been deactivated. Please contact your administrator!";
-			die;
+  	$user = User::byName($name);
+	if (is_null($user)) {
+  	if ($user->loginCountExceeded()) {
+		echo _mb("Permission denied. Login failed %s times. Your account has been deactivated. Please contact your administrator!", MAXLOGIN);
+		die;
-	$row = auth_user($name, $password);
+	// try to log in
+	$authenticatedUser = User::getByNameAndPassword($name, $password);
 	// if given user data is found in database, set session data (db_fetch_array returns false if no row is found)
-	if($row){
-		setSession();
+	if (!is_null($authenticatedUser)) {
+		session_start();
 		include(dirname(__FILE__)."/../../conf/session.conf");
-	if(Mapbender::session()->get("mb_user_id")){
-		if($row["mb_user_login_count"] <= MAXLOGIN){
-			$sql_del_cnt =  "UPDATE mb_user SET mb_user_login_count = 0 WHERE mb_user_id = $1";
-			$v = array(Mapbender::session()->get('mb_user_id'));
-			$t = array("i");
-			db_prep_query($sql_del_cnt, $v, $t);
-			$arrayGUIs = mb_getGUIs($row["mb_user_id"]);
-			new mb_notice("login.setSession.mb_user_guis: ".serialize($arrayGUIs)." in session: " .session_id());
+		if (!$authenticatedUser->loginCountExceeded()) {
+			$authenticatedUser->resetLoginCount();
+			$arrayGUIs = $authenticatedUser->getApplicationsByPermission();
 			Mapbender::session()->set("mb_user_guis",$arrayGUIs);
 			Mapbender::session()->set("mb_login",$login);
 			# a gui is explicitly ordered
-			if((isset($_GET["mb_user_myGui"]) || Mapbender::session()->get("mb_user_myGui")) && in_array($_GET["mb_user_myGui"], $arrayGUIs)){
-				unset($arrayGUIs);
-				if(isset($_GET["mb_user_myGui"])){ $arrayGUIs[0] = $_GET["mb_user_myGui"];}
-				else{ $arrayGUIs[0] = Mapbender::session()->set("mb_user_myGui");}
+			if(isset($_GET["mb_user_myGui"]) && in_array($_GET["mb_user_myGui"], $arrayGUIs)){
+				redirectToApplication(true, $_GET["mb_user_myGui"]);
-			#only one gui is provided
-			if(count($arrayGUIs) == 1){
-				if (isset($_SERVER["HTTPS"]) && $_SERVER["HTTPS"] == "on") {
-					$myURL = "Location: https://".$_SERVER['HTTP_HOST'].dirname($_SERVER['PHP_SELF'])."/index.php?".strip_tags (SID)."&gui_id=".$arrayGUIs[0];
-				else {
-					$myURL = "Location: http://".$_SERVER['HTTP_HOST'].dirname($_SERVER['PHP_SELF'])."/index.php?".strip_tags (SID)."&gui_id=".$arrayGUIs[0];
-				# params for the initial call
-				if(isset($_GET["mb_myBBOX"])){
-					$myURL .= "&mb_myBBOX=".$_GET["mb_myBBOX"];
-				header ($myURL);
-				die;
+			if (Mapbender::session()->get("mb_user_myGui") && in_array(Mapbender::session()->get("mb_user_myGui"), $arrayGUIs)){
+				redirectToApplication(true, Mapbender::session()->get("mb_user_myGui"));
 			# list all guis of this user and his groups
-			else{
-				mb_listGUIs($arrayGUIs);
+			else {
+				redirectToApplication(true);
 	else{
-		$sql_set_cnt = "UPDATE mb_user SET mb_user_login_count = (mb_user_login_count + 1) WHERE mb_user_name = $1";
-		$v = array($name);
-		$t = array('s');
-		db_prep_query($sql_set_cnt,$v,$t);
-			header ("Location: https://".$_SERVER['HTTP_HOST'].dirname($_SERVER['PHP_SELF'])."/login.php?name=".$name);
-		else {
-			header ("Location: http://".$_SERVER['HTTP_HOST'].dirname($_SERVER['PHP_SELF'])."/login.php?name=".$name);
-		die;
+		$userLoginFailed->incrementLoginCount();
Modified: branches/3_dev/http/plugins/mb_loginForm.js
--- branches/3_dev/http/plugins/mb_loginForm.js	2010-04-12 10:27:23 UTC (rev 5945)
+++ branches/3_dev/http/plugins/mb_loginForm.js	2010-04-12 11:22:27 UTC (rev 5946)
@@ -26,12 +26,17 @@
 									callback: function (obj, result, message) {
 										if (!result) {
-											$("#mb_login").loggedOut();
+											$("#mb_login").mapbender(function () {
+												this.loggedOut();
 											return;
 										$loginDiv.dialog("destroy");
-										window.location.href = Mapbender.login + "?name=" + name + "&password=" + password;
+											this.loggedIn(obj.name);
+										//window.location.href = Mapbender.login + "?name=" + name + "&password=" + password;
 								req.send();
Modified: branches/3_dev/http/plugins/mb_login_server.php
--- branches/3_dev/http/plugins/mb_login_server.php	2010-04-12 10:27:23 UTC (rev 5945)
+++ branches/3_dev/http/plugins/mb_login_server.php	2010-04-12 11:22:27 UTC (rev 5946)
@@ -9,68 +9,43 @@
 require_once dirname(__FILE__)."/../../core/lib/class_Mapbender.php";
 require_once dirname(__FILE__)."/../../core/lib/class_User.php";
-function auth_user ($name,$pw) {
-	$v = array($name, md5($pw));
-	$t = array('s', 's');
-		return $row;
-			return $rown;
-	return null;
 $ajaxResponse = new AjaxResponse($_POST, false);
 switch ($ajaxResponse->getMethod()) {
-  case "login" :
+	case "login" :
-    $name = $ajaxResponse->getParameter("name");
-  	$password = $ajaxResponse->getParameter("password");
-  	$resultObj = array();
-  	$user = User::byName($name);
-  	if (is_null($user)) {
-  		$ajaxResponse->setSuccess(false);
-  		$ajaxResponse->setMessage(_mb("Login failed."));
-  		break;
-  	if ($user->loginCountExceeded()) {
-  		$ajaxResponse->setMessage(_mb("Permission denied. Login failed %d times. Your account has been deactivated. Please contact your administrator!", MAXLOGIN));
-  		break;
-  	$user = User::getByNameAndPassword($name, $password);
-	if (!is_null($user)){
-		$ajaxResponse->setSuccess(true);
-  		$ajaxResponse->setMessage(_mb("Login success."));
-  		break;
-	$user->incrementLoginCount();
-	break;
+		$name = $ajaxResponse->getParameter("name");
+		$password = $ajaxResponse->getParameter("password");
+			$ajaxResponse->setSuccess(false);
+			$ajaxResponse->setMessage(_mb("Login failed."));
+			break;
+			$ajaxResponse->setMessage(_mb("Permission denied. Login failed %d times. Your account has been deactivated. Please contact your administrator!", MAXLOGIN));
+			break;
+		$user = User::getByNameAndPassword($name, $password);
+		if (!is_null($user)){
+			session_start();
+			include(dirname(__FILE__)."/../../conf/session.conf");
+			$ajaxResponse->setResult(array("name" => $name));
+			$ajaxResponse->setSuccess(true);
+			$ajaxResponse->setMessage(_mb("Login success."));
+			break;
+		$user->incrementLoginCount();
+		break;
 	case "userInformation" :
 		if (Mapbender::session()->get("mb_user_id")) {
 			$resultObj = array(
-				"name" => Mapbender::session()->get("mb_user_name")
+			"name" => Mapbender::session()->get("mb_user_name")
 			$ajaxResponse->setResult($resultObj);
@@ -82,12 +57,10 @@
 		break;
-  default:
-    $ajaxResponse->setMessage(_mb("An unknown error occured."));
-    break;
+	default:
+		$ajaxResponse->setMessage(_mb("An unknown error occured."));
+		break;
-$firephp->log($_SESSION);
-$firephp->log(session_id());
 $ajaxResponse->send();
\ No newline at end of file
More information about the Mapbender_commits mailing list
