[Mapbender-commits] r5949 - trunk/mapbender/http/plugins
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Tue Apr 13 11:14:54 EDT 2010
Author: christoph
Date: 2010-04-13 11:14:53 -0400 (Tue, 13 Apr 2010)
New Revision: 5949
Added:
   trunk/mapbender/http/plugins/mb_metadata_controller.js
   trunk/mapbender/http/plugins/mb_metadata_edit.js
   trunk/mapbender/http/plugins/mb_metadata_select.js
   trunk/mapbender/http/plugins/mb_metadata_server.php
Added: trunk/mapbender/http/plugins/mb_metadata_controller.js
--- trunk/mapbender/http/plugins/mb_metadata_controller.js	                        (rev 0)
+++ trunk/mapbender/http/plugins/mb_metadata_controller.js	2010-04-13 15:14:53 UTC (rev 5949)
@@ -0,0 +1,23 @@
+Mapbender.events.init.register(function () {
+	if (options.$target.length < 3) {
+		return;
+	var tabsIndex = 0;
+	var selectIndex = 1;
+	var editIndex = 2;
+	var $tabs = options.$target.eq(tabsIndex);
+	var $select = options.$target.eq(selectIndex);
+	var $edit = options.$target.eq(editIndex);
+	var select = $select.mapbender();
+	var edit = $edit.mapbender();
+	select.events.selected.register(function (obj) {
+		$select.fadeOut(function () {
+			$tabs.tabs("select", editIndex-1);
+			edit.edit(obj);
+			$select.show();
Added: trunk/mapbender/http/plugins/mb_metadata_edit.js
--- trunk/mapbender/http/plugins/mb_metadata_edit.js	                        (rev 0)
+++ trunk/mapbender/http/plugins/mb_metadata_edit.js	2010-04-13 15:14:53 UTC (rev 5949)
@@ -0,0 +1,47 @@
+ * Package: mb_metadata_edit
+ * Description:
+ * Files:
+ * SQL:
+ * Help:
+ * Maintainer:
+ * http://www.mapbender.org/User:Christoph_Baudson
+ * License:
+ * Copyright (c) 2009, Open Source Geospatial Foundation
+ * This program is dual licensed under the GNU General Public License
+ * and Simplified BSD license.
+ * http://svn.osgeo.org/mapbender/trunk/mapbender/license/license.txt
+var $metadataEdit = $(this);
+var MetadataEditApi = function (o) {
+	this.edit = function (obj) {
+		// empty form
+		// get metadata from server
+		var req = new Mapbender.Ajax.Request({
+			url: "../plugins/mb_metadata_server.php",
+			method: "getWms",
+			parameters: {
+			callback: function (obj, result, message) {
+				if (!result) {
+					return;
+				console.log(obj);
+		req.send();
+		// fill form
+$metadataEdit.mapbender(new MetadataEditApi(options));
Added: trunk/mapbender/http/plugins/mb_metadata_select.js
--- trunk/mapbender/http/plugins/mb_metadata_select.js	                        (rev 0)
+++ trunk/mapbender/http/plugins/mb_metadata_select.js	2010-04-13 15:14:53 UTC (rev 5949)
@@ -0,0 +1,98 @@
+ * Package: mb_metadata_select
+ * Description:
+ * Files:
+ * SQL:
+ * Help:
+ * Maintainer:
+ * License:
+var $metadataSelect = $(this);
+var MetadataSelectApi = function (o) {
+	var table = null;
+	var that = this;
+	var fnGetSelected = function (oTableLocal){
+		var aReturn = [];
+		var aTrs = oTableLocal.fnGetNodes();
+		for ( var i=0 ; i<aTrs.length ; i++ ){
+			if ( $(aTrs[i]).hasClass('row_selected') ){
+				aReturn.push( aTrs[i] );
+		return aReturn;
+	this.getData = function () {
+			method: "getWms",
+			parameters: {
+				if (!result) {
+					return;
+				var aoColumns = [];
+				for (var i in obj.header) {
+					if (obj.header[i] === "WMS ID") {
+						continue;
+					aoColumns.push({"sTitle": obj.header[i]});
+				// initialize datatables
+				table = $metadataSelect.find("table").dataTable({
+					"aoColumns": aoColumns,
+					"bJQueryUI": true,
+					"bAutoWidth": false
+				// add rows
+				for (var j in obj.data) {
+					var data = obj.data[j];
+					var wmsId = data[0];
+					data.shift();
+					var index = table.fnAddData(data);
+					var rowNode = table.fnGetNodes(index[0]);
+					$(rowNode).data("wmsId", wmsId);
+				// make rows selectable
+				$metadataSelect.find("tbody").click(function (e) {
+					$(table.fnSettings().aoData).each(function (){
+						$(this.nTr).removeClass('row_selected');
+					$(e.target.parentNode).addClass('row_selected');
+					var selectedRow = fnGetSelected(table);
+					that.events.selected.trigger({
+						wmsId: $(selectedRow).data("wmsId")
+		req.send();
+	this.events = {
+		"selected": new Mapbender.Event()
+$metadataSelect.mapbender(new MetadataSelectApi(options));
+$metadataSelect.mapbender("getData");
\ No newline at end of file
Added: trunk/mapbender/http/plugins/mb_metadata_server.php
--- trunk/mapbender/http/plugins/mb_metadata_server.php	                        (rev 0)
+++ trunk/mapbender/http/plugins/mb_metadata_server.php	2010-04-13 15:14:53 UTC (rev 5949)
@@ -0,0 +1,87 @@
+<?php
+require_once dirname(__FILE__) . "/../../core/globalSettings.php";
+require_once dirname(__FILE__) . "/../classes/class_user.php";
+$ajaxResponse = new AjaxResponse($_POST);
+function abort ($message) {
+	$ajaxResponse->setSuccess(false);
+	$ajaxResponse->setMessage($message);
+	$ajaxResponse->send();
+	die;
+function getWms ($wmsId = null) {
+	$user = new User(Mapbender::session()->get("mb_user_id"));
+	$wmsIdArray = $user->getOwnedWms();
+	if (!is_array($wmsIdArray) || count($wmsIdArray) === 0) {
+		abort(_mb("No metadata sets available."));
+	if (!is_null($wmsId) && !in_array($wmsId, $wmsIdArray)) {
+		abort(_mb("You are not allowed to access this WMS."));
+	return $wmsIdArray;
+switch ($ajaxResponse->getMethod()) {
+	case "getWms" :
+		$wmsIdArray = getWms();
+		$wmsList = implode(",", $wmsIdArray);
+		$sql = <<<SQL
+SELECT wms.wms_id, wms.wms_title, wms.wms_timestamp, wms_version, m.status_comment
+FROM wms LEFT JOIN mb_monitor AS m
+ON wms.wms_id = m.fkey_wms_id
+WHERE wms_id IN ($wmsList);
+SQL;
+		$res = db_query($sql);
+		$resultObj = array(
+			"header" => array(
+				"WMS ID",
+				"Titel",
+				"Timestamp",
+				"Version",
+				"Status"
+			"data" => array()
+		while ($row = db_fetch_row($res)) {
+			// convert NULL to '', NULL values cause datatables to crash
+			$walk = array_walk($row, create_function('&$s', '$s=strval($s);'));
+			$resultObj["data"][]= $row;
+		$ajaxResponse->setResult($resultObj);
+		$ajaxResponse->setSuccess(true);
+		break;
+	case "getWms" :
+		$wmsId = $ajaxResponse->getParameter("id");
+		getWms($wmsId);
+		$sql = <<<SQL
+SELECT * FROM wms WHERE wms_id = $wmsId;
+SQL;
+		$resultObj = array();
+			$resultObj[]= $row;
+		break;
+	default:
+		$ajaxResponse->setMessage(_mb("An unknown error occured."));
+		break;
+$ajaxResponse->send();
More information about the Mapbender_commits mailing list
