[Mapbender-commits] r5951 - trunk/mapbender/lib
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Thu Apr 15 10:05:29 EDT 2010
Author: christoph
Date: 2010-04-15 10:05:27 -0400 (Thu, 15 Apr 2010)
New Revision: 5951
   trunk/mapbender/lib/resultGeometryListController.js
refactoring
Modified: trunk/mapbender/lib/resultGeometryListController.js
--- trunk/mapbender/lib/resultGeometryListController.js	2010-04-14 11:30:16 UTC (rev 5950)
+++ trunk/mapbender/lib/resultGeometryListController.js	2010-04-15 14:05:27 UTC (rev 5951)
@@ -21,12 +21,12 @@
 	this.detailColumns = [];
 	// array of buttondef objects
-	this.rowbuttons = []
+	this.rowbuttons = [];
 	this.options = options;
 	 * Method: addFeature
 	 * Description: adds a Feature to the Model
 	 * Parameters:
@@ -40,7 +40,7 @@
 		var result = me.model.addFeature(feature);
 	 * Method: addFeatureCollection
 	 * Description: adds a FeatureCollection to the Model
 	 * Parameters:
@@ -50,7 +50,7 @@
 		var result = me.model.addFeatureCollection(geoJSON);
 	 * Method: addFeatureCollection_callback
 	 * Description: The callback received from the Model upon successfully adding a Feature
 	 * Parameters:
@@ -65,12 +65,10 @@
 			modelIndex = featureEntryCollection.featureCollection[featureIndex].index;
 			var rowData = [];
 			for (ci in me.columns){
-				if(me.model.getFeatureProperty(modelIndex,me.columns[ci].name) === false) {
-					var propertyValue = "";
+				var propertyValue = "";
+				if (me.model.getFeatureProperty(modelIndex,me.columns[ci].name) !== false) {
+					propertyValue = me.model.getFeatureProperty(modelIndex,me.columns[ci].name);
-				else {
-					var propertyValue = me.model.getFeatureProperty(modelIndex,me.columns[ci].name);
 				var cellContent = '<span class="wfsFproperty">' + propertyValue + '</span>';
 				rowData.push(cellContent);
@@ -188,17 +186,20 @@
 		me.detailColumns = getDetailColumns(this.WFSConf);
 		//var buttonrow = $('#'+me.options.id +"buttonrow")
-		$('#' + me.options.id +"_table_wrapper").remove()
+		$('#' + me.options.id +"_table_wrapper").remove();
-		if(me.table != null){me.table.remove() }
-		me.table = $('<table class="display" id="'+ me.options.id +'_table"><thead><tr></tr></thead><tbody></tbody></table>');
+		if (me.table != null) {
+			me.table.remove();
+		me.table = $('<table class="display" id="' + me.options.id +
+			'_table"><thead><tr></tr></thead><tbody></tbody></table>');
 		$('#' + me.options.id).prepend(me.table);
 		//apply columns to table
 		//$("thead tr th",table).remove();
 		theads = "";
 		for(i in me.columns){
 			theads += "<th>"+ me.columns[i].label +"</th>";
@@ -217,7 +218,9 @@
 		//table.append(heads);
 		//table.append($("<tbody></tbody>"));
-		if (me.datatable != null){ me.datatable.remove();}
+		if (me.datatable != null){
+			me.datatable.remove();
 		// and clear all out everythuing wtf why is there
 		me.datatable = me.table.dataTable({
@@ -227,11 +230,7 @@
 		$(".resultdatatable").css("clear","both");
 		$(".resultdatatable table").css("width","95%");
 	// initialize new
 	me.model = new ResultGeometryListModel();
@@ -239,6 +238,4 @@
 	me.model.events.deleted.register();
 	me.model.events.updated.register();
 	me.model.events.cleared.register(clear_callback);
More information about the Mapbender_commits mailing list
