[Mapbender-commits] r5984 - trunk/mapbender/http/php
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Tue Apr 20 05:22:43 EDT 2010
Author: armin11
Date: 2010-04-20 05:22:42 -0400 (Tue, 20 Apr 2010)
New Revision: 5984
Added:
   trunk/mapbender/http/php/mod_UsageShow.php
   trunk/mapbender/http/php/mod_owsproxy_conf.php
have a tool to show the logged wms getmap requests to the owner of the services which are secured by mapbenders proxy function
Added: trunk/mapbender/http/php/mod_UsageShow.php
--- trunk/mapbender/http/php/mod_UsageShow.php	                        (rev 0)
+++ trunk/mapbender/http/php/mod_UsageShow.php	2010-04-20 09:22:42 UTC (rev 5984)
@@ -0,0 +1,195 @@
+<?php
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+#require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
+require_once(dirname(__FILE__)."/../../conf/mapbender.conf");
+require_once(dirname(__FILE__)."/../classes/class_administration.php");
+session_start();
+import_request_variables("PG");
+$con = db_connect($DBSERVER,$OWNER,$PW);
+db_select_db(DB,$con);
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
+<html>
+<head>
+<meta http-equiv="cache-control" content="no-cache">
+<meta http-equiv="pragma" content="no-cache">
+<meta http-equiv="expires" content="0">
+<?php
+echo '<meta http-equiv="Content-Type" content="text/html; charset='.CHARSET.'">';
+</head>
+<body>
+<?php
+$admin = new administration();
+//Test if ID was valid
+if ($_REQUEST['wmsid']) {
+	$wms_id = intval($_GET['wmsid']);
+else {
+	echo "Invalid WMS ID.";
+	die;
+//Test if userid was valid
+if ($_REQUEST['userid']) {
+	$userid = intval($_REQUEST['userid']);
+//else {
+//	echo "Invalid User ID.";
+//	die;
+//Test if User Id exists in db
+//Test if current User is Owner of the service
+//get owners of the wms:
+$wmsOwners = $admin->getOwnerByWms($wms_id);
+echo $wmsOwners;
+if (!(in_array($_SESSION['mb_user_id'], $wmsOwners))) {
+	echo "User with ID: ".$_SESSION['mb_user_id']." - You have no rights to see the requested pages!";
+	//echo "<br> You are: ".$admin->getOwnerByWms($wms_id);
+	die;
+else {
+	echo "OwnerID: ".$_SESSION['mb_user_id']."<br>";
+if (!isset($_REQUEST['userid'])){
+//List Users wich have used the service - read the log table
+$sql = "SELECT distinct fkey_mb_user_id, mb_user_name, mb_user_email, mb_user_phone from mb_proxy_log, mb_user ";
+$sql .= " WHERE fkey_wms_id = $1 AND fkey_mb_user_id = mb_user_id";
+#$sql = "SELECT upload_id, status, status_comment, timestamp_begin, timestamp_end, upload_url, updated FROM mb_monitor ";
+#$sql .= "WHERE fkey_wms_id = $1 AND NOT status = '-2' ORDER BY upload_id DESC";
+$v = array($wms_id);
+$t = array('i');
+$res = db_prep_query($sql,$v,$t);
+$cnt = 0;
+$str = "<span style='font-size:30'>Usage for WMS: </span><hr><br>\n";
+$str .= "<b>" . $wms_id . "</b><br>" . $admin->getWmsTitleByWmsId($wms_id) . "<br><br><br>\n";
+$str .= "<table cellpadding=10 cellspacing=0 border=0>";
+$str .= "<tr bgcolor='#dddddd'>";
+$str .= "<th align='left'>Index</th><th align='left'>ID</th><th align='left'>User Name</th><th align='left'>User Email</th>";
+$str .= "<th align='left'>User Phone</th>";
+$str .= "<th align='left'>Single requests</th></tr>";
+while ($row = db_fetch_array($res)) {
+	$str .= "\n\t\t<tr bgcolor='#e6e6e6'>";
+	$str .= "\n\t\t\t<td>".$cnt."</td>";
+	$UserId[$cnt] = db_result($res,$cnt,"fkey_mb_user_id");
+	$str .= "\n\t\t\t<td>".$UserId[$cnt]."</td>";
+	$UserName[$cnt] = db_result($res,$cnt,"mb_user_name");
+	$str .= "\n\t\t\t<td>".$UserName[$cnt]."</td>";
+	$UserEmail[$cnt] = db_result($res,$cnt,"mb_user_email");
+	$str .= "\n\t\t\t<td>".$UserEmail[$cnt]."</td>";
+	$UserPhone[$cnt] = db_result($res,$cnt,"mb_user_phone");
+	$str .= "\n\t\t\t<td>".$UserPhone[$cnt]."</td>";
+	#$timestamp_end = db_result($res,$cnt,"timestamp_end");
+	#$upload_url[$cnt] = db_result($res,$cnt,"upload_url");
+	#if ($status[$cnt] == '0' || $status[$cnt] == '1') {
+	#	$response_time[$cnt] = strval($timestamp_end-$timestamp_begin) . " s";
+	#else {
+	#	$response_time[$cnt] = "n/a";
+	$str .= "<td><input type=button value='details' onclick=\"var newWindow = window.open('../php/mod_UsageShow.php?wmsid=".$_REQUEST['wmsid']."&userid=".$UserId[$cnt]."','details','width=500,height=700,scrollbars');newWindow.href.location='Usage of Service: ".$wms_id."'\"></td>";
+	$str .= "</tr>";
+	$cnt++;
+$str .= "\n\t</table>\n\t";
+else {
+//UserID was set
+//Get infos about specific user
+$sql = "SELECT mb_user_id, mb_user_name, mb_user_email, mb_user_phone from mb_user ";
+$sql .= " WHERE mb_user_id = $1";
+$v = array($_REQUEST['userid']);
+$t = array('i','i');
+$row = db_fetch_array($res);
+//show usage of this user
+$sql = "SELECT count(*) as sumrequests, sum(pixel) as sumpixel , max(proxy_log_timestamp) as lastaccess FROM mb_proxy_log where fkey_mb_user_id=$2 AND fkey_wms_id=$1";
+//$sql .= " WHERE fkey_wms_id = $1 AND fkey_mb_user_id = mb_user_id";
+$v = array($wms_id,$_REQUEST['userid']);
+$sumrequests = $row["sumrequests"];
+$sumpixel = $row["sumpixel"];
+$lastAccess = $row["lastaccess"];
+//$sumpixel=0;
+$str = "<span style='font-size:30'>Usage of Secured WMS: </span><hr><br>\n";
+$str .= "<hr><b>for User: ".$row['mb_user_name']."</b><br><br>";
+$str .= "UserID: ".$_REQUEST['userid']."<br>UserEmail: ".$row['mb_user_email']."<br>UserPhone: ".$row['mb_user_phone']."<br>Last Access: <b>".$lastAccess."</b><br>";
+//Maximum requests
+$maxRequests = 50;
+//case showSingleRequests
+if (($_REQUEST['requests']) & ($_REQUEST['requests']) == 1 ) {
+	//show usage of this user
+	$sql = "SELECT proxy_log_timestamp, pixel, request FROM mb_proxy_log where fkey_mb_user_id=$2 AND fkey_wms_id=$1 ORDER BY proxy_log_timestamp DESC LIMIT ".$maxRequests;
+	$v = array($wms_id,$_REQUEST['userid']);
+	$t = array('i','i');
+	$res = db_prep_query($sql,$v,$t);
+	$cnt=0;
+	$str .= "<hr><br><b>Last ".$maxRequests." Requests:</b><br>";
+	$str .= "<table cellpadding=10 cellspacing=0 border=0>";
+	$str .= "<tr bgcolor='#dddddd'>";
+	$str .= "<th align='left'>timestamp</th><th align='left'>requested pixels</th><th align='left'>GetMap Request</th></tr>";
+	while ($row = db_fetch_array($res)) {
+		$timestamp[$cnt] = db_result($res,$cnt,"proxy_log_timestamp");
+		$str .= "\n\t\t\t<td>".$timestamp[$cnt]."</td>";
+		$pixels[$cnt] = db_result($res,$cnt,"pixel");
+		//$sumpixel=$sumpixel+$pixels[$cnt];
+		$str .= "\n\t\t\t<td>".$pixels[$cnt]."</td>";
+		$request[$cnt] = db_result($res,$cnt,"request");
+		$str .= "\n\t\t\t<td><input type=button value='Show Map' onclick=\"var newWindow = window.open('".$request[$cnt]."','GetMap','width=500,height=700,scrollbars');newWindow.href.location='Get Map from: ".$timestamp[$cnt]."'\"></td>";
+		$str .= "</tr>";
+		$cnt++;
+$str .= "<hr><b>Total Requests: ".$sumrequests."</b><br><br>";
+$sumpixel=$sumpixel/1000000;
+$str .= "<hr><b>Total MegaPixel: ".$sumpixel."</b><br><br>";
+if (!$_REQUEST['requests']) {
+		$str .= "<input type=button value='Show last ".$maxRequests." Requests' onclick=\"var newWindow = window.open('../php/mod_UsageShow.php?wmsid=".$_REQUEST['wmsid']."&userid=".$_REQUEST["userid"]."&requests=1','details','width=500,height=700,scrollbars');newWindow.href.location='Show Requests: ".$timestamp[$cnt]."'\">";
+echo $str;
+</body></html>
\ No newline at end of file
Modified: trunk/mapbender/http/php/mod_owsproxy_conf.php
--- trunk/mapbender/http/php/mod_owsproxy_conf.php	2010-04-20 08:55:53 UTC (rev 5983)
+++ trunk/mapbender/http/php/mod_owsproxy_conf.php	2010-04-20 09:22:42 UTC (rev 5984)
@@ -15,7 +15,7 @@
-# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
 include(dirname(__FILE__)."/../php/mb_validateSession.php");
 include(dirname(__FILE__)."/../classes/class_administration.php");
@@ -162,6 +162,9 @@
 echo "<td>";
 echo "Price(cent/Mpixel)";
 echo "</td>";
+echo "<td>";
+echo "Show detailed Usage";
+echo "</td>";
 echo "</tr>";
 for($i=0; $i<count($ownwms); $i++){
 	#read out current values in db
@@ -216,7 +219,11 @@
 	echo "</td>";
+if($status_log == 1){
+echo "<td><input type=button value='Show Usage' onclick=\"var newWindow = window.open('../php/mod_UsageShow.php?wmsid=".$ownwms[$i]."','wms','width=800,height=700,scrollbars');newWindow.href.location='Usage of Service: ".$wms_id."'\"></td>";
 echo "</tr>";
 echo "</table>";
@@ -229,4 +236,4 @@
 </table>
 </form>
 </body>
-</html>
+</html>
More information about the Mapbender_commits mailing list
