[Mapbender-commits] r5998 - in trunk/mapbender/http: classes javascripts php
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Thu Apr 22 05:45:47 EDT 2010
Author: armin11
Date: 2010-04-22 05:45:43 -0400 (Thu, 22 Apr 2010)
New Revision: 5998
Added:
   trunk/mapbender/http/javascripts/mod_deleteWfsConf_client.html
   trunk/mapbender/http/php/mod_deleteWfsConf_server.php
   trunk/mapbender/http/classes/class_metadata_new.php
   trunk/mapbender/http/php/mod_callMetadata.php
   trunk/mapbender/http/php/mod_deleteWFS.php
   trunk/mapbender/http/php/mod_metadataWrite.php
   trunk/mapbender/http/php/mod_updateWMS.php
some new functions from geoportal.rlp
Modified: trunk/mapbender/http/classes/class_metadata_new.php
--- trunk/mapbender/http/classes/class_metadata_new.php	2010-04-21 15:37:42 UTC (rev 5997)
+++ trunk/mapbender/http/classes/class_metadata_new.php	2010-04-22 09:45:43 UTC (rev 5998)
@@ -1,1259 +1,890 @@
 <?php
-#Script to call this class: http://www.geoportal.rlp.de/mapbender/php/mod_callMetadata.php
-#Class for getting results out of the mapbender service registry
-#Resulttypes: WMS, WMS-Layer, (WFS), WFS-Featurtyps, WFS-Conf, WMC, GeoRSS-Feeds, ...
-#Possible filters: registrating organizations, time, bbox (fully inside, intersects, fully outside), ISO Topic Categories, INSPIRE themes, INSPIRE: keywords, classification of data/service ... - maybe relevant for the german broker not for one instance, quality and actuality (maybe spatial and temporal), bbox, deegree of conformity with ir, access and use constraints, responsible parties - maybe one is enough? We must have a look at the INSPIRE Metadata IR
-#Metadata we need to fullfil the demands of INSPIRE:
-#1. INSPIRE conformity classification for WMS/WFS/WCS
-#2. Temporal Extents at WMS/WMS-Layer/WFS/WFS-Featuretype levels - for datasets if demanded - til now there is no demand defined in the guidance-paper for metadata ir
-#3. Classified access and use contraints - which classes? - Check IR Data Sharing and IR Metadata
-#4.
-#Every ressource which should be send to INSPIRE can be filtered - but is not neccessary for a standardized approach
-#Another problem is the ranking of the different ressources. The ranking should be homogeneus.
-#Till now we rank the using of WMS Layers when Caps are requested and when s.o. load one layer into the geoportal.
-#The same things have to be done for the wfs-conf, wmc and georssfeeds
-#The searching for metadata should be parallel done. We need different classes for doing the search. They should be requested by one central class (class_metadata.php).
-#Classes for filtering after the results have been send to the portal:
-#1. ISO Topic Categories
-#2. INSPIRE Themes
-#3. Access and use classification
-#4. departments which provides the ressources - we need the new concept for the administration of this departments - store the addresses in the group table and give the relation - originating group in table mb_user_mb_group
-#Cause we have a authorization layer, we need the id of the requesting user which is defined in the session. If no session is set, it should be the anonymous user of the portal.
-#We need a parameter for internationalization - it should be send with the search request! Some of the Classes can be provided with different languages.
-#WMC and GeoRSS-Feeds have no or a to complex authorization info - maybe we need to test if wmc consists of info which is fully or only partually available to the anonymous user.
+#http://www.geoportal.rlp.de/mapbender/php/mod_callMetadata.php?searchText=sozial&outputFormat=json&resultTarget=web&searchResources=wfs
+#http://www.geoportal.rlp.de/mapbender/php/mod_callMetadata.php?searchText=sozial+schwanger&outputFormat=json&resultTarget=web&searchResources=wfs&registratingDepartments=72
+#http://www.geoportal.rlp.de/mapbender/php/mod_callMetadata.php?searchText=sozial&outputFormat=json&resultTarget=web&searchResources=wms&
+#http://www.geoportal.rlp.de/mapbender/php/mod_callMetadata.php?searchText=niedersachsen&outputFormat=json&resultTarget=web&searchResources=wms&maxResults=50
+#http://www.geoportal.rlp.de/mapbender/php/mod_callMetadata.php?searchId=wal&searchText=wald&outputFormat=json&resultTarget=web&searchResources=wms&maxResults=10
+#http://www.geoportal.rlp.de/mapbender/php/mod_callMetadata.php?searchId=test&searchText=e,w&outputFormat=json&registratingDepartments=44,33,29,30,31,35,40,61,101,87&languageCode=en&resultTarget=web&searchResources=wms&maxResults=10
+#http://www.geoportal.rlp.de/mapbender/php/mod_callMetadata.php?searchId=45&searchText=e&outputFormat=json&registratingDepartments=44,33,29,30,31,35,40,61,101,87&languageCode=en&resultTarget=debug&searchResources=wms&maxResults=10&searchPages=1&isoCategories=10
+#http://www.geoportal.rlp.de/mapbender/php/mod_callMetadata.php?searchId=45&searchText=e&outputFormat=json&registratingDepartments=44,33,29,30,31,35,40,61,101,87&languageCode=en&resultTarget=debug&searchResources=wms&maxResults=20&searchPages=1&isoCategories=10,5
+#http://www.geoportal.rlp.de/mapbender/php/mod_callMetadata.php?searchId=wa&searchText=e&outputFormat=json&languageCode=de&resultTarget=debug&searchResources=wms&maxResults=10&isoCategories=10,5&registratingDepartments=44,31
+#http://www.geoportal.rlp.de/mapbender/php/mod_callMetadata.php?searchId=wa&searchText=e&outputFormat=json&languageCode=de&resultTarget=debug&searchResources=wms&maxResults=5&registratingDepartments=44,31&inspireThemes=11&isoCategories=5,10
+#http://www.geoportal.rlp.de/mapbender/php/mod_callMetadata.php?searchId=wa&searchText=e&outputFormat=json&languageCode=de&resultTarget=debug&searchResources=wms&maxResults=5&registratingDepartments=44,31&inspireThemes=11&isoCategories=5,10&searchBbox=7,48,9,51
+#http://www.geoportal.rlp.de/mapbender/php/mod_callMetadata.php?searchId=wa&searchText=e&outputFormat=json&languageCode=de&resultTarget=debug&searchResources=wms&maxResults=99&registratingDepartments=44,31,52&inspireThemes=11&isoCategories=5,10&searchBbox=7,48,9,51&regTimeBegin=2001-12-24&regTimeEnd=2020-10-10
+#http://www.geoportal.rlp.de/mapbender/php/mod_callMetadata.php?searchId=wa&outputFormat=json&languageCode=de&resultTarget=debug&searchResources=wms&maxResults=99&registratingDepartments=44,31,52&inspireThemes=11&isoCategories=5,10&searchBbox=7,48,9,51&regTimeBegin=2001-12-24&regTimeEnd=2020-10-10
 require_once(dirname(__FILE__)."/../../conf/mapbender.conf");
-require_once(dirname(__FILE__)."/class_administration.php");
-require_once(dirname(__FILE__)."/class_mb_exception.php");
-require_once(dirname(__FILE__)."/class_json.php");
+require_once(dirname(__FILE__)."/../../conf/geoportal.conf");
+require_once(dirname(__FILE__)."/../classes/class_metadata_new.php");
+require_once(dirname(__FILE__)."/../classes/class_json.php");
+session_start();
+//initialize request parameters:
+$searchId = "dummysearch";
+$searchText = "e";
+#$registratingDepartments = "33,29,30,31,35,40,61,101,87,44";
+$registratingDepartments = NULL;
+#$isoCategories = "1,2,3";
+$isoCategories = NULL;
+$inspireThemes = NULL;
+$customCategories = NULL;
+$timeBegin = NULL;
+$timeEnd = NULL;
+$regTimeBegin = NULL;
+$regTimeEnd = NULL;
+$maxResults = 5;
+#$searchBbox = "-180.0,-90.0,180.0,90.0";
+$searchBbox = NULL;
+$searchTypeBbox = "intersects"; //outside / inside
+$accessRestrictions = "false";
+$languageCode = "de";
+$outputFormat = 'json';
+#$searchResources = "wms,wfs,wmc,georss";
+#$searchResources = "wms";
+$searchPages = "1";
+$resultTarget = "debug";
+$searchEPSG = "EPSG:31466";
+$classJSON = new Mapbender_JSON;
+#$tempFolder = "/tmp";
+$tempFolder = TMPDIR;
+$orderBy = "rank"; //rank or title or id
+$hostName = $_SERVER['HTTP_HOST'];
-//definition for the things which are common to all kind of metadata ressources
+//read the whole query string:
+$searchURL = $_SERVER['QUERY_STRING'];
-class searchMetadata {
-	var $userId;
-	var $searchId;
-	var $searchText;
-	var $registratingDepartments;
-	var $isoCategories;
-	var $inspireThemes;
-	var $customCategories;
-	var $timeBegin;
-	var $timeEnd;
-	var $regTimeBegin;
-	var $regTimeEnd;
-	var $maxResults;
-	var $searchBbox;
-	var $searchTypeBbox;
-	var $accessRestrictions;
-	var $languageCode;
-	var $searchStartTime;
-	var $searchView;
-	var $searchURL;
-	var $searchEPSG;
-	var $searchResources;
-	var $searchPages;
-	var $outputFormat;
-	var $resultTarget;
-	var $tempFolder;
-	var $orderBy;
+//control if some request variables are not set and set them explicit to NULL
-	function __construct($userId, $searchId, $searchText, $registratingDepartments, $isoCategories, $inspireThemes, $timeBegin, $timeEnd, $regTimeBegin, $regTimeEnd, $maxResults, $searchBbox, $searchTypeBbox, $accessRestrictions, $languageCode, $searchEPSG, $searchResources, $searchPages, $outputFormat, $resultTarget, $searchURL, $customCategories){
-		$this->userId = (integer)$userId;
-		$this->searchId = $searchId;
-		$this->searchText = $searchText;
-		$this->registratingDepartments = $registratingDepartments; //array with ids of the registrating groups in the mb database
-		$this->registratingDepartmentsArray = explode(",",$this->registratingDepartments);
-		$this->isoCategories = $isoCategories;
-		$this->inspireThemes = $inspireThemes;
-		$this->customCategories = $customCategories;
-		$this->timeBegin = $timeBegin;
-		$this->timeEnd = $timeEnd;
-		$this->regTimeBegin = $regTimeBegin;
-		$this->regTimeEnd = $regTimeEnd;
-		$this->maxResults = (integer)$maxResults;
-		$this->searchBbox = $searchBbox;
-		$this->searchTypeBbox = $searchTypeBbox;
-		$this->accessRestrictions = $accessRestrictions;
-		$this->languageCode = $languageCode;
-		$this->searchEPSG = $searchEPSG;
-		$this->searchResources = $searchResources;
-		$this->searchPages = $searchPages;
-		$this->outputFormat = $outputFormat;
-		$this->resultTarget = $resultTarget;
-		$this->searchURL = $searchURL;
-		$this->tempFolder = "/tmp"; //TODO define another path - maybe the one which is given in mapbender.conf
-		if ($this->outputFormat == 'json'){
-			$this->json = new Mapbender_JSON;
-		$this->accessableLayers = NULL;
-		//set a time to find time consumers
-		$this->searchStartTime = $this->microtime_float();
-		//Defining of the different database categories
-		$this->resourceClassifications = array();
-		$this->resourceClassifications[0]['title'] = "ISO 19115"; //TODO: define the translations somewhere? - This is done in call_metadata.php before. Maybe we can get them from there? - It will be shown in the rightside categories table
-		$this->resourceClassifications[0]['tablename'] = 'md_topic_category';
-		$this->resourceClassifications[0]['requestName'] = 'isoCategories';
-		$this->resourceClassifications[0]['id_wms'] = 'layer_id';
-		$this->resourceClassifications[0]['id_wfs'] = 'featuretype_id';
-		$this->resourceClassifications[0]['relation_wms'] = 'layer_md_topic_category';
-		$this->resourceClassifications[0]['relation_wfs'] = 'featuretype_md_topic_category';//TODO: define this in mapbender
-		$this->resourceClassifications[1]['title'] = "INSPIRE"; //TODO: define the translations somewhere? - This is done in call_metadata.php before. Maybe we can get them from there? - It will be shown in the rightside categories table
-		$this->resourceClassifications[1]['tablename'] = 'inspire_category';
-		$this->resourceClassifications[1]['requestName'] = 'inspireThemes';
-		$this->resourceClassifications[1]['id_wms'] = 'layer_id';
-		$this->resourceClassifications[1]['id_wfs'] = 'featuretype_id';
-		$this->resourceClassifications[1]['relation_wms'] = 'layer_inspire_category';
-		$this->resourceClassifications[1]['relation_wfs'] = 'featuretype_inspire_category';//TODO: define this in mapbender
+$checkForNullRequests = array("registratingDepartments","isoCategories","inspireThemes","customCategories","regTimeBegin","regTimeEnd","timeBegin","timeEnd","searchBbox","searchTypeBbox","searchResources","orderBy","hostName");
-		$this->resourceClassifications[2]['title'] = "Custom"; //TODO: define the translations somewhere? - This is done in call_metadata.php before. Maybe we can get them from there? - It will be shown in the rightside categories table
-		$this->resourceClassifications[2]['tablename'] = 'custom_category';
-		$this->resourceClassifications[2]['requestName'] = 'customCategories';
-		$this->resourceClassifications[2]['id_wms'] = 'layer_id';
-		$this->resourceClassifications[2]['id_wfs'] = 'featuretype_id';
-		$this->resourceClassifications[2]['relation_wms'] = 'layer_custom_category';
-		$this->resourceClassifications[2]['relation_wfs'] = 'featuretype_custom_category';//TODO: define this in mapbender
+for($i=0; $i < count($checkForNullRequests); $i++){
+	if (!$_REQUEST[$checkForNullRequests[$i]] or $_REQUEST[$checkForNullRequests[$i]] == 'false' or $_REQUEST[$checkForNullRequests[$i]] == 'undefined') {
+		$_REQUEST[$checkForNullRequests[$i]] = "";
+		$searchURL = delTotalFromQuery($checkForNullRequests[$i],$searchURL);
+//Read out request Parameter:
+if (isset($_REQUEST["searchId"]) & $_REQUEST["searchId"] != "") {
+	//gernerate md5 representation, cause the id is used as a filename later on! - no validation needed
+	$searchId = md5($_REQUEST["searchId"]);
+if (isset($_REQUEST["searchText"]) & $_REQUEST["searchText"] != "") {
+	$test="(SELECT\s[\w\*\)\(\,\s]+\sFROM\s[\w]+)| (UPDATE\s[\w]+\sSET\s[\w\,\'\=]+)| (INSERT\sINTO\s[\d\w]+[\s\w\d\)\(\,]*\sVALUES\s\([\d\w\'\,\)]+)| (DELETE\sFROM\s[\d\w\'\=]+)";
+	//validate to csv integer list
+	$testMatch = $_REQUEST["searchText"];
+	$pattern = '/(\%27)|(\')|(\-\-)|(\")|(\%22)/';
+ 	if (preg_match($pattern,$testMatch)){
+		echo 'searchText: <b>'.$testMatch.'</b> is not valid.<br/>';
+		die();
+	$searchText = $testMatch;
+	$testMatch = NULL;
+if (isset($_REQUEST["registratingDepartments"]) & $_REQUEST["registratingDepartments"] != "") {
+	$testMatch = $_REQUEST["registratingDepartments"];
+	$pattern = '/^[\d,]*$/';
+ 	if (!preg_match($pattern,$testMatch)){
+		echo 'registratingDepartments: <b>'.$testMatch.'</b> is not valid.<br/>';
+		die();
+	$registratingDepartments = $testMatch;
+if (isset($_REQUEST["isoCategories"]) & $_REQUEST["isoCategories"] != "") {
+	$testMatch = $_REQUEST["isoCategories"];
+		echo 'isoCategories: <b>'.$testMatch.'</b> is not valid.<br/>';
+		die();
+	$isoCategories = $testMatch;
+if (isset($_REQUEST["inspireThemes"]) & $_REQUEST["inspireThemes"] != "") {
+	$testMatch = $_REQUEST["inspireThemes"];
+		echo 'inspireThemes: <b>'.$testMatch.'</b> is not valid.<br/>';
+		die();
+	$inspireThemes = $testMatch;
-		//Defining of the different result categories
-		$this->resourceCategories = array();
-		$this->resourceCategories[0]['name'] = 'WMS';
-		$this->resourceCategories[1]['name'] = 'WFS';
-		$this->resourceCategories[2]['name'] = 'WMC';
-		$this->resourceCategories[3]['name'] = 'GeoRSS';
-		switch($this->languageCode){
-        		case 'de':
-                	$this->resourceCategories[0]['name2show'] = 'Darstellungsdienste';
-			$this->resourceCategories[1]['name2show'] = 'Such- und Downloaddienste';
-			$this->resourceCategories[2]['name2show'] = 'Kartenzusammenstellungen';
-			$this->resourceCategories[3]['name2show'] = 'Geokodierte Newsfeeds';
-       			break;
-        		case 'en':
-               		$this->resourceCategories[0]['name2show'] = 'Viewingservices';
-			$this->resourceCategories[1]['name2show'] = 'Search- and Downloadservices';
-			$this->resourceCategories[2]['name2show'] = 'Combined Maps';
-			$this->resourceCategories[3]['name2show'] = 'Geocodet Newsfeeds';
-        		break;
-        		case 'fr':
-       			break;
-     			default:
-		//not needed til now - maybe usefull for georss output
-		if ($this->outputFormat == "xml") {
-			//Initialize XML documents
-			if (isset($this->searchResources) & strtolower($this->searchResources) === "wms") {
-				$this->wmsDoc = new DOMDocument('1.0');
-			if (isset($this->searchResources) & strtolower($this->searchResources) === "wfs") {
-				$this->wfsDoc = new DOMDocument('1.0');
-				$this->generateWFSMetadata($this->wfsDoc);
-			if (isset($this->searchResources) & strtolower($this->searchResources) === "wmc") {
-				$this->wmcDoc = new DOMDocument('1.0');
-			if (isset($this->searchResources) & strtolower($this->searchResources) === "georss") {
-				$this->georssDoc = new DOMDocument('1.0');
-		if ($this->outputFormat === "json") {
-				$this->searchView = 'search_wfs_view';
-				$this->orderBy = " ORDER BY wfs_id,featuretype_id,wfs_conf_id ";
-				$this->resourceClasses = NULL;
-				$this->searchView = 'wms_search_table_test';
-				$this->orderBy = " ORDER BY load_count DESC";
-				$this->resourceClasses = array(0,1,2);
-				$this->generateWMSMetadata($this->wmsDoc);
+if (isset($_REQUEST["customCategories"]) & $_REQUEST["customCategories"] != "") {
+	$testMatch = $_REQUEST["customCategories"];
+		echo 'customCategories: <b>'.$testMatch.'</b> is not valid.<br/>';
+		die();
+	$customCategories = $testMatch;
+if (isset($_REQUEST["timeBegin"]) & $_REQUEST["timeBegin"] != "") {
+	//validate to iso date format YYYY-MM-DD
+	$testMatch = $_REQUEST["timeBegin"];
+	$pattern = '/^(19|20)[0-9]{2}[-](0[1-9]|1[012])[-](0[1-9]|[12][0-9]|3[01])$/';
+		echo 'timeBegin: <b>'.$testMatch.'</b> is not valid.<br/>';
+		die();
+	$timeBegin = $testMatch;
+if (isset($_REQUEST["timeEnd"]) & $_REQUEST["timeEnd"] != "") {
+	$testMatch = $_REQUEST["timeEnd"];
+		echo 'timeEnd: <b>'.$testMatch.'</b> is not valid.<br/>';
+		die();
+	$timeEnd = $testMatch;
+if (isset($_REQUEST["regTimeBegin"]) & $_REQUEST["regTimeBegin"] != "") {
+	$testMatch = $_REQUEST["regTimeBegin"];
+		echo 'regTimeBegin: <b>'.$testMatch.'</b> is not valid.<br/>';
+		die();
+	$regTimeBegin = $testMatch;
+if (isset($_REQUEST["regTimeEnd"]) & $_REQUEST["regTimeEnd"] != "") {
+	$testMatch = $_REQUEST["regTimeEnd"];
+		echo 'regTimeEnd: <b>'.$testMatch.'</b> is not valid.<br/>';
+		die();
+	$regTimeEnd = $testMatch;
+if (isset($_REQUEST["maxResults"]) & $_REQUEST["maxResults"] != "") {
+	//validate integer to 100 - not more
+	$testMatch = $_REQUEST["maxResults"];
+	//give max 99 entries - more will be to slow
+	$pattern = '/^([0-9]{0,1})([0-9]{1})$/';
+		echo 'maxResults: <b>'.$testMatch.'</b> is not valid.<br/>';
+		die();
+	$maxResults = $testMatch;
+if (isset($_REQUEST["searchBbox"]) & $_REQUEST["searchBbox"] != "") {
+	//validate to float/integer
+	$testMatch = $_REQUEST["searchBbox"];
+	//$pattern = '/^[-\d,]*$/';
+	$pattern = '/^[-+]?([0-9]*\.[0-9]+|[0-9]+)*$/';
+	$testMatchArray = explode(',',$testMatch);
+ 	if (count($testMatchArray) != 4) {
+		echo 'searchBbox: <b>'.$testMatch.'</b> has a wrong amount of entries.<br/>';
+		die();
-	private function microtime_float() {
-    		list($usec, $sec) = explode(" ", microtime());
-    		return ((float)$usec + (float)$sec);
+	for($i=0; $i<count($testMatchArray);$i++){
+		if (!preg_match($pattern,$testMatchArray[$i])){
+			echo 'searchBbox: <b>'.$testMatchArray[$i].'</b> is not a valid coordinate value.<br/>';
+			die();
-	private function generateXMLHead($xmlDoc) {
-		$xmlDoc->encoding = CHARSET;
-		$result = $xmlDoc->createElement("result");
-		$xmlDoc->appendChild($result);
-		//Result Count
-		$overLimit = $xmlDoc->createElement("overLimit");
-		$result->appendChild($overLimit);
-		//$tr_text = $xmlDoc->createTextNode($this->isOverLimit);
-		$tr_text = $xmlDoc->createTextNode("really?");
-		$overLimit->appendChild($tr_text);
-		$rd = $xmlDoc->createElement("redirect");
-		$result->appendChild($rd);
-		$trd = $xmlDoc->createTextNode("not yet ready...");
-		$rd->appendChild($trd);
-	private function generateXMLFoot($xmlDoc){
-		$results = $xmlDoc->getElementsByTagName("result");
-		foreach ($results as $result) {
-			$result->appendChild($ready);
+	$searchBbox = $testMatch;
+if (isset($_REQUEST["searchTypeBbox"]) & $_REQUEST["searchTypeBbox"] != "") {
+	//validate to inside / outside - TODO implement other ones than intersects which is default
+	$testMatch = $_REQUEST["searchTypeBbox"];
+ 	if (!($testMatch == 'inside' or $testMatch == 'outside' or $testMatch == 'intersects')){
+		echo 'searchTypeBbox: <b>'.$testMatch.'</b> is not valid.<br/>';
+		die();
+	#$searchTypeBbox = $testMatch; //TODO activate this
+if (isset($_REQUEST["accessRestrictions"]) & $_REQUEST["accessRestrictions"] != "") {
+	//validate to ?
+	#TODO implement me //$accessRestrictions = $_REQUEST["accessRestrictions"];
+if (isset($_REQUEST["languageCode"]) & $_REQUEST["languageCode"] != "") {
+	//validate to de, en, fr
+	$testMatch = $_REQUEST["languageCode"];
+ 	if (!($testMatch == 'de' or $testMatch == 'en' or $testMatch == 'fr')){
+		echo 'languageCode: <b>'.$testMatch.'</b> is not valid.<br/>';
+		die();
+	$languageCode = $testMatch;
+if (isset($_REQUEST["outputFormat"]) & $_REQUEST["outputFormat"] != "") {
+	$testMatch = $_REQUEST["outputFormat"];
+ 	if (!($testMatch == 'json' or $testMatch == 'georss')){
+		echo 'outputFormat: <b>'.$testMatch.'</b> is not valid.<br/>';
+		die();
+	$outputFormat = $testMatch;
+if (isset($_REQUEST["hostName"]) & $_REQUEST["hostName"] != "") {
+	$testMatch = $_REQUEST["hostName"];
+ 	if (!($testMatch == 'www.geoportal.rlp' or $testMatch == 'www.geoportal.rlp.de' or $testMatch == 'geoportal.rlp' or $testMatch == '10.7.101.165' or $testMatch == 'localhost:16580' or $testMatch == 'localhost')){
+		echo 'hostName: <b>'.$testMatch.'</b> is not valid.<br/>';
+		die();
+	$hostName = $testMatch;
+if (isset($_REQUEST["orderBy"]) & $_REQUEST["orderBy"] != "") {
+	$testMatch = $_REQUEST["orderBy"];
+ 	if (!($testMatch == 'rank' or $testMatch == 'title' or $testMatch == 'id')){
+		echo 'orderBy: <b>'.$testMatch.'</b> is not valid.<br/>';
+		die();
+	$orderBy = $testMatch;
+}// else {
+//$orderBy= 'rank';
+if (isset($_REQUEST["searchResources"]) & $_REQUEST["searchResources"] != "") {
+	//validate to wms,wfs,wmc,georss
+	$testMatch = $_REQUEST["searchResources"];
+	#$pattern = '/^(19|20)[0-9]{2}[-](0[1-9]|1[012])[-](0[1-9]|[12][0-9]|3[01])$/';
+	$countSR = count(explode(',',$testMatch));
+ 	if (!($countSR >= 1 && $countSR <= 4)){
+		echo 'searchResources: <b>'.$testMatch.'</b> count of requested resources out of sync.<br/>';
+		die();
+ 	} else {
+		$testArray = explode(',',$testMatch);
+		for($i=0; $i<count($testArray);$i++){
+			if (!($testArray[$i] == 'wms' or $testArray[$i] == 'wfs' or $testArray[$i] == 'wmc' or $testArray[$i] == 'georss')) {
+			echo 'searchResources: <b>'.$testMatch.'</b>at least one of them does not exists!<br/>';
+			die();
+		unset($i);
-	private function flipDiagonally($arr) {
-    		$out = array();
-    		foreach ($arr as $key => $subarr) {
-      			foreach ($subarr as $subkey => $subvalue) {
-        			$out[$subkey][$key] = $subvalue;
-   		return $out;
+	$searchResources = $testMatch;
+if (isset($_REQUEST["searchPages"]) & $_REQUEST["searchPages"] != "") {
+	//validate to csv integer list with dimension of searchResources list
+	$testMatch = $_REQUEST["searchPages"];
+	$pattern = '/^[-\d,]*$/';
+		echo 'searchPages: <b>'.$testMatch.'</b> is not valid.<br/>';
+		die();
+	if (count(explode(',',$testMatch)) != count(explode(',',$searchResources))) {
+		echo 'searchPages: <b>'.$testMatch.'</b> has a wrong amount of entries.<br/>';
+		die();
+	$searchPages = $testMatch;
+#$searchPages = $_REQUEST["searchPages"];
+	#$searchPages = split(',',$searchPages);
+if (isset($_REQUEST["resultTarget"]) & $_REQUEST["resultTarget"] != "") {
+	//validate to web,debug,file
+	$testMatch = $_REQUEST["resultTarget"];
+ 	if (!($testMatch == 'web' or $testMatch == 'debug' or $testMatch == 'file')){
+		echo 'resultTarget: <b>'.$testMatch.'</b> is not valid.<br/>';
+		die();
+	$resultTarget = $testMatch;
-	private function generateWFSMetadataJSON($res, $n) {
-		//initialize object
-		$this->wfsJSON = new stdClass;
-		$this->wfsJSON->wfs = (object) array(
-				'md' => (object) array(
-					'nresults' => $n,
-					'p' => $this->searchPages,
-					'rpp' => $this->maxResults
-				'srv' => array()
-		//read out records
-		$serverCount = 0;
-		$wfsMatrix = db_fetch_all($res);
-		//sort result for accessing the right services
-		$wfsMatrix = $this->flipDiagonally($wfsMatrix);
-		//TODO check if order by db or order by php is faster!
-		#array_multisort($wfsMatrix['wfs_id'], SORT_ASC,$wfsMatrix['featuretype_id'], SORT_ASC,$wfsMatrix['wfs_conf_id'], SORT_ASC); //have some problems - the database version is more stable
-		#print_r($wfsMatrix);
-		//read out first server entry - maybe this a little bit timeconsuming TODO
-		$j = 0; //count identical wfs_id => double featuretype
-		$l = 0; //index featuretype and or modul per wfs
-		$m = 0; //index modul per featuretype
-		for($i=0; $i<count($wfsMatrix);$i++){
-				$this->wfsJSON->wfs->srv[$i-$j]->id = $wfsMatrix[$i]['wfs_id'];
-				$this->wfsJSON->wfs->srv[$i-$j]->title = $wfsMatrix[$i]['wfs_title'];
-				$this->wfsJSON->wfs->srv[$i-$j]->abstract = $wfsMatrix[$i]['wfs_abstract'];
-				$this->wfsJSON->wfs->srv[$i-$j]->date = date("d.m.Y",$wfsMatrix[$i]['wfs_timestamp']);
-				$this->wfsJSON->wfs->srv[$i-$j]->respOrg = $wfsMatrix[$i]['mb_group_name'];
-				$this->wfsJSON->wfs->srv[$i-$j]->mdLink = $_SERVER['HOSTNAME']."/mapbender/x_geoportal/showWFSMetadata.php?id=".$wfsMatrix[$i]['wfs_id'];
-				$spatialSource = "";
-				$stateOrProvince = $wfsMatrix[$i]['administrativearea'];
-				if ($stateOrProvince == "NULL" || $stateOrProvince == "") {
-					$spatialSource = $wfsMatrix[$i]['country'];
-				} else {
-					$spatialSource = $wfsMatrix[$i]['administrativearea'];
-				$this->wfsJSON->wfs->srv[$i-$j]->iso3166 = $spatialSource;
-				$this->wfsJSON->wfs->srv[$i-$j]->tou = $wfsMatrix[$i]['termsofuse'];
-				//TODO check the field accessconstraints - which should be presented?
-				$this->wfsJSON->wfs->srv[$i-$j]->status = NULL; //$wfsMatrix[$i][''];
-				$this->wfsJSON->wfs->srv[$i-$j]->avail = NULL; //$wfsMatrix[$i][''];
-				$this->wfsJSON->wfs->srv[$i-$j]->logged = NULL; //$wfsMatrix[$i][''];
-				$this->wfsJSON->wfs->srv[$i-$j]->price = NULL; //$wfsMatrix[$i][''];
-				$this->wfsJSON->wfs->srv[$i-$j]->nwaccess = NULL; //$wfsMatrix[$i][''];
-				$this->wfsJSON->wfs->srv[$i-$j]->bbox = array(-180.0,-90.0,180.0,90.0); //$wfsMatrix[$i][''];
-				//if featuretype hasn't been created - do it
-				if (!isset($this->wfsJSON->wfs->srv[$i-$j]->ftype)) {
-					$this->wfsJSON->wfs->srv[$i-$j]->ftype = array();
-				//fill in featuretype infos
-				$this->wfsJSON->wfs->srv[$i-$j]->ftype[$l-$m]->id = (integer)$wfsMatrix[$i]['featuretype_id'];
-				$this->wfsJSON->wfs->srv[$i-$j]->ftype[$l-$m]->title = $wfsMatrix[$i]['featuretype_title'];
-				$this->wfsJSON->wfs->srv[$i-$j]->ftype[$l-$m]->abstract = $wfsMatrix[$i]['featuretype_abstract'];
-				$this->wfsJSON->wfs->srv[$i-$j]->ftype[$l-$m]->mdLink = $_SERVER['HOST']."/mapbender/x_geoportal/showWFeatureTypeMetadata.php?id=".$wfsMatrix[$i]['featuretype_id'];
-				$this->wfsJSON->wfs->srv[$i-$j]->ftype[$l-$m]->geomtype = $wfsMatrix[$i]['element_type'];
-				$this->wfsJSON->wfs->srv[$i-$j]->ftype[$l-$m]->bbox = array(-180.0,-90.0,180.0,90.0);//TODO: $wfsMatrix[$i]['bbox'];
-				//fill in categories
-				if (!isset($this->wfsJSON->wfs->srv[$i-$j]->ftype[$l-$m]->cat)) {
-					$this->wfsJSON->wfs->srv[$i-$j]->ftype[$l-$m]->cat = array();
-				if (isset($wfsMatrix[$i]['iso_categories'])) {
-				//if (isset($wfsMatrix[$i]['inspire_category'])) {
-					//TODO write the categories as JSON into Database!
-					$this->wfsJSON->wfs->srv[$i-$j]->ftype[$l-$m]->cat[0]->type = 'INSPIRE Kategorie';
- 					$this->wfsJSON->wfs->srv[$i-$j]->ftype[$l-$m]->cat[0]->value = 'Umwelt';
-					$this->wfsJSON->wfs->srv[$i-$j]->ftype[$l-$m]->cat[0]->symbol = 'umwelt.png';
-				if (isset($wfsMatrix[$i]['custom_categories'])) {
-				//if modul hasn't been created - do it
-				if (!isset($this->wfsJSON->wfs->srv[$i-$j]->ftype[$l-$m]->modul)) {
-					$this->wfsJSON->wfs->srv[$i-$j]->ftype[$l-$m]->modul = array();
-				//fill in modul infos
-				$this->wfsJSON->wfs->srv[$i-$j]->ftype[$l-$m]->modul[$m]->id = $wfsMatrix[$i]['wfs_conf_id'];
-				$this->wfsJSON->wfs->srv[$i-$j]->ftype[$l-$m]->modul[$m]->title = $wfsMatrix[$i]['wfs_conf_description'];
-				$this->wfsJSON->wfs->srv[$i-$j]->ftype[$l-$m]->modul[$m]->abstract = $wfsMatrix[$i]['wfs_conf_abstract'];
-				$this->wfsJSON->wfs->srv[$i-$j]->ftype[$l-$m]->modul[$m]->type = $wfsMatrix[$i]['modultype'];
-				$equalEPSG = $wfsMatrix[$i]['featuretype_srs'];
-                       		$isEqual = "true";
-				//control if EPSG is supported by Client
-		        	if ($equalEPSG == $this->searchEPSG){
-					$isEqual = "false";
-				$this->wfsJSON->wfs->srv[$i-$j]->ftype[$l-$m]->modul[$m]->srsProblem = $isEqual;
-				//generate Link to show metadata
-				$this->wfsJSON->wfs->srv[$i-$j]->ftype[$l-$m]->modul[$m]->mdLink = $_SERVER['HOST']."/mapbender/x_geoportal/showWFSConfMetadata.php?id=".$wfsMatrix[$i]['wfs_conf_id'];
-				$perText = $this->getPermissionValueForWFS($wfsMatrix[$i]['wfs_id'], $wfsMatrix[$i]['wfs_conf_id']);
-				$this->wfsJSON->wfs->srv[$i-$j]->ftype[$l-$m]->modul[$m]->permission = $perText;
-				if ($wfsMatrix[$i]['wfs_id'] == $wfsMatrix[$i+1]['wfs_id']){
-					$j++; //next record is the same service
-					$l++;
-				else
-					$l = 0;
+if (isset($_REQUEST["userId"]) & $_REQUEST["userId"] != "") {
+        $testMatch = $_REQUEST["userId"];
+        $pattern = '/^[0-9]*$/';
+                echo 'userId: <b>'.$testMatch.'</b> is not valid.<br/>';
+                die();
+        $userId = $testMatch;
+} else {
-				if ($wfsMatrix[$i]['featuretype_id'] == $wfsMatrix[$i+1]['featuretype_id']){
-					$m++;
-				else
-					$m = 0;
-	private function generateWMSMetadataJSON($res, $n) {
-		$this->wmsJSON = new stdClass;
-		$this->wmsJSON->wms = (object) array(
-					'nresults' => $n,
-				'srv' => array()
-		$serverCount = 0;
-		$wmsMatrix = db_fetch_all($res);
-		$layerIdArray = array();
-		//read out array with unique wms_ids in wmsMatrix
-		$wmsIdArray = array();
-		//initialize root layer id;
-		$rootLayerId = -1;
-		$j = 0;
-		//get array with all available layer_id for this user:
- 		$admin = new administration();
-		$this->accessableLayers = $admin->getLayersByPermission($this->userId);
-		#echo "<br>user_id: ".$this->userId."<br><br>";
-		#var_dump($this->accessableLayers);
-		#echo "<br>";
-		#$countWmsMatrix = count($wmsMatrix);
-		#echo $countWmsMatrix;
-		if ($n != 0) {
-		for($i=0; $i<count($wmsMatrix);$i++){
-			$layerID = $wmsMatrix[$i]['layer_id'];
-			#echo "<br>LayerID: ".$layerID."<br>";
-			#$wmsID = $wmsMatrix[$i]['wms_id']; //get first wms id - in the next loop - dont get second, but some else!
-			if (!in_array($layerID, $layerIdArray) or !in_array($rootLayerId, $layerIdArray)) {
-				$wmsID = $wmsMatrix[$i]['wms_id']; //get first wms id - in the next loop - dont get second, but some else!
-				//Select all layers of with this wms_id into new array per WMS - the grouping should be done by wms!
-				$subLayers = $this->filter_by_value($wmsMatrix, 'wms_id', $wmsID);
-				#echo "<br>wms_id: ".$wmsID."<br>";
-				#echo "<br>Number of sublayers: <br>";
-				#print(count($subLayers));
-				//Sort array by load_count - problem: maybe there are some groups between where count is to low (they have no load count because you cannot load them by name)? - Therefor we need some ideas - or pull them out of the database and show them greyed out. Another way will be to define a new group (or wms with the same id) for those layers which are more than one integer away from their parents
-				$subLayersFlip = $this->flipDiagonally($subLayers);
-				#var_dump($subLayers['layer_pos']);
-				#$subLayers = $this->flipDiagonally($subLayers);
-				//go backwards through the layerTree to get the layer with the highest position without gaps in between
-				#var_dump($subLayers['layer_id']);
-				#echo "<br>";
-				$index = array_search($layerID, $subLayersFlip['layer_id']);
-				#echo "<br>found layer_id= ".$layerID." at index: ".$index." in sublayerstable layer_pos=".$subLayers[$index]['layer_pos']." <br>";
-				#echo "<br>sublayers: ";
-				#var_dump($subLayersFlip);
-				#echo "<br>";
-				$rootIndex = $this->getLayerParent($subLayersFlip, $index);
-				$rootLayerPos = $subLayers[$rootIndex]['layer_pos'];
-				$rootLayerId = $subLayers[$rootIndex]['layer_id'];
-				#echo "<br>root layer for this layer: <br>";
-				#echo "<br>id= "..""
-				#echo "<br>";
-				#echo "<br>LayerId:<br>";
-				#echo "<br>".$layerID."<br>";
-				#echo "<br>rootLayerPos:<br>";
-				#echo "<br>".$rootLayerPos."<br>";
-				#echo "<br>rootLayerId:<br>";
-				#echo "<br>".$rootLayerId."<br>";
-				//push root layer id in array
-				array_push($layerIdArray, $rootLayerId);
-				#echo "<br>root Layer ID: ".$rootLayerId."<br>";
-				#array_multisort($subLayers['layer_pos'], SORT_ASC);
-				#print_r($subLayers);
-				#print_r("<br>rootIndex: ".$rootIndex."<br>");
-				//Create object for wms service level
-				$this->wmsJSON->wms->srv[$j]->id = (integer)$subLayers[$rootIndex]['wms_id'];
-				$this->wmsJSON->wms->srv[$j]->title = $subLayers[$rootIndex]['wms_title'];
-				$this->wmsJSON->wms->srv[$j]->abstract = $subLayers[$rootIndex]['wms_abstract'];
-				$this->wmsJSON->wms->srv[$j]->date = date("d.m.Y",$subLayers[$rootIndex]['wms_timestamp']);
-				$this->wmsJSON->wms->srv[$j]->respOrg = $subLayers[$rootIndex]['mb_group_name'];
-				$this->wmsJSON->wms->srv[$j]->loadCount = (integer)$subLayers[$rootIndex]['load_count'];
-				$this->wmsJSON->wms->srv[$j]->mdLink = "http://".$_SERVER['HTTP_HOST']."/mapbender/x_geoportal/mod_layerMetadata.php?id=".$rootLayerId;
-				$stateOrProvince = $wmsMatrix[$i]['administrativearea'];
-					$spatialSource = $wmsMatrix[$i]['country'];
-				} else {
-					$spatialSource = $wmsMatrix[$i]['administrativearea'];
-				$this->wmsJSON->wms->srv[$j]->iso3166 = $spatialSource;
-				$this->wmsJSON->wms->srv[$j]->tou = $subLayers[$rootIndex]['termsofuse'];
-				$this->wmsJSON->wms->srv[$j]->status = $subLayers[$rootIndex]['status']; //$wmsMatrix[$i][''];
-				$this->wmsJSON->wms->srv[$j]->avail = $subLayers[$rootIndex]['availability']; //$wmsMatrix[$i][''];
-				//get info about defined price
-				if ($subLayers[$rootIndex]['wms_pricevolume'] == '' OR $subLayers[$rootIndex]['wms_pricevolume'] == 0){
-					$this->wmsJSON->wms->srv[$j]->price = NULL;
-				else {
-					$this->wmsJSON->wms->srv[$j]->price = $subLayers[$rootIndex]['wms_pricevolume'];
-				//get info about logging of resource
-				if ($subLayers[$rootIndex]['wms_proxylog'] == NULL OR $subLayers[$rootIndex]['wms_proxylog'] == 0){
-					 $this->wmsJSON->wms->srv[$j]->logged = false;
-				else {
-					 $this->wmsJSON->wms->srv[$j]->logged = true;
-				//get info about network_accessability
-				if ($subLayers[$rootIndex]['wms_network_access'] == NULL OR $subLayers[$rootIndex]['wms_network_access'] == 0){
-					 $this->wmsJSON->wms->srv[$j]->nwaccess = false;
-				else {
-					 $this->wmsJSON->wms->srv[$j]->nwaccess = true;
+if (!isset($_SESSION['mb_user_id']) ) {
+        $userId = ANONYMOUS_USER;
+else
+        $userId = $_SESSION['mb_user_id'];
-				$this->wmsJSON->wms->srv[$j]->logged = NULL; //$wmsMatrix[$i][''];
-				$this->wmsJSON->wms->srv[$j]->price = NULL; //$wmsMatrix[$i][''];
-				$this->wmsJSON->wms->srv[$j]->nwaccess = NULL; //$wmsMatrix[$i][''];
-				$this->wmsJSON->wms->srv[$j]->bbox = $subLayers[$rootIndex]['bbox']; //$wmsMatrix[$i][''];
-				//Call recursively the child elements, give and pull $layerIdArray to push the done elements in the array to avoid double results
-				//generate the layer-entry for the so called root layer - maybe this is only a group layer if there is a gap in the layer hierachy
-				$this->wmsJSON->wms->srv[$j]->layer = array();
-				$this->wmsJSON->wms->srv[$j]->layer[0]->id = (integer)$subLayers[$rootIndex]['layer_id'];
-				$this->wmsJSON->wms->srv[$j]->layer[0]->title = $subLayers[$rootIndex]['layer_title'];
-				$this->wmsJSON->wms->srv[$j]->layer[0]->abstract = $subLayers[$rootIndex]['layer_abstract'];
-				if ($subLayers[$rootIndex]['layer_name'] == ''){
-					$this->wmsJSON->wms->srv[$j]->layer[0]->loadable = 0;
-				else {
-					$this->wmsJSON->wms->srv[$j]->layer[0]->loadable = 1;
-				if ($subLayers[$rootIndex]['layer_pos'] == '0'){
-					$this->wmsJSON->wms->srv[$j]->layer[0]->isRoot = true;
-				else {
-					$this->wmsJSON->wms->srv[$j]->layer[0]->isRoot = false;
-				//give info for inspire categories - not relevant for other services or instances of mapbender TODO: comment it if the mapbender installation is not used to generate inspire output
-				if ($subLayers[$rootIndex]['md_inspire_cats'] == ''){
-					$this->wmsJSON->wms->srv[$j]->layer[0]->inspire = 0;
-				else {
-					$this->wmsJSON->wms->srv[$j]->layer[0]->inspire = 1;
-				//get info about queryable or not
-				if ($subLayers[$rootIndex]['layer_queryable'] == 1){
-					$this->wmsJSON->wms->srv[$j]->layer[0]->queryable = 1;
-				else {
-					$this->wmsJSON->wms->srv[$j]->layer[0]->queryable = 0;
-				#if ($subLayers[$rootIndex]['layer_name'] == ''){
-				#	$this->wmsJSON->wms->srv[$i-$j]->layer[0]->loadable = 0;
-				#else {
-				#	$this->wmsJSON->wms->srv[$i-$j]->layer[0]->loadable = 1;
-				$this->wmsJSON->wms->srv[$j]->layer[0]->loadCount = $subLayers[$rootIndex]['load_count'];
-				#$servObject->layer[$countsublayer]->mdLink = $_SERVER['HOST']."/mapbender/x_geoportal/showWFeatureTypeMetadata.php?id=".$wfsMatrix[$i]['featuretype_id'];
-				#$servObject->layer[$countsublayer]->geomtype = $wfsMatrix[$i]['element_type'];
-				$this->wmsJSON->wms->srv[$j]->layer[0]->bbox = $subLayers[$rootIndex]['bbox'];
-				$this->wmsJSON->wms->srv[$j]->layer[0]->permission = $this->getPermissionValueForLayer($subLayers[$rootIndex]['layer_id'], $subLayers[$rootIndex]['wms_id']); //TODO: Make this much more faster
-				//when the entry for the first server has been written, the server entry is fixed and the next one will be a new server or a part of the old one.
-				 //increment server (highest object id)
-				$layerIdArray = $this->writeWMSChilds($layerIdArray, $rootLayerPos, $subLayers, $this->wmsJSON->wms->srv[$j]->layer[0]);
-				$j++;
-				//generate php object - if root layer was found - > layer_parent='' give hint to visualize folder symbol.
+#$searchResources = array('wms','wfs','wmc','georss');
+#$searchPages = array(1,1,1,1);
+//TODO: if class is called directly
+if ($resultTarget == 'debug') {
+	echo "<br>DEBUG: searchURL: ".$searchURL."<br>";
+	#echo "<br>DEBUG: languageCode: ".$languageCode."<br>";
+if ($resultTarget == 'file') {
+	if (!isset($searchResources) OR ($searchResources == "")) {
+		$searchResources = "wms,wfs";
+		$searchPages = "1,1";
-	private function generateWMSMetadata($xmlDoc) {
-		$starttime = $this->microtime_float();
-		list($sql, $v, $t, $n) = $this->generateSearchSQL();
-		//call database search in limits
-		$res = db_prep_query($sql, $v, $t);
-			//generate json
-			$this->generateWMSMetadataJSON($res,$n);
-			$usedTime = $this->microtime_float() - $starttime;
-			//put in the time to generate the data
-			$this->wmsJSON->wms->md->genTime = $usedTime;
-			$this->wmsJSON = $this->json->encode($this->wmsJSON);
-			if ($this->resultTarget == 'file') {
-				if($wmsFileHandle = fopen($this->tempFolder."/".$this->searchId."_".$this->searchResources."_".$this->searchPages.".json","w")){
-					fwrite($wmsFileHandle,$this->wmsJSON);
-					fclose($wmsFileHandle);
-			if ($this->resultTarget == 'web' or $this->resultTarget == 'debug') {
-				echo $this->wmsJSON;
-		$usedTime2 = $this->microtime_float() - $starttime;
-		//echo "<br>used time: ".$usedTime."<br>";
-		$e = new mb_exception("Time to generate WMS-Metadata: ".$usedTime2);
-		$e = new mb_exception("Wrote the MD_WMS-File");
+if ($resultTarget == 'web' or $resultTarget == 'debug') {
+		$searchResources = "wms";
+		$searchPages = "1";
+//convert the respources and the pagenumbers into arrays
+$searchResources = explode(",",$searchResources);
+$searchPages = explode(",",$searchPages);
-	private function generateWFSMetadata($xmlDoc) {
-			//generate json
-			$this->generateWFSMetadataJSON($res, $n);
-			$this->wfsJSON = $this->json->encode($this->wfsJSON);
-				if($wfsFileHandle = fopen($this->tempFolder."/".$this->searchId."_".$this->searchResources."_".$this->searchPages.".json","w")){
-					fwrite($wfsFileHandle,$this->wfsJSON);
-					fclose($wfsFileHandle);
+//Generate search filter file. This file holds the defined search filter to allow the user to see how he searched
+//The user should become the possibility to drop the search filters by clicking in some buttons
+//list of options to display:
+//searchText (textfields) - dropping only if more than one text is given
+//registratingDepartments (list) - dropping allowed - maybe give a webservice for mb_group data
+//isoCategories - dropping allowed
+//inspireThemes - dropping allowed
+//customCategories - dropping allowed
+//bbox (show) - dropping allowed
+//regTimeBegin - dropping allowed
+//regTimeEnd -dropping allowed
+//the idea is, to rewrite the searchURL directly and then have another url for the special case!
+//we have to get the searchURL as a parameter for this wrapper cause the class_metadata should give filters for the found categories
+//use regular expressions to do this!
+//define internationalization
+//searchText
+//bbox
+//generate query json:
+//some objects like names of categories and other objects have to be pulled of the database. Maybe a webservice is the better way? But now there are no webservices - therefor: pull the names out of the database into arrays - only those who are requested:
+//function to get the information about the registrating departments (mb_groups) out of the mapbender database
+function get_registratingDepartmentsArray($departmentIds,$languageCode) {
+			$sql = "SELECT mb_group_id, mb_group_name FROM mb_group WHERE mb_group_id IN (";
+			$v = array();
+			$t = array();
+			$departmentsArray = array();
+			for($i=0; $i<count($departmentIds);$i++){
+				if($i > 0){$sql .= ",";}
+				$sql .= "$".strval($i+1);
+				array_push($v,$departmentIds[$i]);
+				array_push($t,"i");
-			if ($this->resultTarget == 'web'or $this->resultTarget == 'debug') {
-				echo $this->wfsJSON;
+			$sql .= ")";
+			$res = db_prep_query($sql,$v,$t);
+			$countDepArray = 0;
+			while($row = db_fetch_array($res)){
+				$departmentsArray[$countDepArray]["id"] = $row["mb_group_id"];
+				$departmentsArray[$countDepArray]["name"] = $row["mb_group_name"];
+				$departmentsArray[$countDepArray]["showScript"] = "../php/mod_showRegistratingGroup.php?";
+				$countDepArray = $countDepArray + 1;
+			return $departmentsArray;
-		if ($this->outputFormat == 'xml'){
-			//generate xml
-			$this->generateXMLHead($xmlDoc);
-			$this->generateXMLFoot($xmlDoc);
-			$this->generateWFSResultXML($xmlDoc,$res);
-				if($wfsFileHandleXML = fopen($this->tempFolder."/".$this->searchId."_".$this->searchResources."_".$this->searchPages.".xml","w")){
-					fwrite($wfsFileHandleXML,$xmlDoc->saveXML());
-					fclose($wfsFileHandleXML);
+//get the information about the requested isoCategories
+function get_isoCategoriesArray($isoCategoryIds,$languageCode) {
+			$sql = "SELECT md_topic_category_id, md_topic_category_code_".$languageCode;
+			#$e = new mb_exception("php/mod_callMetadata.php: language code: ".$languageCode);
+			$sql .= " FROM md_topic_category WHERE md_topic_category_id IN (";
+			$v = array();
+			$t = array();
+			$isoCategoryArray = array();
+			for($i=0; $i<count($isoCategoryIds);$i++){
+				array_push($v,$isoCategoryIds[$i]);
-			if ($this->resultTarget == 'web') {
-				header("Content-type: application/xhtml+xml; charset=UTF-8");
-				echo $xmlDoc->saveXML();
+			$sql .= ")";
+			#$e = new mb_exception("php/mod_callMetadata.php: sql for getting topic cats: ".$sql);
+			$countIsoArray = 0;
+				$isoCategoryArray[$countIsoArray]["id"] = $row["md_topic_category_id"];
+				$isoCategoryArray[$countIsoArray]["name"] = $row["md_topic_category_code_".$languageCode];
+				$countIsoArray = $countDepArray + 1;
+			return $isoCategoryArray;
-		$e = new mb_exception("Time to generate WFS-Metadata: ".$usedTime);
-		$e = new mb_exception("Wrote the MD_WFS-File");
-	private function replaceChars_all($text){
-		$search = array( "ä",  "ö",  "ü",  "Ä",  "Ö",  "Ü",  "ß");
-		$repWith = array("ae", "oe", "ue", "AE", "OE", "UE", "ss");
-		$replaced = str_replace($search, $repWith, $text);
-		return $replaced;
-	private function generateSearchSQL() {
-		//elements needed to exist in mb wfs view or table:
-		//1. textfield - all texts - searchText
-		//2. responsible organisations - given id
-		//3. bbox - is not explicit given in the wfs metadata? Since WFS 1.1.0 a latlonbbox is present
-		//4. isoTopicCategory - is not been saved til now
-		//5. ...
-		//parse searchText into different array elements to allow an AND search
-		$searchStringArray = $this->generateSearchStringArray();
-		$v = array();
-		$t = array();
-		$sql = "SELECT * from ".$this->searchView." where ";
-		#$sqlN = "SELECT count(".$this->searchResources."_id) from ".$this->searchView." where ";
-		$whereStr = "";
-		$whereCondArray = array();
-		$isTextSearch = "false";
-		$e = new mb_exception("Number of used searchstrings: ".count($searchStringArray));
-		//textsearch
-		if ($this->searchText != NULL) {
-			for($i=0; $i < count($searchStringArray); $i++){
-				$isTextSearch = "true";
-				if($i>0) {
-					$whereStr .= " AND ";
-				$whereStr .= "searchtext LIKE $".($i+1);
-				//output for debugging
-				$e = new mb_notice("Part of string".$i.": ".$searchStringArray[$i]);
-				$e = new mb_notice("converted: ".$this->replaceChars_all($searchStringArray[$i]));
-				$va = "%".trim(strtoupper($this->replaceChars_all($searchStringArray[$i])))."%";
-				$e = new mb_notice($this->searchResources." Searchtext in SQL: ".$va);
-				array_push($v,$va);
-				array_push($t,"s");
+//get the information about the inspireThemes
+function get_inspireThemesArray($inspireThemesIds,$languageCode) {
+			$sql = "SELECT inspire_category_id, inspire_category_code_".$languageCode." FROM inspire_category WHERE inspire_category_id IN (";
+			$v = array();
+			$t = array();
+			$inspireCategoryArray = array();
+			for($i=0; $i<count($inspireThemesIds);$i++){
+				array_push($v,$inspireThemesIds[$i]);
+			$sql .= ")";
+			$e = new mb_exception("php/mod_callMetadata.php: sql for getting inspire cats: ".$sql);
+			$countInspireArray = 0;
+				$inspireCategoryArray[$countInspireArray]["id"] = $row["inspire_category_id"];
+				$inspireCategoryArray[$countInspireArray]["name"] = $row["inspire_category_code_".$languageCode];
+				$countInspireArray = $countInspireArray + 1;
+			return $inspireCategoryArray;
-/* This is only for the later postgis versions. The within and disjoint is to slow, cause there is no usage of the geometrical index in the old versions!
-		//spatial search filter - ist should be the first filter in the where clause, cause it is
-		if (strtolower($this->searchResources) === "wms" & $this->searchBbox != NULL) {
-			#$spatialFilter = "(the_geom ";
-			#echo "<br> spatial operator: ".$this->searchTypeBbox."<br>";
-			if ($this->searchTypeBbox == 'outside') {
-				$spatialFilter = ' disjoint(';
-			} elseif ($this->searchTypeBbox == 'inside') {
-				$spatialFilter = ' within(';
-			} else {
-				$spatialFilter = ' intersects(';
+function get_customCategoriesArray($customCategoriesIds,$languageCode) {
+			$sql = "SELECT custom_category_id, custom_category_code_".$languageCode." FROM custom_category WHERE custom_category_id IN (";
+			$v = array();
+			$t = array();
+			$customCategoryArray = array();
+			for($i=0; $i<count($customCategoriesIds);$i++){
+				array_push($v,$customCategoriesIds[$i]);
-			//define spatial filter
-			if(count(explode(',',$this->searchBbox)) == 4){   //if searchBbox has 4 entries
-				$spatialFilterCoords = explode(',',$this->searchBbox);//read out searchBbox
-				//definition of the spatial filter
-				$spatialFilter .= 'GeomFromText(\'POLYGON(('.$spatialFilterCoords[0];//minx
-				$spatialFilter .= ' '.$spatialFilterCoords[1].',';//miny
-				$spatialFilter .= $spatialFilterCoords[0];//minx
-				$spatialFilter .= ' '.$spatialFilterCoords[3].',';//maxy
-				$spatialFilter .= $spatialFilterCoords[2];//maxx
-				$spatialFilter .= ' '.$spatialFilterCoords[1].'))\',4326)';//miny
-				$spatialFilter .= ",the_geom)";
-				array_push($whereCondArray, $spatialFilter);
+			$sql .= ")";
+			$e = new mb_exception("php/mod_callMetadata.php: sql for getting custom cats: ".$sql);
+			$countCustomArray = 0;
+				$customCategoryArray[$countCustomArray]["id"] = $row["custom_category_id"];
+				$customCategoryArray[$countCustomArray]["name"] = $row["custom_category_code_".$languageCode];
+				$countCustomArray = $countCustomArray + 1;
-			#array_push($whereCondArray, $spatialFilter);
+			return $customCategoryArray;
-			#if ($this->searchTypeBbox == 'outside') {
-			#	$spatialFilter = ' disjoint(';
-			#} elseif ($this->searchTypeBbox == 'inside') {
-			#	$spatialFilter = ' within(';
-			#} else {
-			#	$spatialFilter = ' intersects(';
-			$spatialFilter = ' the_geom && ';
-				#$spatialFilter .= ",the_geom)";
-		//search filter for md_topic_categories
-		if (strtolower($this->searchResources) === "wms" & $this->isoCategories != NULL) {
-			$isoArray = explode(',',$this->isoCategories);
-			$topicCond = "(";
-			for($i=0; $i < count($isoArray); $i++){
-				if ($i == 0) {
-					$topicCond .= "(md_topic_cats LIKE '%{".$isoArray[$i]."}%') ";
-				} else {
-					$topicCond .= "OR (md_topic_cats LIKE '%{".$isoArray[$i]."}%') ";
-			$topicCond .= ")";
-			array_push($whereCondArray, $topicCond);
+//define where to become the information from - this is relavant for the information which must be pulled out of the database
+$classificationElements = array();
+$classificationElements[0]['name'] = 'searchText';
+$classificationElements[1]['name'] = 'registratingDepartments';
+$classificationElements[2]['name'] = 'isoCategories';
+$classificationElements[3]['name'] = 'inspireThemes';
+$classificationElements[4]['name'] = 'customCategories';
+$classificationElements[5]['name'] = 'searchBbox';
+$classificationElements[6]['name'] = 'regTimeBegin';
+$classificationElements[7]['name'] = 'regTimeEnd';
+$classificationElements[0]['source'] = '';
+$classificationElements[1]['source'] = 'database';
+$classificationElements[2]['source'] = 'database';
+$classificationElements[3]['source'] = 'database';
+$classificationElements[4]['source'] = 'database';
+$classificationElements[5]['source'] = '';
+$classificationElements[6]['source'] = '';
+$classificationElements[7]['source'] = '';
+$classificationElements[0]['list'] = true;
+$classificationElements[1]['list'] = true;
+$classificationElements[2]['list'] = true;
+$classificationElements[3]['list'] = true;
+$classificationElements[4]['list'] = true;
+$classificationElements[5]['list'] = false;
+$classificationElements[6]['list'] = false;
+$classificationElements[7]['list'] = false;
+//Defining of the different result categories
+		$resourceCategories = array();
+		#$resourceCategories[0]['wms'] = 'WMS';
+		#$resourceCategories[1]['wfs'] = 'WFS';
+		#$resourceCategories[2]['wmc'] = 'WMC';
+		#$resourceCategories[3]['georss'] = 'GeoRSS';
+switch($languageCode){
+        case 'de':
+        	$classificationElements[0]['name2show'] = 'Suchbegriff(e):';
+		$classificationElements[1]['name2show'] = 'Anbietende Stelle(n):';
+		$classificationElements[3]['name2show'] = 'INSPIRE Themen:';
+		$classificationElements[2]['name2show'] = 'ISO Kategorien:';
+		$classificationElements[4]['name2show'] = 'RP Kategorien:';
+		$classificationElements[5]['name2show'] = 'Räumliche Einschränkung:';
+		$classificationElements[6]['name2show'] = 'Registrierung/Aktualisierung von:';
+		$classificationElements[7]['name2show'] = 'Registrierung/Aktualisierung bis:';
+		$resourceCategories['wms'] = 'Darstellungsdienste';
+		$resourceCategories['wfs'] = 'Such- und Downloaddienste';
+		$resourceCategories['wmc'] = 'Kartenzusammenstellungen';
+		$resourceCategories['georss'] = 'Geokodierte Newsfeeds';
+		$orderByTitle['header'] = 'Sortierung nach:';
+		$orderByTitle['id'] = 'ID';
+		$orderByTitle['title'] = 'Titel';
+		$orderByTitle['rank'] = 'Relevanz';
+       	break;
+        case 'en':
+        	$classificationElements[0]['name2show'] = 'Search Term(s):';
+		$classificationElements[1]['name2show'] = 'Department(s):';
+		$classificationElements[3]['name2show'] = 'INSPIRE Themes:';
+		$classificationElements[2]['name2show'] = 'ISO Topic Categories:';
+		$classificationElements[4]['name2show'] = 'RP Categories:';
+		$classificationElements[5]['name2show'] = 'Spatial Filter:';
+		$classificationElements[6]['name2show'] = 'Registration/Update from:';
+		$classificationElements[7]['name2show'] = 'Registration/Update till:';
+		$resourceCategories['wms'] = 'Viewingservices';
+		$resourceCategories['wfs'] = 'Search- and Downloadservices';
+		$resourceCategories['wmc'] = 'Combined Maps';
+		$resourceCategories['georss'] = 'Geocodet Newsfeeds';
+		$orderByTitle['header'] = 'Sort by:';
+		$orderByTitle['title'] = 'title';
+		$orderByTitle['rank'] = 'relevance';
+        break;
+        case 'fr':
+		$orderByTitle['id'] = 'identification';
+       	break;
+     	default:
+$queryJSON = new stdClass;
+$queryJSON->searchFilter = (object) array();
+$queryJSON->searchFilter->origURL = $searchURL;
+#$queryJSON->searchFilter->classes = (object) array();
+for($i=0; $i<count($searchResources);$i++){
+//fill in the different search classes into the filter - the client can generate the headers out of this information
+	$queryJSON->searchFilter->classes[$i]->title = $resourceCategories[$searchResources[$i]];
+	$queryJSON->searchFilter->classes[$i]->name = $searchResources[$i];
+//generate search filter file - if more categories are defined give
+#echo "<br> number of filter elements: ".count($classificationElements)."<br>";
+for($i=0; $i < count($classificationElements); $i++){
+	if (isset(${$classificationElements[$i]['name']}) & ${$classificationElements[$i]['name']} !='' & ${$classificationElements[$i]['name']} != NULL) {
+		//pull register information out of database in arrays
+		if ($classificationElements[$i]['source'] == 'database') {
+			$funcName = "get_".$classificationElements[$i]['name']."Array";
+			${$classificationElements[$i]['name']."Array"} = $funcName(explode(',',${$classificationElements[$i]['name']}),$languageCode);
-		//search filter for inspire_categories
-		if (strtolower($this->searchResources) === "wms" & $this->inspireThemes != NULL) {
-			$inspireArray = explode(',',$this->inspireThemes);
-			$inspireCond = "(";
-			for($i=0; $i < count($inspireArray); $i++){
-				if ($i == 0) {
-					$inspireCond .= "(md_inspire_cats LIKE '%{".$inspireArray[$i]."}%') ";
+		$queryJSON->searchFilter->{$classificationElements[$i]['name']}->title = $classificationElements[$i]['name2show'];
+		//check if the filter has subfilters - if not delete the whole filter from query
+		if ($classificationElements[$i]['list'] == false) { //the object has no subsets - like bbox or time filters
+			$queryJSON->searchFilter->{$classificationElements[$i]['name']}->delLink = delTotalFromQuery($classificationElements[$i]['name'],$searchURL);
+		} else {
+			//TODO delete all entries of this main category (not for searchText)
+			if ($classificationElements[$i]['name'] != 'searchText') {
+			} else {
+				$queryJSON->searchFilter->{$classificationElements[$i]['name']}->delLink = NULL;
+			$queryJSON->searchFilter->{$classificationElements[$i]['name']}->item = array();
+			$queryArray = explode(',',${$classificationElements[$i]['name']});
+			//loop for the subcategories
+			for($j=0; $j < count($queryArray); $j++){
+					$identArray = ${$classificationElements[$i]['name']."Array"};
+					$identArray = flipDiagonally($identArray);
+					//find searched id in information from database
+					$key = array_search($queryArray[$j], $identArray['id']);
+					if ($key === false) {
+						$queryJSON->searchFilter->{$classificationElements[$i]['name']}->item[$j]->title = "no information found in database";
+					} else {
+						$queryJSON->searchFilter->{$classificationElements[$i]['name']}->item[$j]->title = ${$classificationElements[$i]['name']."Array"}[$key]['name'];
 				} else {
-					$inspireCond .= "OR (md_inspire_cats LIKE '%{".$inspireArray[$i]."}%') ";
+					$queryJSON->searchFilter->{$classificationElements[$i]['name']}->item[$j]->title = $queryArray[$j];
-			$inspireCond .= ")";
-			array_push($whereCondArray, $inspireCond);
-		//search filter for custom_categories
-		if (strtolower($this->searchResources) === "wms" & $this->customCategories != NULL) {
-			$customArray = explode(',',$this->customCategories);
-			$customCond = "(";
-			for($i=0; $i < count($customArray); $i++){
-				if ($i == 0) {
-					$customCond .= "(md_custom_cats LIKE '%{".$customArray[$i]."}%') ";
+				//generate links to disable filters on a simple way
+				if ($classificationElements[$i]['name'] === 'searchText' & count(explode(',',${$classificationElements[$i]['name']})) === 1) {
+					$queryJSON->searchFilter->{$classificationElements[$i]['name']}->item[$j]->delLink = NULL;
 				} else {
-					$customCond .= "OR (md_custom_cats LIKE '%{".$customArray[$i]."}%') ";
+					$newSearchLink = delFromQuery($classificationElements[$i]['name'], $searchURL,$queryArray[$j],$queryArray,${$classificationElements[$i]['name']});
+					$newSearchLink = delTotalFromQuery('searchId',$newSearchLink);
+					$queryJSON->searchFilter->{$classificationElements[$i]['name']}->item[$j]->delLink = $newSearchLink;
-			$customCond .= ")";
-			array_push($whereCondArray, $customCond);
-		//date condition
-		//if begin and end are set
-		//echo "<br> regTimeBegin: ".$this-> regTimeBegin." regTimeEnd: ".$this-> regTimeEnd."<br>";
-		if ($this->regTimeBegin != NULL && $this->regTimeEnd != NULL){
-			$time ="(TO_TIMESTAMP(".$this->searchResources."_timestamp) BETWEEN '".$this->regTimeBegin."' AND '".$this->regTimeEnd."')";
-			array_push($whereCondArray, $time);
-			//only begin is set
-		if ($this->regTimeBegin != NULL && $this->regTimeEnd == NULL){
-			$time ="(TO_TIMESTAMP(".$this->searchResources."_timestamp) > '".$this->regTimeBegin."')";
-		if ($this->regTimeBegin == NULL && $this->regTimeEnd != NULL){
-			$time ="(TO_TIMESTAMP(".$this->searchResources."_timestamp) < '".$this->regTimeEnd."')";
+//generate filter for different order possibilities
-		//department condition
-		//TODO: generate filter for new sql check if at least some department is requested
-		//generate array
-		//$this->registratingDepartments = explode(',',$this->registratingDepartments);
-		#if(count($this->registratingDepartments) > 0 & $this->registratingDepartments){
-		if($this->registratingDepartments != NULL){
-			$dep = " department IN (".$this->registratingDepartments.") ";
-			array_push($whereCondArray, $dep);
-		// Creating the WHERE clause, based on a array
-		if(count($whereCondArray) > 0){
-			$txt_whereCond = "";
-			for ($index = 0; $index < sizeof($whereCondArray); $index++) {
-				$array_element = $whereCondArray[$index];
-				if($isTextSearch == "true") {
-					$txt_whereCond .= " AND ".$array_element;
-				} else {
-					if($index>0){
-					} else {
-						$txt_whereCond .= " ".$array_element;
-			$whereStr .= $txt_whereCond;
-		//Add WHERE condition to search
-		$sql .= $whereStr;
-		//TODO ORDER BY in SQL - not necessary for counting things:
-		$sql .= $this->orderBy;
-		//Calculate Paging for OFFSET and LIMIT values:
-		$offset = ((integer)$this->maxResults) * ((integer)$this->searchPages -1);
-		$limit = (integer)$this->maxResults;
-		//defining range for paging
-		$sql .= " LIMIT ".$limit." OFFSET ".$offset."";
-		//Print out search SQL term
-		$e = new mb_exception("class_metadata.php: Search => SQL-Request of ".$this->searchResources." service metadata: ".$sql."");
-		//parameter: searchId -> can be used global, searchResources -> is only one type per instance!!-> global,which categories -> can be defined global! $whereStr
-		$n = $this->writeCategories($whereStr, $v, $t);
-		//write counts to filesystem to avoid to many database connections
-		//only write them, if searchId is given - problem: searches with same searchId's maybe get wrong information
-		return array($sql, $v, $t, $n);
+//$queryJSON->searchFilter = (object) array();
+if ($_REQUEST["orderBy"] == '') {
+//echo "<br>orderBy:>".$_REQUEST["orderBy"]."<<br>";
+	$queryJSON->searchFilter->orderFilter->title = $orderByTitle['header'];
-	private function writeCategories($whereStr, $v, $t) {
-		//generate count sql
-		//generate count of all entries
-		$sqlN = "SELECT count(".$this->searchResources."_id) from ".$this->searchView." where ";
-		$sqlN .= $whereStr;
-		//Get total number of results
-		$count = db_prep_query($sqlN, $v, $t);
-		$n = db_fetch_all($count);
-		#echo "<br>N: ".var_dump($n)."<br>";
-		$n = $n[0]['count'];
-		$e = new mb_notice("class_metadata.php: Search => SQL-Request of ".$this->searchResources." service metadata N: ".$sqlN." Number of found objects: ".$n);
-		if ($this->searchId != 'dummysearch') { //searchId is not the default id! - it has been explicitly defined
-			//check if cat file already exists:
-			//filename to search for:
-			$filename = $this->tempFolder."/".$this->searchId."_".$this->searchResources."_cat.json";
-			if (!file_exists($filename) or $this->resultTarget == 'debug') { //TODO at the moment the cat file will be overwritten - change this in production system
-				//open category file for wfs results
-				$this->catJSON = new stdClass;
-				$this->catJSON->searchMD = (object) array(
-					'searchId' => $this->searchId,
-					'n' => $n
-				//generate the list of category counts
-				$sqlCat = array();
-				//check if categories are defined for the resource
-				if ($this->resourceClasses != NULL) {
-					$this->catJSON->searchMD->category = array();
-					for ($i = 0; $i < count($this->resourceClasses); $i++) {
-						//TODO: not to set the classification?
-						$this->catJSON->searchMD->category[$i]->title = $this->resourceClassifications[$i]['title'];
-						$sqlCat[$i] = "SELECT ".$this->resourceClassifications[$i]['tablename'];
-						$sqlCat[$i] .= ".".$this->resourceClassifications[$i]['tablename']."_id, ";
-						$sqlCat[$i] .= " ".$this->resourceClassifications[$i]['tablename'].".";
-						$sqlCat[$i] .= $this->resourceClassifications[$i]['tablename']."_code_";
-						$sqlCat[$i] .= $this->languageCode.", COUNT(*) FROM ".$this->searchView;
+	$queryJSON->searchFilter->orderFilter->item[0]->title = $orderByTitle['title'];
+	$queryJSON->searchFilter->orderFilter->item[0]->url = $searchURL."&orderBy=title";
+	$queryJSON->searchFilter->orderFilter->item[1]->title = $orderByTitle['id'];
+	$queryJSON->searchFilter->orderFilter->item[1]->url = $searchURL."&orderBy=id";
+} else {
+//read out actual order filter
+switch ($orderBy) {
+					case "rank":
+						$queryJSON->searchFilter->orderFilter->item[0]->title = $orderByTitle['id'];
-						//first join for connection table
-						$sqlCat[$i] .= " INNER JOIN ".$this->resourceClassifications[$i]['relation_'.$this->searchResources];
-						$sqlCat[$i] .= " ON (";
-						$sqlCat[$i] .= $this->resourceClassifications[$i]['relation_'.$this->searchResources].".fkey_";
-						$sqlCat[$i] .= $this->resourceClassifications[$i]['id_'.$this->searchResources]."=".$this->searchView;
-						$sqlCat[$i] .= ".".$this->resourceClassifications[$i]['id_'.$this->searchResources];
-						$sqlCat[$i] .= ") INNER JOIN ";
-						$sqlCat[$i] .= $this->resourceClassifications[$i]['tablename']." ON (";
-						$sqlCat[$i] .= $this->resourceClassifications[$i]['tablename'].".";
-						$sqlCat[$i] .= $this->resourceClassifications[$i]['tablename']."_id=";
-						$sqlCat[$i] .= $this->resourceClassifications[$i]['tablename']."_id)";
-						$sqlCat[$i] .= " WHERE ".$whereStr."  GROUP BY ";
+						$queryJSON->searchFilter->orderFilter->item[0]->url = str_replace("orderBy=rank", "orderBy=id", $searchURL);
+						$queryJSON->searchFilter->orderFilter->item[1]->title = $orderByTitle['title'];
-						$sqlCat[$i] .= $this->resourceClassifications[$i]['tablename']."_id,";
-						$sqlCat[$i] .= $this->resourceClassifications[$i]['tablename']."_code_".$this->languageCode." ORDER BY ";
-						$sqlCat[$i] .= $this->resourceClassifications[$i]['tablename']."_id";
-						$sqlCategory = $sqlCat[$i];
+						$queryJSON->searchFilter->orderFilter->item[1]->url = str_replace("orderBy=rank", "orderBy=title", $searchURL);
+						break;
+					case "id":
+						$queryJSON->searchFilter->orderFilter->item[0]->title = $orderByTitle['rank'];
-						//call sql for count of category
-						$res = db_prep_query($sqlCategory, $v, $t);
-						$categoryCounts = db_fetch_all($res);
-						//if none found: $categoryCounts=false
-						#echo "<br>count sub categories :".$categoryCounts."<br>";
-						if ($categoryCounts) {
-						//write results in json object
-						if (count($categoryCounts) > 0) {
-							#echo "<br>count main categories".count($categoryCounts)."<br>";
-							#echo "<br>vardump main categories".var_dump($categoryCounts)."<br>";
-							$this->catJSON->searchMD->category[$i]->subcat = array();
-							for ($j = 0; $j < count($categoryCounts); $j++) {
-								$this->catJSON->searchMD->category[$i]->subcat[$j]->id = $categoryCounts[$j][$this->resourceClassifications[$i]['tablename']."_id"];
-								$this->catJSON->searchMD->category[$i]->subcat[$j]->title = $categoryCounts[$j][$this->resourceClassifications[$i]['tablename']."_code_".$this->languageCode];
-								$this->catJSON->searchMD->category[$i]->subcat[$j]->count = $categoryCounts[$j]['count'];
-								//delete requestParam for this category and for id - cause a new search is started from searchURL
-								$filteredSearchString = $this->delTotalFromQuery('searchId',$this->searchURL);
-								$filteredSearchString = $this->delTotalFromQuery($this->resourceClassifications[$i]['requestName'],$filteredSearchString);
-								//set filter for this categoryid
-								$filteredSearchString .= "&".$this->resourceClassifications[$i]['requestName']."=".$categoryCounts[$j][$this->resourceClassifications[$i]['tablename']."_id"];
-								$this->catJSON->searchMD->category[$i]->subcat[$j]->filterLink = $filteredSearchString;
-						} else {
-							#$this->catJSON->searchMD->category[$i]->subcat = array();
-						$e = new mb_notice("class_metadata: countsql: ".$sqlCat[$i]);
+						$queryJSON->searchFilter->orderFilter->item[0]->url = str_replace("orderBy=id", "orderBy=rank", $searchURL);
-				$this->catJSON = $this->json->encode($this->catJSON);
-				//write categories files only when file is requested and the searchid was not used before!
-					if($catFileHandle = fopen($filename, "w")){
-						fwrite($catFileHandle,$this->catJSON);
-						fclose($catFileHandle);
-						$e = new mb_notice("class_metadata: new ".$this->searchResources."_class_file created!");
-					} else {
-						$e = new mb_notice("class_metadata: cannot create ".$this->searchResources."_cat_file!");
-				if ($this->resultTarget == 'debug') {
-					echo "<br>DEBUG: show categories: <br>".$this->catJSON."<br><br>";
-			} else {
-				$e = new mb_exception("class_metadata: ".$this->searchResources."_class_file: ".$filename." already exists - no new one is generated!");
-		} else {
-				echo "<br>DEBUG: Standard ID dummysearch was invoked - classifications won't be counted!<br>";
-			$e = new mb_exception("class_metadata: standard dummysearch was invoked - classifications won't be counted!");
-		return $n;
+						$queryJSON->searchFilter->orderFilter->item[1]->url = str_replace("orderBy=id", "orderBy=title", $searchURL);
+						break;
+					case "title":
+						$queryJSON->searchFilter->orderFilter->item[0]->url = str_replace("orderBy=title", "orderBy=rank", $searchURL);
+						$queryJSON->searchFilter->orderFilter->item[1]->url = str_replace("orderBy=title", "orderBy=id", $searchURL);
+						break;
+//write out json to file or web
+$queryFilter = $classJSON->encode($queryJSON);
-	private function generateWFSResultXML($wfsDoc, $res) {
-		$c = $this->wfsDoc->createElement("category");
-		$results = $this->wfsDoc->getElementsByTagName("result");
-			$result->appendChild($c);
-			$c->setAttribute('name', "WFS");
-			$c->setAttribute('count', "0");
-		$i = 0;
-		while($row = db_fetch_array($res)){
-			$m = $this->wfsDoc->createElement('member');
-			$m->setAttribute('wfs_id', $row['wfs_id']);
-			$m->setAttribute('layer_pos', "");
-			$c->appendChild($m);	 // member categorie 1 (first member)
-			// epsg - TODO adopt
-			$epsg = $this->wfsDoc->createElement('epsg');
-			$m->appendChild($epsg);
-			$equalEPSG = $row['featuretype_srs'];
-                       	$isequal = "false";
-		        if ($equalEPSG == $this->search_epsg){
-				$isequal = "true";
-		       	//Insert end
-			$epsg_text = $this->wfsDoc->createTextNode($isequal);
-			$epsg->appendChild($epsg_text);
-			// country codes
-			$state = $this->wfsDoc->createElement('federalstate');
-			$m->appendChild($state);
-			$stateorprovince = $row['administrativearea'];
-			if ($stateorprovince == "NULL" || $stateorprovince == "") {
-				$spatialSource = $row['country'];
-			} else {
-				$spatialSource = $row['administrativearea'];
-			$countr_code_text = $this->wfsDoc->createTextNode($spatialSource);
-			$state->appendChild($countr_code_text);
-			//type
-			$type = $this->wfsDoc->createElement('type');
-			$m->appendChild($type);
-			$ttype = $this->wfsDoc->createTextNode("wfs");
-			$type->appendChild($ttype);
-                        //wfs_id
-			$wfsid = $this->wfsDoc->createElement('wfs_id');
-			$m->appendChild($wfsid);
-			$twfsid = $this->wfsDoc->createTextNode($row['wfs_id']);
-			$wfsid->appendChild($twfsid);
-			//id
-			$id = $this->wfsDoc->createElement('featuretype_id');
-			$m->appendChild($id);
-			$tid = $this->wfsDoc->createTextNode($row['featuretype_id']);
-			$id->appendChild($tid);
-			//title
-			$title = $this->wfsDoc->createElement('featuretype_title');
-			$m->appendChild($title);
-			$ttitle = $this->wfsDoc->createTextNode($row['featuretype_title']);
-			$title->appendChild($ttitle);
-			//abstract
-			$abst = $this->wfsDoc->createElement('featuretype_abstract');
-			$m->appendChild($abst);
-			$tabst = $this->wfsDoc->createTextNode($row['featuretype_abstract']);
-			$abst->appendChild($tabst);
-			// accesscontraints
-			$ac = $this->wfsDoc->createElement('accessconstraints');
-			$m->appendChild($ac);
-//			$myac = $this->getAccessConstraints($this->cat[$i]['member'][$ii]['wms_id'], $this->cat[$i]['member'][$ii]['accessconstraints'], $this->cat[$i]['member'][$ii]['layer_id']);
-			$myac = $this->wfsDoc->createTextNode($row['accessconstraints']);
-			$ac->appendChild($myac);
-			// termsofuse
-			$ter = $this->wfsDoc->createElement('termsofuse');
-			$m->appendChild($ter);
-			$myter =  $this->wfsDoc->createTextNode($row['termsofuse']);
-			$ter->appendChild($myter);
-			//date
-			$date = $this->wfsDoc->createElement('date');
-			$m->appendChild($date);
-			$tdate = $this->wfsDoc->createTextNode(date("d.m.Y",$row['wfs_timestamp']));
-			$date->appendChild($tdate);
-			// Geomtype
-			$geo = $this->wfsDoc->createElement('geomtype');
-			$m->appendChild($geo);
-			//$geo_text = $this->getGeoType($row['wfs_id'], $row['featuretype_id']);
-			$geo_text = $this->wfsDoc->createTextNode($row['element_type']);
-			//$ge =  $this->wfsDoc->createTextNode($geo_text);
-			$geo->appendChild($geo_text);
-			//department
-			$dm = $this->wfsDoc->createElement('department');
-			$m->appendChild($dm);
-			$tdm = $this->wfsDoc->createTextNode($row['mb_group_name']);
-			$dm->appendChild($tdm);
-			//permission  		 Leseberechtigung des Benutzers(true), sonst Email zur Beantragung(email)
-			$per = $this->wfsDoc->createElement('permission');
-			$m->appendChild($per);
-			$per_text = $this->getPermissionValueForWFS($row['wfs_id'], $row['wfs_conf_id']);
-			$pe =  $this->wfsDoc->createTextNode($per_text);
-			$per->appendChild($pe);
-			//wfs_conf_id
-			$conf_id = $this->wfsDoc->createElement('wfs_conf_id');
-			$m->appendChild($conf_id);
-			$c_id = $this->wfsDoc->createTextNode($row['wfs_conf_id']);
-			$conf_id->appendChild($c_id);
-			//wfs_conf_title
-			$conf_title = $this->wfsDoc->createElement('wfs_conf_title');
-			$m->appendChild($conf_title);
-			$conf_title_text = $this->wfsDoc->createTextNode($row['wfs_conf_abstract']);
-			$conf_title->appendChild($conf_title_text);
-			//wfs_conf_abstract
-			$conf_abstract = $this->wfsDoc->createElement('wfs_conf_abstract');
-			$m->appendChild($conf_abstract);
-			$c_abstract = $this->wfsDoc->createTextNode($row['wfs_conf_description']);
-			$conf_abstract->appendChild($c_abstract);
-			//wfs_conf_modul
-			$conf_modul = $this->wfsDoc->createElement('wfs_conf_modul');
-			$m->appendChild($conf_modul);
-			$c_modul = $this->wfsDoc->createTextNode($row['modultype']);
-			$conf_modul->appendChild($c_modul);
-			$i++;
-		$c->setAttribute('count', $i);
+	echo "<br>DEBUG: filter: ".$queryFilter."<br>";
+	#echo "<br>DEBUG: searchTypeBbox: ".$searchTypeBbox."<br>";
+	$filename = $tempFolder."/".$searchId."_filter.json";
+	if (file_exists($filename)) {
+    		$e = new mb_notice("php/callMetdata.php: The file $filename exists - it will not be overwritten!");
-	private function getPermissionValueForWFS($wfs_id, $wfs_conf_id){
-		//TODO: Set Email of owner into view for ressource - so it don't have to be searched?
-		$return_permission = "";
-		//get permission
-		$myWFSconfs = $admin->getWfsConfByPermission($this->userId);
-		$this->myWFSConfs = $myWFSconfs;
-		for ($index = 0; $index < sizeof($this->myWFSConfs); $index++) {
-			$array_element = $this->myWFSConfs[$index];
-		if (in_array($wfs_conf_id, $this->myWFSConfs)){
-			$return_permission = "true";
+	} else {
+   		if($catFileHandle = fopen($filename, "w")){
+			fwrite($catFileHandle,$queryFilter);
+			fclose($catFileHandle);
+			$e = new mb_notice("php/callMetdata.php: new filter_file created!");
 		} else {
-			$sql = "SELECT wfs.wfs_id, mb_user.mb_user_email as email FROM wfs, mb_user where wfs.wfs_owner=mb_user.mb_user_id "."and wfs.wfs_id=$1";
-			$v = array($wfs_id);
-			$t = array('i');
-			// get email
-			$mail = "";
-				$mail = $row['email'];
-				$return_permission = $mail;
+		$e = new mb_notice("php/callMetdata.php: cannot create filter_file!");
-		return $return_permission;
-	private function getPermissionValueForLayer($layerId,$wmsId){
-		$return_permission="";
-		#$admin = new administration();
-		#$permission = $admin->getLayerPermission($wms_id, $layer_name, $this->userId);
-		#echo "<br>wms_id: ".$wms_id."<br>";
-		#echo "<br>layer_name: ".$layer_name."<br>";
-		#echo "<br>user_id: ".$this->userId."<br>";
-		#echo "<br>Permission: ".$permission."<br>";
-               # var_dump($this->accessableLayers);
-		if (in_array($layerId, $this->accessableLayers)){
-		} else {
-			$sql = "SELECT mb_user.mb_user_email as email FROM wms, mb_user WHERE wms.wms_owner=mb_user.mb_user_id";
-			$sql .= " AND wms.wms_id=$1";
-			$v = array($wmsId);
-			$t = array('i');
-			// get email
-			$mail="";
+//function to transpose a matrix - sometimes needed to do an array search
+function flipDiagonally($arr) {
+    	$out = array();
+    	foreach ($arr as $key => $subarr) {
+      		foreach ($subarr as $subkey => $subvalue) {
+        		$out[$subkey][$key] = $subvalue;
+   	return $out;
-	private function generateSearchStringArray() {
-		//'wfs test array' -> ('wfs' 'test' 'array')
-		$asstr = array();
-		if ($this->searchText != "false"){
-			$asstr = split(",",$this->searchText);
+//function to delete one of the comma separated values from one get request
+function delFromQuery($paramName,$queryString,$string,$queryArray,$queryList) {
+	//check if if count searchArray = 1
+	if (count($queryArray) == 1){
+		//remove request parameter from url by regexpr or replace
+		$str2search = $paramName."=".$queryList;
+		$str2exchange = "";
+		$queryStringNew = str_replace($str2search, $str2exchange, $queryString);
+		$queryStringNew = str_replace("&&", "&", $queryStringNew);
+	} else {
+	//there are more than one filter - reduce the filter
+		$objectList = "";
+		for($i=0; $i < count($queryArray); $i++){
+			if ($queryArray[$i] != $string){
+				$objectList .= $queryArray[$i].",";
-		return $asstr;
-	//out of php doc - test if it is faster than normal array_search
-	private function fast_in_array($elem, $array) {
-   		$top = sizeof($array) -1;
-   		$bot = 0;
-		while($top >= $bot) {
-			$p = floor(($top + $bot) / 2);
-			if ($array[$p] < $elem) $bot = $p + 1;
-			elseif ($array[$p] > $elem) $top = $p - 1;
-			else return TRUE;
-    	return FALSE;
+		//remove last comma
+		$objectList = rtrim($objectList, ",");
+		$str2exchange = $paramName."=".$objectList;
-	* filtering an array
-	private function filter_by_value ($array, $index, $value){
-        	if(is_array($array) && count($array)>0) {
-            		foreach(array_keys($array) as $key){
-                		$temp[$key] = $array[$key][$index];
-                		if ($temp[$key] == $value){
-                    			$newarray[$key] = $array[$key];
-      	return $newarray;
+	return $queryStringNew;
-	//function to get the parent of the given layer by crawling the layertree upwards
-	private function getLayerParent ($layerArray, $index){
-		//only layers of one service should be in $layerArray
-		#$parentExists = false;
-		#var_dump($layerArray);
-		$layerIDKey = $layerArray['layer_id'][$index];
-		#echo ("layerIDKey= ".$layerIDKey."<br>");
-		$layerParentPos = $layerArray['layer_parent'][$index];//get first parent object position
-		#echo ("layerParentPos= ".$layerParentPos."<br>");
-		#echo("<br>number of sublayers ".count(flipDiagonally($layerArray))."<br>");
-		#echo("<br>size of layerArray['layer_pos']: ".count($layerArray['layer_pos'])."<br>");
-		#var_dump($layerArray['layer_pos']);
-		#echo "<br>flipped layerArray: <br> ";
-		#var_dump(flipDiagonally($layerArray));
-		#echo "<br>";
+//function to remove one complete get param out of the query
+function delTotalFromQuery($paramName,$queryString) {
+	//echo $paramName ."<br>";
+	$queryString = "&".$queryString;
+	$queryStringNew = preg_replace('/\b'.$paramName.'\=[^&]*&?/',"",$queryString); //TODO find empty get params
+	$queryStringNew = ltrim($queryStringNew,'&');
+	$queryStringNew = rtrim($queryStringNew,'&');
-		if ($layerParentPos == '') {
-			//root layer directly found
-			return $index;
-		//Initialize index of layer parent - first it references the layer itself
-		$layerParentIndex = $index;
-		//loop to search higher parent objects - maybe this can be faster if the loop is not used over all sublayer elements! Do a while loop instead!
-		$highestParentLayerNotFound = true;
-		while ($highestParentLayerNotFound) {
-			#echo("<br>i= ".$i."<br>");
-			#echo("<br>layerParentPosNew= ".$layerParentPos."<br>");
-			$layerParentIndexNew = array_search((string)$layerParentPos, $layerArray['layer_pos']);
-			#echo("<br>layerParentIndexNew= ".$layerParentIndexNew."<br>");
-			if ($layerParentIndexNew != false) {
-				//some parent has been found
-				$layerParentIndex = $layerParentIndexNew;
-				$layerParentPos = $layerArray['layer_parent'][$layerParentIndex];
-					$highestParentLayerNotFound = false;
-					return $layerParentIndex; //a real root layer was found!
-				#$layerParentIndex = array_search($layerParentPos, $layerArray['layer_pos']);
-			} else {
-				$highestParentLayerNotFound = false; //no higher layer could be found
-	//function to write the child elements to the resulting wms object -> object is given by reference
-	private function writeWMSChilds($layerIdArray, $rootLayerPos, $subLayers, &$servObject) {
-		#echo "test";
-		#echo "<br>subLayers:<br>";
-		#var_dump($subLayers);
-		#echo "<br>";
-		$childLayers = $this->filter_by_value($subLayers, 'layer_parent', $rootLayerPos); //the root layer position in the sublayer array was located before. In this step, all layers will be pulled out of sublayer, where root layer position is parent object
-		#echo "<br<childLayers:<br>";
-		#var_dump($childLayers);
-		#echo "<br>";
-		#echo "test";
-		#print_r($childLayers);
-		$countsublayer = 0;
-		//if child exists create a new layer array for these
-		if (count($childLayers) != 0) {
-			$servObject->layer = array();
-		foreach ($childLayers as $child){
-			#echo "<br>countsublayer: ".$countsublayer."<br>";
-			#echo "<br>Child id: ".$child['layer_id']."<br>";
-			#echo "<br>Child pos: ".$child['layer_pos']."<br>";
-			$servObject->layer[$countsublayer]->id = $child['layer_id'];
-			$servObject->layer[$countsublayer]->title = $child['layer_title'];
-			$servObject->layer[$countsublayer]->abstract = $child['layer_abstract'];
-			$servObject->layer[$countsublayer]->mdLink = "http://".$_SERVER['HTTP_HOST']."/mapbender/x_geoportal/mod_layerMetadata.php?id=".$child['layer_id'];
-			if ($child['layer_name'] == ''){
-				$servObject->layer[$countsublayer]->loadable = 0;
-			} else {
-				$servObject->layer[$countsublayer]->loadable = 1;
-			if ($child['md_inspire_cats'] == ''){
-				$servObject->layer[$countsublayer]->inspire = 0;
-			else {
-				$servObject->layer[$countsublayer]->inspire = 1;
-			if ($child['layer_queryable'] == 1){
-				$servObject->layer[$countsublayer]->queryable = 1;
-			else {
-				$servObject->layer[$countsublayer]->queryable = 0;
-			$servObject->layer[$countsublayer]->loadCount = $child['load_count'];
-			$servObject->layer[$countsublayer]->bbox = $child['bbox'];
-			$servObject->layer[$countsublayer]->permission = $this->getPermissionValueForLayer($child['layer_id'],$child['wms_id']); //TODO: make this much faster!!!! - is done by collecting all accessable resources once. Maybe this has to be adopted if the count of the resources become higher
-			//call this function itself - search sublayers in the layer object.
-			$layerIdArray = $this->writeWMSChilds($layerIdArray, $child['layer_pos'], $subLayers, $servObject->layer[$countsublayer]);//TODO create a timeout condition !
-			array_push($layerIdArray, $child['layer_id']); //child have been identified and recursively written
-			#var_dump($layerIdArray);#
-			#echo "<br>";
-			$countsublayer ++;
-		return $layerIdArray;
+//call class_metadata - in case of file for all requested resources, in case of web only for one resource - cause there are different result files
-	private function delTotalFromQuery($paramName,$queryString) {
-		$queryString = "&".$queryString;
-		#echo "<br>queryString: ".$queryString."<br>";
-		$queryStringNew = preg_replace('/\b'.$paramName.'\=[^&]+&?/',"",$queryString);
-		$queryStringNew = ltrim($queryStringNew,'&');
-		$queryStringNew = rtrim($queryStringNew,'&');
-		return $queryStringNew;
+	for($i=0; $i<count($searchResources);$i++){
+		$str = "nohup php5 /data/mapbender/http/php/mod_metadataWrite.php ";
+		$str .= "'".$userId."' ";
+		$str .= "'".$searchId."' ";
+		$str .= "'".$searchText."' ";
+		$str .= "'".$registratingDepartments."' ";
+		$str .= "'".$isoCategories."' ";
+		$str .= "'".$inspireThemes."' ";
+		$str .= "'".$timeBegin."' ";
+		$str .= "'".$timeEnd."' ";
+		$str .= "'".$regTimeBegin."' ";
+		$str .= "'".$regTimeEnd."' ";
+		$str .= "'".$maxResults."' ";
+		$str .= "'".$searchBbox."' ";
+		$str .= "'".$searchTypeBbox."' ";
+		$str .= "'".$accessRestrictions."' ";
+		$str .= "'".$languageCode."' ";
+		$str .= "'".$searchEPSG."' ";
+		$str .= "'".$searchResources[$i]."' ";
+		$str .= "'".$searchPages[$i]."' ";
+		$str .= "'".$outputFormat."' ";
+		$str .= "'".$resultTarget."' ";
+		$str .= "'".$searchURL."' ";
+		$str .= "'".$customCategories."' ";
+		$str .= "'".$hostName."' ";
+		$str .= "'".$orderBy."' ";
+		$str .= " & ";
+		$e = new mb_exception($str);
+		exec($str);
+	if (count($searchResources) == 1) {
+		$metadata = new searchMetadata($userId, $searchId, $searchText, $registratingDepartments, $isoCategories, $inspireThemes, $timeBegin, $timeEnd, $regTimeBegin, $regTimeEnd, $maxResults, $searchBbox, $searchTypeBbox, $accessRestrictions, $languageCode, $searchEPSG, $searchResources[0], $searchPages[0], $outputFormat, $resultTarget, $searchURL, $customCategories, $hostName, $orderBy);
+		#if ($outputFormat == 'xml') {
+		#	header("Content-type: application/xhtml+xml; charset=UTF-8");
+		#echo "class initiated<br>";
+	else {
+		echo "Result for web can only requested for one type of resource (wms, wfs, wmc, georss)!";
+How does the webservice look like?
+First request: Do search for all classes.
+Next request: Search only in the requested class and the numbered page.
+search.php?q=test&classes=wms,wfs,wmc,georss&pages=1,1,1,1&iso=1,2,3&inspire=1,2,3,4&department=1,2,3,4&bbox=123,123,123,123
+simple other request:
+search.php?q=test&classes=wms&pages=2&iso=1,2,3&inspire=1,2,3,4&department=1,2,3,4&beginDate=2009-10-10&endDate=2010-11-12&searchId=12hjxa31231
+There is a possibility to exchange some classes by other information - the id will be used to update the search result files - but this can only update the class infos. The pagenumber should be updated in the metadata file
+//Name of searchMetadata file
+//searchid_classes.json
+//Name of searchCategories file
+//Name of searchResult files
+//searchid_wms_1.json
+//searchid_wfs_1.json
+//searchid_wmc_1.json - doesn't exists till now
+//searchid_georss_1.json - doesn't exists till now
+//categories files - will only be generated when the search is started and resultType = 'file'. if the categories files already exists it will not be updated! - Here we can spare a reasonable amount of calculating power. Another approach is to generate a md5 hash of an ordered searchURL. With this we can cache the requests!
+//searchid_wms_cat.json
+//searchid_wfs_cat.json
+//searchid_wmc_cat.json - doesn't exists till now
+//searchid_georss_cat.json - doesn't exists till now
+//searchid_filter.json
\ No newline at end of file
Added: trunk/mapbender/http/javascripts/mod_deleteWfsConf_client.html
--- trunk/mapbender/http/javascripts/mod_deleteWfsConf_client.html	                        (rev 0)
+++ trunk/mapbender/http/javascripts/mod_deleteWfsConf_client.html	2010-04-22 09:45:43 UTC (rev 5998)
@@ -0,0 +1,220 @@
+<html>
+<head>
+<meta http-equiv="content-type" content="text/html;CHARSET=iso-8859-1">
+<link rel="stylesheet" type="text/css" media="screen,projection" href="../css/admin.screen.css" title="screen" />
+<script type='text/javascript'>
+ * services['action']: instructs the servercomponent
+ * services['services']: infos about the services (wfs)
+ * services['services']['id']: a list of ids
+ * services['service']['title']: a corresponding list of titles
+var services = {};
+ * wfsConf['action']: instructs the servercomponent
+ * wfsConf['wfs']: the ID of the selected wfs
+ * wfsConf['wfsConf']: infos about the wfs configurations
+ * wfsConf['wfsConf']['id']: a list of ids
+ * wfsConf['wfsConf']['abstract']: a corresponding list of descriptions
+var wfsConf = {};
+ * guis['action']: instructs the servercomponent
+ * guis['id']: a list of gui-IDs where the current user is owner
+ * guis['selectedGui']: the selected Gui
+var guis = {};
+ * handleAssignment['action']: instructs the servercomponent
+ * handleAssignment['selectedConf']: a list of wfs-conf Ids
+ * handleAssignment['selectedGui']: the selected Gui
+var handleAssignment = {}
+ * deleteWfsConf['action']: instructs the servercomponent
+ * deleteWfsConf['confs']: a list of wfs-conf Ids to delete
+ var deleteWfsConf = {};
+function getWfsList(){
+	services['action'] = 'getServices';
+	getData(services);
+function getWfsConfData(){
+	wfsConf['action'] = 'getWfsConfData';
+	wfsConf['wfs'] = getSelectedWfs();
+	getData(wfsConf);
+function getSelectedWfs(){
+	var w = document.wfsForm.wfsList;
+	var ind  = w.selectedIndex;
+	if(ind == -1){
+		return false;
+//	if(ind == w.options.length-1){
+//		return "gui_confs";
+	return w.options[ind].value;
+function getGuiConfs(){
+	guis['action'] = 'getAssignedGuis';
+	guis['selectedWfs'] = wfsConf['wfs'];
+	guis['selectedConf'] =getSelectedConfs();
+	getData(guis);
+function deleteWfsConfs(){
+	deleteWfsConf['action'] = 'deleteSelectedConfs';
+	deleteWfsConf['confs'] = getSelectedConfs();
+	if(deleteWfsConf['confs']){
+		if(confirm("Do you really want to delete the Wfs conf with ID:"+deleteWfsConf['confs']+"?")){
+			getData(deleteWfsConf);
+		return true;
+	return false;
+function setIndicator(){
+	var str = "<img src='../img/indicator_wheel.gif'>";
+	document.getElementById("indicator").innerHTML = str;
+function removeIndicator(){
+	document.getElementById("indicator").innerHTML = "";
+ * Ajax-function to get data from the server
+function getData(obj){
+//console.log(obj);
+	setIndicator();
+	var obj2json = parent.$.toJSON(obj);
+	parent.mb_ajax_post("../php/mod_deleteWfsConf_server.php",{"obj":obj2json}, function (json,status){
+		if(status == 'success'){
+			var dsJson = eval('(' + json + ')');
+			switch(obj['action']){
+				case "getServices":
+					appendServices(dsJson);
+				break;
+				case "getWfsConfData":
+					appendWfsConfData(dsJson);
+				break;
+				case "deleteSelectedConfs":
+					if(dsJson['success']){
+						alert("WFS conf deleted.");
+						getWfsConfData();
+				break;
+				case "getAssignedGuis":
+					checkGuiConfs(dsJson);
+				break;
+				case "remove":
+					getGuiConfs();
+				break;
+				default:
+					alert("No action specified.....");
+				break;
+		else{
+			alert("An error occured!");
+		removeIndicator();
+function removeChildNodes(node) {
+	while (node.childNodes.length > 0) {
+		var childNode = node.firstChild;
+		node.removeChild(childNode);
+function appendServices(dsJson){
+	services['services'] = dsJson.services;
+	var o = services['services'];
+	removeChildNodes(document.getElementById('wfsList'));
+	for(var i=0; i<o.id.length; i++){
+		appendOption(document.forms[0].wfsList, o.title[i], o.id[i], false);
+	//appendOption(document.forms[0].wfsList, "WFS Configurations", "-1", false);
+function appendWfsConfData(dsJson){
+	wfsConf['wfsConf'] = {};
+	wfsConf['wfsConf'] = dsJson.wfsConf;
+	var o = wfsConf['wfsConf'];
+	document.forms[0].wfsConfList.innerHTML = '';
+	if(o.id){
+			appendOption(document.forms[0].wfsConfList, o.abstract[i], o.id[i], false);
+function checkGuiConfs(dsJson){
+	var checkedGuis = '';
+	for(var i=0; i<dsJson.assignedGuis.length; i++){
+		if(i>0){
+			checkedGuis += ", ";
+		checkedGuis += dsJson.assignedGuis[i];
+		//checkedGuis.push(dsJson.assignedGuis[i]);
+	if(dsJson.assignedGuis.length>0){
+		alert("Achtung: WFS-Konfiguration wird noch in den Guis "+checkedGuis+" verwendet.");
+function getSelectedConfs(){
+	var list = document.forms[0].wfsConfList;
+	var confs = [];
+	for(var i=0; i<list.length; i++){
+		if(list.options[i].selected === true){
+			confs.push(list.options[i].value);
+	return confs;
+function appendOption(boxObject, optionText, optionValue, selected){
+	var newOption = new Option(optionText,optionValue,false,selected);
+	boxObject.options[boxObject.length] = newOption;
+</script>
+</head>
+<body onload='getWfsList();'>
+<h1>Delete WFS Configuration </h1>
+<form name='wfsForm'>
+	<div id='indicator'>ahh</div>
+	<fieldset class="leftContainer">
+	<legend>WFS List</legend>
+		<p>
+			<select size='4' name='wfsList' id='wfsList' class='wfsList' onchange='getWfsConfData();'></select>
+		</p>
+	</fieldset>
+	<legend>WFS Configuration List</legend>
+		<p>
+			<select size='4' name='wfsConfList' class='wfsConfList' onchange='' multiple="multiple"></select>
+		</p>
+		<input type='button' value='Delete WFS Conf' name='delete' id='deleteButton' onclick='getGuiConfs();deleteWfsConfs();' />
+	</fieldset>
+	<hr />
+</form>
+</body>
+</html>
Modified: trunk/mapbender/http/php/mod_callMetadata.php
--- trunk/mapbender/http/php/mod_callMetadata.php	2010-04-21 15:37:42 UTC (rev 5997)
+++ trunk/mapbender/http/php/mod_callMetadata.php	2010-04-22 09:45:43 UTC (rev 5998)
@@ -14,6 +14,7 @@
 #http://www.geoportal.rlp.de/mapbender/php/mod_callMetadata.php?searchId=wa&searchText=e&outputFormat=json&languageCode=de&resultTarget=debug&searchResources=wms&maxResults=99&registratingDepartments=44,31,52&inspireThemes=11&isoCategories=5,10&searchBbox=7,48,9,51&regTimeBegin=2001-12-24&regTimeEnd=2020-10-10
 #http://www.geoportal.rlp.de/mapbender/php/mod_callMetadata.php?searchId=wa&outputFormat=json&languageCode=de&resultTarget=debug&searchResources=wms&maxResults=99&registratingDepartments=44,31,52&inspireThemes=11&isoCategories=5,10&searchBbox=7,48,9,51&regTimeBegin=2001-12-24&regTimeEnd=2020-10-10
 require_once(dirname(__FILE__)."/../../conf/mapbender.conf");
+require_once(dirname(__FILE__)."/../../conf/geoportal.conf");
 require_once(dirname(__FILE__)."/../classes/class_metadata_new.php");
 require_once(dirname(__FILE__)."/../classes/class_json.php");
 session_start();
@@ -43,10 +44,31 @@
 $resultTarget = "debug";
 $searchEPSG = "EPSG:31466";
 $classJSON = new Mapbender_JSON;
-$tempFolder = "/tmp";
+#$tempFolder = "/tmp";
+$tempFolder = TMPDIR;
+$orderBy = "rank"; //rank or title or id
+$hostName = $_SERVER['HTTP_HOST'];
+//read the whole query string:
+$searchURL = $_SERVER['QUERY_STRING'];
+//control if some request variables are not set and set them explicit to NULL
+$checkForNullRequests = array("registratingDepartments","isoCategories","inspireThemes","customCategories","regTimeBegin","regTimeEnd","timeBegin","timeEnd","searchBbox","searchTypeBbox","searchResources","orderBy","hostName");
+for($i=0; $i < count($checkForNullRequests); $i++){
+	if (!$_REQUEST[$checkForNullRequests[$i]] or $_REQUEST[$checkForNullRequests[$i]] == 'false' or $_REQUEST[$checkForNullRequests[$i]] == 'undefined') {
+		$_REQUEST[$checkForNullRequests[$i]] = "";
+		$searchURL = delTotalFromQuery($checkForNullRequests[$i],$searchURL);
 //Read out request Parameter:
 if (isset($_REQUEST["searchId"]) & $_REQUEST["searchId"] != "") {
 	//gernerate md5 representation, cause the id is used as a filename later on! - no validation needed
@@ -123,7 +145,7 @@
 if (isset($_REQUEST["timeEnd"]) & $_REQUEST["timeEnd"] != "") {
 	$testMatch = $_REQUEST["timeEnd"];
-	$pattern = '/(19|20)[0-9]{2}[- /.](0[1-9]|1[012])[- /.](0[1-9]|[12][0-9]|3[01])/';
+	$pattern = '/^(19|20)[0-9]{2}[-](0[1-9]|1[012])[-](0[1-9]|[12][0-9]|3[01])$/';
  	if (!preg_match($pattern,$testMatch)){
 		echo 'timeEnd: <b>'.$testMatch.'</b> is not valid.<br/>';
 		die();
@@ -166,24 +188,28 @@
 	$testMatch = NULL;
 if (isset($_REQUEST["searchBbox"]) & $_REQUEST["searchBbox"] != "") {
-	//validate to csv integer list
+	//validate to float/integer
 	$testMatch = $_REQUEST["searchBbox"];
-	$pattern = '/^[-\d,]*$/';
- 	if (!preg_match($pattern,$testMatch)){
-		echo 'searchBbox: <b>'.$testMatch.'</b> is not valid.<br/>';
-		die();
-	if (count(explode(',',$testMatch)) != 4) {
+	//$pattern = '/^[-\d,]*$/';
+	$pattern = '/^[-+]?([0-9]*\.[0-9]+|[0-9]+)*$/';
+	$testMatchArray = explode(',',$testMatch);
+ 	if (count($testMatchArray) != 4) {
 		echo 'searchBbox: <b>'.$testMatch.'</b> has a wrong amount of entries.<br/>';
 		die();
+	for($i=0; $i<count($testMatchArray);$i++){
+		if (!preg_match($pattern,$testMatchArray[$i])){
+			echo 'searchBbox: <b>'.$testMatchArray[$i].'</b> is not a valid coordinate value.<br/>';
+			die();
 	$searchBbox = $testMatch;
 	$testMatch = NULL;
 if (isset($_REQUEST["searchTypeBbox"]) & $_REQUEST["searchTypeBbox"] != "") {
 	//validate to inside / outside - TODO implement other ones than intersects which is default
 	$testMatch = $_REQUEST["searchTypeBbox"];
- 	if (!($testMatch == 'inside' or $testMatch == 'outside')){
+ 	if (!($testMatch == 'inside' or $testMatch == 'outside' or $testMatch == 'intersects')){
 		echo 'searchTypeBbox: <b>'.$testMatch.'</b> is not valid.<br/>';
 		die();
@@ -213,6 +239,26 @@
 	$outputFormat = $testMatch;
 	$testMatch = NULL;
+if (isset($_REQUEST["hostName"]) & $_REQUEST["hostName"] != "") {
+	$testMatch = $_REQUEST["hostName"];
+ 	if (!($testMatch == 'www.geoportal.rlp' or $testMatch == 'www.geoportal.rlp.de' or $testMatch == 'geoportal.rlp' or $testMatch == '10.7.101.165' or $testMatch == 'localhost:16580' or $testMatch == 'localhost')){
+		echo 'hostName: <b>'.$testMatch.'</b> is not valid.<br/>';
+		die();
+	$hostName = $testMatch;
+	$testMatch = NULL;
+if (isset($_REQUEST["orderBy"]) & $_REQUEST["orderBy"] != "") {
+	$testMatch = $_REQUEST["orderBy"];
+ 	if (!($testMatch == 'rank' or $testMatch == 'title' or $testMatch == 'id')){
+		echo 'orderBy: <b>'.$testMatch.'</b> is not valid.<br/>';
+		die();
+	$orderBy = $testMatch;
+}// else {
+//$orderBy= 'rank';
 if (isset($_REQUEST["searchResources"]) & $_REQUEST["searchResources"] != "") {
 	//validate to wms,wfs,wmc,georss
 	$testMatch = $_REQUEST["searchResources"];
@@ -262,15 +308,32 @@
 	$resultTarget = $testMatch;
 	$testMatch = NULL;
-//validate request parameters
-if (!isset($_SESSION['mb_user_id'])) {
-	$userId = ANONYMOUS_USER;
+if (isset($_REQUEST["userId"]) & $_REQUEST["userId"] != "") {
+        //validate integer to 100 - not more
+        $testMatch = $_REQUEST["userId"];
+        //give max 99 entries - more will be to slow
+        $pattern = '/^[0-9]*$/';
+        if (!preg_match($pattern,$testMatch)){
+                echo 'userId: <b>'.$testMatch.'</b> is not valid.<br/>';
+                die();
+        $userId = $testMatch;
+} else {
+if (!isset($_SESSION['mb_user_id']) ) {
+        $userId = ANONYMOUS_USER;
 else
-	$userId = $_SESSION['mb_user_id'];
+        $userId = $_SESSION['mb_user_id'];
@@ -278,8 +341,15 @@
-//read the whole query string:
-$searchURL = $_SERVER['QUERY_STRING'];
@@ -489,6 +559,12 @@
        	break;
         case 'en':
@@ -506,6 +582,11 @@
         break;
         case 'fr':
@@ -522,6 +603,11 @@
        	break;
      	default:
@@ -538,10 +624,16 @@
@@ -601,10 +693,56 @@
-//write out json to file or web
+} else {
+					case "rank":
+						break;
+					case "id":
+						break;
+					case "title":
+						break;
@@ -613,13 +751,19 @@
-		fwrite($catFileHandle,$queryFilter);
-		$e = new mb_notice("php/callMetdata.php: new filter_file created!");
 	} else {
+		} else {
@@ -660,8 +804,9 @@
@@ -697,6 +842,8 @@
 		$str .= " & ";
 		exec($str);
@@ -704,7 +851,7 @@
-		$metadata = new searchMetadata($userId, $searchId, $searchText, $registratingDepartments, $isoCategories, $inspireThemes, $timeBegin, $timeEnd, $regTimeBegin, $regTimeEnd, $maxResults, $searchBbox, $searchTypeBbox, $accessRestrictions, $languageCode, $searchEPSG, $searchResources[0], $searchPages[0], $outputFormat, $resultTarget, $searchURL, $customCategories);
Modified: trunk/mapbender/http/php/mod_deleteWFS.php
--- trunk/mapbender/http/php/mod_deleteWFS.php	2010-04-21 15:37:42 UTC (rev 5997)
+++ trunk/mapbender/http/php/mod_deleteWFS.php	2010-04-22 09:45:43 UTC (rev 5998)
@@ -17,10 +17,17 @@
 # along with this program; if not, write to the Free Software
 # Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+#session_start();
+$e_id="deleteWFS";
 import_request_variables("PG");
-$e_id="deleteWFS";
 require_once(dirname(__FILE__)."/../php/mb_validatePermission.php");
-require_once(dirname(__FILE__)."/../classes/class_administration.php");
+#require_once(dirname(__FILE__)."/../../conf/mapbender.conf");
+#$con = db_connect($DBSERVER,$OWNER,$PW);
+#db_select_db(DB,$con);
+#require_once(dirname(__FILE__)."/../classes/class_administration.php");
+#$admin = new administration();
+#$ownguis = $admin->getGuisByOwner($_SESSION["mb_user_id"],true);
+$gui_id = Mapbender::session()->get("mb_user_gui");
 <!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
@@ -40,14 +47,61 @@
 <script type="text/javascript">
 function validate(){
 	var ind = document.form1.wfsList.selectedIndex;
+	var wfsData = document.form1.wfsList.options[ind].value.split("###");
 	if(ind > -1){
-		var permission =  confirm("delete: "  + document.form1.wfsList.options[ind].text + " ?");
+		var permission =  confirm("delete: "  + wfsData[0] + " ?");
 		if(permission === true){
-			document.form1.del.value = 1;
+			document.form1.del.value = wfsData[0];
 			document.form1.submit();
+function sel(){
+	var ind = document.form1.wfsList.selectedIndex;
+	var i,wfsConfList,wfsConfLinkList;
+	var wfsConfList = wfsData[1].split(",");
+	//document.form1.capURL.value = wmsData[1];
+	//document.form1.myWMS.value = wmsData[0];
+	//new for showing metadata - 30.05.2008 AR
+	document.getElementById("metadatalink").href = "mod_wfsMetadata.php?wfs_id="+wfsData[0];
+	document.getElementById("metadatatext").firstChild.nodeValue = "WFS-ID: "+wfsData[0];
+	//delete all childs of wfsconflist
+	var countChild = document.getElementById("wfsconflist").childNodes.length;
+	for (i = 0; i < countChild; ++i) {
+			document.getElementById("wfsconflist").removeChild(document.getElementById("wfsconflist").childNodes[0]);
+	//document.getElementById("wfsconflist").removeChild(document.getElementById("wfsconflist").firstChild);
+	if (wfsData[1] != "") {
+	for (i = 0; i < wfsConfList.length; ++i) {
+		//create anchors:
+		var newAnchor = document.createElement("a");
+		//var newBr = document.createElement("br");
+		var newSpace = document.createTextNode(" | ");
+		var newAnchorText = document.createTextNode("WFS-CONF: " + wfsConfList[i]);
+		//set anchor href
+		newAnchor.setAttribute("href", "mod_featuretypeMetadata.php?wfs_conf_id=" + wfsConfList[i]);
+		newAnchor.setAttribute("onclick","window.open(this.href,'Metadaten','width=500,height=600,left=100,top=200,scrollbars=yes ,dependent=yes'); return false");
+		newAnchor.appendChild(newAnchorText);
+		//newAnchor.appendChild(newSpace);
+		//append childs
+		document.getElementById("wfsconflist").appendChild(newAnchor);
+		document.getElementById("wfsconflist").appendChild(newSpace);
+	//delete last komma
+	document.getElementById("guilist").firstChild.nodeValue = wfsData[2];
+	//ggf. create child
+	//document.getElementById("wfsConfTable").firstChild.nodeValue = wfsConfLinkList;
+	//end ***
 </script>
 <style type="text/css">
@@ -69,29 +123,94 @@
 $logged_user_id=Mapbender::session()->get("mb_user_id");
 ###delete
-if($wfsList){
-	 $sql = "DELETE FROM wfs WHERE wfs_id = $1";
-	 $v = array($wfsList);
-	 $t = array("i");
-	 $res = db_prep_query($sql, $v, $t);
+if($_REQUEST['del']!='-1'){
+	 $sql = "DELETE FROM wfs WHERE wfs_id = '".$_REQUEST['del']."'";
+	 $res = db_query($sql);
-$sql_wfs = "SELECT * FROM wfs ORDER BY wfs_id";
+//adopted for owned wfs and not all!!!!!!
+$sql_wfs = "SELECT * FROM wfs ";
+$sql_wfs .= " where wfs_owner=".$_SESSION["mb_user_id"]." ORDER BY wfs_name";
 $res_wfs = db_query($sql_wfs);
 $cnt_wfs = 0;
-echo "<form name='form1' action='" . $self ."' method='post'>";
+echo "<form name='form1' action='" . $PHP_SELF . "?".SID."' method='post'>";
 echo "<br><b>WFS List: <b><br><br>";
-echo "<select class='wfsList' size='20' name='wfsList' >";
+echo "<select class='wfsList' size='20' name='wfsList'  onchange='sel();'>";
+//var wfsInfo = this.value.split(\"###\");document.form1.wfsList.value=wfsInfo[0];
+//morgen zu kontrollieren
-while($row = db_fetch_array($res_wfs)){
-	echo "<option value='".$row["wfs_id"]."'>".$row["wfs_id"]." ".$row["wfs_name"]." - ".$row["wfs_title"]."</option>";
+while($row1 = db_fetch_array($res_wfs)){
+	$wfs_conf_gui=array();
+	//$wfs_conf_gui_single=array();
+	$wfs_conf_id=array();
+	//get wfs_conf information by wfs_id
+	$sql_wfs_conf = "SELECT  wfs_conf_id, wfs_conf_abstract from wfs_conf where fkey_wfs_id=".$row1["wfs_id"]."";
+	$res_wfs_conf = db_query($sql_wfs_conf);
+	$cnt_wfs_conf=0;
+	while($row2 = db_fetch_array($res_wfs_conf)){
+		//$wfs_conf[$cnt_wfs_conf]=$row2["wfs_conf_id"];
+		array_push($wfs_conf_id,$row2["wfs_conf_id"]);
+		//get GUI list assigned to wfs_conf
+		$sql_wfs_conf_gui = "select fkey_gui_id from gui_element_vars where var_name = 'wfsConfIdString' and ',' || var_value || ',' like '%,".$row2["wfs_conf_id"].",%'";
+		$res_wfs_conf_gui = db_query($sql_wfs_conf_gui);
+		$cnt_wfs_gui=0;
+		while($row3 = db_fetch_array($res_wfs_conf_gui)){
+			array_push($wfs_conf_gui,$row3["fkey_gui_id"]);
+			//$wfs_conf_gui[$cnt_wfs_gui]=$row3["wfs_conf_id"];
+			$cnt_wfs_gui++;
+		$cnt_wfs_conf++;
+	//make the entries unique
+	$unique_wfs_conf=array_unique($wfs_conf_id);
+	$unique_wfs_gui=array_unique($wfs_conf_gui);
+	//create lists:
+	$str_wfs_conf="";
+	$str_wfs_gui="";
+	for ($i = 0; $i < count($unique_wfs_conf); $i++) {
+    		$str_wfs_conf.=",".$unique_wfs_conf[$i];
+	$str_wfs_conf=ltrim($str_wfs_conf, ",");
+	for ($i = 0; $i < count($unique_wfs_gui); $i++) {
+    		$str_wfs_gui.=",".$unique_wfs_gui[$i];
+	$str_wfs_gui=ltrim($str_wfs_gui, ",");
+	//output to table
+	echo "<option value='".$row1["wfs_id"]."###".$str_wfs_conf."###".$str_wfs_gui."'>".$row1["wfs_name"]." - ".$row1["wfs_title"]."</option>";
 	$cnt_wfs++;
 echo "</select><br><br>";
+<!--Line for showing wfs metadata-->
+	View wfs metadata: <a id='metadatalink' href='' onclick="window.open(this.href,'Metadata','width=500,height=600,left=100,top=200,scrollbars=yes ,dependent=yes'); return false" target="_blank"><span id="metadatatext">no WFS selected</span></a><br><br>
+List of dependend wfs_conf:
+ <div id="wfsconflist"> no WFS selected</div><br><br>
+List of GUIs where dependend wfs_conf are used:<span id="guilist"> no WFS selected</span><br><br>
+<?php
+//kann ja nur beim neu laden passieren. Man sollte hier dynamisch was hineinsetzen lassen(javascript) dafuer muss es aber schon vorher ausgewaehlt worden sein, d.h. die options um titel_list, abstarct_list, wfs_conf_id_list, sowie GUI_list erweitern lassen. is aufwand!
+//Liste der wfs_conf's
+//SELECT wfs_conf_id, wfs_conf_abstract from wfs_conf where fkey_wfs_id=...
+//hier muss tabelle angezeigt werden
+//Liste der GUI's die eine WFS Conf des WFS enthalten
+//select fkey_gui_id from gui_element_vars where var_name = 'wfsConfIdString' and ',' || var_value || ',' like '%,54,%'
+//muss iterativ ueber or verknuepft werden!
 echo "<input class='button_del' type='button' value='delete' onclick='validate()'>";
-<input type='hidden' name='del'>
+<input type='hidden' name='del' value='-1'>
 </form>
 </body>
 </html>
Added: trunk/mapbender/http/php/mod_deleteWfsConf_server.php
--- trunk/mapbender/http/php/mod_deleteWfsConf_server.php	                        (rev 0)
+++ trunk/mapbender/http/php/mod_deleteWfsConf_server.php	2010-04-22 09:45:43 UTC (rev 5998)
@@ -0,0 +1,190 @@
+<?php
+session_start();
+include_once(dirname(__FILE__)."/../../conf/mapbender.conf");
+require_once(dirname(__FILE__)."/../classes/class_administration.php");
+require_once(dirname(__FILE__)."/../classes/class_mb_exception.php");
+require_once(dirname(__FILE__)."/../classes/class_wfs.php");
+include_once(dirname(__FILE__)."/../extensions/JSON.php");
+//db connection
+$con = db_connect(DBSERVER,OWNER,PW);
+db_select_db(DB,$con);
+$json = new Services_JSON();
+$obj = $json->decode(stripslashes($_REQUEST['obj']));
+//workflow:
+switch($obj->action){
+	case 'getServices':
+		$obj->services = getServices($obj);
+		sendOutput($obj);
+	break;
+	case 'getWfsConfData':
+		$obj->wfsConf = getWfsConfData($obj->wfs);
+		sendOutput($obj);
+	break;
+	case 'getAssignedGuis':
+		$obj->assignedGuis = getAssignedGuis($obj);
+		sendOutput($obj);
+	break;
+	case 'deleteSelectedConfs':
+		deleteWfsConf($obj);
+		sendOutput($obj);
+	break;
+	default:
+		sendOutput("no action specified...");
+ * Get all services (ids and titles) where the current user is owner
+ * @return mixed[] services the ids and titles of the services
+function getServices(){
+	global $con;
+	$services = array();
+	$services['id'] = array();
+	$services['title'] = array();
+	$adm = new administration();
+	$serviceList = $adm->getWfsByOwner($_SESSION['mb_user_id']);
+	if(count($serviceList) == 0){
+		return false;
+	$sql = "SELECT * FROM wfs WHERE wfs_id IN(".join(",",$serviceList).") ORDER BY wfs_title";
+	while($row = db_fetch_array($res)){
+		array_push($services['id'], $row['wfs_id']);
+		array_push($services['title'], $row['wfs_title']);
+	return $services;
+ * Get all configurations of the selcted wfs if the current user is owner
+ * @return mixed[]
+function getWfsConfData($wfsID){
+	global $con;
+	// re-check permission
+	if(in_array($wfsID, $serviceList)){
+		$wfsConf = array();
+		$wfsConf['id'] = array();
+		$wfsConf['abstract'] = array();
+		$sql = "SELECT * FROM wfs_conf WHERE fkey_wfs_id = $1 ORDER BY wfs_conf_abstract";
+		$v = array($wfsID);
+		$t = array('i');
+		$res = db_prep_query($sql,$v,$t);
+		$cnt = 0;
+			array_push($wfsConf['id'], $row['wfs_conf_id']);
+			array_push($wfsConf['abstract'], $row['wfs_conf_abstract']);
+			$cnt++;
+		if($cnt == 0){
+			return false;
+		else{
+			return $wfsConf;
+//	else if($wfsID==="gui_confs"){
+//		$wfsConf = array();
+//		$wfsConf['id'] = array();
+//		$wfsConf['abstract'] = array();
+//		$wfsConf['id'] = $adm->getWfsConfByPermission($_SESSION['mb_user_id']);
+//		$cnt = 0;
+//		foreach($wfsConf['id'] as $wfscid){
+//			$sql = "SELECT wfs_conf_abstract FROM wfs_conf WHERE wfs_conf_id = $1";
+//			$v = array($wfscid);
+//			$t = array('i');
+//			$res = db_prep_query($sql,$v,$t);
+//			while($row = db_fetch_array($res)){
+//				array_push($wfsConf['abstract'], $row['wfs_conf_abstract']);
+//			$cnt++;
+//		if($cnt == 0){
+//			return false;
+//		else{
+//			return $wfsConf;
+ * get all guis which are assigned to the selected wfs conf
+ * @param
+ * @return mixed[]
+function getAssignedGuis($obj){
+	global $con;
+	$guis = array();
+	$wfsConf['id'] = $obj->selectedConf;
+	$confs = "";
+	foreach($wfsConf['id'] as $wfsConfId){
+		if($confs!=''){
+			$confs .= ",";
+		$confs .= $wfsConfId;
+	if($confs === false){
+		return false;
+	$sql = "SELECT * FROM gui_wfs_conf WHERE fkey_wfs_conf_id IN (".$confs.")";
+	if(!$res){
+		$e = new mb_exception("Error: SQL: " . $sql . " -> WFS conf: " .$obj->selectedConf);
+		array_push($guis, $row['fkey_gui_id']);
+	return $guis;
+ * deletes a WFS conf
+ * @param object the un-encoded object
+ * @return boolean success
+function deleteWfsConf($obj){
+	global $con;
+	$wfsConf['id'] = $obj->confs;
+		$sql = "DELETE FROM gui_wfs_conf WHERE fkey_wfs_conf_id =$1";
+		$v = array($wfsConfId);
+		$t = array('i');
+		$sql1 = "DELETE FROM wfs_conf WHERE wfs_conf_id = $1";
+		$v1 = array($wfsConfId);
+		$t1 = array('i');
+		$res1 = db_prep_query($sql1,$v1,$t1);
+	$obj->success = true;
+	return true;
+ * encodes and delivers the data
+function sendOutput($out){
+	global $json;
+	$output = $json->encode($out);
+	header("Content-Type: text/x-json");
+	echo $output;
Modified: trunk/mapbender/http/php/mod_metadataWrite.php
--- trunk/mapbender/http/php/mod_metadataWrite.php	2010-04-21 15:37:42 UTC (rev 5997)
+++ trunk/mapbender/http/php/mod_metadataWrite.php	2010-04-22 09:45:43 UTC (rev 5998)
@@ -22,5 +22,8 @@
 $resultTarget = $_SERVER["argv"][20];
 $searchURL = $_SERVER["argv"][21];
 $customCategories = $_SERVER["argv"][22];
-$metadata = new searchMetadata($userId, $searchId, $searchText, $registratingDepartments, $isoCategories, $inspireThemes, $timeBegin, $timeEnd, $regTimeBegin, $regTimeEnd, $maxResults, $searchBbox, $searchTypeBbox, $accessRestrictions, $languageCode, $searchEPSG, $searchResources, $searchPages, $outputFormat, $resultTarget, $searchURL,$customCategories);
+$hostName = $_SERVER["argv"][23];
+$orderBy = $_SERVER["argv"][24];
+$metadata = new searchMetadata($userId, $searchId, $searchText, $registratingDepartments, $isoCategories, $inspireThemes, $timeBegin, $timeEnd, $regTimeBegin, $regTimeEnd, $maxResults, $searchBbox, $searchTypeBbox, $accessRestrictions, $languageCode, $searchEPSG, $searchResources, $searchPages, $outputFormat, $resultTarget, $searchURL, $customCategories, $hostName, $orderBy);
Modified: trunk/mapbender/http/php/mod_updateWMS.php
--- trunk/mapbender/http/php/mod_updateWMS.php	2010-04-21 15:37:42 UTC (rev 5997)
+++ trunk/mapbender/http/php/mod_updateWMS.php	2010-04-22 09:45:43 UTC (rev 5998)
@@ -26,6 +26,11 @@
 $myWMS = $_POST["myWMS"];
 $myURL = $_POST["myURL"];
+$secParams = SID."&guiID=".$_REQUEST["guiID"]."&elementID=".$_REQUEST["elementID"];
+$self = $PHP_SELF."?".$secParams;
 <html>
 <head>
@@ -52,6 +57,11 @@
 	var wmsData = document.form1.selWMS.options[ind].value.split("###");
+	document.getElementById("metadatalink").href = "mod_layerMetadata.php?id="+wmsData[2];
+	document.getElementById("metadatatext").firstChild.nodeValue = "WMS-ID: "+wmsData[0];
+	//end ***
 </script>
 </head>
@@ -71,7 +81,8 @@
 	$v = array();
 	$t = array();
 	$c = 1;
-	$sql = "SELECT wms_id, wms_title, wms_getcapabilities, wms_upload_url  FROM wms ";
+	//$sql = "SELECT wms_id, wms_title, wms_getcapabilities, wms_upload_url  FROM wms ";
+	$sql = "SELECT wms.wms_id, wms.wms_title, wms.wms_getcapabilities, wms.wms_upload_url, layer.layer_id  FROM wms, layer ";
 	$sql .= "WHERE wms_id IN(";
 	for($i=0; $i<count($wms_id_own); $i++){
 		if($wms_id_own[$i] != ''){
@@ -82,16 +93,24 @@
 			$c++;
-	$sql .= ")";
+	//$sql .= ")";
+	//select has been adopted for showing metadata
+	$sql .= ") AND wms.wms_id=layer.fkey_wms_id and layer.layer_pos=0";
 	$sql .= " ORDER BY wms_title";
 	$cnt = 0;
 	echo "<select name='selWMS' size='15' onchange='sel()'>";
-		echo "<option value='".$row['wms_id']."###".$row['wms_upload_url']."'>".$row['wms_title']."</option>";
+		//echo "<option value='".$row['wms_id']."###".$row['wms_upload_url']."'>".$row['wms_title']."</option>";
+		echo "<option value='".$row['wms_id']."###".$row['wms_upload_url']."###".$row['layer_id']."'>".$row['wms_title']."</option>";
 		$cnt++;
 	echo "</select><br /><br />";
+	<!--Line for showing wms metadata-->
+	view wms metadata: <a id='metadatalink' href='' onclick="window.open(this.href,'Metadaten','width=500,height=600,left=100,top=200,scrollbars=yes ,dependent=yes'); return false" target="_blank"><span id="metadatatext">no WMS selected</span></a><br><br>
+<?php
 	echo "Link to the last uploaded Online Resource URL:<br><input type='text' size='120' name='capURL'><br />";
 	echo "<input type='hidden' name='myWMS' value=''><br>";
 	echo "Add the following REQUEST to the Online Resource URL to obtain the Capabilities document:<br>";
@@ -110,6 +129,7 @@
 	$mywms->createObjFromXML($myURL);
 	$mywms->optimizeWMS();
 	echo "<br />";
+	//$mywms->overwrite=false; //TODO:this handling is used if the information should not be overwritten in the mapbender database. The owner has to explicitly overwrite them in the metadata editor - like geoportal.rlp
 	$mywms->updateObjInDB($myWMS);
 	$mywms->displayWMS();
More information about the Mapbender_commits mailing list
