[Mapbender-commits] r6011 - trunk/mapbender/http/plugins
svn_mapbender at osgeo.org
Fri Apr 23 04:53:39 EDT 2010
Author: astrid_emde
Date: 2010-04-23 04:53:38 -0400 (Fri, 23 Apr 2010)
New Revision: 6011
trunk/mapbender/http/plugins/mb_handleStartUpWmsParams.php
only check if parameter are passed with url, check gui_layer properties
Modified: trunk/mapbender/http/plugins/mb_handleStartUpWmsParams.php
--- trunk/mapbender/http/plugins/mb_handleStartUpWmsParams.php 2010-04-23 07:56:12 UTC (rev 6010)
+++ trunk/mapbender/http/plugins/mb_handleStartUpWmsParams.php 2010-04-23 08:53:38 UTC (rev 6011)
@@ -70,103 +70,110 @@
// set queryability and visibility
Mapbender.events.init.register(function () {
- var currentVisibleLayerMatchTrue = false;
- var currentQueryLayerMatchTrue = false;
- var mapObject = Mapbender.modules[options.target[0]];
- var wmsArray = mapObject.wms;
+ if(apiVisibleLayers != '' || apiQueryLayers != '' ||
+ apiVisibleLayersRegExpr != '' || apiQueryLayersRegExpr != ''){
- for (var i in wmsArray) {
- var currentWms = wmsArray[i];
- for (var j in currentWms.objLayer) {
- var currentLayer = currentWms.objLayer[j];
- // parameter apiVisibleLayers
- for (var k in apiVisibleLayerArray) {
- var visibleLayer = apiVisibleLayerArray[k];
+ var currentVisibleLayerMatchTrue = false;
+ var currentQueryLayerMatchTrue = false;
+ var mapObject = Mapbender.modules[options.target[0]];
+ var wmsArray = mapObject.wms;
+ for (var i in wmsArray) {
+ var currentWms = wmsArray[i];
+ for (var j in currentWms.objLayer) {
+ var currentLayer = currentWms.objLayer[j];
- if (visibleLayer == currentLayer.layer_name) {
- currentLayer.gui_layer_visible = 1;
- checkForVisibleLayerArray.push(currentLayer.layer_name);
+ // parameter apiVisibleLayers
+ for (var k in apiVisibleLayerArray) {
+ var visibleLayer = apiVisibleLayerArray[k];
+ if (visibleLayer == currentLayer.layer_name && currentLayer.gui_layer_status == '1' &&
+ (currentLayer.gui_layer_selectable == 1 || currentLayer.gui_layer_visible == 1)
+ currentLayer.gui_layer_visible = 1;
+ checkForVisibleLayerArray.push(currentLayer.layer_name);
- // parameter apiQueryLayers
- for (var k in apiQueryLayerArray) {
- var queryLayer = apiQueryLayerArray[k];
- if (queryLayer == currentLayer.layer_name && currentLayer.gui_layer_queryable) {
- currentLayer.gui_layer_querylayer = 1;
- checkForQueryLayerArray.push(currentLayer.layer_name);
+ // parameter apiQueryLayers
+ for (var k in apiQueryLayerArray) {
+ var queryLayer = apiQueryLayerArray[k];
+ if (queryLayer == currentLayer.layer_name && currentLayer.gui_layer_queryable) {
+ currentLayer.gui_layer_querylayer = 1;
+ checkForQueryLayerArray.push(currentLayer.layer_name);
- // parameter apiVisibleLayersRegExpr
- if(apiVisibleLayersRegExpr !== "") {
- var pattern = new RegExp(apiVisibleLayersRegExpr);
- var currentVisibleLayerMatch = currentLayer.layer_name.match(pattern);
- if (currentVisibleLayerMatch && currentLayer.gui_layer_selectable) {
- currentVisibleLayerMatchTrue = true;
+ // parameter apiVisibleLayersRegExpr
+ if(apiVisibleLayersRegExpr !== "") {
+ var pattern = new RegExp(apiVisibleLayersRegExpr);
+ var currentVisibleLayerMatch = currentLayer.layer_name.match(pattern);
+ if (currentVisibleLayerMatch && currentLayer.gui_layer_status == '1' &&
+ currentVisibleLayerMatchTrue = true;
+ // parameter apiQueryLayersRegExpr
+ if (apiQueryLayersRegExpr !== "") {
+ var pattern = new RegExp(apiQueryLayersRegExpr);
+ var currentQueryLayerMatch = currentLayer.layer_name.match(pattern);
+ if (currentQueryLayerMatch && currentLayer.gui_layer_queryable) {
+ currentQueryLayerMatchTrue = true;
- // parameter apiQueryLayersRegExpr
- if (apiQueryLayersRegExpr !== "") {
- var pattern = new RegExp(apiQueryLayersRegExpr);
- var currentQueryLayerMatch = currentLayer.layer_name.match(pattern);
- if (currentQueryLayerMatch && currentLayer.gui_layer_queryable) {
- currentQueryLayerMatchTrue = true;
+ mb_restateLayers(options.target[0], currentWms.wms_id);
- mb_restateLayers(options.target[0], currentWms.wms_id);
- if(apiVisibleLayers !== "") {
- var visibleLayerNotFound = array_diff(apiVisibleLayerArray, checkForVisibleLayerArray);
- if(visibleLayerNotFound.length > 0) {
- var visibleLayerString = visibleLayerNotFound.join(",");
- var visibleLayerNotFoundMsg = "Visible layer " + visibleLayerString + " not found.";
- new Mapbender.Notice(visibleLayerNotFoundMsg);
- //alert(visibleLayerNotFoundMsg);
+ if(apiVisibleLayers !== "") {
+ var visibleLayerNotFound = array_diff(apiVisibleLayerArray, checkForVisibleLayerArray);
+ if(visibleLayerNotFound.length > 0) {
+ var visibleLayerString = visibleLayerNotFound.join(",");
+ var visibleLayerNotFoundMsg = "Visible layer " + visibleLayerString + " not found.";
+ new Mapbender.Notice(visibleLayerNotFoundMsg);
+ //alert(visibleLayerNotFoundMsg);
- if(apiQueryLayers !== "") {
- var queryLayerNotFound = array_diff(apiQueryLayerArray, checkForQueryLayerArray);
- if(queryLayerNotFound.length > 0) {
- var queryLayerString = queryLayerNotFound.join(",");
- var queryLayerNotFoundMsg = "Query layer " + queryLayerString + " not found.";
- new Mapbender.Notice(queryLayerNotFoundMsg);
- //alert(queryLayerNotFoundMsg);
+ if(apiQueryLayers !== "") {
+ var queryLayerNotFound = array_diff(apiQueryLayerArray, checkForQueryLayerArray);
+ if(queryLayerNotFound.length > 0) {
+ var queryLayerString = queryLayerNotFound.join(",");
+ var queryLayerNotFoundMsg = "Query layer " + queryLayerString + " not found.";
+ new Mapbender.Notice(queryLayerNotFoundMsg);
+ //alert(queryLayerNotFoundMsg);
- if (apiVisibleLayersRegExpr !== "") {
- if(currentVisibleLayerMatchTrue === false) {
- var visibleLayerNotFoundMsg = "No visible layer matches the given regular expression.";
+ if (apiVisibleLayersRegExpr !== "") {
+ if(currentVisibleLayerMatchTrue === false) {
+ var visibleLayerNotFoundMsg = "No visible layer matches the given regular expression.";
- if(currentQueryLayerMatchTrue === false) {
- var queryLayerNotFoundMsg = "No queryable layer matches the given regular expression.";
+ if(currentQueryLayerMatchTrue === false) {
+ var queryLayerNotFoundMsg = "No queryable layer matches the given regular expression.";
+ eventAfterMapRequest.trigger({
+ map: mapObject
- eventAfterMapRequest.trigger({
- map: mapObject
function array_diff(a1, a2) {
More information about the Mapbender_commits
