[Mapbender-commits] r6674 - trunk/mapbender/http/javascripts
svn_mapbender at osgeo.org
Mon Aug 2 09:54:36 EDT 2010
Author: christoph
Date: 2010-08-02 13:54:36 +0000 (Mon, 02 Aug 2010)
New Revision: 6674
trunk/mapbender/http/javascripts/map_obj.js
html 4.01 transitional compatibility
scale calculation
bug fix slippy map
Modified: trunk/mapbender/http/javascripts/map_obj.js
--- trunk/mapbender/http/javascripts/map_obj.js 2010-08-02 13:52:19 UTC (rev 6673)
+++ trunk/mapbender/http/javascripts/map_obj.js 2010-08-02 13:54:36 UTC (rev 6674)
@@ -36,7 +36,10 @@
var localizeMap = function(){
- $.post("../php/mod_map_messages.php", function(obj, status){
+ $.post("../php/mod_map_messages.php", {
+ "sessionName": Mapbender.sessionName,
+ "sessionId": Mapbender.sessionId
+ }, function(obj, status){
mapMsgObj = $.parseJSON(obj);
@@ -143,12 +146,12 @@
this.height = parseInt(h, 10);
if (this.frameName) {
- document.getElementById(this.frameName).style.width = this.width;
- document.getElementById(this.frameName).style.height = this.height;
+ document.getElementById(this.frameName).style.width = this.width + "px";
+ document.getElementById(this.frameName).style.height = this.height + "px";
var domElement = this.getDomElement();
- domElement.style.width = this.width;
- domElement.style.height = this.height;
+ domElement.style.width = this.width + "px";
+ domElement.style.height = this.height + "px";
this.calculateExtent(this.extent);
this.setMapRequest();
@@ -190,10 +193,10 @@
this.height = parseInt(height, 10);
//apply new height
this.events.dimensionsChanged.trigger({
width: this.width,
@@ -999,6 +1002,18 @@
return false;
+ var calculateDistanceGeographic = function (a, b) {
+ var lon_from = (a.x * Math.PI) / 180;
+ var lat_from = (a.y * Math.PI) / 180;
+ var lon_to = (b.x * Math.PI) / 180;
+ var lat_to = (b.y * Math.PI) / 180;
+ return Math.abs(6371229 * Math.acos(
+ Math.sin(lat_from) * Math.sin(lat_to) +
+ Math.cos(lat_from) * Math.cos(lat_to) *
+ Math.cos(lon_from - lon_to)
* calculation of the mapscale
@@ -1014,21 +1029,22 @@
return null;
if (this.epsg == "EPSG:4326") {
- // xl_length and yl_length refers to linear widths on horizontal and vertical axes
- var xl_length=(parseFloat(bbox[3]) - parseFloat(bbox[1]));
- var yl_length=(parseFloat(bbox[2]) - parseFloat(bbox[0]));
- // xa_length and ya_length refers to angular width on horizontal and vertical axes
- var xa_length=(xl_length*360)/(2*Math.PI*6378137);
- var ya_length=(xl_length*360)/(2*Math.PI*6378137);
- scale=((xl_length/this.getHeight())/mb_resolution);
+ var xtenty = calculateDistanceGeographic(
+ new Mapbender.Point(
+ this.extent.center.x,
+ this.extent.min.y
+ this.extent.max.y
+// console.log(xtenty);
else {
- xtenty = parseFloat(bbox[3]) - parseFloat(bbox[1]);
- scale = (xtenty / this.getHeight()) * (mb_resolution * 100);
+ var xtenty = parseFloat(bbox[3]) - parseFloat(bbox[1]);
+ scale = (xtenty / this.getHeight()) * (mb_resolution * 100);
return parseInt(Math.round(scale), 10);
@@ -1071,18 +1087,27 @@
this.repaintScale = function(x, y, scale){
if (x === null && y === null) {
- var arrayBBox = this.extent.toString().split(",");
- x = parseFloat(arrayBBox[0]) +
- ((parseFloat(arrayBBox[2]) - parseFloat(arrayBBox[0])) /
- 2);
- y = parseFloat(arrayBBox[1]) +
- ((parseFloat(arrayBBox[3]) - parseFloat(arrayBBox[1])) /
- 2);
+ x = this.extent.center.x;
+ y = this.extent.center.y;
- var minx = parseFloat(x) - (this.getWidth() / (mb_resolution * 100 * 2) * scale);
- var miny = parseFloat(y) - (this.getHeight() / (mb_resolution * 100 * 2) * scale);
- var maxx = parseFloat(x) + (this.getWidth() / (mb_resolution * 100 * 2) * scale);
- var maxy = parseFloat(y) + (this.getHeight() / (mb_resolution * 100 * 2) * scale);
+ if (this.epsg == "EPSG:4326") {
+ var minx = parseFloat(x);
+ var miny = this.extent.min.y;
+ var maxx = minx + 0.01;
+ var xtenty = scale * this.getHeight() / (mb_resolution * 100);
+ var maxy = miny + xtenty/6371229;
+ else {
+ var minx = parseFloat(x) - (this.getWidth() / (mb_resolution * 100 * 2) * scale);
+ var miny = parseFloat(y) - (this.getHeight() / (mb_resolution * 100 * 2) * scale);
+ var maxx = parseFloat(x) + (this.getWidth() / (mb_resolution * 100 * 2) * scale);
+ var maxy = parseFloat(y) + (this.getHeight() / (mb_resolution * 100 * 2) * scale);
this.repaint(new Point(minx, miny), new Point(maxx, maxy));
@@ -1090,6 +1115,7 @@
if (typeof min !== "undefined" && typeof max !== "undefined") {
this.extent = this.calculateExtent(new Extent(min, max));
+// console.log(this.extent);
@@ -1262,11 +1288,8 @@
- var deactivatePreviousMapImg = function (domNode, index) {
- var tmpId = domNode.id;
- var pattern = /_request_([0-9]+)_/;
- var newId = tmpId.replace(pattern, "_request_" + (index-1) + "_");
- $("#" + newId).css({
+ var deactivatePreviousMapImg = function (selector) {
+ $(selector).css({
visibility: "hidden"
@@ -1295,6 +1318,15 @@
+ var hideOutOfScaleWms = function (previousWmsIndices, currentWmsIndices, index) {
+ $(previousWmsIndices).each(function () {
+ if ($.inArray(parseInt(this, 10), currentWmsIndices) === -1) {
+ var selector = "#" + that.elementName + "_request_" + (index-1) + "_map_" + parseInt(this, 10);
+ deactivatePreviousMapImg(selector);
var animateMaps = function (index) {
@@ -1317,25 +1349,59 @@
if (newLeft === 0 && newTop === 0 && newHeight === that.getHeight() && newWidth === that.getWidth()) {
return;
+ // check which WMS need to be deactivated because they are out of scale
+ // indices of wms in old map
+ var prevMapImg = $("#" + that.elementName + "_request_" + (index-1) + " div img");
+ var previousWmsIndices = [];
+ prevMapImg.each(function () {
+ var id = parseInt(this.id.split("_").pop(), 10);
+ previousWmsIndices.push(id);
+ // indices of wms in new map
+ var currentMapImg = $("#" + that.elementName + "_request_" + index + " div img");
+ var currentWmsIndices = [];
+ currentMapImg.each(function () {
+ currentWmsIndices.push(id);
// show previous maps for animation
$("#" + that.elementName + "_request_" + (index - 1)).show();
// hide new images until complete, but perform pan animation
- $("#" + that.elementName + "_request_" + index + " div img").css({
- visibility: "hidden"
- }).load(function () {
- this.style.visibility = "visible";
- $(this).data("loaded", true);
- if ($(this).data("loaded") && (wasPanned || $(this).data("animationFinished"))) {
- deactivatePreviousMapImg(this, index);
+ if (currentMapImg.size() === 0) {
+ hideOutOfScaleWms(previousWmsIndices, currentWmsIndices, index);
+ else {
+ currentMapImg.css({
+ visibility: "hidden"
+ }).load(function () {
+ this.style.visibility = "visible";
+ $(this).data("loaded", true);
+ if ($(this).data("loaded") && (wasPanned || $(this).data("animationFinished"))) {
+ var tmpId = this.id;
+ var pattern = /_request_([0-9]+)_/;
+ var selector = "#" + tmpId.replace(pattern, "_request_" + (index-1) + "_");
if (wasPanned) {
return;
@@ -1345,7 +1411,7 @@
// animate new images (zoom)
if (newWidth !== that.getWidth() || newHeight !== that.getHeight()) {
- var currentMapImg = $("#" + that.elementName + "_request_" + index + " div img");
currentMapImg.css({
width: newWidth,
height: newHeight
@@ -1354,9 +1420,15 @@
width: that.getWidth() + "px",
height: that.getHeight() + "px"
}, "normal", "linear", function () {
$(this).data("animationFinished", true);
if ($(this).data("loaded") && ($(this).data("animationFinished"))) {
@@ -1377,7 +1449,12 @@
$(this).children().children().each(function () {
if ($(this).data("loaded") && $(this).data("animationFinished")) {
@@ -1662,7 +1739,7 @@
this.width = this.getWidth();
if (this.height) {
else {
this.height = this.getHeight();
More information about the Mapbender_commits
