[Mapbender-commits] r6695 - trunk/mapbender/http/php
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Thu Aug 5 06:26:11 EDT 2010
Author: christoph
Date: 2010-08-05 10:26:11 +0000 (Thu, 05 Aug 2010)
New Revision: 6695
   trunk/mapbender/http/php/mod_meetingPoint.php
removed jQuery, now used from parent
new order of elements (textarea first, then button)
more sophisticated ux
Modified: trunk/mapbender/http/php/mod_meetingPoint.php
--- trunk/mapbender/http/php/mod_meetingPoint.php	2010-08-05 10:24:54 UTC (rev 6694)
+++ trunk/mapbender/http/php/mod_meetingPoint.php	2010-08-05 10:26:11 UTC (rev 6695)
@@ -24,17 +24,20 @@
 <html>
 <head>
 <title>meetingPoint</title>
+<meta http-equiv="Content-Type" content="text/html; charset=<?php echo CHARSET;?>">
 <?php
 include '../include/dyn_css.php';
-<script type="text/javascript" src="../extensions/jquery-1.3.2.min.js"></script>
-<script language='JavaScript'>
+<script type="text/javascript">
 <?php
 include('../include/dyn_js.php');
 echo "var mod_meetingPoint_target = '" . $_REQUEST["e_target"] . "';";
 echo "var meetingPoint_write_to = 'meetingPoint';";
+window.alert = parent.alert;
 try{
 	if (meetingPoint_export_subject){}
@@ -134,23 +137,31 @@
 	parent.mb_button[ind].stop = new Function ("mod_meetingPoint_disable()");
+var mod_meetingPoint_getMousePosition = function (e) {
+	var mapObject = parent.getMapObjByName(mod_meetingPoint_target);
+	var clickPos = mapObject.getMousePosition(e);
+	mod_meetingPointRealPoint = mapObject.convertPixelToReal(clickPos);
+	mod_meetingPoint_write(mod_meetingPointRealPoint.x, mod_meetingPointRealPoint.y);
+	mod_meetingPoint_draw();
+	parent.mb_disableThisButton(mod_meetingPoint_button);
 function mod_meetingPoint_run(){
+	if (document.forms[0].mytext.value === "") {
+		alert("<?php echo _mb("Please define a text!") ?>");
+		return;
 	if (mapObject) {
-		mapObject.getDomElement().ownerDocument.onclick = function (e) {
-			var clickPos = mapObject.getMousePosition(e);
-			mod_meetingPointRealPoint = mapObject.convertPixelToReal(clickPos);
-			mod_meetingPoint_write(mod_meetingPointRealPoint.x, mod_meetingPointRealPoint.y);
-			mod_meetingPoint_draw();
-			parent.mb_disableThisButton(mod_meetingPoint_button);
+		parent.$(mapObject.getDomElement()).bind("click", mod_meetingPoint_getMousePosition);
 function mod_meetingPoint_disable(){
 	if (mapObject) {
-		mapObject.getDomElement().ownerDocument.onclick = null;
+		parent.$(mapObject.getDomElement()).unbind("click", mod_meetingPoint_getMousePosition);
@@ -162,7 +173,7 @@
 function mod_meetingPoint_hide(){
 	var map_el = mapObject.getDomElement();
-	$(parent.document.getElementById(mapObject.elementName + "_meetingPoint_permanent")).empty();
+	parent.$(parent.document.getElementById(mapObject.elementName + "_meetingPoint_permanent")).empty();
@@ -177,9 +188,11 @@
 			var meetingPointClickPos = mapObject.convertRealToPixel(mod_meetingPointRealPoint);
 			var tagSource = "";
-			tagSource += "<div style='visibility:visible;z-index:13;position:absolute;left:"+(meetingPointClickPos.x- Math.round(0.5*meetingPoint_width))+"px;top:"+(meetingPointClickPos.y-Math.round(0.5*meetingPoint_height))+"px'>";
+			tagSource += "<div style='visibility:visible;z-index:105;position:absolute;left:"+
+				(meetingPointClickPos.x- Math.round(0.5*meetingPoint_width))+"px;top:"+
+				(meetingPointClickPos.y-Math.round(0.5*meetingPoint_height))+"px'>";
 			tagSource += "<img src='"+meetingPoint_icon+"' />";
-			tagSource += "<span style='"+meetingPoint_style+"'>"+document.forms[0].mytext.value+"</span>";
+			tagSource += "<div class='ui-widget-content ui-corner-all' style='padding:3px'><span style='white-space:nowrap;'>"+document.forms[0].mytext.value.replace("\n", "<br>")+"</span></div>";
 			tagSource += "</div>";
@@ -190,12 +203,13 @@
 				$div.css({
 					position: "absolute",
 					top: "0px",
-					left: "0px",
-					zIndex: 20
+					left: "0px"
-				$(map_el).append($div);
+				parent.$(map_el).append($div);
+				parent.mb_registerPanSubElement(mapObject.elementName + "_meetingPoint_permanent")
+				console.log(mapObject.elementName + "_meetingPoint_permanent");
-			$(parent.document.getElementById(mapObject.elementName + "_meetingPoint_permanent")).html(tagSource);
+			parent.$(parent.document.getElementById(mapObject.elementName + "_meetingPoint_permanent")).html(tagSource);
@@ -206,7 +220,7 @@
 	var stringLength = document.forms[0].mytext.value.length;
 	if (stringLength > meetingPoint_max_characters) {
 		document.forms[0].mytext.value = document.forms[0].mytext.value.slice(0, meetingPoint_max_characters) ;
-		alert("meetingPoint_max_characters is set to " + meetingPoint_max_characters);
+		alert("<?php echo _mb("Input too long. Maximum of allowed characters is"); ?> " + meetingPoint_max_characters);
@@ -228,15 +242,16 @@
 function validate(){
 	var mycheck = true;
-	var checkObj= document.forms[0].mytext.value;
-	if(checkObj == '') {
+	var checkObj= document.forms[0].mytext;
+	if(checkObj.value == '') {
 		alert ("<?php echo _mb("Please define a text!") ?>");
 		checkObj.focus();
 		mycheck=false;
+		return false;
-	var checkObj= document.forms[0].x.value;
+	var checkObj= document.forms[0].x;
 		alert (meetingPoint_please_click);
 		mycheck = false;
@@ -274,7 +289,15 @@
 			createEmail(my_meetingPoint,meetingPoint_export_subject);
 		else {
-			prompt(meetingPoint_export_subject,my_meetingPoint);
+			var div = parent.$("<div/>").attr("title", "Treffpunkt").text(meetingPoint_export_subject);
+			var textarea = parent.$("<textarea />").attr({
+				"rows": 5,
+				"cols": 30
+			}).text(my_meetingPoint);
+			div.append("<br /><br />");
+			div.append(textarea);
+			div.dialog();
+		//			prompt(meetingPoint_export_subject,my_meetingPoint);
@@ -314,8 +337,6 @@
 <form action="" >
-<img  id='my_getCoords' name='my_getCoords' onclick="mod_meetingPoint_run()" onmouseover ="parent.mb_regButton_frame('init_mod_meetingPoint','meetingPoint',null)"  title="Treffpunkt setzen"  src = '../img/button_digitize/point_off.png'>
-<br>
 <input class='strinput' type="hidden" name='myurl' value='<?php  echo LOGIN;  ?>'>
 <input class='strinput' type="hidden" name='mygui' value='<?php  echo Mapbender::session()->get("mb_user_gui");  ?>'>
@@ -323,10 +344,11 @@
 <input class='strinput' type="hidden" name='myuser' value='<?php  echo Mapbender::session()->get("mb_user_name");  ?>'>
 <input class='strinput' type="hidden" name='mypw' value='<?php  echo Mapbender::session()->get("mb_user_password");  ?>'>
-<br>
 <!--<input class='strinput' type="textarea" size=2 name='mytext' value='' "maxlength=70" title="max. 70 Zeichen">-->
 <textarea class='strinput' rows="3" name='mytext' id='mytext' onmouseover='checkMaxCharacters()' title='' onkeyup='checkMaxCharacters()'></textarea>
-<br>
+<br><br>
+<img  id='my_getCoords' name='my_getCoords' onclick="mod_meetingPoint_run()" onmouseover ="parent.mb_regButton_frame('init_mod_meetingPoint','meetingPoint',null)"  title="Treffpunkt setzen"  src = '../img/button_digitize/point_off.png'>
+<br><br>
 <input class="okbutton" name="Send"   type="button" value="ok" onclick="validate();">
 <input class="ibutton" type="button" value="<?php echo _mb("cancel") ?>" onClick="emptyfields();">
 <br>
More information about the Mapbender_commits mailing list
